I've tried to use the bug reporting tool but unfortunately it did not work (armbianmonitor -u did not work, and it was too big for http://paste.debian.net/), so I've posted here.
I'm trying to use a PCTV 292e plugged into the USB2 port of my Odroid N2. I have the correct firmware for this device downloaded into the /lib/firmware/ folder however I have the errors:
writing to i2c device at 0xc8 failed (error=-5)
I think it is a USB issue as it does work in the USB3 ports, but I am unsure. Logs below.
If there is any more info I need to supply please let me know. Thanks.
armbianmonitor -U
     1
     2	### Activated 1 lzo-rle zram swap devices with 1816 MB each
     3
     4	### Activated Armbian ramlog partition with zstd compression
     5
     6	### Activated lzo-rle compressed /tmp
     7
     8	Thu 04 Feb 2021 01:01:21 PM UTC | Odroid N2 | 21.02.1 | arm64 | aarch64 | 5.10.12-meson64
     9
    10	### dmesg:
    11
    12	[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    13	[    0.000000] Linux version 5.10.12-meson64 (root@beast) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #21.02.1 SMP PREEMPT Wed Feb 3 21:06:36 CET 2021
    14	[    0.000000] Machine model: Hardkernel ODROID-N2
    15	[    0.000000] efi: UEFI not found.
    16	[    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
    17	[    0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB
    18	[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
    19	[    0.000000] NUMA: No NUMA configuration found
    20	[    0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ed7fffff]
    21	[    0.000000] NUMA: NODE_DATA [mem 0xb502f100-0xb5030fff]
    22	[    0.000000] Zone ranges:
    23	[    0.000000]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
    24	[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000ed7fffff]
    25	[    0.000000]   Normal   empty
    26	[    0.000000] Movable zone start for each node
    27	[    0.000000] Early memory node ranges
    28	[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000004ffffff]
    29	[    0.000000]   node   0: [mem 0x0000000005300000-0x00000000ed7fffff]
    30	[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ed7fffff]
    31	[    0.000000] On node 0 totalpages: 972032
    32	[    0.000000]   DMA zone: 4096 pages used for memmap
    33	[    0.000000]   DMA zone: 0 pages reserved
    34	[    0.000000]   DMA zone: 261376 pages, LIFO batch:63
    35	[    0.000000]   DMA32 zone: 11104 pages used for memmap
    36	[    0.000000]   DMA32 zone: 710656 pages, LIFO batch:63
    37	[    0.000000] psci: probing for conduit method from DT.
    38	[    0.000000] psci: PSCIv1.0 detected in firmware.
    39	[    0.000000] psci: Using standard PSCI v0.2 function IDs
    40	[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
    41	[    0.000000] psci: SMC Calling Convention v1.1
    42	[    0.000000] percpu: Embedded 23 pages/cpu s56728 r8192 d29288 u94208
    43	[    0.000000] pcpu-alloc: s56728 r8192 d29288 u94208 alloc=23*4096
    44	[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
    45	[    0.000000] Detected VIPT I-cache on CPU0
    46	[    0.000000] CPU features: detected: ARM erratum 845719
    47	[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 956832
    48	[    0.000000] Policy zone: DMA32
    49	[    0.000000] Kernel command line: root=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c rootwait rootfstype=ext4 console=ttyAML0,115200n8 console=tty1 loglevel=1  no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=1080p60hz cvbsmode=576cvbs max_freq_a53=1896 max_freq_a73=1800 maxcpus=6 voutmode=hdmi  disablehpd=false  cvbscable=0 overscan=100 consoleblank=0
    50	[    0.000000] Kernel parameter elevator= does not have any effect anymore.
    51	               Please use sysfs to set IO scheduler for individual devices.
    52	[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
    53	[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    54	[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
    55	[    0.000000] software IO TLB: mapped [mem 0x0000000038ac4000-0x000000003cac4000] (64MB)
    56	[    0.000000] Memory: 2785348K/3888128K available (14144K kernel code, 1760K rwdata, 5508K rodata, 3328K init, 592K bss, 185276K reserved, 917504K cma-reserved)
    57	[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
    58	[    0.000000] rcu: Preemptible hierarchical RCU implementation.
    59	[    0.000000] rcu: 	RCU event tracing is enabled.
    60	[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
    61	[    0.000000] 	Trampoline variant of Tasks RCU enabled.
    62	[    0.000000] 	Rude variant of Tasks RCU enabled.
    63	[    0.000000] 	Tracing variant of Tasks RCU enabled.
    64	[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    65	[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
    66	[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    67	[    0.000000] GIC: Using split EOI/Deactivate mode
    68	[    0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized
    69	[    0.000000] random: get_random_bytes called from start_kernel+0x378/0x538 with crng_init=0
    70	[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
    71	[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
    72	[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
    73	[    0.000248] Console: colour dummy device 80x25
    74	[    0.000282] printk: console [tty1] enabled
    75	[    0.000372] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
    76	[    0.000385] pid_max: default: 32768 minimum: 301
    77	[    0.000468] LSM: Security Framework initializing
    78	[    0.000495] Yama: becoming mindful.
    79	[    0.000586] AppArmor: AppArmor initialized
    80	[    0.000636] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    81	[    0.000656] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    82	[    0.002644] rcu: Hierarchical SRCU implementation.
    83	[    0.005149] EFI services will not be available.
    84	[    0.005570] smp: Bringing up secondary CPUs ...
    85	[    0.006241] Detected VIPT I-cache on CPU1
    86	[    0.006303] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    87	[    0.007492] CPU features: detected: ARM erratum 858921
    88	[    0.007500] CPU features: detected: Spectre-v2
    89	[    0.007503] CPU features: detected: Spectre-v4
    90	[    0.007510] Detected VIPT I-cache on CPU2
    91	[    0.007536] arch_timer: Enabling local workaround for ARM erratum 858921
    92	[    0.007550] arch_timer: CPU2: Trapping CNTVCT access
    93	[    0.007563] CPU2: Booted secondary processor 0x0000000100 [0x410fd092]
    94	[    0.008270] Detected VIPT I-cache on CPU3
    95	[    0.008286] arch_timer: Enabling local workaround for ARM erratum 858921
    96	[    0.008294] arch_timer: CPU3: Trapping CNTVCT access
    97	[    0.008302] CPU3: Booted secondary processor 0x0000000101 [0x410fd092]
    98	[    0.008926] Detected VIPT I-cache on CPU4
    99	[    0.008943] arch_timer: Enabling local workaround for ARM erratum 858921
   100	[    0.008949] arch_timer: CPU4: Trapping CNTVCT access
   101	[    0.008957] CPU4: Booted secondary processor 0x0000000102 [0x410fd092]
   102	[    0.009572] Detected VIPT I-cache on CPU5
   103	[    0.009589] arch_timer: Enabling local workaround for ARM erratum 858921
   104	[    0.009595] arch_timer: CPU5: Trapping CNTVCT access
   105	[    0.009603] CPU5: Booted secondary processor 0x0000000103 [0x410fd092]
   106	[    0.009684] smp: Brought up 1 node, 6 CPUs
   107	[    0.009701] SMP: Total of 6 processors activated.
   108	[    0.009708] CPU features: detected: 32-bit EL0 Support
   109	[    0.009714] CPU features: detected: CRC32 instructions
   110	[    0.009720] CPU features: detected: 32-bit EL1 Support
   111	[    0.020926] CPU: All CPU(s) started at EL2
   112	[    0.020977] alternatives: patching kernel code
   113	[    0.022914] devtmpfs: initialized
   114	[    0.030538] Registered cp15_barrier emulation handler
   115	[    0.030552] Registered setend emulation handler
   116	[    0.030716] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
   117	[    0.030760] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
   118	[    0.044682] pinctrl core: initialized pinctrl subsystem
   119	[    0.045439] DMI not present or invalid.
   120	[    0.045808] NET: Registered protocol family 16
   121	[    0.047309] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
   122	[    0.047580] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
   123	[    0.047807] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
   124	[    0.047853] audit: initializing netlink subsys (disabled)
   125	[    0.047959] audit: type=2000 audit(0.044:1): state=initialized audit_enabled=0 res=1
   126	[    0.049276] thermal_sys: Registered thermal governor 'fair_share'
   127	[    0.049284] thermal_sys: Registered thermal governor 'bang_bang'
   128	[    0.049288] thermal_sys: Registered thermal governor 'step_wise'
   129	[    0.049291] thermal_sys: Registered thermal governor 'user_space'
   130	[    0.049767] cpuidle: using governor menu
   131	[    0.050104] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
   132	[    0.050224] ASID allocator initialised with 65536 entries
   133	[    0.051183] Serial: AMBA PL011 UART driver
   134	[    0.085349] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
   135	[    0.085363] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
   136	[    0.085368] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
   137	[    0.085374] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
   138	[    0.087346] cryptd: max_cpu_qlen set to 1000
   139	[    0.156247] raid6: neonx8   gen()  2780 MB/s
   140	[    0.224302] raid6: neonx8   xor()  2042 MB/s
   141	[    0.292354] raid6: neonx4   gen()  3003 MB/s
   142	[    0.360418] raid6: neonx4   xor()  2347 MB/s
   143	[    0.428488] raid6: neonx2   gen()  2582 MB/s
   144	[    0.496550] raid6: neonx2   xor()  2138 MB/s
   145	[    0.564621] raid6: neonx1   gen()  2014 MB/s
   146	[    0.632681] raid6: neonx1   xor()  1721 MB/s
   147	[    0.700749] raid6: int64x8  gen()  1373 MB/s
   148	[    0.768812] raid6: int64x8  xor()   735 MB/s
   149	[    0.836909] raid6: int64x4  gen()  1463 MB/s
   150	[    0.904957] raid6: int64x4  xor()   733 MB/s
   151	[    0.973022] raid6: int64x2  gen()  1363 MB/s
   152	[    1.041092] raid6: int64x2  xor()   619 MB/s
   153	[    1.109150] raid6: int64x1  gen()  1120 MB/s
   154	[    1.177210] raid6: int64x1  xor()   462 MB/s
   155	[    1.177213] raid6: using algorithm neonx4 gen() 3003 MB/s
   156	[    1.177217] raid6: .... xor() 2347 MB/s, rmw enabled
   157	[    1.177220] raid6: using neon recovery algorithm
   158	[    1.177685] ACPI: Interpreter disabled.
   159	[    1.178454] 5V: supplied by 12V
   160	[    1.179353] VDDAO_3V3: supplied by 12V
   161	[    1.179851] iommu: Default domain type: Translated
   162	[    1.179962] vgaarb: loaded
   163	[    1.180923] SCSI subsystem initialized
   164	[    1.181171] usbcore: registered new interface driver usbfs
   165	[    1.181210] usbcore: registered new interface driver hub
   166	[    1.181249] usbcore: registered new device driver usb
   167	[    1.181556] pps_core: LinuxPPS API ver. 1 registered
   168	[    1.181562] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
   169	[    1.181583] PTP clock support registered
   170	[    1.181791] EDAC MC: Ver: 3.0.0
   171	[    1.183125] NetLabel: Initializing
   172	[    1.183133] NetLabel:  domain hash size = 128
   173	[    1.183135] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
   174	[    1.183177] NetLabel:  unlabeled traffic allowed by default
   175	[    1.183599] clocksource: Switched to clocksource arch_sys_counter
   176	[    1.183801] VFS: Disk quotas dquot_6.6.0
   177	[    1.183846] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
   178	[    1.184192] AppArmor: AppArmor Filesystem Enabled
   179	[    1.184246] pnp: PnP ACPI: disabled
   180	[    1.190120] NET: Registered protocol family 2
   181	[    1.190584] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
   182	[    1.190688] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
   183	[    1.190944] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
   184	[    1.191132] TCP: Hash tables configured (established 32768 bind 32768)
   185	[    1.191291] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
   186	[    1.191354] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
   187	[    1.191401] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
   188	[    1.191548] NET: Registered protocol family 1
   189	[    1.191567] PCI: CLS 0 bytes, default 64
   190	[    1.191743] Trying to unpack rootfs image as initramfs...
   191	[    1.727704] Freeing initrd memory: 13548K
   192	[    1.728632] kvm [1]: IPA Size Limit: 40 bits
   193	[    1.729336] kvm [1]: vgic interrupt IRQ9
   194	[    1.729469] kvm [1]: Hyp mode initialized successfully
   195	[    1.734596] Initialise system trusted keyrings
   196	[    1.734632] Key type blacklist registered
   197	[    1.734777] workingset: timestamp_bits=44 max_order=20 bucket_order=0
   198	[    1.737976] zbud: loaded
   199	[    1.738962] squashfs: version 4.0 (2009/01/31) Phillip Lougher
   200	[    1.739428] fuse: init (API version 7.32)
   201	[    1.740208] integrity: Platform Keyring initialized
   202	[    1.767642] xor: measuring software checksum speed
   203	[    1.770481]    8regs           :  3473 MB/sec
   204	[    1.772943]    32regs          :  4022 MB/sec
   205	[    1.775599]    arm64_neon      :  3719 MB/sec
   206	[    1.775603] xor: using function: 32regs (4022 MB/sec)
   207	[    1.775610] Key type asymmetric registered
   208	[    1.775614] Asymmetric key parser 'x509' registered
   209	[    1.775655] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
   210	[    1.775763] io scheduler mq-deadline registered
   211	[    1.775767] io scheduler kyber registered
   212	[    1.775850] io scheduler bfq registered
   213	[    1.778394] gpio-447 (usb-hub-reset): hogged as output/high
   214	[    1.781385] EINJ: ACPI disabled.
   215	[    1.787583] soc soc0: Amlogic Meson G12B (S922X) Revision 29:a (40:2) Detected
   216	[    1.789059] VCC_3V3: supplied by VDDAO_3V3
   217	[    1.789098] FLASH_1V8: supplied by VCC_3V3
   218	[    1.789141] VCC_1V8: supplied by VCC_3V3
   219	[    1.789171] VDDAO_1V8: supplied by VDDAO_3V3
   220	[    1.789199] VDDCPU_A: supplied by regulator-dummy
   221	[    1.789553] VDDCPU_B: supplied by regulator-dummy
   222	[    1.790248] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
   223	[    1.792638] Serial: AMBA driver
   224	[    1.792917] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart
   225	[    1.793011] printk: console [ttyAML0] enabled
   226	[    1.793556] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 33, base_baud = 1500000) is a meson_uart
   227	[    1.798875] loop: module loaded
   228	[    1.800711] libphy: Fixed MDIO Bus: probed
   229	[    1.801658] tun: Universal TUN/TAP device driver, 1.6
   230	[    1.802325] thunder_xcv, ver 1.0
   231	[    1.802353] thunder_bgx, ver 1.0
   232	[    1.802382] nicpf, ver 1.0
   233	[    1.802846] e1000e: Intel(R) PRO/1000 Network Driver
   234	[    1.802850] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
   235	[    1.802892] igb: Intel(R) Gigabit Ethernet Network Driver
   236	[    1.802895] igb: Copyright (c) 2007-2014 Intel Corporation.
   237	[    1.802930] igbvf: Intel(R) Gigabit Virtual Function Network Driver
   238	[    1.802933] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
   239	[    1.803062] sky2: driver version 1.30
   240	[    1.803435] VFIO - User Level meta-driver version: 0.3
   241	[    1.805078] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
   242	[    1.805100] ehci-pci: EHCI PCI platform driver
   243	[    1.805132] ehci-platform: EHCI generic platform driver
   244	[    1.805272] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
   245	[    1.805283] ohci-pci: OHCI PCI platform driver
   246	[    1.805315] ohci-platform: OHCI generic platform driver
   247	[    1.805736] usbcore: registered new interface driver usb-storage
   248	[    1.807089] mousedev: PS/2 mouse device common for all mice
   249	[    1.807504] i2c /dev entries driver
   250	[    1.812637] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17
   251	[    1.813775] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz
   252	[    1.814530] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-1 failed:-17
   253	[    1.815161] sdhci: Secure Digital Host Controller Interface driver
   254	[    1.815166] sdhci: Copyright(c) Pierre Ossman
   255	[    1.815289] Synopsys Designware Multimedia Card Interface Driver
   256	[    1.815867] sdhci-pltfm: SDHCI platform and OF driver helper
   257	[    1.816636] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq
   258	[    1.817128] ledtrig-cpu: registered to indicate activity on CPUs
   259	[    1.817354] meson-sm: secure-monitor enabled
   260	[    1.817524] hid: raw HID events driver (C) Jiri Kosina
   261	[    1.817603] usbcore: registered new interface driver usbhid
   262	[    1.817605] usbhid: USB HID core driver
   263	[    1.818565] NET: Registered protocol family 10
   264	[    1.818974] Segment Routing with IPv6
   265	[    1.819001] NET: Registered protocol family 17
   266	[    1.819067] 8021q: 802.1Q VLAN Support v1.8
   267	[    1.819094] Key type dns_resolver registered
   268	[    1.819396] registered taskstats version 1
   269	[    1.819401] Loading compiled-in X.509 certificates
   270	[    1.821356] Loaded X.509 cert 'Build time autogenerated kernel key: f47c178852ca39740c3546b008122b65f5ed9bce'
   271	[    1.822974] zswap: loaded using pool zstd/z3fold
   272	[    1.823157] Key type ._fscrypt registered
   273	[    1.823159] Key type .fscrypt registered
   274	[    1.823161] Key type fscrypt-provisioning registered
   275	[    1.824353] Btrfs loaded, crc32c=crc32c-generic
   276	[    1.830236] Key type encrypted registered
   277	[    1.830249] AppArmor: AppArmor sha1 policy hashing enabled
   278	[    1.836635] HUB_5V: supplied by 5V
   279	[    1.836854] USB_PWR_EN: supplied by 5V
   280	[    1.838483] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2
   281	[    1.838490] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1
   282	[    1.841176] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator
   283	[    1.841222] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator
   284	[    1.841327] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM
   285	[    1.841913] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
   286	[    1.841924] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
   287	[    1.842013] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010
   288	[    1.842037] xhci-hcd xhci-hcd.0.auto: irq 41, io mem 0xff500000
   289	[    1.842163] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
   290	[    1.842166] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   291	[    1.842169] usb usb1: Product: xHCI Host Controller
   292	[    1.842171] usb usb1: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
   293	[    1.842173] usb usb1: SerialNumber: xhci-hcd.0.auto
   294	[    1.842361] hub 1-0:1.0: USB hub found
   295	[    1.842374] hub 1-0:1.0: 2 ports detected
   296	[    1.842504] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
   297	[    1.842511] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
   298	[    1.842516] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
   299	[    1.842538] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
   300	[    1.842570] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
   301	[    1.842573] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   302	[    1.842576] usb usb2: Product: xHCI Host Controller
   303	[    1.842578] usb usb2: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
   304	[    1.842580] usb usb2: SerialNumber: xhci-hcd.0.auto
   305	[    1.842728] hub 2-0:1.0: USB hub found
   306	[    1.842738] hub 2-0:1.0: 1 port detected
   307	[    1.843020] dwc3-meson-g12a ffe09000.usb: switching to Device Mode
   308	[    1.844074] meson-gx-mmc ffe05000.sd: Got CD GPIO
   309	[    1.868643] Freeing unused kernel memory: 3328K
   310	[    1.907715] Run /init as init process
   311	[    1.907719]   with arguments:
   312	[    1.907721]     /init
   313	[    1.907723]   with environment:
   314	[    1.907724]     HOME=/
   315	[    1.907726]     TERM=linux
   316	[    1.907728]     hdmimode=1080p60hz
   317	[    1.907729]     cvbsmode=576cvbs
   318	[    1.907731]     max_freq_a53=1896
   319	[    1.907733]     max_freq_a73=1800
   320	[    1.907734]     voutmode=hdmi
   321	[    1.907735]     disablehpd=false
   322	[    1.907736]     cvbscable=0
   323	[    1.907738]     overscan=100
   324	[    1.933812] mmc1: new ultra high speed SDR25 SDHC card at address b368
   325	[    1.934357] mmcblk1: mmc1:b368 CBADS 30.0 GiB
   326	[    1.936287]  mmcblk1: p1
   327	[    2.057001] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found
   328	[    2.057007] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found
   329	[    2.057090] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock
   330	[    2.057578] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37
   331	[    2.057588] meson8b-dwmac ff3f0000.ethernet: 	DWMAC1000
   332	[    2.057592] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported
   333	[    2.057596] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported
   334	[    2.057599] meson8b-dwmac ff3f0000.ethernet: COE Type 2
   335	[    2.057602] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported
   336	[    2.057605] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported
   337	[    2.057677] meson8b-dwmac ff3f0000.ethernet: Normal descriptors
   338	[    2.057680] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled
   339	[    2.057684] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
   340	[    2.058039] libphy: stmmac: probed
   341	[    2.060155] libphy: mdio_mux: probed
   342	[    2.073350] meson-vrtc ff8000a8.rtc: registered as rtc1
   343	[    2.088951] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
   344	[    2.089193] rtc-pcf8563 1-0051: registered as rtc0
   345	[    2.090430] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
   346	[    2.090442] rtc-pcf8563 1-0051: hctosys: unable to read the hardware clock
   347	[    2.091800] random: fast init done
   348	[    2.179747] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
   349	[    2.204346] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.04
   350	[    2.204354] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
   351	[    2.204358] usb 2-1: Product: USB3.1 Hub
   352	[    2.204361] usb 2-1: Manufacturer: GenesysLogic
   353	[    2.226801] hub 2-1:1.0: USB hub found
   354	[    2.227098] hub 2-1:1.0: 4 ports detected
   355	[    2.264195] libphy: mdio_mux: probed
   356	[    2.327622] usb 1-1: new high-speed USB device number 2 using xhci-hcd
   357	[    2.477893] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.04
   358	[    2.477901] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
   359	[    2.477904] usb 1-1: Product: USB2.1 Hub
   360	[    2.477907] usb 1-1: Manufacturer: GenesysLogic
   361	[    2.514814] hub 1-1:1.0: USB hub found
   362	[    2.515070] hub 1-1:1.0: 4 ports detected
   363	[    2.826998] EXT4-fs (mmcblk1p1): mounted filesystem with writeback data mode. Opts: (null)
   364	[    3.602186] systemd[1]: System time before build time, advancing clock.
   365	[    3.616889] systemd[1]: Inserted module 'autofs4'
   366	[    3.663238] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
   367	[    3.663456] systemd[1]: Detected architecture arm64.
   368	[    3.705834] systemd[1]: Set hostname to <odroidn2>.
   369	[    3.995878] random: systemd: uninitialized urandom read (16 bytes read)
   370	[    3.999193] random: systemd: uninitialized urandom read (16 bytes read)
   371	[    3.999463] systemd[1]: Listening on udev Control Socket.
   372	[    3.999732] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
   373	[    3.999753] random: systemd: uninitialized urandom read (16 bytes read)
   374	[    3.999768] systemd[1]: Reached target Swap.
   375	[    4.000008] systemd[1]: Listening on Journal Socket (/dev/log).
   376	[    4.000087] systemd[1]: Reached target Remote File Systems.
   377	[    4.000268] systemd[1]: Listening on Syslog Socket.
   378	[    4.000436] systemd[1]: Listening on udev Kernel Socket.
   379	[    4.110762] EXT4-fs (mmcblk1p1): re-mounted. Opts: commit=600,errors=remount-ro
   380	[    4.665452] zram: Added device: zram0
   381	[    4.665752] zram: Added device: zram1
   382	[    4.665964] zram: Added device: zram2
   383	[    4.766024] pwm-gpio pwmgpio: 1 gpio pwms loaded
   384	[    4.877426] zram0: detected capacity change from 0 to 1904500736
   385	[    4.940248] meson-saradc ff809000.adc: supply vref not found, using dummy regulator
   386	[    4.954791] mc: Linux media interface: v0.10
   387	[    5.024618] videodev: Linux video capture interface: v2.00
   388	[    5.035640] Registered IR keymap rc-odroid
   389	[    5.044595] meson-drm ff900000.vpu: Queued 2 outputs on vpu
   390	[    5.068114] IR NEC protocol handler initialized
   391	[    5.068495] panfrost ffe40000.gpu: clock rate = 24000000
   392	[    5.068553] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19
   393	[    5.069117] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0
   394	[    5.069120] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400
   395	[    5.069125] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
   396	[    5.069127] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1
   397	[    5.085945] meson-drm ff900000.vpu: CVBS Output connector not available
   398	[    5.087556] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 0
   399	[    5.095731] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0
   400	[    5.095820] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
   401	[    5.095876] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input0
   402	[    5.096279] meson-ir ff808000.ir: receiver initialized
   403	[    5.114047] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
   404	[    5.114985] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
   405	[    5.115245] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
   406	[    5.115493] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 1
   407	[    5.115551] meson-drm ff900000.vpu: [drm] Cannot find any crtc or sizes
   408	[    5.145002] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
   409	[    5.188907] axg-sound-card sound: ASoC: no DMI vendor name!
   410	[    5.959606] Adding 1859860k swap on /dev/zram0.  Priority:5 extents:1 across:1859860k SSFS
   411	[    6.023890] zram1: detected capacity change from 0 to 52428800
   412	[    8.069093] zram2: detected capacity change from 0 to 1904500736
   413	[   10.102707] EXT4-fs (zram2): mounted filesystem without journal. Opts: discard
   414	[   10.120527] systemd[1]: Started Armbian ZRAM config.
