vk81 Posted June 19, 2020 Share Posted June 19, 2020 Hello, I use the NanoPi Neo (4.19.38-sunxi, Armbian #5.85 ) to pool an external device over /dev/ttyS1 serial port. At flashing moment of the external device, I should switch pins of ttyS1 to input mode by using bash commands #!/bin/bash firmware=`ls update_*.hex` echo "198" > /sys/class/gpio/export echo "199" > /sys/class/gpio/export echo "in" > /sys/class/gpio/gpio198/direction echo "in" > /sys/class/gpio/gpio199/direction # device update flash -P linuxgpio -b 40000 $firmware echo "198" > /sys/class/gpio/unexport echo "199" > /sys/class/gpio/unexport Is it possible to change up the mode of pins to the alternate function (ALT5) without the rebooting the OS? Link to comment Share on other sites More sharing options...
sfx2000 Posted July 11, 2020 Share Posted July 11, 2020 While I'd like to give a foxing clever response... I'm not seeing a way to do what you're asking - it's late in the day for me, so I'm sure someone will find a solution perhaps.. GPIO's are assigned by uboot/device tree/DT overlay on boot Link to comment Share on other sites More sharing options...
