I posted here since this is more a generic question related to initrd than specific to board
My scenario is this:
I modified my ARMBIAN uInitrd ( unpacked and repacked ) and added a driver I needed , in particular driver for recognizing internal nand.
Of course in the init script I added insmod aml_nftl_dev.ko
The process was successfull and infact now i can see the internal nand
lsblk
NAME        MAJ:MIN RM  SIZE RO TYPE MOUNTPOINT
mmcblk0     179:0    0  980M  0 disk
|-mmcblk0p1 179:1    0  128M  0 part /boot
`-mmcblk0p2 179:2    0  848M  0 part /
cache       250:0    0  512M  0 disk
logo        250:1    0   32M  0 disk
recovery    250:2    0   32M  0 disk
misc        250:3    0   32M  0 disk
boot        250:4    0   32M  0 disk
system      250:5    0    1G  0 disk
data        250:6    0  5.4G  0 disk
I can give for sure that the module is loaded by init because I HAVEN'T at all this module under /lib/modules, so for sure it is loaded by init
lsmod
aml_nftl_dev           66089  0
Now comes the problem: when i try to install the whole thing in internal nand and let it boot by internal nand (install.sh) the process goes straight to the end.
When I reboot thought the kernel hangs because is not found the correct /dev/root
QA5:B;SVN:B72;POC:3FF;STS:0;BOOT:0;INIT:0;READ:0;CHECK:0;PASS:0;
no sdio debug board detected!Uj
BT : 16:03:56 Feb 18 2016
PMU:NONE
##### VDDEE voltage = 0x044c1100
CPU clock is 792MHz
All ddr mode test start...
DDR mode: 32 bit mode (auto)
DDR size: 512MB (auto)
DDR check: Pass!
DDR clock: 636MHz with 2T mode
DDR pll bypass: Disabled
DDR init use : 18177 us
HHH
ucl decompress...pass
0x12345678
Boot from internal device 1st NAND
TE : 217970
System Started
U-boot-00000-g621ad54-dirty(m8b_m201_v1@) (Feb 18 2016 - 16:03:46)
clr h-ram
DRAM:  512 MiB
relocation Offset is: 0feb8000
show partition table:
part: 0, name :       logo, size : 2000000
part: 1, name :   recovery, size : 2000000
part: 2, name :       misc, size : 2000000
part: 3, name :       boot, size : 2000000
part: 4, name :     system, size : 40000000
part: 5, name :      cache, size : 20000000
part: 6, name :       data, size : end
aml_card_type=0x100
MMC:   [mmc_register] add mmc dev_num=0, port=1, if_type=6
[mmc_register] add mmc dev_num=1, port=2, if_type=6
SDIO Port B: 0, SDIO Port C: 1
power init
out reg=c110804c,value=dfffffff
IR init done!
register usb cfg[0][1] = 1ff67ba4
register usb cfg[2][0] = 1ff6ab40
NAND:  NAND BOOT: boot_device_flag 1
Nand PHY driver Version: 2.01.001.0004 (c) 2013 Amlogic Inc.
amlnf_phy_init : amlnf init flag 0
NAND device id: ad de 14 a7 42 4a ad de
detect NAND device: E revision 1Ynm NAND 8GiB H27UCG8T2E
nand chip ce mask 1
AML_NAND_NEW_OOB : new oob
bus_cycle=6, bus_timing=8,system=3.9ns,flash->T_REA =16,flash->T_RHOH=15
hynix nand get default reg value at blk:7, page:1792
NAND CKECK  : arg nbbt: arg_valid= 1, valid_blk_addr = 10, valid_page_addr = 0
NAND CKECK  : arg ncnf: arg_valid= 1, valid_blk_addr = 5, valid_page_addr = 0
NAND CKECK  : arg nkey: arg_valid= 1, valid_blk_addr = 4, valid_page_addr = 2
i=0,register --- nand_key
NAND CKECK  : arg nenv: arg_valid= 1, valid_blk_addr = 6, valid_page_addr = 108
NAND CKECK  : arg phyp: arg_valid= 1, valid_blk_addr = 8, valid_page_addr = 2
amlnand_phydev_init,1172,phydev->offset=0,phydev->size=1000000
amlnand_phydev_init,1172,phydev->offset=d000000,phydev->size=26000000
amlnand_phydev_init,1172,phydev->offset=33000000,phydev->size=52000000
amlnand_phydev_init,1172,phydev->offset=85000000,phydev->size=17b000000
nfboot    : offset: 0x000000000000 -0x000001000000 : partitons 0 : single_chip single_plane
nfcache   : offset: 0x00000d000000 -0x000026000000 : partitons 1 : single_chip multi_plane
nfcode    : offset: 0x000033000000 -0x000052000000 : partitons 5 : single_chip multi_plane
nfdata    : offset: 0x000085000000 -0x00017b000000 : partitons 1 : single_chip multi_plane
bad block count = 0
bad block count = 1
bad block count = 1
bad block count = 0
amlnf_logic_init: START
amlnf_logic_init:  COMPLETE
get_boot_device_flag: init_ret 0
get_boot_device_flag NAND BOOT:
NAND BOOT,nand_env_relocate_spec : env_relocate_spec 49
uboot env amlnf_env_read : ####
set_storage_device_flag: store 1
vpu clk_level in dts: 3
set vpu clk: 182150000Hz, readback: 182150000Hz(0x701)
Net:   Meson_Ethernet
init suspend firmware done. (ret:0)
cvbs trimming.1.v5: 0xa0, 0x0
hdmi tx power init
TV mode 576cvbs selected.
vdac open.1 = 0x1, 0x0
mode is: 4
viu chan = 1
config HPLL
config HPLL done
clk_util_clk_msr(6)=216,cnt=5
not config efuse version
current storer:nand_key
ERR(v2_common/optimus_download_key.c)L473:failed to query key state, rc 0, keyIsBurned=0
reboot_mode=charging
efuse version is not selected.
Hit Enter key to stop autoboot -- :  1  0
exit abortboot: 0
(Re)start USB(0)...
USB0:   dwc_usb driver version: 2.94 6-June-2012
USB (1) peri reg base: c1108820
USB (1) use clock source: XTAL input
USB (1) base addr: 0xc90c0000
Force id mode: Host
dwc_otg: Highspeed device found !
scanning bus 0 for devices... dwc_otg: submit_control_msg: control data phase error (ret = -1)
2 USB Device(s) found
** Invalid boot device **
[mmc_init] SDIO Port B:0, SD or TSD: Card did not respond to voltage select! mmc->block_dev.if_type=7
Booting...
## ANDROID Format IMAGE
## Booting kernel from Legacy Image at 12000000 ...
   Image Name:   Linux-3.10.33
   Image Type:   ARM Linux Kernel Image (lzo compressed)
   Data Size:    5875633 Bytes = 5.6 MiB
   Load Address: 00208000
   Entry Point:  00208000
   Verifying Checksum ... OK
    Ramdisk start addr = 0x1259b000, len = 0x69d272
    Flat device tree start addr = 0x12c38800, len = 0x58a1 magic=0xedfe0dd0
board_usb_stop cfg: 0
   Uncompressing Kernel Image ... OK
uboot time: 18086895 us.
EFUSE machid is not set.
Using machid 0xf81 from environment
From device tree /memory/ node aml_reserved_end property, for relocate ramdisk and fdt, relocate_addr: 0x56a7001
   Loading Ramdisk to 05009000, end 056a6272 ... OK
   Loading Device Tree to 05000000, end 050088a0 ... OK
Starting kernel ...
