I developped an application on orange pi pc using qt.
I installed qtcreator to begin with.
Afterwards I had to install some additional packages.
CLI compiling using qmake was possible.
There's this thing about qt version 4 or 5...
I'll install qt again on my 2E some time soon.
Thanks, i will try installing qt creator on another sd to make a test. I didn't know it would be possible to install the editor.
OK, I reinstalled it on the 2E. (apt-get install)
qt4-qmake
qt4-default
libqt4-designer
qtcreator
libqtcore4 (I'm not really sure about this one)
in qtcreator/options/build&run  I defined under compilers ->  "GCC"
I need qt5.
Unfortunately qt5-default does not install due to problem with Mali lib. I will try to compile them from source. Thanks anyway.
