R_R Posted May 7, 2020 Share Posted May 7, 2020 Armbianmonitor: http://ix.io/2l82 Hello, We are using Orange Pi Zero with Armbian Bionic with Linux 5.4.20-sunxi armv7l GNU/Linux we are facing a problem, our orange pi heats up some time during processing and then freezes. We can ping the devices, but ssh stops working and all the application don't respond We followed the suggestion in thread: https://forum.armbian.com/topic/7848-mysterious-freeze-and-overheat-of-orange-pi-zero/?ct=1587196371&_fromLogin=1 But output of "armbianmonitor -m" is as below Stop monitoring using [ctrl]-[c] Time CPU load %cpu %sys %usr %nice %io %irq CPU C.St. 11:19:37: 1008MHz 0.18 6% 1% 4% 0% 0% 0% 76.4°C 0/4 11:19:42: 1008MHz 0.17 3% 0% 2% 0% 0% 0% 75.1°C 0/4 11:19:47: 1008MHz 0.15 3% 1% 2% 0% 0% 0% 75.2°C 0/4 11:19:52: 1008MHz 0.14 4% 1% 2% 0% 0% 0% 74.8°C 0/4 11:19:57: 1008MHz 0.13 3% 0% 2% 0% 0% 0% 75.3°C 0/4 11:20:02: 480MHz 0.12 4% 1% 2% 0% 0% 0% 75.7°C 0/4 11:20:08: 1008MHz 0.11 14% 3% 10% 0% 0% 0% 74.8°C 0/4 11:20:13: 1008MHz 0.18 15% 1% 13% 0% 0% 0% 78.7°C 0/4 11:20:18: 1008MHz 0.41 13% 3% 9% 0% 0% 0% 79.1°C 0/4 11:20:23: 480MHz 0.37 21% 5% 15% 0% 0% 0% 76.8°C 0/4 11:20:28: 1008MHz 0.34 5% 1% 3% 0% 0% 0% 75.0°C 0/4 11:20:33: 1008MHz 0.32 4% 1% 3% 0% 0% 0% 74.5°C 0/4^C As you can see there is a flip in frequency for a very short time, not enough to cool the CPU Also the content of /sys/devices/system/cpu/cpufreq/ondemand/sampling_rate is 200000 So what could be the reason that the device freezes. Thanks, Link to comment Share on other sites More sharing options...
