aniol Posted March 16, 2021 Posted March 16, 2021 I have a problem with remote desktop operation on R4S. It installs according to the RDP guide and unfortunately does not work properly, after installing vncserver I also have information about - Cannot find a running X server. Everything works fine on neo3, only here I have a problem. Log VNC xstartup terminated Sending TERM signal to Xvnc... X connection to :1 broken (explicit kill or server shutdown). FreeFontPath: FPE "/usr/share/vnc/fonts/" refcount is 2, should be 1; fixing. <13> 2021-03-16T17:40:30.716Z nanopi-r4s Xvnc[5435]: ServerManager: Server stopped Link Status R4S Please Help 1) Armbian_21.02.3_Nanopi-r4s_focal_current_5.10.21.img.xz 2) armbian-config (Install full firmware) 3) armbian-config (Install Desktop...) 4) armbian-config (Install RDP) When trying to connect from the client side after entering the login and password, the window closes. Xorg.0.log xrdp-sesman.log I observed the problem is R4S: Firmware:Armbian_21.02.3_Nanopi-r4s_focal_current_5.10.21.img.xz - is not correct Firmware: Armbian_21.02.3_Nanopi-r4s_buster_current_5.10.21.img.xz - it is good Neo 3 Armbian_20.11.6_Nanopineo3_focal_current_5.9.14_minimal.img.xz - it is good Armbian_21.02.1_Nanopineo3_focal_current_5.10.12_minimal.img.xz - is not correct What has changed, how to properly start the desktop and RDP.
