HI,
I am using armbian config to set up an hotspot on orangepipcplus
I have eth0 and eth1, two different interface connected to the internet
when i set up the hotspot, wlan0 will access internet through eth0
I would like to change this on the fly then so that wlan0 can access internet through eth1.
I tried a lot of things but not getting anywhere...
I looked at the source and tried to redo clear iptables/ apply new iptables nat config but it is not working
https://github.com/armbian/config/blob/master/debian-config-jobs#L617
I just changed $DEFAULT_ADAPTER to eth1, and keep $WIRELESS_ADAPTER to wlan0 to run:
# Clear iptables
iptables-save | awk '/^[*]/ { print $1 } /^:[A-Z]+ [^-]/ { print $1 " ACCEPT" ; } /COMMIT/ { print $0; }' | iptables-restore
# - Apply iptables
iptables -t nat -A POSTROUTING -o $DEFAULT_ADAPTER -j MASQUERADE
iptables -A FORWARD -i $DEFAULT_ADAPTER -o $WIRELESS_ADAPTER -m state --state RELATED,ESTABLISHED -j ACCEPT
iptables -A FORWARD -i $WIRELESS_ADAPTER -o $DEFAULT_ADAPTER -j ACCEPT
# - Save IP tables, applied during ifup in /etc/network/interfaces.
iptables-save > /etc/iptables.ipv4.nat
But then this is not working, no internet access. (Noting I verified internet access through curl --interface eth1 and working perfectly)
If I revert back to eth0, working again properly.
What do I miss to route traffic through eth1 properly?
Thanks
Louis
Edited by lmdc45
No... I understand the gateway for eth1 is link to this interface eth1...
Now seems a good point so I would need to change gateway on wlan0 to match gateway of eth1.
I am a bit confused quite new to linux and looking for a good book/pdf to get basics infos, any idea what I could get?
try
ip route | grep default
ip -4 addr show scope global
cat /etc/network/interfaces
the default gateway is where all internet traffic will be sent. Try the changes you made originally, then see how it affects your default gateway.
I think you will need to affect a change to the dgw in addition to your other changes.
you seem advanced with iptables but maybe these might give some references
https://www.unixmen.com/how-to-find-default-gateway-in-linux/
https://www.systutorials.com/setting-up-gateway-using-iptables-and-route-on-linux/
https://www.cyberciti.biz/faq/ip-route-add-network-command-for-linux-explained/
https://serverfault.com/questions/567487/iptables-packet-forwarding-to-one-of-two-gateways-depending-on-origin
Thanks for prompting me to look this up. I've never really dove into iptables, and I found these
https://www.linode.com/docs/security/firewalls/control-network-traffic-with-iptables/
is nftables in armbian yet? I didn't know about nftables until I read a comment from one of the above threads...
I am just ok to copy and paste the code for the iptables and change as required but have not much knowledge yet. I got javscript/nodejs background so quite ok to understand the code if I see it but cannot make it.
nftables should be in armbian as latest version is based on Debian 10 buster, so shoud go though nftables probably.
