Solution scaevola Posted March 22, 2021 Solution Posted March 22, 2021 Armbianmonitor: https://paste.debian.net/1190400/ Hi there. I use Orange Pi zero as home print server. It works for few months for now and I am very pleased with that. Although, my printer falls into deep sleep after printing (it's Brother HL-1110EW) and cannot be woken up by the server. I have to start printer manually to print next printouts. Thus I wanted to install tea4cups to drive a relay turning the printer on and off when needed. I installed the WiringOP-zero (from here: https://github.com/xpertsavenue/WiringOP-Zero) but then strange things become to happen. I connected temporarily a LED diode to indicate the changes of the GPIO. (GPIO-7 and GND). The LED is on all the time, no matter what command I send. Even if "gpio readall" shows "0" state on GPIO-7 the led still is on. Quote qbunjo@printserver:~$ gpio readall +-----+-----+----------+------+--Orange Pi Zero--+------+----------+-----+-----+ | H2+ | wPi | Name | Mode | V | Physical | V | Mode | Name | wPi | H2+ | +-----+-----+----------+------+---+----++----+---+------+----------+-----+-----+ | | | 3.3v | | | 1 || 2 | | | 5v | | | | 12 | 8 | SDA.0 | ALT3 | 0 | 3 || 4 | | | 5V | | | | 11 | 9 | SCL.0 | ALT3 | 0 | 5 || 6 | | | 0v | | | | 6 | 7 | GPIO.7 | OUT | 0 | 7 || 8 | 0 | ALT3 | TxD3 | 15 | 198 | | | | 0v | | | 9 || 10 | 0 | ALT3 | RxD3 | 16 | 199 | | 1 | 0 | RxD2 | ALT3 | 0 | 11 || 12 | 0 | ALT3 | GPIO.1 | 1 | 7 | | 0 | 2 | TxD2 | ALT3 | 0 | 13 || 14 | | | 0v | | | | 3 | 3 | CTS2 | ALT3 | 0 | 15 || 16 | 0 | ALT3 | GPIO.4 | 4 | 19 | | | | 3.3v | | | 17 || 18 | 0 | ALT3 | GPIO.5 | 5 | 18 | | 15 | 12 | MOSI | ALT3 | 0 | 19 || 20 | | | 0v | | | | 16 | 13 | MISO | ALT3 | 0 | 21 || 22 | 0 | ALT3 | RTS2 | 6 | 2 | | 14 | 14 | SCLK | ALT3 | 0 | 23 || 24 | 0 | ALT3 | CE0 | 10 | 13 | | | | 0v | | | 25 || 26 | 0 | ALT3 | GPIO.11 | 11 | 10 | +-----+-----+----------+------+---+---LEDs---+---+------+----------+-----+-----+ | 17 | 30 | STAT-LED | OUT | 0 | 27 || 28 | | | PWR-LED | | | +-----+-----+----------+------+---+-----+----+---+------+----------+-----+-----+ | H2+ | wPi | Name | Mode | V | Physical | V | Mode | Name | wPi | H2+ | +-----+-----+----------+------+--Orange Pi Zero--+---+------+---------+-----+--+ I tried to push the values through "echo": Quote echo 7 > /sys/class/gpio/export echo "out" > /sys/class/gpio/gpio7/direction echo 1 > /sys/class/gpio/gpio7/value But also without success. That means gpio readall still shows changes in the table but there are no physical changes on the pin (the voltage still is on). Then I thought that maybe there is no kernel module loaded, but I can see that w1-gpio is loaded: lsmod Module Size Used by aes_arm_bs 20480 2 crypto_simd 16384 1 aes_arm_bs ccm 20480 6 xradio_wlan 110592 1 mac80211 532480 1 xradio_wlan sun4i_gpadc_iio 16384 0 cfg80211 491520 2 mac80211,xradio_wlan industrialio 53248 1 sun4i_gpadc_iio zram 24576 2 sun8i_thermal 16384 0 sunxi_cedrus 32768 0 rfkill 20480 3 cfg80211 libarc4 16384 1 mac80211 v4l2_mem2mem 20480 1 sunxi_cedrus videobuf2_dma_contig 20480 1 sunxi_cedrus videobuf2_memops 20480 1 videobuf2_dma_contig videobuf2_v4l2 20480 2 sunxi_cedrus,v4l2_mem2mem videobuf2_common 40960 3 sunxi_cedrus,v4l2_mem2mem,videobuf2_v4l2 w1_gpio 16384 0 wire 32768 1 w1_gpio cn 16384 1 wire uio_pdrv_genirq 20480 0 uio 16384 1 uio_pdrv_genirq cpufreq_dt 20480 0 usb_f_acm 20480 1 u_serial 24576 3 usb_f_acm g_serial 16384 0 libcomposite 45056 2 g_serial,usb_f_acm ip_tables 24576 0 x_tables 24576 1 ip_tables autofs4 36864 2 pwrseq_simple 16384 1 sunxi 16384 0 phy_generic 20480 2 sunxi Then I started to read forums, including this one. Still no clue what is happening, I did not find any similar case. I run out of ideas -maybe anyone would have some? Oh, I forgot one thing that may be interesting - driving onboard red led actually works. (gpio 30) EDIT: I changed the driving pin for pin9 and it works fine. Pin 7 is damaged or anything? Dunno.
hal8k Posted April 2, 2021 Posted April 2, 2021 I use the same gpio library and all pins are working on my OPi Zero. It may be worth re-soldering pin 9 on the IDC header and see if the soldered connection is at fault. Below is a very quick bash script to set all pins as outputs, activate them, then turn off all pins you can use as a check. There's probably more efficient ways of doing the same thing #!/bin/bash gpio reset; sleep 1; for n in {0..30}; do gpio mode $n out; gpio write $n on; done gpio readall sleep 3 for n in {0..30}; do gpio write $n off; done gpio readall; sleep 3; gpio reset 1