[    0.000000@0] Booting Linux on physical CPU 0x200
[    0.000000@0] Linux version 3.10.33 (S8XXBOX@ubuntu01) (gcc version 4.7.3 20130205 (prerelease) (crosstool-NG linaro-1.13.1-4.7-2013.02-01-20130221 - Linaro GCC 2013.02) ) #1 SMP PREEMPT Tue Jan 5 09:54:42 CST 2016
[    0.000000@0] CPU: ARMv7 Processor [410fc051] revision 1 (ARMv7), cr=10c5387d
[    0.000000@0] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000@0] Machine: Amlogic Meson8B, model: AMLOGIC
[    0.000000@0] physical memory start address is 0x200000
[    0.000000@0] reserved_end is c1fffff
[    0.000000@0]
[    0.000000@0] Total memory is  510 MiB
[    0.000000@0] Reserved low memory from 0x06000000 to 0x0c1fffff, size:  98 MiB
[    0.000000@0] mesonfb0(low)   : 0x06100000 - 0x07900000 ( 24 MiB)
[    0.000000@0] mesonfb1(low)   : 0x07900000 - 0x07a00000 (  1 MiB)
[    0.000000@0] deinterlace0(high)   : 0x1e800000 - 0x20000000 ( 24 MiB)
[    0.000000@0] mesonstream0(low)   : 0x07a00000 - 0x08200000 (  8 MiB)
[    0.000000@0] vdec0(low)   : 0x08200000 - 0x0c200000 ( 64 MiB)
[    0.000000@0] ppmgr0(high)   : 0x1d800000 - 0x1e800000 ( 16 MiB)
[    0.000000@0] cma: CMA: reserved 8 MiB at 1d000000
[    0.000000@0] cma: Found region@0, memory base 0, size 18 MiB
[    0.000000@0] cma: CMA: reserved 20 MiB at 1bc00000
[    0.000000@0] Memory policy: ECC disabled, Data cache writealloc
[    0.000000@0] Meson chip version = RevA (1B:A - 0:B72)
[    0.000000@0] PERCPU: Embedded 8 pages/cpu @c10d0000 s8832 r8192 d15744 u32768
[    0.000000@0] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 90708
[    0.000000@0] Kernel command line: root=/dev/data rootflags=data=writeback rw console=ttyS0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.repair=yes net.ifnames=0 mac=${mac} vdaccfg=0xa000 logo=osd1,loaded,0x7900000,576cvbs,full hdmimode=1080p cvbsmode=576cvbs androidboot.firstboot=0 hdmitx=
[    0.000000@0] ******** uboot setup mac-addr: 00:ac:60:ea:6e:c0
[    0.000000@0] cvbs trimming line = 0xa000
[    0.000000@0] cvbs trimming.1.v5: 0xa0, 0x0
[    0.000000@0] osd1:1
[    0.000000@0] loaded:268435459
[    0.000000@0] logo has been loaded
[    0.000000@0] 576cvbs:8
[    0.000000@0] full:2
[    0.000000@0] kernel get hdmimode form uboot is 1080p
[    0.000000@0] kernel get cvbsmode form uboot is 576cvbs
[    0.000000@0] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000@0] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000@0] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000@0] Memory: 64MB 16MB 278MB = 358MB total
[    0.000000@0] Memory: 313284k/313284k available, 53308k reserved, 0K highmem
[    0.000000@0] Virtual kernel memory layout:
[    0.000000@0]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000@0]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000@0]     vmalloc : 0xdd800000 - 0xff000000   ( 536 MB)
[    0.000000@0]     lowmem  : 0xc0000000 - 0xdd600000   ( 470 MB)
[    0.000000@0]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000@0]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000@0]       .text : 0xc0008000 - 0xc09c8134   (9985 kB)
[    0.000000@0]       .init : 0xc09c9000 - 0xc0a01280   ( 225 kB)
[    0.000000@0]       .data : 0xc0a02000 - 0xc0a78780   ( 474 kB)
[    0.000000@0]        .bss : 0xc0a78780 - 0xc0d13a6c   (2669 kB)
[    0.000000@0] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000@0] Preemptible hierarchical RCU implementation.
[    0.000000@0] NR_IRQS:256
[    0.000000@0] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
[    0.000000@0] Global timer: MESON TIMER-F (c0a201c0) initialized
[    0.000000@0] Switching to timer-based delay loop
[    0.000000@0] Console: colour dummy device 80x30
[    0.000000@0] console [tty0] enabled
[    0.000000@0] console [ttyS0] enabled
[    0.345461@0] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=10000)
[    0.355742@0] pid_max: default: 32768 minimum: 301
[    0.360779@0] Security Framework initialized
[    0.364754@0] SELinux:  Initializing.
[    0.368565@0] Mount-cache hash table entries: 512
[    0.380574@0] CPU: Testing write buffer coherency: ok
[    0.381275@0] CPU0: thread -1, cpu 0, socket 2, mpidr 80000200
[    0.385879@0] Setting up static identity map for 0xc06ca8d8 - 0xc06ca930
[    0.392701@0] L310 cache controller enabled
[    0.396652@0] l2x0: 8 ways, 2048 sets, CACHE_ID 0x4100a0c9,  Cache size: 524288 B
[    0.404148@0]       AUX_CTRL 0x7ec60001, PERFETCH_CTRL 0x75000007, POWER_CTRL  0x00000000
[    0.412250@0]       TAG_LATENCY 0x00000111, DATA_LATENCY 0x00000222
[    0.490398@1] CPU1: Booted secondary processor
[    0.490422@1] CPU1: thread -1, cpu 1, socket 2, mpidr 80000201
[    0.510395@2] CPU2: Booted secondary processor
[    0.510418@2] CPU2: thread -1, cpu 2, socket 2, mpidr 80000202
[    0.530394@3] CPU3: Booted secondary processor
[    0.530418@3] CPU3: thread -1, cpu 3, socket 2, mpidr 80000203
[    0.530554@0] Brought up 4 CPUs
[    0.558765@0] SMP: Total of 4 processors activated (8.00 BogoMIPS).
[    0.564989@0] CPU: All CPU(s) started in SVC mode.
[    0.570821@0] devtmpfs: initialized
[    0.583654@0] clkrate [ xtal ] : 24000000
[    0.583717@0] clkrate [ pll_sys ] : 792000000
[    0.586559@0] clkrate [ pll_fixed ] : 2550000000
[    0.591258@0] clkrate [ pll_vid ] : 648000000
[    0.595648@0] clkrate [ pll_ddr ] : 0
[    0.599373@0] clkrate [ a9_clk ] : 792000000
[    0.603719@0] clkrate [ clk81 ] : 159375000
[    0.608530@0] pinctrl core: initialized pinctrl subsystem
[    0.613694@0] regulator-dummy: no parameters
[    0.619213@0] NET: Registered protocol family 16
[    0.627664@0] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[    0.631346@0] VPU driver version: v02
[    0.632884@0] load vpu_clk in dts: 182150000Hz(3)
[    0.637583@0] vpu_probe OK
[    0.640836@0] cma: Assigned CMA region with name cma_0 to amvenc_avc.0 device
[    0.651542@0] amlogic_gpio gpio: Probed amlogic GPIO driver
[    0.653164@0] register lm device lm-root
[    0.656847@0] register lm device lm1
[    0.660431@0] register lm device lm0
[    0.664129@0] Init pinux probe!
[    0.668035@0] pinmux-m8b pinmux: Probed amlogic pinctrl driver
[    0.672862@0] tv_init_module
[    0.675665@0] major number 254 for disp
[    0.679465@0] vout_register_server
[    0.682860@0] register tv module server ok
[    0.687001@0] aml_i2c version: 20140813
[    0.691023@0] aml-i2c i2c-AO: add adapter aml_i2c_adap0(db32a4a8)
[    0.696788@0] aml-i2c i2c-AO: aml i2c bus driver.
