shigeki Posted April 1, 2020 Posted April 1, 2020 Armbianmonitor: http://ix.io/2ggr Hi again. After 2 years i want to try configure CanBus on BananaPi and still nothing. I'm continuing my previous post What i do: 1) Paths dtb with this instruction : 2) Load kernel modules: # lsmod | grep can can_raw 20480 1 can_bcm 24576 0 can 20480 2 can_raw,can_bcm sun4i_can 16384 0 can_dev 20480 1 sun4i_can 3) Spawn can0 interface # ip link set can0 type can bitrate 500000 restart-ms 100 triple-sampling on loopback on # ip link set up can0 4) Play with candump / cansend On loopback my messages show in candump, but on arduino receiver still nothing My test env: Two arduino uno with mcp2515 + tja1050 - one as sender other as receiver BananaPi 4.19.62-sunxi and tja1051 transceiver Bitrate on all boards set to 500k Maybe this may be helpful: # ip -det link show can0 4: can0: <NOARP,UP,LOWER_UP,ECHO> mtu 16 qdisc pfifo_fast state UP mode DEFAULT group default qlen 10 link/can promiscuity 0 minmtu 0 maxmtu 0 can <LOOPBACK,TRIPLE-SAMPLING> state ERROR-WARNING (berr-counter tx 0 rx 129) restart-ms 100 bitrate 500000 sample-point 0.875 tq 125 prop-seg 6 phase-seg1 7 phase-seg2 2 sjw 1 sun4i_can: tseg1 1..16 tseg2 1..8 sjw 1..4 brp 1..64 brp-inc 1 clock 24000000numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535 # dmesg | grep can [ 8.090861] sun4i_can 1c2bc00.can: device registered (base=(ptrval), irq=53) [ 8.120057] can: controller area network core (rev 20170425 abi 9) [ 8.128499] can: broadcast manager protocol (rev 20170425 t) [ 8.132629] can: raw protocol (rev 20170425) [ 3502.151374] sun4i_can 1c2bc00.can can0: bus-off [ 3502.255288] IPv6: ADDRCONF(NETDEV_CHANGE): can0: link becomes ready [ 3507.633774] sun4i_can 1c2bc00.can can0: bus-off [ 3507.735553] IPv6: ADDRCONF(NETDEV_CHANGE): can0: link becomes ready [ 3509.316187] sun4i_can 1c2bc00.can can0: bus-off [ 3509.419665] IPv6: ADDRCONF(NETDEV_CHANGE): can0: link becomes ready [ 3510.275698] sun4i_can 1c2bc00.can can0: bus-off [ 3510.388158] IPv6: ADDRCONF(NETDEV_CHANGE): can0: link becomes ready [ 3518.457783] sun4i_can 1c2bc00.can can0: bus-off [ 3518.560252] IPv6: ADDRCONF(NETDEV_CHANGE): can0: link becomes ready [ 3520.323530] sun4i_can 1c2bc00.can can0: bus-off [ 3520.710972] IPv6: ADDRCONF(NETDEV_CHANGE): can0: link becomes ready [ 3522.219241] sun4i_can 1c2bc00.can can0: bus-off [ 3522.320498] IPv6: ADDRCONF(NETDEV_CHANGE): can0: link becomes ready [ 3523.602391] sun4i_can 1c2bc00.can can0: bus-off [ 3523.704584] IPv6: ADDRCONF(NETDEV_CHANGE): can0: link becomes ready
shigeki Posted April 4, 2020 Author Posted April 4, 2020 So, i finally manege this to work. Tested on newest kernel : Linux bananapi 5.4.26-sunxi #20.02.5 SMP Thu Mar 19 22:23:40 CET 2020 armv7l GNU/Linux First, you need to patch dtb : # cd /boot/dtb-5.4.26-sunxi # diff sun7i-a20-bananapi.dts sun7i-a20-bananapi.dts.bak 710c710,716 < can0_pins_a: can0@0 { --- > can-pa-pins { > pins = "PA16\0PA17"; > function = "can"; > phandle = < 0x63 >; > }; > > can-ph-pins { 713d718 < linux,phandle = < 0x64 >; 1446,1447c1451 < status = "okay"; < linux,phandle = < 0xb0 >; --- > status = "disabled"; 1449,1450d1452 < pinctrl-names = "default"; < pinctrl-0 = <&can0_pins_a>; 1862c1864,1865 < can0_pins_a = "/soc/pinctrl@1c20800/can0@0"; --- > can_pa_pins = "/soc/pinctrl@1c20800/can-pa-pins"; > can_ph_pins = "/soc/pinctrl@1c20800/can-ph-pins"; And in my test environment (two Arduino with mcp2515 CAN Module receiver and sender ) and bananapi i had to set baud rate 125K on banana pi and 250K on Arduino sender/receiver.
