jorsto Posted March 26, 2021 Posted March 26, 2021 Hello! I'm trying to boot latest releases of of Armbian (following images: Armbian_21.02.3_Cubox-i_buster_current_5.10.21.img and Armbian_21.02.3_Cubox-i_focal_current_5.10.21.img) on a Solid-Run Hummingboard2 Gate V1.4 board. (Board V1.2 freeze during Uboot) I'm getting to the "Starting kernel" message but after that things stop. Switching on the verbose output in ArmbianEnv.txt result in the output below where the kernel always stop at message: [ 0.000000] Freeing unused kernel memory: 2048K Do anyone have any thoughts/ideas here on what could possibly be the problem stopping the kernel from booting? U-Boot SPL 2018.01-armbian (Mar 08 2021 - 10:51:22) Trying to boot from MMC1 U-Boot 2018.01-armbian (Mar 08 2021 - 10:51:22 +0000) CPU: Freescale i.MX6SOLO rev1.3 996 MHz (running at 792 MHz) CPU: Commercial temperature grade (0C to 95C) at 38C Reset cause: POR Board: MX6 HummingBoard2 Watchdog enabled DRAM: 512 MiB MMC: FSL_SDHC: 0, FSL_SDHC: 1 *** Warning - bad CRC, using default environment No panel detected: default to HDMI Display: HDMI (1024x768) In: serial Out: serial Err: serial Net: FEC Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 2091 bytes read in 104 ms (19.5 KiB/s) ## Executing script at 12000000 0 bytes read in 72 ms (0 Bytes/s) 147 bytes read in 88 ms (1000 Bytes/s) 37976 bytes read in 1600 ms (22.5 KiB/s) 21327224 bytes read in 19315 ms (1.1 MiB/s) 10707456 bytes read in 650 ms (15.7 MiB/s) ## Loading init Ramdisk from Legacy Image at 14800000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 21327160 Bytes = 20.3 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 18000000 Booting using the fdt blob at 0x18000000 Using Device Tree in place at 18000000, end 1800c457 Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 5.10.21-imx6 (root@hirsute) (arm-linux-gnueabihf-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 2.32.0.20190321) #21.02.3 SMP Mon Mar 8 07:05:20 UTC 2021 [ 0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] OF: fdt: Machine model: SolidRun Cubox-i Dual/Quad [ 0.000000] printk: debug: ignoring loglevel setting. [ 0.000000] Memory policy: Data cache writeback [ 0.000000] efi: UEFI not found. [ 0.000000] cma: Size (0x10000000) of region at 0x80000000 exceeds limit (0x30000000) [ 0.000000] cma: Failed to reserve 256 MiB [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000010000000-0x000000002fffffff] [ 0.000000] Normal empty [ 0.000000] HighMem empty [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000010000000-0x000000002fffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000010000000-0x000000002fffffff] [ 0.000000] On node 0 totalpages: 131072 [ 0.000000] DMA zone: 1152 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 131072 pages, LIFO batch:31 [ 0.000000] CPU: All CPU(s) started in SVC mode. [ 0.000000] percpu: Embedded 19 pages/cpu s46924 r8192 d22708 u77824 [ 0.000000] pcpu-alloc: s46924 r8192 d22708 u77824 alloc=19*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129920 [ 0.000000] Kernel command line: root=UUID=17df30e5-6838-4ce3-b871-47f297687856 rootfstype=ext4 rootwait console=ttymxc0,115200 consoleblank=0 video=mxcfb0:dev=hdmi,1920x1080m60,if=RGB24,bpp=32 coherent_pool=2M cma=256M@2G rd.dm=0 rd.luks=0 rd.lvm=0 raid=noautodetect pci=nomsi vt.global_cursor_default=0 loglevel=7 usb-storage.quirks= earlyprintk ignore_loglevel [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off [ 0.000000] Memory: 476608K/524288K available (10511K kernel code, 2391K rwdata, 5352K rodata, 2048K init, 532K bss, 47680K reserved, 0K cma-reserved, 0K highmem) [ 0.000000] random: get_random_u32 called from __kmem_cache_create+0x28/0x324 with crng_init=0 [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] ftrace: allocating 47647 entries in 94 pages [ 0.000000] ftrace: allocated 94 pages with 5 groups [ 0.000000] rcu: Hierarchical RCU implementation. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Rude variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] GIC physical location is 0xa01000 [ 0.000000] L2C-310 erratum 769419 enabled [ 0.000000] L2C-310 enabling early BRESP for Cortex-A9 [ 0.000000] L2C-310 full line of zeros enabled for Cortex-A9 [ 0.000000] L2C-310 ID prefetch enabled, offset 16 lines [ 0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled [ 0.000000] L2C-310 cache controller enabled, 16 ways, 512 kB [ 0.000000] L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76450001 [ 0.000000] Switching to timer-based delay loop, resolution 333ns [ 0.000000] sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 715827882841ns [ 0.000000] clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 637086815595 ns [ 0.000000] Console: colour dummy device 80x30 [ 0.000000] Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=3000) [ 0.000000] pid_max: default: 32768 minimum: 301 [ 0.000000] LSM: Security Framework initializing [ 0.000000] Yama: becoming mindful. [ 0.000000] SELinux: Initializing. [ 0.000000] TOMOYO Linux initialized [ 0.000000] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear) [ 0.000000] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear) [ 0.000000] CPU: Testing write buffer coherency: ok [ 0.000000] CPU0: Spectre v2: using BPIALL workaround [ 0.000000] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.000000] Setting up static identity map for 0x10300000 - 0x103000ac [ 0.000000] rcu: Hierarchical SRCU implementation. [ 0.000000] EFI services will not be available. [ 0.000000] smp: Bringing up secondary CPUs ... [ 0.000000] smp: Brought up 1 node, 1 CPU [ 0.000000] SMP: Total of 1 processors activated (6.00 BogoMIPS). [ 0.000000] CPU: All CPU(s) started in SVC mode. [ 0.000000] devtmpfs: initialized [ 0.000000] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4 [ 0.000000] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns [ 0.000000] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [ 0.000000] pinctrl core: initialized pinctrl subsystem [ 0.000000] DMI not present or invalid. [ 0.000000] NET: Registered protocol family 16 [ 0.000000] DMA: preallocated 2048 KiB pool for atomic coherent allocations [ 0.000000] audit: initializing netlink subsys (disabled) [ 0.000000] thermal_sys: Registered thermal governor 'fair_share' [ 0.000000] thermal_sys: Registered thermal governor 'step_wise' [ 0.000000] thermal_sys: Registered thermal governor 'user_space' [ 0.000000] cpuidle: using governor menu [ 0.000000] CPU identified as i.MX6DL, silicon rev 1.3 [ 0.000000] imx6q_suspend_init: failed to get iomuxc base -19! [ 0.000000] imx6_pm_common_init: No DDR LPM support with suspend -19! [ 0.000000] No ATAGs? [ 0.000000] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers. [ 0.000000] hw-breakpoint: maximum watchpoint size is 4 bytes. [ 0.000000] debugfs: Directory 'dummy-iomuxc-gpr@20e0000' with parent 'regmap' already present! [ 0.000000] imx6q-pinctrl 20e0000.pinctrl: initialized IMX pinctrl driver [ 0.000000] Serial: AMBA PL011 UART driver [ 0.000000] Kprobes globally optimized [ 0.000000] audit: type=2000 audit(0.052:1): state=initialized audit_enabled=0 res=1 [ 0.000000] cryptd: max_cpu_qlen set to 1000 [ 0.000000] raid6: skip pq benchmark and using algorithm neonx8 [ 0.000000] raid6: using neon recovery algorithm [ 0.000000] vcc_3v3: supplied by v_5v0 [ 0.000000] v_usb2: supplied by v_5v0 [ 0.000000] v_usb1: supplied by v_5v0 [ 0.000000] iommu: Default domain type: Translated [ 0.000000] vgaarb: loaded [ 0.000000] SCSI subsystem initialized [ 0.000000] libata version 3.00 loaded. [ 0.000000] usbcore: registered new interface driver usbfs [ 0.000000] usbcore: registered new interface driver hub [ 0.000000] usbcore: registered new device driver usb [ 0.000000] pps_core: LinuxPPS API ver. 1 registered [ 0.000000] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.000000] PTP clock support registered [ 0.000000] EDAC MC: Ver: 3.0.0 [ 0.000000] NetLabel: Initializing [ 0.000000] NetLabel: domain hash size = 128 [ 0.000000] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO [ 0.000000] NetLabel: unlabeled traffic allowed by default [ 0.000000] clocksource: Switched to clocksource mxc_timer1 [ 0.000000] VFS: Disk quotas dquot_6.6.0 [ 0.000000] VFS: Dquot-cache hash table entries [ 0.000000] Segment Routing with IPv6 [ 0.000000] NET: Registered protocol family 17 [ 0.000000] ThumbEE CPU extension supported. [ 0.000000] Registering SWP/SWPB emulation handler [ 0.000000] registered taskstats version 1 [ 0.00000scrypt registered [ 0.000000] Key type fscrypt-provisioning registered [ 0.000000] Btrfs loaded, crc32c=crc32c-generic [ 0.000000] Key type encrypted registered [ 0.000000] ima: No TPM chip found, activating TPM-bypass! [ 0.000000] ima: Allocated hash algorithm: sha256 [ 0.000000] ima: No architecture policies found [ 0.000000] Freeing unused kernel memory: 2048K