ip route gives me:
root@orangepipcplus:~# ip route
default via 192.168.8.1 dev eth0 proto dhcp metric 50
default via 172.20.10.1 dev eth1 proto dhcp metric 78
169.254.0.0/16 dev eth0 scope link metric 1000
172.17.0.0/16 dev docker0 proto kernel scope link src 172.17.0.1 linkdown
172.20.10.0/28 dev eth1 proto kernel scope link src 172.20.10.5 metric 78
172.24.1.0/24 dev wlan0 proto kernel scope link src 172.24.1.1
192.168.8.0/24 dev eth0 proto kernel scope link src 192.168.8.104 metric 50
ip -4 addr show scope global :
root@orangepipcplus:~# ip -4 addr show scope global
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
    inet 192.168.8.104/24 brd 192.168.8.255 scope global dynamic noprefixroute eth0
       valid_lft 78604sec preferred_lft 78604sec
3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
    inet 172.24.1.1/24 brd 172.24.1.255 scope global wlan0
       valid_lft forever preferred_lft forever
5: docker0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default
    inet 172.17.0.1/16 brd 172.17.255.255 scope global docker0
45: eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    inet 172.20.10.5/28 brd 172.20.10.15 scope global dynamic noprefixroute eth1
       valid_lft 85245sec preferred_lft 85245sec
and cat /etc/network/interfaces:
root@orangepipcplus:~# cat /etc/network/interfaces
source /etc/network/interfaces.d/*
# Network is managed by Network manager
auto lo
iface lo inet loopback
and in /etc/network/interfaces.d there is only one file armbian.ap.nat with:
root@orangepipcplus:/etc/network/interfaces.d# cat armbian.ap.nat
# armbian NAT hostapd
allow-hotplug wlan0
iface wlan0 inet static
        address 172.24.1.1
        netmask 255.255.255.0
        network 172.24.1.0
        broadcast 172.24.1.255
Noting I understand amrbian-config use nmcli so here is the output as well:
nmcli device show :
GENERAL.DEVICE:                         eth0
GENERAL.TYPE:                           ethernet
GENERAL.HWADDR:                         02:81:13:E9:A3:CA
GENERAL.MTU:                            1500
GENERAL.STATE:                          100 (connected)
GENERAL.CONNECTION:                     Wired connection 1
GENERAL.CON-PATH:                       /org/freedesktop/NetworkManager/ActiveConnection/1
WIRED-PROPERTIES.CARRIER:               on
IP4.ADDRESS[1]:                         192.168.8.104/24
IP4.GATEWAY:                            192.168.8.1
IP4.ROUTE[1]:                           dst = 0.0.0.0/0, nh = 192.168.8.1, mt = 50
IP4.ROUTE[2]:                           dst = 169.254.0.0/16, nh = 0.0.0.0, mt = 1000
IP4.ROUTE[3]:                           dst = 192.168.8.0/24, nh = 0.0.0.0, mt = 50
IP4.DNS[1]:                             192.168.8.1
IP6.ADDRESS[1]:                         fe80::4670:cd96:29fa:c462/64
IP6.GATEWAY:                            fe80::e2a3:acff:fe58:f6f3
IP6.ROUTE[1]:                           dst = ::/0, nh = fe80::e2a3:acff:fe58:f6f3, mt = 100
IP6.ROUTE[2]:                           dst = fe80::/64, nh = ::, mt = 100
IP6.ROUTE[3]:                           dst = ff00::/8, nh = ::, mt = 256, table=255
IP6.DNS[1]:                             fe80::e2a3:acff:fe58:f6f3
GENERAL.DEVICE:                         eth1
GENERAL.HWADDR:                         62:8B:0E:AD:DB:49
GENERAL.MTU:                            1500
GENERAL.CONNECTION:                     Wired connection 2
GENERAL.CON-PATH:                       /org/freedesktop/NetworkManager/ActiveConnection/12
IP4.ADDRESS[1]:                         172.20.10.5/28
IP4.GATEWAY:                            172.20.10.1
IP4.ROUTE[1]:                           dst = 0.0.0.0/0, nh = 172.20.10.1, mt = 78
IP4.ROUTE[2]:                           dst = 172.20.10.0/28, nh = 0.0.0.0, mt = 78
IP4.DNS[1]:                             172.20.10.1
IP6.ADDRESS[1]:                         fe80::7a8d:2c94:4a6a:c639/64
IP6.GATEWAY:                            --
