HI,
Sorry for my poor english.
I have installed armbian image on a sdcard  (Armbian_21.05.0-trunk_Aw-h6-tv_focal_current_5.10.27_xfce_desktop.img.xz). I used tanix t6 dtb but the screen is black after starting the box.
Here is the model of the tv box with allwinner h6 soc :
When i connect my pc with usb wire, i'm able to connect it with adb. And i see that the board in the android box is configured with sun50iw6p1.
In the balbes150 repositories this configuration don't exists.
But i can find the dts files in github : https://github.com/Allwinner-Homlet/H6-BSP4.9-linux
There are 4 dts files :
sun50iw6p1-soc.dts
sun50iw6p1.dtsi
sun50iw6p1-clk.dtsi
sun50iw6p1-pinctrl.dtsi
The sun50iw6p1.dtsi file includes :
arm-gic.h
gpio.h
The arm-gic.h file includes :
irq.h
Is there a way with device-tree-compiler to make the dtb file to integrate in the armbian installation ?
If it is possible, how can i do ?
Bests regards.
PS : I joint the differents files :
sun50iw6p1-soc.dts
 * Allwinner Technology CO., Ltd. sun50iw6p1 soc board.
 * soc board support.
/dts-v1/;
#include "sun50iw6p1.dtsi"
	soc@03000000 {
	wlan:wlan {
		compatible = "allwinner,sunxi-wlan";
		wlan_busnum = <1>;
		wlan_usbnum = <3>;
		wlan_power;
		wlan_io_regulator;
		wlan_en;
		wlan_regon;
		wlan_hostwake;
		status = "disabled";
	bt:bt {
		compatible = "allwinner,sunxi-bt";
		clocks = <&clk_losc_out>;
		bt_power = "vcc-wifi";
		bt_io_regulator = "vcc-wifi-io";
		bt_rst_n = <&r_pio PM 4 1 0 0 0>;
		status = "okay";
	btlpm:btlpm {
		compatible = "allwinner,sunxi-btlpm";
		uart_index = <1>;
		bt_wake = <&r_pio PM 2 1 0 0 1>;
		bt_hostwake = <&r_pio PM 1 6 0 0 0>;
		status = "okay";
sun50iw6p1.dtsi
 * Allwinner Technology CO., Ltd. sun50iw6p1 platform
 * modify base on juno.dts
/* kernel used */
/memreserve/ 0x40020000 0x00000800; /* super standby range        : [0x40020000~0x41020800], size = 2K  */
/memreserve/ 0x48000000 0x01000000; /* atf                        : [0x48000000~0x49000000], size = 16M */
/* tf used */
/memreserve/ 0x48100000 0x00004000; /* arisc dram code space range: [0x48100000~0x48104000], size = 16K */
/memreserve/ 0x48104000 0x00001000; /* arisc para cfg range       : [0x48104000~0x48105000], size = 4K  */
/memreserve/ 0x48105000 0x00001000; /* arisc message pool range   : [0x48105000~0x48106000], size = 4K  */
#include <dt-bindings/interrupt-controller/arm-gic.h>
#include <dt-bindings/gpio/gpio.h>
#include "sun50iw6p1-clk.dtsi"
#include "sun50iw6p1-pinctrl.dtsi"
	model = "sun50iw6";
	compatible = "arm,sun50iw6p1";
	interrupt-parent = <&gic>;
	#address-cells = <2>;
	#size-cells = <2>;
	aliases {
		serial0 = &uart0;
		serial1 = &uart1;
		serial2 = &uart2;
		serial3 = &uart3;
		twi0 = &twi0;
		twi1 = &twi1;
		twi2 = &twi2;
		twi3 = &twi3;
		spi0 = &spi0;
		spi1 = &spi1;
		pcie = &pcie;
		scr0 = &scr0;
		scr1 = &scr1;
		gmac0 = &gmac0;
		global_timer0  = &soc_timer0;
		mmc0 = &sdc0;
		mmc2 = &sdc2;
		nand0 =&nand0;
		disp = &disp;
		lcd0 = &lcd0;
		lcd1 = &lcd1;
		hdmi = &hdmi;
		pwm = &pwm;
		pwm0 = &pwm0;
		pwm1 = &pwm1;
		tv0 = &tv0;
		s_pwm = &s_pwm;
		spwm0 = &spwm0;
		ac200 = &ac200;
		boot_disp = &boot_disp;
		charger0 = &charger0;
		regulator0 = &regulator0;
	chosen {
		bootargs = "earlyprintk=sunxi-uart,0x05000000 loglevel=8 initcall_debug=1 console=ttyS0 init=/init";
		linux,initrd-start = <0x0 0x0>;
		linux,initrd-end = <0x0 0x0>;
	cpus {
		#size-cells = <0>;
		cpu@0 {
			device_type = "cpu";
			compatible = "arm,cortex-a53","arm,armv8";
			reg = <0x0 0x0>;
			enable-method = "psci";
			clocks = <&clk_pll_cpu>;
			clock-latency = <2000000>;
			clock-frequency = <1320000000>;
			operating-points-v2 = <&cpu_opp_l_table0 &cpu_opp_l_table1 &cpu_opp_l_table2>;
			cpu-idle-states = <&CPU_SLEEP_0 &CLUSTER_SLEEP_0 &SYS_SLEEP_0>;
		cpu@1 {
			reg = <0x0 0x1>;
		cpu@2 {
			reg = <0x0 0x2>;
		cpu@3 {
			reg = <0x0 0x3>;
		idle-states {
			entry-method = "arm,psci";
			CPU_SLEEP_0: cpu-sleep-0 {
				compatible = "arm,idle-state";
				arm,psci-suspend-param = <0x0010000>;
				entry-latency-us = <4000>;
				exit-latency-us = <10000>;
				min-residency-us = <15000>;
			CLUSTER_SLEEP_0: cluster-sleep-0 {
				arm,psci-suspend-param = <0x1010000>;
				entry-latency-us = <50000>;
				exit-latency-us = <100000>;
				min-residency-us = <250000>;
			SYS_SLEEP_0: sys-sleep-0 {
				arm,psci-suspend-param = <0x2010000>;
				entry-latency-us = <100000>;
				exit-latency-us = <2000000>;
				min-residency-us = <4500000>;
	psci {
	    compatible		=  "arm,psci-0.2";
	    method		=  "smc";
	    psci_version	=  <0x84000000>;
	    cpu_suspend		=  <0xc4000001>;
	    cpu_off		=  <0x84000002>;
	    cpu_on		=  <0xc4000003>;
	    affinity_info	=  <0xc4000004>;
	    migrate		=  <0xc4000005>;
	    migrate_info_type	=  <0x84000006>;
	    migrate_info_up_cpu =  <0xc4000007>;
	    system_off		=  <0x84000008>;
	    system_reset	=  <0x84000009>;
	n_brom {
		compatible = "allwinner,n-brom";
		reg = <0x0 0x0 0x0 0xa000>;
	s_brom {
		compatible = "allwinner,s-brom";
		reg = <0x0 0x0 0x0 0x10000>;
	sram_ctrl {
		device_type = "sram_ctrl";
		compatible = "allwinner,sram_ctrl";
		reg = <0x0 0x03000000 0x0 0x100>;
	sram_a1 {
		compatible = "allwinner,sram_a1";
		reg = <0x0 0x00020000 0x0 0x8000>;
	sram_a2 {
		compatible = "allwinner,sram_a2";
		reg = <0x0 0x00100000 0x0 0x14000>;
	prcm {
		compatible = "allwinner,prcm";
		reg = <0x0 0x01f01400 0x0 0x400>;
	s_cpuscfg {
		compatible = "allwinner,s_cpuscfg";
		reg = <0x0 0x01f01c00 0x0 0x400>;
	ion {
		compatible = "allwinner,sunxi-ion";
		/*types is list here:
			ION_HEAP_TYPE_SYSTEM = 0,
			ION_HEAP_TYPE_SYSTEM_CONTIG = 1,
			ION_HEAP_TYPE_CARVEOUT = 2,
			ION_HEAP_TYPE_CHUNK = 3,
			ION_HEAP_TYPE_DMA = 4,
			ION_HEAP_TYPE_SECURE = 5,
		heap_sys_user@0{
			compatible = "allwinner,sys_user";
			heap-name  = "sys_user";
			heap-id    = <0x0>;
			heap-base  = <0x0>;
			heap-size  = <0x0>;
			heap-type  = "ion_system";
		heap_sys_contig@0{
			compatible = "allwinner,sys_contig";
			heap-name  = "sys_contig";
			heap-id    = <0x1>;
			heap-base  = <0x0>;
			heap-size  = <0x0>;
			heap-type  = "ion_contig";
		heap_cma@0{
			compatible = "allwinner,cma";
			heap-name  = "cma";
			heap-id    = <0x4>;
			heap-base  = <0x0>;
			heap-size  = <0x0>;
			heap-type  = "ion_cma";
		heap_secure@0{
			compatible = "allwinner,secure";
			heap-name  = "secure";
			heap-id    = <0x5>;
			heap-base  = <0x0>;
			heap-size  = <0x0>;
			heap-type  = "ion_secure";
	dram: dram {
		compatible = "allwinner,dram";
		clocks = <&clk_pll_ddr0>;
		clock-names = "pll_ddr";
		dram_clk        = <672>;
		dram_type       = <3>;
		dram_zq         = <0x003F3FDD>;
		dram_odt_en     = <1>;
		dram_para1      = <0x10f41000>;
		dram_para2      = <0x00001200>;
		dram_mr0        = <0x1A50>;
		dram_mr1        = <0x40>;
		dram_mr2        = <0x10>;
		dram_mr3        = <0>;
		dram_tpr0       = <0x04E214EA>;
		dram_tpr1       = <0x004214AD>;
		dram_tpr2       = <0x10A75030>;
		dram_tpr3       = <0>;
		dram_tpr4       = <0>;
		dram_tpr5       = <0>;
		dram_tpr6       = <0>;
		dram_tpr7       = <0>;
		dram_tpr8       = <0>;
		dram_tpr9       = <0>;
		dram_tpr10      = <0>;
		dram_tpr11      = <0>;
		dram_tpr12      = <168>;
		dram_tpr13      = <0x823>;
	memory@40000000 {
		device_type = "memory";
		reg = <0x00000000 0x40000000 0x00000000 0x20000000>;
	gic: interrupt-controller@03020000 {
		compatible = "arm,cortex-a15-gic", "arm,cortex-a9-gic";
		#interrupt-cells = <3>;
		#address-cells = <0>;
		device_type = "gic";
		interrupt-controller;
		reg = <0x0 0x03021000 0 0x1000>, /* GIC Dist */
		      <0x0 0x03022000 0 0x2000>, /* GIC CPU */
		      <0x0 0x03024000 0 0x2000>, /* GIC VCPU Control */
		      <0x0 0x03026000 0 0x2000>; /* GIC VCPU */
		interrupts = <GIC_PPI 9 0xf04>; /* GIC Maintenence IRQ */
	sid: sunxi-sid@03006000 {
		compatible = "allwinner,sunxi-sid";
		device_type = "sid";
		reg = <0x0 0x03006000 0 0x1000>;
	chipid: sunxi-chipid@03006200 {
		compatible = "allwinner,sunxi-chipid";
		device_type = "chipid";
		reg = <0x0 0x03006200 0 0x0200>;
	timer_arch {
		compatible = "arm,armv8-timer";
		interrupts = <GIC_PPI 13 0xff01>, /* Secure Phys IRQ */
			     <GIC_PPI 14 0xff01>, /* Non-secure Phys IRQ */
			     <GIC_PPI 11 0xff01>, /* Virt IRQ */
			     <GIC_PPI 10 0xff01>; /* Hyp IRQ */
		clock-frequency = <24000000>;
	pmu {
		compatible = "arm,armv8-pmuv3";
		interrupts = <GIC_SPI 140 4>,
			     <GIC_SPI 141 4>,
			     <GIC_SPI 142 4>,
			     <GIC_SPI 143 4>;
	opp_dvfs_table:opp_dvfs_table {
		cluster_num = <1>;
		opp_table_count = <3>;
		cpu_opp_l_table0: opp_l_table0 {
			compatible = "allwinner,opp_l_table0";
			opp_count = <8>;
			opp-shared;
			opp00 {
				opp-hz = /bits/ 64 <480000000>;
				opp-microvolt = <880000>;
				axi-bus-divide-ratio = <3>;
				clock-latency-ns = <2000000>;
			opp01 {
				opp-hz = /bits/ 64 <720000000>;
			opp02 {
				opp-hz = /bits/ 64 <816000000>;
			opp03 {
