Uninstall home assistant (installed with softy)
Go to solution Solved by SHA_ndy,
Hi all,
I played around with home assistant on my Odroid HC1 (running NCP as main task) and now wanted to remove home assistant completely because I don't need it anymore. I tried to uncheck the software in Softy but that doesn't have any impact.
How can I completely remove home assistant?
Thanks!
You will have to check the home-assistant documentation on how to remove it completely.
armbian-config/softy does not have a remove feature build in.
See also:
  • Solution
See also:
Thanks for your reply. I realized that docker was also installed when installing home assistant so I completely removed docker (by "apt remove docker-ce*") and did a "find" with *hass*. Afterward I removed all found *hass*-files manually. Worked fine.
