ZFS on RockPro64 Armbian current image
Go to solution Solved by clariion,
  • Solution
After a few hours, I finally made it with current Focal release. Thanks to @jbergler
Linux RockPro64 5.8.17-rockchip64 #20.08.21 SMP PREEMPT Sat Oct 31 08:22:59 CET 2020 aarch64 aarch64 aarch64 GNU/Linux
# sudo add-apt-repository ppa:ubuntu-toolchain-r/ppa
# sudo apt update
# sudo apt upgrade
# sudo apt install g++-10
# armbian-config -> Software -> Headers install
# mkdir zfs-scratch
# cd zfs-scratch
# apt-get download linux-headers-current-rockchip64
# git clone -b zfs-0.8.5 https://github.com/openzfs/zfs.git
# apt install build-essential autoconf automake libtool gawk alien fakeroot dkms libblkid-dev uuid-dev libudev-dev libssl-dev zlib1g-dev libaio-dev libattr1-dev libelf-dev python3 python3-dev python3-setuptools python3-cffi libffi-dev
# dpkg -i linux-headers-current-*.deb
# cd zfs
# sh autogen.sh
# ./configure
# make
# make install
# sudo apt install spl-dkms
# sudo apt install zfsutils-linux
# reboot
On 11/9/2020 at 10:39 AM, clariion said:
No. Do you have created it?
Yes, that's my PPA. It works fine for x86_64 but I haven't tested on arm64 though I don't know why it would be any different.
Thank you Jonathon.
I'm running Armbian 22.08.2 Jammy with Linux 5.15.69-rockchip64 (RockPro64 as a NAS server so ARM64)
and it worked for me.
here is what i did :
sudo add-apt-repository ppa:jonathonf/zfs
sudo apt update
sudo apt install zfs-dkms zfs-zed zfsutils-linux
sudo zpool status
i can't thank you enough.
Actually, I spoke too fast :
I redid everything on a clean system, and using your PPA was not enough.
Here is the full list of commands that worked :
sudo apt update
git clone https://github.com/nathmo/makeZFS_armbian
cd makeZFS_armbian
sudo python3 makeZFS_armbian.py
(the whole RockPro64 NAS setup is on github (i'm not allow to paste the link nor modify my previous post. Sorry about that)
if of any use to someone : nathmo/makeZFS_armbian)
I Had to fork from the original script to fix a broken tab and the python version that was deprecated.
I also document the rest of the instruction to duplicate my setup
