Guest Posted April 18, 2021 Posted April 18, 2021 Hello, I have a PineA64LTS I use as a nextcloud server (running on docker). A few days ago, I updated it (for the first time in a loong time) and ended up on a boot problem. Loading, please wait... Starting version 245.4-4ubuntu3.4 Begin: Loading essential drivers ... done. Begin: Runing /scripts/init-premount ... done. Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done. Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems done. Begin: Waiting for root file system ... Begin: Running /scripts/local-block ... done. done. Gave up waiting for root file system device. Common problems: - Boot args (cat /proc/cmdline) - Check rootdelay= (did the system wait long enough?) - Missing modules (cat /proc/modules; ls /dev) ALERT! UUID=22b42cf5-1fe2-452f-a24f-517ca91c8f58 does not exist. Dropping to a shell! BusyBox v1.30.1 (Ubuntu 1:1.30.1-4ubuntu6.3) built-in shell (ash) Enter 'help' for a list of built-in commands. (initramfs) _ Thought this was no big deal, took my files and decided i would reinstall armbian later. I just tried a fresh armbian install from here : https://www.armbian.com/sopine-a64/ and got the same problem. Can anyone explain to me what is happening here ?
tparys Posted April 20, 2021 Posted April 20, 2021 Explanation of what you're seeing: https://forum.armbian.com/topic/11366-alert-devmmcblk0p1-does-not-exist/?do=findComment&comment=120713 Short version is that the early boot is looking for your boot partition by UUID (sort of a unique fingerprint) and cannot find it. You might be missing a driver in the initramfs, have a drive that's not being powered correctly, or just a bad image. I would start in that shell, and see what MMC block devices you have (/dev/mmcblk*) or hard drives (/dev/sd*) that you're expecting. Also worthwhile is to check the kernel log ( " dmesg | more " ) and check to see if any important hardware failed to initialize, missing firmware, etc ...
Guest Posted May 9, 2021 Posted May 9, 2021 Thanks a lot for your answer. I reflashed a sdcard with the link provided directly by pine64 here https://wiki.pine64.org/wiki/SOPINE_Software_Release#Armbian using the "Armbian Debian Buster for Server and Light Desktop Usage" link. It appears the UUID causing the problem is the same as the my "root=UUDI=" kernel argument. Gave up waiting for root file system device. Common problems: - Boot args (cat /proc/cmdline) - Check rootdelay= (did the system wait long enougth?) - Missing modules (cat /proc/modules; ls /dev) ALERT! UUID=b9866ace-f260-437c-9794-8e1a363a3c71 does not exist. Dropping to a shell. (initramfs) cat /proc/cmdline root=UUID=b9866ace-f260-437c-9794-8e1a363a3c71 rootwait rootfstype=ext4 ........ I thought that the given UUID might not be the right one. But when I plug my sdcard and run blkid I have the same : sudo blkid /dev/mmcblk0p1 /dev/mmcblk0p1: UUID="b9866ace-f260-437c-9794-8e1a363a3c71" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="a1a25812-01" When i ran /dev/m* and /dev/s* I could not find any mmcblk* or sd* partitions (I guess that's normal since it couldn't find the root).
Guest Posted May 9, 2021 Posted May 9, 2021 By the way I tried "cat /proc/modules" and this is the result : (initramfs) cat /proc/modules realtek 24576 0 - Live 0xffff800008d5c000 pinctrl_axp209 16384 0 - Live 0xffff800008d48000 dwmac_sun8i 28672 0 - Live 0xffff800008d48000 mdio_mux 16384 1 dwmac_sun8i, Live 0xffff800008d40000 I will try to learn more about initramfs and it's modules.
Guest Posted May 9, 2021 Posted May 9, 2021 On 4/20/2021 at 3:22 AM, tparys said: Also worthwhile is to check the kernel log ( " dmesg | more " ) I could only see the lower part of those since I cannot access the 'more' command. Maybe the debian-base and ubuntu-base initramfs rescue shells are different though.
Patrick Peters Posted May 9, 2021 Posted May 9, 2021 Hi ArthurS, You probably ran into the same problem as i did. At least if it is a SD card you are using? Please see my posting with how i fixed it:
Guest Posted May 9, 2021 Posted May 9, 2021 Hi Patrick, thanks for your answer. I am using a sd card and made the changes you suggested. The line to change was weirdly at 600 and not at 1200~ as written in your post. mmc@1c0f000 { compatible = "allwinner,sun50i-a64-mmc"; reg = <0x1c0f000 0x1000>; clocks = <0x02 0x1f 0x02 0x4b>; clock-names = "ahb\0mmc"; resets = <0x02 0x08>; reset-names = "ahb"; interrupts = <0x00 0x3c 0x04>; max-frequency = <0x8f0d180>; status = "okay"; bus-width = <0x04>; #address-cells = <0x01>; #size-cells = <0x00>; pinctrl-names = "default"; pinctrl-0 = <0x25>; vmmc-supply = <0x26>; disable-wp; non-removable; cd-gpios = <0x27 0x05 0x06 0x01>; phandle = <0x69>; }; mmc@1c10000 { compatible = "allwinner,sun50i-a64-mmc"; reg = <0x1c10000 0x1000>; clocks = <0x02 0x20 0x02 0x4c>; clock-names = "ahb\0mmc"; resets = <0x02 0x09>; reset-names = "ahb"; interrupts = <0x00 0x3d 0x04>; max-frequency = <0x8f0d180>; status = "okay"; #address-cells = <0x01>; #size-cells = <0x00>; pinctrl-names = "default"; pinctrl-0 = <0x28>; vmmc-supply = <0x29>; vqmmc-supply = <0x2a>; non-removable; bus-width = <0x04>; phandle = <0x6a>; }; mmc@1c11000 { compatible = "allwinner,sun50i-a64-emmc"; reg = <0x1c11000 0x1000>; clocks = <0x02 0x21 0x02 0x4d>; clock-names = "ahb\0mmc"; resets = <0x02 0x0a>; reset-names = "ahb"; interrupts = <0x00 0x3e 0x04>; max-frequency = <0x8f0d180>; status = "okay"; #address-cells = <0x01>; #size-cells = <0x00>; pinctrl-names = "default"; pinctrl-0 = <0x2b>; vmmc-supply = <0x26>; vqmmc-supply = <0x2c>; bus-width = <0x08>; non-removable; cap-mmc-hw-reset; mmc-hs200-1_8v; phandle = <0x6b>; }; The boot problem still persist though. The following line loops until it throws me into the initramfs shell. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. ... Should i try to put non-removable on all mmc@* blocks ?
Guest Posted June 24, 2021 Posted June 24, 2021 Just retried and now works on Armbian buster 21.05.1. Image : Armbian_21.05.1_Pine64so_buster_current_5.10.34.img Thanks for your help everyone