   415	[   10.122329] systemd[1]: Starting Armbian memory supported logging...
   416	[   10.164471] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
   417	[   10.164490] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
   418	[   11.006694] systemd[1]: Started Armbian memory supported logging.
   419	[   11.009017] systemd[1]: Starting Journal Service...
   420	[   11.068661] systemd[1]: Started Journal Service.
   421	[   11.087892] systemd-journald[1823]: Received request to flush runtime journal from PID 1
   422
   423	### armbian-release:
   424
   425	# PLEASE DO NOT EDIT THIS FILE
   426	BOARD=odroidn2
   427	BOARD_NAME="Odroid N2"
   428	BOARDFAMILY=meson-g12b
   429	BUILD_REPOSITORY_URL=https://github.com/armbian/build
   430	BUILD_REPOSITORY_COMMIT=5f03d652
   431	DISTRIBUTION_CODENAME=buster
   432	DISTRIBUTION_STATUS=supported
   433	VERSION=21.02.1
   434	LINUXFAMILY=meson64
   435	BRANCH=current
   436	ARCH=arm64
   437	IMAGE_TYPE=stable
   438	BOARD_TYPE=conf
   439	INITRD_ARCH=arm64
   440	KERNEL_IMAGE_TYPE=Image
   441
   442	### boot environment:
   443
   444	verbosity=1
   445	console=both
   446	overlay_prefix=meson
   447	rootdev=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c
   448	rootfstype=ext4
   449
   450	### lsusb:
   451
   452	Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc.
   453	Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
   454	Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
   455	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
   456
   457	### lscpu:
   458
   459	Architecture:        aarch64
   460	Byte Order:          Little Endian
   461	CPU(s):              6
   462	On-line CPU(s) list: 0-5
   463	Thread(s) per core:  1
   464	Core(s) per socket:  3
   465	Socket(s):           2
   466	NUMA node(s):        1
   467	Vendor ID:           ARM
   468	Model:               4
   469	Model name:          Cortex-A53
   470	Stepping:            r0p4
   471	CPU max MHz:         1992.0000
   472	CPU min MHz:         100.0000
   473	BogoMIPS:            48.00
   474	L1d cache:           unknown size
   475	L1i cache:           unknown size
   476	L2 cache:            unknown size
   477	NUMA node0 CPU(s):   0-5
   478	Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   479
   480	### cpuinfo:
   481
   482	processor	: 0
   483	BogoMIPS	: 48.00
   484	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   485	CPU implementer	: 0x41
   486	CPU architecture: 8
   487	CPU variant	: 0x0
   488	CPU part	: 0xd03
   489	CPU revision	: 4
   490
   491	processor	: 1
   492	BogoMIPS	: 48.00
   493	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   494	CPU implementer	: 0x41
   495	CPU architecture: 8
   496	CPU variant	: 0x0
   497	CPU part	: 0xd03
   498	CPU revision	: 4
   499
   500	processor	: 2
   501	BogoMIPS	: 48.00
   502	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   503	CPU implementer	: 0x41
   504	CPU architecture: 8
   505	CPU variant	: 0x0
   506	CPU part	: 0xd09
   507	CPU revision	: 2
   508
   509	processor	: 3
   510	BogoMIPS	: 48.00
   511	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   512	CPU implementer	: 0x41
   513	CPU architecture: 8
   514	CPU variant	: 0x0
   515	CPU part	: 0xd09
   516	CPU revision	: 2
   517
   518	processor	: 4
   519	BogoMIPS	: 48.00
   520	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   521	CPU implementer	: 0x41
   522	CPU architecture: 8
   523	CPU variant	: 0x0
   524	CPU part	: 0xd09
   525	CPU revision	: 2
   526
   527	processor	: 5
   528	BogoMIPS	: 48.00
   529	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   530	CPU implementer	: 0x41
   531	CPU architecture: 8
   532	CPU variant	: 0x0
   533	CPU part	: 0xd09
   534	CPU revision	: 2
   535
   536
   537	### meminfo:
   538
   539	MemTotal:        3719728 kB
   540	MemFree:         3397716 kB
   541	MemAvailable:    3348364 kB
   542	Buffers:           10316 kB
   543	Cached:            40288 kB
   544	SwapCached:            0 kB
   545	Active:            29212 kB
   546	Inactive:         185872 kB
   547	Active(anon):         88 kB
   548	Inactive(anon):   169544 kB
   549	Active(file):      29124 kB
   550	Inactive(file):    16328 kB
   551	Unevictable:           0 kB
   552	Mlocked:               0 kB
   553	SwapTotal:       1859860 kB
   554	SwapFree:        1859860 kB
   555	Dirty:               580 kB
   556	Writeback:             0 kB
   557	AnonPages:        165100 kB
   558	Mapped:            10744 kB
   559	Shmem:              4860 kB
   560	KReclaimable:      12560 kB
   561	Slab:              38440 kB
   562	SReclaimable:      12560 kB
   563	SUnreclaim:        25880 kB
   564	KernelStack:        2096 kB
   565	PageTables:         4508 kB
   566	NFS_Unstable:          0 kB
   567	Bounce:                0 kB
   568	WritebackTmp:          0 kB
   569	CommitLimit:     3719724 kB
   570	Committed_AS:    4212588 kB
   571	VmallocTotal:   135290159040 kB
   572	VmallocUsed:       38212 kB
   573	VmallocChunk:          0 kB
   574	Percpu:             1368 kB
   575	HardwareCorrupted:     0 kB
   576	AnonHugePages:     40960 kB
   577	ShmemHugePages:        0 kB
   578	ShmemPmdMapped:        0 kB
   579	FileHugePages:         0 kB
   580	FilePmdMapped:         0 kB
   581	CmaTotal:         917504 kB
   582	CmaFree:          909824 kB
   583	HugePages_Total:       0
   584	HugePages_Free:        0
   585	HugePages_Rsvd:        0
   586	HugePages_Surp:        0
   587	Hugepagesize:       2048 kB
   588	Hugetlb:               0 kB
   589
   590	### virtual memory:
   591
   592	vm.admin_reserve_kbytes = 8192
   593	Thu 04 Feb 2021 01:01:21 PM UTC | Odroid N2 | 21.02.1 | arm64 | aarch64 | 5.10.12-meson64
   594	vm.block_dump = 0
   595	vm.compaction_proactiveness = 20
   596	vm.compact_unevictable_allowed = 1
   597	vm.dirty_background_bytes = 0
   598	vm.dirty_background_ratio = 10
   599	vm.dirty_bytes = 0
   600	vm.dirty_expire_centisecs = 3000
   601	vm.dirty_ratio = 20
   602	vm.dirtytime_expire_seconds = 43200
   603	vm.dirty_writeback_centisecs = 500
   604	vm.extfrag_threshold = 500
   605	vm.hugetlb_shm_group = 0
   606	vm.laptop_mode = 0
   607
   608	### [resize2fs] Leaving 1% spare area. Start resizing partition /dev/mmcblk1p1 now:
   609
   610	major minor  #blocks  name
   611
   612	 179        0   31464960 mmcblk1
   613	 179        1    1802240 mmcblk1p1
   614	 252        0    1859864 zram0
   615	 252        1      51200 zram1
   616	 252        2    1859864 zram2
   617	vm.legacy_va_layout = 0
   618
   619	Executing fdisk, fsck and partprobe:
   620	vm.lowmem_reserve_ratio = 256	256	32	0
   621	vm.max_map_count = 65530
   622	vm.memory_failure_early_kill = 0
   623	vm.memory_failure_recovery = 1
   624
   625	Welcome to fdisk (util-linux 2.33.1).
   626	Changes will remain in memory only, until you decide to write them.
   627	Be careful before using the write command.
   628
   629
   630	Command (m for help): Selected partition 1
   631	Partition 1 has been deleted.
   632
   633	Command (m for help): Partition type
   634	   p   primary (0 primary, 0 extended, 4 free)
   635	   e   extended (container for logical partitions)
   636	Select (default p): Partition number (1-4, default 1): First sector (2048-62929919, default 2048): Last sector, +/-sectors or +/-size{K,M,G,T,P} (8192-62929919, default 62929919): vm.min_free_kbytes = 45056
   637	vm.min_slab_ratio = 5
   638	vm.min_unmapped_ratio = 1
   639
   640	Created a new partition 1 of type 'Linux' and of size 29.7 GiB.
   641	Partition #1 contains a ext4 signature.
   642
   643	Command (m for help): vm.mmap_min_addr = 4096
   644	vm.mmap_rnd_bits = 18
   645	vm.mmap_rnd_compat_bits = 11
   646	vm.nr_hugepages = 0
   647	vm.nr_hugepages_mempolicy = 0
   648	vm.nr_overcommit_hugepages = 0
   649
   650	The partition table has been altered.
   651	Syncing disks.
   652
   653	vm.numa_stat = 1
   654	vm.numa_zonelist_order = Node
   655	vm.oom_dump_tasks = 1
   656	vm.oom_kill_allocating_task = 0
   657	vm.overcommit_kbytes = 0
   658	vm.overcommit_memory = 0
   659	vm.overcommit_ratio = 50
   660	New partition table:
   661
   662	major minor  #blocks  name
   663
   664	 179        0   31464960 mmcblk1
   665	 179        1   31146208 mmcblk1p1
   666	 252        0    1859864 zram0
   667	 252        1      51200 zram1
   668	 252        2    1859864 zram2
   669
   670	Now trying to resize ext4 filesystem on /dev/mmcblk1p1 to the limits:
   671
   672	vm.page-cluster = 0
   673	resize2fs 1.44.5 (15-Dec-2018)
   674	vm.page_lock_unfairness = 5
   675	vm.panic_on_oom = 0
   676	vm.percpu_pagelist_fraction = 0
   677	vm.stat_interval = 1
   678	vm.swappiness = 100
   679	vm.user_reserve_kbytes = 115014
   680	vm.vfs_cache_pressure = 100
   681	vm.watermark_boost_factor = 15000
   682	vm.watermark_scale_factor = 10
   683	vm.zone_reclaim_mode = 0
   684
   685	### ip addr:
   686
   687	1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
   688	    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
   689	    inet XXX.XXX.0.1/8 scope host lo
   690	       valid_lft forever preferred_lft forever
   691	    inet6 ::1/128 scope host
   692	       valid_lft forever preferred_lft forever
   693	2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
   694	    link/ether 00:1e:06:42:03:f8 brd ff:ff:ff:ff:ff:ff
   695
   696	### partitions:
   697
   698	major minor  #blocks  name
   699
   700	 179        0   31464960 mmcblk1
   701	 179        1   31146208 mmcblk1p1
   702	 252        0    1859864 zram0
   703	 252        1      51200 zram1
   704	 252        2    1859864 zram2
   705
   706	### df:
   707
   708	udev            1.4G     0  1.4G   0% /dev
   709	tmpfs           364M  4.9M  359M   2% /run
   710	/dev/mmcblk1p1  2.0G  1.5G  479M  76% /
   711	tmpfs           1.8G     0  1.8G   0% /dev/shm
   712	tmpfs           5.0M  4.0K  5.0M   1% /run/lock
   713	tmpfs           1.8G     0  1.8G   0% /sys/fs/cgroup
   714	/dev/zram2      1.8G  5.4M  1.7G   1% /tmp
   715	/dev/zram1       49M  604K   45M   2% /var/log
   716
   717	### lsblk:
   718
   719	NAME        FSTYPE  SIZE MOUNTPOINT UUID
   720	mmcblk1              30G
   721	└─mmcblk1p1 ext4   29.7G /          bd34953d-41be-49d6-b1c0-c0c28a5e239c
   722	zram1                50M /var/log
   723	zram2               1.8G /tmp
   724
   725	### zramctl:
   726
   727	NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
   728	/dev/zram2 lzo-rle       1.8G  1.1M 18.9K  108K       6 /tmp
   729	/dev/zram1 zstd           50M  684K 95.6K  400K       6 /var/log
   730	/dev/zram0 lzo-rle       1.8G    4K   74B   12K       6 [SWAP]
   731
   732	### mtab:
   733
   734	/dev/mmcblk1p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
   735	/dev/mmcblk1p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
   736	/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
   737	/dev/zram2 /tmp ext4 rw,nosuid,relatime,discard 0 0
   738
   739	### mmc1:b368 info:
   740
   741	               fwrev: 0x0
   742	              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=CBADS MODALIAS=mmc:block
   743	                 cid: 6f0303434241445310aa002b4d013b00
   744	                 rca: 0xb368
   745	                 csd: 400e005a5b590000f00e7f800a404000
   746	              manfid: 0x00006f
   747	                 ocr: 0x00200000
   748	preferred_erase_size: 2097152
   749	                type: SD
   750	               hwrev: 0x1
   751	                date: 11/2019
   752	                 dsr: 0x404
   753	          erase_size: 512
   754	               oemid: 0x0303
   755	              serial: 0xaa002b4d
   756	                 ssr: 00000000000000280402800100fd180a001e00000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
   757	                 scr: 02b5800300000000
   758	                name: CBADS
   759
   760	### Boot system health:
   761
   762	Time       big.LITTLE   load %cpu %sys %usr %nice %io %irq   CPU  C.St.
   763	13:01:22: 1908/1992MHz  2.36  22%  10%   4%   0%   7%   0% 24.9°C  0/11
   764	13:01:22: 1908/1992MHz  2.36  13%   1%   0%   0%  11%   0% 21.9°C  0/11
   765	13:01:23: 1908/1992MHz  2.36   8%   1%   0%   0%   6%   0% 21.8°C  0/11
   766	13:01:23: 1908/1992MHz  2.36   6%   1%   0%   0%   4%   0% 21.3°C  0/11
   767	13:01:23: 1908/1992MHz  2.36  34%   5%   1%   0%  27%   0% 21.9°C  0/11
   768	Filesystem at /dev/mmcblk1p1 is mounted on /; on-line resizing required
   769	old_desc_blocks = 1, new_desc_blocks = 2
   770	The filesystem on /dev/mmcblk1p1 is now 7786552 (4k) blocks long.
   771
   772
   773	### [resize2fs] Start resizing ext4 partition /dev/mmcblk1p1 now
   774
   775	resize2fs 1.44.5 (15-Dec-2018)
   776	The filesystem is already 7786552 (4k) blocks long.  Nothing to do!
   777
   778
   779	### quick iozone test: 4      376      559      600     1110     8475     3638
   780
   781	### Activated 1 lzo-rle zram swap devices with 1816 MB each
   782
   783	### Activated Armbian ramlog partition with zstd compression
   784
   785	Sun 14 Feb 2021 01:49:20 PM GMT | Odroid N2 | 21.02.1 | arm64 | aarch64 | 5.10.12-meson64
   786
   787	### dmesg:
   788
   789	[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
   790	[    0.000000] Linux version 5.10.12-meson64 (root@beast) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #21.02.1 SMP PREEMPT Wed Feb 3 21:06:36 CET 2021
   791	[    0.000000] Machine model: Hardkernel ODROID-N2
   792	[    0.000000] efi: UEFI not found.
   793	[    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
   794	[    0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB
   795	[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
   796	[    0.000000] NUMA: No NUMA configuration found
   797	[    0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ed7fffff]
   798	[    0.000000] NUMA: NODE_DATA [mem 0xb502f100-0xb5030fff]
   799	[    0.000000] Zone ranges:
   800	[    0.000000]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
   801	[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000ed7fffff]
   802	[    0.000000]   Normal   empty
   803	[    0.000000] Movable zone start for each node
   804	[    0.000000] Early memory node ranges
   805	[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000004ffffff]
   806	[    0.000000]   node   0: [mem 0x0000000005300000-0x00000000ed7fffff]
   807	[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ed7fffff]
   808	[    0.000000] On node 0 totalpages: 972032
   809	[    0.000000]   DMA zone: 4096 pages used for memmap
   810	[    0.000000]   DMA zone: 0 pages reserved
   811	[    0.000000]   DMA zone: 261376 pages, LIFO batch:63
   812	[    0.000000]   DMA32 zone: 11104 pages used for memmap
   813	[    0.000000]   DMA32 zone: 710656 pages, LIFO batch:63
   814	[    0.000000] psci: probing for conduit method from DT.
   815	[    0.000000] psci: PSCIv1.0 detected in firmware.
   816	[    0.000000] psci: Using standard PSCI v0.2 function IDs
   817	[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
   818	[    0.000000] psci: SMC Calling Convention v1.1
   819	[    0.000000] percpu: Embedded 23 pages/cpu s56728 r8192 d29288 u94208
   820	[    0.000000] pcpu-alloc: s56728 r8192 d29288 u94208 alloc=23*4096
   821	[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
   822	[    0.000000] Detected VIPT I-cache on CPU0
   823	[    0.000000] CPU features: detected: ARM erratum 845719
   824	[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 956832
   825	[    0.000000] Policy zone: DMA32
   826	[    0.000000] Kernel command line: root=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c rootwait rootfstype=ext4 console=ttyAML0,115200n8 console=tty1 loglevel=1  no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=1080p60hz cvbsmode=576cvbs max_freq_a53=1896 max_freq_a73=1800 maxcpus=6 voutmode=hdmi  disablehpd=false  cvbscable=0 overscan=100 consoleblank=0
   827	[    0.000000] Kernel parameter elevator= does not have any effect anymore.
   828	               Please use sysfs to set IO scheduler for individual devices.
   829	[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
   830	[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
   831	[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
   832	[    0.000000] software IO TLB: mapped [mem 0x0000000038ac4000-0x000000003cac4000] (64MB)
   833	[    0.000000] Memory: 2785348K/3888128K available (14144K kernel code, 1760K rwdata, 5508K rodata, 3328K init, 592K bss, 185276K reserved, 917504K cma-reserved)
   834	[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
   835	[    0.000000] rcu: Preemptible hierarchical RCU implementation.
   836	[    0.000000] rcu: 	RCU event tracing is enabled.
   837	[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
   838	[    0.000000] 	Trampoline variant of Tasks RCU enabled.
   839	[    0.000000] 	Rude variant of Tasks RCU enabled.
   840	[    0.000000] 	Tracing variant of Tasks RCU enabled.
   841	[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
   842	[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
   843	[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
   844	[    0.000000] GIC: Using split EOI/Deactivate mode
   845	[    0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized
   846	[    0.000000] random: get_random_bytes called from start_kernel+0x378/0x538 with crng_init=0
   847	[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
   848	[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
   849	[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
   850	[    0.000249] Console: colour dummy device 80x25
   851	[    0.000282] printk: console [tty1] enabled
   852	[    0.000370] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
   853	[    0.000381] pid_max: default: 32768 minimum: 301
   854	[    0.000464] LSM: Security Framework initializing
   855	[    0.000490] Yama: becoming mindful.
   856	[    0.000582] AppArmor: AppArmor initialized
   857	[    0.000632] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
   858	[    0.000651] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
   859	[    0.002642] rcu: Hierarchical SRCU implementation.
   860	[    0.005097] EFI services will not be available.
   861	[    0.005518] smp: Bringing up secondary CPUs ...
   862	[    0.006186] Detected VIPT I-cache on CPU1
   863	[    0.006247] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
   864	[    0.007437] CPU features: detected: ARM erratum 858921
   865	[    0.007446] CPU features: detected: Spectre-v2
   866	[    0.007449] CPU features: detected: Spectre-v4
   867	[    0.007455] Detected VIPT I-cache on CPU2
   868	[    0.007482] arch_timer: Enabling local workaround for ARM erratum 858921
   869	[    0.007496] arch_timer: CPU2: Trapping CNTVCT access
   870	[    0.007509] CPU2: Booted secondary processor 0x0000000100 [0x410fd092]
   871	[    0.008213] Detected VIPT I-cache on CPU3
   872	[    0.008229] arch_timer: Enabling local workaround for ARM erratum 858921
   873	[    0.008236] arch_timer: CPU3: Trapping CNTVCT access
   874	[    0.008244] CPU3: Booted secondary processor 0x0000000101 [0x410fd092]
   875	[    0.008865] Detected VIPT I-cache on CPU4
   876	[    0.008882] arch_timer: Enabling local workaround for ARM erratum 858921
   877	[    0.008889] arch_timer: CPU4: Trapping CNTVCT access
   878	[    0.008896] CPU4: Booted secondary processor 0x0000000102 [0x410fd092]
   879	[    0.009508] Detected VIPT I-cache on CPU5
   880	[    0.009524] arch_timer: Enabling local workaround for ARM erratum 858921
   881	[    0.009531] arch_timer: CPU5: Trapping CNTVCT access
   882	[    0.009539] CPU5: Booted secondary processor 0x0000000103 [0x410fd092]
   883	[    0.009621] smp: Brought up 1 node, 6 CPUs
   884	[    0.009638] SMP: Total of 6 processors activated.
   885	[    0.009646] CPU features: detected: 32-bit EL0 Support
   886	[    0.009652] CPU features: detected: CRC32 instructions
   887	[    0.009658] CPU features: detected: 32-bit EL1 Support
   888	[    0.020943] CPU: All CPU(s) started at EL2
   889	[    0.020992] alternatives: patching kernel code
   890	[    0.022942] devtmpfs: initialized
   891	[    0.030586] Registered cp15_barrier emulation handler
   892	[    0.030601] Registered setend emulation handler
   893	[    0.030736] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
   894	[    0.030776] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
   895	[    0.044719] pinctrl core: initialized pinctrl subsystem
   896	[    0.045454] DMI not present or invalid.
   897	[    0.045820] NET: Registered protocol family 16
   898	[    0.047339] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
   899	[    0.047627] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
   900	[    0.047856] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
   901	[    0.047895] audit: initializing netlink subsys (disabled)
   902	[    0.048001] audit: type=2000 audit(0.048:1): state=initialized audit_enabled=0 res=1
   903	[    0.049230] thermal_sys: Registered thermal governor 'fair_share'
   904	[    0.049238] thermal_sys: Registered thermal governor 'bang_bang'
   905	[    0.049244] thermal_sys: Registered thermal governor 'step_wise'
   906	[    0.049247] thermal_sys: Registered thermal governor 'user_space'
   907	[    0.049667] cpuidle: using governor menu
   908	[    0.050002] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
   909	[    0.050124] ASID allocator initialised with 65536 entries
   910	[    0.051080] Serial: AMBA PL011 UART driver
   911	[    0.085746] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
   912	[    0.085757] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
   913	[    0.085762] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
   914	[    0.085766] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
   915	[    0.087314] cryptd: max_cpu_qlen set to 1000
   916	[    0.156189] raid6: neonx8   gen()  2780 MB/s
   917	[    0.224267] raid6: neonx8   xor()  1604 MB/s
   918	[    0.292312] raid6: neonx4   gen()  3153 MB/s
   919	[    0.360376] raid6: neonx4   xor()  2399 MB/s
   920	[    0.428447] raid6: neonx2   gen()  2544 MB/s
   921	[    0.496506] raid6: neonx2   xor()  2207 MB/s
   922	[    0.564593] raid6: neonx1   gen()  2070 MB/s
   923	[    0.632677] raid6: neonx1   xor()  1247 MB/s
   924	[    0.700729] raid6: int64x8  gen()  1374 MB/s
   925	[    0.768801] raid6: int64x8  xor()   735 MB/s
   926	[    0.836883] raid6: int64x4  gen()  1463 MB/s
   927	[    0.904931] raid6: int64x4  xor()   733 MB/s
   928	[    0.972986] raid6: int64x2  gen()  1362 MB/s
   929	[    1.041067] raid6: int64x2  xor()   619 MB/s
   930	[    1.109117] raid6: int64x1  gen()  1120 MB/s
   931	[    1.177198] raid6: int64x1  xor()   462 MB/s
   932	[    1.177201] raid6: using algorithm neonx4 gen() 3153 MB/s
   933	[    1.177204] raid6: .... xor() 2399 MB/s, rmw enabled
   934	[    1.177208] raid6: using neon recovery algorithm
   935	[    1.177657] ACPI: Interpreter disabled.
   936	[    1.178454] 5V: supplied by 12V
   937	[    1.179360] VDDAO_3V3: supplied by 12V
   938	[    1.179821] iommu: Default domain type: Translated
   939	[    1.179953] vgaarb: loaded
   940	[    1.180890] SCSI subsystem initialized
   941	[    1.181196] usbcore: registered new interface driver usbfs
   942	[    1.181236] usbcore: registered new interface driver hub
   943	[    1.181267] usbcore: registered new device driver usb
   944	[    1.181577] pps_core: LinuxPPS API ver. 1 registered
   945	[    1.181582] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
   946	[    1.181608] PTP clock support registered
   947	[    1.181796] EDAC MC: Ver: 3.0.0
   948	[    1.183101] NetLabel: Initializing
   949	[    1.183108] NetLabel:  domain hash size = 128
   950	[    1.183111] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
   951	[    1.183154] NetLabel:  unlabeled traffic allowed by default
   952	[    1.183578] clocksource: Switched to clocksource arch_sys_counter
   953	[    1.183786] VFS: Disk quotas dquot_6.6.0
   954	[    1.183832] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
   955	[    1.184182] AppArmor: AppArmor Filesystem Enabled
   956	[    1.184227] pnp: PnP ACPI: disabled
   957	[    1.189843] NET: Registered protocol family 2
   958	[    1.190304] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
   959	[    1.190408] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
   960	[    1.190664] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
   961	[    1.190850] TCP: Hash tables configured (established 32768 bind 32768)
   962	[    1.190999] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
   963	[    1.191064] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
   964	[    1.191110] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
   965	[    1.191265] NET: Registered protocol family 1
   966	[    1.191284] PCI: CLS 0 bytes, default 64
   967	[    1.191417] Trying to unpack rootfs image as initramfs...