				opp-hz = /bits/ 64 <888000000>;
				opp-microvolt = <940000>;
			opp04 {
				opp-hz = /bits/ 64 <1080000000>;
				opp-microvolt = <1060000>;
			opp05 {
				opp-hz = /bits/ 64 <1320000000>;
				opp-microvolt = <1160000>;
			opp06 {
				opp-hz = /bits/ 64 <1488000000>;
			opp07 {
				opp-hz = /bits/ 64 <1800000000>;
		cpu_opp_l_table1: opp_l_table1 {
			compatible = "allwinner,opp_l_table1";
			opp_count = <8>;
			opp-shared;
			opp00 {
				opp-microvolt = <820000>;
			opp01 {
			opp02 {
			opp03 {
			opp04 {
			opp05 {
			opp06 {
				opp-microvolt = <1000000>;
			opp07 {
				opp-microvolt = <1100000>;
		cpu_opp_l_table2: opp_l_table2 {
			compatible = "allwinner,opp_l_table2";
			opp_count = <8>;
			opp-shared;
			opp00 {
				opp-microvolt = <800000>;
			opp01 {
			opp02 {
			opp03 {
			opp04 {
				opp-microvolt = <840000>;
			opp05 {
				opp-microvolt = <900000>;
			opp06 {
				opp-microvolt = <960000>;
			opp07 {
	dramfreq {
		compatible = "allwinner,sunxi-dramfreq";
		reg = <0x0 0x04002000 0x0 0x1000>,
		      <0x0 0x04003000 0x0 0x3000>,
		      <0x0 0x03001000 0x0 0x1000>;
		interrupts = <GIC_SPI 33 0x4>;
		status = "okay";
	uboot: uboot {
	mmu_aw: iommu@030f0000 {
		compatible = "allwinner,sunxi-iommu";
		reg = <0x0 0x030f0000 0x0 0x1000>;
		interrupts = <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>;
		interrupt-names = "iommu-irq";
		clocks = <&clk_iommu>;
		clock-names = "iommu";
		/* clock-frequency = <24000000>; */
		#iommu-cells = <2>;
		status = "okay";
	soc: soc@03000000 {
		compatible = "simple-bus";
		#size-cells = <2>;
		ranges;
		device_type = "soc";
		dma0:dma-controller@03002000 {
			compatible = "allwinner,sun50i-dma";
			reg = <0x0 0x03002000 0x0 0x1000>;
			interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&clk_dma>;
			#dma-cells = <1>;
		mbus0:mbus-controller@04002000 {
			compatible = "allwinner,sun50i-mbus";
			reg = <0x0 0x04002000 0x0 0x1000>;
			#mbus-cells = <1>;
		arisc {
			compatible = "allwinner,sunxi-arisc";
			#size-cells = <2>;
			clocks = <&clk_losc>, <&clk_iosc>, <&clk_hosc>, <&clk_pll_periph0>;
			clock-names = "losc", "iosc", "hosc", "pll_periph0";
			powchk_used = <0x0>;
			power_reg = <0x02309621>;
			system_power = <50>;
		arisc_space {
			compatible = "allwinner,arisc_space";
			/* num    dst        offset     size                              */
			space1 = <0x48040000 0x00000000 0x00014000>; /* srama2 code space */
			space2 = <0x48100000 0x00018000 0x00004000>; /* dram code space   */
			space3 = <0x48104000 0x00000000 0x00001000>; /* para space        */
			space4 = <0x48105000 0x00000000 0x00001000>; /* msgpool space     */
		standby_space {
			compatible = "allwinner,sun50iw6-usbstandby";
			space1 = <0x40020000 0x00000000 0x00000800>; /* super standby para space        */
		msgbox: msgbox@03003000 {
			compatible = "allwinner,msgbox";
			clocks = <&clk_msgbox>;
			clock-names = "clk_msgbox";
			reg = <0x0 0x03003000 0x0 0x1000>;
			interrupts = <GIC_SPI 39 IRQ_TYPE_EDGE_RISING>;
			status = "okay";
		hwspinlock: hwspinlock@3004000 {
			compatible = "allwinner,sunxi-hwspinlock";
			clocks = <&clk_hwspinlock_rst>, <&clk_hwspinlock_bus>;
			clock-names = "clk_hwspinlock_rst", "clk_hwspinlock_bus";
			reg = <0x0 0x03004000 0x0 0x1000>;
			num-locks = <8>; /* the number hwspinlock we needed, max 32 */
			status = "okay";
		s_cir0: s_cir@07040000 {
			compatible = "allwinner,s_cir";
			reg = <0x0 0x07040000 0x0 0x400>;
			interrupts = <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>;
			pinctrl-names = "default";
			pinctrl-0 = <&s_cir0_pins_a>;
			clocks = <&clk_hosc>,<&clk_cpurcir>;
			supply = "vcc-pl";
			supply_vol = "3300000";
			status = "okay";
		s_uart0: s_uart@7080000 {
			compatible = "allwinner,s_uart";
			reg = <0x0 0x07080000 0x0 0xd0>;
			interrupts = <GIC_SPI 106 IRQ_TYPE_LEVEL_HIGH>;
			pinctrl-0 = <&s_uart0_pins_a>;
			status = "okay";
		s_twi0: s_twi@1f03400 {
			compatible = "allwinner,s_twi";
			reg = <0x0 0x01f02400 0x0 0x20>;
			interrupts = <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>;
			pinctrl-0 = <&s_twi0_pins_a>;
			status = "okay";
		s_jtag0: s_jtag0 {
			compatible = "allwinner,s_jtag";
			pinctrl-0 = <&s_jtag0_pins_a>;
			status = "disable";
		box_start_os: box_start_os0 {
			compatible = "allwinner,box_start_os";
			start_type = <0x0>;
			irkey_used = <0x0>;
			pmukey_used = <0x0>;
			pmukey_num = <0x0>;
			led_power = <0x0>;
			led_state = <0x0>;
			status = "disable";
		soc_timer0: timer@03009000 {
			compatible = "allwinner,sun4i-a10-timer";
			device_type = "timer";
			reg = <0x0 0x03009000 0x0 0x400>;
			interrupts = <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>;
			timer-prescale = <16>;
		rtc: rtc@07000000 {
			compatible = "allwinner,sun50iw6-rtc";
			device_type = "rtc";
			reg = <0x0 0x07000000 0x0 0x200>;
			interrupts = <GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH>;
			gpr_offset = <0x100>;
			gpr_len	   = <8>;
			gpr_cur_pos = <6>;
		wdt: watchdog@030090a0 {
			compatible = "allwinner,sun50i-wdt";
			reg = <0x0 0x030090a0 0x0 0x20>;
			interrupts = <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>;
		ve: ve@01c0e000 {
			compatible = "allwinner,sunxi-cedar-ve";
			reg = <0x0 0x01c0e000 0x0 0x1000>,
			      <0x0 0x03000000 0x0 0x10>,
			interrupts = <GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&clk_pll_ve>,	<&clk_ve>;
			iommus = <&mmu_aw 3 1>;
		vp9: vp9@01c00000 {
			compatible = "allwinner,sunxi-google-vp9";
			reg = <0x0 0x01c00000 0x0 0x1000>,
			interrupts = <GIC_SPI 90 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&clk_pll_ve>,	<&clk_vp9>;
			#clocks = <&clk_pll_periph0x2>,	<&clk_vp9>;
			iommus = <&mmu_aw 5 1>;
		uart0: uart@05000000 {
			compatible = "allwinner,sun50i-uart";
			device_type = "uart0";
			reg = <0x0 0x05000000 0x0 0x400>;
			interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&clk_uart0>;
			pinctrl-names = "default", "sleep";
			pinctrl-0 = <&uart0_pins_a>;
			pinctrl-1 = <&uart0_pins_b>;
			uart0_port = <0>;
			uart0_type = <2>;
		uart1: uart@05000400 {
			device_type = "uart1";
			reg = <0x0 0x05000400 0x0 0x400>;
			interrupts = <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&clk_uart1>;
			pinctrl-0 = <&uart1_pins_a>;
			pinctrl-1 = <&uart1_pins_b>;
			uart1_port = <1>;
			uart1_type = <4>;
		uart2: uart@05000800 {
			device_type = "uart2";
			reg = <0x0 0x05000800 0x0 0x400>;
			interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&clk_uart2>;
			pinctrl-0 = <&uart2_pins_a>;
			pinctrl-1 = <&uart2_pins_b>;
			uart2_port = <2>;
			uart2_type = <4>;
			status = "okay";
		uart3: uart@05000c00 {
			device_type = "uart3";
			reg = <0x0 0x05000c00 0x0 0x400>;
			interrupts = <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&clk_uart3>;
			pinctrl-0 = <&uart3_pins_a>;
			pinctrl-1 = <&uart3_pins_b>;
			uart3_port = <3>;
			uart3_type = <4>;
		twi0: twi@0x05002000{
			#address-cells = <1>;
			#size-cells = <0>;
			compatible = "allwinner,sun50i-twi";
			device_type = "twi0";
			reg = <0x0 0x05002000 0x0 0x400>;
			interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&clk_twi0>;
			clock-frequency = <400000>;
			pinctrl-0 = <&twi0_pins_a>;
			pinctrl-1 = <&twi0_pins_b>;
		twi1: twi@0x05002400{
			#size-cells = <0>;
			device_type = "twi1";
			reg = <0x0 0x05002400 0x0 0x400>;
			interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&clk_twi1>;
			clock-frequency = <200000>;
			pinctrl-0 = <&twi1_pins_a>;
			pinctrl-1 = <&twi1_pins_b>;
		twi2: twi@0x05002800{
			#size-cells = <0>;
			device_type = "twi2";
			reg = <0x0 0x05002800 0x0 0x400>;
			interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&clk_twi2>;
			pinctrl-0 = <&twi2_pins_a>;
			pinctrl-1 = <&twi2_pins_b>;
		twi3: twi@0x05002c00{
			#size-cells = <0>;
			device_type = "twi3";
			reg = <0x0 0x05002c00 0x0 0x400>;
			interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&clk_twi3>;
			pinctrl-0 = <&twi3_pins_a>;
			pinctrl-1 = <&twi3_pins_b>;
		usbc0:usbc0@0 {
			device_type = "usbc0";
			compatible = "allwinner,sunxi-otg-manager";
			usb_port_type = <2>;
			usb_detect_type = <1>;
			usb_id_gpio;
			usb_det_vbus_gpio;
			usb_drv_vbus_gpio;
			usb_host_init_state = <0>;
			usb_regulator_io = "nocare";
			usb_wakeup_suspend = <0>;
			usb_luns = <3>;
			usb_serial_unique = <0>;
			usb_serial_number = "20080411";
			rndis_wceis = <1>;
			status = "okay";
		udc:udc-controller@0x05100000 {
			compatible = "allwinner,sunxi-udc";
			reg = <0x0 0x05100000 0x0 0x1000>, /*udc base*/
			      <0x0 0x00000000 0x0 0x100>; /*sram base*/
			interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&clk_usbphy0>, <&clk_usbotg>;
			status = "okay";
		ehci0:ehci0-controller@0x05101000 {
			compatible = "allwinner,sunxi-ehci0";
			reg = <0x0 0x05101000 0x0 0xFFF>, /*hci0 base*/
			      <0x0 0x00000000 0x0 0x100>, /*sram base*/
			      <0x0 0x05100000 0x0 0x1000>; /*otg base*/
			interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&clk_usbphy0>, <&clk_usbehci0>;
			hci_ctrl_no = <0>;
			status = "okay";
		ohci0:ohci0-controller@0x05101400 {
			compatible = "allwinner,sunxi-ohci0";
			interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&clk_usbphy0>, <&clk_usbohci0>, <&clk_usbohci0_12m>, <&clk_osc48md4>, <&clk_hosc>, <&clk_losc>;
			hci_ctrl_no = <0>;
			status = "okay";
		usbc1:usbc1@0 {
			device_type = "usbc1";
			usb_drv_vbus_gpio;
			usb_host_init_state = <1>;
			status = "okay";
		xhci:xhci-controller@0x05200000 {
			compatible = "allwinner,sunxi-xhci";
			reg = <0x0 0x05200000 0x0 0xFFFFF>, /*Xhci base*/
			interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&clk_usbphy1>, <&clk_usb3_0_host>;
			hci_ctrl_no = <1>;
			status = "okay";
		usbc2:usbc2@0 {
			device_type = "usbc2";
			usb_drv_vbus_gpio;
			status = "okay";
		ehci3:ehci3-controller@0x05311000 {
			compatible = "allwinner,sunxi-ehci3";
			reg = <0x0 0x05311000 0x0 0xFFF>,/*hci2 base*/
			interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&clk_usbphy3>, <&clk_usbehci3>, <&clk_usbhsic>, <&clk_usbhsic>, <&clk_pll_hsic>;
			hci_ctrl_no = <3>;
			status = "okay";
		ohci3:ohci3-controller@0x05311400 {
			compatible = "allwinner,sunxi-ohci3";
			reg = <0x0 0x05311000 0x0 0xFFF>, /*hci2 base*/
			interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&clk_usbphy3>, <&clk_usbohci3>, <&clk_usbohci3_12m>, <&clk_osc48md4>, <&clk_hosc>, <&clk_losc>;
			hci_ctrl_no = <3>;
			status = "okay";
		ac200_codec: ac200_codec {
			compatible = "allwinner,ac200_codec";
		daudio0:daudio@0x05090000 {
			compatible = "allwinner,sunxi-daudio";
			reg = <0x0 0x05090000 0x0 0x74>;
			clocks = <&clk_pll_audio>,<&clk_i2s0>;
			pinctrl-names = "default","sleep";
			pinctrl-0 = <&daudio0_pins_a>;
			pinctrl-1 = <&daudio0_pins_b>;
			pcm_lrck_period =  <0x20>;
			slot_width_select =  <0x20>;
			daudio_master =  <0x04>;
			audio_format =  <0x01>;
			signal_inversion =  <0x01>;
			tdm_config =  <0x01>;
			frametype = <0x00>;
			tdm_num = <0x00>;
			mclk_div = <0x00>;
		audiohdmi:daudio@0x05091000 {
			compatible = "allwinner,sunxi-tdmhdmi";
			reg = <0x0 0x05091000 0x0 0x74>;
			clocks = <&clk_pll_audio>,<&clk_i2s1>;
		daudio2:daudio@0x05092000 {
			reg = <0x0 0x05092000 0x0 0x74>;
			clocks = <&clk_pll_audio>,<&clk_i2s2>;
			pinctrl-0 = <&daudio2_pins_a>;
			pinctrl-1 = <&daudio2_pins_b>;
			frametype = <0x00>;
			tdm_num = <0x2>;
			mclk_div = <0x0>;
		daudio3:daudio@0x0508f000{
			reg = <0x0 0x0508f000 0x0 0x74>;
			clocks = <&clk_pll_audio>,<&clk_i2s3>;
			pinctrl-0 = <&daudio3_pins_a>;
			pinctrl-1 = <&daudio3_pins_b>;
			frametype = <0x00>;
			tdm_num = <0x3>;
			mclk_div = <0x0>;
		spdif:spdif-controller@0x05093000{
			compatible = "allwinner,sunxi-spdif";
			reg = <0x0 0x05093000 0x0 0x40>;
			clocks = <&clk_pll_audio>,<&clk_spdif>;
			pinctrl-0 = <&spdif_pins_a>;
			pinctrl-1 = <&spdif_pins_b>;
		dmic:dmic-controller@0x05095000{
			compatible = "allwinner,sunxi-dmic";
			reg = <0x0 0x05095000 0x0 0x50>;
			clocks = <&clk_pll_audio>,<&clk_dmic>;
			pinctrl-0 = <&dmic_pins_a>;
			pinctrl-1 = <&dmic_pins_b>;
		ahub_cpudai0:cpudai0-controller@0x05097000 {
			compatible = "allwinner,sunxi-ahub-cpudai";
			reg = <0x0 0x05097000 0x0 0xADF>;
			id = <0x0>;
			status = "okay";
		ahub_cpudai1:cpudai1-controller@0x05097000 {
			id = <0x1>;
			status = "okay";
		ahub_cpudai2:cpudai2-controller@0x05097000 {
			id = <0x2>;
			status = "okay";
		ahub_codec:ahub_codec@0x05097000{
			compatible = "allwinner,sunxi-ahub";
			clocks = <&clk_pll_audio>,<&clk_ahub>;
			status = "okay";
		ahub_daudio0:ahub_daudio0@0x05097000{
			compatible = "allwinner,sunxi-ahub-daudio";
			pinctrl-0 = <&ahub_daudio0_pins_a>;
			pinctrl-1 = <&ahub_daudio0_pins_b>;
			pinconfig = <0x1>;
			frametype = <0x0>;
			tdm_num = <0x0>;
			mclk_div = <0x0>;
		ahub_daudio1:ahub_daudio1@0x05097000{
			pinconfig = <0x0>;
			frametype = <0x0>;
			tdm_num = <0x1>;
			mclk_div = <0x0>;
			status = "okay";
		ahub_daudio2:ahub_daudio2@0x05097000{
			pinctrl-0 = <&ahub_daudio2_pins_a>;
			pinctrl-1 = <&ahub_daudio2_pins_b>;
			pinconfig = <0x1>;
			frametype = <0x0>;
			tdm_num = <0x2>;
			mclk_div = <0x0>;
			status = "okay";
		ahub_daudio3:ahub_daudio3@0x05097000{
			pinctrl-0 = <&ahub_daudio3_pins_a>;
			pinctrl-1 = <&ahub_daudio3_pins_b>;
			pinconfig = <0x1>;
			frametype = <0x0>;
			tdm_num = <0x3>;
			mclk_div = <0x4>;
			status = "okay";
		snddaudio0:sound@0{
			compatible = "allwinner,sunxi-daudio0-machine";
			sunxi,daudio-controller = <&daudio0>;
			sunxi,cpudai-controller = <&ahub_daudio0>;
			status = "disable";
		sndhdmi:sound@1{
			compatible = "allwinner,sunxi-hdmi-machine";
			sunxi,hdmi-controller = <&audiohdmi>;
			sunxi,cpudai-controller = <&ahub_daudio1>;
			status = "okay";
		snddaudio2:sound@2{
			compatible = "allwinner,sunxi-daudio2-machine";
			sunxi,daudio-controller = <&daudio2>;
			sunxi,cpudai-controller = <&ahub_daudio2>;
			status = "okay";
		snddaudio3:sound@3{
			compatible = "allwinner,sunxi-daudio3-machine";
			sunxi,daudio-controller = <&daudio3>;
			sunxi,cpudai-controller = <&ahub_daudio3>;
			/* acx00-codec throught mfd_add_devices */
			sunxi,snddaudio-codec = "acx00-codec";
			sunxi,snddaudio-codec-dai = "acx00-dai";
			status = "okay";
		sndspdif:sound@4{
			compatible = "allwinner,sunxi-spdif-machine";
			sunxi,spdif-controller = <&spdif>;
		snddmic:sound@5{
			compatible = "allwinner,sunxi-dmic-machine";
			sunxi,dmic-controller = <&dmic>;
		sndahub:sound@6{
			compatible = "allwinner,sunxi-ahub-machine";
			sunxi,cpudai-controller0 = <&ahub_cpudai0>;
			sunxi,cpudai-controller1 = <&ahub_cpudai1>;
			sunxi,cpudai-controller2 = <&ahub_cpudai2>;
			sunxi,audio-codec = <&ahub_codec>;
			status = "okay";
		spi0: spi@05010000 {
			#size-cells = <0>;
			compatible = "allwinner,sun50i-spi";
			device_type = "spi0";
			reg = <0x0 0x05010000 0x0 0x1000>;
			interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&clk_pll_periph0>, <&clk_spi0>;
			clock-frequency = <100000000>;
			pinctrl-0 = <&spi0_pins_a &spi0_pins_b>;
			pinctrl-1 = <&spi0_pins_c>;
			spi0_cs_number = <1>;
			spi0_cs_bitmap = <1>;
		spi1: spi@05011000 {
			#size-cells = <0>;
			device_type = "spi1";
			reg = <0x0 0x05011000 0x0 0x1000>;
			interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&clk_pll_periph0>, <&clk_spi1>;
			pinctrl-0 = <&spi1_pins_a &spi1_pins_b>;
			pinctrl-1 = <&spi1_pins_c>;
			spi1_cs_number = <1>;
			spi1_cs_bitmap = <1>;
		pcie: pcie@0x05400000 {
			#address-cells = <3>;
			#size-cells = <2>;
			compatible = "allwinner,sun50i-pcie";
			reg = <0 0x05400000 0 0x2000>,
			      <0 0x05410000 0 0x10000>;
			reg-names = "dbi", "config";
			device_type = "pci";
			ranges = <0x00000800 0 0x05410000 0 0x05410000 0 0x00010000 /* configuration space */
				  0x81000000 0 0          0 0x05e00000 0 0x00010000 /* downstream I/O */
				  0x82000000 0 0x05500000 0 0x05500000 0 0x00800000>; /* non-prefetchable memory */
			num-lanes = <1>;
			interrupts = <GIC_SPI 127 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 126 IRQ_TYPE_LEVEL_HIGH>;
			interrupt-names = "msi";
			clocks = <&clk_pcieref>,
				<&clk_pciemaxi>,
				<&clk_pcieaux>,
				<&clk_pcie_bus>,
				<&clk_pcie_power>,
				<&clk_pcie_rst>;
			#interrupt-cells = <1>;
			interrupt-map-mask = <0 0 0 0>;
			interrupt-map = <0 0 0 1 &gic GIC_SPI 127 IRQ_TYPE_LEVEL_HIGH>;
			status = "okay";
		sdc2: sdmmc@04022000 {
			compatible = "allwinner,sunxi-mmc-v4p6x";
			device_type = "sdc2";
			reg = <0x0 0x04022000 0x0 0x1000>;
			interrupts = <GIC_SPI 37 0x0104>;
				 <&clk_pll_periph1x2>,
				 <&clk_sdmmc2_mod>,
				 <&clk_sdmmc2_bus>,
				 <&clk_sdmmc2_rst>;
			clock-names = "osc24m","pll_periph","mmc","ahb","rst";
			pinctrl-0 = <&sdc2_pins_a>;
			pinctrl-1 = <&sdc2_pins_b>;
			bus-width = <8>;
			/*mmc-ddr-1_8v;*/
			/*mmc-hs200-1_8v;*/
			/*mmc-hs400-1_8v;*/
			/*non-removable;*/
			/*max-frequency = <200000000>;*/
			max-frequency = <50000000>;
			cap-sd-highspeed;
			cap-mmc-highspeed;
			cap-erase;
			mmc-high-capacity-erase-size;
			no-sdio;
			no-sd;
			/*-- speed mode --*/
			/*sm0: DS26_SDR12*/
			/*sm1: HSSDR52_SDR25*/
			/*sm2: HSDDR52_DDR50*/
			/*sm3: HS200_SDR104*/
			/*sm4: HS400*/
			/*-- frequency point --
			/*f0: CLK_400K*/
			/*f1: CLK_25M*/
			/*f2: CLK_50M*/
			/*f3: CLK_100M*/
			/*f4: CLK_150M*/
			/*f5: CLK_200M*/
			sdc_tm4_sm0_freq0 = <0>;
			sdc_tm4_sm0_freq1 = <0>;
			sdc_tm4_sm1_freq0 = <0x00000000>;
			sdc_tm4_sm1_freq1 = <0>;
			sdc_tm4_sm2_freq0 = <0x00000000>;
			sdc_tm4_sm2_freq1 = <0>;
			sdc_tm4_sm3_freq0 = <0x05000000>;
			sdc_tm4_sm3_freq1 = <0x00000005>;
			sdc_tm4_sm4_freq0 = <0x00050000>;
			sdc_tm4_sm4_freq1 = <0x00000004>;
			/*vmmc-supply = <&reg_3p3v>;*/
			/*vqmc-supply = <&reg_3p3v>;*/
			/*vdmc-supply = <&reg_3p3v>;*/
			/*vmmc = "vcc-card";*/
			/*vqmc = "";*/
			/*vdmc = "";*/