Hans Heukenkamp Posted May 27, 2020 Posted May 27, 2020 On 4/4/2020 at 7:38 PM, shigeki said: So, i finally manege this to work. Tested on newest kernel : Linux bananapi 5.4.26-sunxi #20.02.5 SMP Thu Mar 19 22:23:40 CET 2020 armv7l GNU/Linux First, you need to patch dtb : # cd /boot/dtb-5.4.26-sunxi # diff sun7i-a20-bananapi.dts sun7i-a20-bananapi.dts.bak 710c710,716 < can0_pins_a: can0@0 { --- > can-pa-pins { > pins = "PA16\0PA17"; > function = "can"; > phandle = < 0x63 >; > }; > > can-ph-pins { 713d718 < linux,phandle = < 0x64 >; 1446,1447c1451 < status = "okay"; < linux,phandle = < 0xb0 >; --- > status = "disabled"; 1449,1450d1452 < pinctrl-names = "default"; < pinctrl-0 = <&can0_pins_a>; 1862c1864,1865 < can0_pins_a = "/soc/pinctrl@1c20800/can0@0"; --- > can_pa_pins = "/soc/pinctrl@1c20800/can-pa-pins"; > can_ph_pins = "/soc/pinctrl@1c20800/can-ph-pins"; And in my test environment (two Arduino with mcp2515 CAN Module receiver and sender ) and bananapi i had to set baud rate 125K on banana pi and 250K on Arduino sender/receiver. Thank you! This is helpful.
wollik Posted May 27, 2020 Posted May 27, 2020 Hi Hans, what is the difference compared to the previous entry from shigeki ?
Hans Heukenkamp Posted July 17, 2020 Posted July 17, 2020 @wollik: Sorry for the delay. Shikegis changes pointed me in the right direction. I wanted to express that. CAN is indeed working with the current stable Armbian version on BananaPi M1: root@bananapi:~/dtb# cat /etc/armbian-release # PLEASE DO NOT EDIT THIS FILE BOARD=bananapi BOARD_NAME="Banana Pi" BOARDFAMILY=sun7i BUILD_REPOSITORY_URL=https://github.com/armbian/build BUILD_REPOSITORY_COMMIT=eb9dad92 DISTRIBUTION_CODENAME=buster DISTRIBUTION_STATUS=supported VERSION=20.05.2 LINUXFAMILY=sunxi BRANCH=current ARCH=arm IMAGE_TYPE=stable BOARD_TYPE=conf INITRD_ARCH=arm KERNEL_IMAGE_TYPE=Image I have just changed the pins in the dtb overlay file, which looks like that now: root@bananapi:~/dtb# cat sun7i-a20-can.dts /dts-v1/; / { compatible = "allwinner,sun7i-a20"; fragment@0 { target = < 0xffffffff >; __overlay__ { pinctrl-names = "default"; pinctrl-0 = < 0xffffffff >; status = "okay"; }; }; __fixups__ { can0 = "/fragment@0:target:0"; can_ph_pins = "/fragment@0/__overlay__:pinctrl-0:0"; }; }; I have added this overlay as user overlay with armbian-add-overlay sun7i-a20-can.dts and rebooted. As my hardware requires a 500 kBit setting, I use this as setup: modprobe can_raw ip link set can0 type can bitrate 500000 triple-sampling on ifconfig can0 up Btw. dynamic loading of the overlay at runtime works as well.
wollik Posted July 22, 2020 Posted July 22, 2020 Hi Hans, how did you activate/bind the overlay ? I get this eror: sudo armbian-add-overlay sun7i-a20-can.dts Error: dtc does not support compiling overlays Regards Wolfgang
Hans Heukenkamp Posted July 23, 2020 Posted July 23, 2020 18 hours ago, wollik said: Hi Hans, how did you activate/bind the overlay ? I get this eror: sudo armbian-add-overlay sun7i-a20-can.dts Error: dtc does not support compiling overlays Regards Wolfgang The dtc on my Bananapi did not complain about overlays. This is the version installed on my side: root@bananapi:~# dtc --version Version: DTC 1.4.7 Just try by hand to find out, what is going on: root@bananapi:~/dtb# dtc -I dts -O dtb -o sun7i-a20-can.dtbo sun7i-a20-can.dts
Hans Heukenkamp Posted July 23, 2020 Posted July 23, 2020 If you do not succeed compiling the overlay directly on the BananaPi M1, you may do it anywhere else, if you have a working dtc there. Any Linux box with a dtc installed will do.