   968	[    1.726831] Freeing initrd memory: 13548K
   969	[    1.727802] kvm [1]: IPA Size Limit: 40 bits
   970	[    1.728513] kvm [1]: vgic interrupt IRQ9
   971	[    1.728653] kvm [1]: Hyp mode initialized successfully
   972	[    1.732535] Initialise system trusted keyrings
   973	[    1.732566] Key type blacklist registered
   974	[    1.732664] workingset: timestamp_bits=44 max_order=20 bucket_order=0
   975	[    1.735864] zbud: loaded
   976	[    1.736840] squashfs: version 4.0 (2009/01/31) Phillip Lougher
   977	[    1.737346] fuse: init (API version 7.32)
   978	[    1.738115] integrity: Platform Keyring initialized
   979	[    1.765876] xor: measuring software checksum speed
   980	[    1.768724]    8regs           :  3473 MB/sec
   981	[    1.771173]    32regs          :  4022 MB/sec
   982	[    1.773825]    arm64_neon      :  3721 MB/sec
   983	[    1.773829] xor: using function: 32regs (4022 MB/sec)
   984	[    1.773836] Key type asymmetric registered
   985	[    1.773840] Asymmetric key parser 'x509' registered
   986	[    1.773873] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
   987	[    1.773958] io scheduler mq-deadline registered
   988	[    1.773962] io scheduler kyber registered
   989	[    1.774047] io scheduler bfq registered
   990	[    1.776615] gpio-447 (usb-hub-reset): hogged as output/high
   991	[    1.779544] EINJ: ACPI disabled.
   992	[    1.785808] soc soc0: Amlogic Meson G12B (S922X) Revision 29:a (40:2) Detected
   993	[    1.787200] VCC_3V3: supplied by VDDAO_3V3
   994	[    1.787240] FLASH_1V8: supplied by VCC_3V3
   995	[    1.787271] VCC_1V8: supplied by VCC_3V3
   996	[    1.787298] VDDAO_1V8: supplied by VDDAO_3V3
   997	[    1.787340] VDDCPU_A: supplied by regulator-dummy
   998	[    1.787734] VDDCPU_B: supplied by regulator-dummy
   999	[    1.788418] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
  1000	[    1.790779] Serial: AMBA driver
  1001	[    1.791072] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart
  1002	[    1.791168] printk: console [ttyAML0] enabled
  1003	[    1.791780] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 33, base_baud = 1500000) is a meson_uart
  1004	[    1.797306] loop: module loaded
  1005	[    1.799227] libphy: Fixed MDIO Bus: probed
  1006	[    1.800438] tun: Universal TUN/TAP device driver, 1.6
  1007	[    1.801124] thunder_xcv, ver 1.0
  1008	[    1.801154] thunder_bgx, ver 1.0
  1009	[    1.801183] nicpf, ver 1.0
  1010	[    1.801640] e1000e: Intel(R) PRO/1000 Network Driver
  1011	[    1.801644] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
  1012	[    1.801686] igb: Intel(R) Gigabit Ethernet Network Driver
  1013	[    1.801689] igb: Copyright (c) 2007-2014 Intel Corporation.
  1014	[    1.801719] igbvf: Intel(R) Gigabit Virtual Function Network Driver
  1015	[    1.801722] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
  1016	[    1.801850] sky2: driver version 1.30
  1017	[    1.802248] VFIO - User Level meta-driver version: 0.3
  1018	[    1.803754] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  1019	[    1.803790] ehci-pci: EHCI PCI platform driver
  1020	[    1.803828] ehci-platform: EHCI generic platform driver
  1021	[    1.803969] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  1022	[    1.803980] ohci-pci: OHCI PCI platform driver
  1023	[    1.804016] ohci-platform: OHCI generic platform driver
  1024	[    1.804446] usbcore: registered new interface driver usb-storage
  1025	[    1.805794] mousedev: PS/2 mouse device common for all mice
  1026	[    1.806187] i2c /dev entries driver
  1027	[    1.811321] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17
  1028	[    1.812456] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz
  1029	[    1.813152] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-1 failed:-17
  1030	[    1.813787] sdhci: Secure Digital Host Controller Interface driver
  1031	[    1.813795] sdhci: Copyright(c) Pierre Ossman
  1032	[    1.813918] Synopsys Designware Multimedia Card Interface Driver
  1033	[    1.814372] sdhci-pltfm: SDHCI platform and OF driver helper
  1034	[    1.814788] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq
  1035	[    1.815225] ledtrig-cpu: registered to indicate activity on CPUs
  1036	[    1.815497] meson-sm: secure-monitor enabled
  1037	[    1.815920] hid: raw HID events driver (C) Jiri Kosina
  1038	[    1.816027] usbcore: registered new interface driver usbhid
  1039	[    1.816030] usbhid: USB HID core driver
  1040	[    1.817214] NET: Registered protocol family 10
  1041	[    1.817660] Segment Routing with IPv6
  1042	[    1.817687] NET: Registered protocol family 17
  1043	[    1.817742] 8021q: 802.1Q VLAN Support v1.8
  1044	[    1.817766] Key type dns_resolver registered
  1045	[    1.818031] registered taskstats version 1
  1046	[    1.818036] Loading compiled-in X.509 certificates
  1047	[    1.819778] Loaded X.509 cert 'Build time autogenerated kernel key: f47c178852ca39740c3546b008122b65f5ed9bce'
  1048	[    1.821439] zswap: loaded using pool zstd/z3fold
  1049	[    1.821608] Key type ._fscrypt registered
  1050	[    1.821610] Key type .fscrypt registered
  1051	[    1.821612] Key type fscrypt-provisioning registered
  1052	[    1.822712] Btrfs loaded, crc32c=crc32c-generic
  1053	[    1.828821] Key type encrypted registered
  1054	[    1.828832] AppArmor: AppArmor sha1 policy hashing enabled
  1055	[    1.835169] HUB_5V: supplied by 5V
  1056	[    1.835384] USB_PWR_EN: supplied by 5V
  1057	[    1.836964] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2
  1058	[    1.836970] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1
  1059	[    1.839601] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator
  1060	[    1.839838] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator
  1061	[    1.840366] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM
  1062	[    1.840996] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  1063	[    1.841008] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
  1064	[    1.841129] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010
  1065	[    1.841148] xhci-hcd xhci-hcd.0.auto: irq 41, io mem 0xff500000
  1066	[    1.841264] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
  1067	[    1.841267] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1068	[    1.841270] usb usb1: Product: xHCI Host Controller
  1069	[    1.841272] usb usb1: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
  1070	[    1.841274] usb usb1: SerialNumber: xhci-hcd.0.auto
  1071	[    1.841506] hub 1-0:1.0: USB hub found
  1072	[    1.841519] hub 1-0:1.0: 2 ports detected
  1073	[    1.841649] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  1074	[    1.841654] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  1075	[    1.841659] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  1076	[    1.841681] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
  1077	[    1.841711] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
  1078	[    1.841714] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1079	[    1.841717] usb usb2: Product: xHCI Host Controller
  1080	[    1.841719] usb usb2: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
  1081	[    1.841721] usb usb2: SerialNumber: xhci-hcd.0.auto
  1082	[    1.841888] hub 2-0:1.0: USB hub found
  1083	[    1.841899] hub 2-0:1.0: 1 port detected
  1084	[    1.842150] dwc3-meson-g12a ffe09000.usb: switching to Device Mode
  1085	[    1.842997] meson-gx-mmc ffe05000.sd: Got CD GPIO
  1086	[    1.868619] Freeing unused kernel memory: 3328K
  1087	[    1.915638] Run /init as init process
  1088	[    1.915642]   with arguments:
  1089	[    1.915644]     /init
  1090	[    1.915646]   with environment:
  1091	[    1.915648]     HOME=/
  1092	[    1.915649]     TERM=linux
  1093	[    1.915651]     hdmimode=1080p60hz
  1094	[    1.915653]     cvbsmode=576cvbs
  1095	[    1.915654]     max_freq_a53=1896
  1096	[    1.915656]     max_freq_a73=1800
  1097	[    1.915657]     voutmode=hdmi
  1098	[    1.915659]     disablehpd=false
  1099	[    1.915660]     cvbscable=0
  1100	[    1.915661]     overscan=100
  1101	[    1.918277] mmc0: new high speed SDHC card at address b368
  1102	[    1.918775] mmcblk0: mmc0:b368 CBADS 30.0 GiB
  1103	[    1.920445]  mmcblk0: p1
  1104	[    2.060424] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found
  1105	[    2.060435] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found
  1106	[    2.060539] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock
  1107	[    2.063534] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37
  1108	[    2.063548] meson8b-dwmac ff3f0000.ethernet: 	DWMAC1000
  1109	[    2.063551] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported
  1110	[    2.063555] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported
  1111	[    2.063558] meson8b-dwmac ff3f0000.ethernet: COE Type 2
  1112	[    2.063561] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported
  1113	[    2.063592] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported
  1114	[    2.063671] meson8b-dwmac ff3f0000.ethernet: Normal descriptors
  1115	[    2.063675] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled
  1116	[    2.063678] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
  1117	[    2.064033] libphy: stmmac: probed
  1118	[    2.065797] libphy: mdio_mux: probed
  1119	[    2.080423] meson-vrtc ff8000a8.rtc: registered as rtc1
  1120	[    2.093694] rtc-pcf8563 1-0051: registered as rtc0
  1121	[    2.094963] rtc-pcf8563 1-0051: setting system clock to 2021-02-14T13:49:13 UTC (1613310553)
  1122	[    2.179713] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
  1123	[    2.204307] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.04
  1124	[    2.204315] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  1125	[    2.204318] usb 2-1: Product: USB3.1 Hub
  1126	[    2.204320] usb 2-1: Manufacturer: GenesysLogic
  1127	[    2.225917] hub 2-1:1.0: USB hub found
  1128	[    2.226204] hub 2-1:1.0: 4 ports detected
  1129	[    2.268185] libphy: mdio_mux: probed
  1130	[    2.327591] usb 1-1: new high-speed USB device number 2 using xhci-hcd
  1131	[    2.328233] random: fast init done
  1132	[    2.477872] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.04
  1133	[    2.477876] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  1134	[    2.477879] usb 1-1: Product: USB2.1 Hub
  1135	[    2.477881] usb 1-1: Manufacturer: GenesysLogic
  1136	[    2.513868] hub 1-1:1.0: USB hub found
  1137	[    2.514111] hub 1-1:1.0: 4 ports detected
  1138	[    2.817028] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
  1139	[    3.600959] systemd[1]: Inserted module 'autofs4'
  1140	[    3.647403] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  1141	[    3.647630] systemd[1]: Detected architecture arm64.
  1142	[    3.681838] systemd[1]: Set hostname to <odroidn2>.
  1143	[    3.970929] random: systemd: uninitialized urandom read (16 bytes read)
  1144	[    3.974293] random: systemd: uninitialized urandom read (16 bytes read)
  1145	[    3.974513] systemd[1]: Listening on Journal Audit Socket.
  1146	[    3.974723] random: systemd: uninitialized urandom read (16 bytes read)
  1147	[    3.974740] systemd[1]: Reached target System Time Synchronized.
  1148	[    3.976073] systemd[1]: Created slice system-getty.slice.
  1149	[    3.976399] systemd[1]: Listening on Syslog Socket.
  1150	[    3.976864] systemd[1]: Created slice User and Session Slice.
  1151	[    3.977107] systemd[1]: Listening on Journal Socket (/dev/log).
  1152	[    3.977260] systemd[1]: Listening on initctl Compatibility Named Pipe.
  1153	[    4.060382] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
  1154	[    4.672758] zram: Added device: zram0
  1155	[    4.672931] zram: Added device: zram1
  1156	[    4.673100] zram: Added device: zram2
  1157	[    4.781972] zram0: detected capacity change from 0 to 1904500736
  1158	[    4.860262] pwm-gpio pwmgpio: 1 gpio pwms loaded
  1159	[    5.008474] panfrost ffe40000.gpu: clock rate = 24000000
  1160	[    5.008547] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19
  1161	[    5.009517] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0
  1162	[    5.009527] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400
  1163	[    5.009533] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
  1164	[    5.009536] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1
  1165	[    5.024724] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 0
  1166	[    5.046143] mc: Linux media interface: v0.10
  1167	[    5.057224] meson-saradc ff809000.adc: supply vref not found, using dummy regulator
  1168	[    5.076886] meson-drm ff900000.vpu: Queued 2 outputs on vpu
  1169	[    5.099439] videodev: Linux video capture interface: v2.00
  1170	[    5.137532] meson-drm ff900000.vpu: CVBS Output connector not available
  1171	[    5.159682] Registered IR keymap rc-odroid
  1172	[    5.164007] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
  1173	[    5.167007] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
  1174	[    5.167506] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
  1175	[    5.168025] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 1
  1176	[    5.168131] meson-drm ff900000.vpu: [drm] Cannot find any crtc or sizes
  1177	[    5.173264] IR NEC protocol handler initialized
  1178	[    5.199703] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0
  1179	[    5.199910] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
  1180	[    5.200042] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input0
  1181	[    5.200314] meson-ir ff808000.ir: receiver initialized
  1182	[    5.214937] axg-sound-card sound: ASoC: no DMI vendor name!
  1183	[    5.231924] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  1184	[    5.851616] Adding 1859860k swap on /dev/zram0.  Priority:5 extents:1 across:1859860k SSFS
  1185	[    5.922836] zram1: detected capacity change from 0 to 52428800
  1186	[    8.016287] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
  1187	[    8.016306] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
  1188	[    8.892906] systemd[1]: Started Armbian memory supported logging.
  1189	[    8.897091] systemd[1]: Starting Journal Service...
  1190	[    8.951421] systemd[1]: Started Journal Service.
  1191	[    8.972762] systemd-journald[2003]: Received request to flush runtime journal from PID 1
  1192
  1193	### armbian-release:
  1194
  1195	# PLEASE DO NOT EDIT THIS FILE
  1196	BOARD=odroidn2
  1197	BOARD_NAME="Odroid N2"
  1198	BOARDFAMILY=meson-g12b
  1199	BUILD_REPOSITORY_URL=https://github.com/armbian/build
  1200	BUILD_REPOSITORY_COMMIT=5f03d652
  1201	DISTRIBUTION_CODENAME=buster
  1202	DISTRIBUTION_STATUS=supported
  1203	VERSION=21.02.1
  1204	LINUXFAMILY=meson64
  1205	BRANCH=current
  1206	ARCH=arm64
  1207	IMAGE_TYPE=stable
  1208	BOARD_TYPE=conf
  1209	INITRD_ARCH=arm64
  1210	KERNEL_IMAGE_TYPE=Image
  1211
  1212	### boot environment:
  1213
  1214	verbosity=1
  1215	console=both
  1216	overlay_prefix=meson
  1217	rootdev=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c
  1218	rootfstype=ext4
  1219	usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
  1220
  1221	### lsusb:
  1222
  1223	Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc.
  1224	Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  1225	Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
  1226	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  1227
  1228	### lscpu:
  1229
  1230	Architecture:        aarch64
  1231	Byte Order:          Little Endian
  1232	CPU(s):              6
  1233	On-line CPU(s) list: 0-5
  1234	Thread(s) per core:  1
  1235	Core(s) per socket:  3
  1236	Socket(s):           2
  1237	NUMA node(s):        1
  1238	Vendor ID:           ARM
  1239	Model:               4
  1240	Model name:          Cortex-A53
  1241	Stepping:            r0p4
  1242	CPU max MHz:         1992.0000
  1243	CPU min MHz:         100.0000
  1244	BogoMIPS:            48.00
  1245	L1d cache:           unknown size
  1246	L1i cache:           unknown size
  1247	L2 cache:            unknown size
  1248	NUMA node0 CPU(s):   0-5
  1249	Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1250
  1251	### cpuinfo:
  1252
  1253	processor	: 0
  1254	BogoMIPS	: 48.00
  1255	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1256	CPU implementer	: 0x41
  1257	CPU architecture: 8
  1258	CPU variant	: 0x0
  1259	CPU part	: 0xd03
  1260	CPU revision	: 4
  1261
  1262	processor	: 1
  1263	BogoMIPS	: 48.00
  1264	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1265	CPU implementer	: 0x41
  1266	CPU architecture: 8
  1267	CPU variant	: 0x0
  1268	CPU part	: 0xd03
  1269	CPU revision	: 4
  1270
  1271	processor	: 2
  1272	BogoMIPS	: 48.00
  1273	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1274	CPU implementer	: 0x41
  1275	CPU architecture: 8
  1276	CPU variant	: 0x0
  1277	CPU part	: 0xd09
  1278	CPU revision	: 2
  1279
  1280	processor	: 3
  1281	BogoMIPS	: 48.00
  1282	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1283	CPU implementer	: 0x41
  1284	CPU architecture: 8
  1285	CPU variant	: 0x0
  1286	CPU part	: 0xd09
  1287	CPU revision	: 2
  1288
  1289	processor	: 4
  1290	BogoMIPS	: 48.00
  1291	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1292	CPU implementer	: 0x41
  1293	CPU architecture: 8
  1294	CPU variant	: 0x0
  1295	CPU part	: 0xd09
  1296	CPU revision	: 2
  1297
  1298	processor	: 5
  1299	BogoMIPS	: 48.00
  1300	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1301	CPU implementer	: 0x41
  1302	CPU architecture: 8
  1303	CPU variant	: 0x0
  1304	CPU part	: 0xd09
  1305	CPU revision	: 2
  1306
  1307
  1308	### meminfo:
  1309
  1310	MemTotal:        3719728 kB
  1311	MemFree:         3416676 kB
  1312	MemAvailable:    3369584 kB
  1313	Buffers:           10788 kB
  1314	Cached:            43300 kB
  1315	SwapCached:            0 kB
  1316	Active:            29168 kB
  1317	Inactive:         173564 kB
  1318	Active(anon):        204 kB
  1319	Inactive(anon):   153312 kB
  1320	Active(file):      28964 kB
  1321	Inactive(file):    20252 kB
  1322	Unevictable:           0 kB
  1323	Mlocked:               0 kB
  1324	SwapTotal:       1859860 kB
  1325	SwapFree:        1859860 kB
  1326	Dirty:              1192 kB
  1327	Writeback:             0 kB
  1328	AnonPages:        148664 kB
  1329	Mapped:            13340 kB
  1330	Shmem:              4860 kB
  1331	KReclaimable:      13316 kB
  1332	Slab:              39232 kB
  1333	SReclaimable:      13316 kB
  1334	SUnreclaim:        25916 kB
  1335	KernelStack:        2496 kB
  1336	PageTables:         5848 kB
  1337	NFS_Unstable:          0 kB
  1338	Bounce:                0 kB
  1339	WritebackTmp:          0 kB
  1340	CommitLimit:     3719724 kB
  1341	Committed_AS:    4239844 kB
  1342	VmallocTotal:   135290159040 kB
  1343	VmallocUsed:       31360 kB
  1344	VmallocChunk:          0 kB
  1345	Percpu:             1368 kB
  1346	HardwareCorrupted:     0 kB
  1347	AnonHugePages:         0 kB
  1348	ShmemHugePages:        0 kB
  1349	ShmemPmdMapped:        0 kB
  1350	FileHugePages:         0 kB
  1351	FilePmdMapped:         0 kB
  1352	CmaTotal:         917504 kB
  1353	CmaFree:          909824 kB
  1354	HugePages_Total:       0
  1355	HugePages_Free:        0
  1356	HugePages_Rsvd:        0
  1357	HugePages_Surp:        0
  1358	Hugepagesize:       2048 kB
  1359	Hugetlb:               0 kB
  1360
  1361	### virtual memory:
  1362
  1363	vm.admin_reserve_kbytes = 8192
  1364	vm.block_dump = 0
  1365	vm.compaction_proactiveness = 20
  1366	vm.compact_unevictable_allowed = 1
  1367	vm.dirty_background_bytes = 0
  1368	vm.dirty_background_ratio = 10
  1369	vm.dirty_bytes = 0
  1370	vm.dirty_expire_centisecs = 3000
  1371	vm.dirty_ratio = 20
  1372	vm.dirtytime_expire_seconds = 43200
  1373	vm.dirty_writeback_centisecs = 500
  1374	vm.extfrag_threshold = 500
  1375	vm.hugetlb_shm_group = 0
  1376	vm.laptop_mode = 0
  1377	vm.legacy_va_layout = 0
  1378	vm.lowmem_reserve_ratio = 256	256	32	0
  1379	vm.max_map_count = 65530
  1380	vm.memory_failure_early_kill = 0
  1381	vm.memory_failure_recovery = 1
  1382	vm.min_free_kbytes = 45056
  1383	vm.min_slab_ratio = 5
  1384	vm.min_unmapped_ratio = 1
  1385	vm.mmap_min_addr = 4096
  1386	vm.mmap_rnd_bits = 18
  1387	vm.mmap_rnd_compat_bits = 11
  1388	vm.nr_hugepages = 0
  1389	vm.nr_hugepages_mempolicy = 0
  1390	vm.nr_overcommit_hugepages = 0
  1391	vm.numa_stat = 1
  1392	vm.numa_zonelist_order = Node
  1393	vm.oom_dump_tasks = 1
  1394	vm.oom_kill_allocating_task = 0
  1395	vm.overcommit_kbytes = 0
  1396	vm.overcommit_memory = 0
  1397	vm.overcommit_ratio = 50
  1398	vm.page-cluster = 0
  1399	vm.page_lock_unfairness = 5
  1400	vm.panic_on_oom = 0
  1401	vm.percpu_pagelist_fraction = 0
  1402	vm.stat_interval = 1
  1403	vm.swappiness = 100
  1404	vm.user_reserve_kbytes = 115024
  1405	vm.vfs_cache_pressure = 100
  1406	vm.watermark_boost_factor = 15000
  1407	vm.watermark_scale_factor = 10
  1408	vm.zone_reclaim_mode = 0
  1409
  1410	### ip addr:
  1411
  1412	1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  1413	    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  1414	    inet XXX.XXX.0.1/8 scope host lo
  1415	       valid_lft forever preferred_lft forever
  1416	    inet6 ::1/128 scope host
  1417	       valid_lft forever preferred_lft forever
  1418	2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  1419	    link/ether 00:1e:06:42:03:f8 brd ff:ff:ff:ff:ff:ff
  1420
  1421	### partitions:
  1422
  1423	major minor  #blocks  name
  1424
  1425	 179        0   31464960 mmcblk0
  1426	 179        1   31146208 mmcblk0p1
  1427	 252        0    1859864 zram0
  1428	 252        1      51200 zram1
  1429
  1430	### df:
  1431
  1432	udev            1.4G     0  1.4G   0% /dev
  1433	tmpfs           364M  4.9M  359M   2% /run
  1434	/dev/mmcblk0p1   30G  1.6G   28G   6% /
  1435	tmpfs           1.8G     0  1.8G   0% /dev/shm
  1436	tmpfs           5.0M  4.0K  5.0M   1% /run/lock
  1437	tmpfs           1.8G     0  1.8G   0% /sys/fs/cgroup
  1438	tmpfs           1.8G     0  1.8G   0% /tmp
  1439	/dev/zram1       49M  1.2M   44M   3% /var/log
  1440
  1441	### lsblk:
  1442
  1443	NAME        FSTYPE  SIZE MOUNTPOINT UUID
  1444	mmcblk0              30G
  1445	└─mmcblk0p1 ext4   29.7G /          bd34953d-41be-49d6-b1c0-c0c28a5e239c
  1446	zram1                50M /var/log
  1447
  1448	### zramctl:
  1449
  1450	NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
  1451	/dev/zram1 zstd           50M  132K  695B   36K       6 /var/log
  1452	/dev/zram0 lzo-rle       1.8G    4K   74B   12K       6 [SWAP]
  1453
  1454	### mtab:
  1455
  1456	/dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  1457	/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  1458	/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
  1459
  1460	### mmc0:b368 info:
  1461
  1462	               fwrev: 0x0
  1463	              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=CBADS MODALIAS=mmc:block
  1464	                 cid: 6f0303434241445310aa002b4d013b00
  1465	                 rca: 0xb368
  1466	                 csd: 400e005a5b590000f00e7f800a404000
  1467	              manfid: 0x00006f
  1468	                 ocr: 0x00200000
  1469	preferred_erase_size: 2097152
  1470	                type: SD
  1471	               hwrev: 0x1
  1472	                date: 11/2019
  1473	                 dsr: 0x404
  1474	          erase_size: 512
  1475	               oemid: 0x0303
  1476	              serial: 0xaa002b4d
  1477	                 ssr: 00000000000000280402800100fd180a001e00000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  1478	                 scr: 02b5800300000000
  1479	                name: CBADS
  1480
  1481	### Boot system health:
  1482
  1483	Time       big.LITTLE   load %cpu %sys %usr %nice %io %irq   CPU  C.St.
  1484	13:49:21: 1908/1992MHz  2.64  25%  11%   6%   0%   6%   0% 30.2°C  0/11
  1485	13:49:21: 1908/1992MHz  2.67  72%  29%   8%   0%  32%   1% 30.1°C  0/11
  1486	13:49:22: 1908/1992MHz  2.67  89%  14%   0%   0%  72%   0% 27.2°C  0/11
  1487	13:49:22: 1908/1992MHz  2.67  56%  11%   7%   0%  37%   1% 27.4°C  0/11
  1488	13:49:22: 1908/1992MHz  2.67  42%   2%   5%   0%  32%   0% 26.1°C  0/11
  1489
  1490	### Activated 1 lzo-rle zram swap devices with 1816 MB each
  1491
  1492	### Activated Armbian ramlog partition with zstd compression
  1493
  1494	Sun 14 Feb 2021 02:21:27 PM GMT | Odroid N2 | 21.02.1 | arm64 | aarch64 | 5.10.12-meson64
  1495
  1496	### dmesg:
  1497
  1498	[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
  1499	[    0.000000] Linux version 5.10.12-meson64 (root@beast) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #21.02.1 SMP PREEMPT Wed Feb 3 21:06:36 CET 2021
  1500	[    0.000000] Machine model: Hardkernel ODROID-N2
  1501	[    0.000000] efi: UEFI not found.
