TV Box Name: MX10
CPU: RK3328
Armbian build file name: Armbian_20.10_Arm-64_focal_current_5.9.0_desktop_201014
DTB file used: rk3328-box.dtb
Kernel Version: 5.9.0
Distribution Installed: focal
Working Ethernet: Yes
Max Ethernet Speed that works: 100
Does wifi work: No
Does bluetooth work: not tested
Does HDMI audio work: Yes
Additional Comments: this is the newer hw version with SV6051 wifi chip instead of the 8723 found on older boards, so that's why onboard wifi is not working. USB wifi dongle with Ralink MT7601 chipset working perfectly. Small tweaks to the DT gets the blue LED working as it should.
