Peter1 Posted May 28, 2020 Posted May 28, 2020 (edited) Hello, in a Overlay (compatible = "simple-panel-dsi";) I have the following proerties: reset-gpios = <&gpio8 3 1>; /* GPIO8_A3 */ reset-delay-ms = <10>; enable-delay-ms = <60>; ... in the panel-simple.c driver File I can find the properties "reset-delay-ms", "enable-delay-ms" - but not the "reset-gpios" property. Even though the reset at GPIO8_A3 is working correctly. I also had no success to find this property in another file... so I'm very confused about where or in which driver / include is this property defined/specified? I also have tried to search "reset-gpios" in all files with grep, see below, but I could not find a related driver/include file that use this property. sudo grep --include=\*.{c,h,dtsi,dts} -rnw '/home/yy/build/cache/' -e "reset-gpios" in the panel-simple.c driver File I can find the property "reset" instead of "reset-gpios", but if I use "reset = <..." in my Overlay - the reset at GPIO8_A3 does not work. So I'm really wondering why that "reset-gpios" is working? Maybe someone can give a hint? Many thanks Peter EDIT: can someone move this Thread to "Common Issues" ? Edited May 28, 2020 by Peter1
martinayotte Posted May 28, 2020 Posted May 28, 2020 3 hours ago, Peter1 said: but I could not find a related driver/include file that use this property. you should look here in cache/sources/linux-mainline/linux-5.4.y/Documentation/devicetree/bindings/display/