			/*sunxi-power-save-mode;*/
			/*status = "disabled";*/
			status = "okay";
		sdc0: sdmmc@04020000 {
			compatible = "allwinner,sunxi-mmc-v4p1x";
			device_type = "sdc0";
			reg = <0x0 0x04020000 0x0 0x1000>;
			interrupts = <GIC_SPI 35 0x0104>;
				 <&clk_sdmmc0_mod>,
				 <&clk_sdmmc0_bus>,
				 <&clk_sdmmc0_rst>;
			pinctrl-0 = <&sdc0_pins_a>;
			pinctrl-1 = <&sdc0_pins_b>;
			bus-width = <4>;
			/*non-removable;*/
			/*broken-cd;*/
			/*cd-inverted*/
			cd-gpios = <&pio PF 6 0 1 2 0>;
			/* vmmc-supply = <&reg_3p3v>;*/
			/* vqmc-supply = <&reg_3p3v>;*/
			/* vdmc-supply = <&reg_3p3v>;*/
			/*vqmc = "";*/
			/*vdmc = "";*/
			cap-sd-highspeed;
			cap-mmc-highspeed;
			no-sdio;
			no-mmc;
			/*sd-uhs-sdr50;*/
			/*sd-uhs-ddr50;*/
			/*cap-sdio-irq;*/
			/*keep-power-in-suspend;*/
			/*ignore-pm-notify;*/
			/*sunxi-dly-400k = <1 0 0 0>; */
			/*sunxi-dly-26M  = <1 0 0 0>;*/
			/*sunxi-dly-52M  = <1 0 0 0>;*/
			/*sunxi-dly-52M-ddr4  = <1 0 0 0>;*/
			/*sunxi-dly-52M-ddr8  = <1 0 0 0>;*/
			/*sunxi-dly-104M  = <1 0 0 0>;*/
			/*sunxi-dly-208M  = <1 0 0 0>;*/
			/*sunxi-dly-104M-ddr  = <1 0 0 0>;*/
			/*sunxi-dly-208M-ddr  = <1 0 0 0>;*/
			status = "okay";
		sdc1: sdmmc@04021000 {
			device_type = "sdc1";
			reg = <0x0 0x04021000 0x0 0x1000>;
			interrupts = <GIC_SPI 36 0x0104>;
				 <&clk_sdmmc1_mod>,
				 <&clk_sdmmc1_bus>,
				 <&clk_sdmmc1_rst>;
			pinctrl-0 = <&sdc1_pins_a>;
			pinctrl-1 = <&sdc1_pins_b>;
			bus-width = <4>;
			/*broken-cd;*/
			/*cd-inverted*/
			/*cd-gpios = <&pio PG 6 6 1 2 0>;*/
			/*vqmc = "";*/
			/*vdmc = "";*/
			cap-sd-highspeed;
			cap-mmc-highspeed;
			no-mmc;
			/*sd-uhs-sdr50;*/
			/*sd-uhs-ddr50;*/
			/*sd-uhs-sdr104;*/
			/*cap-sdio-irq;*/
			/*sunxi-dly-400k = <1 0 0 0 0>; */
			/*sunxi-dly-26M  = <1 0 0 0 0>;*/
			/*sunxi-dly-52M  = <1 0 0 0 0>;*/
			sunxi-dly-52M-ddr4  = <1 0 0 0 2>;
			/*sunxi-dly-52M-ddr8  = <1 0 0 0 0>;*/
			sunxi-dly-104M  = <1 0 0 0 1>;
			/*sunxi-dly-208M  = <1 1 0 0 0>;*/
			sunxi-dly-208M  = <1 0 0 0 1>;
			/*sunxi-dly-104M-ddr  = <1 0 0 0 0>;*/
			/*sunxi-dly-208M-ddr  = <1 0 0 0 0>;*/
		disp: disp@01000000 {
			compatible = "allwinner,sunxi-disp";
			reg = <0x0 0x01000000 0x0 0x01400000>,/*de*/
			      <0x0 0x06510000 0x0 0x100>,/*tcon-top*/
			      <0x0 0x06511000 0x0 0x800>,/*tcon0*/
			      <0x0 0x06515000 0x0 0x800>;/*tcon1*/
			interrupts = <GIC_SPI 65 0x0104>, <GIC_SPI 66 0x0104>;
			clocks = <&clk_de>,
				 <&clk_display_top>,
				 <&clk_tcon_lcd>,
				 <&clk_tcon_tv>;
			boot_disp = <0>;
			boot_disp1 = <0>;
			boot_disp2 = <0>;
			fb_base = <0>;
			iommus = <&mmu_aw 0 0>;
			status = "okay";
		lcd0: lcd0@01c0c000 {
			compatible = "allwinner,sunxi-lcd0";
			pinctrl-names = "active","sleep";
			status = "okay";
		lcd1: lcd1@01c0c001 {
			compatible = "allwinner,sunxi-lcd1";
			status = "okay";
		hdmi: hdmi@06000000 {
			compatible = "allwinner,sunxi-hdmi";
			reg = <0x0 0x06000000 0x0 0x100000>;
			interrupts = <GIC_SPI 64 IRQ_TYPE_NONE>;
			clocks = <&clk_hdmi>,<&clk_hdmi_slow>,<&clk_hdmi_hdcp>,<&clk_hdmi_cec>;
			pinctrl-names = "ddc_active","ddc_sleep","cec_active", "cec_sleep";
			pinctrl-0 = <&hdmi_ddc_pin_a>;
			pinctrl-1 = <&hdmi_ddc_pin_b>;
			pinctrl-2 = <&hdmi_cec_pin_a>;
			pinctrl-3 = <&hdmi_cec_pin_b>;
			status = "okay";
		tv0: tv0@01c94000 {
			compatible = "allwinner,sunxi-tv";
			reg = <0x0 0x01e40000 0x0 0x1000>;
			/* clocks = <&clk_tve>; */
		soc_tr: tr@01000000 {
			compatible = "allwinner,sun50i-tr";
			reg = <0x0 0x01000000 0x0 0x000200bc>;
			interrupts = <GIC_SPI 96 0x0104>;
			clocks = <&clk_de>;
			status = "okay";
		pwm: pwm@0300a000 {
			compatible = "allwinner,sunxi-pwm";
			reg = <0x0 0x0300a000 0x0 0x3c>;
			clocks = <&clk_pwm>;
			pwm-number = <2>;
			pwm-base = <0x0>;
			pwms = <&pwm0>, <&pwm1>;
		pwm0: pwm0@0300a000 {
			compatible = "allwinner,sunxi-pwm0";
			pinctrl-names = "active", "sleep";
			reg_base = <0x0300a000>;
			reg_busy_offset = <0x00>;
			reg_busy_shift = <28>;
			reg_enable_offset = <0x00>;
			reg_enable_shift = <4>;
			reg_clk_gating_offset = <0x00>;
			reg_clk_gating_shift = <6>;
			reg_bypass_offset = <0x00>;
			reg_bypass_shift = <9>;
			reg_pulse_start_offset = <0x00>;
			reg_pulse_start_shift = <8>;
			reg_mode_offset = <0x00>;
			reg_mode_shift = <7>;
			reg_polarity_offset = <0x00>;
			reg_polarity_shift = <5>;
			reg_period_offset = <0x04>;
			reg_period_shift = <16>;
			reg_period_width = <16>;
			reg_active_offset = <0x04>;
			reg_active_shift = <0>;
			reg_active_width = <16>;
			reg_prescal_offset = <0x00>;
			reg_prescal_shift = <0>;
			reg_prescal_width = <4>;
		pwm1: pwm1@0300a000 {
			compatible = "allwinner,sunxi-pwm1";
			reg_busy_shift = <29>;
			reg_enable_shift = <19>;
			reg_clk_gating_shift = <21>;
			reg_bypass_shift = <24>;
			reg_pulse_start_shift = <23>;
			reg_mode_shift = <22>;
			reg_polarity_shift = <20>;
			reg_period_offset = <0x08>;
			reg_active_offset = <0x08>;
			reg_prescal_shift = <15>;
		s_pwm: s_pwm@07020c00 {
			compatible = "allwinner,sunxi-s_pwm";
			reg = <0x0 0x07020c00 0x0 0x3c>;
			clocks = <&clk_spwm>;
			pwm-number = <1>;
			pwm-base = <0x10>;
			pwms = <&spwm0>;
		spwm0: spwm0@07020c00 {
			compatible = "allwinner,sunxi-pwm16";
			reg_base = <0x07020c00>;
		boot_disp: boot_disp {
			compatible = "allwinner,boot_disp";
		ac200: ac200 {
			compatible = "allwinner,sunxi-ac200";
			clocks = <&clk_tcon_lcd>;
			pinctrl-names = "active","sleep", "ccir_clk_active",
			"ccir_clk_sleep";
			pinctrl-2 = <&ccir_clk_pin_a>;
			pinctrl-3 = <&ccir_clk_pin_b>;
			status = "okay";
		vind0:vind@0 {
			compatible = "allwinner,sunxi-vin-media", "simple-bus";
			#size-cells = <2>;
			ranges;
			device_id = <0>;
			reg = <0x0 0x06620000 0x0 0x1000>;
			clocks = <&clk_csi_top>, <&clk_pll_periph0>,
				 <&clk_csi_master0>, <&clk_hosc>, <&clk_pll_periph0>;
			pinctrl-names = "mclk0-default","mclk0-sleep";
			pinctrl-0 = <&csi_mclk0_pins_a>;
			pinctrl-1 = <&csi_mclk0_pins_b>;
			status = "okay";
			csi_cci0:cci@0x0662e000 {
				compatible = "allwinner,sunxi-csi_cci";
				reg = <0x0 0x0662e000 0x0 0x1000>;
				interrupts = <GIC_SPI 72 4>;
				clocks 			= <&clk_csi_misc>;
				pinctrl-0 		= <&csi_cci0_pins_a>;
				pinctrl-1 		= <&csi_cci0_pins_b>;
				device_id = <0>;
				status = "okay";
			csi0:csi@0x06621000 {
				device_type = "csi0";
				compatible = "allwinner,sunxi-csi";
				reg = <0x0 0x06621000 0x0 0x1000>;
				interrupts = <GIC_SPI 70 4>;
				pinctrl-0 = <&csi0_pins_a>;
				pinctrl-1 = <&csi0_pins_b>;
				device_id = <0>;
				iommus = <&mmu_aw 4 1>;
				status = "okay";
			csi1:csi@1 {
				device_type = "csi1";
				device_id = <1>;
			mipi0:mipi@0 {
				compatible = "allwinner,sunxi-mipi";
				device_id = <0>;
			mipi1:mipi@1 {
				device_id = <1>;
			isp0:isp@0 {
				compatible = "allwinner,sunxi-isp";
				reg = <0x0 0x02100000 0x0 0x800>;
				interrupts = <GIC_SPI 86 4>;
				device_id = <0>;
				status = "okay";
			isp1:isp@1 {
				reg = <0x0 0x02100800 0x0 0x800>;
				device_id = <1>;
			scaler0:scaler@0x02101000 {
				compatible = "allwinner,sunxi-scaler";
				reg = <0x0 0x02101000 0x0 0x400>;
				device_id = <0>;
				status = "okay";
			scaler1:scaler@0x02101400 {
				reg = <0x0 0x02101400 0x0 0x400>;
				device_id = <1>;
				status = "okay";
			scaler2:scaler@2 {
				device_id = <2>;
			scaler3:scaler@3 {
				device_id = <3>;
			actuator0:actuator@0 {
				device_type = "actuator0";
				compatible = "allwinner,sunxi-actuator";
				actuator0_name = "ad5820_act";
				actuator0_slave = <0x18>;
				actuator0_af_pwdn = <>;
				actuator0_afvdd = "afvcc-csi";
				actuator0_afvdd_vol = <2800000>;
			flash0:flash@0 {
				device_type = "flash0";
				compatible = "allwinner,sunxi-flash";
				flash0_type = <2>;
				flash0_en = <>;
				flash0_mode = <>;
				flash0_flvdd = "";
				flash0_flvdd_vol = <>;
				device_id = <0>;
			sensor0:sensor@0 {
				device_type = "sensor0";
				sensor0_mname = "ov5640";
				sensor0_twi_cci_id = <0>;
				sensor0_twi_addr = <0x78>;
				sensor0_pos = "rear";
				sensor0_isp_used = <0>;
				sensor0_fmt = <0>;
				sensor0_stby_mode = <0>;
				sensor0_vflip = <0>;
				sensor0_hflip = <0>;
				sensor0_iovdd = "iovdd-csi";
				sensor0_iovdd_vol = <2800000>;
				sensor0_avdd = "avdd-csi";
				sensor0_avdd_vol = <2800000>;
				sensor0_dvdd = "dvdd-csi-18";
				sensor0_dvdd_vol = <1500000>;
				sensor0_power_en = <>;
				sensor0_reset = <&pio PE 14 1 0 1 0>;
				sensor0_pwdn = <&pio PE 16 1 0 1 0>;
				flash_handle = <&flash0>;
				act_handle = <&actuator0>;
				status	= "okay";
			sensor1:sensor@1 {
				device_type = "sensor1";
				sensor1_mname = "ov5647";
				sensor1_twi_cci_id = <0>;
				sensor1_twi_addr = <0x6c>;
				sensor1_pos = "front";
				sensor1_isp_used = <0>;
				sensor1_fmt = <0>;
				sensor1_stby_mode = <0>;
				sensor1_vflip = <0>;
				sensor1_hflip = <0>;
				sensor1_iovdd = "iovdd-csi";
				sensor1_iovdd_vol = <2800000>;
				sensor1_avdd = "avdd-csi";
