_r9 Posted April 23, 2020 Share Posted April 23, 2020 Tested this on clearfog base, banana pi m64, banana pi m2+ ## Building and providing The elastic team doesn't provide deb packages for ARM devices. But together with docker, we're able to build the main executable for it. We will create a build directory which includes anything to install filebeat on a ARM device. So please stay inside the build directory the whole time you are using this tutorial. mkdir build && cd $_ ## Prepare source code First we will download, check and extract the source code of filebeat. Source: https://www.elastic.co/downloads/past-releases/filebeat-7-6-2 wget https://artifacts.elastic.co/downloads/beats/filebeat/filebeat-7.6.0-linux-x86.tar.gz wget https://artifacts.elastic.co/downloads/beats/filebeat/filebeat-7.6.0-linux-x86.tar.gz.sha512 sha512sum filebeat-7.6.0-linux-x86.tar.gz Extract and prepare tar xfz filebeat-7.6.0-linux-x86.tar.gz --transform 's/filebeat-7.6.0-linux-x86/filebeat-latest/' ## Using docker Install docker on any machine you want. We use a host with Debian Buster installed. ### Install docker on a Debian Buster x64 machine sudo apt install apt-transport-https ca-certificates curl gnupg2 software-properties-common wget -q -O - https://download.docker.com/linux/debian/gpg | sudo apt-key add - sudo add-apt-repository "deb [arch=amd64] https://download.docker.com/linux/debian stretch stable apt update sudo apt install docker-ce Instantiate a go container for cross-compilation (Debian Buster x64) Using latest docker go image docker run -it --rm -v `pwd`:/build golang:1.14 /bin/bash Inside the "go" docker container create filebeat for arm modules.listand arm64 go get github.com/elastic/beats cd /go/src/github.com/elastic/beats/filebeat/ git checkout v7.6.0 GOARCH=arm go build cp filebeat /build/filebeat-arm GOARCH=arm64 go build cp filebeat /build/filebeat-arm64 exit You can find the filebeat executeable inside your build directory. Leave it there for the moment. ## Download installation scripts I wrote an install script and collected a few files from other filebeat installations and uploaded them to github.com. You can find any information on the github repository itself. So we will clone the repository to the build directory. git clone https://github.com/rothirschtec/RT-Blog-elastic.git ## Filebeat configuration Now you have to copy the filebeat.yml so that that the install.sh we'll use later on can move it to the right place. cp filebeat-latest/filebeat.yml my-filebeat.yml and change it to your needs vi my-filebeat.yml ## Other configurations There are other configurations that might interests you. cp filebeat-latest/modules.d/YOUR_MODULE.yml.disabled my-YOUR_MODULE.yml Change this files too vi my-YOUR_MODULE.yml The install script will loop through all .yml files starting with my- and will copy them to the right direction ## Ready for installation The build directory is ready to use. You are able to upload the build directory to a ARM server of your choice and execute the install.sh there. rsync -av --exclude={".git","*.tar.gz","*.tar.gz.sha512"} ../build/ server-of-your-choice:/opt/build/ ssh server-of-your-choice cd /opt/build/ bash /opt/build/RT-Blog-elastic/install.sh rm -rf /opt/build/ ## Modules You're able to enable modules with the installation script. Create a file called modules.list inside the build directory and write the modules separated by whitespaces like iptables system apache Link to comment Share on other sites More sharing options...
