Hey Community!
I installed Armbian Jessie without any problem to SD Card. HDMI was the default screen output, and I changed to VGA with the help of this topic: http://forum.armbian.com/index.php/topic/445-debian-images-cubietruck-vga-output-problem/
The next boot went fine, VGA works. But, after the system upgrade-update, after the reboot the screen is HDMI again. I checked the card's file system with NAND ubuntu, the output order (the 4 row) is 4-4-4-4. So, I can't understand. The VGA monitor is fine, working in the next few phase before the kernel starts, but after that: just blinking. If I connect the Samsung HDTV, the desktop present there....
Thanks for the advices!
Antal
You have to redo the change described in that post for every upgrade.
The upgrade affects also the file /boot/bin/cubietruck.bin so your changes get lost.