[    0.701728@0] aml-i2c i2c-A: add adapter aml_i2c_adap1(db32a8a8)
[    0.707438@0] aml-i2c i2c-A: aml i2c bus driver.
[    0.712280@0] aml-i2c i2c-B: add adapter aml_i2c_adap2(db32aca8)
[    0.718001@0] aml-i2c i2c-B: aml i2c bus driver.
[    0.722827@0] aml-i2c i2c-C: add adapter aml_i2c_adap3(db32b0a8)
[    0.728566@0] aml-i2c i2c-C: aml i2c bus driver.
[    0.733379@0] aml-i2c i2c-D: add adapter aml_i2c_adap4(db32b4a8)
[    0.739128@0] aml-i2c i2c-D: aml i2c bus driver.
[    0.743899@0] aml_pmu_init, 454
[    0.746874@0] call aml_dvfs_init in
[    0.750699@0] hdmitx: system: amhdmitx_init
[    0.754451@0] hdmitx: system: Ver: 2014May6
[    0.758714@0] hdmitx: system: amhdmitx_probe
[    0.763381@0] hdmitx: system: gate/pwr cmd: 7
[    0.767181@0] hdmitx: system: gate/pwr cmd: 1
[    0.771535@0] hdmitx: system: hw init
[    0.775733@1] hdmitx: system: reset intr mask
[    0.839025@0] bio: create slab <bio-0> at 0
[    0.839898@0] SCSI subsystem initialized
[    0.841796@0] usbcore: registered new interface driver usbfs
[    0.847187@0] usbcore: registered new interface driver hub
[    0.852723@0] usbcore: registered new device driver usb
[    0.857898@0] Linux video capture interface: v2.00
[    0.862630@0] pps_core: LinuxPPS API ver. 1 registered
[    0.867647@0] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.876953@0] PTP clock support registered
[    0.881500@0] mode is 8,sync_duration_den=1,sync_duration_num=50
[    0.886959@0] request vpu clk holdings: venci 106250000Hz
[    0.892371@0] TV mode 576cvbs selected.
[    0.896134@0] already display in uboot
[    0.905059@0] call aml_pmu_probe_init in
[    0.905588@0] Advanced Linux Sound Architecture Driver Initialized.
[    0.910620@0] Bluetooth: Core ver 2.16
[    0.913793@0] NET: Registered protocol family 31
[    0.918301@0] Bluetooth: HCI device and connection manager initialized
[    0.924830@0] Bluetooth: HCI socket layer initialized
[    0.929824@0] Bluetooth: L2CAP socket layer initialized
[    0.935082@0] Bluetooth: SCO socket layer initialized
[    0.940375@0] cfg80211: Calling CRDA to update world regulatory domain
[    0.948808@0] Switching to clocksource Timer-E
[    0.963230@0] NET: Registered protocol family 2
[    0.963997@0] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[    0.969426@0] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[    0.976056@0] TCP: Hash tables configured (established 4096 bind 4096)
[    0.982494@0] TCP: reno registered
[    0.985802@0] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.991814@0] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.998508@0] NET: Registered protocol family 1
[    1.002829@0] wifi_dev_probe
[    1.005538@0] wifi_dt : interrupt_pin=GPIOX_21
[    1.009958@0] wifi_dt : irq_num=null
[    1.013545@0] wifi_dt : irq_trigger_type=GPIO_IRQ_HIGH
[    1.018609@0] wifi_dt : power_on_pin=GPIOAO_6
[    1.022965@0] wifi_dt : power_on_pin2=GPIOX_11
[    1.027360@0] interrupt_pin=118, irq_num=4, irq_trigger_type=0, power_on_pin=6,clock_32k_pin=0
[    1.036365@0] Unpacking initramfs...
[    1.039488@0] Initramfs unpacking failed: junk in compressed archive
[    1.058629@0] Freeing initrd memory: 6772K (c4e09000 - c54a6000)
[    1.061111@0] audit: initializing netlink socket (disabled)
[    1.064603@0] type=2000 audit(0.980:1): initialized
[    1.077122@0] VFS: Disk quotas dquot_6.5.2
[    1.077513@0] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.085798@0] fuse init (API version 7.22)
[    1.087123@0] msgmni has been set to 681
[    1.092630@0] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[    1.097780@0] io scheduler noop registered
[    1.101876@0] io scheduler deadline registered
[    1.106473@0] io scheduler cfq registered (default)
[    1.191695@0] loop: module loaded
[    1.192616@0] tun: Universal TUN/TAP device driver, 1.6
[    1.194603@0] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    1.201789@0] ethernet base addr is fe0c0000
[    1.205194@0] key device don't create,extenal_api_key_set_version:2052
[    1.211689@0] ret = -22
[    1.211689@0] print_buff=
[    1.216764@0] DWMAC100
[    1.219108@0] stmmac - user ID: 0x10, Synopsys ID: 0x37
[    1.224323@0]  Normal descriptors
[    1.227591@0]  Ring mode enabled
[    1.230795@0]  DMA HW capability register supported
[    1.235512@0]  RX Checksum Offload Engine supported (type 2)
[    1.241288@0]  TX Checksum insertion supported
[    1.245688@0]  Wake-Up On Lan supported
[    1.249544@0]  Enable RX Mitigation via HW Watchdog Timer
[    1.257819@0] libphy: stmmac: probed
[    1.258423@0] eth0: PHY ID 02430c54 at 0 IRQ POLL (stmmac-0:00) active
[    1.265051@0] PPP generic driver version 2.4.2
[    1.269577@0] PPP BSD Compression module registered
[    1.274223@0] PPP Deflate Compression module registered
[    1.279385@0] PPP MPPE Compression module registered
[    1.284329@0] NET: Registered protocol family 24
[    1.288981@0] usbcore: registered new interface driver asix
[    1.294569@0] usbcore: registered new interface driver ax88179_178a
[    1.300751@0] usbcore: registered new interface driver cdc_ether
[    1.306741@0] usbcore: registered new interface driver dm9601
[    1.312467@0] usbcore: registered new interface driver net1080
[    1.318218@0] usbcore: registered new interface driver cdc_subset
[    1.324304@0] usbcore: registered new interface driver zaurus
[    1.330035@0] usbcore: registered new interface driver cdc_ncm
[    1.336100@0] usbcore: registered new interface driver cdc_acm
[    1.341571@0] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    1.349763@0] usbcore: registered new interface driver usb-storage
[    1.356014@0] usbcore: registered new interface driver usbserial
[    1.361882@0] usbcore: registered new interface driver option
[    1.367572@0] usbserial: USB Serial support registered for GSM modem (1-port)
[    1.375088@0] mousedev: PS/2 mouse device common for all mice
[    1.380848@0] i2c /dev entries driver
[    1.385022@0] usbcore: registered new interface driver uvcvideo
[    1.389858@0] USB Video Class driver (1.1.1)
[    1.394571@0] device-mapper: uevent: version 1.0.3
[    1.399300@0] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[    1.407820@0] Bluetooth: HCI UART driver ver 2.2
[    1.412072@0] Bluetooth: HCI H4 protocol initialized
[    1.417705@0] usbcore: registered new interface driver usbhid
[    1.422712@0] usbhid: USB HID core driver
[    1.427387@0] zram: Created 1 device(s) ...
