Miro-Sk Posted February 6, 2021 Posted February 6, 2021 Hello, I am using Armbian 21.02.1 Focal with Linux 5.10.12-sunxi (Armbian Focal from https://www.armbian.com/orange-pi-zero/). I use the default logrotate configuration (ratate logs in /var/log) but I have a problem that the /var/log/syslog file is still growing (even if logrotate is run daily). Currently the logrotate process takes place in 3 steps (see /etc/systemd/system/logrotate.service -> [Service] section): 1) ExecStartPre =/usr/lib/armbian/armbian-ramlog write (ramlog write files to update log.hdd before rotation) 2) ExecStart =/usr/sbin/logrotate /etc/logrotate.conf (Logrotate) 3) ExecStartPost =/usr/lib/armbian/armbian-ramlog postrotate (ramlog postrotate (which will copy to/var/log the modified files of /var/log.hdd) I think step 3 is wrong. Assume that the following are performed during the logrotate: 1) ExecStartPre =/usr/lib/armbian/armbian-ramlog write = ramlog write (to update log.hdd before rotation) - it is ok 2) the system writes another data to /var/log/syslog (at this moment /var/log/syslog <> /var/log.hdd/syslog)- that's ok 3) ExecStart =/usr/sbin/logrotate /etc/logrotate.conf = logrotate is performed (/var/log/syslog is renamed to /var/log/syslog.1, an empty /var/log/syslog is created, the system starts writing to the new empty /var/log/syslog). - it is OK 4) the system writes data to new /var/log/syslog (at this step /var/log/syslog is not empty) - that's ok 5) ExecStartPost =/usr/lib/armbian/armbian-ramlog postrotate = the ramlog postrotate is started. During postrotate are executed commands (cat /var/log.hdd/... > /var.log/...), which copy files from /var/log.hdd to /var.log). The command "cat $ file> $ dest" overwrites data in new /var/log/syslog with data from the old /var/log.hdd/syslog - so data written to syslog in step 4 is lost - this is a bug in my opinion Another consequence of ramlog postrotate is that the new file /var/log/syslog is filled with the data that was written to syslog in the past (so the /var/log/syslog file is still growing). Proposed solution is to change etc/systemd/system/logrotate.service -> [Service] section as follows: [Service] Type=oneshot ExecStart=/usr/sbin/logrotate /etc/logrotate.conf ExecStartPost=/usr/lib/armbian/armbian-ramlog write There are no lost entries in the syslog in this solution.
tparys Posted February 6, 2021 Posted February 6, 2021 If you think it's wrong, submit a change via pull request? https://github.com/armbian/build/pulls
Miro-Sk Posted February 6, 2021 Author Posted February 6, 2021 @tparys - thank you for your reply but I am new here, and I am not sure, if I am able to create pull request...
tparys Posted February 8, 2021 Posted February 8, 2021 I assure you that you can, and it's encouraged (see HERE). Fork the repository on github Make a change to your copy Hit the button to create a merge request
noone Posted March 10, 2021 Posted March 10, 2021 I noticed the same issue. I can submit a change. However, I am not familiar with armbian-ramlog program. So, I guess I will first see what this program does. On my armbian I just commented out ExecStartPost in logrotate.service, and now logs are no longer rewritten with old data after rotation. I am not sure that is the correct way as I am not sure how it is supposed to rotate and archive logs.
Miro-Sk Posted March 10, 2021 Author Posted March 10, 2021 @noone - you commented out ExecStartPost -> so your logfiles are not written to the SD card (/var/log.hdd). you will lost all your logs located in /var/log on power failure. @noone - I made a mistake - commented out ExecStartPost is ok from my point of view.
Miro-Sk Posted May 22, 2021 Author Posted May 22, 2021 Hello, I registered that after upgrading to Armbian 21.05.1 the behaviour of /usr/sbin/logrotate /etc/logrotate.conf was changed. Currently, step "3) ExecStart = /usr/sbin/logrotate /etc/logrotate.conf" is performed in the /var/log.hdd/ directory (in the previous version this step was performed in the /var/log directory). So after the upgrade, I changed: 1) in /etc/logrotate.d/rsyslog: /var/log.hdd/syslog -> /var/log/syslog 2) in the /etc/systemd/system/logrotate.service [Service] section as follows: [Service] Type = oneshot ExecStart = / usr / sbin / logrotate /etc/logrotate.conf ExecStartPost = / usr / lib / armbian / armbian-ramlog write After these changes logrotate works according to my expectations again. 2