				sensor1_avdd_vol = <2800000>;
				sensor1_dvdd = "dvdd-csi-18";
				sensor1_dvdd_vol = <1500000>;
				sensor1_power_en = <>;
				sensor1_reset = <&pio PE 14 1 0 1 0>;
				sensor1_pwdn = <&pio PE 15 1 0 1 0>;
				flash_handle = <>;
				act_handle = <>;
				status	= "okay";
			vinc0:vinc@0x06623000 {
				device_type = "vinc0";
				compatible = "allwinner,sunxi-vin-core";
				reg = <0x0 0x06623000 0x0 0x100>;
				interrupts = <GIC_SPI 67 4>;
				vinc0_csi_sel = <0>;
				vinc0_mipi_sel = <0xff>;
				vinc0_isp_sel = <0>;
				vinc0_sensor_sel = <0>;
				vinc0_sensor_list = <0>;
				isp_handle = <&isp0 &isp1>;
				sensor_handle = <&sensor0 &sensor1>;
				device_id = <0>;
				status = "okay";
			vinc1:vinc@0x06623100 {
				device_type = "vinc1";
				reg = <0x0 0x06623100 0x0 0x100>;
				interrupts = <GIC_SPI 68 4>;
				vinc1_csi_sel = <0>;
				vinc1_mipi_sel = <0xff>;
				vinc1_isp_sel = <0>;
				vinc1_sensor_sel = <1>;
				vinc1_sensor_list = <0>;
				device_id = <1>;
				status = "okay";
		Vdevice: vdevice@0 {
			compatible = "allwinner,sun50i-vdevice";
			device_type = "Vdevice";
			pinctrl-0 = <&vdevice_pins_a>;
			test-gpios = <&pio PB 0 1 2 2 1>;
		emce: emce@01905000 {
			compatible = "allwinner,sunxi-emce";
			device_name = "emce";
			reg = <0x0 0x01905000 0 0x100>;
			clock-frequency = <300000000>; /*300MHZ*/
			clocks = <&clk_emce>, <&clk_pll_periph0x2>;
		cryptoengine: ce@1904000 {
			compatible = "allwinner,sunxi-ce";
			device_name = "ce";
			reg = <0x0 0x01904000 0x0 0xa0>, /* non-secure space */
			      <0x0 0x01904800 0x0 0xa0>; /* secure space */
			interrupts = <GIC_SPI 87 0xff01>, /* non-secure space */
				     <GIC_SPI 88 0xff01>; /* secure space */
			clock-frequency = <300000000>; /* 300MHz */
			clocks = <&clk_ce>, <&clk_pll_periph0x2>;
		di:deinterlace@0x01420000{
			#size-cells = <0>;
			compatible = "allwinner,sunxi-deinterlace";
			reg = <0x0 0x01420000 0x0 0x20c>;
			interrupts = <GIC_SPI 79 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&clk_di> ,<&clk_pll_periph0>;
			iommus = <&mmu_aw 2 1>;
			status = "okay";
		scr0:smartcard@0x05005000{
			#size-cells = <0>;
			compatible = "allwinner,sunxi-scr";
			device_type = "scr0";
			reg = <0x0 0x05005000 0x0 0x400>;
			interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&clk_scr0>, <&clk_apb2>;
			pinctrl-0 = <&scr0_pins_a &scr0_pins_b>;
			pinctrl-1 = <&scr0_pins_c>;
		scr1:smartcard@0x05005400{
			#size-cells = <0>;
			device_type = "scr1";
			reg = <0x0 0x05005400 0x0 0x400>;
			interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&clk_scr1>, <&clk_apb2>;
			pinctrl-0 = <&scr1_pins_a &scr1_pins_b>;
			pinctrl-1 = <&scr1_pins_c>;
		pmu0: pmu@0{
			interrupts = <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>;
			status = "okay";
			powerkey0: powerkey@0{
				status = "okay";
			regulator0: regulator@0{
				status = "okay";
			axp_gpio0: axp_gpio@0{
				gpio-controller;
				#size-cells = <0>;
				#gpio-cells = <6>;
				status = "okay";
				device_type = "axp_pio";
			charger0: charger@0{
		nmi:nmi@0x01f00c00{
			#size-cells = <0>;
			compatible = "allwinner,sunxi-nmi";
			reg = <0x0 0x01f00c00 0x0 0x50>;
			nmi_irq_ctrl = <0x0c>;
			nmi_irq_en = <0x40>;
			nmi_irq_status = <0x10>;
			nmi_irq_mask = <0x50>;
			status = "okay";
		nand0:nand0@04011000 {
			compatible = "allwinner,sun50iw6-nand";
			device_type = "nand0";
			reg = <0x0 0x04011000 0x0 0x1000>;/* nand0 */
			interrupts = <GIC_SPI 34 0x04>;
			clocks = <&clk_pll_periph0x2>,<&clk_nand0>,<&clk_nand1>;
			pinctrl-0 = <&nand0_pins_a &nand0_pins_b>;
			pinctrl-1 = <&nand0_pins_c>;
			nand0_regulator1 = "vcc-nand";
			nand0_regulator2 = "none";
			nand0_cache_level = <0x55aaaa55>;
			nand0_flush_cache_num = <0x55aaaa55>;
			nand0_capacity_level = <0x55aaaa55>;
			nand0_id_number_ctl = <0x55aaaa55>;
			nand0_print_level = <0x55aaaa55>;
			nand0_p0 = <0x55aaaa55>;
			nand0_p1 = <0x55aaaa55>;
			nand0_p2 = <0x55aaaa55>;
			nand0_p3 = <0x55aaaa55>;
			status = "okay";
		ts0:ts0@05060000 {
			compatible = "allwinner,sun50i-tsc";
			device_type = "ts0";
			reg = <0x0 0x05060000 0x0 0x1000>;
			interrupts = <GIC_SPI 14 4>;
			clocks = <&clk_pll_periph0>,<&clk_ts>;
			clock-frequency = <120000000>;
			pinctrl-names = "ts0-default","ts1-default",
					"ts2-default","ts3-default",
					"ts0-sleep","ts1-sleep",
					"ts2-sleep","ts3-sleep";
			pinctrl-0 = <&ts0_pins_a>;
			pinctrl-1 = <&ts1_pins_a>;
			pinctrl-2 = <&ts2_pins_a>;
			pinctrl-3 = <&ts3_pins_a>;
			pinctrl-4 = <&ts0_pins_b>;
			pinctrl-5 = <&ts1_pins_b>;
			pinctrl-6 = <&ts2_pins_b>;
			pinctrl-7 = <&ts3_pins_b>;
			ts0config = <0x1>;
			ts1config = <0x0>;
			ts2config = <0x0>;
			ts3config = <0x0>;
			status = "okay";
		sunxi_thermal_sensor:thermal_sensor{
			compatible = "allwinner,thermal_sensor";
			reg = <0x0 0x05070400 0x0 0x400>;
			interrupts = <GIC_SPI 15 IRQ_TYPE_NONE>;
			clocks = <&clk_hosc>,<&clk_ths>;
			sensor_num = <2>;
			combine_num = <2>;
			alarm_low_temp = <105>;
			alarm_high_temp = <110>;
			alarm_temp_hysteresis = <15>;
			shut_temp= <115>;
			status = "okay";
			ths_combine0:ths_combine0{
				compatible = "allwinner,ths_combine0";
				#thermal-sensor-cells = <1>;
				combine_sensor_num = <1>;
				combine_sensor_type = "cpu";
				combine_sensor_temp_type = "max";
				combine_sensor_id = <0>;
			ths_combine1:ths_combine1{
				compatible = "allwinner,ths_combine1";
				combine_sensor_type = "gpu";
				combine_sensor_id = <1>;
		cpu_budget_cooling:cpu_budget_cool{
			device_type = "cpu_budget_cool";
			compatible = "allwinner,budget_cooling";
			#cooling-cells = <2>;
			status = "okay";
			state_cnt = <7>;
			cluster_num = <1>;
			state0 = <1800000 4>;
			state1 = <1488000 4>;
			state2 = <1320000 3>;
			state3 = <1080000 2>;
			state4 = <888000 1>;
			state5 = <720000 1>;
			state6 = <480000 1>;
		gpu_cooling:gpu_cooling{
			compatible = "allwinner,gpu_cooling";
			reg = <0x0 0x0 0x0 0x0>;
			status = "okay";
			state_cnt = <4>;
			state0 = <0>;
			state1 = <1>;
			state2 = <2>;
			state3 = <3>;
		thermal-zones{
			cpu_thermal_zone{
				polling-delay-passive = <1000>;
				polling-delay = <1000>;
				thermal-sensors = <&ths_combine0 0>;
				trips{
					cpu_trip0:t0{
						temperature = <60>;
						type = "passive";
						hysteresis = <0>;
					cpu_trip1:t1{
						temperature = <90>;
						type = "passive";
						hysteresis = <0>;
					cpu_trip2:t2{
						temperature = <95>;
						type = "passive";
						hysteresis = <0>;
					cpu_trip3:t3{
						temperature = <100>;
						type = "passive";
						hysteresis = <0>;
					cpu_trip4:t4{
						temperature = <105>;
						type = "passive";
						hysteresis = <0>;
					cpu_trip5:t5{
						temperature = <110>;
						type = "passive";
						hysteresis = <0>;
					crt_trip0:t6{
						temperature = <115>;
						type = "critical";
						hysteresis = <0>;
				cooling-maps{
					bind0{
						contribution = <0>;
						trip = <&cpu_trip0>;
						cooling-device = <&cpu_budget_cooling 1 1>;
					bind1{
						contribution = <0>;
						trip = <&cpu_trip1>;
						cooling-device = <&cpu_budget_cooling 2 2>;
					bind2{
						contribution = <0>;
						trip = <&cpu_trip2>;
						cooling-device = <&cpu_budget_cooling 3 3>;
					bind3{
						contribution = <0>;
						trip = <&cpu_trip3>;
						cooling-device =
						<&cpu_budget_cooling 4 4>;
					bind4{
						contribution = <0>;
						trip = <&cpu_trip4>;
						cooling-device =
						<&cpu_budget_cooling 5 5>;
					bind5{
						contribution = <0>;
						trip = <&cpu_trip5>;
						cooling-device = <&cpu_budget_cooling 6 6>;
			gpu_thermal_zone{
				polling-delay = <2000>;
				thermal-sensors = <&ths_combine1 1>;
				trips{
					gpu_trip0:t0{
						temperature = <95>;
						type = "passive";
						hysteresis = <0>;
					gpu_trip1:t1{
						type = "passive";
						hysteresis = <0>;
					gpu_trip2:t2{
						type = "passive";
						hysteresis = <0>;
					crt_trip1:t3{
						type = "critical";
						hysteresis = <0>;
				cooling-maps{
					bind0{
						contribution = <0>;
						trip = <&gpu_trip0>;
						cooling-device = <&gpu_cooling 1 1>;
					bind1{
						contribution = <0>;
						trip = <&gpu_trip1>;
						cooling-device = <&gpu_cooling 2 2>;
					bind2{
						contribution = <0>;
						trip = <&gpu_trip2>;
						cooling-device = <&gpu_cooling 3 3>;
		keyboard0:keyboard{
			compatible = "allwinner,keyboard_1200mv";
			reg = <0x0 0x05070800 0x0 0x400>;
			interrupts = <GIC_SPI 16 IRQ_TYPE_NONE>;
			status = "okay";
			key_cnt = <5>;
			key0 = <115 115>;
			key1 = <235 114>;
			key2 = <330 139>;
			key3 = <420 28>;
			key4 = <520 102>;
		gmac0: eth@05020000 {
			compatible = "allwinner,sunxi-gmac";
			reg = <0x0 0x05020000 0x0 0x10000>,
			      <0x0 0x03000030 0x0 0x4>;
			interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>;
			interrupt-names = "gmacirq";
			clocks = <&clk_gmac>;
			clock-names = "gmac";
			pinctrl-0 = <&gmac_pins_a>;
