Damien Wang Posted May 28, 2020 Posted May 28, 2020 Dear community, Im trying to get an USB gadget via OTG running on Linux (OrangePI Lite 2). As OPI Lite 2 doesn't support 'USB-UART/Gadget mode' like OPI Zero, I just modify the build config and rebuild kernel by myself as steps shown below. 1. I change the mode of USB from host to otg in the: https://github.com/armbian/build/blob/master/patch/kernel/sunxi-current/board-h6-orangepi-lite2-fix-missing-all.patch 2. I add MODULES_CURRENT="g_serial" & SERIALCON="ttyS0,ttyGS0" to build/config/boards/orangepilite2.conf file. 3. I rebuild the kernel and flashed the new image to sdcard. Unfortunately, I find it doesn't work, the WIN10 does find a USB device but cannot recognize it. In win10 device manager, it shows "Unknown USB Device (Device Descriptor Request Failed)" I was wondering if anyone tried 'USB-UART/Gadget mode' in OPI Lite2, could you help give some suggestions? Here is some messages when I tried debug this issue: root@orangepilite2:~# cat /etc/modules g_serial root@orangepilite2:~# dmesg | grep gadget [ 5.955959] g_serial gadget: Gadget Serial v2.4 [ 5.955967] g_serial gadget: g_serial ready root@orangepilite2:~# ls /sys/bus/platform/devices/sunxi_usb_udc/ ls: cannot access '/sys/bus/platform/devices/sunxi_usb_udc/': No such file or directory root@orangepilite2:~# ll /sys/kernel/config/usb_gadget/ total 0 root@orangepilite2:~# ls /sys/class/udc musb-hdrc.5.auto root@orangepilite2:~# ls /dev/tty* /dev/tty /dev/tty2 /dev/tty31 /dev/tty43 /dev/tty55 /dev/ttyGS0 /dev/tty0 /dev/tty20 /dev/tty32 /dev/tty44 /dev/tty56 /dev/ttyS0 /dev/tty1 /dev/tty21 /dev/tty33 /dev/tty45 /dev/tty57 /dev/ttyS2 /dev/tty10 /dev/tty22 /dev/tty34 /dev/tty46 /dev/tty58 /dev/ttyS3 /dev/tty11 /dev/tty23 /dev/tty35 /dev/tty47 /dev/tty59 /dev/ttyS4 /dev/tty12 /dev/tty24 /dev/tty36 /dev/tty48 /dev/tty6 /dev/ttyS5 /dev/tty13 /dev/tty25 /dev/tty37 /dev/tty49 /dev/tty60 /dev/ttyS6 /dev/tty14 /dev/tty26 /dev/tty38 /dev/tty5 /dev/tty61 /dev/ttyS7 /dev/tty15 /dev/tty27 /dev/tty39 /dev/tty50 /dev/tty62 /dev/tty16 /dev/tty28 /dev/tty4 /dev/tty51 /dev/tty63 /dev/tty17 /dev/tty29 /dev/tty40 /dev/tty52 /dev/tty7 /dev/tty18 /dev/tty3 /dev/tty41 /dev/tty53 /dev/tty8 /dev/tty19 /dev/tty30 /dev/tty42 /dev/tty54 /dev/tty9