wollik Posted July 24, 2020 Posted July 24, 2020 Hi Hans, I running an old Armbian version on my M1 that shows this older dtc version: pi@hnet-fhem-203:~$ dtc --version Version: DTC 1.4.2 My other BPI's (R1's) are upgradet to the latest buster version, where the CAN is enabled. At the moment I can't upgrade my M1 to the latest version. I have to migrate the apps first, so I want to get the CAN working on my M1 with the informations patches and workarounds I found on the internet. When I try to run it manualy like you suggested in your last message, I got this syntax error: pi@hnet-fhem-203:/boot/dtb$ dtc -I dts -O dtb -o sun7i-a20-can.dtbo sun7i-a20-can.dts Error: sun7i-a20-can.dts:2.1-2 syntax error FATAL ERROR: Unable to parse input tree pi@hnet-fhem-203:/boot/dtb$ ls -l *can* -rw-r--r-- 1 root root 356 Jul 22 21:40 sun7i-a20-can.dts Like I said, on my M1 are runing applications so I don't trust to bring the dts version 1.4.7 from my R1 to the M1 and try to run it , not knowing what sideeffects that will cause bacause of the different Armbian releases. There is no man entyr for dts, please can you help ? Regards WolliK
JoachimJF Posted July 25, 2020 Posted July 25, 2020 On 7/17/2020 at 11:24 AM, Hans Heukenkamp said: @wollik: Sorry for the delay. Shikegis changes pointed me in the right direction. I wanted to express that. CAN is indeed working with the current stable Armbian version on BananaPi M1: root@bananapi:~/dtb# cat /etc/armbian-release # PLEASE DO NOT EDIT THIS FILE BOARD=bananapi BOARD_NAME="Banana Pi" BOARDFAMILY=sun7i BUILD_REPOSITORY_URL=https://github.com/armbian/build BUILD_REPOSITORY_COMMIT=eb9dad92 DISTRIBUTION_CODENAME=buster DISTRIBUTION_STATUS=supported VERSION=20.05.2 LINUXFAMILY=sunxi BRANCH=current ARCH=arm IMAGE_TYPE=stable BOARD_TYPE=conf INITRD_ARCH=arm KERNEL_IMAGE_TYPE=Image I have just changed the pins in the dtb overlay file, which looks like that now: root@bananapi:~/dtb# cat sun7i-a20-can.dts /dts-v1/; / { compatible = "allwinner,sun7i-a20"; fragment@0 { target = < 0xffffffff >; __overlay__ { pinctrl-names = "default"; pinctrl-0 = < 0xffffffff >; status = "okay"; }; }; __fixups__ { can0 = "/fragment@0:target:0"; can_ph_pins = "/fragment@0/__overlay__:pinctrl-0:0"; }; }; I have added this overlay as user overlay with armbian-add-overlay sun7i-a20-can.dts and rebooted. As my hardware requires a 500 kBit setting, I use this as setup: modprobe can_raw ip link set can0 type can bitrate 500000 triple-sampling on ifconfig can0 up Btw. dynamic loading of the overlay at runtime works as well. Hello, I am not able to reproduce this. apt update and apt upgrade cat /etc/armbian-release: VERSION=20.05.2 sudo armbian-add-overlay sun7i-a20-can.dts works: Compiling the overlay Copying the compiled overlay file to /boot/overlay-user/ Reboot is required to apply the changes Reboot, but no can0 interface with sudo ifconfig -a jjf@bpi2:~$ dmesg | grep can Joachim
Hans Heukenkamp Posted July 28, 2020 Posted July 28, 2020 (edited) On 7/24/2020 at 10:22 AM, wollik said: Hi Hans, I running an old Armbian version on my M1 that shows this older dtc version: pi@hnet-fhem-203:~$ dtc --version Version: DTC 1.4.2 My other BPI's (R1's) are upgradet to the latest buster version, where the CAN is enabled. At the moment I can't upgrade my M1 to the latest version. I have to migrate the apps first, so I want to get the CAN working on my M1 with the informations patches and workarounds I found on the internet. When I try to run it manualy like you suggested in your last message, I got this syntax error: pi@hnet-fhem-203:/boot/dtb$ dtc -I dts -O dtb -o sun7i-a20-can.dtbo sun7i-a20-can.dts Error: sun7i-a20-can.dts:2.1-2 syntax error FATAL ERROR: Unable to parse input tree pi@hnet-fhem-203:/boot/dtb$ ls -l *can* -rw-r--r-- 1 root root 356 Jul 22 21:40 sun7i-a20-can.dts Like I said, on my M1 are runing applications so I don't trust to bring the dts version 1.4.7 from my R1 to the M1 and try to run it , not knowing what sideeffects that will cause bacause of the different Armbian releases. There is no man entyr for dts, please can you help ? Regards WolliK It looks like you would need to modify the actual DTB of your Armbian version on the M1. I suspect the overlay code cited here will not work with your Armbian version. It is a hint that the DTC compiler refuses to accept the dts file. You may want to check the CAN overlay that comes with exactly the Armbian version you run on your M1. That is certainly the best way to start. Edited July 28, 2020 by Hans Heukenkamp typo
Hans Heukenkamp Posted July 28, 2020 Posted July 28, 2020 On 7/25/2020 at 4:53 PM, JoachimJF said: Hello, I am not able to reproduce this. apt update and apt upgrade cat /etc/armbian-release: VERSION=20.05.2 sudo armbian-add-overlay sun7i-a20-can.dts works: Compiling the overlay Copying the compiled overlay file to /boot/overlay-user/ Reboot is required to apply the changes Reboot, but no can0 interface with sudo ifconfig -a jjf@bpi2:~$ dmesg | grep can Joachim Do you use a BananaPi M1? The prompt indicates otherwise.
