MarkLuun Posted March 22, 2021 Posted March 22, 2021 (edited) Armbianmonitor: http://ix.io/2TLX Hi Armbians I have a problem with one of my NanoPi Neo 3 boards and dropped RX packages on eth0. From multiple Neo 3`s I have running, this is the only one having this issue. But its also the only one with 1GB of RAM. All other boards have 2GB of RAM. But this should not matter I think. Output ifconfig: eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet XXXXXXXXXX netmask 255.XXXXXXX broadcast XXXXXXXXXX ether XXXXXXXXXXX txqueuelen 20000 (Ethernet) RX packets 140166777 bytes 110091299296 (102.5 GiB) RX errors 0 dropped 3686 overruns 0 frame 0 TX packets 127249076 bytes 110451144546 (102.8 GiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 device interrupt 39 lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536 inet 127.0.0.1 netmask 255.0.0.0 loop txqueuelen 20000 (Lokale Schleife) RX packets 96 bytes 7103 (6.9 KiB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 96 bytes 7103 (6.9 KiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 Output "ethtool -S eth0": Spoiler NIC statistics: mmc_tx_octetcount_gb: 1248134398 mmc_tx_framecount_gb: 129436587 mmc_tx_broadcastframe_g: 0 mmc_tx_multicastframe_g: 0 mmc_tx_64_octets_gb: 0 mmc_tx_65_to_127_octets_gb: 0 mmc_tx_128_to_255_octets_gb: 0 mmc_tx_256_to_511_octets_gb: 0 mmc_tx_512_to_1023_octets_gb: 0 mmc_tx_1024_to_max_octets_gb: 0 mmc_tx_unicast_gb: 0 mmc_tx_multicast_gb: 0 mmc_tx_broadcast_gb: 0 mmc_tx_underflow_error: 0 mmc_tx_singlecol_g: 0 mmc_tx_multicol_g: 0 mmc_tx_deferred: 0 mmc_tx_latecol: 0 mmc_tx_exesscol: 0 mmc_tx_carrier_error: 0 mmc_tx_octetcount_g: 1248134398 mmc_tx_framecount_g: 129436587 mmc_tx_excessdef: 0 mmc_tx_pause_frame: 0 mmc_tx_vlan_frame_g: 0 mmc_rx_framecount_gb: 142525394 mmc_rx_octetcount_gb: 738098903 mmc_rx_octetcount_g: 738098903 mmc_rx_broadcastframe_g: 0 mmc_rx_multicastframe_g: 5416 mmc_rx_crc_error: 0 mmc_rx_align_error: 0 mmc_rx_run_error: 0 mmc_rx_jabber_error: 0 mmc_rx_undersize_g: 0 mmc_rx_oversize_g: 0 mmc_rx_64_octets_gb: 0 mmc_rx_65_to_127_octets_gb: 0 mmc_rx_128_to_255_octets_gb: 0 mmc_rx_256_to_511_octets_gb: 0 mmc_rx_512_to_1023_octets_gb: 0 mmc_rx_1024_to_max_octets_gb: 0 mmc_rx_unicast_g: 0 mmc_rx_length_error: 0 mmc_rx_autofrangetype: 0 mmc_rx_pause_frames: 0 mmc_rx_fifo_overflow: 0 mmc_rx_vlan_frames_gb: 0 mmc_rx_watchdog_error: 0 mmc_rx_ipc_intr_mask: 1073692671 mmc_rx_ipc_intr: 0 mmc_rx_ipv4_gd: 136217611 mmc_rx_ipv4_hderr: 284 mmc_rx_ipv4_nopay: 0 mmc_rx_ipv4_frag: 0 mmc_rx_ipv4_udsbl: 0 mmc_rx_ipv4_gd_octets: 0 mmc_rx_ipv4_hderr_octets: 45040 mmc_rx_ipv4_nopay_octets: 0 mmc_rx_ipv4_frag_octets: 0 mmc_rx_ipv4_udsbl_octets: 0 mmc_rx_ipv6_gd_octets: 0 mmc_rx_ipv6_hderr_octets: 0 mmc_rx_ipv6_nopay_octets: 0 mmc_rx_ipv6_gd: 4844 mmc_rx_ipv6_hderr: 0 mmc_rx_ipv6_nopay: 0 mmc_rx_udp_gd: 0 mmc_rx_udp_err: 0 mmc_rx_tcp_gd: 0 mmc_rx_tcp_err: 331 mmc_rx_icmp_gd: 0 mmc_rx_icmp_err: 0 mmc_rx_udp_gd_octets: 0 mmc_rx_udp_err_octets: 0 mmc_rx_tcp_gd_octets: 0 mmc_rx_tcp_err_octets: 18515 mmc_rx_icmp_gd_octets: 0 mmc_rx_icmp_err_octets: 0 mmc_tx_fpe_fragment_cntr: 0 