IP6.ROUTE[1]:                           dst = fe80::/64, nh = ::, mt = 101
IP6.ROUTE[2]:                           dst = ff00::/8, nh = ::, mt = 256, table=255
GENERAL.DEVICE:                         docker0
GENERAL.TYPE:                           bridge
GENERAL.HWADDR:                         02:42:5E:DD:46:90
GENERAL.MTU:                            1500
GENERAL.STATE:                          10 (unmanaged)
GENERAL.CONNECTION:                     --
GENERAL.CON-PATH:                       --
IP4.ADDRESS[1]:                         172.17.0.1/16
IP4.GATEWAY:                            --
IP4.ROUTE[1]:                           dst = 172.17.0.0/16, nh = 0.0.0.0, mt = 0
IP6.GATEWAY:                            --
GENERAL.DEVICE:                         lo
GENERAL.TYPE:                           loopback
GENERAL.HWADDR:                         00:00:00:00:00:00
GENERAL.MTU:                            65536
IP4.ADDRESS[1]:                         127.0.0.1/8
IP4.GATEWAY:                            --
IP6.ADDRESS[1]:                         ::1/128
IP6.GATEWAY:                            --
IP6.ROUTE[1]:                           dst = ::1/128, nh = ::, mt = 256
GENERAL.DEVICE:                         wlan0
GENERAL.TYPE:                           wifi
GENERAL.HWADDR:                         12:81:13:E9:A3:CA
GENERAL.MTU:                            1500
IP4.ADDRESS[1]:                         172.24.1.1/24
IP4.GATEWAY:                            --
IP4.ROUTE[1]:                           dst = 172.24.1.0/24, nh = 0.0.0.0, mt = 0
IP6.ADDRESS[1]:                         fe80::1081:13ff:fee9:a3ca/64
IP6.GATEWAY:                            --
IP6.ROUTE[1]:                           dst = fe80::/64, nh = ::, mt = 256
I also tried to set up a bond conenction before I understand a bond is only for two cables connected to the same gateway... Took ne too long to get that unfortunately.
Idea would be to have a new connection 'con0' that is linked to eth0 and eth1, and then I could bring eth0 or eth1 up or down, the wifi will be connected to con0 and would not notice.
A bit like the bond system 'active-backup', but with two differents IP addresses and gateway on eth0 and eth1.
I am sure there is a proper linux way to do this but could not yet find it.
Also
root@orangepipcplus:/etc/network/interfaces.d# iptables -nvL
Chain INPUT (policy ACCEPT 50287 packets, 14M bytes)
 pkts bytes target     prot opt in     out     source               destination
Chain FORWARD (policy ACCEPT 3137 packets, 283K bytes)
 422K  451M ACCEPT     all  --  eth0   wlan0   0.0.0.0/0            0.0.0.0/0            state RELATED,ESTABLISHED
 307K   36M ACCEPT     all  --  wlan0  eth0    0.0.0.0/0            0.0.0.0/0
Chain OUTPUT (policy ACCEPT 51731 packets, 12M bytes)
root@orangepipcplus:~# iptables --t nat  -nvL
Chain PREROUTING (policy ACCEPT 22926 packets, 2106K bytes)
Chain INPUT (policy ACCEPT 9720 packets, 672K bytes)
Chain POSTROUTING (policy ACCEPT 6247 packets, 392K bytes)
21594 1783K MASQUERADE  all  --  *      eth0    0.0.0.0/0            0.0.0.0/0
Chain OUTPUT (policy ACCEPT 20645 packets, 1600K bytes)
From what I see the only 'bridge' that connect wlan0 and eth0 is on iptables rules, and I don't understand why the connection do not go trhough when I change these rules from eth0 to eth1.
iptables taxes my ability already lol but I read a few places that iptables and network manager don't always play well together? In Official Ubuntu iptables documentation it says "WARNING: Iptables and NetworkManager can conflict."  Perhaps explore if this is happening to you.
https://askubuntu.com/questions/904048/network-manager-is-adding-unwanted-rules-to-iptables
https://feeding.cloud.geek.nz/posts/using-iptables-with-network-manager/
note the pre-up statements ...
and dumb question ... are we sure that your second adapter is called eth1 and not something like wlp3s0?
