dear fellows,
what is aimed: on Raspberry Pi i want monitor the CPU temp at a command line, there is the vcgencmd command.
Well  We can do this in bash:
To read CPU temp at a command line, we can use the vcgencmd command.
Example in bash:
echo "The CPU is at $(vcgencmd measure_temp) degrees."
The CPU is at temp=45.5'C degrees.
i think that we can do this with Python as well:
import re, subprocess
def check_CPU_temp():
    temp = None
    err, msg = subprocess.getstatusoutput('vcgencmd measure_temp')
    if not err:
        m = re.search(r'-?\d\.?\d*', msg)   # a solution with a  regex
        try:
            temp = float(m.group())
        except ValueError: # catch only error needed
            pass
    return temp, msg
temp, msg = check_CPU_temp()
print(f"temperature {temp}°C")
print(f"full message {msg}")
and this will return temperatures  - like so
temperature (°C):  67.0
full message:     temp=67.6'C
I hopefully have ceated the the code right - with usage of supprocess
cf: Python 3 Subprocess Examples
https://queirozf.com/entries/python-3-subprocess-examples
There are some strong opinions on the Raspberry Pi here, and many are not positive, mostly due to the closed hardware platform.
If you need support with Raspberry Pi temperature sensing, you'd find better results asking on their forums.
More standard SBC boards would use "sensors" from lm-sensors package, or just read the thermal sensors directly
tparys@hobbes:/sys/class/hwmon$ ls -l /sys/class/hwmon/*/temp*_input
-r--r--r-- 1 root root 4096 Apr 14 00:17 /sys/class/hwmon/hwmon0/temp1_input
-r--r--r-- 1 root root 4096 Apr 14 00:17 /sys/class/hwmon/hwmon1/temp1_input
cat /sys/class/hwmon/hwmon0/temp1_input
give exactly the same result than 'vcgencmd measure_temp'
Thanks to tparys : I h
Thanks to tparys : I had forgotten the /sys path. I **never** check the cpu temp : with the aluminium cases availables for RPI4 which press  the cpu, the RPI4 provide an excellent passive cooling solution.
On the contrary, I wish raspbian would not corrupt the root file system (on USB3 bus) when there is a USB error (on USB2 bus) ?!?
