Dombo 71 Posted January 23, 2021 Posted January 23, 2021 Hi to all: I run a odroid N2: / _ \ __| |_ __ ___ (_) __| | | \ | |___ \ | | | |/ _` | '__/ _ \| |/ _` | | \| | __) | | |_| | (_| | | | (_) | | (_| | | |\ |/ __/ \___/ \__,_|_| \___/|_|\__,_| |_| \_|_____| Welcome to Armbian 20.11.6 Focal with Linux 5.9.14-meson64 System load: 18% Up time: 20 min Local users: 3 Memory usage: 20% of 3.55G IP: 192.168.5.70 CPU temp: 43°C Usage of /: 11% of 57G Try to install a sonso api on my system. After a reboot i get a strange error with python . I did a upgrade to some dofferent packages. No luck @ all. Now with everthing i do i get a strange error: And hwo strange there is no python 3 installed? <no Python frame> dpkg: fout bij verwerken van pakket apt-xapian-index (--remove): subproces van pakket apt-xapian-index werd script pre-removal geïnstalleerd gaf de foutwaarde 1 terug dpkg: te veel fouten; er wordt gestopt Could not find platform independent libraries <prefix> Could not find platform dependent libraries <exec_prefix> Consider setting $PYTHONHOME to <prefix>[:<exec_prefix>] Python path configuration: PYTHONHOME = (not set) PYTHONPATH = (not set) program name = '/usr/bin/python3' isolated = 0 environment = 1 user site = 1 import site = 1 sys._base_executable = '/usr/bin/python3' sys.base_prefix = '/usr' sys.base_exec_prefix = '/usr' sys.executable = '/usr/bin/python3' sys.prefix = '/usr' sys.exec_prefix = '/usr' sys.path = [ '/usr/lib/python38.zip', '/usr/lib/python3.8', '/usr/lib/lib-dynload', ] Fatal Python error: init_fs_encoding: failed to get the Python codec of the filesystem encoding Python runtime state: core initialized ModuleNotFoundError: No module named 'encodings' Current thread 0x0000ffff87d6f010 (most recent call first): <no Python frame> dpkg: fout tijdens opruimen: subproces van pakket apt-xapian-index werd script post-installation geïnstalleerd gaf de foutwaarde 1 terug Fouten gevonden tijdens verwerken van: apt-xapian-index Verwerking werd afgebroken omdat er te veel fouten waren. E: Sub-process /usr/bin/dpkg returned an error code (1) pi@odroidn2:~$ python3 python3: error while loading shared libraries: libpython3.5m.so.1.0: cannot open shared object file: No such file or directory I try to uninstall xapian en reinstall Did this also with some some python packages.. Hope there is some support. I am a Windows noop...
