Hi all,
Maybe there are a lot people who got this working but for me was today the day. I buyed a time a go a cheap but fast NVME SSD from Aliexpress. The smallest one a 128GB. I have also a 512GB in my laptop and for the price they are really good. :) But i needed also a USB-NVME external housing. That is the Ugreen NVME 10GBps to USB adapter.
In very short but i will explain more in the future.
1. Flash a MicroSD card with your favourite Armbian to the MicroSD. Update with sudo apt-get update.  Also with a SSH session not a problem.
2. Place the USB disk in a USB 3.0 port of the Orange Pi. By the OrangePi 4 it´s the blue one on the top.
3. run the command lsusb
4. Notice the dev id. In my situation it´s 174c:2362
5. Run the command with off course your dev id. Notice the :u at the end that must be added.
echo "174c:2362:u" | sudo tee /sys/module/usb_storage/parameters/quirks
6. Replug the USB drive. I see the activity led on the drive short flashing.
7. Run the following command
sudo nano /boot/armbianEnv.txt
8. Add the dev id after usbstoragequirks and close and save the file. By my system is the complete row:
usbstoragequirks=174c:2362:u,0x2537:0x1066:u,0x2537:0x1068:u
7. Logout and in with your root account! This is very important. With sudo is this not possible.
8. Open armbian-config. Select System->Update Bootloader-> Boot from SD, root from NVME/eMMC etc.
9. The tool will ask you the directory to the disk. Most of time is this standard correct. You get a question about the filesystem. Select EXT4. You get a warning that the disk would be erased. Click on Ok.
10. Wait patiently to finish
11. And without failures you could click reboot and boot from USB/NVME! :)
By my is the Orange:Pi a  lot faster! Booting, updating copy files. Everything. I am really happy with this! :)
Edited by Werner
Add prefix
