Christos Posted January 19, 2021 Posted January 19, 2021 When running this sudo cat /sys/kernel/debug/clk/clk_summary I get the list of clocks and the specific interest is in these pll-audio-base 0 0 0 24576000 50000 0 50000 pll-audio-8x 0 0 0 49152000 50000 0 50000 i2s1 0 0 0 49152000 50000 0 50000 pll-audio-4x 0 0 0 24576000 50000 0 50000 i2s0 0 0 0 24576000 50000 0 50000 i2s2 0 0 0 24576000 50000 0 50000 pll-audio-2x 0 0 0 12288000 50000 0 50000 pll-audio 0 0 0 24576000 50000 0 50000 ac-dig 0 0 0 24576000 50000 0 50000 spdif 0 0 0 24576000 50000 0 50000 Now, the i2s0 (which interests me) is under pll-audio-4x and has 24576000Hz So the is20 is clocked at 24576000Hz, but I want it to be clocked at 49152000Hz The question is this, how can I move the i2s0 under pll-audio-8x with 49152000Hz ? Can I simply instruct it via a DT overlay that its master clock will be 49152000Hz? Should I need to re-parent it ? Is there an example on how this can be done via a DT overlay for i2s0 or does it need kernel source patching ? Is it even feasible ? Christos