			pinctrl-1 = <&gmac_pins_b>;
			phy-mode;
			tx-delay = <7>;
			rx-delay = <31>;
			phy-rst;
			gmac-power0;
			gmac-power1;
			gmac-power2;
			status = "disable";
	gpu: gpu@0x01800000 {
		device_type = "gpu";
		compatible = "arm,mali-t720", "arm,mali-midgard";
		reg = <0x0 0x01800000 0x0 0x4000>;
		interrupts = <GIC_SPI 83 4>, <GIC_SPI 84 4>, <GIC_SPI 85 4>;
		interrupt-names = "GPU", "JOB", "MMU";
		clocks = <&clk_pll_gpu>, <&clk_gpu>;
		clock-names = "clk_parent", "clk_mali";
		operating-points = <
			/* KHz   uV */
			756000 1040000
			624000 950000
			576000 930000
			540000 910000
			504000 890000
			456000 870000
			432000 860000
			420000 850000
			408000 840000
			384000 830000
			360000 820000
			336000 810000
			312000 810000
			264000 810000
			216000 810000
sun50iw6p1-clk.dtsi
clocks {
	compatible = "allwinner,clk-init";
	device_type = "clocks";
	#size-cells = <2>;
	ranges;
	reg = <0x0 0x03001000 0x0 0x1000>,	/*cpux space*/
	      <0x0 0x07010000 0x0 0x400>,	/*cpus space*/
	      <0x0 0x07000000 0x0 0x4>;
/* register fixed rate clock*/
		clk_losc: losc {
			#clock-cells = <0>;
			compatible = "allwinner,fixed-clock";
			clock-frequency = <32768>;
			clock-output-names = "losc";
		clk_iosc: iosc {
			#clock-cells = <0>;
			clock-frequency = <16000000>;
			clock-output-names = "iosc";
		clk_hosc: hosc {
			#clock-cells = <0>;
			clock-output-names = "hosc";
		clk_osc48m: osc48m {
			#clock-cells = <0>;
			clock-frequency = <48000000>;
			clock-output-names = "osc48m";
/* register allwinner,pll-clock */
		clk_pll_cpu: pll_cpu {
			#clock-cells = <0>;
			compatible = "allwinner,pll-clock";
			lock-mode = "new";
			clock-output-names = "pll_cpu";
		clk_pll_ddr0: pll_ddr0 {
			#clock-cells = <0>;
			lock-mode = "new";
			clock-output-names = "pll_ddr0";
		clk_pll_periph0: pll_periph0 {
			#clock-cells = <0>;
			assigned-clock-rates = <600000000>;
			lock-mode = "new";
			clock-output-names = "pll_periph0";
		clk_pll_periph1: pll_periph1 {
			#clock-cells = <0>;
			lock-mode = "new";
			clock-output-names = "pll_periph1";
		clk_pll_gpu: pll_gpu {
			#clock-cells = <0>;
			lock-mode = "new";
			clock-output-names = "pll_gpu";
		clk_pll_video0: pll_video0 {
			#clock-cells = <0>;
			lock-mode = "new";
			clock-output-names = "pll_video0";
		clk_pll_video1: pll_video1 {
			#clock-cells = <0>;
			lock-mode = "new";
			assigned-clock-rates = <594000000>;
			clock-output-names = "pll_video1";
		clk_pll_ve: pll_ve {
			#clock-cells = <0>;
			device_type = "clk_pll_ve";
			lock-mode = "new";
			/*assigned-clock-rates = <??>*/
			clock-output-names = "pll_ve";
		clk_pll_de: pll_de {
			#clock-cells = <0>;
			assigned-clock-rates = <696000000>;
			lock-mode = "new";
			clock-output-names = "pll_de";
		clk_pll_hsic: pll_hsic {
			#clock-cells = <0>;
			lock-mode = "new";
			clock-output-names = "pll_hsic";
		clk_pll_audio: pll_audio {
			#clock-cells = <0>;
			lock-mode = "new";
			clock-output-names = "pll_audio";
/* register fixed factor clock*/
		clk_pll_periph0x2: pll_periph0x2 {
			#clock-cells = <0>;
			compatible = "allwinner,fixed-factor-clock";
			clocks = <&clk_pll_periph0>;
			clock-mult = <2>;
			clock-div = <1>;
			clock-output-names = "pll_periph0x2";
		clk_pll_periph0x4: pll_periph0x4 {
			#clock-cells = <0>;
			clock-mult = <4>;
			clock-div = <1>;
			clock-output-names = "pll_periph0x4";
		clk_periph32k: periph32k {
			#clock-cells = <0>;
			clock-mult = <2>;
			clock-div = <36621>;
			clock-output-names = "periph32k";
		clk_pll_periph1x2: pll_periph1x2 {
			#clock-cells = <0>;
			clocks = <&clk_pll_periph1>;
			clock-mult = <2>;
			clock-div = <1>;
			clock-output-names = "pll_periph1x2";
		clk_pll_audiox4: pll_audiox4 {
			#clock-cells = <0>;
			clocks = <&clk_pll_audio>;
			clock-mult = <4>;
			clock-div = <1>;
			clock-output-names = "pll_audiox4";
		clk_pll_audiox2: pll_audiox2 {
			#clock-cells = <0>;
			clock-mult = <2>;
			clock-div = <1>;
			clock-output-names = "pll_audiox2";
		clk_pll_video0x4: pll_video0x4 {
			#clock-cells = <0>;
			clocks = <&clk_pll_video0>;
			clock-mult = <4>;
			clock-div = <1>;
			clock-output-names = "pll_video0x4";
		clk_pll_video1x4: pll_video1x4 {
			#clock-cells = <0>;
			clocks = <&clk_pll_video1>;
			clock-mult = <4>;
			clock-div = <1>;
			clock-output-names = "pll_video1x4";
		clk_hoscd2: hoscd2 {
			#clock-cells = <0>;
			clocks = <&clk_hosc>;
			clock-mult = <1>;
			clock-div = <2>;
			clock-output-names = "hoscd2";
		clk_osc48md4: osc48md4 {
			#clock-cells = <0>;
			clocks = <&clk_osc48m>;
			clock-mult = <1>;
			clock-div = <4>;
			clock-output-names = "osc48md4";
		clk_pll_periph0d6: pll_periph0d6 {
			#clock-cells = <0>;
			clock-mult = <1>;
			clock-div = <6>;
			clock-output-names = "pll_periph0d6";
/* register allwinner,periph-clock */
		clk_cpu: cpu {
			#clock-cells = <0>;
			compatible = "allwinner,periph-clock";
			clock-output-names = "cpu";
		clk_axi: axi {
			#clock-cells = <0>;
			clock-output-names = "axi";
		clk_cpuapb: cpuapb {
			#clock-cells = <0>;
			clock-output-names = "cpuapb";
		clk_psi: psi {
			#clock-cells = <0>;
			clock-output-names = "psi";
		clk_ahb1: ahb1 {
			#clock-cells = <0>;
			clock-output-names = "ahb1";
		clk_ahb2: ahb2 {
			#clock-cells = <0>;
			clock-output-names = "ahb2";
		clk_ahb3: ahb3 {
			#clock-cells = <0>;
			clock-output-names = "ahb3";
		clk_apb1: apb1 {
			#clock-cells = <0>;
			clock-output-names = "apb1";
		clk_apb2: apb2 {
			#clock-cells = <0>;
			clock-output-names = "apb2";
		clk_mbus: mbus {
			#clock-cells = <0>;
			clock-output-names = "mbus";
		clk_de: de {
			#clock-cells = <0>;
			assigned-clock-parents = <&clk_pll_de>;
			assigned-clocks = <&clk_de>;
			clock-output-names = "de";
		clk_di: di {
			#clock-cells = <0>;
			clock-output-names = "di";
		clk_gpu: gpu {
			#clock-cells = <0>;
			clock-output-names = "gpu";
		clk_ce: ce {
			#clock-cells = <0>;
			clock-output-names = "ce";
		clk_ve: ve {
			#clock-cells = <0>;
			clock-output-names = "ve";
		clk_emce: emce {
			#clock-cells = <0>;
			clock-output-names = "emce";
		clk_vp9: vp9 {
			#clock-cells = <0>;
			clock-output-names = "vp9";
		clk_dma: dma {
			#clock-cells = <0>;
			clock-output-names = "dma";
		clk_msgbox: msgbox {
			#clock-cells = <0>;
			clock-output-names = "msgbox";
		clk_hwspinlock_rst: hwspinlock_rst {
			#clock-cells = <0>;
			clock-output-names = "hwspinlock_rst";
		clk_hwspinlock_bus: hwspinlock_bus {
			#clock-cells = <0>;
			clock-output-names = "hwspinlock_bus";
		clk_hstimer: hstimer {
			#clock-cells = <0>;
			clock-output-names = "hstimer";
		clk_avs: avs {
			#clock-cells = <0>;
			clock-output-names = "avs";
		clk_dbgsys: dbgsys {
			#clock-cells = <0>;
			clock-output-names = "dbgsys";
		clk_pwm: pwm {
			#clock-cells = <0>;
			clock-output-names = "pwm";
		clk_iommu: iommu {
			#clock-cells = <0>;
			clock-output-names = "iommu";
		clk_sdram: sdram {
			#clock-cells = <0>;
			clock-output-names = "sdram";
		clk_nand0: nand0 {
			#clock-cells = <0>;
			clock-output-names = "nand0";
		clk_nand1: nand1 {
			#clock-cells = <0>;
			clock-output-names = "nand1";
		clk_sdmmc0_mod: sdmmc0_mod {
			#clock-cells = <0>;
			clock-output-names = "sdmmc0_mod";
		clk_sdmmc0_bus: sdmmc0_bus {
			#clock-cells = <0>;
			clock-output-names = "sdmmc0_bus";
		clk_sdmmc0_rst: sdmmc0_rst {
			#clock-cells = <0>;
			clock-output-names = "sdmmc0_rst";
		clk_sdmmc1_mod: sdmmc1_mod {
			#clock-cells = <0>;
			clock-output-names = "sdmmc1_mod";
		clk_sdmmc1_bus: sdmmc1_bus {
			#clock-cells = <0>;
			clock-output-names = "sdmmc1_bus";
		clk_sdmmc1_rst: sdmmc1_rst {
			#clock-cells = <0>;
			clock-output-names = "sdmmc1_rst";
		clk_sdmmc2_mod: sdmmc2_mod {
			#clock-cells = <0>;
			clock-output-names = "sdmmc2_mod";
		clk_sdmmc2_bus: sdmmc2_bus {
			#clock-cells = <0>;
			clock-output-names = "sdmmc2_bus";
		clk_sdmmc2_rst: sdmmc2_rst {
			#clock-cells = <0>;
			clock-output-names = "sdmmc2_rst";
		clk_uart0: uart0 {
			#clock-cells = <0>;
			clock-output-names = "uart0";
		clk_uart1: uart1 {
			#clock-cells = <0>;
			clock-output-names = "uart1";
		clk_uart2: uart2 {
			#clock-cells = <0>;
			clock-output-names = "uart2";
		clk_uart3: uart3 {
			#clock-cells = <0>;
			clock-output-names = "uart3";
		clk_twi0: twi0 {
			#clock-cells = <0>;
			clock-output-names = "twi0";
		clk_twi1: twi1 {
			#clock-cells = <0>;
			clock-output-names = "twi1";
		clk_twi2: twi2 {
			#clock-cells = <0>;
			clock-output-names = "twi2";
		clk_twi3: twi3 {
			#clock-cells = <0>;
			clock-output-names = "twi3";
		clk_scr0: scr0 {
			#clock-cells = <0>;
			clock-output-names = "scr0";
		clk_scr1: scr1 {
			#clock-cells = <0>;
			clock-output-names = "scr1";
		clk_spi0: spi0 {
			#clock-cells = <0>;
			clock-output-names = "spi0";
		clk_spi1: spi1 {
			#clock-cells = <0>;
			clock-output-names = "spi1";
		clk_gmac: gmac {
			#clock-cells = <0>;
			clock-output-names = "gmac";
