I've installed Armbian on my brand new Odroid N2. I realise it still is WIP, but almost everything works great. There is just one issue, which prevents me from setting it up the way I want.
I use my eMMC card to boot the system. I've also added a larger A1 SD card for application data. However, after a reboot the SD card isn't recognized. There isn't even a message about it in dmesg log. But when, after booting, I remove the SD card and insert it, all of the sudden it's detected and mounted.
Does anyone know how I kan make this happen at boot, so I don't need to physically access the device in order to use it after a reboot?
