Hello, I am trying to use BPI with legacy Armbian and Stella emulator with 16:10 monitor (using HDMI-DVI cable)
I just dont know how to set proper 16:10 resolution. The resolution I set in armbian-config is 1680x1050, but it is different from resolution that Stella uses, when I launch it on the startup. It uses the resolution defined in FEX.
So I checked https://linux-sunxi.org/Fex_Guide#disp_init_configuration and tried various resolutions, but dont know which of them is 16:10 and what is the exact resolution. For example 576p can mean anything. How can I find it out?
Thank you very much.
