HC4 re-use system in SATA
Go to solution Solved by Igge,
Good evening,
Is it possible to "re-use" the system on SATA ? And how would I do that.
I use a HC4 with SD card, a SSD and a HDD
I flashed the SD card with Armbian_20.11.1_Odroidhc4_buster_current_5.9.12.img.xz
then used armbian-config to Boot from SD - system on SATA.  (sdb2)
also I installed PiHole, OMV ...
Due to an power failure the HC4 was not booting anymore.
With a newly flashed SD card its booting again, but of course its not using the system on sdb2
When using armbian-config it would erase by sdb2 before
Could I somehow use the system which still should be on sdb2 instead of starting from beginning?
thanks for your help
best Regards
Igge
I'm guessing.
Check the sata device name.
blkid
Then in /boot/armbianEnv.txt
Change rootdev with your sata device name.
Let me know if it works.
Unfortunately this is not working,
I changed the rootdev UUID from the current one of mmcblk1p1 to the one of my sdb2 in /boot/armbianEnv.txt using nano.
When I reboot, board is not booting at all now.
I will flash the SD card again.
sdb2 is not the UUID. It should be something like :
UUID=12346d03-4127-4fc2-9536-4e14f386acfa
Hi Nico,
thanks for your help. Sorry to answer only now, I needed to wait 24 hours to be able to write again.
What you describe is what I did
blkid showed for /dev/mmcblk1p1: UUID="719e2259-339c-4a64-8012-cdd30ffc7dfc"
This UUID was the one mentioned in /boot/armbianEnv.txt
And I changed it to the UUID of /dev/sdb2: UUID="bd07f3d4-1caa-443d-b91a-07e4057b41f6"
didnt work
  • Solution
I managed to get it done,
on top of your advise I needed to change the UUID as well in the fstab