[    1.431494@0] ashmem: initialized
[    1.434395@0] logger: created 256K log 'log_main'
[    1.439012@0] logger: created 256K log 'log_events'
[    1.443889@0] logger: created 256K log 'log_radio'
[    1.448650@0] logger: created 256K log 'log_system'
[    1.453631@0] vout_init_module
[    1.456342@0] start init vout module
[    1.460052@0] create  vout attribute ok
[    1.464519@0] ge2d_init
[    1.466411@0] ge2d_dev major:245
[    1.469922@0] ge2d start monitor
[    1.473135@0] osd_init
[    1.473149@1] ge2d workqueue monitor start
[    1.479536@0] osd_probe, vinfo:c070dc4c
[    1.483769@0] Frame buffer memory assigned at phy:0x06100000, vir:0xde000000, size=24576K
[    1.491457@0] osd_probe, mydef_var:c0a41120, vinfo:c070dc4c
[    1.496992@0] init fbdev bpp is :32
[    1.500518@0] ---------------clear framebuffer0 memory
[    1.532158@0] Frame buffer memory assigned at phy:0x07900000, vir:0xdda00000, size=1024K
[    1.534640@0] osd_probe, mydef_var:c0a41120, vinfo:c070dc4c
[    1.540179@0] don't find to display_size_default from mesonfb-dts
[    1.546264@0] init fbdev bpp is :16
[    1.551927@0] osd probe ok
[    1.553793@0] amlvideo-000: V4L2 device registered as video10
[    1.558820@0] ionvideo-000: V4L2 device registered as video13
[    1.564191@0] Video Technology Magazine Ion Video Capture Board ver 1.0 successfully loaded.
[    1.573216@0] aml_wdt_driver_init,301
[    1.576200@0] ** disable watchdog
[    1.579756@0] keys===========================================
[    1.585287@0] keys_devno=f200000
[    1.588620@0] securitykey: device aml_keys created
[    1.593274@0] amlkeys=0
[    1.595651@0] platform_driver_register--aml_keys_driver--------------------
[    1.602717@0] key unify config unifykey-num is 6
[    1.607154@0] key unify fact unifykey-num is 6
[    1.611596@0] aml_unifykeys_probe:694=============unifykey_devno:f100000
[    1.618431@0] unifykey: device unifykeys created ok
[    1.623161@0] platform_driver_register--unifykey management  driver--------------------
[    1.631467@0] start uart_ao_ttyS0:(irq = 122)
[    1.635365@0] register uart_ao ok
[    1.638956@0] start uart_a_ttyS1:(irq = 58)
[    1.642855@0] register uart_a ok
[    1.646334@0] set uart_b pinmux use pinctrl subsystem
[    1.651079@0] P_AO_RTI_PIN_MUX_REG:5861
[    1.654868@0] start uart_b_ttyS2:(irq = 107)
[    1.659066@0] register uart_b ok
[    1.662687@0] start uart_d_ttyS4:(irq = 126)
[    1.666512@0] register uart_d ok
[    1.669901@0] dwc_otg: version 3.10a 12-MAY-2014
[    1.674448@0] dwc_otg_driver_probe NOT match
[    1.678609@0] usb1: type: 1, speed: 0, config: 0, dma: 0, id: 1, phy: fe108820, ctrl: fe080000
[    1.687205@0] USB (1) use clock source: XTAL input
[    1.713183@0] Core Release: 3.10a
[    1.713237@0] Setting default values for core params
[    1.715830@0] curmode: 1, host_only: 1
[    1.739784@0] Using Buffer DMA mode
[    1.739838@0] OTG VER PARAM: 1, OTG VER FLAG: 1
[    1.742216@0] Working on port type = HOST
[    1.747469@0] dwc_otg lm1: DWC OTG Controller
[    1.750508@0] dwc_otg lm1: new USB bus registered, assigned bus number 1
[    1.757276@0] dwc_otg lm1: irq 63, io mem 0x00000000
[    1.762138@0] -------hcd->flags.d32 = 0
[    1.765912@0] Init: Port Power? op_state=1
[    1.769957@0] Init1: Power Port (0)
[    1.774297@0] hub 1-0:1.0: USB hub found
[    1.777338@0] hub 1-0:1.0: 1 port detected
[    1.781865@0] usb0: type: 1, speed: 0, config: 0, dma: 0, id: 0, phy: fe108800, ctrl: fe040000
[    1.789972@0] USB (0) use clock source: XTAL input
[    1.815942@0] Core Release: 3.10a
[    1.815995@0] Setting default values for core params
[    1.818587@0] curmode: 1, host_only: 1
[    1.842630@0] Using Buffer DMA mode
[    1.842685@0] OTG VER PARAM: 1, OTG VER FLAG: 1
[    1.845010@0] Working on port type = HOST
[    1.849253@0] dwc_otg lm0: DWC OTG Controller
[    1.853439@0] dwc_otg lm0: new USB bus registered, assigned bus number 2
[    1.860024@0] dwc_otg lm0: irq 62, io mem 0x00000000
[    1.864985@0] -------hcd->flags.d32 = 0
[    1.868757@0] Init: Port Power? op_state=1
[    1.872877@0] Init1: Power Port (0)
[    1.877061@0] hub 2-0:1.0: USB hub found
[    1.880184@0] hub 2-0:1.0: 1 port detected
[    1.884843@0] boot_device_flag : 1
[    1.887612@0] ===========================================amlnf_init:642,nand device tree ok,dev-name:nand
[    1.897143@0] Nand PHY driver Version: 2.01.001.0006 (c) 2013 Amlogic Inc.
[    1.904037@0] amlnf_phy_init : amlnf init flag 0
[    1.908684@0] ######STS IRQ mode for nand driver
[    1.913315@0] NAND device id: ad de 14 a7 42 4a ad de
[    1.918181@0] detect NAND device: E revision 1Ynm NAND 8GiB H27UCG8T2E
[    1.972015@0] AML_NAND_NEW_OOB : new oob
[    1.972076@0] bus_cycle=6, bus_timing=8,system=3.9ns,flash->T_REA =16,flash->T_RHOH=15
[    1.978208@0] boot_device_flag = 1
[    1.981708@1] Indeed it is in host mode hprt0 = 00021501
[    1.984130@0] hynix nand get default reg value at blk:7, page:1792
[    1.988722@0] NAND CKECK  : arg nbbt: arg_valid= 1, valid_blk_addr = 10, valid_page_addr = 0
[    1.993693@0] NAND CKECK  : arg ncnf: arg_valid= 1, valid_blk_addr = 5, valid_page_addr = 0
[    1.994305@0] nand shipped bbt at block 0
[    2.023048@0] NAND CKECK  : arg phyp: arg_valid= 1, valid_blk_addr = 8, valid_page_addr = 2
[    2.055178@0] NAND CKECK  : arg nkey: arg_valid= 1, valid_blk_addr = 4, valid_page_addr = 2
[    2.058512@0] i=0,register --- nand_key
[    2.100484@0] NAND CKECK  : arg nenv: arg_valid= 1, valid_blk_addr = 6, valid_page_addr = 108
[    2.106230@0] amlnand_phydev_init,1179,phydev->offset=0,phydev->size=1000000
[    2.110419@0] amlnand_phydev_init,1179,phydev->offset=d000000,phydev->size=26000000
[    2.118126@0] amlnand_phydev_init,1179,phydev->offset=33000000,phydev->size=52000000
[    2.125818@0] amlnand_phydev_init,1179,phydev->offset=85000000,phydev->size=17b000000
[    2.133613@0] nfboot     : offset: 0x000000000000 -0x000001000000 : partitons 0 : single_chip single_plane
[    2.143202@0] nfcache    : offset: 0x00000d000000 -0x000026000000 : partitons 1 : single_chip multi_plane
[    2.152745@0] nfcode     : offset: 0x000033000000 -0x000052000000 : partitons 5 : single_chip multi_plane
[    2.162249@0] nfdata     : offset: 0x000085000000 -0x00017b000000 : partitons 1 : single_chip multi_plane
[    2.171897@0] bad block count = 0
[    2.171897@0]
[    2.178891@0] bad block count = 1
[    2.178891@0]
[    2.186435@0] bad block count = 1
[    2.186435@0]
[    2.191061@1] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    2.193266@1] Indeed it is in host mode hprt0 = 00001101
[    2.209245@0] bad block count = 0
[    2.209245@0]
[    2.209322@0] amlnand_add_nftl:
[    2.212027@0] Creating 1 ntd partitions
[    2.215531@0] block_num 76
[    2.220567@0] ------init_ntd
[    2.221639@0] ntd: Giving out device 0 to nfcache
[    2.225834@0] Creating 5 ntd partitions
[    2.229645@0] block_num 164
[    2.237818@0] ntd: Giving out device 1 to nfcode
[    2.237888@0] Creating 1 ntd partitions
[    2.240901@0] block_num 758
[    2.266588@0] ntd: Giving out device 2 to nfdata
[    2.268042@0] amvideocap_init_module
[    2.269326@0] Amlogic A/V streaming port init
[    2.275486@0] buffersize=262144,0,start=0
[    2.277466@0] Subtitle stbuf alloced at 0xdac00000, size = 262144
[    2.283591@0] changed the (2) buffer size from 0 to 262144
[    2.289222@0] init vdec memsource 8200000->c1fffff
[    2.294002@0] [tsync_pcr_init]init success.
