When ./compile.sh command is used to compiling a new Armbian version (especially with some source changes for debugging), in case there was an error during compilation, it can be impossible to find real reason of the problem. Log files located in output/debug folder are not very informative - they just show the last message, which also appears on the screen - failed in script line number . The following command was used to get full log of the compilation process:
command | tee -a log.txt
Hope this will be useful for somebody else (newbie), who like me spent a lot of time trying to understand, why the compilation failed after some changes in kernel configuration.