mmc_tx_hold_req_cntr: 0 mmc_rx_packet_assembly_err_cntr: 0 mmc_rx_packet_smd_err_cntr: 0 mmc_rx_packet_assembly_ok_cntr: 0 mmc_rx_fpe_fragment_cntr: 0 tx_underflow: 0 tx_carrier: 0 tx_losscarrier: 0 vlan_tag: 0 tx_deferred: 0 tx_vlan: 0 tx_jabber: 0 tx_frame_flushed: 0 tx_payload_error: 0 tx_ip_header_error: 0 rx_desc: 0 sa_filter_fail: 0 overflow_error: 0 ipc_csum_error: 0 rx_collision: 0 rx_crc_errors: 0 dribbling_bit: 0 rx_length: 0 rx_mii: 0 rx_multicast: 0 rx_gmac_overflow: 0 rx_watchdog: 0 da_rx_filter_fail: 0 sa_rx_filter_fail: 0 rx_missed_cntr: 0 rx_overflow_cntr: 0 rx_vlan: 0 rx_split_hdr_pkt_n: 0 tx_undeflow_irq: 0 tx_process_stopped_irq: 0 tx_jabber_irq: 0 rx_overflow_irq: 0 rx_buf_unav_irq: 0 rx_process_stopped_irq: 0 rx_watchdog_irq: 0 tx_early_irq: 0 fatal_bus_error_irq: 0 rx_early_irq: 3022161 threshold: 1 tx_pkt_n: 129436577 rx_pkt_n: 142525394 normal_irq_n: 75128600 rx_normal_irq_n: 65978675 napi_poll: 79308076 tx_normal_irq_n: 9223077 tx_clean: 13329602 tx_set_ic_bit: 9223084 irq_receive_pmt_irq_n: 0 mmc_tx_irq_n: 0 mmc_rx_irq_n: 0 mmc_rx_csum_offload_irq_n: 0 irq_tx_path_in_lpi_mode_n: 0 irq_tx_path_exit_lpi_mode_n: 0 irq_rx_path_in_lpi_mode_n: 0 irq_rx_path_exit_lpi_mode_n: 0 phy_eee_wakeup_error_n: 0 ip_hdr_err: 0 ip_payload_err: 0 ip_csum_bypassed: 0 ipv4_pkt_rcvd: 0 ipv6_pkt_rcvd: 0 no_ptp_rx_msg_type_ext: 0 ptp_rx_msg_type_sync: 0 ptp_rx_msg_type_follow_up: 0 ptp_rx_msg_type_delay_req: 0 ptp_rx_msg_type_delay_resp: 0 ptp_rx_msg_type_pdelay_req: 0 ptp_rx_msg_type_pdelay_resp: 0 ptp_rx_msg_type_pdelay_follow_up: 0 ptp_rx_msg_type_announce: 0 ptp_rx_msg_type_management: 0 ptp_rx_msg_pkt_reserved_type: 0 ptp_frame_type: 0 ptp_ver: 0 timestamp_dropped: 0 av_pkt_rcvd: 0 av_tagged_pkt_rcvd: 0 vlan_tag_priority_val: 0 l3_filter_match: 0 l4_filter_match: 0 l3_l4_filter_no_match: 0 irq_pcs_ane_n: 0 irq_pcs_link_n: 0 irq_rgmii_n: 0 mtl_tx_status_fifo_full: 0 mtl_tx_fifo_not_empty: 0 mmtl_fifo_ctrl: 0 mtl_tx_fifo_read_ctrl_write: 0 mtl_tx_fifo_read_ctrl_wait: 0 mtl_tx_fifo_read_ctrl_read: 0 mtl_tx_fifo_read_ctrl_idle: 0 mac_tx_in_pause: 0 mac_tx_frame_ctrl_xfer: 0 mac_tx_frame_ctrl_idle: 0 mac_tx_frame_ctrl_wait: 0 mac_tx_frame_ctrl_pause: 0 mac_gmii_tx_proto_engine: 0 mtl_rx_fifo_fill_level_full: 0 mtl_rx_fifo_fill_above_thresh: 0 mtl_rx_fifo_fill_below_thresh: 0 mtl_rx_fifo_fill_level_empty: 0 mtl_rx_fifo_read_ctrl_flush: 0 mtl_rx_fifo_read_ctrl_read_data: 0 mtl_rx_fifo_read_ctrl_status: 0 mtl_rx_fifo_read_ctrl_idle: 0 mtl_rx_fifo_ctrl_active: 0 mac_rx_frame_ctrl_fifo: 0 mac_gmii_rx_proto_engine: 0 tx_tso_frames: 0 tx_tso_nfrags: 0 Any secure way to fix this issue? Edited March 24, 2021 by TRS-80 put long output inside spoiler
MarkLuun Posted March 23, 2021 Author Posted March 23, 2021 I just wanted to add that, if someone is able to help me to fix this soon, I have the chance to test the maximum throughput this board can handle under a 1 Gigabit network connection, and so under real and counting test conditions! The connection speed is valid for the next 30 days till it falls back to 100 MBits standart. So we all would benefit from solving this issue soon