[    2.298052@0] regist mpeg12 codec profile
[    2.302098@0] regist mpeg4 codec profile
[    2.305855@0] amvdec_vc1 module init
[    2.309474@0] regist vc1 codec profile
[    2.313207@0] amvdec_h264 module init
[    2.316911@0] regist h264 codec profile
[    2.320576@0] amvdec_h264mvc module init
[    2.324615@0] regist hmvc codec profile
[    2.328283@0] amvdec_h265 module init
[    2.332074@0] regist hevc codec profile
[    2.335798@0] regist mjpeg codec profile
[    2.339624@0] amvdec_real module init
[    2.343390@0] regist real codec profile
[    2.347072@0] amvdec_avs module init
[    2.350804@0] amvenc_avc memory resource undefined.
[    2.355549@0] encode_wq_init.
[    2.358418@0] encode start monitor.
[    2.362017@1] encode workqueue monitor start.
[    2.366474@0] jpegenc module init
[    2.369914@0] picdec buffer size is 4000000
[    2.373965@0] alloc_keep_buffer keep_y_addr da600000
[    2.378608@0] alloc_keep_buffer keep_u_addr dad00000
[    2.383660@0] alloc_keep_buffer keep_v_addr dac80000
[    2.388463@0] yaddr=da600000,u_addr=dad00000,v_addr=dac80000
[    2.394618@0] create_ge2d_work_queue video task ok
[    2.399543@0] efuse===========================================
[    2.405043@0] efuse: device efuse created
[    2.408793@0] efuse--------------------------------------------
[    2.414854@0] SARADC Driver init.
[    2.418320@0] __saradc_probe__
[    2.421690@0] hub 1-1:1.0: USB hub found
[    2.424963@0] hub 1-1:1.0: 4 ports detected
[    2.561173@0] saradc calibration: ref_val = 510
[    2.561236@0] saradc calibration: ref_nominal = 512
[    2.564941@0] saradc calibration: coef = 4088
[    2.569653@0] ir irblaster probe
[    2.572881@0] Remote Driver
[    2.575371@0] Remote platform_data g_remote_base=fe600580
[    2.580653@0] set drvdata completed
[    2.584251@0] device_create_file completed
[    2.589122@0] input: aml_keypad as /devices/platform/meson-remote/input/input0
[    2.596082@0] input_register_device completed
[    2.600158@0] [0x0] = 0x1dd0190
[    2.603289@0] [0x4] = 0xf800ca
[    2.606245@0] [0x8] = 0x820064
[    2.609275@0] [0xc] = 0x3c0030
[    2.612391@0] [0x10] = 0x30fa0013
[    2.615596@0] [0x18] = 0x6f19000
[    2.618800@0] [0x1c] = 0x9f40
[    2.621898@0] [0x20] = 0x0
[    2.624580@0] [0x24] = 0x0
[    2.627190@0] [0x28] = 0x0
[    2.629806@0] set_remote_mode[65]
[    2.633237@0] remote config major:233
[    2.637038@0] physical address:0x1ae5e000
[    2.640886@0] ADC Keypad Driver init.
[    2.644818@0] ==touch_ts_init==
[    2.647717@0] ==ft5x0x_ts_init==
[    2.650819@0] ==goodix_ts_init==
[    2.654162@0] i2c-core: driver [gslx680_compatible] using legacy suspend method
[    2.661296@0] i2c-core: driver [gslx680_compatible] using legacy resume method
[    2.668497@0] !!!ntp_ts: ret = 0.
[    2.671860@0] VTL ct36x TouchScreen driver, <george.chen@vtl.com.cn>.
[    2.678303@0] i2c-core: driver [ct36x] using legacy suspend method
[    2.684412@0] i2c-core: driver [ct36x] using legacy resume method
[    2.690421@0] VTL ct36x TouchScreen driver End.
[    2.695005@0] ==gsl_ts_init==
[    2.697915@0] ret=0
[    2.700252@0] i2c-core: driver [mir3da] using legacy suspend method
[    2.706271@0] i2c-core: driver [mir3da] using legacy resume method
[    2.712449@3] usb 1-1.4: new high-speed USB device number 3 using dwc_otg
[    2.712531@0] i2c-core: driver [lis3dh_acc] using legacy suspend method
[    2.712535@0] i2c-core: driver [lis3dh_acc] using legacy resume method
[    2.712638@0] i2c-core: driver [bma222] using legacy suspend method
[    2.712642@0] i2c-core: driver [bma222] using legacy resume method
[    2.712763@0] i2c-core: driver [dmard06] using legacy suspend method
[    2.712766@0] i2c-core: driver [dmard06] using legacy resume method
[    2.712815@0] lsm303d driver: init
[    2.712908@0] i2c-core: driver [dmard10] using legacy suspend method
[    2.712912@0] i2c-core: driver [dmard10] using legacy resume method
[    2.712969@0] stk8313_init
[    2.713015@0] ======stk831x init ok======
[    2.713018@0] stk831x_init
[    2.713064@0] mxc622x accelerometer driver: init
[    2.713117@0] i2c-core: driver [mxc622x] using legacy suspend method
[    2.713121@0] i2c-core: driver [mxc622x] using legacy resume method
[    2.713128@0] mxc6255xc accelerometer driver: init
[    2.713171@0] i2c-core: driver [mxc6255xc] using legacy suspend method
[    2.713174@0] i2c-core: driver [mxc6255xc] using legacy resume method
[    2.713334@0] cm3217 v.1.0.0.1
[    2.713379@0] i2c-core: driver [elan_epl6814] using legacy suspend method
[    2.713383@0] i2c-core: driver [elan_epl6814] using legacy resume method
[    2.713461@0] i2c-core: driver [LTR501] using legacy suspend method
[    2.713464@0] i2c-core: driver [LTR501] using legacy resume method
[    2.713600@0] GPIO Keypad Driver init.
[    2.713725@0] ==gpio_key_probe==
[    2.713771@0]  reg:2620,clearmask=400040,setmask=1
[    2.713776@0] reg:2622,clearmask=ff0000,set pin=3
[    2.713781@0] reg:2623,clearmask=7000000,setmask=7
[    2.713788@0]  reg:2620,clearmask=800080,setmask=10001
[    2.713793@0] reg:2622,clearmask=ff000000,set pin=3
[    2.713799@0] reg:2623,clearmask=70000000,setmask=7
[    2.713907@0] power key(116) registed.
