  Thank you all for so much work to fully implement the mainline kernel for the Pine64!
So much is now working out-of-the-box with armbian, that there is no need to use the legacy version based on kernel 3.10.
The pine64 does have CIR capabilities and the sunxi-cir kernel module is available, but we are still missing DT bindings for the device, although I see that an overlay file is present for the h5:
/dts-v1/;
        compatible = "allwinner,sun50i-h5";
        fragment@0 {
                target = <0xffffffff>;
                __overlay__ {
                        pinctrl-names = "default";
                        pinctrl-0 = <0xffffffff>;
                        status = "okay";
        __fixups__ {
                ir = "/fragment@0:target:0";
                r_ir_rx_pin = "/fragment@0/__overlay__:pinctrl-0:0";
/tmp/sun50i-h5-cir.dtbs (END)
I would be very happy to try to implement and test this, if anyone can suggest changes to the overlay code, to shoehorn it into the pine64-plus DT.
Update:
I did try the obvious, simple approach of changing the compatible line to compatible = "allwinner,sun50i-a64"
, recompiling and changing the filename to
/boot/overlay-user/sun50i-a64-pine64-cir.dtbo
but this looks like it messes up the official 7 inch lcd overlay (blank screen) that otherwise loads fine. So looks like it needs more changes.
Many thanks in advance for any suggestions!
BR.
I found the solution at
I was expecting this to be called "cir something", but the device is already listed in the device tree as ir@1f02000.
I did a
sudo fdtput -t s /boot/dtb/allwinner/sun50i-a64-pine64-plus.dtb /soc/ir@1f02000 status okay
and rebooted. Device now shows up as /dev/input/event2
Now all I need is to find some codes that can be used with it.
  • Learnincurve changed the title to RESOLVED: a64 (pine64) dt bindings for cir?
