Anna Vahtera Posted April 11, 2020 Posted April 11, 2020 (edited) I cannot get the screen to rotate 90 or 270 degrees. Inverting it works like it should, but not "sideways". uname -a: Linux orangepilite2 5.4.20-sunxi64 #20.02.1 SMP Mon Feb 17 02:37:37 CET 2020 aarch64 GNU/Linux xrandr --version: xrandr program version 1.5.0 xrandr Screen 0: minimum 320 x 200, current 1024 x 768, maximum 8192 x 8192 HDMI-1 connected 1024x768+0+0 (normal left inverted right x axis y axis) 0mm x 0mm 1024x768 60.00* 800x600 60.32 56.25 848x480 60.00 640x480 59.94 /etc/X11/xorg.conf.d/01-armbian-defaults.conf: Section "Monitor" Identifier "Monitor0" Option "DPMS" "false" Option "Rotate" "right" EndSection Section "ServerFlags" Option "BlankTime" "0" Option "StandbyTime" "0" Option "SuspendTime" "0" Option "OffTime" "0" EndSection Screen is in "normal" orientation regardless of the rotate right option in the xorg conf. xrandr -o inverted works like it should and is noted in the xrandr output. Similarly with "normal". "right" and "left" however, do nothing. Or more precisely, they turn the display black for 1-2 seconds and then it returns to "normal" and displays the normal xrandr output, no "right" or "left" after resolution. echo <number> sudo tee /sys/class/graphics/fbcon/rotate_all works perfectly for all rotations on the console however. But of course it does not rotate X. EDIT: xrandr --output HDMI-1 --mode 848x480 works perfectly and sets the resolution like it should. xrandr --output HDMI-1 --mode 848x480 --rotate right does not. It blanks the display for 2 seconds, resets rotation to normal and resolution to 1024x7688, regardless of what they were before. Edited April 11, 2020 by Anna Vahtera added more