[    2.714150@0] input: gpio_keypad as /devices/platform/gpio_keypad.6/input/input1
[    2.714384@0] gpio keypad register input device completed.
[    2.714395@0] gpio keypad major:232
[    2.714731@0] spi_nor_init
[    2.714898@0] amlogic_spi_nor_probe:
[    2.714909@0] amlogic_spi->state_name:default
[    2.715064@0] AMLOGIC_SPI_NOR cc000000.spi: master is unqueued, this is deprecated
[    2.715198@0] check_storage_device : spi boot_device_flag : -1
[    2.715212@0] spi_nor_probe
[    2.715217@0] spi_nor_probe 629 boot_device_flag -1 : do not init spi
[    2.715235@0] spi_nor: probe of apollospi:32766 failed with error -12
[    2.715242@0] amlogic_spi_nor_probe over
[    2.715393@0] mmc driver version: 1.07, 2015-01-21: fix a bug in tuning which caused eMMC data CRC error
[    2.955538@0] host->base fe108c20
[    2.958290@0] pdata->caps 7
[    2.961083@0] pdata->caps2 0
[    2.963869@0] get property:                     port, value:0x00000001
[    2.970358@0] get property:                ocr_avail, value:0x00200000
[    2.977015@0] get property:                    f_min, value:0x000493e0
[    2.983410@0] get property:                    f_max, value:0x02faf080
[    2.989842@0] get property:                  f_max_w, value:0x02faf080
[    2.996423@0] get property:             max_req_size, value:0x00020000
[    3.002879@0] get property:                   irq_in, value:0x00000003
[    3.009325@0] get property:                  irq_out, value:0x00000005
[    3.015914@0] get property:                  gpio_cd, str:CARD_6
[    3.021847@0] get property:                  pinname, str:sd
[    3.027425@0] get property:                 jtag_pin, str:CARD_0
[    3.033533@0] get property:                card_type, value:0x00000005
[    3.039942@0] get property:                gpio_dat3, str:CARD_4
[    3.082151@0]  reg:2620,clearmask=80008,setmask=10001
[    3.082224@0] reg:2621,clearmask=ff000000,set pin=49
[    3.086531@0] reg:2623,clearmask=7000,setmask=7
[    3.091113@0]  reg:2620,clearmask=200020,setmask=1
[    3.095797@0] reg:2622,clearmask=ff00,set pin=49
[    3.100385@0] reg:2623,clearmask=700000,setmask=7
[    3.105490@0] pdata->caps 10f
[    3.108015@0] pdata->caps2 0
[    3.110874@0] get property:                     port, value:0x00000000
[    3.117481@0] get property:                ocr_avail, value:0x00200000
[    3.123927@0] get property:                    f_min, value:0x000493e0
[    3.130356@0] get property:                    f_max, value:0x02faf080
[    3.136969@0] get property:             max_req_size, value:0x00020000
[    3.143401@0] get property:                  pinname, str:sdio
[    3.149145@0] get property:                card_type, value:0x00000003
[    3.251066@0] [aml_sdio_probe] aml_sdio_probe() success!
[    3.252675@0] host->base fe108e00
[    3.254166@0] pdata->caps 80000547
[    3.257443@0] pdata->caps2 0
[    3.260300@0] get property:                     port, value:0x00000005
[    3.266910@0] get property:                ocr_avail, value:0x00200000
[    3.273397@0] get property:                    f_min, value:0x000493e0
[    3.279783@0] get property:                    f_max, value:0x02faf080
[    3.286329@0] get property:             max_req_size, value:0x00020000
[    3.292864@0] get property:                  pinname, str:emmc
[    3.298573@0] get property:                card_type, value:0x00000001
[    3.305131@0] get property:                gpio_dat3, str:BOOT_3
[    3.311093@0] [is_emmc_exist] host->storage_flag=0, POR_BOOT_VALUE=7
[    3.317411@0] [aml_sdhc_probe]: there is not eMMC/tsd, skip sdhc_c dts config!
[    3.324670@0] pdata->caps 78107
[    3.327664@0] pdata->caps2 0
[    3.330523@0] get property:                     port, value:0x00000003
[    3.337097@0] get property:                ocr_avail, value:0x00200000
[    3.343562@0] get property:                    f_min, value:0x000493e0
[    3.350006@0] get property:                    f_max, value:0x02faf080
[    3.356578@0] get property:             max_req_size, value:0x00020000
[    3.363056@0] get property:                  pinname, str:sdio
[    3.368797@0] get property:                card_type, value:0x00000003
[    3.375435@0] ------------[ cut here ]------------
[    3.380068@0] WARNING: at /service2/ambox/m8_kitkat44_20150414/common/fs/sysfs/dir.c:530 sysfs_add_one+0x78/0x98()
[    3.390413@0] sysfs: cannot create duplicate filename '/class/mmc_host/sdio'
[    3.397459@0] Modules linked in:
[    3.400578@0] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.10.33 #1
[    3.406812@0] [<c00149c8>] (unwind_backtrace+0x0/0xf8) from [<c0011aac>] (show_stack+0x10/0x14)
[    3.415482@0] [<c0011aac>] (show_stack+0x10/0x14) from [<c002d4b8>] (warn_slowpath_common+0x4c/0x6c)
[    3.424544@0] [<c002d4b8>] (warn_slowpath_common+0x4c/0x6c) from [<c002d56c>] (warn_slowpath_fmt+0x30/0x40)
[    3.434263@0] [<c002d56c>] (warn_slowpath_fmt+0x30/0x40) from [<c011f228>] (sysfs_add_one+0x78/0x98)
[    3.443334@0] [<c011f228>] (sysfs_add_one+0x78/0x98) from [<c011fdd4>] (sysfs_do_create_link_sd+0xec/0x1fc)
[    3.453063@0] [<c011fdd4>] (sysfs_do_create_link_sd+0xec/0x1fc) from [<c0283f9c>] (device_add+0x20c/0x5b0)
[    3.462651@0] [<c0283f9c>] (device_add+0x20c/0x5b0) from [<c0379fe0>] (mmc_add_host+0x2c/0x78)
[    3.471222@0] [<c0379fe0>] (mmc_add_host+0x2c/0x78) from [<c049cae0>] (aml_sdhc_probe+0x5cc/0x870)
[    3.480124@0] [<c049cae0>] (aml_sdhc_probe+0x5cc/0x870) from [<c0287614>] (platform_drv_probe+0x14/0x18)
[    3.489575@0] [<c0287614>] (platform_drv_probe+0x14/0x18) from [<c028644c>] (driver_probe_device+0xc4/0x20c)
[    3.499379@0] [<c028644c>] (driver_probe_device+0xc4/0x20c) from [<c02865fc>] (__driver_attach+0x68/0x8c)
[    3.508871@0] [<c02865fc>] (__driver_attach+0x68/0x8c) from [<c0284bb8>] (bus_for_each_dev+0x4c/0x8c)
[    3.518089@0] [<c0284bb8>] (bus_for_each_dev+0x4c/0x8c) from [<c0285bb4>] (bus_add_driver+0xcc/0x234)
[    3.527238@0] [<c0285bb4>] (bus_add_driver+0xcc/0x234) from [<c0286b48>] (driver_register+0xa0/0x13c)
[    3.536445@0] [<c0286b48>] (driver_register+0xa0/0x13c) from [<c0008554>] (do_one_initcall+0x94/0x144)
[    3.545674@0] [<c0008554>] (do_one_initcall+0x94/0x144) from [<c09c9b6c>] (kernel_init_freeable+0x100/0x1cc)
[    3.555504@3] [<c09c9b6c>] (kernel_init_freeable+0x100/0x1cc) from [<c06b8388>] (kernel_init+0x8/0xe4)
[    3.564690@3] [<c06b8388>] (kernel_init+0x8/0xe4) from [<c000e1d8>] (ret_from_fork+0x14/0x3c)
[    3.573172@3] ---[ end trace 1077898f3bde87da ]---
[    3.577956@3] [aml_sdhc_probe] Failed to add mmc host.
