andrey_and Posted November 4, 2020 Posted November 4, 2020 Armbianmonitor: http://ix.io/2CYw Hello all ! I connected relle to pins (Physical): Relle Orange in 35 gnd 6 ucc 2 But it is constantly active (on), although the port status 32 is off (0). Why is that? # gpio write 24 1 Changes the port status, but has no effect on the relay. Relle ist ON alweys! If you physically disable the pin (in - 35), then the relay is turned off. I just installed the system. I did not install any additional services and packages. Maybe I need to configure something in the system to activate the GPIO?