		clk_sata: sata {
			#clock-cells = <0>;
			clock-output-names = "sata";
		clk_sata_24m: sata_24m {
			#clock-cells = <0>;
			clock-output-names = "sata_24m";
		clk_ts: ts {
			#clock-cells = <0>;
			clock-output-names = "ts";
		clk_irtx: irtx {
			#clock-cells = <0>;
			clock-output-names = "irtx";
		clk_ths: ths {
			#clock-cells = <0>;
			clock-output-names = "ths";
		clk_i2s0: i2s0 {
			#clock-cells = <0>;
			clock-output-names = "i2s0";
		clk_i2s1: i2s1 {
			#clock-cells = <0>;
			clock-output-names = "i2s1";
		clk_i2s2: i2s2 {
			#clock-cells = <0>;
			clock-output-names = "i2s2";
		clk_i2s3: i2s3 {
			#clock-cells = <0>;
			clock-output-names = "i2s3";
		clk_spdif: spdif {
			#clock-cells = <0>;
			clock-output-names = "spdif";
		clk_dmic: dmic {
			#clock-cells = <0>;
			clock-output-names = "dmic";
		clk_ahub: ahub {
			#clock-cells = <0>;
			clock-output-names = "ahub";
		clk_usbphy0: usbphy0 {
			#clock-cells = <0>;
			clock-output-names = "usbphy0";
		clk_usbphy1: usbphy1 {
			#clock-cells = <0>;
			clock-output-names = "usbphy1";
		clk_usbphy3: usbphy3 {
			#clock-cells = <0>;
			clock-output-names = "usbphy3";
		clk_usbohci0: usbohci0 {
			#clock-cells = <0>;
			clock-output-names = "usbohci0";
		clk_usbohci0_12m: usbohci0_12m {
			#clock-cells = <0>;
			clock-output-names = "usbohci0_12m";
		clk_usbohci3: usbohci3 {
			#clock-cells = <0>;
			clock-output-names = "usbohci3";
		clk_usbohci3_12m: usbohci3_12m {
			#clock-cells = <0>;
			clock-output-names = "usbohci3_12m";
		clk_usbehci0: usbehci0 {
			#clock-cells = <0>;
			clock-output-names = "usbehci0";
		clk_usbehci3: usbehci3 {
			#clock-cells = <0>;
			clock-output-names = "usbehci3";
		clk_usb3_0_host: usb3_0_host {
			#clock-cells = <0>;
			clock-output-names = "usb3_0_host";
		clk_usbotg: usbotg {
			#clock-cells = <0>;
			clock-output-names = "usbotg";
		clk_usbhsic: usbhsic {
			#clock-cells = <0>;
			clock-output-names = "usbhsic";
		clk_pcieref: pcieref {
			#clock-cells = <0>;
			clock-output-names = "pcieref";
		clk_pciemaxi: pciemaxi {
			#clock-cells = <0>;
			assigned-clocks = <&clk_pciemaxi>;
			assigned-clock-rates = <200000000>;
			clock-output-names = "pciemaxi";
		clk_pcieaux: pcieaux {
			#clock-cells = <0>;
			assigned-clock-rates = <1000000>;
			assigned-clocks = <&clk_pcieaux>;
			clock-output-names = "pcieaux";
		clk_pcie_bus: pcie_bus {
			#clock-cells = <0>;
			clock-output-names = "pcie_bus";
		clk_pcie_power: pcie_power {
			#clock-cells = <0>;
			clock-output-names = "pcie_power";
		clk_pcie_rst: pcie_rst {
			#clock-cells = <0>;
			clock-output-names = "pcie_rst";
		clk_hdmi: hdmi {
			#clock-cells = <0>;
			assigned-clock-parents = <&clk_pll_video1>;
			assigned-clocks = <&clk_hdmi>;
			clock-output-names = "hdmi";
		clk_hdmi_slow: hdmi_slow {
			#clock-cells = <0>;
			assigned-clocks = <&clk_hdmi_slow>;
			clock-output-names = "hdmi_slow";
		clk_hdmi_cec: hdmi_cec {
			#clock-cells = <0>;
			assigned-clocks = <&clk_hdmi_cec>;
			clock-output-names = "hdmi_cec";
		clk_display_top: display_top {
			#clock-cells = <0>;
			clock-output-names = "display_top";
		clk_tcon_lcd: tcon_lcd {
			#clock-cells = <0>;
			clock-output-names = "tcon_lcd";
		clk_tcon_tv: tcon_tv {
			#clock-cells = <0>;
			assigned-clocks = <&clk_tcon_tv>;
			clock-output-names = "tcon_tv";
		clk_csi_misc: csi_misc {
			#clock-cells = <0>;
			clock-output-names = "csi_misc";
		clk_csi_top: csi_top {
			#clock-cells = <0>;
			clock-output-names = "csi_top";
		clk_csi_master0: csi_master0 {
			#clock-cells = <0>;
			clock-output-names = "csi_master0";
		clk_hdmi_hdcp: hdmi_hdcp {
			#clock-cells = <0>;
			assigned-clock-parents = <&clk_pll_periph1>;
			assigned-clocks = <&clk_hdmi_hdcp>;
			clock-output-names = "hdmi_hdcp";
		clk_pio: pio {
			#clock-cells = <0>;
			clock-output-names = "pio";
/*cpus space clocks from PRCM-SPEC*/
		clk_cpurcir: cpurcir {
			#clock-cells = <0>;
			compatible = "allwinner,periph-cpus-clock";
			clock-output-names = "cpurcir";
		clk_losc_out: losc_out {
			#clock-cells = <0>;
			clock-output-names = "losc_out";
		/* clk below are read only , just to keep a clock tree */
		clk_cpurcpus_pll: cpurcpus_pll {
			#clock-cells = <0>;
			clock-output-names = "cpurcpus_pll";
		clk_cpurcpus: cpurcpus {
			#clock-cells = <0>;
			clock-output-names = "cpurcpus";
		clk_cpurahbs: cpurahbs {
			#clock-cells = <0>;
			clock-output-names = "cpurahbs";
		clk_cpurapbs1: cpurapbs1 {
			#clock-cells = <0>;
			clock-output-names = "cpurapbs1";
		clk_cpurapbs2_pll: cpurapbs2_pll {
			#clock-cells = <0>;
			clock-output-names = "cpurapbs2_pll";
		clk_cpurapbs2: cpurapbs2 {
			#clock-cells = <0>;
			clock-output-names = "cpurapbs2";
		clk_cpurpio: cpurpio {
			#clock-cells = <0>;
			clock-output-names = "cpurpio";
		clk_spwm: spwm {
			#clock-cells = <0>;
			clock-output-names = "spwm";
		clk_dcxo_out: dcxo_out {
			#clock-cells = <0>;
			clock-output-names = "dcxo_out";
 * Allwinner sun50iw6 pin config info.
	soc@03000000{
		r_pio: pinctrl@07022000 {
			compatible = "allwinner,sun50iw6p1-r-pinctrl";
			reg = <0x0 0x07022000 0x0 0x400>;
			interrupts = <GIC_SPI 105 4>,
			<GIC_SPI 111 4>;
			clocks = <&clk_cpurpio>;
			device_type = "r_pio";
			gpio-controller;
			#interrupt-cells = <2>;
			#size-cells = <0>;
			#gpio-cells = <6>;
			s_uart0_pins_a: s_uart0@0 {
				allwinner,pins = "PL2", "PL3";
				allwinner,function = "s_uart0";
				allwinner,muxsel = <2>;
				allwinner,drive = <1>;
				allwinner,pull = <1>;
			s_twi0_pins_a: s_twi0@0 {
				allwinner,pins = "PL0", "PL1";
				allwinner,function = "s_twi0";
				allwinner,muxsel = <3>;
				allwinner,drive = <0>;
			s_jtag0_pins_a: s_jtag0@0 {
				allwinner,pins = "PL4", "PL5", "PL6", "PL7";
				allwinner,function = "s_jtag0";
				allwinner,drive = <2>;
			s_cir0_pins_a: s_cir0@0 {
				allwinner,pins = "PL9";
				allwinner,function = "s_cir0";
		pio: pinctrl@0300b000 {
			compatible = "allwinner,sun50iw6p1-pinctrl";
			reg = <0x0 0x0300b000 0x0 0x400>;
			interrupts = <GIC_SPI 51 4>,
				     <GIC_SPI 53 4>,
				     <GIC_SPI 54 4>,
				     <GIC_SPI 59 4>;
			device_type = "pio";
			clocks = <&clk_pio>;
			gpio-controller;
			#size-cells = <0>;
			#gpio-cells = <6>;
			vdevice_pins_a: vdevice@0 {
				allwinner,pins = "PA1", "PA2";
				allwinner,function = "vdevice";
				allwinner,muxsel = <5>;
			uart0_pins_a: uart0@0 {
				allwinner,pins = "PF2", "PF4";
				allwinner,pname = "uart0_tx", "uart0_rx";
				allwinner,function = "uart0";
			uart0_pins_b: uart0@1 {
				allwinner,function = "io_disabled";
				allwinner,muxsel = <7>;
				allwinner,pull = <0>;
			uart1_pins_a: uart1@0 {
				allwinner,pins = "PG6", "PG7", "PG8", "PG9";
				allwinner,pname = "uart1_tx", "uart1_rx",
						  "uart1_rts", "uart1_cts";
				allwinner,function = "uart1";
			uart1_pins_b: uart1@1 {
			uart2_pins_a: uart2@0 {
				allwinner,pins = "PD19", "PD20", "PD21", "PD22";
				allwinner,pname = "uart2_tx", "uart2_rx",
						  "uart2_rts", "uart2_cts";
				allwinner,function = "uart2";
				allwinner,muxsel = <4>;
			uart2_pins_b: uart2@1 {
			uart3_pins_a: uart3@0 {
				allwinner,pins = "PE0", "PE1", "PE2", "PE3";
				allwinner,pname = "uart3_tx", "uart3_rx",
						  "uart3_rts", "uart3_cts";
				allwinner,function = "uart3";
			uart3_pins_b: uart3@1 {
			twi0_pins_a: twi0@0 {
				allwinner,pins = "PD25", "PD26";
				allwinner,pname = "twi0_scl", "twi0_sda";
				allwinner,function = "twi0";
			twi0_pins_b: twi0@1 {
			twi1_pins_a: twi1@0 {
				allwinner,pins = "PH5", "PH6";
				allwinner,pname = "twi1_scl", "twi1_sda";
				allwinner,function = "twi1";
			twi1_pins_b: twi1@1 {
			twi2_pins_a: twi2@0 {
				allwinner,pins = "PD23", "PD24";
				allwinner,pname = "twi2_scl", "twi2_sda";
				allwinner,function = "twi2";
			twi2_pins_b: twi2@1 {
			twi3_pins_a: twi3@0 {
				allwinner,pins = "PB17", "PB18";
				allwinner,pname = "twi3_scl", "twi3_sda";
				allwinner,function = "twi3";
			twi3_pins_b: twi3@1 {
			ts0_pins_a: ts0@0 {
				allwinner,pins = "PD0", "PD1", "PD2", "PD3",
						 "PD4", "PD5", "PD6", "PD7",
						 "PD8", "PD9", "PD10", "PD11";
				allwinner,pname = "ts0_clk", "ts0_err",
						  "ts0_sync", "ts0_dvld",
						  "ts0_d0", "ts0_d1",
						  "ts0_d2", "ts0_d3",
						  "ts0_d4", "ts0_d5",
						  "ts0_d6", "ts0_d7";
				allwinner,function = "ts0";
			ts0_pins_b: ts0_sleep@0 {
						  "ts0_d0", "ts0_d1",
						  "ts0_d2", "ts0_d3",
						  "ts0_d4", "ts0_d5",
						  "ts0_d6", "ts0_d7";
			ts1_pins_a: ts1@0 {
				allwinner,pins = "PD12", "PD13", "PD14",
						 "PD15", "PD16";
				allwinner,pname = "ts1_clk", "ts1_err",
						  "ts1_sync", "ts1_dvld",
						  "ts1_d0";
				allwinner,function = "ts1";
			ts1_pins_b: ts1_sleep@0 {
						 "PD15", "PD16";
						  "ts1_d0";
			ts2_pins_a: ts2@0 {
				allwinner,pins = "PD17", "PD18", "PD19", "PD20",
						 "PD21";
				allwinner,pname = "ts2_clk", "ts2_err",
						  "ts2_sync", "ts2_dvld",
