Hello, everybody!
Today I've got very interesting behavior during debian8-3.4.112 startup.
If the network cable is plugged in - everything is ok. dhclient starting correctly with an ip address obtained from dhcp server.
BUT! If the board started with unolugged network cable, dhclient do not start.
Moreover, if I try to connect network cable when the system is up and running,
dhclient is never start and network is unreachable respectively.
Does somebody knows how to solve this problem?\
Thanx a lot!
Well, parallelizing boot script or making it dependant of network is a bad idee, because it tends to make it unpredictable. Especially when some init process depends on clock and the RTC dont keep time if you unplug power supply ...
