Hello everybody,
the images from armbian for my Orange Pi 3 work very fine and stable.
Thank you for that.
I came to armbian by links form orangepi.org.
When I tried to get an Android image from there I got
an Xutuntu image. (https://drive.google.com/drive/folders/1Urh9-yljq9Mrrafp7ZWRVf_s_AdjUoTQ)
Do you know where to get an Android for my Orange Pi 3?
Thanks if you have information for me about that.
You can download board specific images from :
http://www.orangepi.org/downloadresources/
Also if you only need the Android Image, you can download the official orange pi build from :
https://drive.google.com/drive/mobile/folders/1Urh9-yljq9Mrrafp7ZWRVf_s_AdjUoTQ?usp=drive_open
EDIT:
Are sure you used the correct file?
The image provided by the link you mentioned, is 383 Mb, and no other orange pi's official linux image has a size equal to that
So go double check the file you used/extracted
On 3/30/2020 at 2:11 PM, rauscharm said:
Hello everybody,
Thank you for that.
Also, note that OrangePi Android images cannot be flashed to microsd cards with a simple Etcher or WinImager (or whatever it was called). You need to use PhoenixCard v4.1.2 I'll type that out again; 4.1.2. I know, google tells you that the latest version of PhoenixCard is 3.1.x, but you can find the 4.1.2 from orangepi's site somewhere, I forgot exactly where. At least for me, the 3.1.x did NOT work at all. Once I found the v4.1.2 everything worked.
Edited by Anna Vahtera
typo
thanks for your reply.
I found 2 PhoenixCard V4.1.2. When open them, I can see buttons but they are blank.
It's on Windows 10. I also tried it on a Windows 10 in a virtual machine both had the same appearance with most of nothing. :-)
How can you use it?
P.S. the Xubuntu that started was from emmc, as I think the pi did not boot the "Andriod Card" so first I thought I burned the wrong image.
I got the PhoenixCard v4.1.2 straight from OrangePi.org, from their download folders, here: https://drive.google.com/drive/folders/1Vh2H14q9GDyfTdepVOIfAlrVjVZ_FM2A
I'm using Windows 10 too and I didn't have any problems with it.  I don't know if it needs the latest dotNET or no, but might be worth to see if both 3.x and 4.x are of the latest version.
Other than that, I can't really help since it's working on my computer without problems.
EDIT:
I can install the Android 7 on Orange Pi 3 but there are no google store, and everytime i try to run Netflix/Youtube or other program, it said
