I'm working with mpd on armbian 20.02.0 with i2s device and found some problem: periodically sound is interrupted. I enable verbose logging in mpd and I get message:
May 20 04:36 : alsa_output: Underrun on ALSA device "hw:0,0"
May 20 04:37 : alsa_output: Underrun on ALSA device "hw:0,0"
This is not permanent and some time maybe work fine, but if it starts, messages go with an interval of 10-11 seconds until I restart mpd.
I rebuilt armbian with enabled ALSA debug options CONFIG_SND_PCM_XRUN_DEBUG, CONFIG_SND_VERBOSE_PROCFS, CONFIG_SND_DEBUG and try again.
This is result with my i2s card and echo 3 > /proc/asound/card0/pcm0p/xrun_debug
May 20 03:30:59 localhost kernel: [ 1099.726101] i2s_clock_board: i2s_clock_board_trigger
May 20 03:30:59 localhost kernel: [ 1099.726136] I2S Command State 0
May 20 03:30:59 localhost kernel: [ 1099.726200] asoc-simple-card sound_i2s: XRUN: pcmC1D0p:0
May 20 03:30:59 localhost kernel: [ 1099.726213] CPU: 0 PID: 1348 Comm: kworker/0:1 Tainted: G C O 5.4.18-sunxi #20.02.0
May 20 03:30:59 localhost kernel: [ 1099.726216] Hardware name: Allwinner sun7i (A20) Family
May 20 03:30:59 localhost kernel: [ 1099.726239] Workqueue: events_freezable_power_ thermal_zone_device_check
May 20 03:30:59 localhost kernel: [ 1099.726268] [<c010da8d>] (unwind_backtrace) from [<c010a0ad>] (show_stack+0x11/0x14)
May 20 03:30:59 localhost kernel: [ 1099.726282] [<c010a0ad>] (show_stack) from [<c093704f>] (dump_stack+0x6f/0x7c)
May 20 03:30:59 localhost kernel: [ 1099.726344] [<c093704f>] (dump_stack) from [<bf856305>] (__snd_pcm_xrun+0x101/0x108 [snd_pcm])
May 20 03:30:59 localhost kernel: [ 1099.726384] [<bf856305>] (__snd_pcm_xrun [snd_pcm]) from [<bf8563b3>] (snd_pcm_update_state+0xa7/0xac [snd_pcm])
May 20 03:30:59 localhost kernel: [ 1099.726420] [<bf8563b3>] (snd_pcm_update_state [snd_pcm]) from [<bf856549>] (snd_pcm_update_hw_ptr0+0x191/0x5a4 [snd_pcm])
May 20 03:30:59 localhost kernel: [ 1099.726455] [<bf856549>] (snd_pcm_update_hw_ptr0 [snd_pcm]) from [<bf8569a7>] (snd_pcm_period_elapsed+0x4b/0x90 [snd_pcm])
May 20 03:30:59 localhost kernel: [ 1099.726483] [<bf8569a7>] (snd_pcm_period_elapsed [snd_pcm]) from [<bf84928f>] (dmaengine_pcm_dma_complete+0x3b/0x3c [snd_pcm_dmaengine])
May 20 03:30:59 localhost kernel: [ 1099.726500] [<bf84928f>] (dmaengine_pcm_dma_complete [snd_pcm_dmaengine]) from [<c05f9fdf>] (vchan_complete+0x133/0x140)
May 20 03:30:59 localhost kernel: [ 1099.726517] [<c05f9fdf>] (vchan_complete) from [<c0120413>] (tasklet_action_common.constprop.3+0x2f/0x80)
May 20 03:30:59 localhost kernel: [ 1099.726531] [<c0120413>] (tasklet_action_common.constprop.3) from [<c01022f7>] (__do_softirq+0xdf/0x288)
May 20 03:30:59 localhost kernel: [ 1099.726541] [<c01022f7>] (__do_softirq) from [<c0120333>] (irq_exit+0x7b/0x90)
May 20 03:30:59 localhost kernel: [ 1099.726555] [<c0120333>] (irq_exit) from [<c0160233>] (__handle_domain_irq+0x47/0x84)
May 20 03:30:59 localhost kernel: [ 1099.726570] [<c0160233>] (__handle_domain_irq) from [<c05ca5dd>] (gic_handle_irq+0x39/0x6c)
May 20 03:30:59 localhost kernel: [ 1099.726581] [<c05ca5dd>] (gic_handle_irq) from [<c0101ae5>] (__irq_svc+0x65/0x94)
