Romber Posted May 29, 2020 Author Posted May 29, 2020 42 minutes ago, xwiggen said: The only other possible explanation I can think of not reaching NTP servers is that your ISP is blocking remote NTP servers (DDOS mitigation), that happens rarely, is easily checked by 'ntpdate -vd pool.ntp.org' (non privileged port, so not blocked), or even simpler, use your gateway ip as most routers broadcast it anyway. destructor@orangepiplus:~$ sudo ntpdate -vd pool.ntp.org 26 May 16:09:51 ntpdate[17774]: ntpdate 4.2.8p12@1.3728-o (1) Looking for host pool.ntp.org and service ntp 167.86.76.95 reversed to jonasled.de jonasled.de forward check lookup fail: Unknown error host found : 167.86.76.95 (jonasled.de) transmit(167.86.76.95) receive(167.86.76.95) transmit(212.83.179.156) receive(212.83.179.156) transmit(185.244.195.159) receive(185.244.195.159) transmit(108.61.56.35) receive(108.61.56.35) transmit(167.86.76.95) transmit(212.83.179.156) receive(212.83.179.156) transmit(185.244.195.159) receive(185.244.195.159) transmit(108.61.56.35) receive(108.61.56.35) transmit(167.86.76.95) transmit(212.83.179.156) transmit(185.244.195.159) receive(185.244.195.159) transmit(108.61.56.35) receive(108.61.56.35) transmit(167.86.76.95) transmit(212.83.179.156) transmit(185.244.195.159) receive(185.244.195.159) transmit(108.61.56.35) receive(108.61.56.35) server 167.86.76.95, port 123 stratum 2, precision -23, leap 00, trust 000 refid [237.17.204.95], root delay 0.013870, root dispersion 0.061859 transmitted 4, in filter 4 reference time: e27bd9db.ec609209 Fri, May 29 2020 21:58:35.923 originate timestamp: e27be072.e319e100 Fri, May 29 2020 22:26:42.887 transmit timestamp: e27793a5.b078107b Tue, May 26 2020 16:09:57.689 filter delay: 0.07034 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000 filter offset: 281811.1 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 delay 0.07034, dispersion 56.00000 offset 281811.175392 server 212.83.179.156, port 123 stratum 2, precision -24, leap 00, trust 000 refid [35.192.231.136], root delay 0.008606, root dispersion 0.047073 transmitted 4, in filter 4 reference time: e27bd87d.a9d9bf50 Fri, May 29 2020 21:52:45.663 originate timestamp: e27be075.173b62e5 Fri, May 29 2020 22:26:45.090 transmit timestamp: e27793a5.e3aca77e Tue, May 26 2020 16:09:57.889 filter delay: 0.07707 0.07664 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000 filter offset: 281811.1 281811.1 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 delay 0.07664, dispersion 24.00000 offset 281811.175878 server 185.244.195.159, port 123 stratum 3, precision -25, leap 00, trust 000 refid [80.237.128.149], root delay 0.022736, root dispersion 0.025070 transmitted 4, in filter 4 reference time: e27bde3d.b21e1ba7 Fri, May 29 2020 22:17:17.695 originate timestamp: e27be079.4937a2cc Fri, May 29 2020 22:26:49.286 transmit timestamp: e27793a6.16dd6640 Tue, May 26 2020 16:09:58.089 filter delay: 0.06255 0.06229 0.06241 0.06226 0.00000 0.00000 0.00000 0.00000 filter offset: 281811.1 281811.1 281811.1 281811.1 0.000000 0.000000 0.000000 0.000000 delay 0.06226, dispersion 0.00000 offset 281811.178343 server 108.61.56.35, port 123 stratum 2, precision -22, leap 00, trust 000 refid [198.30.92.2], root delay 0.023178, root dispersion 0.021896 transmitted 4, in filter 4 reference time: e27bdefd.9d69293c Fri, May 29 2020 22:20:29.614 originate timestamp: e27be079.89bbf28f Fri, May 29 2020 22:26:49.538 transmit timestamp: e27793a6.4a10719b Tue, May 26 2020 16:09:58.289 filter delay: 0.16010 0.15996 0.15985 0.15987 0.00000 0.00000 0.00000 0.00000 filter offset: 281811.1 281811.1 281811.1 281811.1 0.000000 0.000000 0.000000 0.000000 delay 0.15985, dispersion 0.00000 offset 281811.181579 26 May 16:09:59 ntpdate[17774]: step time server 167.86.76.95 offset 281811.175392 sec destructor@orangepiplus:~$
Romber Posted May 29, 2020 Author Posted May 29, 2020 I've done armbianmonitor -U and got this output, maybe it help to resolve my problemhttps://www.dropbox.com/s/49m3f7w6h2lfujf/armbianmonitor.txt?dl=0
Romber Posted June 2, 2020 Author Posted June 2, 2020 I've reinstalled chrony and problem went away! Thank all for attention
