I'm trying to run with a PREEMPT_RT kernel to get a real-time (lowest latency as possible) performance.
But in addition to the PREEMPT_RT patch, I want to make sure the system doesn't go to sleep (or using power save modes) to avoid additional wake-ups latencies (that the PREEMPT_RT patch cannot reduce).
I've reviewed the AXP209 datasheet and tried to understand if I can somehow disable the system from going to sleep, but I didn't find the answer for that. I do know that register 0x31 can control the entrance to sleep mode if we write '1' to bit-3, but I can't prevent other drivers or applications from doing it.
Question:
Is there a way to disable the option to control the sleep-mode ?
Thanks