  1502	[    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
  1503	[    0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB
  1504	[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
  1505	[    0.000000] NUMA: No NUMA configuration found
  1506	[    0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ed7fffff]
  1507	[    0.000000] NUMA: NODE_DATA [mem 0xb502f100-0xb5030fff]
  1508	[    0.000000] Zone ranges:
  1509	[    0.000000]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
  1510	[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000ed7fffff]
  1511	[    0.000000]   Normal   empty
  1512	[    0.000000] Movable zone start for each node
  1513	[    0.000000] Early memory node ranges
  1514	[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000004ffffff]
  1515	[    0.000000]   node   0: [mem 0x0000000005300000-0x00000000ed7fffff]
  1516	[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ed7fffff]
  1517	[    0.000000] On node 0 totalpages: 972032
  1518	[    0.000000]   DMA zone: 4096 pages used for memmap
  1519	[    0.000000]   DMA zone: 0 pages reserved
  1520	[    0.000000]   DMA zone: 261376 pages, LIFO batch:63
  1521	[    0.000000]   DMA32 zone: 11104 pages used for memmap
  1522	[    0.000000]   DMA32 zone: 710656 pages, LIFO batch:63
  1523	[    0.000000] psci: probing for conduit method from DT.
  1524	[    0.000000] psci: PSCIv1.0 detected in firmware.
  1525	[    0.000000] psci: Using standard PSCI v0.2 function IDs
  1526	[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
  1527	[    0.000000] psci: SMC Calling Convention v1.1
  1528	[    0.000000] percpu: Embedded 23 pages/cpu s56728 r8192 d29288 u94208
  1529	[    0.000000] pcpu-alloc: s56728 r8192 d29288 u94208 alloc=23*4096
  1530	[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
  1531	[    0.000000] Detected VIPT I-cache on CPU0
  1532	[    0.000000] CPU features: detected: ARM erratum 845719
  1533	[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 956832
  1534	[    0.000000] Policy zone: DMA32
  1535	[    0.000000] Kernel command line: root=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c rootwait rootfstype=ext4 console=ttyAML0,115200n8 console=tty1 loglevel=1  no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=1080p60hz cvbsmode=576cvbs max_freq_a53=1896 max_freq_a73=1800 maxcpus=6 voutmode=hdmi  disablehpd=false  cvbscable=0 overscan=100 consoleblank=0
  1536	[    0.000000] Kernel parameter elevator= does not have any effect anymore.
  1537	               Please use sysfs to set IO scheduler for individual devices.
  1538	[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
  1539	[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
  1540	[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
  1541	[    0.000000] software IO TLB: mapped [mem 0x0000000038ac5000-0x000000003cac5000] (64MB)
  1542	[    0.000000] Memory: 2785352K/3888128K available (14144K kernel code, 1760K rwdata, 5508K rodata, 3328K init, 592K bss, 185272K reserved, 917504K cma-reserved)
  1543	[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
  1544	[    0.000000] rcu: Preemptible hierarchical RCU implementation.
  1545	[    0.000000] rcu: 	RCU event tracing is enabled.
  1546	[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
  1547	[    0.000000] 	Trampoline variant of Tasks RCU enabled.
  1548	[    0.000000] 	Rude variant of Tasks RCU enabled.
  1549	[    0.000000] 	Tracing variant of Tasks RCU enabled.
  1550	[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  1551	[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
  1552	[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
  1553	[    0.000000] GIC: Using split EOI/Deactivate mode
  1554	[    0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized
  1555	[    0.000000] random: get_random_bytes called from start_kernel+0x378/0x538 with crng_init=0
  1556	[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
  1557	[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  1558	[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  1559	[    0.000248] Console: colour dummy device 80x25
  1560	[    0.000281] printk: console [tty1] enabled
  1561	[    0.000367] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
  1562	[    0.000379] pid_max: default: 32768 minimum: 301
  1563	[    0.000462] LSM: Security Framework initializing
  1564	[    0.000488] Yama: becoming mindful.
  1565	[    0.000579] AppArmor: AppArmor initialized
  1566	[    0.000628] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
  1567	[    0.000646] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
  1568	[    0.002635] rcu: Hierarchical SRCU implementation.
  1569	[    0.005093] EFI services will not be available.
  1570	[    0.005514] smp: Bringing up secondary CPUs ...
  1571	[    0.006185] Detected VIPT I-cache on CPU1
  1572	[    0.006246] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
  1573	[    0.007441] CPU features: detected: ARM erratum 858921
  1574	[    0.007449] CPU features: detected: Spectre-v2
  1575	[    0.007452] CPU features: detected: Spectre-v4
  1576	[    0.007458] Detected VIPT I-cache on CPU2
  1577	[    0.007484] arch_timer: Enabling local workaround for ARM erratum 858921
  1578	[    0.007498] arch_timer: CPU2: Trapping CNTVCT access
  1579	[    0.007511] CPU2: Booted secondary processor 0x0000000100 [0x410fd092]
  1580	[    0.008218] Detected VIPT I-cache on CPU3
  1581	[    0.008234] arch_timer: Enabling local workaround for ARM erratum 858921
  1582	[    0.008241] arch_timer: CPU3: Trapping CNTVCT access
  1583	[    0.008249] CPU3: Booted secondary processor 0x0000000101 [0x410fd092]
  1584	[    0.008874] Detected VIPT I-cache on CPU4
  1585	[    0.008890] arch_timer: Enabling local workaround for ARM erratum 858921
  1586	[    0.008897] arch_timer: CPU4: Trapping CNTVCT access
  1587	[    0.008905] CPU4: Booted secondary processor 0x0000000102 [0x410fd092]
  1588	[    0.009521] Detected VIPT I-cache on CPU5
  1589	[    0.009537] arch_timer: Enabling local workaround for ARM erratum 858921
  1590	[    0.009543] arch_timer: CPU5: Trapping CNTVCT access
  1591	[    0.009551] CPU5: Booted secondary processor 0x0000000103 [0x410fd092]
  1592	[    0.009631] smp: Brought up 1 node, 6 CPUs
  1593	[    0.009648] SMP: Total of 6 processors activated.
  1594	[    0.009656] CPU features: detected: 32-bit EL0 Support
  1595	[    0.009661] CPU features: detected: CRC32 instructions
  1596	[    0.009667] CPU features: detected: 32-bit EL1 Support
  1597	[    0.020878] CPU: All CPU(s) started at EL2
  1598	[    0.020928] alternatives: patching kernel code
  1599	[    0.022869] devtmpfs: initialized
  1600	[    0.030524] Registered cp15_barrier emulation handler
  1601	[    0.030538] Registered setend emulation handler
  1602	[    0.030676] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  1603	[    0.030715] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
  1604	[    0.044634] pinctrl core: initialized pinctrl subsystem
  1605	[    0.045376] DMI not present or invalid.
  1606	[    0.045741] NET: Registered protocol family 16
  1607	[    0.047214] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
  1608	[    0.047487] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
  1609	[    0.047713] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
  1610	[    0.047759] audit: initializing netlink subsys (disabled)
  1611	[    0.047868] audit: type=2000 audit(0.044:1): state=initialized audit_enabled=0 res=1
  1612	[    0.049244] thermal_sys: Registered thermal governor 'fair_share'
  1613	[    0.049251] thermal_sys: Registered thermal governor 'bang_bang'
  1614	[    0.049255] thermal_sys: Registered thermal governor 'step_wise'
  1615	[    0.049258] thermal_sys: Registered thermal governor 'user_space'
  1616	[    0.049681] cpuidle: using governor menu
  1617	[    0.050015] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  1618	[    0.050134] ASID allocator initialised with 65536 entries
  1619	[    0.051090] Serial: AMBA PL011 UART driver
  1620	[    0.085603] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
  1621	[    0.085613] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
  1622	[    0.085618] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
  1623	[    0.085622] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
  1624	[    0.087982] cryptd: max_cpu_qlen set to 1000
  1625	[    0.156200] raid6: neonx8   gen()  2785 MB/s
  1626	[    0.224264] raid6: neonx8   xor()  2042 MB/s
  1627	[    0.292356] raid6: neonx4   gen()  2996 MB/s
  1628	[    0.360400] raid6: neonx4   xor()  2399 MB/s
  1629	[    0.428472] raid6: neonx2   gen()  2560 MB/s
  1630	[    0.496543] raid6: neonx2   xor()  2201 MB/s
  1631	[    0.564605] raid6: neonx1   gen()  2089 MB/s
  1632	[    0.632663] raid6: neonx1   xor()  1726 MB/s
  1633	[    0.700739] raid6: int64x8  gen()  1375 MB/s
  1634	[    0.768802] raid6: int64x8  xor()   735 MB/s
  1635	[    0.836875] raid6: int64x4  gen()  1462 MB/s
  1636	[    0.904938] raid6: int64x4  xor()   733 MB/s
  1637	[    0.973008] raid6: int64x2  gen()  1363 MB/s
  1638	[    1.041073] raid6: int64x2  xor()   619 MB/s
  1639	[    1.109139] raid6: int64x1  gen()  1120 MB/s
  1640	[    1.177191] raid6: int64x1  xor()   462 MB/s
  1641	[    1.177195] raid6: using algorithm neonx4 gen() 2996 MB/s
  1642	[    1.177198] raid6: .... xor() 2399 MB/s, rmw enabled
  1643	[    1.177202] raid6: using neon recovery algorithm
  1644	[    1.177648] ACPI: Interpreter disabled.
  1645	[    1.178429] 5V: supplied by 12V
  1646	[    1.179312] VDDAO_3V3: supplied by 12V
  1647	[    1.179848] iommu: Default domain type: Translated
  1648	[    1.179973] vgaarb: loaded
  1649	[    1.180753] SCSI subsystem initialized
  1650	[    1.181084] usbcore: registered new interface driver usbfs
  1651	[    1.181120] usbcore: registered new interface driver hub
  1652	[    1.181161] usbcore: registered new device driver usb
  1653	[    1.181458] pps_core: LinuxPPS API ver. 1 registered
  1654	[    1.181464] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  1655	[    1.181527] PTP clock support registered
  1656	[    1.181712] EDAC MC: Ver: 3.0.0
  1657	[    1.183023] NetLabel: Initializing
  1658	[    1.183031] NetLabel:  domain hash size = 128
  1659	[    1.183034] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
  1660	[    1.183076] NetLabel:  unlabeled traffic allowed by default
  1661	[    1.183524] clocksource: Switched to clocksource arch_sys_counter
  1662	[    1.183739] VFS: Disk quotas dquot_6.6.0
  1663	[    1.183783] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  1664	[    1.184130] AppArmor: AppArmor Filesystem Enabled
  1665	[    1.184174] pnp: PnP ACPI: disabled
  1666	[    1.189511] NET: Registered protocol family 2
  1667	[    1.189972] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
  1668	[    1.190080] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
  1669	[    1.190337] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
  1670	[    1.190524] TCP: Hash tables configured (established 32768 bind 32768)
  1671	[    1.190686] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
  1672	[    1.190751] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
  1673	[    1.190798] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
  1674	[    1.190939] NET: Registered protocol family 1
  1675	[    1.190963] PCI: CLS 0 bytes, default 64
  1676	[    1.191102] Trying to unpack rootfs image as initramfs...
  1677	[    1.727357] Freeing initrd memory: 13544K
  1678	[    1.728312] kvm [1]: IPA Size Limit: 40 bits
  1679	[    1.729018] kvm [1]: vgic interrupt IRQ9
  1680	[    1.729152] kvm [1]: Hyp mode initialized successfully
  1681	[    1.733060] Initialise system trusted keyrings
  1682	[    1.733095] Key type blacklist registered
  1683	[    1.733185] workingset: timestamp_bits=44 max_order=20 bucket_order=0
  1684	[    1.736382] zbud: loaded
  1685	[    1.737370] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  1686	[    1.737808] fuse: init (API version 7.32)
  1687	[    1.738561] integrity: Platform Keyring initialized
  1688	[    1.766290] xor: measuring software checksum speed
  1689	[    1.769139]    8regs           :  3473 MB/sec
  1690	[    1.771594]    32regs          :  4023 MB/sec
  1691	[    1.774243]    arm64_neon      :  3719 MB/sec
  1692	[    1.774246] xor: using function: 32regs (4023 MB/sec)
  1693	[    1.774252] Key type asymmetric registered
  1694	[    1.774256] Asymmetric key parser 'x509' registered
  1695	[    1.774289] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
  1696	[    1.774374] io scheduler mq-deadline registered
  1697	[    1.774378] io scheduler kyber registered
  1698	[    1.774460] io scheduler bfq registered
  1699	[    1.777006] gpio-447 (usb-hub-reset): hogged as output/high
  1700	[    1.779963] EINJ: ACPI disabled.
  1701	[    1.786084] soc soc0: Amlogic Meson G12B (S922X) Revision 29:a (40:2) Detected
  1702	[    1.787552] VCC_3V3: supplied by VDDAO_3V3
  1703	[    1.787591] FLASH_1V8: supplied by VCC_3V3
  1704	[    1.787623] VCC_1V8: supplied by VCC_3V3
  1705	[    1.787652] VDDAO_1V8: supplied by VDDAO_3V3
  1706	[    1.787684] VDDCPU_A: supplied by regulator-dummy
  1707	[    1.788061] VDDCPU_B: supplied by regulator-dummy
  1708	[    1.788721] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
  1709	[    1.790944] Serial: AMBA driver
  1710	[    1.791225] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart
  1711	[    1.791320] printk: console [ttyAML0] enabled
  1712	[    1.791898] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 33, base_baud = 1500000) is a meson_uart
  1713	[    1.797441] loop: module loaded
  1714	[    1.799285] libphy: Fixed MDIO Bus: probed
  1715	[    1.800293] tun: Universal TUN/TAP device driver, 1.6
  1716	[    1.800978] thunder_xcv, ver 1.0
  1717	[    1.801006] thunder_bgx, ver 1.0
  1718	[    1.801031] nicpf, ver 1.0
  1719	[    1.801495] e1000e: Intel(R) PRO/1000 Network Driver
  1720	[    1.801499] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
  1721	[    1.801537] igb: Intel(R) Gigabit Ethernet Network Driver
  1722	[    1.801540] igb: Copyright (c) 2007-2014 Intel Corporation.
  1723	[    1.801575] igbvf: Intel(R) Gigabit Virtual Function Network Driver
  1724	[    1.801578] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
  1725	[    1.801711] sky2: driver version 1.30
  1726	[    1.802097] VFIO - User Level meta-driver version: 0.3
  1727	[    1.803537] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  1728	[    1.803557] ehci-pci: EHCI PCI platform driver
  1729	[    1.803599] ehci-platform: EHCI generic platform driver
  1730	[    1.803741] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  1731	[    1.803752] ohci-pci: OHCI PCI platform driver
  1732	[    1.803784] ohci-platform: OHCI generic platform driver
  1733	[    1.804203] usbcore: registered new interface driver usb-storage
  1734	[    1.805542] mousedev: PS/2 mouse device common for all mice
  1735	[    1.805924] i2c /dev entries driver
  1736	[    1.811056] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17
  1737	[    1.811734] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz
  1738	[    1.812418] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-1 failed:-17
  1739	[    1.812983] sdhci: Secure Digital Host Controller Interface driver
  1740	[    1.812990] sdhci: Copyright(c) Pierre Ossman
  1741	[    1.813103] Synopsys Designware Multimedia Card Interface Driver
  1742	[    1.813542] sdhci-pltfm: SDHCI platform and OF driver helper
  1743	[    1.813979] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq
  1744	[    1.814328] ledtrig-cpu: registered to indicate activity on CPUs
  1745	[    1.814572] meson-sm: secure-monitor enabled
  1746	[    1.814854] hid: raw HID events driver (C) Jiri Kosina
  1747	[    1.814937] usbcore: registered new interface driver usbhid
  1748	[    1.814939] usbhid: USB HID core driver
  1749	[    1.816060] NET: Registered protocol family 10
  1750	[    1.816473] Segment Routing with IPv6
  1751	[    1.816502] NET: Registered protocol family 17
  1752	[    1.816550] 8021q: 802.1Q VLAN Support v1.8
  1753	[    1.816577] Key type dns_resolver registered
  1754	[    1.816852] registered taskstats version 1
  1755	[    1.816857] Loading compiled-in X.509 certificates
  1756	[    1.818528] Loaded X.509 cert 'Build time autogenerated kernel key: f47c178852ca39740c3546b008122b65f5ed9bce'
  1757	[    1.820272] zswap: loaded using pool zstd/z3fold
  1758	[    1.820479] Key type ._fscrypt registered
  1759	[    1.820482] Key type .fscrypt registered
  1760	[    1.820483] Key type fscrypt-provisioning registered
  1761	[    1.821569] Btrfs loaded, crc32c=crc32c-generic
  1762	[    1.828127] Key type encrypted registered
  1763	[    1.828137] AppArmor: AppArmor sha1 policy hashing enabled
  1764	[    1.834358] HUB_5V: supplied by 5V
  1765	[    1.834542] USB_PWR_EN: supplied by 5V
  1766	[    1.836235] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2
  1767	[    1.836242] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1
  1768	[    1.838910] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator
  1769	[    1.838960] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator
  1770	[    1.839064] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM
  1771	[    1.839822] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  1772	[    1.839837] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
  1773	[    1.839930] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010
  1774	[    1.839957] xhci-hcd xhci-hcd.0.auto: irq 41, io mem 0xff500000
  1775	[    1.840081] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
  1776	[    1.840085] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1777	[    1.840088] usb usb1: Product: xHCI Host Controller
  1778	[    1.840090] usb usb1: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
  1779	[    1.840092] usb usb1: SerialNumber: xhci-hcd.0.auto
  1780	[    1.840288] hub 1-0:1.0: USB hub found
  1781	[    1.840305] hub 1-0:1.0: 2 ports detected
  1782	[    1.840434] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  1783	[    1.840440] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  1784	[    1.840446] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  1785	[    1.840466] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
  1786	[    1.840500] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
  1787	[    1.840503] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1788	[    1.840506] usb usb2: Product: xHCI Host Controller
  1789	[    1.840508] usb usb2: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
  1790	[    1.840510] usb usb2: SerialNumber: xhci-hcd.0.auto
  1791	[    1.840662] hub 2-0:1.0: USB hub found
  1792	[    1.840672] hub 2-0:1.0: 1 port detected
  1793	[    1.841004] dwc3-meson-g12a ffe09000.usb: switching to Device Mode
  1794	[    1.842292] meson-gx-mmc ffe05000.sd: Got CD GPIO
  1795	[    1.868624] Freeing unused kernel memory: 3328K
  1796	[    1.919586] Run /init as init process
  1797	[    1.919590]   with arguments:
  1798	[    1.919592]     /init
  1799	[    1.919594]   with environment:
  1800	[    1.919596]     HOME=/
  1801	[    1.919598]     TERM=linux
  1802	[    1.919599]     hdmimode=1080p60hz
  1803	[    1.919601]     cvbsmode=576cvbs
  1804	[    1.919602]     max_freq_a53=1896
  1805	[    1.919604]     max_freq_a73=1800
  1806	[    1.919605]     voutmode=hdmi
  1807	[    1.919607]     disablehpd=false
  1808	[    1.919608]     cvbscable=0
  1809	[    1.919610]     overscan=100
  1810	[    1.933670] mmc0: new ultra high speed SDR25 SDHC card at address b368
  1811	[    1.934167] mmcblk0: mmc0:b368 CBADS 30.0 GiB
  1812	[    1.936098]  mmcblk0: p1
  1813	[    2.063676] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found
  1814	[    2.063683] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found
  1815	[    2.063772] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock
  1816	[    2.064204] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37
  1817	[    2.064216] meson8b-dwmac ff3f0000.ethernet: 	DWMAC1000
  1818	[    2.064221] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported
  1819	[    2.064225] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported
  1820	[    2.064228] meson8b-dwmac ff3f0000.ethernet: COE Type 2
  1821	[    2.064231] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported
  1822	[    2.064234] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported
  1823	[    2.064325] meson8b-dwmac ff3f0000.ethernet: Normal descriptors
  1824	[    2.064330] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled
  1825	[    2.064334] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
  1826	[    2.064727] libphy: stmmac: probed
  1827	[    2.068832] libphy: mdio_mux: probed
  1828	[    2.079912] meson-vrtc ff8000a8.rtc: registered as rtc1
  1829	[    2.100057] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
  1830	[    2.100670] rtc-pcf8563 1-0051: registered as rtc0
  1831	[    2.101194] random: fast init done
  1832	[    2.102287] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
  1833	[    2.102297] rtc-pcf8563 1-0051: hctosys: unable to read the hardware clock
  1834	[    2.179550] usb 1-1: new high-speed USB device number 2 using xhci-hcd
  1835	[    2.276200] libphy: mdio_mux: probed
  1836	[    2.329903] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.04
  1837	[    2.329913] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  1838	[    2.329916] usb 1-1: Product: USB2.1 Hub
  1839	[    2.329920] usb 1-1: Manufacturer: GenesysLogic
  1840	[    2.384743] hub 1-1:1.0: USB hub found
  1841	[    2.384995] hub 1-1:1.0: 4 ports detected
  1842	[    2.455658] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
  1843	[    2.478125] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.04
  1844	[    2.478130] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  1845	[    2.478134] usb 2-1: Product: USB3.1 Hub
  1846	[    2.478137] usb 2-1: Manufacturer: GenesysLogic
  1847	[    2.496729] hub 2-1:1.0: USB hub found
  1848	[    2.497025] hub 2-1:1.0: 4 ports detected
  1849	[    2.888047] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
  1850	[    3.687484] systemd[1]: System time before build time, advancing clock.
  1851	[    3.702349] systemd[1]: Inserted module 'autofs4'
  1852	[    3.752905] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  1853	[    3.753281] systemd[1]: Detected architecture arm64.
  1854	[    3.802404] systemd[1]: Set hostname to <odroidn2>.
  1855	[    4.205191] random: systemd: uninitialized urandom read (16 bytes read)
  1856	[    4.210804] random: systemd: uninitialized urandom read (16 bytes read)
  1857	[    4.212610] systemd[1]: Created slice User and Session Slice.
  1858	[    4.212994] random: systemd: uninitialized urandom read (16 bytes read)
  1859	[    4.213466] systemd[1]: Listening on Journal Socket (/dev/log).
  1860	[    4.213741] systemd[1]: Reached target System Time Synchronized.
  1861	[    4.214153] systemd[1]: Listening on initctl Compatibility Named Pipe.
  1862	[    4.214831] systemd[1]: Listening on Journal Audit Socket.
  1863	[    4.215272] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
  1864	[    4.217149] systemd[1]: Created slice system-serial\x2dgetty.slice.
  1865	[    4.306635] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
  1866	[    4.817571] zram: Added device: zram0
  1867	[    4.817766] zram: Added device: zram1
  1868	[    4.817950] zram: Added device: zram2
  1869	[    4.847427] pwm-gpio pwmgpio: 1 gpio pwms loaded
  1870	[    5.019977] mc: Linux media interface: v0.10
  1871	[    5.045560] panfrost ffe40000.gpu: clock rate = 24000000
  1872	[    5.045621] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19
  1873	[    5.050858] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0
  1874	[    5.050866] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400
  1875	[    5.050870] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
  1876	[    5.050873] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1
  1877	[    5.065393] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 0
  1878	[    5.072117] meson-saradc ff809000.adc: supply vref not found, using dummy regulator
  1879	[    5.089900] videodev: Linux video capture interface: v2.00
  1880	[    5.131142] meson-drm ff900000.vpu: Queued 2 outputs on vpu
  1881	[    5.152243] Registered IR keymap rc-odroid
  1882	[    5.182759] IR NEC protocol handler initialized
  1883	[    5.188475] meson-drm ff900000.vpu: CVBS Output connector not available
  1884	[    5.211613] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0
  1885	[    5.211698] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
  1886	[    5.211766] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input0
  1887	[    5.213741] meson-ir ff808000.ir: receiver initialized
  1888	[    5.218778] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
  1889	[    5.223849] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
  1890	[    5.224101] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
  1891	[    5.224332] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 1
  1892	[    5.224391] meson-drm ff900000.vpu: [drm] Cannot find any crtc or sizes
  1893	[    5.227002] zram0: detected capacity change from 0 to 1904500736
  1894	[    5.267118] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  1895	[    5.274065] axg-sound-card sound: ASoC: no DMI vendor name!