I think this is as far as I can help you :\
https://wiki.nftables.org/wiki-nftables/index.php/Main_Page
Thank you for your help
I though that any ip packet directed to eth0 would use eth0 gateway, and any packet using eth1 would use eth1 gateway. But its not the case and any packet directed to addresses in the outside wold would take the same gateway, the one with lowest metric.
I also had to change the metric of the ip route so that if wlan0 is directed to eth1, eth1 gateway will be used. Seems that packet were directed to eth1 but using eth0 gateway and then never hearing back from them.
had to change the metric with
nmcli con mod 'eth1 connection' connection.route-metric 45 (or any lowest number)
and then
nmcli con up 'eth1 connection'
to activate, and internet is working fine then through eth1.
Only issue is that active socket are disconnected, I would like to find a way to keep socket active but it is not a big issue for me at this stage.
then I monitor network with nmcli monitor and change to eth1 as required is eth1 is connected, and swith back to eth0 when eth1 is disconnected...
Seeems like there is a way to do this a bit more easily with network configuration file but would mean not using nmcli anymore and I guess armbian-config will not be ok with that as it is managing connection through nmcli
at least the above is working, seems like there is not confilct between nmcli and iptables, working ok together
Awesome glad you are able to get it going.
Expand
That sounds like a challenge as some connections might see that as a security risk.
Maybe you write up a little tutorial now that you have it figured out? ;]
Expand
I understand maybe a bridge could do it?
Would create a bridge between eth0 and wlan0, then on connection of eth1 could disconnect eth0 from the bridge and connect eth1. I am a very beginner in linux so not sure.
At this stage I use a copy of the armbian-config script to switch the interface, with a monitor to trigger the switch.
#!/bin/bash
current_interface='eth0'
nmcli dev monitor | while read event
do
    echo $event
    case $event in
        "eth1: device removed")
            if [ "$current_interface" != "eth0" ]; then
                bash /root/lscript/switch.sh "eth0"
                current_interface="eth0"
                echo -e "\t switched to eth0"
            fi
        "eth1: connected")
            if [ "$current_interface" != "eth1" ]; then
                bash /root/lscript/switch.sh "eth1"
                current_interface="eth1"
                echo -e "\t switched to eth1"
            fi
            echo -e "\t unmanaged event "
    esac
done
#and in switch.sh :
#!/bin/bash
DEFAULT_ADAPTER=$1
WIRELESS_ADAPTER="wlan0"
function switch_int ()
    # Clear iptables
    /sbin/iptables-save | awk '/^[*]/ { print $1 } /^:[A-Z]+ [^-]/ { print $1 " ACCEPT" ; } /COMMIT/ { print $0; }' | /sbin/iptables-restore
    # - Apply iptables
    /sbin/iptables -t nat -A POSTROUTING -o $DEFAULT_ADAPTER -j MASQUERADE
    /sbin/iptables -A FORWARD -i $DEFAULT_ADAPTER -o $WIRELESS_ADAPTER -m state --state RELATED,ESTABLISHED -j ACCEPT
    /sbin/iptables -A FORWARD -i $WIRELESS_ADAPTER -o $DEFAULT_ADAPTER -j ACCEPT
    /sbin/iptables-save > /etc/iptables.ipv4.nat
    sed -i 's/^bridge=.*/#&/' /etc/hostapd.conf
    #sed -e 's/exit 0//g' -i /etc/rc.local
    # workaround if hostapd is too slow
    #echo "service dnsmasq start" >> /etc/rc.local
    #echo "iptables-restore < /etc/iptables.ipv4.nat" >> /etc/rc.local
    #echo "exit 0" >> /etc/rc.local
    systemctl stop armbian-restore-iptables.service