May 20 03:30:59 localhost kernel: [ 1099.726586] Exception stack(0xedae7e30 to 0xedae7e78)
May 20 03:30:59 localhost kernel: [ 1099.726593] 7e20: 00000fe0 00000006 fac81000 c010d0f1
May 20 03:30:59 localhost kernel: [ 1099.726603] 7e40: c1054fa8 332c1eac 00005dbf 0000008d 00000045 ecf17b54 c0c51994 1ffffc70
May 20 03:30:59 localhost kernel: [ 1099.726611] 7e60: ee405a78 edae7e80 c010d105 c0935016 200f0033 ffffffff
May 20 03:30:59 localhost kernel: [ 1099.726626] [<c0101ae5>] (__irq_svc) from [<c0935016>] (__timer_delay+0x26/0x34)
May 20 03:30:59 localhost kernel: [ 1099.726644] [<c0935016>] (__timer_delay) from [<bfa2d3c5>] (sun4i_gpadc_read+0x10d/0x15c [sun4i_gpadc_iio])
May 20 03:30:59 localhost kernel: [ 1099.726677] [<bfa2d3c5>] (sun4i_gpadc_read [sun4i_gpadc_iio]) from [<bfa2d4f5>] (sun4i_gpadc_temp_read+0x29/0x70 [sun4i_gpadc_iio])
May 20 03:30:59 localhost kernel: [ 1099.726691] [<bfa2d4f5>] (sun4i_gpadc_temp_read [sun4i_gpadc_iio]) from [<bfa2d561>] (sun4i_gpadc_get_temp+0x25/0x54 [sun4i_gpadc_iio])
May 20 03:30:59 localhost kernel: [ 1099.726703] [<bfa2d561>] (sun4i_gpadc_get_temp [sun4i_gpadc_iio]) from [<c07a456f>] (thermal_zone_get_temp+0x33/0x44)
May 20 03:30:59 localhost kernel: [ 1099.726717] [<c07a456f>] (thermal_zone_get_temp) from [<c07a1e21>] (thermal_zone_device_update.part.4+0x21/0xe0)
May 20 03:30:59 localhost kernel: [ 1099.726730] [<c07a1e21>] (thermal_zone_device_update.part.4) from [<c012f6d9>] (process_one_work+0x179/0x3cc)
May 20 03:30:59 localhost kernel: [ 1099.726740] [<c012f6d9>] (process_one_work) from [<c012fa2f>] (worker_thread+0x103/0x410)
May 20 03:30:59 localhost kernel: [ 1099.726752] [<c012fa2f>] (worker_thread) from [<c01340a5>] (kthread+0x109/0x10c)
May 20 03:30:59 localhost kernel: [ 1099.726763] [<c01340a5>] (kthread) from [<c01010f9>] (ret_from_fork+0x11/0x38)
May 20 03:30:59 localhost kernel: [ 1099.726767] Exception stack(0xedae7fb0 to 0xedae7ff8)
May 20 03:30:59 localhost kernel: [ 1099.726773] 7fa0: 00000000 00000000 00000000 00000000
May 20 03:30:59 localhost kernel: [ 1099.726782] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
May 20 03:30:59 localhost kernel: [ 1099.726789] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
May 20 03:30:59 localhost kernel: [ 1099.812099] i2s_clock_board: i2s_clock_board_trigger
May 20 03:30:59 localhost kernel: [ 1099.812156] I2S Command State 1
I changed device output to analog codec, rebooted and create armbianmonitor log. Messages about snd_pcm* like messages i2s device, but haven't messages about sun4i_gpadc*.
I'm confused and don't know what make further.
I played files from connected sata hdd and NAS, but it does not matter. And maybe this issue related kworker problem? Because I periodically see kworker/0:4-events_freezable_power_ in top
Question
nikkov
May 20 04:36 : alsa_output: Underrun on ALSA device "hw:0,0" May 20 04:36 : alsa_output: Underrun on ALSA device "hw:0,0" May 20 04:37 : alsa_output: Underrun on ALSA device "hw:0,0"
Link to comment
Share on other sites
1 answer to this question