  1896	[    6.291536] Adding 1859860k swap on /dev/zram0.  Priority:5 extents:1 across:1859860k SSFS
  1897	[    6.355170] zram1: detected capacity change from 0 to 52428800
  1898	[    8.439310] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
  1899	[    8.439328] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
  1900	[    9.355810] systemd[1]: Started Armbian memory supported logging.
  1901	[    9.358066] systemd[1]: Starting Journal Service...
  1902	[    9.414026] systemd[1]: Started Journal Service.
  1903	[    9.438714] systemd-journald[1816]: Received request to flush runtime journal from PID 1
  1904
  1905	### armbian-release:
  1906
  1907	# PLEASE DO NOT EDIT THIS FILE
  1908	BOARD=odroidn2
  1909	BOARD_NAME="Odroid N2"
  1910	BOARDFAMILY=meson-g12b
  1911	BUILD_REPOSITORY_URL=https://github.com/armbian/build
  1912	BUILD_REPOSITORY_COMMIT=5f03d652
  1913	DISTRIBUTION_CODENAME=buster
  1914	DISTRIBUTION_STATUS=supported
  1915	VERSION=21.02.1
  1916	LINUXFAMILY=meson64
  1917	BRANCH=current
  1918	ARCH=arm64
  1919	IMAGE_TYPE=stable
  1920	BOARD_TYPE=conf
  1921	INITRD_ARCH=arm64
  1922	KERNEL_IMAGE_TYPE=Image
  1923
  1924	### boot environment:
  1925
  1926	verbosity=1
  1927	console=both
  1928	overlay_prefix=meson
  1929	rootdev=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c
  1930	rootfstype=ext4
  1931	usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
  1932
  1933	### lsusb:
  1934
  1935	Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc.
  1936	Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  1937	Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
  1938	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  1939
  1940	### lscpu:
  1941
  1942	Architecture:        aarch64
  1943	Byte Order:          Little Endian
  1944	CPU(s):              6
  1945	On-line CPU(s) list: 0-5
  1946	Thread(s) per core:  1
  1947	Core(s) per socket:  3
  1948	Socket(s):           2
  1949	NUMA node(s):        1
  1950	Vendor ID:           ARM
  1951	Model:               4
  1952	Model name:          Cortex-A53
  1953	Stepping:            r0p4
  1954	CPU max MHz:         1992.0000
  1955	CPU min MHz:         100.0000
  1956	BogoMIPS:            48.00
  1957	L1d cache:           unknown size
  1958	L1i cache:           unknown size
  1959	L2 cache:            unknown size
  1960	NUMA node0 CPU(s):   0-5
  1961	Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1962
  1963	### cpuinfo:
  1964
  1965	processor	: 0
  1966	BogoMIPS	: 48.00
  1967	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1968	CPU implementer	: 0x41
  1969	CPU architecture: 8
  1970	CPU variant	: 0x0
  1971	CPU part	: 0xd03
  1972	CPU revision	: 4
  1973
  1974	processor	: 1
  1975	BogoMIPS	: 48.00
  1976	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1977	CPU implementer	: 0x41
  1978	CPU architecture: 8
  1979	CPU variant	: 0x0
  1980	CPU part	: 0xd03
  1981	CPU revision	: 4
  1982
  1983	processor	: 2
  1984	BogoMIPS	: 48.00
  1985	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1986	CPU implementer	: 0x41
  1987	CPU architecture: 8
  1988	CPU variant	: 0x0
  1989	CPU part	: 0xd09
  1990	CPU revision	: 2
  1991
  1992	processor	: 3
  1993	BogoMIPS	: 48.00
  1994	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1995	CPU implementer	: 0x41
  1996	CPU architecture: 8
  1997	CPU variant	: 0x0
  1998	CPU part	: 0xd09
  1999	CPU revision	: 2
  2000
  2001	processor	: 4
  2002	BogoMIPS	: 48.00
  2003	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  2004	CPU implementer	: 0x41
  2005	CPU architecture: 8
  2006	CPU variant	: 0x0
  2007	CPU part	: 0xd09
  2008	CPU revision	: 2
  2009
  2010	processor	: 5
  2011	BogoMIPS	: 48.00
  2012	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  2013	CPU implementer	: 0x41
  2014	CPU architecture: 8
  2015	CPU variant	: 0x0
  2016	CPU part	: 0xd09
  2017	CPU revision	: 2
  2018
  2019
  2020	### meminfo:
  2021
  2022	MemTotal:        3719728 kB
  2023	MemFree:         3429232 kB
  2024	MemAvailable:    3380928 kB
  2025	Buffers:           11812 kB
  2026	Cached:            40512 kB
  2027	SwapCached:            0 kB
  2028	Active:            30404 kB
  2029	Inactive:         161468 kB
  2030	Active(anon):         92 kB
  2031	Inactive(anon):   144464 kB
  2032	Active(file):      30312 kB
  2033	Inactive(file):    17004 kB
  2034	Unevictable:           0 kB
  2035	Mlocked:               0 kB
  2036	SwapTotal:       1859860 kB
  2037	SwapFree:        1859860 kB
  2038	Dirty:              1580 kB
  2039	Writeback:             0 kB
  2040	AnonPages:        139692 kB
  2041	Mapped:            11016 kB
  2042	Shmem:              4864 kB
  2043	KReclaimable:      12792 kB
  2044	Slab:              38804 kB
  2045	SReclaimable:      12792 kB
  2046	SUnreclaim:        26012 kB
  2047	KernelStack:        2112 kB
  2048	PageTables:         3960 kB
  2049	NFS_Unstable:          0 kB
  2050	Bounce:                0 kB
  2051	WritebackTmp:          0 kB
  2052	CommitLimit:     3719724 kB
  2053	Committed_AS:    4210540 kB
  2054	VmallocTotal:   135290159040 kB
  2055	VmallocUsed:       30928 kB
  2056	VmallocChunk:          0 kB
  2057	Percpu:             1368 kB
  2058	HardwareCorrupted:     0 kB
  2059	AnonHugePages:     40960 kB
  2060	ShmemHugePages:        0 kB
  2061	ShmemPmdMapped:        0 kB
  2062	FileHugePages:         0 kB
  2063	FilePmdMapped:         0 kB
  2064	CmaTotal:         917504 kB
  2065	CmaFree:          909824 kB
  2066	HugePages_Total:       0
  2067	HugePages_Free:        0
  2068	HugePages_Rsvd:        0
  2069	HugePages_Surp:        0
  2070	Hugepagesize:       2048 kB
  2071	Hugetlb:               0 kB
  2072
  2073	### virtual memory:
  2074
  2075	vm.admin_reserve_kbytes = 8192
  2076	vm.block_dump = 0
  2077	vm.compaction_proactiveness = 20
  2078	vm.compact_unevictable_allowed = 1
  2079	vm.dirty_background_bytes = 0
  2080	vm.dirty_background_ratio = 10
  2081	vm.dirty_bytes = 0
  2082	vm.dirty_expire_centisecs = 3000
  2083	vm.dirty_ratio = 20
  2084	vm.dirtytime_expire_seconds = 43200
  2085	vm.dirty_writeback_centisecs = 500
  2086	vm.extfrag_threshold = 500
  2087	vm.hugetlb_shm_group = 0
  2088	vm.laptop_mode = 0
  2089	vm.legacy_va_layout = 0
  2090	vm.lowmem_reserve_ratio = 256	256	32	0
  2091	vm.max_map_count = 65530
  2092	vm.memory_failure_early_kill = 0
  2093	vm.memory_failure_recovery = 1
  2094	vm.min_free_kbytes = 45056
  2095	vm.min_slab_ratio = 5
  2096	vm.min_unmapped_ratio = 1
  2097	vm.mmap_min_addr = 4096
  2098	vm.mmap_rnd_bits = 18
  2099	vm.mmap_rnd_compat_bits = 11
  2100	vm.nr_hugepages = 0
  2101	vm.nr_hugepages_mempolicy = 0
  2102	vm.nr_overcommit_hugepages = 0
  2103	vm.numa_stat = 1
  2104	vm.numa_zonelist_order = Node
  2105	vm.oom_dump_tasks = 1
  2106	vm.oom_kill_allocating_task = 0
  2107	vm.overcommit_kbytes = 0
  2108	vm.overcommit_memory = 0
  2109	vm.overcommit_ratio = 50
  2110	vm.page-cluster = 0
  2111	vm.page_lock_unfairness = 5
  2112	vm.panic_on_oom = 0
  2113	vm.percpu_pagelist_fraction = 0
  2114	vm.stat_interval = 1
  2115	vm.swappiness = 100
  2116	vm.user_reserve_kbytes = 115020
  2117	vm.vfs_cache_pressure = 100
  2118	vm.watermark_boost_factor = 15000
  2119	vm.watermark_scale_factor = 10
  2120	vm.zone_reclaim_mode = 0
  2121
  2122	### ip addr:
  2123
  2124	1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  2125	    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  2126	    inet XXX.XXX.0.1/8 scope host lo
  2127	       valid_lft forever preferred_lft forever
  2128	    inet6 ::1/128 scope host
  2129	       valid_lft forever preferred_lft forever
  2130	2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  2131	    link/ether 00:1e:06:42:03:f8 brd ff:ff:ff:ff:ff:ff
  2132
  2133	### partitions:
  2134
  2135	major minor  #blocks  name
  2136
  2137	 179        0   31464960 mmcblk0
  2138	 179        1   31146208 mmcblk0p1
  2139	 252        0    1859864 zram0
  2140	 252        1      51200 zram1
  2141
  2142	### df:
  2143
  2144	udev            1.4G     0  1.4G   0% /dev
  2145	tmpfs           364M  4.9M  359M   2% /run
  2146	/dev/mmcblk0p1   30G  1.7G   28G   6% /
  2147	tmpfs           1.8G     0  1.8G   0% /dev/shm
  2148	tmpfs           5.0M  4.0K  5.0M   1% /run/lock
  2149	tmpfs           1.8G     0  1.8G   0% /sys/fs/cgroup
  2150	tmpfs           1.8G     0  1.8G   0% /tmp
  2151	/dev/zram1       49M  1.6M   44M   4% /var/log
  2152
  2153	### lsblk:
  2154
  2155	NAME        FSTYPE  SIZE MOUNTPOINT UUID
  2156	mmcblk0              30G
  2157	└─mmcblk0p1 ext4   29.7G /          bd34953d-41be-49d6-b1c0-c0c28a5e239c
  2158	zram1                50M /var/log
  2159
  2160	### zramctl:
  2161
  2162	NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
  2163	/dev/zram1 zstd           50M  132K  698B   36K       6 /var/log
  2164	/dev/zram0 lzo-rle       1.8G    4K   74B   12K       6 [SWAP]
  2165
  2166	### mtab:
  2167
  2168	/dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  2169	/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  2170	/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
  2171
  2172	### mmc0:b368 info:
  2173
  2174	               fwrev: 0x0
  2175	              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=CBADS MODALIAS=mmc:block
  2176	                 cid: 6f0303434241445310aa002b4d013b00
  2177	                 rca: 0xb368
  2178	                 csd: 400e005a5b590000f00e7f800a404000
  2179	              manfid: 0x00006f
  2180	                 ocr: 0x00200000
  2181	preferred_erase_size: 2097152
  2182	                type: SD
  2183	               hwrev: 0x1
  2184	                date: 11/2019
  2185	                 dsr: 0x404
  2186	          erase_size: 512
  2187	               oemid: 0x0303
  2188	              serial: 0xaa002b4d
  2189	                 ssr: 00000000000000280402800100fd180a001e00000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  2190	                 scr: 02b5800300000000
  2191	                name: CBADS
  2192
  2193	### Boot system health:
  2194
  2195	Time       big.LITTLE   load %cpu %sys %usr %nice %io %irq   CPU  C.St.
  2196	14:21:28: 1908/1992MHz  2.75  23%  11%   5%   0%   6%   0% 34.1°C  0/11
  2197	14:21:28: 1908/1992MHz  2.75  87%  26%   7%   0%  51%   1% 33.1°C  0/11
  2198	14:21:28: 1908/1992MHz  2.75  76%   9%   1%   0%  63%   0% 30.2°C  0/11
  2199	14:21:29: 1908/1992MHz  2.75  57%   7%   9%   0%  38%   1% 30.4°C  0/11
  2200	14:21:29: 1908/1992MHz  2.75  33%   2%   2%   0%  27%   1% 29.9°C  0/11
  2201
  2202	### Activated 1 lzo-rle zram swap devices with 1816 MB each
  2203
  2204	### Activated Armbian ramlog partition with zstd compression
  2205
  2206	Sun 14 Feb 2021 02:26:36 PM GMT | Odroid N2 | 21.02.1 | arm64 | aarch64 | 5.10.12-meson64
  2207
  2208	### dmesg:
  2209
  2210	[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
  2211	[    0.000000] Linux version 5.10.12-meson64 (root@beast) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #21.02.1 SMP PREEMPT Wed Feb 3 21:06:36 CET 2021
  2212	[    0.000000] Machine model: Hardkernel ODROID-N2
  2213	[    0.000000] efi: UEFI not found.
  2214	[    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
  2215	[    0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB
  2216	[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
  2217	[    0.000000] NUMA: No NUMA configuration found
  2218	[    0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ed7fffff]
  2219	[    0.000000] NUMA: NODE_DATA [mem 0xb502f100-0xb5030fff]
  2220	[    0.000000] Zone ranges:
  2221	[    0.000000]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
  2222	[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000ed7fffff]
  2223	[    0.000000]   Normal   empty
  2224	[    0.000000] Movable zone start for each node
  2225	[    0.000000] Early memory node ranges
  2226	[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000004ffffff]
  2227	[    0.000000]   node   0: [mem 0x0000000005300000-0x00000000ed7fffff]
  2228	[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ed7fffff]
  2229	[    0.000000] On node 0 totalpages: 972032
  2230	[    0.000000]   DMA zone: 4096 pages used for memmap
  2231	[    0.000000]   DMA zone: 0 pages reserved
  2232	[    0.000000]   DMA zone: 261376 pages, LIFO batch:63
  2233	[    0.000000]   DMA32 zone: 11104 pages used for memmap
  2234	[    0.000000]   DMA32 zone: 710656 pages, LIFO batch:63
  2235	[    0.000000] psci: probing for conduit method from DT.
  2236	[    0.000000] psci: PSCIv1.0 detected in firmware.
  2237	[    0.000000] psci: Using standard PSCI v0.2 function IDs
  2238	[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
  2239	[    0.000000] psci: SMC Calling Convention v1.1
  2240	[    0.000000] percpu: Embedded 23 pages/cpu s56728 r8192 d29288 u94208
  2241	[    0.000000] pcpu-alloc: s56728 r8192 d29288 u94208 alloc=23*4096
  2242	[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
  2243	[    0.000000] Detected VIPT I-cache on CPU0
  2244	[    0.000000] CPU features: detected: ARM erratum 845719
  2245	[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 956832
  2246	[    0.000000] Policy zone: DMA32
  2247	[    0.000000] Kernel command line: root=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c rootwait rootfstype=ext4 console=ttyAML0,115200n8 console=tty1 loglevel=1  no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=1080p60hz cvbsmode=576cvbs max_freq_a53=1896 max_freq_a73=1800 maxcpus=6 voutmode=hdmi  disablehpd=false  cvbscable=0 overscan=100 consoleblank=0
  2248	[    0.000000] Kernel parameter elevator= does not have any effect anymore.
  2249	               Please use sysfs to set IO scheduler for individual devices.
  2250	[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
  2251	[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
  2252	[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
  2253	[    0.000000] software IO TLB: mapped [mem 0x0000000038ac5000-0x000000003cac5000] (64MB)
  2254	[    0.000000] Memory: 2785352K/3888128K available (14144K kernel code, 1760K rwdata, 5508K rodata, 3328K init, 592K bss, 185272K reserved, 917504K cma-reserved)
  2255	[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
  2256	[    0.000000] rcu: Preemptible hierarchical RCU implementation.
  2257	[    0.000000] rcu: 	RCU event tracing is enabled.
  2258	[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
  2259	[    0.000000] 	Trampoline variant of Tasks RCU enabled.
  2260	[    0.000000] 	Rude variant of Tasks RCU enabled.
  2261	[    0.000000] 	Tracing variant of Tasks RCU enabled.
  2262	[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  2263	[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
  2264	[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
  2265	[    0.000000] GIC: Using split EOI/Deactivate mode
  2266	[    0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized
  2267	[    0.000000] random: get_random_bytes called from start_kernel+0x378/0x538 with crng_init=0
  2268	[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
  2269	[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  2270	[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  2271	[    0.000248] Console: colour dummy device 80x25
  2272	[    0.000283] printk: console [tty1] enabled
  2273	[    0.000372] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
  2274	[    0.000384] pid_max: default: 32768 minimum: 301
  2275	[    0.000467] LSM: Security Framework initializing
  2276	[    0.000492] Yama: becoming mindful.
  2277	[    0.000584] AppArmor: AppArmor initialized
  2278	[    0.000635] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
  2279	[    0.000654] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
  2280	[    0.002643] rcu: Hierarchical SRCU implementation.
  2281	[    0.005115] EFI services will not be available.
  2282	[    0.005530] smp: Bringing up secondary CPUs ...
  2283	[    0.006202] Detected VIPT I-cache on CPU1
  2284	[    0.006263] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
  2285	[    0.007456] CPU features: detected: ARM erratum 858921
  2286	[    0.007464] CPU features: detected: Spectre-v2
  2287	[    0.007467] CPU features: detected: Spectre-v4
  2288	[    0.007474] Detected VIPT I-cache on CPU2
  2289	[    0.007498] arch_timer: Enabling local workaround for ARM erratum 858921
  2290	[    0.007513] arch_timer: CPU2: Trapping CNTVCT access
  2291	[    0.007525] CPU2: Booted secondary processor 0x0000000100 [0x410fd092]
  2292	[    0.008233] Detected VIPT I-cache on CPU3
  2293	[    0.008249] arch_timer: Enabling local workaround for ARM erratum 858921
  2294	[    0.008256] arch_timer: CPU3: Trapping CNTVCT access
  2295	[    0.008264] CPU3: Booted secondary processor 0x0000000101 [0x410fd092]
  2296	[    0.008888] Detected VIPT I-cache on CPU4
  2297	[    0.008904] arch_timer: Enabling local workaround for ARM erratum 858921
  2298	[    0.008911] arch_timer: CPU4: Trapping CNTVCT access
  2299	[    0.008918] CPU4: Booted secondary processor 0x0000000102 [0x410fd092]
  2300	[    0.009532] Detected VIPT I-cache on CPU5
  2301	[    0.009549] arch_timer: Enabling local workaround for ARM erratum 858921
  2302	[    0.009555] arch_timer: CPU5: Trapping CNTVCT access
  2303	[    0.009563] CPU5: Booted secondary processor 0x0000000103 [0x410fd092]
  2304	[    0.009644] smp: Brought up 1 node, 6 CPUs
  2305	[    0.009661] SMP: Total of 6 processors activated.
  2306	[    0.009668] CPU features: detected: 32-bit EL0 Support
  2307	[    0.009674] CPU features: detected: CRC32 instructions
  2308	[    0.009680] CPU features: detected: 32-bit EL1 Support
  2309	[    0.020923] CPU: All CPU(s) started at EL2
  2310	[    0.020971] alternatives: patching kernel code
  2311	[    0.022901] devtmpfs: initialized
  2312	[    0.030528] Registered cp15_barrier emulation handler
  2313	[    0.030543] Registered setend emulation handler
  2314	[    0.030705] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  2315	[    0.030749] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
  2316	[    0.044681] pinctrl core: initialized pinctrl subsystem
  2317	[    0.045427] DMI not present or invalid.
  2318	[    0.045791] NET: Registered protocol family 16
  2319	[    0.047282] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
  2320	[    0.047555] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
  2321	[    0.047780] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
  2322	[    0.047824] audit: initializing netlink subsys (disabled)
  2323	[    0.047941] audit: type=2000 audit(0.044:1): state=initialized audit_enabled=0 res=1
  2324	[    0.049235] thermal_sys: Registered thermal governor 'fair_share'
  2325	[    0.049242] thermal_sys: Registered thermal governor 'bang_bang'
  2326	[    0.049246] thermal_sys: Registered thermal governor 'step_wise'
  2327	[    0.049250] thermal_sys: Registered thermal governor 'user_space'
  2328	[    0.049658] cpuidle: using governor menu
  2329	[    0.050002] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  2330	[    0.050122] ASID allocator initialised with 65536 entries
  2331	[    0.051074] Serial: AMBA PL011 UART driver
  2332	[    0.085694] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
  2333	[    0.085736] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
  2334	[    0.085742] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
  2335	[    0.085746] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
  2336	[    0.087315] cryptd: max_cpu_qlen set to 1000
  2337	[    0.156198] raid6: neonx8   gen()  2781 MB/s
  2338	[    0.224258] raid6: neonx8   xor()  2042 MB/s
  2339	[    0.292347] raid6: neonx4   gen()  2996 MB/s
  2340	[    0.360392] raid6: neonx4   xor()  2399 MB/s
  2341	[    0.428458] raid6: neonx2   gen()  2537 MB/s
  2342	[    0.496524] raid6: neonx2   xor()  2200 MB/s
  2343	[    0.564613] raid6: neonx1   gen()  2063 MB/s
  2344	[    0.632658] raid6: neonx1   xor()  1726 MB/s
  2345	[    0.700731] raid6: int64x8  gen()  1380 MB/s
  2346	[    0.768793] raid6: int64x8  xor()   735 MB/s
  2347	[    0.836880] raid6: int64x4  gen()  1463 MB/s
  2348	[    0.904921] raid6: int64x4  xor()   732 MB/s
  2349	[    0.972991] raid6: int64x2  gen()  1362 MB/s
  2350	[    1.041067] raid6: int64x2  xor()   619 MB/s
  2351	[    1.109131] raid6: int64x1  gen()  1120 MB/s
  2352	[    1.177204] raid6: int64x1  xor()   462 MB/s
  2353	[    1.177208] raid6: using algorithm neonx4 gen() 2996 MB/s
  2354	[    1.177211] raid6: .... xor() 2399 MB/s, rmw enabled
  2355	[    1.177215] raid6: using neon recovery algorithm
  2356	[    1.177672] ACPI: Interpreter disabled.
  2357	[    1.178469] 5V: supplied by 12V
  2358	[    1.179349] VDDAO_3V3: supplied by 12V
  2359	[    1.179850] iommu: Default domain type: Translated
  2360	[    1.179962] vgaarb: loaded
  2361	[    1.180723] SCSI subsystem initialized
  2362	[    1.181070] usbcore: registered new interface driver usbfs
  2363	[    1.181107] usbcore: registered new interface driver hub
  2364	[    1.181143] usbcore: registered new device driver usb
  2365	[    1.181403] pps_core: LinuxPPS API ver. 1 registered
  2366	[    1.181408] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  2367	[    1.181424] PTP clock support registered
  2368	[    1.181613] EDAC MC: Ver: 3.0.0
  2369	[    1.182969] NetLabel: Initializing
  2370	[    1.182977] NetLabel:  domain hash size = 128
  2371	[    1.182980] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
  2372	[    1.183022] NetLabel:  unlabeled traffic allowed by default
  2373	[    1.183445] clocksource: Switched to clocksource arch_sys_counter
  2374	[    1.183653] VFS: Disk quotas dquot_6.6.0
  2375	[    1.183698] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  2376	[    1.184069] AppArmor: AppArmor Filesystem Enabled
  2377	[    1.184116] pnp: PnP ACPI: disabled
  2378	[    1.189322] NET: Registered protocol family 2
  2379	[    1.189781] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
  2380	[    1.189888] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
  2381	[    1.190144] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
  2382	[    1.190330] TCP: Hash tables configured (established 32768 bind 32768)
  2383	[    1.190479] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
  2384	[    1.190542] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
  2385	[    1.190593] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
  2386	[    1.190734] NET: Registered protocol family 1
  2387	[    1.190754] PCI: CLS 0 bytes, default 64
  2388	[    1.190886] Trying to unpack rootfs image as initramfs...
  2389	[    1.726467] Freeing initrd memory: 13544K
  2390	[    1.727429] kvm [1]: IPA Size Limit: 40 bits
  2391	[    1.728165] kvm [1]: vgic interrupt IRQ9
  2392	[    1.728308] kvm [1]: Hyp mode initialized successfully
  2393	[    1.732193] Initialise system trusted keyrings
  2394	[    1.732226] Key type blacklist registered
  2395	[    1.732356] workingset: timestamp_bits=44 max_order=20 bucket_order=0
  2396	[    1.735536] zbud: loaded
  2397	[    1.736530] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  2398	[    1.736967] fuse: init (API version 7.32)
  2399	[    1.737722] integrity: Platform Keyring initialized
  2400	[    1.765393] xor: measuring software checksum speed
  2401	[    1.768241]    8regs           :  3473 MB/sec
  2402	[    1.770690]    32regs          :  4023 MB/sec
  2403	[    1.773345]    arm64_neon      :  3719 MB/sec
  2404	[    1.773349] xor: using function: 32regs (4023 MB/sec)
  2405	[    1.773355] Key type asymmetric registered
  2406	[    1.773359] Asymmetric key parser 'x509' registered
  2407	[    1.773391] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
  2408	[    1.773488] io scheduler mq-deadline registered
  2409	[    1.773492] io scheduler kyber registered
  2410	[    1.773578] io scheduler bfq registered
  2411	[    1.776138] gpio-447 (usb-hub-reset): hogged as output/high
  2412	[    1.779087] EINJ: ACPI disabled.
