Piecho Posted December 5, 2020 Posted December 5, 2020 (edited) Hello, When I comment device via USB 3.0 I see it: ender3@ender3:~$ lsusb Bus 005 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 004 Device 002: ID 1d50:614e OpenMoko, Inc. Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub However with pins GND, DP1, DM1, +5V Bus 005 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub See Layout / USB2.0 - https://wiki.friendlyarm.com/wiki/index.php/NanoPi_NEO3 Any ideas how I should activate these pins? Want to connect 3d printer and endoscope OTG camera that works with RPi, so should be matter of drivers. Testing on printer now. Also, if it is not supported, may I use simple USB 2.0 hub to connect to USB 3.0 port WiFI card, 3d printer and OTG endoscope camera? Prefer to activate these pins if I may to choose : ) Edited December 5, 2020 by Piecho
kisdia Posted March 11, 2021 Posted March 11, 2021 Same problem here. Changed OTG to "host" in device tree in armbian-config but still doesn't recognise connected USB device. Any ideas?