    systemctl disable armbian-restore-iptables.service
    cat <<-EOF > /etc/systemd/system/armbian-restore-iptables.service
    [Unit]
    Description="Restore IP tables"
    [Timer]
    OnBootSec=20Sec
    [Service]
    Type=oneshot
    ExecStart=/sbin/iptables-restore /etc/iptables.ipv4.nat
    [Install]
    WantedBy=sysinit.target
EOF
    systemctl enable armbian-restore-iptables.service
function select_default_interface ()
	# set highest metric to default adaptor
	HIGHEST_METRIC=$(nmcli -t -f UUID,TYPE,DEVICE connection show --active | grep $DEFAULT_ADAPTER | sed 's/:.*$//')
	# set metric to 50
	nmcli connection modify $HIGHEST_METRIC ipv4.route-metric 50 2> /dev/null
	#nmcli con down $HIGHEST_METRIC > /dev/null
	nmcli con up $HIGHEST_METRIC > /dev/null
	METRIC=77
	# set others wired
	REMAINING=( `nmcli -t -f UUID,TYPE,DEVICE connection show --active | grep ethernet | grep -v $DEFAULT_ADAPTER | sed 's/:.*$//'` )
	if [[ ${#REMAINING[@]} -ge 1 ]]; then
		for i in "${REMAINING[@]}"
		do
			METRIC=$(( $METRIC + 1 ))
			nmcli connection modify ${i} ipv4.route-metric $METRIC
			#nmcli con down ${i} > /dev/null
			nmcli con up ${i} > /dev/null
		done
	fi
	# set other wireless
	METRIC=88
	REMAINING=( `nmcli -t -f UUID,TYPE,DEVICE connection show --active | grep wireless | grep -v $DEFAULT_ADAPTER | sed 's/:.*$//'` )
		do
		done
	fi
	# create default metrics file
	cat <<-EOF > /etc/NetworkManager/conf.d/armbian-default-metric.conf
	[connection-ethernet-gateway]
	match-device=interface-name:$DEFAULT_ADAPTER
	ipv4.route-metric=50
	[connection-wifi-other]
	match-device=type:wifi
	ipv4.route-metric=88
	[connection-ethernet-other]
	match-device=type:ethernet
	ipv4.route-metric=77
EOF
switch_int
Noting it is possible to change the switch interface function to work with nftables
The main advantage seems to be the inet service which means rules will apply for both ipv4 and ipv6, only issue is that it does not allow to use armbian-config for the hostpot anymore as this would use iptables
#!/bin/bash
DEFAULT_ADAPTER=$1
    #clear nf
    cat << EOF > /etc/nftables.rules
#!/usr/sbin/nft -f
flush ruleset
add table inet nat
#add chain inet nat PREROUTING { type nat hook prerouting priority -100; policy accept; }
#add chain inet nat INPUT { type nat hook input priority 100; policy accept; }
add chain inet nat POSTROUTING { type nat hook postrouting priority 100; policy accept; }
#add chain nat OUTPUT { type nat hook output priority -100; policy accept; }
add table inet filter
#add chain inet filter INPUT { type filter hook input priority 0; policy accept; }
add chain inet filter FORWARD { type filter hook forward priority 0; policy accept; }
#add chain inet filter OUTPUT { type filter hook output priority 0; policy accept; }
EOF
    chmod u+x /etc/nftables.rules
    /etc/nftables.rules
    nft add rule inet nat POSTROUTING oifname $DEFAULT_ADAPTER counter masquerade
    nft add rule inet filter FORWARD iifname $DEFAULT_ADAPTER oifname $WIRELESS_ADAPTER ct state related,established  counter accept
    nft add rule inet filter FORWARD iifname $WIRELESS_ADAPTER oifname $DEFAULT_ADAPTER counter accept
    #save nft
    nft list ruleset > /etc/nftables.ruleset
    systemctl stop armbian-restore-nftables.service
    systemctl disable armbian-restore-nftables.service
    cat <<-EOF > /etc/systemd/system/armbian-restore-nftables.service
    [Unit]
    Description="Restore NF tables"
    [Timer]
    OnBootSec=20Sec
    [Service]
    Type=oneshot
    ExecStart=nft -f /etc/nftables.ruleset
    [Install]
EOF
    systemctl enable armbian-restore-nftables.service
switch_int
Edited by lmdc45
