Create and restore image backups of disk drives
Dear all,
I used win32diskimager to write the armbian image on a 8G sd card and everything works good. when I finish working on the image I read the final image also by using win32diskimager, the size of this image is right now 8G since the sd card size is 8G. After that I wrote this 8G image on a 16 G sd card. when I check the size of this new sd card after writing the 8G image it shows that the sd card size is 8G not 16 G.
So, please how can I read an image from a 8G sd card and write it to a 16 G sd card and the size of the sd card remains 16 G to be used later.
Best regards
The easiest way is using some disk tool to resize the partition. In Linux, Gparted will do the job. For Windows, I'm not sure, probably minitool partition wizard.
Enviado desde mi moto g(6) plus mediante Tapatalk