  2413	[    1.785290] soc soc0: Amlogic Meson G12B (S922X) Revision 29:a (40:2) Detected
  2414	[    1.786665] VCC_3V3: supplied by VDDAO_3V3
  2415	[    1.786699] FLASH_1V8: supplied by VCC_3V3
  2416	[    1.786729] VCC_1V8: supplied by VCC_3V3
  2417	[    1.786763] VDDAO_1V8: supplied by VDDAO_3V3
  2418	[    1.786803] VDDCPU_A: supplied by regulator-dummy
  2419	[    1.787151] VDDCPU_B: supplied by regulator-dummy
  2420	[    1.787891] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
  2421	[    1.790109] Serial: AMBA driver
  2422	[    1.790400] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart
  2423	[    1.790496] printk: console [ttyAML0] enabled
  2424	[    1.791026] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 33, base_baud = 1500000) is a meson_uart
  2425	[    1.796529] loop: module loaded
  2426	[    1.798461] libphy: Fixed MDIO Bus: probed
  2427	[    1.799406] tun: Universal TUN/TAP device driver, 1.6
  2428	[    1.800115] thunder_xcv, ver 1.0
  2429	[    1.800148] thunder_bgx, ver 1.0
  2430	[    1.800174] nicpf, ver 1.0
  2431	[    1.800654] e1000e: Intel(R) PRO/1000 Network Driver
  2432	[    1.800658] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
  2433	[    1.800700] igb: Intel(R) Gigabit Ethernet Network Driver
  2434	[    1.800703] igb: Copyright (c) 2007-2014 Intel Corporation.
  2435	[    1.800736] igbvf: Intel(R) Gigabit Virtual Function Network Driver
  2436	[    1.800739] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
  2437	[    1.800868] sky2: driver version 1.30
  2438	[    1.801232] VFIO - User Level meta-driver version: 0.3
  2439	[    1.802638] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  2440	[    1.802659] ehci-pci: EHCI PCI platform driver
  2441	[    1.802693] ehci-platform: EHCI generic platform driver
  2442	[    1.802829] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  2443	[    1.802839] ohci-pci: OHCI PCI platform driver
  2444	[    1.802871] ohci-platform: OHCI generic platform driver
  2445	[    1.803293] usbcore: registered new interface driver usb-storage
  2446	[    1.804660] mousedev: PS/2 mouse device common for all mice
  2447	[    1.805058] i2c /dev entries driver
  2448	[    1.810242] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17
  2449	[    1.810896] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz
  2450	[    1.811582] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-1 failed:-17
  2451	[    1.812174] sdhci: Secure Digital Host Controller Interface driver
  2452	[    1.812179] sdhci: Copyright(c) Pierre Ossman
  2453	[    1.812274] Synopsys Designware Multimedia Card Interface Driver
  2454	[    1.812713] sdhci-pltfm: SDHCI platform and OF driver helper
  2455	[    1.813157] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq
  2456	[    1.813545] ledtrig-cpu: registered to indicate activity on CPUs
  2457	[    1.813793] meson-sm: secure-monitor enabled
  2458	[    1.814085] hid: raw HID events driver (C) Jiri Kosina
  2459	[    1.814169] usbcore: registered new interface driver usbhid
  2460	[    1.814171] usbhid: USB HID core driver
  2461	[    1.815230] NET: Registered protocol family 10
  2462	[    1.816040] Segment Routing with IPv6
  2463	[    1.816073] NET: Registered protocol family 17
  2464	[    1.816130] 8021q: 802.1Q VLAN Support v1.8
  2465	[    1.816153] Key type dns_resolver registered
  2466	[    1.816430] registered taskstats version 1
  2467	[    1.816435] Loading compiled-in X.509 certificates
  2468	[    1.818154] Loaded X.509 cert 'Build time autogenerated kernel key: f47c178852ca39740c3546b008122b65f5ed9bce'
  2469	[    1.819992] zswap: loaded using pool zstd/z3fold
  2470	[    1.820157] Key type ._fscrypt registered
  2471	[    1.820160] Key type .fscrypt registered
  2472	[    1.820162] Key type fscrypt-provisioning registered
  2473	[    1.821237] Btrfs loaded, crc32c=crc32c-generic
  2474	[    1.827100] Key type encrypted registered
  2475	[    1.827111] AppArmor: AppArmor sha1 policy hashing enabled
  2476	[    1.833334] HUB_5V: supplied by 5V
  2477	[    1.833567] USB_PWR_EN: supplied by 5V
  2478	[    1.835212] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2
  2479	[    1.835218] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1
  2480	[    1.837895] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator
  2481	[    1.837952] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator
  2482	[    1.838058] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM
  2483	[    1.838630] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  2484	[    1.838642] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
  2485	[    1.838726] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010
  2486	[    1.838747] xhci-hcd xhci-hcd.0.auto: irq 41, io mem 0xff500000
  2487	[    1.838871] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
  2488	[    1.838874] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  2489	[    1.838877] usb usb1: Product: xHCI Host Controller
  2490	[    1.838880] usb usb1: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
  2491	[    1.838882] usb usb1: SerialNumber: xhci-hcd.0.auto
  2492	[    1.839070] hub 1-0:1.0: USB hub found
  2493	[    1.839084] hub 1-0:1.0: 2 ports detected
  2494	[    1.839212] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  2495	[    1.839218] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  2496	[    1.839223] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  2497	[    1.839244] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
  2498	[    1.839275] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
  2499	[    1.839278] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  2500	[    1.839281] usb usb2: Product: xHCI Host Controller
  2501	[    1.839283] usb usb2: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
  2502	[    1.839285] usb usb2: SerialNumber: xhci-hcd.0.auto
  2503	[    1.839699] hub 2-0:1.0: USB hub found
  2504	[    1.839712] hub 2-0:1.0: 1 port detected
  2505	[    1.839976] dwc3-meson-g12a ffe09000.usb: switching to Device Mode
  2506	[    1.840822] meson-gx-mmc ffe05000.sd: Got CD GPIO
  2507	[    1.868115] Freeing unused kernel memory: 3328K
  2508	[    1.891526] Run /init as init process
  2509	[    1.891531]   with arguments:
  2510	[    1.891533]     /init
  2511	[    1.891535]   with environment:
  2512	[    1.891537]     HOME=/
  2513	[    1.891539]     TERM=linux
  2514	[    1.891541]     hdmimode=1080p60hz
  2515	[    1.891542]     cvbsmode=576cvbs
  2516	[    1.891543]     max_freq_a53=1896
  2517	[    1.891545]     max_freq_a73=1800
  2518	[    1.891546]     voutmode=hdmi
  2519	[    1.891548]     disablehpd=false
  2520	[    1.891549]     cvbscable=0
  2521	[    1.891551]     overscan=100
  2522	[    1.918960] mmc0: new high speed SDHC card at address b368
  2523	[    1.920163] mmcblk0: mmc0:b368 CBADS 30.0 GiB
  2524	[    1.922030]  mmcblk0: p1
  2525	[    2.045499] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found
  2526	[    2.045507] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found
  2527	[    2.045627] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock
  2528	[    2.046211] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37
  2529	[    2.046225] meson8b-dwmac ff3f0000.ethernet: 	DWMAC1000
  2530	[    2.046229] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported
  2531	[    2.046232] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported
  2532	[    2.046235] meson8b-dwmac ff3f0000.ethernet: COE Type 2
  2533	[    2.046238] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported
  2534	[    2.046240] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported
  2535	[    2.046343] meson8b-dwmac ff3f0000.ethernet: Normal descriptors
  2536	[    2.046348] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled
  2537	[    2.046351] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
  2538	[    2.046654] libphy: stmmac: probed
  2539	[    2.048234] libphy: mdio_mux: probed
  2540	[    2.063245] meson-vrtc ff8000a8.rtc: registered as rtc1
  2541	[    2.082036] rtc-pcf8563 1-0051: registered as rtc0
  2542	[    2.082518] random: fast init done
  2543	[    2.083316] rtc-pcf8563 1-0051: setting system clock to 2021-02-14T14:26:29 UTC (1613312789)
  2544	[    2.171465] usb 1-1: new high-speed USB device number 2 using xhci-hcd
  2545	[    2.251922] libphy: mdio_mux: probed
  2546	[    2.321886] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.04
  2547	[    2.321896] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  2548	[    2.321900] usb 1-1: Product: USB2.1 Hub
  2549	[    2.321903] usb 1-1: Manufacturer: GenesysLogic
  2550	[    2.383528] hub 1-1:1.0: USB hub found
  2551	[    2.383759] hub 1-1:1.0: 4 ports detected
  2552	[    2.447559] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
  2553	[    2.470059] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.04
  2554	[    2.470068] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  2555	[    2.470071] usb 2-1: Product: USB3.1 Hub
  2556	[    2.470075] usb 2-1: Manufacturer: GenesysLogic
  2557	[    2.495526] hub 2-1:1.0: USB hub found
  2558	[    2.495822] hub 2-1:1.0: 4 ports detected
  2559	[    2.737853] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
  2560	[    3.554447] systemd[1]: Inserted module 'autofs4'
  2561	[    3.600937] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  2562	[    3.601164] systemd[1]: Detected architecture arm64.
  2563	[    3.625325] systemd[1]: Set hostname to <odroidn2>.
  2564	[    4.026501] random: systemd: uninitialized urandom read (16 bytes read)
  2565	[    4.032435] random: systemd: uninitialized urandom read (16 bytes read)
  2566	[    4.032672] systemd[1]: Listening on initctl Compatibility Named Pipe.
  2567	[    4.033175] random: systemd: uninitialized urandom read (16 bytes read)
  2568	[    4.035609] systemd[1]: Created slice system-getty.slice.
  2569	[    4.035911] systemd[1]: Reached target System Time Synchronized.
  2570	[    4.036527] systemd[1]: Listening on Journal Socket (/dev/log).
  2571	[    4.037253] systemd[1]: Listening on Journal Audit Socket.
  2572	[    4.037940] systemd[1]: Listening on Journal Socket.
  2573	[    4.041609] systemd[1]: Starting Restore / save the current clock...
  2574	[    4.086641] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
  2575	[    4.609923] zram: Added device: zram0
  2576	[    4.610108] zram: Added device: zram1
  2577	[    4.610291] zram: Added device: zram2
  2578	[    4.698972] pwm-gpio pwmgpio: 1 gpio pwms loaded
  2579	[    4.853474] meson-saradc ff809000.adc: supply vref not found, using dummy regulator
  2580	[    4.871591] mc: Linux media interface: v0.10
  2581	[    4.971900] Registered IR keymap rc-odroid
  2582	[    4.973016] videodev: Linux video capture interface: v2.00
  2583	[    4.978038] meson-drm ff900000.vpu: Queued 2 outputs on vpu
  2584	[    4.986191] IR NEC protocol handler initialized
  2585	[    4.987935] zram0: detected capacity change from 0 to 1904500736
  2586	[    5.015624] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0
  2587	[    5.015765] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
  2588	[    5.015825] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input0
  2589	[    5.016589] meson-ir ff808000.ir: receiver initialized
  2590	[    5.023205] meson-drm ff900000.vpu: CVBS Output connector not available
  2591	[    5.056762] panfrost ffe40000.gpu: clock rate = 24000000
  2592	[    5.056839] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19
  2593	[    5.057853] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0
  2594	[    5.057861] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400
  2595	[    5.057865] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
  2596	[    5.057868] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1
  2597	[    5.060396] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
  2598	[    5.063804] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
  2599	[    5.064438] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
  2600	[    5.066271] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 0
  2601	[    5.067438] meson-drm ff900000.vpu: [drm] Cannot find any crtc or sizes
  2602	[    5.072759] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 1
  2603	[    5.101541] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  2604	[    5.127988] axg-sound-card sound: ASoC: no DMI vendor name!
  2605	[    6.051465] Adding 1859860k swap on /dev/zram0.  Priority:5 extents:1 across:1859860k SSFS
  2606	[    6.114369] zram1: detected capacity change from 0 to 52428800
  2607	[    8.199985] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
  2608	[    8.200004] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
  2609	[    9.134113] systemd[1]: Started Armbian memory supported logging.
  2610	[    9.138216] systemd[1]: Starting Journal Service...
  2611	[    9.194616] systemd[1]: Started Journal Service.
  2612	[    9.222654] systemd-journald[1814]: Received request to flush runtime journal from PID 1
  2613
  2614	### armbian-release:
  2615
  2616	# PLEASE DO NOT EDIT THIS FILE
  2617	BOARD=odroidn2
  2618	BOARD_NAME="Odroid N2"
  2619	BOARDFAMILY=meson-g12b
  2620	BUILD_REPOSITORY_URL=https://github.com/armbian/build
  2621	BUILD_REPOSITORY_COMMIT=5f03d652
  2622	DISTRIBUTION_CODENAME=buster
  2623	DISTRIBUTION_STATUS=supported
  2624	VERSION=21.02.1
  2625	LINUXFAMILY=meson64
  2626	BRANCH=current
  2627	ARCH=arm64
  2628	IMAGE_TYPE=stable
  2629	BOARD_TYPE=conf
  2630	INITRD_ARCH=arm64
  2631	KERNEL_IMAGE_TYPE=Image
  2632
  2633	### boot environment:
  2634
  2635	verbosity=1
  2636	console=both
  2637	overlay_prefix=meson
  2638	rootdev=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c
  2639	rootfstype=ext4
  2640	usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
  2641
  2642	### lsusb:
  2643
  2644	Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc.
  2645	Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  2646	Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
  2647	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  2648
  2649	### lscpu:
  2650
  2651	Architecture:        aarch64
  2652	Byte Order:          Little Endian
  2653	CPU(s):              6
  2654	On-line CPU(s) list: 0-5
  2655	Thread(s) per core:  1
  2656	Core(s) per socket:  3
  2657	Socket(s):           2
  2658	NUMA node(s):        1
  2659	Vendor ID:           ARM
  2660	Model:               4
  2661	Model name:          Cortex-A53
  2662	Stepping:            r0p4
  2663	CPU max MHz:         1992.0000
  2664	CPU min MHz:         100.0000
  2665	BogoMIPS:            48.00
  2666	L1d cache:           unknown size
  2667	L1i cache:           unknown size
  2668	L2 cache:            unknown size
  2669	NUMA node0 CPU(s):   0-5
  2670	Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  2671
  2672	### cpuinfo:
  2673
  2674	processor	: 0
  2675	BogoMIPS	: 48.00
  2676	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  2677	CPU implementer	: 0x41
  2678	CPU architecture: 8
  2679	CPU variant	: 0x0
  2680	CPU part	: 0xd03
  2681	CPU revision	: 4
  2682
  2683	processor	: 1
  2684	BogoMIPS	: 48.00
  2685	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  2686	CPU implementer	: 0x41
  2687	CPU architecture: 8
  2688	CPU variant	: 0x0
  2689	CPU part	: 0xd03
  2690	CPU revision	: 4
  2691
  2692	processor	: 2
  2693	BogoMIPS	: 48.00
  2694	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  2695	CPU implementer	: 0x41
  2696	CPU architecture: 8
  2697	CPU variant	: 0x0
  2698	CPU part	: 0xd09
  2699	CPU revision	: 2
  2700
  2701	processor	: 3
  2702	BogoMIPS	: 48.00
  2703	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  2704	CPU implementer	: 0x41
  2705	CPU architecture: 8
  2706	CPU variant	: 0x0
  2707	CPU part	: 0xd09
  2708	CPU revision	: 2
  2709
  2710	processor	: 4
  2711	BogoMIPS	: 48.00
  2712	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  2713	CPU implementer	: 0x41
  2714	CPU architecture: 8
  2715	CPU variant	: 0x0
  2716	CPU part	: 0xd09
  2717	CPU revision	: 2
  2718
  2719	processor	: 5
  2720	BogoMIPS	: 48.00
  2721	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  2722	CPU implementer	: 0x41
  2723	CPU architecture: 8
  2724	CPU variant	: 0x0
  2725	CPU part	: 0xd09
  2726	CPU revision	: 2
  2727
  2728
  2729	### meminfo:
  2730
  2731	MemTotal:        3719728 kB
  2732	MemFree:         3418672 kB
  2733	MemAvailable:    3370612 kB
  2734	Buffers:           11672 kB
  2735	Cached:            40796 kB
  2736	SwapCached:            0 kB
  2737	Active:            29504 kB
  2738	Inactive:         172620 kB
  2739	Active(anon):        112 kB
  2740	Inactive(anon):   154400 kB
  2741	Active(file):      29392 kB
  2742	Inactive(file):    18220 kB
  2743	Unevictable:           0 kB
  2744	Mlocked:               0 kB
  2745	SwapTotal:       1859860 kB
  2746	SwapFree:        1859860 kB
  2747	Dirty:              1764 kB
  2748	Writeback:             0 kB
  2749	AnonPages:        149692 kB
  2750	Mapped:            11044 kB
  2751	Shmem:              4860 kB
  2752	KReclaimable:      12984 kB
  2753	Slab:              38516 kB
  2754	SReclaimable:      12984 kB
  2755	SUnreclaim:        25532 kB
  2756	KernelStack:        2112 kB
  2757	PageTables:         5820 kB
  2758	NFS_Unstable:          0 kB
  2759	Bounce:                0 kB
  2760	WritebackTmp:          0 kB
  2761	CommitLimit:     3719724 kB
  2762	Committed_AS:    4210340 kB
  2763	VmallocTotal:   135290159040 kB
  2764	VmallocUsed:       30880 kB
  2765	VmallocChunk:          0 kB
  2766	Percpu:             1368 kB
  2767	HardwareCorrupted:     0 kB
  2768	AnonHugePages:     40960 kB
  2769	ShmemHugePages:        0 kB
  2770	ShmemPmdMapped:        0 kB
  2771	FileHugePages:         0 kB
  2772	FilePmdMapped:         0 kB
  2773	CmaTotal:         917504 kB
  2774	CmaFree:          909824 kB
  2775	HugePages_Total:       0
  2776	HugePages_Free:        0
  2777	HugePages_Rsvd:        0
  2778	HugePages_Surp:        0
  2779	Hugepagesize:       2048 kB
  2780	Hugetlb:               0 kB
  2781
  2782	### virtual memory:
  2783
  2784	vm.admin_reserve_kbytes = 8192
  2785	vm.block_dump = 0
  2786	vm.compaction_proactiveness = 20
  2787	vm.compact_unevictable_allowed = 1
  2788	vm.dirty_background_bytes = 0
  2789	vm.dirty_background_ratio = 10
  2790	vm.dirty_bytes = 0
  2791	vm.dirty_expire_centisecs = 3000
  2792	vm.dirty_ratio = 20
  2793	vm.dirtytime_expire_seconds = 43200
  2794	vm.dirty_writeback_centisecs = 500
  2795	vm.extfrag_threshold = 500
  2796	vm.hugetlb_shm_group = 0
  2797	vm.laptop_mode = 0
  2798	vm.legacy_va_layout = 0
  2799	vm.lowmem_reserve_ratio = 256	256	32	0
  2800	vm.max_map_count = 65530
  2801	vm.memory_failure_early_kill = 0
  2802	vm.memory_failure_recovery = 1
  2803	vm.min_free_kbytes = 45056
  2804	vm.min_slab_ratio = 5
  2805	vm.min_unmapped_ratio = 1
  2806	vm.mmap_min_addr = 4096
  2807	vm.mmap_rnd_bits = 18
  2808	vm.mmap_rnd_compat_bits = 11
  2809	vm.nr_hugepages = 0
  2810	vm.nr_hugepages_mempolicy = 0
  2811	vm.nr_overcommit_hugepages = 0
  2812	vm.numa_stat = 1
  2813	vm.numa_zonelist_order = Node
  2814	vm.oom_dump_tasks = 1
  2815	vm.oom_kill_allocating_task = 0
  2816	vm.overcommit_kbytes = 0
  2817	vm.overcommit_memory = 0
  2818	vm.overcommit_ratio = 50
  2819	vm.page-cluster = 0
  2820	vm.page_lock_unfairness = 5
  2821	vm.panic_on_oom = 0
  2822	vm.percpu_pagelist_fraction = 0
  2823	vm.stat_interval = 1
  2824	vm.swappiness = 100
  2825	vm.user_reserve_kbytes = 115067
  2826	vm.vfs_cache_pressure = 100
  2827	vm.watermark_boost_factor = 15000
  2828	vm.watermark_scale_factor = 10
  2829	vm.zone_reclaim_mode = 0
  2830
  2831	### ip addr:
  2832
  2833	1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  2834	    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  2835	    inet XXX.XXX.0.1/8 scope host lo
  2836	       valid_lft forever preferred_lft forever
  2837	    inet6 ::1/128 scope host
  2838	       valid_lft forever preferred_lft forever
  2839	2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  2840	    link/ether 00:1e:06:42:03:f8 brd ff:ff:ff:ff:ff:ff
  2841
  2842	### partitions:
  2843
  2844	major minor  #blocks  name
  2845
  2846	 179        0   31464960 mmcblk0
  2847	 179        1   31146208 mmcblk0p1
  2848	 252        0    1859864 zram0
  2849	 252        1      51200 zram1
  2850
  2851	### df:
  2852
  2853	udev            1.4G     0  1.4G   0% /dev
  2854	tmpfs           364M  4.9M  359M   2% /run
  2855	/dev/mmcblk0p1   30G  1.7G   28G   6% /
  2856	tmpfs           1.8G     0  1.8G   0% /dev/shm
  2857	tmpfs           5.0M  4.0K  5.0M   1% /run/lock
  2858	tmpfs           1.8G     0  1.8G   0% /sys/fs/cgroup
  2859	tmpfs           1.8G     0  1.8G   0% /tmp
  2860	/dev/zram1       49M  1.8M   44M   4% /var/log
  2861
  2862	### lsblk:
  2863
  2864	NAME        FSTYPE  SIZE MOUNTPOINT UUID
  2865	mmcblk0              30G
  2866	└─mmcblk0p1 ext4   29.7G /          bd34953d-41be-49d6-b1c0-c0c28a5e239c
  2867	zram1                50M /var/log
  2868
  2869	### zramctl:
  2870
  2871	NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
  2872	/dev/zram1 zstd           50M  132K  698B   36K       6 /var/log
  2873	/dev/zram0 lzo-rle       1.8G    4K   74B   12K       6 [SWAP]
  2874
  2875	### mtab:
  2876
  2877	/dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  2878	/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  2879	/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
  2880
  2881	### mmc0:b368 info:
  2882
  2883	               fwrev: 0x0
  2884	              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=CBADS MODALIAS=mmc:block
  2885	                 cid: 6f0303434241445310aa002b4d013b00
  2886	                 rca: 0xb368
  2887	                 csd: 400e005a5b590000f00e7f800a404000
  2888	              manfid: 0x00006f
  2889	                 ocr: 0x00200000
  2890	preferred_erase_size: 2097152
  2891	                type: SD
  2892	               hwrev: 0x1
  2893	                date: 11/2019
  2894	                 dsr: 0x404
  2895	          erase_size: 512
  2896	               oemid: 0x0303
  2897	              serial: 0xaa002b4d
  2898	                 ssr: 00000000000000280402800100fd180a001e00000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  2899	                 scr: 02b5800300000000
  2900	                name: CBADS
  2901
  2902	### Boot system health:
  2903
  2904	Time       big.LITTLE   load %cpu %sys %usr %nice %io %irq   CPU  C.St.
  2905	14:26:38: 1908/1992MHz  2.60  26%  12%   5%   0%   8%   0% 32.0°C  0/11
  2906	14:26:38: 1908/1992MHz  2.60  74%  14%   9%   0%  48%   1% 30.6°C  0/11
  2907	14:26:38: 1908/1992MHz  2.60  60%   2%   2%   1%  55%   0% 29.6°C  0/11
  2908	14:26:39: 1908/1992MHz  2.60  58%   3%   3%   0%  51%   0% 29.7°C  0/11
  2909	14:26:39: 1908/1992MHz  2.60  47%   3%   4%   0%  38%   0% 29.5°C  0/11
  2910
  2911	### Activated 1 lzo-rle zram swap devices with 1816 MB each
  2912
  2913	### Activated Armbian ramlog partition with zstd compression
  2914
  2915	Sun 14 Feb 2021 02:30:12 PM GMT | Odroid N2 | 21.02.1 | arm64 | aarch64 | 5.10.12-meson64
  2916
  2917	### dmesg:
  2918
  2919	[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
  2920	[    0.000000] Linux version 5.10.12-meson64 (root@beast) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #21.02.1 SMP PREEMPT Wed Feb 3 21:06:36 CET 2021
  2921	[    0.000000] Machine model: Hardkernel ODROID-N2
  2922	[    0.000000] efi: UEFI not found.