[aml_sdhc_probe] aml_sdhc_probe() fail!
[    3.587787@1] aml_sdhc: probe of aml_sdhc.0 failed with error -17
[    3.594007@1] [dsp]DSP start addr 0xc5e00000
[    3.598106@1] [dsp]register dsp to char divece(257)
[    3.603470@1] amlogic audio spdif interface device init!
[    3.608307@1] name=nand_key nand_key
[    3.612423@1] register_aes_algorithm:488,new way
[    3.616394@1] unkown current key-name,key_read_show:1396
[    3.621649@1] get keyexample fail, aml_rtc_probe:750
[    3.627430@1] aml_rtc rtc.0: rtc core: registered aml_rtc as rtc0
[    3.634485@1] vdin_drv_init: major 230
[    3.636511@1] amvdec_656in module: init.
[    3.640242@1] amvdec_656in_init_module:major 229
[    3.645310@1] amvdec_656in probe ok.
[    3.648804@1] amvdec_csi probe ok.
[    3.651825@1] [viuin..]viuin_init_module viuin module init
[    3.657452@1] [viuin..]viuin_probe probe ok.
[    3.662852@1] amaudio2: device amaudio2 created
[    3.666231@1] wifi_power power_gpio is 6
[    3.669857@1] wifi_power power_gpio2 is 108
[    3.674367@1] amlogic rfkill init
[    3.677391@1] not get gpio_en
[    3.680242@1] not get gpio_wake
[    3.711177@1] wifi_request_32k_clk : no 32k pincam_devs num is 5
[    3.821694@1] camera ar0543 is not support
[    3.821788@1] cam_devs num is 5
[    3.824896@1] camera ov5647 is not support
[    3.828974@1] cam_devs num is 5
[    3.832107@1] camera ar0833 is not support
[    3.836834@1] aml_hw_crypto initialization.
[    3.841366@1] usbcore: registered new interface driver snd-usb-audio
[    3.847116@1] enter rt5616_modinit
[    3.850214@1] dummy_codec_platform_probe
[    3.854227@1] == ES8323 == es8323_modinit()
[    3.858827@1] i2s get no clk src setting in dts, use the default mpll 0
[    3.864767@1] [aml-i2s-dai]enterd aml_i2s_dai_probe,old_samplerate:0,sample_rate=48000
[    3.872945@1] [aml-spdif-dai]enter aml_dai_spdif_init
[    3.877719@1] [aml-spdif-dai]enterd aml_spdif_play,set_clock:-1,sample_rate=4
[    3.884870@1] audio_set_958_clk, freq=4,
[    3.888718@1] IEC958 16bit
[    3.891420@1] hdmitx: audio: aout notify rate 48000
[    3.896245@1] hdmitx: audio: aout notify size 16
[    3.900835@1] hdmitx: audio: aout notify format CT_PCM
[    3.906072@1] [aml-spdif-dai]aml_spdif_probe
[    3.910474@1] test codec rt5616
[    3.913417@1] test_codec_of_node, node rt5616 disable
[    3.918412@1] test codec rt5631
[    3.921546@1] test_codec_of_node, node rt5631 disable
[    3.926551@1] test codec wm8960
[    3.929668@1] test_codec_of_node, node wm8960 disable
[    3.934719@1] test codec dummy_codec
[    3.938242@1] using external codec, index = 4
[    3.942586@1] using external dummy codec
[    3.946642@1] enter spdif_dit_probe
[    3.950016@1] aml_spdif_unmute
[    3.953365@1] codec_name = dummy_codec.0
[    3.957700@1] p_aml_audio->hp_disable=1
[    3.960841@1] falied to get spk event delay time paraments from dts file
[    3.967536@1] spk_event delay_time = 0
[    3.972527@1] aml-i2s 0:playback preallocate_dma_buffer: area=dd300000, addr=1d500000, size=524288
[    3.980650@1] aml-i2s 1:capture preallocate_dma_buffer: area=dd240000, addr=1d440000, size=65536
[    3.988954@1] aml_snd_m8 aml_m8_sound_card.4:  dummy_codec <-> aml-i2s-dai.0 mapping ok
[    3.998649@1] aml-i2s 0:playback preallocate_dma_buffer: area=dd400000, addr=1d600000, size=524288
[    4.006269@1] aml-i2s 1:capture preallocate_dma_buffer: area=dd260000, addr=1d460000, size=65536
[    4.014581@1] aml_snd_m8 aml_m8_sound_card.4:  dit-hifi <-> aml-spdif-dai.0 mapping ok
[    4.024229@1] -----ext_codec=1---
[    4.025716@1] =aml_m8_pinmux_init==,aml_m8_pinmux_init done,---0
[    4.031915@1] GACT probability NOT on
[    4.035313@1] Mirror/redirect action on
[    4.039118@1] u32 classifier
[    4.041995@1]     Actions configured
[    4.045527@1] Netfilter messages via NETLINK v0.30.
[    4.050441@1] nf_conntrack version 0.5.0 (5448 buckets, 21792 max)
[    4.057313@1] ctnetlink v0.93: registering with nfnetlink.
[    4.062081@1] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[    4.069075@1] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[    4.075569@1] xt_time: kernel timezone is -0000
[    4.079945@1] ip_tables: (C) 2000-2006 Netfilter Core Team
[    4.085300@1] arp_tables: (C) 2002 David S. Miller
[    4.089842@1] TCP: cubic registered
[    4.093965@1] NET: Registered protocol family 10
[    4.098943@1] mip6: Mobile IPv6
[    4.100979@1] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    4.106817@1] sit: IPv6 over IPv4 tunneling driver
[    4.112650@1] NET: Registered protocol family 17
[    4.115869@1] NET: Registered protocol family 15
[    4.120521@1] Bridge firewalling registered
[    4.124769@1] Bluetooth: RFCOMM TTY layer initialized
[    4.129635@1] Bluetooth: RFCOMM socket layer initialized
[    4.134985@1] Bluetooth: RFCOMM ver 1.11
[    4.138782@1] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    4.144255@1] Bluetooth: BNEP filters: protocol multicast
[    4.149620@1] Bluetooth: BNEP socket layer initialized
[    4.154731@1] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    4.160785@1] Bluetooth: HIDP socket layer initialized
[    4.165930@1] NET: Registered protocol family 35
[    4.171711@1] VFP support v0.3: implementor 41 architecture 2 part 30 variant 5 rev 1
[    4.178290@1] Registering SWP/SWPB emulation handler
[    4.183221@1] enter meson_pm_init
[    4.187143@1] enter meson_pm_probe!
[    4.189979@1] hdmi: cec_pm: cec config:0xf
[    4.194043@1] meson_pm_probe done !
[    4.197528@1] AO cpu runs ok.
[    4.201549@1] ERROR::usb_gadget_probe_driver:1372: usb_gadget_register_driver ENODEV
[    4.201549@1]
[    4.209782@1] init: failed to probe driver -19AO cpu stop ok.
[    4.215874@1] AO cpu runs ok.
[    4.218477@1] aml_rtc rtc.0: setting system clock to 2020-04-09 10:44:42 UTC (1586429082)
[    4.226629@1] ### dt-test ### No testcase data in device tree; not running tests
[    4.234123@1] meson_cpufreq_probe:SYSPLL request to be fixed
[    4.239569@1] meson_cpufreq: no voltage_control prop
[    4.244524@1] voltage_control = 0
[    4.249187@1] <<-GTP-INFO->> GTP driver installing...
