gabrielwong1991 Posted July 17, 2016 Posted July 17, 2016 Hi basically i am switching from Raspberry pi to orangepi PC. Managed to find armbian which looks way better than raspberry gui! Now my problem is i used raspi-config to set login after POST in CLI in Rpi but in armbian we dont have this config thing and I want to make the system login at CLI then I could either continue to use CLI or go into gui mode by typing startx. Any ideas for this? I have tried systemctl enable multi-user.target but it seems nothing change and I also tried to find the directory of grub but there is none at armbian. Many thanks, Gabriel
zador.blood.stained Posted July 17, 2016 Posted July 17, 2016 I have tried systemctl enable multi-user.target but it seems nothing change and I also tried to find the directory of grub but there is none at armbian. If I remember correctly, you need to disable nodm ("systemctl disable nodm") and use "systemctl start nodm" to start the desktop environment.
gabrielwong1991 Posted July 17, 2016 Author Posted July 17, 2016 the command works many thanks zador! one more question tho.. How do I enable SSH? I installed XRDP and try to run RDP from Windows it doesnt connect, putty also doesnt connect. I am running the Window and OPi in the same LAN so shouldnt be network problem
zador.blood.stained Posted July 17, 2016 Posted July 17, 2016 one more question tho.. How do I enable SSH? I installed XRDP and try to run RDP from Windows it doesnt connect, putty also doesnt connect. I am running the Window and OPi in the same LAN so shouldnt be network problem So SSH or RDP? SSH should be enabled and active by default, make sure that SSH service is running ("systemctl status sshd") and that you can ping your board from your PC. For RDP also make sure that XRDP was started without any errors and that it has proper configuration.
gabrielwong1991 Posted July 17, 2016 Author Posted July 17, 2016 Both XRDP and SSH are active (running). Regarding the ping it is acting weird, i get 2/4 packet loss from pinging. Firewall on the armbian image? I thought XRDP use SSH protocol to communicate with OPi acting as server and computer as client?
zador.blood.stained Posted July 17, 2016 Posted July 17, 2016 Regarding the ping it is acting weird, i get 2/4 packet loss from pinging. Firewall on the armbian image? No, even if iptables is installed, there are no custom rules (ACCEPT by default in all chains), and I'm not sure we even have kernel modules to simulate this behavior. . Packet loss is a sign of hardware issues, please try using different Ethernet cable to connect your board.
gabrielwong1991 Posted July 17, 2016 Author Posted July 17, 2016 In fact I am using RT5370 to connect to the LAN network. Let me try from eth0
gabrielwong1991 Posted July 17, 2016 Author Posted July 17, 2016 hahaha I found out the problem! Its the power PSU! I used a USB cable, cut the wire, take the positive and negative out and solder it directly to the board since I dont have the power plug before. The wire is too thin for 2Amps to pass. Ran down and bought the cable and is all good now. Thanks Zador for your help!