  2923	[    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
  2924	[    0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB
  2925	[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
  2926	[    0.000000] NUMA: No NUMA configuration found
  2927	[    0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ed7fffff]
  2928	[    0.000000] NUMA: NODE_DATA [mem 0xb502f100-0xb5030fff]
  2929	[    0.000000] Zone ranges:
  2930	[    0.000000]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
  2931	[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000ed7fffff]
  2932	[    0.000000]   Normal   empty
  2933	[    0.000000] Movable zone start for each node
  2934	[    0.000000] Early memory node ranges
  2935	[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000004ffffff]
  2936	[    0.000000]   node   0: [mem 0x0000000005300000-0x00000000ed7fffff]
  2937	[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ed7fffff]
  2938	[    0.000000] On node 0 totalpages: 972032
  2939	[    0.000000]   DMA zone: 4096 pages used for memmap
  2940	[    0.000000]   DMA zone: 0 pages reserved
  2941	[    0.000000]   DMA zone: 261376 pages, LIFO batch:63
  2942	[    0.000000]   DMA32 zone: 11104 pages used for memmap
  2943	[    0.000000]   DMA32 zone: 710656 pages, LIFO batch:63
  2944	[    0.000000] psci: probing for conduit method from DT.
  2945	[    0.000000] psci: PSCIv1.0 detected in firmware.
  2946	[    0.000000] psci: Using standard PSCI v0.2 function IDs
  2947	[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
  2948	[    0.000000] psci: SMC Calling Convention v1.1
  2949	[    0.000000] percpu: Embedded 23 pages/cpu s56728 r8192 d29288 u94208
  2950	[    0.000000] pcpu-alloc: s56728 r8192 d29288 u94208 alloc=23*4096
  2951	[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
  2952	[    0.000000] Detected VIPT I-cache on CPU0
  2953	[    0.000000] CPU features: detected: ARM erratum 845719
  2954	[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 956832
  2955	[    0.000000] Policy zone: DMA32
  2956	[    0.000000] Kernel command line: root=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c rootwait rootfstype=ext4 console=ttyAML0,115200n8 console=tty1 loglevel=1  no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=1080p60hz cvbsmode=576cvbs max_freq_a53=1896 max_freq_a73=1800 maxcpus=6 voutmode=hdmi  disablehpd=false  cvbscable=0 overscan=100 consoleblank=0
  2957	[    0.000000] Kernel parameter elevator= does not have any effect anymore.
  2958	               Please use sysfs to set IO scheduler for individual devices.
  2959	[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
  2960	[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
  2961	[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
  2962	[    0.000000] software IO TLB: mapped [mem 0x0000000038ac5000-0x000000003cac5000] (64MB)
  2963	[    0.000000] Memory: 2785352K/3888128K available (14144K kernel code, 1760K rwdata, 5508K rodata, 3328K init, 592K bss, 185272K reserved, 917504K cma-reserved)
  2964	[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
  2965	[    0.000000] rcu: Preemptible hierarchical RCU implementation.
  2966	[    0.000000] rcu: 	RCU event tracing is enabled.
  2967	[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
  2968	[    0.000000] 	Trampoline variant of Tasks RCU enabled.
  2969	[    0.000000] 	Rude variant of Tasks RCU enabled.
  2970	[    0.000000] 	Tracing variant of Tasks RCU enabled.
  2971	[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  2972	[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
  2973	[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
  2974	[    0.000000] GIC: Using split EOI/Deactivate mode
  2975	[    0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized
  2976	[    0.000000] random: get_random_bytes called from start_kernel+0x378/0x538 with crng_init=0
  2977	[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
  2978	[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  2979	[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  2980	[    0.000249] Console: colour dummy device 80x25
  2981	[    0.000284] printk: console [tty1] enabled
  2982	[    0.000370] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
  2983	[    0.000382] pid_max: default: 32768 minimum: 301
  2984	[    0.000465] LSM: Security Framework initializing
  2985	[    0.000492] Yama: becoming mindful.
  2986	[    0.000581] AppArmor: AppArmor initialized
  2987	[    0.000632] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
  2988	[    0.000651] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
  2989	[    0.002653] rcu: Hierarchical SRCU implementation.
  2990	[    0.005091] EFI services will not be available.
  2991	[    0.005515] smp: Bringing up secondary CPUs ...
  2992	[    0.006187] Detected VIPT I-cache on CPU1
  2993	[    0.006249] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
  2994	[    0.007446] CPU features: detected: ARM erratum 858921
  2995	[    0.007454] CPU features: detected: Spectre-v2
  2996	[    0.007457] CPU features: detected: Spectre-v4
  2997	[    0.007463] Detected VIPT I-cache on CPU2
  2998	[    0.007490] arch_timer: Enabling local workaround for ARM erratum 858921
  2999	[    0.007503] arch_timer: CPU2: Trapping CNTVCT access
  3000	[    0.007517] CPU2: Booted secondary processor 0x0000000100 [0x410fd092]
  3001	[    0.008230] Detected VIPT I-cache on CPU3
  3002	[    0.008246] arch_timer: Enabling local workaround for ARM erratum 858921
  3003	[    0.008253] arch_timer: CPU3: Trapping CNTVCT access
  3004	[    0.008260] CPU3: Booted secondary processor 0x0000000101 [0x410fd092]
  3005	[    0.008883] Detected VIPT I-cache on CPU4
  3006	[    0.008900] arch_timer: Enabling local workaround for ARM erratum 858921
  3007	[    0.008907] arch_timer: CPU4: Trapping CNTVCT access
  3008	[    0.008914] CPU4: Booted secondary processor 0x0000000102 [0x410fd092]
  3009	[    0.009528] Detected VIPT I-cache on CPU5
  3010	[    0.009544] arch_timer: Enabling local workaround for ARM erratum 858921
  3011	[    0.009551] arch_timer: CPU5: Trapping CNTVCT access
  3012	[    0.009559] CPU5: Booted secondary processor 0x0000000103 [0x410fd092]
  3013	[    0.009641] smp: Brought up 1 node, 6 CPUs
  3014	[    0.009658] SMP: Total of 6 processors activated.
  3015	[    0.009665] CPU features: detected: 32-bit EL0 Support
  3016	[    0.009671] CPU features: detected: CRC32 instructions
  3017	[    0.009677] CPU features: detected: 32-bit EL1 Support
  3018	[    0.020892] CPU: All CPU(s) started at EL2
  3019	[    0.020943] alternatives: patching kernel code
  3020	[    0.022883] devtmpfs: initialized
  3021	[    0.030529] Registered cp15_barrier emulation handler
  3022	[    0.030542] Registered setend emulation handler
  3023	[    0.030680] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  3024	[    0.030718] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
  3025	[    0.044635] pinctrl core: initialized pinctrl subsystem
  3026	[    0.045364] DMI not present or invalid.
  3027	[    0.045739] NET: Registered protocol family 16
  3028	[    0.047260] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
  3029	[    0.047530] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
  3030	[    0.047758] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
  3031	[    0.047799] audit: initializing netlink subsys (disabled)
  3032	[    0.047911] audit: type=2000 audit(0.044:1): state=initialized audit_enabled=0 res=1
  3033	[    0.049236] thermal_sys: Registered thermal governor 'fair_share'
  3034	[    0.049244] thermal_sys: Registered thermal governor 'bang_bang'
  3035	[    0.049248] thermal_sys: Registered thermal governor 'step_wise'
  3036	[    0.049251] thermal_sys: Registered thermal governor 'user_space'
  3037	[    0.049718] cpuidle: using governor menu
  3038	[    0.050053] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  3039	[    0.050170] ASID allocator initialised with 65536 entries
  3040	[    0.051125] Serial: AMBA PL011 UART driver
  3041	[    0.085127] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
  3042	[    0.085138] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
  3043	[    0.085144] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
  3044	[    0.085148] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
  3045	[    0.087393] cryptd: max_cpu_qlen set to 1000
  3046	[    0.156152] raid6: neonx8   gen()  2783 MB/s
  3047	[    0.224217] raid6: neonx8   xor()  2042 MB/s
  3048	[    0.292307] raid6: neonx4   gen()  2987 MB/s
  3049	[    0.360349] raid6: neonx4   xor()  2399 MB/s
  3050	[    0.428415] raid6: neonx2   gen()  2561 MB/s
  3051	[    0.496487] raid6: neonx2   xor()  2190 MB/s
  3052	[    0.564550] raid6: neonx1   gen()  2062 MB/s
  3053	[    0.632612] raid6: neonx1   xor()  1727 MB/s
  3054	[    0.700685] raid6: int64x8  gen()  1376 MB/s
  3055	[    0.768754] raid6: int64x8  xor()   735 MB/s
  3056	[    0.836843] raid6: int64x4  gen()  1463 MB/s
  3057	[    0.904885] raid6: int64x4  xor()   733 MB/s
  3058	[    0.972956] raid6: int64x2  gen()  1363 MB/s
  3059	[    1.041023] raid6: int64x2  xor()   619 MB/s
  3060	[    1.109086] raid6: int64x1  gen()  1120 MB/s
  3061	[    1.177145] raid6: int64x1  xor()   462 MB/s
  3062	[    1.177149] raid6: using algorithm neonx4 gen() 2987 MB/s
  3063	[    1.177152] raid6: .... xor() 2399 MB/s, rmw enabled
  3064	[    1.177156] raid6: using neon recovery algorithm
  3065	[    1.177614] ACPI: Interpreter disabled.
  3066	[    1.178419] 5V: supplied by 12V
  3067	[    1.179327] VDDAO_3V3: supplied by 12V
  3068	[    1.179817] iommu: Default domain type: Translated
  3069	[    1.179928] vgaarb: loaded
  3070	[    1.180910] SCSI subsystem initialized
  3071	[    1.181117] usbcore: registered new interface driver usbfs
  3072	[    1.181150] usbcore: registered new interface driver hub
  3073	[    1.181182] usbcore: registered new device driver usb
  3074	[    1.181438] pps_core: LinuxPPS API ver. 1 registered
  3075	[    1.181442] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  3076	[    1.181465] PTP clock support registered
  3077	[    1.181666] EDAC MC: Ver: 3.0.0
  3078	[    1.183010] NetLabel: Initializing
  3079	[    1.183017] NetLabel:  domain hash size = 128
  3080	[    1.183020] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
  3081	[    1.183061] NetLabel:  unlabeled traffic allowed by default
  3082	[    1.183491] clocksource: Switched to clocksource arch_sys_counter
  3083	[    1.183699] VFS: Disk quotas dquot_6.6.0
  3084	[    1.183742] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  3085	[    1.184112] AppArmor: AppArmor Filesystem Enabled
  3086	[    1.184160] pnp: PnP ACPI: disabled
  3087	[    1.189941] NET: Registered protocol family 2
  3088	[    1.190404] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
  3089	[    1.190509] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
  3090	[    1.190766] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
  3091	[    1.190953] TCP: Hash tables configured (established 32768 bind 32768)
  3092	[    1.191103] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
  3093	[    1.191167] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
  3094	[    1.191213] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
  3095	[    1.191364] NET: Registered protocol family 1
  3096	[    1.191384] PCI: CLS 0 bytes, default 64
  3097	[    1.191566] Trying to unpack rootfs image as initramfs...
  3098	[    1.727544] Freeing initrd memory: 13544K
  3099	[    1.728481] kvm [1]: IPA Size Limit: 40 bits
  3100	[    1.729184] kvm [1]: vgic interrupt IRQ9
  3101	[    1.729316] kvm [1]: Hyp mode initialized successfully
  3102	[    1.733236] Initialise system trusted keyrings
  3103	[    1.733266] Key type blacklist registered
  3104	[    1.733414] workingset: timestamp_bits=44 max_order=20 bucket_order=0
  3105	[    1.736580] zbud: loaded
  3106	[    1.737550] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  3107	[    1.738038] fuse: init (API version 7.32)
  3108	[    1.738817] integrity: Platform Keyring initialized
  3109	[    1.767010] xor: measuring software checksum speed
  3110	[    1.769855]    8regs           :  3473 MB/sec
  3111	[    1.772310]    32regs          :  4022 MB/sec
  3112	[    1.774957]    arm64_neon      :  3722 MB/sec
  3113	[    1.774961] xor: using function: 32regs (4022 MB/sec)
  3114	[    1.774969] Key type asymmetric registered
  3115	[    1.774973] Asymmetric key parser 'x509' registered
  3116	[    1.775010] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
  3117	[    1.775120] io scheduler mq-deadline registered
  3118	[    1.775124] io scheduler kyber registered
  3119	[    1.775206] io scheduler bfq registered
  3120	[    1.777770] gpio-447 (usb-hub-reset): hogged as output/high
  3121	[    1.780772] EINJ: ACPI disabled.
  3122	[    1.786941] soc soc0: Amlogic Meson G12B (S922X) Revision 29:a (40:2) Detected
  3123	[    1.788410] VCC_3V3: supplied by VDDAO_3V3
  3124	[    1.788444] FLASH_1V8: supplied by VCC_3V3
  3125	[    1.788476] VCC_1V8: supplied by VCC_3V3
  3126	[    1.788517] VDDAO_1V8: supplied by VDDAO_3V3
  3127	[    1.788553] VDDCPU_A: supplied by regulator-dummy
  3128	[    1.788909] VDDCPU_B: supplied by regulator-dummy
  3129	[    1.789576] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
  3130	[    1.791906] Serial: AMBA driver
  3131	[    1.792200] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart
  3132	[    1.792291] printk: console [ttyAML0] enabled
  3133	[    1.792797] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 33, base_baud = 1500000) is a meson_uart
  3134	[    1.797999] loop: module loaded
  3135	[    1.799933] libphy: Fixed MDIO Bus: probed
  3136	[    1.801017] tun: Universal TUN/TAP device driver, 1.6
  3137	[    1.801675] thunder_xcv, ver 1.0
  3138	[    1.801708] thunder_bgx, ver 1.0
  3139	[    1.801738] nicpf, ver 1.0
  3140	[    1.802204] e1000e: Intel(R) PRO/1000 Network Driver
  3141	[    1.802208] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
  3142	[    1.802248] igb: Intel(R) Gigabit Ethernet Network Driver
  3143	[    1.802251] igb: Copyright (c) 2007-2014 Intel Corporation.
  3144	[    1.802279] igbvf: Intel(R) Gigabit Virtual Function Network Driver
  3145	[    1.802282] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
  3146	[    1.802411] sky2: driver version 1.30
  3147	[    1.802786] VFIO - User Level meta-driver version: 0.3
  3148	[    1.804235] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  3149	[    1.804273] ehci-pci: EHCI PCI platform driver
  3150	[    1.804309] ehci-platform: EHCI generic platform driver
  3151	[    1.804452] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  3152	[    1.804463] ohci-pci: OHCI PCI platform driver
  3153	[    1.804498] ohci-platform: OHCI generic platform driver
  3154	[    1.804926] usbcore: registered new interface driver usb-storage
  3155	[    1.806268] mousedev: PS/2 mouse device common for all mice
  3156	[    1.806647] i2c /dev entries driver
  3157	[    1.811803] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17
  3158	[    1.812470] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz
  3159	[    1.813436] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-1 failed:-17
  3160	[    1.814042] sdhci: Secure Digital Host Controller Interface driver
  3161	[    1.814046] sdhci: Copyright(c) Pierre Ossman
  3162	[    1.814151] Synopsys Designware Multimedia Card Interface Driver
  3163	[    1.814596] sdhci-pltfm: SDHCI platform and OF driver helper
  3164	[    1.815001] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq
  3165	[    1.815347] ledtrig-cpu: registered to indicate activity on CPUs
  3166	[    1.815641] meson-sm: secure-monitor enabled
  3167	[    1.815801] hid: raw HID events driver (C) Jiri Kosina
  3168	[    1.815973] usbcore: registered new interface driver usbhid
  3169	[    1.815977] usbhid: USB HID core driver
  3170	[    1.817175] NET: Registered protocol family 10
  3171	[    1.817566] Segment Routing with IPv6
  3172	[    1.817595] NET: Registered protocol family 17
  3173	[    1.817640] 8021q: 802.1Q VLAN Support v1.8
  3174	[    1.817664] Key type dns_resolver registered
  3175	[    1.817937] registered taskstats version 1
  3176	[    1.817942] Loading compiled-in X.509 certificates
  3177	[    1.819693] Loaded X.509 cert 'Build time autogenerated kernel key: f47c178852ca39740c3546b008122b65f5ed9bce'
  3178	[    1.821314] zswap: loaded using pool zstd/z3fold
  3179	[    1.821489] Key type ._fscrypt registered
  3180	[    1.821491] Key type .fscrypt registered
  3181	[    1.821493] Key type fscrypt-provisioning registered
  3182	[    1.822573] Btrfs loaded, crc32c=crc32c-generic
  3183	[    1.831945] Key type encrypted registered
  3184	[    1.831957] AppArmor: AppArmor sha1 policy hashing enabled
  3185	[    1.838309] HUB_5V: supplied by 5V
  3186	[    1.838526] USB_PWR_EN: supplied by 5V
  3187	[    5.728088] ------------[ cut here ]------------
  3188	[    5.728095] pcie_pll_pll already disabled
  3189	[    5.728122] WARNING: CPU: 3 PID: 1261 at drivers/clk/clk.c:952 clk_core_disable+0xb0/0xb8
  3190	[    5.728124] Modules linked in:
  3191	[    5.728131] CPU: 3 PID: 1261 Comm: kworker/3:2 Not tainted 5.10.12-meson64 #21.02.1
  3192	[    5.728133] Hardware name: Hardkernel ODROID-N2 (DT)
  3193	[    5.728141] Workqueue: events deferred_probe_work_func
  3194	[    5.728146] pstate: 60000085 (nZCv daIf -PAN -UAO -TCO BTYPE=--)
  3195	[    5.728148] pc : clk_core_disable+0xb0/0xb8
  3196	[    5.728151] lr : clk_core_disable+0xb0/0xb8
  3197	[    5.728152] sp : ffff800013bd3b00
  3198	[    5.728154] x29: ffff800013bd3b00 x28: 0000000000000000
  3199	[    5.728159] x27: ffff000044383dc8 x26: ffff8000118d5528
  3200	[    5.728162] x25: ffff000040835400 x24: ffff0000b505feb8
  3201	[    5.728165] x23: ffff800010efcda0 x22: ffff000040b26000
  3202	[    5.728169] x21: ffff000040bb5180 x20: ffff00004025a600
  3203	[    5.728172] x19: ffff00004025a600 x18: ffff80001173b1e0
  3204	[    5.728175] x17: 0000000000000020 x16: 000000000000000c
  3205	[    5.728178] x15: 000000000000010d x14: ffff800013bd37c0
  3206	[    5.728182] x13: 00000000ffffffea x12: ffff8000117ab218
  3207	[    5.728185] x11: 0000000000000003 x10: ffff8000117931d8
  3208	[    5.728188] x9 : ffff800011793230 x8 : 0000000000017fe8
  3209	[    5.728191] x7 : c0000000ffffefff x6 : 0000000000000001
  3210	[    5.728194] x5 : 0000000000000000 x4 : 0000000000000000
  3211	[    5.728197] x3 : 00000000ffffffff x2 : ffff80001173b1a8
  3212	[    5.728200] x1 : ce3edb13a9fd6400 x0 : 0000000000000000
  3213	[    5.728204] Call trace:
  3214	[    5.728207]  clk_core_disable+0xb0/0xb8
  3215	[    5.728209]  clk_core_disable_lock+0x24/0x40
  3216	[    5.728211]  clk_disable+0x20/0x30
  3217	[    5.728215]  phy_g12a_usb3_pcie_probe+0x120/0x1f0
  3218	[    5.728218]  platform_drv_probe+0x54/0xa8
  3219	[    5.728220]  really_probe+0xe8/0x4d0
  3220	[    5.728223]  driver_probe_device+0xf4/0x160
  3221	[    5.728225]  __device_attach_driver+0x8c/0x118
  3222	[    5.728228]  bus_for_each_drv+0x7c/0xd0
  3223	[    5.728231]  __device_attach+0xe8/0x168
  3224	[    5.728233]  device_initial_probe+0x14/0x20
  3225	[    5.728236]  bus_probe_device+0x9c/0xa8
  3226	[    5.728238]  deferred_probe_work_func+0x88/0xd8
  3227	[    5.728243]  process_one_work+0x1e8/0x360
  3228	[    5.728245]  worker_thread+0x210/0x480
  3229	[    5.728247]  kthread+0x154/0x158
  3230	[    5.728251]  ret_from_fork+0x10/0x34
  3231	[    5.728253] ---[ end trace d25d3f5e82e377cf ]---
  3232	[    5.728255] ------------[ cut here ]------------
  3233	[    5.728257] pcie_pll_pll already unprepared
  3234	[    5.728272] WARNING: CPU: 3 PID: 1261 at drivers/clk/clk.c:811 clk_core_unprepare+0xf0/0x110
  3235	[    5.728273] Modules linked in:
  3236	[    5.728276] CPU: 3 PID: 1261 Comm: kworker/3:2 Tainted: G        W         5.10.12-meson64 #21.02.1
  3237	[    5.728278] Hardware name: Hardkernel ODROID-N2 (DT)
  3238	[    5.728282] Workqueue: events deferred_probe_work_func
  3239	[    5.728285] pstate: 60000005 (nZCv daif -PAN -UAO -TCO BTYPE=--)
  3240	[    5.728287] pc : clk_core_unprepare+0xf0/0x110
  3241	[    5.728290] lr : clk_core_unprepare+0xf0/0x110
  3242	[    5.728291] sp : ffff800013bd3b10
  3243	[    5.728293] x29: ffff800013bd3b10 x28: 0000000000000000
  3244	[    5.728296] x27: ffff000044383dc8 x26: ffff8000118d5528
  3245	[    5.728300] x25: ffff000040835400 x24: ffff0000b505feb8
  3246	[    5.728303] x23: ffff800010efcda0 x22: ffff000040b26000
  3247	[    5.728306] x21: ffff000040bb5180 x20: ffff000040835400
  3248	[    5.728310] x19: ffff00004025a600 x18: ffff80001173b1e0
  3249	[    5.728313] x17: 0000000000000020 x16: 000000000000000c
  3250	[    5.728316] x15: 000000000000013a x14: ffff800013bd37d0
  3251	[    5.728319] x13: 00000000ffffffea x12: ffff8000117ab218
  3252	[    5.728322] x11: 0000000000000003 x10: ffff8000117931d8
  3253	[    5.728325] x9 : ffff800011793230 x8 : 0000000000017fe8
  3254	[    5.728328] x7 : c0000000ffffefff x6 : 0000000000000001
  3255	[    5.728331] x5 : 0000000000000000 x4 : 0000000000000000
  3256	[    5.728334] x3 : 00000000ffffffff x2 : ffff80001173b1a8
  3257	[    5.728337] x1 : ce3edb13a9fd6400 x0 : 0000000000000000
  3258	[    5.728340] Call trace:
  3259	[    5.728343]  clk_core_unprepare+0xf0/0x110
  3260	[    5.728345]  clk_unprepare+0x2c/0x48
  3261	[    5.728348]  phy_g12a_usb3_pcie_probe+0x128/0x1f0
  3262	[    5.728350]  platform_drv_probe+0x54/0xa8
  3263	[    5.728353]  really_probe+0xe8/0x4d0
  3264	[    5.728356]  driver_probe_device+0xf4/0x160
  3265	[    5.728358]  __device_attach_driver+0x8c/0x118
  3266	[    5.728360]  bus_for_each_drv+0x7c/0xd0
  3267	[    5.728363]  __device_attach+0xe8/0x168
  3268	[    5.728365]  device_initial_probe+0x14/0x20
  3269	[    5.728367]  bus_probe_device+0x9c/0xa8
  3270	[    5.728370]  deferred_probe_work_func+0x88/0xd8
  3271	[    5.728372]  process_one_work+0x1e8/0x360
  3272	[    5.728374]  worker_thread+0x210/0x480
  3273	[    5.728376]  kthread+0x154/0x158
  3274	[    5.728379]  ret_from_fork+0x10/0x34
  3275	[    5.728380] ---[ end trace d25d3f5e82e377d0 ]---
  3276	[    5.728423] phy-g12a-usb3-pcie: probe of ff646000.phy failed with error -5
  3277	[    5.730142] meson-gx-mmc ffe05000.sd: Got CD GPIO
  3278	[    5.756496] Freeing unused kernel memory: 3328K
  3279	[    5.779555] Run /init as init process
  3280	[    5.779560]   with arguments:
  3281	[    5.779562]     /init
  3282	[    5.779565]   with environment:
  3283	[    5.779566]     HOME=/
  3284	[    5.779568]     TERM=linux
  3285	[    5.779570]     hdmimode=1080p60hz
  3286	[    5.779572]     cvbsmode=576cvbs
  3287	[    5.779573]     max_freq_a53=1896
  3288	[    5.779575]     max_freq_a73=1800
  3289	[    5.779576]     voutmode=hdmi
  3290	[    5.779578]     disablehpd=false
  3291	[    5.779579]     cvbscable=0
  3292	[    5.779581]     overscan=100
  3293	[    5.821716] mmc0: new ultra high speed SDR25 SDHC card at address b368
  3294	[    5.822290] mmcblk0: mmc0:b368 CBADS 30.0 GiB
  3295	[    5.824388]  mmcblk0: p1
  3296	[    5.952775] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found
  3297	[    5.952781] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found
  3298	[    5.952861] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock
  3299	[    5.953252] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37
  3300	[    5.953258] meson8b-dwmac ff3f0000.ethernet: 	DWMAC1000
  3301	[    5.953262] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported
  3302	[    5.953265] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported
  3303	[    5.953267] meson8b-dwmac ff3f0000.ethernet: COE Type 2
  3304	[    5.953269] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported
  3305	[    5.953271] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported
  3306	[    5.953312] meson8b-dwmac ff3f0000.ethernet: Normal descriptors
  3307	[    5.953316] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled
  3308	[    5.953318] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
  3309	[    5.953490] libphy: stmmac: probed
  3310	[    5.956379] libphy: mdio_mux: probed
  3311	[    5.963210] meson-vrtc ff8000a8.rtc: registered as rtc1
  3312	[    5.983254] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
  3313	[    5.983433] rtc-pcf8563 1-0051: registered as rtc0
  3314	[    5.984776] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
  3315	[    5.984784] rtc-pcf8563 1-0051: hctosys: unable to read the hardware clock
  3316	[    5.988229] random: fast init done
  3317	[    6.159996] libphy: mdio_mux: probed
  3318	[    6.406327] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
  3319	[    7.207132] systemd[1]: System time before build time, advancing clock.