						  "ts2_d0";
				allwinner,function = "ts2";
			ts2_pins_b: ts2_sleep@0 {
						 "PD21";
						  "ts2_d0";
			ts3_pins_a: ts3@0 {
				allwinner,pins = "PD22", "PD23", "PD24",
						 "PD25", "PD26";
				allwinner,pname = "ts3_clk", "ts3_err",
						  "ts3_sync", "ts3_dvld",
						  "ts3_d0";
				allwinner,function = "ts3";
			ts3_pins_b: ts3_sleep@0 {
						 "PD25", "PD26";
						  "ts3_d0";
			spi0_pins_a: spi0@0 {
				allwinner,pins = "PC0", "PC2", "PC3";
				allwinner,pname = "spi0_sclk", "spi0_mosi",
						  "spi0_miso";
				allwinner,function = "spi0";
			spi0_pins_b: spi0@1 {
				allwinner,pins = "PC5";
				allwinner,pname = "spi0_cs0";
				allwinner,pull = <1>;	// only CS should be pulled up
			spi0_pins_c: spi0@2 {
				allwinner,pins = "PC0", "PC2", "PC3", "PC5";
			spi1_pins_a: spi1@0 {
				allwinner,pins = "PH4", "PH5", "PH6";
				allwinner,pname = "spi1_sclk", "spi1_mosi",
						  "spi1_miso";
				allwinner,function = "spi1";
			spi1_pins_b: spi1@1 {
				allwinner,pins = "PH3";
				allwinner,pname = "spi1_cs0";
			spi1_pins_c: spi1@2 {
				allwinner,pins = "PH3", "PH4", "PH5", "PH6";
			sdc0_pins_a: sdc0@0 {
				allwinner,pins = "PF0", "PF1", "PF2",
						 "PF3", "PF4", "PF5";
				allwinner,function = "sdc0";
			sdc0_pins_b: sdc0@1 {
			sdc1_pins_a: sdc1@0 {
				allwinner,pins = "PG0", "PG1", "PG2",
						 "PG3", "PG4", "PG5";
				allwinner,function = "sdc1";
				allwinner,drive = <3>;
			sdc1_pins_b: sdc1@1 {
			sdc2_pins_a: sdc2@0 {
				allwinner,pins = "PC1", "PC4", "PC5", "PC6",
						 "PC7", "PC8", "PC9", "PC10",
						 "PC11", "PC12", "PC13", "PC14";
				allwinner,function = "sdc2";
			sdc2_pins_b: sdc2@1 {
			daudio0_pins_a: daudio0@0 {
				allwinner,pins = "PH0", "PH1", "PH2", "PH3", "PH4";
				allwinner,function = "pcm0";
			daudio0_pins_b: daudio0_sleep@0 {
			daudio2_pins_a: daudio2@0 {
				allwinner,pins = "PG10", "PG11", "PG12", "PG13", "PG14";
				allwinner,function = "pcm2";
			daudio2_pins_b: daudio2_sleep@0 {
			daudio3_pins_a: daudio3@0 {
					allwinner,pins = "PB12", "PB13", "PB14", "PB15", "PB16";
					allwinner,function = "pcm3";
					allwinner,driver = <1>;
			daudio3_pins_b: daudio3_sleep@0 {
			spdif_pins_a: spdif@0 {
				allwinner,pins = "PH5", "PH6", "PH7";
				allwinner,function = "spdif0";
			spdif_pins_b: spdif_sleep@0 {
			dmic_pins_a: dmic@0 {
				allwinner,pins = "PD14", "PD15", "PD16", "PD17", "PD18";
				allwinner,function = "dmic";
				dmic_pins_b: dmic_sleep@0 {
			ahub_daudio0_pins_a: ahub_daudio0@0 {
					allwinner,function = "h_pcm0";
			ahub_daudio0_pins_b: ahub_daudio0_sleep@0 {
			ahub_daudio2_pins_a: ahub_daudio2@0 {
				allwinner,function = "h_pcm2";
			ahub_daudio2_pins_b: ahub_daudio2_sleep@0 {
			ahub_daudio3_pins_a: ahub_daudio3@0 {
					allwinner,function = "h_pcm3";
			ahub_daudio3_pins_b: ahub_daudio3_sleep@0 {
			csi0_pins_a: csi0@0 {
				allwinner,pins = "PD0", "PD2", "PD3", "PD4", "PD5",
						 "PD6", "PD7", "PD8", "PD9", "PD10", "PD11";
				allwinner,pname = "csi0_pck", "csi0_hsync", "csi0_vsync",
						  "csi0_d0", "csi0_d1", "csi0_d2", "csi0_d3",
						  "csi0_d4", "csi0_d5", "csi0_d6", "csi0_d7";
				allwinner,function = "csi0";
				allwinner,data = <0>;
			csi0_pins_b: csi0@1 {
			csi_mclk0_pins_a: csi_mclk0@0 {
				allwinner,pins = "PD1";
				allwinner,pname = "csi_mclk0";
				allwinner,function = "csi_mclk0";
			csi_mclk0_pins_b: csi_mclk0@1 {
			csi_cci0_pins_a: csi_cci0@0 {
				allwinner,pins = "PD12","PD13";
				allwinner,pname = "csi_cci0_sck","csi_cci0_sda";
				allwinner,function = "csi_cci0";
			csi_cci0_pins_b: csi_cci0@1 {
			scr0_pins_a: scr0@0 {
				allwinner,pins = "PG13", "PG14", "PG10", "PG11", "PG12";
				allwinner,pname = "scr0_rst", "scr0_det", "scr0_vccen", "scr0_sck", "scr0_sda";
				allwinner,function = "sim0";
			scr0_pins_b: scr0@1 {
				allwinner,pins = "PG8", "PG9";
				allwinner,pname = "scr0_vppen", "scr0_vppp";
			scr0_pins_c: scr0@2 {
				allwinner,pins = "PG8", "PG9", "PG10", "PG11", "PG12", "PG13", "PG14";
			scr1_pins_a: scr1@0 {
				allwinner,pins = "PH5", "PH6", "PH2",
						 "PH3", "PH4";
				allwinner,pname = "scr1_rst", "scr1_det",
						  "scr1_vccen", "scr1_sck",
						  "scr1_sda";
				allwinner,function = "sim1";
			scr1_pins_b: scr1@1 {
				allwinner,pins = "PH0", "PH1";
				allwinner,pname = "scr1_vppen", "scr1_vppp";
			scr1_pins_c: scr1@2 {
						 "PH6";
			nand0_pins_a: nand0@0 {
				allwinner,pins = "PC0", "PC1", "PC2", "PC4",
						 "PC6", "PC7", "PC8", "PC9",
						 "PC10", "PC11", "PC12", "PC13",
						 "PC14";
				allwinner,pname= "nand0_we", "nand0_ale","nand0_cle", "nand0_nre",
						 "nand0_d0", "nand0_d1", "nand0_d2", "nand0_d3",
						 "nand0_d4", "nand0_d5", "nand0_d6", "nand0_d7",
						 "nand0_ndqs";
				allwinner,function = "nand0";
			nand0_pins_b: nand0@1 {
				allwinner,pins = "PC3", "PC5", "PC15", "PC16";
				allwinner,pname= "nand0_ce0", "nand0_rb0", "nand0_ce1", "nand0_rb1";
				allwinner,pull = <1>;// only RB&CE should be pulled up
			nand0_pins_c: nand0@2 {
				allwinner,pins = "PC0", "PC1", "PC2", "PC3",
						 "PC4", "PC5", "PC6", "PC7",
						 "PC8", "PC9", "PC10", "PC11",
						 "PC12", "PC13", "PC14", "PC15",
						 "PC16";
			hdmi_ddc_pin_a: hdmi@0 {
				allwinner,pins = "PH8","PH9";
				allwinner,function = "ddc";
			hdmi_ddc_pin_b: hdmi@1 {
			hdmi_cec_pin_a: hdmi@2 {
				allwinner,pins = "PH10";
				allwinner,function = "hcec0";
			hdmi_cec_pin_b: hdmi@3 {
			ccir_clk_pin_a: ac200@2 {
				allwinner,pins = "PB0";
				allwinner,function = "ac200";
			ccir_clk_pin_b: ac200@3 {
			gmac_pins_a: gmac@0 {
				allwinner,pins = "PA0", "PA1", "PA2", "PA3",
						"PA4", "PA5", "PA6", "PA7",
						"PA8", "PA9";
				allwinner,function = "gmac0";
			gmac_pins_b: gmac@1 {
						"PA8", "PA9";
arm-gic.h
 * This header provides constants for the ARM GIC.
#ifndef _DT_BINDINGS_INTERRUPT_CONTROLLER_ARM_GIC_H
#define _DT_BINDINGS_INTERRUPT_CONTROLLER_ARM_GIC_H
#include <dt-bindings/interrupt-controller/irq.h>
/* interrupt specifier cell 0 */
#define GIC_SPI 0
#define GIC_PPI 1
 * Interrupt specifier cell 2.
 * The flags in irq.h are valid, plus those below.
#define GIC_CPU_MASK_RAW(x) ((x) << 8)
#define GIC_CPU_MASK_SIMPLE(num) GIC_CPU_MASK_RAW((1 << (num)) - 1)
#endif
gpio.h
 * This header provides constants for most GPIO bindings.
 * Most GPIO bindings include a flags cell as part of the GPIO specifier.
 * In most cases, the format of the flags cell uses the standard values
 * defined in this header.
#ifndef _DT_BINDINGS_GPIO_GPIO_H
#define _DT_BINDINGS_GPIO_GPIO_H
/* Bit 0 express polarity */
#define GPIO_ACTIVE_HIGH 0
#define GPIO_ACTIVE_LOW 1
/* Bit 1 express single-endedness */
#define GPIO_PUSH_PULL 0
#define GPIO_SINGLE_ENDED 2
 * Open Drain/Collector is the combination of single-ended active low,
 * Open Source/Emitter is the combination of single-ended active high.
#define GPIO_OPEN_DRAIN (GPIO_SINGLE_ENDED | GPIO_ACTIVE_LOW)
#define GPIO_OPEN_SOURCE (GPIO_SINGLE_ENDED | GPIO_ACTIVE_HIGH)
/* sunxi gpio arg */
#define  PA  0
#define  PB  1
#define  PC  2
#define  PD  3
#define  PE  4
#define  PF  5
#define  PG  6
#define  PH  7
#define  PI  8
#define  PJ  9
#define  PK  10
#define  PL  11
#define  PM  12
#define  PN  13
#define  PO  14
#define  PP  15
#define  default 0xffffffff
#endif
irq.h
 * This header provides constants for most IRQ bindings.
 * Most IRQ bindings include a flags cell as part of the IRQ specifier.
#ifndef _DT_BINDINGS_INTERRUPT_CONTROLLER_IRQ_H
#define _DT_BINDINGS_INTERRUPT_CONTROLLER_IRQ_H
#define IRQ_TYPE_NONE		0
#define IRQ_TYPE_EDGE_RISING	1
#define IRQ_TYPE_EDGE_FALLING	2
#define IRQ_TYPE_EDGE_BOTH	(IRQ_TYPE_EDGE_FALLING | IRQ_TYPE_EDGE_RISING)
#define IRQ_TYPE_LEVEL_HIGH	4
#define IRQ_TYPE_LEVEL_LOW	8
#endif
irq.h arm-gic.h gpio.h sun50iw6p1-soc.dts sun50iw6p1-pinctrl.dtsi sun50iw6p1-clk.dtsi sun50iw6p1.dtsi
Board: Not on the list
Edited by eric971
complete description
I've just got another TV box of same model.
I am also interested to look into building a DTB file for running  balbes150's  AW-H6-TV Armbian image  on this box.
If there's any guide on how-to build this DTB image,  it is really appreciated.
Update:. I just discovered that this box could be using AW H616 SoC instead.  Suppose it's a different game then.
Edited by Willy Moto
New findings maybe
Finaly i have installed Armbian_20.10_Arm-64_bullseye_current_5.9.0_desktop.img.xz like this :
- flash the armbian image on sdcard with balena etcher
- choose the tanix-tx6 dtb
- copy the file in attached piece with this command :
                      sudo dd if=u-boot-sunxi-with-spl-h6-noname.bin of=/dev/sdb bs=1024 seek=8
- boot from the sd card
- delete all partition on the mmc with gparted
- copy the sdcard partitions to mmc
- copy u-boot-sunxiwith-spl-h6-noname.bin with dd (similar to sdcard)
- change uuid reference or label reference to boot on mmc
- reboot without sdcard
And all works fine (wifi inclued).
Bests regards
