Pizzanova Posted March 31, 2020 Posted March 31, 2020 Hello. I have successfully booted Armbian_20.02.0-rc1.035_Aw-h6-tv_buster_current_5.5.0-rc6_desktop_20200204 on to R TV Box X10 Plus and have docker and Home assistant running at about 25% load. I would like to move it from SD card to emmc but when I issue the nand-sata-install command in a terminal window, it reports command not found and lists special scripts for many setups, but not the H6. I also cannot access the usb3 port, which I think is a device tree issue, I believe the proper dtb needs to be loaded but I don't know where to find it or how to install it.
lapuglisi Posted July 28, 2020 Posted July 28, 2020 Pizzanova, look for the dtb file in /boot/dtb/allwinner. You will have to convert it to DTS (which is the editable device tree source) with dtc, using: dtc -I dtb -O dts -o sun50i-h6-orangepi-3.dts sun50i-h6-orangepi-3.dtb Then, edit the sun50i-h6-orangepi-3.dts and change it according to what you want to achieve.