[    4.252951@1] hdmitx: cec: CEC init
[    4.256476@1] input: cec_input as /devices/virtual/input/input2
[    4.262194@2] hdmitx: cec: CEC task process
[    4.262362@1] hdmitx: cec: hdmitx_device->cec_init_ready:0x1
[    4.262363@1] ALSA device list:
[    4.262366@1]   #0: AML-M8AUDIO
[    4.278488@1] VFS: Cannot open root device "data" or unknown-block(0,0): error -6
[    4.285651@1] Please append a correct "root=" boot option; here are the available partitions:
[    4.294140@1] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[    4.302518@1] CPU: 1 PID: 1 Comm: swapper/0 Tainted: G        W    3.10.33 #1
[    4.309635@1] [<c00149c8>] (unwind_backtrace+0x0/0xf8) from [<c0011aac>] (show_stack+0x10/0x14)
[    4.318285@1] [<c0011aac>] (show_stack+0x10/0x14) from [<c06bcedc>] (panic+0x90/0x1ec)
[    4.326163@1] [<c06bcedc>] (panic+0x90/0x1ec) from [<c09c9f24>] (mount_block_root+0x1e0/0x298)
[    4.334732@1] [<c09c9f24>] (mount_block_root+0x1e0/0x298) from [<c09ca16c>] (prepare_namespace+0x12c/0x18c)
[    4.344429@1] [<c09ca16c>] (prepare_namespace+0x12c/0x18c) from [<c09c9bf0>] (kernel_init_freeable+0x184/0x1cc)
[    4.354473@1] [<c09c9bf0>] (kernel_init_freeable+0x184/0x1cc) from [<c06b8388>] (kernel_init+0x8/0xe4)
[    4.363739@1] [<c06b8388>] (kernel_init+0x8/0xe4) from [<c000e1d8>] (ret_from_fork+0x14/0x3c)
[    4.372222@3] CPU3: stopping
[    4.375079@3] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G        W    3.10.33 #1
[    4.382186@3] [<c00149c8>] (unwind_backtrace+0x0/0xf8) from [<c0011aac>] (show_stack+0x10/0x14)
[    4.390841@3] [<c0011aac>] (show_stack+0x10/0x14) from [<c0013294>] (handle_IPI+0xc4/0x180)
[    4.399152@3] [<c0013294>] (handle_IPI+0xc4/0x180) from [<c0008474>] (gic_handle_irq+0x54/0x5c)
[    4.407812@3] [<c0008474>] (gic_handle_irq+0x54/0x5c) from [<c000dd00>] (__irq_svc+0x40/0x70)
[    4.416293@3] Exception stack(0xdb28dfa0 to 0xdb28dfe8)
[    4.421492@3] dfa0: 00000003 00000000 00000256 00000000 db28c000 c0a16550 c06ceb34 c0a7866e
[    4.429803@3] dfc0: c0a7866e 410fc051 00000001 00000000 00000000 db28dfe8 c000f4c4 c000f4c8
[    4.438113@3] dfe0: 60000113 ffffffff
[    4.441755@3] [<c000dd00>] (__irq_svc+0x40/0x70) from [<c000f4c8>] (arch_cpu_idle+0x24/0x2c)
[    4.450157@3] [<c000f4c8>] (arch_cpu_idle+0x24/0x2c) from [<c0065f90>] (cpu_startup_entry+0xe8/0x140)
[    4.459333@3] [<c0065f90>] (cpu_startup_entry+0xe8/0x140) from [<008ba1c4>] (0x8ba1c4)
[    4.467208@0] CPU0: stopping
[    4.470066@0] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G        W    3.10.33 #1
[    4.477173@0] [<c00149c8>] (unwind_backtrace+0x0/0xf8) from [<c0011aac>] (show_stack+0x10/0x14)
[    4.485828@0] [<c0011aac>] (show_stack+0x10/0x14) from [<c0013294>] (handle_IPI+0xc4/0x180)
[    4.494139@0] [<c0013294>] (handle_IPI+0xc4/0x180) from [<c0008474>] (gic_handle_irq+0x54/0x5c)
[    4.502798@0] [<c0008474>] (gic_handle_irq+0x54/0x5c) from [<c000dd00>] (__irq_svc+0x40/0x70)
[    4.511280@0] Exception stack(0xc0a03f70 to 0xc0a03fb8)
[    4.516477@0] 3f60:                                     00000000 00000000 0000a29e 00000000
[    4.524791@0] 3f80: c0a02000 c0a16550 c06ceb34 c0a7866e c0a7866e 410fc051 00000001 00000000
[    4.533102@0] 3fa0: 00000000 c0a03fb8 c000f4c4 c000f4c8 60000113 ffffffff
[    4.539859@0] [<c000dd00>] (__irq_svc+0x40/0x70) from [<c000f4c8>] (arch_cpu_idle+0x24/0x2c)
[    4.548259@0] [<c000f4c8>] (arch_cpu_idle+0x24/0x2c) from [<c0065f90>] (cpu_startup_entry+0xe8/0x140)
[    4.557436@0] [<c0065f90>] (cpu_startup_entry+0xe8/0x140) from [<c09c9a18>] (start_kernel+0x2a8/0x2fc)
[    4.566700@0] [<c09c9a18>] (start_kernel+0x2a8/0x2fc) from [<00208070>] (0x208070)
[    4.574230@2] CPU2: stopping
[    4.577089@2] CPU: 2 PID: 0 Comm: swapper/2 Tainted: G        W    3.10.33 #1
[    4.584196@2] [<c00149c8>] (unwind_backtrace+0x0/0xf8) from [<c0011aac>] (show_stack+0x10/0x14)
[    4.592851@2] [<c0011aac>] (show_stack+0x10/0x14) from [<c0013294>] (handle_IPI+0xc4/0x180)
[    4.601162@2] [<c0013294>] (handle_IPI+0xc4/0x180) from [<c0008474>] (gic_handle_irq+0x54/0x5c)
[    4.609821@2] [<c0008474>] (gic_handle_irq+0x54/0x5c) from [<c000dd00>] (__irq_svc+0x40/0x70)
[    4.618303@2] Exception stack(0xdb28bfa0 to 0xdb28bfe8)
[    4.623501@2] bfa0: 00000002 00000000 000003a2 00000000 db28a000 c0a16550 c06ceb34 c0a7866e
[    4.631814@2] bfc0: c0a7866e 410fc051 00000001 00000000 00000000 db28bfe8 c000f4c4 c000f4c8
[    4.640123@2] bfe0: 60000113 ffffffff
[    4.643765@2] [<c000dd00>] (__irq_svc+0x40/0x70) from [<c000f4c8>] (arch_cpu_idle+0x24/0x2c)
[    4.652165@2] [<c000f4c8>] (arch_cpu_idle+0x24/0x2c) from [<c0065f90>] (cpu_startup_entry+0xe8/0x140)
[    4.661341@2] [<c0065f90>] (cpu_startup_entry+0xe8/0x140) from [<008ba1c4>] (0x8ba1c4)
 It is clear that the internal nand has not been recognized :
I also double checked if really I transferred my modified uInitrd with right driver  in the internal nand /dev/boot
abootimg -i /dev/boot > aboot.txt
abootimg -x /dev/boot
and yes it is mine uInitrd
My question is:
why if I boot from SD it boots and recognizes internal nand partition and when I boot from internal nand with same uInitrd the partitions don't exist anymore ?
Is there a way for letting init wait and be sure that aml_nftl_dev.ko is loaded, internal nand recognized and then go on?
some sleep, some wait, some early-init?
Thanks in adavence