  3320	[    7.221948] systemd[1]: Inserted module 'autofs4'
  3321	[    7.268432] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  3322	[    7.268646] systemd[1]: Detected architecture arm64.
  3323	[    7.293324] systemd[1]: Set hostname to <odroidn2>.
  3324	[    7.620719] random: systemd: uninitialized urandom read (16 bytes read)
  3325	[    7.624049] random: systemd: uninitialized urandom read (16 bytes read)
  3326	[    7.624331] systemd[1]: Listening on udev Control Socket.
  3327	[    7.624535] random: systemd: uninitialized urandom read (16 bytes read)
  3328	[    7.624641] systemd[1]: Listening on udev Kernel Socket.
  3329	[    7.625537] systemd[1]: Created slice User and Session Slice.
  3330	[    7.625630] systemd[1]: Reached target Slices.
  3331	[    7.625879] systemd[1]: Listening on Syslog Socket.
  3332	[    7.626684] systemd[1]: Created slice system-serial\x2dgetty.slice.
  3333	[    7.626996] systemd[1]: Listening on Journal Socket.
  3334	[    7.682441] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
  3335	[    8.238727] pwm-gpio pwmgpio: 1 gpio pwms loaded
  3336	[    8.317144] zram: Added device: zram0
  3337	[    8.317486] zram: Added device: zram1
  3338	[    8.317803] zram: Added device: zram2
  3339	[    8.408957] mc: Linux media interface: v0.10
  3340	[    8.417850] meson-saradc ff809000.adc: supply vref not found, using dummy regulator
  3341	[    8.440629] panfrost ffe40000.gpu: clock rate = 24000000
  3342	[    8.440690] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19
  3343	[    8.441316] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0
  3344	[    8.441321] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400
  3345	[    8.441325] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
  3346	[    8.441328] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1
  3347	[    8.456580] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 0
  3348	[    8.482923] videodev: Linux video capture interface: v2.00
  3349	[    8.520765] meson-drm ff900000.vpu: Queued 2 outputs on vpu
  3350	[    8.527536] Registered IR keymap rc-odroid
  3351	[    8.538996] IR NEC protocol handler initialized
  3352	[    8.546082] meson-drm ff900000.vpu: CVBS Output connector not available
  3353	[    8.567567] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0
  3354	[    8.567673] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
  3355	[    8.567734] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input0
  3356	[    8.568416] meson-ir ff808000.ir: receiver initialized
  3357	[    8.576351] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
  3358	[    8.578018] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
  3359	[    8.578316] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
  3360	[    8.578600] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 1
  3361	[    8.578659] meson-drm ff900000.vpu: [drm] Cannot find any crtc or sizes
  3362	[    8.613799] zram0: detected capacity change from 0 to 1904500736
  3363	[    8.644149] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  3364	[    8.658096] axg-sound-card sound: ASoC: no DMI vendor name!
  3365	[    9.651510] Adding 1859860k swap on /dev/zram0.  Priority:5 extents:1 across:1859860k SSFS
  3366	[    9.714218] zram1: detected capacity change from 0 to 52428800
  3367	[   11.799746] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
  3368	[   11.799765] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
  3369	[   12.752409] systemd[1]: Started Armbian memory supported logging.
  3370	[   12.756354] systemd[1]: Starting Journal Service...
  3371	[   12.801657] systemd[1]: Started Journal Service.
  3372	[   12.829055] systemd-journald[1797]: Received request to flush runtime journal from PID 1
  3373
  3374	### armbian-release:
  3375
  3376	# PLEASE DO NOT EDIT THIS FILE
  3377	BOARD=odroidn2
  3378	BOARD_NAME="Odroid N2"
  3379	BOARDFAMILY=meson-g12b
  3380	BUILD_REPOSITORY_URL=https://github.com/armbian/build
  3381	BUILD_REPOSITORY_COMMIT=5f03d652
  3382	DISTRIBUTION_CODENAME=buster
  3383	DISTRIBUTION_STATUS=supported
  3384	VERSION=21.02.1
  3385	LINUXFAMILY=meson64
  3386	BRANCH=current
  3387	ARCH=arm64
  3388	IMAGE_TYPE=stable
  3389	BOARD_TYPE=conf
  3390	INITRD_ARCH=arm64
  3391	KERNEL_IMAGE_TYPE=Image
  3392
  3393	### boot environment:
  3394
  3395	verbosity=1
  3396	console=both
  3397	overlay_prefix=meson
  3398	rootdev=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c
  3399	rootfstype=ext4
  3400	usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
  3401
  3402	### lsusb:
  3403
  3404
  3405	### lscpu:
  3406
  3407	Architecture:        aarch64
  3408	Byte Order:          Little Endian
  3409	CPU(s):              6
  3410	On-line CPU(s) list: 0-5
  3411	Thread(s) per core:  1
  3412	Core(s) per socket:  3
  3413	Socket(s):           2
  3414	NUMA node(s):        1
  3415	Vendor ID:           ARM
  3416	Model:               4
  3417	Model name:          Cortex-A53
  3418	Stepping:            r0p4
  3419	CPU max MHz:         1992.0000
  3420	CPU min MHz:         100.0000
  3421	BogoMIPS:            48.00
  3422	L1d cache:           unknown size
  3423	L1i cache:           unknown size
  3424	L2 cache:            unknown size
  3425	NUMA node0 CPU(s):   0-5
  3426	Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  3427
  3428	### cpuinfo:
  3429
  3430	processor	: 0
  3431	BogoMIPS	: 48.00
  3432	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  3433	CPU implementer	: 0x41
  3434	CPU architecture: 8
  3435	CPU variant	: 0x0
  3436	CPU part	: 0xd03
  3437	CPU revision	: 4
  3438
  3439	processor	: 1
  3440	BogoMIPS	: 48.00
  3441	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  3442	CPU implementer	: 0x41
  3443	CPU architecture: 8
  3444	CPU variant	: 0x0
  3445	CPU part	: 0xd03
  3446	CPU revision	: 4
  3447
  3448	processor	: 2
  3449	BogoMIPS	: 48.00
  3450	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  3451	CPU implementer	: 0x41
  3452	CPU architecture: 8
  3453	CPU variant	: 0x0
  3454	CPU part	: 0xd09
  3455	CPU revision	: 2
  3456
  3457	processor	: 3
  3458	BogoMIPS	: 48.00
  3459	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  3460	CPU implementer	: 0x41
  3461	CPU architecture: 8
  3462	CPU variant	: 0x0
  3463	CPU part	: 0xd09
  3464	CPU revision	: 2
  3465
  3466	processor	: 4
  3467	BogoMIPS	: 48.00
  3468	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  3469	CPU implementer	: 0x41
  3470	CPU architecture: 8
  3471	CPU variant	: 0x0
  3472	CPU part	: 0xd09
  3473	CPU revision	: 2
  3474
  3475	processor	: 5
  3476	BogoMIPS	: 48.00
  3477	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  3478	CPU implementer	: 0x41
  3479	CPU architecture: 8
  3480	CPU variant	: 0x0
  3481	CPU part	: 0xd09
  3482	CPU revision	: 2
  3483
  3484
  3485	### meminfo:
  3486
  3487	MemTotal:        3719728 kB
  3488	MemFree:         3405144 kB
  3489	MemAvailable:    3356628 kB
  3490	Buffers:           11672 kB
  3491	Cached:            40100 kB
  3492	SwapCached:            0 kB
  3493	Active:            29768 kB
  3494	Inactive:         185860 kB
  3495	Active(anon):         84 kB
  3496	Inactive(anon):   168520 kB
  3497	Active(file):      29684 kB
  3498	Inactive(file):    17340 kB
  3499	Unevictable:           0 kB
  3500	Mlocked:               0 kB
  3501	SwapTotal:       1859860 kB
  3502	SwapFree:        1859860 kB
  3503	Dirty:              2040 kB
  3504	Writeback:             0 kB
  3505	AnonPages:        163768 kB
  3506	Mapped:            10424 kB
  3507	Shmem:              4900 kB
  3508	KReclaimable:      12660 kB
  3509	Slab:              38264 kB
  3510	SReclaimable:      12660 kB
  3511	SUnreclaim:        25604 kB
  3512	KernelStack:        2096 kB
  3513	PageTables:         4212 kB
  3514	NFS_Unstable:          0 kB
  3515	Bounce:                0 kB
  3516	WritebackTmp:          0 kB
  3517	CommitLimit:     3719724 kB
  3518	Committed_AS:    4210668 kB
  3519	VmallocTotal:   135290159040 kB
  3520	VmallocUsed:       30896 kB
  3521	VmallocChunk:          0 kB
  3522	Percpu:             1368 kB
  3523	HardwareCorrupted:     0 kB
  3524	AnonHugePages:         0 kB
  3525	ShmemHugePages:        0 kB
  3526	ShmemPmdMapped:        0 kB
  3527	FileHugePages:         0 kB
  3528	FilePmdMapped:         0 kB
  3529	CmaTotal:         917504 kB
  3530	CmaFree:          909824 kB
  3531	HugePages_Total:       0
  3532	HugePages_Free:        0
  3533	HugePages_Rsvd:        0
  3534	HugePages_Surp:        0
  3535	Hugepagesize:       2048 kB
  3536	Hugetlb:               0 kB
  3537
  3538	### virtual memory:
  3539
  3540	vm.admin_reserve_kbytes = 8192
  3541	vm.block_dump = 0
  3542	vm.compaction_proactiveness = 20
  3543	vm.compact_unevictable_allowed = 1
  3544	vm.dirty_background_bytes = 0
  3545	vm.dirty_background_ratio = 10
  3546	vm.dirty_bytes = 0
  3547	vm.dirty_expire_centisecs = 3000
  3548	vm.dirty_ratio = 20
  3549	vm.dirtytime_expire_seconds = 43200
  3550	vm.dirty_writeback_centisecs = 500
  3551	vm.extfrag_threshold = 500
  3552	vm.hugetlb_shm_group = 0
  3553	vm.laptop_mode = 0
  3554	vm.legacy_va_layout = 0
  3555	vm.lowmem_reserve_ratio = 256	256	32	0
  3556	vm.max_map_count = 65530
  3557	vm.memory_failure_early_kill = 0
  3558	vm.memory_failure_recovery = 1
  3559	vm.min_free_kbytes = 45056
  3560	vm.min_slab_ratio = 5
  3561	vm.min_unmapped_ratio = 1
  3562	vm.mmap_min_addr = 4096
  3563	vm.mmap_rnd_bits = 18
  3564	vm.mmap_rnd_compat_bits = 11
  3565	vm.nr_hugepages = 0
  3566	vm.nr_hugepages_mempolicy = 0
  3567	vm.nr_overcommit_hugepages = 0
  3568	vm.numa_stat = 1
  3569	vm.numa_zonelist_order = Node
  3570	vm.oom_dump_tasks = 1
  3571	vm.oom_kill_allocating_task = 0
  3572	vm.overcommit_kbytes = 0
  3573	vm.overcommit_memory = 0
  3574	vm.overcommit_ratio = 50
  3575	vm.page-cluster = 0
  3576	vm.page_lock_unfairness = 5
  3577	vm.panic_on_oom = 0
  3578	vm.percpu_pagelist_fraction = 0
  3579	vm.stat_interval = 1
  3580	vm.swappiness = 100
  3581	vm.user_reserve_kbytes = 115023
  3582	vm.vfs_cache_pressure = 100
  3583	vm.watermark_boost_factor = 15000
  3584	vm.watermark_scale_factor = 10
  3585	vm.zone_reclaim_mode = 0
  3586
  3587	### ip addr:
  3588
  3589	1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  3590	    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  3591	    inet XXX.XXX.0.1/8 scope host lo
  3592	       valid_lft forever preferred_lft forever
  3593	    inet6 ::1/128 scope host
  3594	       valid_lft forever preferred_lft forever
  3595	2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  3596	    link/ether 00:1e:06:42:03:f8 brd ff:ff:ff:ff:ff:ff
  3597
  3598	### partitions:
  3599
  3600	major minor  #blocks  name
  3601
  3602	 179        0   31464960 mmcblk0
  3603	 179        1   31146208 mmcblk0p1
  3604	 252        0    1859864 zram0
  3605	 252        1      51200 zram1
  3606
  3607	### df:
  3608
  3609	udev            1.4G     0  1.4G   0% /dev
  3610	tmpfs           364M  4.9M  359M   2% /run
  3611	/dev/mmcblk0p1   30G  1.7G   28G   6% /
  3612	tmpfs           1.8G     0  1.8G   0% /dev/shm
  3613	tmpfs           5.0M  4.0K  5.0M   1% /run/lock
  3614	tmpfs           1.8G     0  1.8G   0% /sys/fs/cgroup
  3615	tmpfs           1.8G     0  1.8G   0% /tmp
  3616	/dev/zram1       49M  2.0M   43M   5% /var/log
  3617
  3618	### lsblk:
  3619
  3620	NAME        FSTYPE  SIZE MOUNTPOINT UUID
  3621	mmcblk0              30G
  3622	└─mmcblk0p1 ext4   29.7G /          bd34953d-41be-49d6-b1c0-c0c28a5e239c
  3623	zram1                50M /var/log
  3624
  3625	### zramctl:
  3626
  3627	NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
  3628	/dev/zram1 zstd           50M  132K  698B   36K       6 /var/log
  3629	/dev/zram0 lzo-rle       1.8G    4K   74B   12K       6 [SWAP]
  3630
  3631	### mtab:
  3632
  3633	/dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  3634	/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  3635	/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
  3636
  3637	### mmc0:b368 info:
  3638
  3639	               fwrev: 0x0
  3640	              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=CBADS MODALIAS=mmc:block
  3641	                 cid: 6f0303434241445310aa002b4d013b00
  3642	                 rca: 0xb368
  3643	                 csd: 400e005a5b590000f00e7f800a404000
  3644	              manfid: 0x00006f
  3645	                 ocr: 0x00200000
  3646	preferred_erase_size: 2097152
  3647	                type: SD
  3648	               hwrev: 0x1
  3649	                date: 11/2019
  3650	                 dsr: 0x404
  3651	          erase_size: 512
  3652	               oemid: 0x0303
  3653	              serial: 0xaa002b4d
  3654	                 ssr: 00000000000000280402800100fd180a001e00000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  3655	                 scr: 02b5800300000000
  3656	                name: CBADS
  3657
  3658	### Boot system health:
  3659
  3660	Time       big.LITTLE   load %cpu %sys %usr %nice %io %irq   CPU  C.St.
  3661	14:30:13: 1908/1992MHz  0.29  18%   8%   4%   0%   5%   0% 32.8°C  0/11
  3662	14:30:13: 1908/1992MHz  0.29  85%  31%   9%   0%  42%   1% 31.7°C  0/11
  3663	14:30:13: 1908/1992MHz  0.29  73%  14%   1%   0%  56%   1% 30.6°C  0/11
  3664	14:30:14: 1908/1992MHz  0.29  65%   7%   4%   0%  50%   1% 31.0°C  0/11
  3665	14:30:14: 1908/1000MHz  0.83  65%   5%   5%   0%  53%   0% 29.9°C  0/11
  3666
  3667	### Activated 1 lzo-rle zram swap devices with 1816 MB each
  3668
  3669	### Activated Armbian ramlog partition with zstd compression
  3670
  3671	Sun 14 Feb 2021 02:39:31 PM GMT | Odroid N2 | 21.02.1 | arm64 | aarch64 | 5.10.12-meson64
  3672
  3673	### dmesg:
  3674
  3675	[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
  3676	[    0.000000] Linux version 5.10.12-meson64 (root@beast) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #21.02.1 SMP PREEMPT Wed Feb 3 21:06:36 CET 2021
  3677	[    0.000000] Machine model: Hardkernel ODROID-N2
  3678	[    0.000000] efi: UEFI not found.
  3679	[    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
  3680	[    0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB
  3681	[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
  3682	[    0.000000] NUMA: No NUMA configuration found
  3683	[    0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ed7fffff]
  3684	[    0.000000] NUMA: NODE_DATA [mem 0xb502f100-0xb5030fff]
  3685	[    0.000000] Zone ranges:
  3686	[    0.000000]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
  3687	[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000ed7fffff]
  3688	[    0.000000]   Normal   empty
  3689	[    0.000000] Movable zone start for each node
  3690	[    0.000000] Early memory node ranges
  3691	[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000004ffffff]
  3692	[    0.000000]   node   0: [mem 0x0000000005300000-0x00000000ed7fffff]
  3693	[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ed7fffff]
  3694	[    0.000000] On node 0 totalpages: 972032
  3695	[    0.000000]   DMA zone: 4096 pages used for memmap
  3696	[    0.000000]   DMA zone: 0 pages reserved
  3697	[    0.000000]   DMA zone: 261376 pages, LIFO batch:63
  3698	[    0.000000]   DMA32 zone: 11104 pages used for memmap
  3699	[    0.000000]   DMA32 zone: 710656 pages, LIFO batch:63
  3700	[    0.000000] psci: probing for conduit method from DT.
  3701	[    0.000000] psci: PSCIv1.0 detected in firmware.
  3702	[    0.000000] psci: Using standard PSCI v0.2 function IDs
  3703	[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
  3704	[    0.000000] psci: SMC Calling Convention v1.1
  3705	[    0.000000] percpu: Embedded 23 pages/cpu s56728 r8192 d29288 u94208
  3706	[    0.000000] pcpu-alloc: s56728 r8192 d29288 u94208 alloc=23*4096
  3707	[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
  3708	[    0.000000] Detected VIPT I-cache on CPU0
  3709	[    0.000000] CPU features: detected: ARM erratum 845719
  3710	[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 956832
  3711	[    0.000000] Policy zone: DMA32
  3712	[    0.000000] Kernel command line: root=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c rootwait rootfstype=ext4 console=ttyAML0,115200n8 console=tty1 loglevel=1  no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=1080p60hz cvbsmode=576cvbs max_freq_a53=1896 max_freq_a73=1800 maxcpus=6 voutmode=hdmi  disablehpd=false  cvbscable=0 overscan=100 consoleblank=0
  3713	[    0.000000] Kernel parameter elevator= does not have any effect anymore.
  3714	               Please use sysfs to set IO scheduler for individual devices.
  3715	[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
  3716	[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
  3717	[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
  3718	[    0.000000] software IO TLB: mapped [mem 0x0000000038ac5000-0x000000003cac5000] (64MB)
  3719	[    0.000000] Memory: 2785352K/3888128K available (14144K kernel code, 1760K rwdata, 5508K rodata, 3328K init, 592K bss, 185272K reserved, 917504K cma-reserved)
  3720	[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
  3721	[    0.000000] rcu: Preemptible hierarchical RCU implementation.
  3722	[    0.000000] rcu: 	RCU event tracing is enabled.
  3723	[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
  3724	[    0.000000] 	Trampoline variant of Tasks RCU enabled.
  3725	[    0.000000] 	Rude variant of Tasks RCU enabled.
  3726	[    0.000000] 	Tracing variant of Tasks RCU enabled.
  3727	[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  3728	[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
  3729	[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
  3730	[    0.000000] GIC: Using split EOI/Deactivate mode
  3731	[    0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized
  3732	[    0.000000] random: get_random_bytes called from start_kernel+0x378/0x538 with crng_init=0
  3733	[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
  3734	[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  3735	[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  3736	[    0.000249] Console: colour dummy device 80x25
  3737	[    0.000282] printk: console [tty1] enabled
  3738	[    0.000369] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
  3739	[    0.000381] pid_max: default: 32768 minimum: 301
  3740	[    0.000467] LSM: Security Framework initializing
  3741	[    0.000493] Yama: becoming mindful.
  3742	[    0.000587] AppArmor: AppArmor initialized
  3743	[    0.000636] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
  3744	[    0.000655] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
  3745	[    0.002651] rcu: Hierarchical SRCU implementation.
  3746	[    0.005096] EFI services will not be available.
  3747	[    0.005521] smp: Bringing up secondary CPUs ...
  3748	[    0.006194] Detected VIPT I-cache on CPU1
  3749	[    0.006255] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
  3750	[    0.007448] CPU features: detected: ARM erratum 858921
  3751	[    0.007456] CPU features: detected: Spectre-v2
  3752	[    0.007460] CPU features: detected: Spectre-v4
  3753	[    0.007467] Detected VIPT I-cache on CPU2
  3754	[    0.007493] arch_timer: Enabling local workaround for ARM erratum 858921
  3755	[    0.007508] arch_timer: CPU2: Trapping CNTVCT access
  3756	[    0.007522] CPU2: Booted secondary processor 0x0000000100 [0x410fd092]
  3757	[    0.008230] Detected VIPT I-cache on CPU3
  3758	[    0.008246] arch_timer: Enabling local workaround for ARM erratum 858921
  3759	[    0.008253] arch_timer: CPU3: Trapping CNTVCT access
  3760	[    0.008261] CPU3: Booted secondary processor 0x0000000101 [0x410fd092]
  3761	[    0.008884] Detected VIPT I-cache on CPU4
  3762	[    0.008901] arch_timer: Enabling local workaround for ARM erratum 858921
  3763	[    0.008908] arch_timer: CPU4: Trapping CNTVCT access
  3764	[    0.008916] CPU4: Booted secondary processor 0x0000000102 [0x410fd092]
  3765	[    0.009531] Detected VIPT I-cache on CPU5
  3766	[    0.009548] arch_timer: Enabling local workaround for ARM erratum 858921
  3767	[    0.009555] arch_timer: CPU5: Trapping CNTVCT access
  3768	[    0.009563] CPU5: Booted secondary processor 0x0000000103 [0x410fd092]
  3769	[    0.009643] smp: Brought up 1 node, 6 CPUs
  3770	[    0.009660] SMP: Total of 6 processors activated.
  3771	[    0.009668] CPU features: detected: 32-bit EL0 Support
  3772	[    0.009674] CPU features: detected: CRC32 instructions
  3773	[    0.009680] CPU features: detected: 32-bit EL1 Support
  3774	[    0.020895] CPU: All CPU(s) started at EL2
  3775	[    0.020944] alternatives: patching kernel code
  3776	[    0.022889] devtmpfs: initialized
  3777	[    0.030534] Registered cp15_barrier emulation handler
  3778	[    0.030548] Registered setend emulation handler
  3779	[    0.030680] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  3780	[    0.030718] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
  3781	[    0.044641] pinctrl core: initialized pinctrl subsystem
  3782	[    0.045259] DMI not present or invalid.
  3783	[    0.045630] NET: Registered protocol family 16
  3784	[    0.047209] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
  3785	[    0.047481] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
  3786	[    0.047711] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
  3787	[    0.047756] audit: initializing netlink subsys (disabled)
  3788	[    0.047874] audit: type=2000 audit(0.044:1): state=initialized audit_enabled=0 res=1
  3789	[    0.049198] thermal_sys: Registered thermal governor 'fair_share'
  3790	[    0.049205] thermal_sys: Registered thermal governor 'bang_bang'
  3791	[    0.049209] thermal_sys: Registered thermal governor 'step_wise'
  3792	[    0.049213] thermal_sys: Registered thermal governor 'user_space'
  3793	[    0.049658] cpuidle: using governor menu
  3794	[    0.049997] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  3795	[    0.050115] ASID allocator initialised with 65536 entries
  3796	[    0.051075] Serial: AMBA PL011 UART driver
  3797	[    0.084873] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
  3798	[    0.084884] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
  3799	[    0.084889] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
  3800	[    0.084893] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
  3801	[    0.087179] cryptd: max_cpu_qlen set to 1000
  3802	[    0.156242] raid6: neonx8   gen()  2786 MB/s
  3803	[    0.224619] raid6: neonx8   xor()  1601 MB/s
  3804	[    0.292430] raid6: neonx4   gen()  2193 MB/s
  3805	[    0.360467] raid6: neonx4   xor()  2399 MB/s
  3806	[    0.428540] raid6: neonx2   gen()  2559 MB/s
  3807	[    0.496604] raid6: neonx2   xor()  2208 MB/s
  3808	[    0.564668] raid6: neonx1   gen()  2070 MB/s
  3809	[    0.632730] raid6: neonx1   xor()  1726 MB/s
  3810	[    0.700799] raid6: int64x8  gen()  1376 MB/s
  3811	[    0.768864] raid6: int64x8  xor()   735 MB/s
  3812	[    0.836942] raid6: int64x4  gen()  1463 MB/s
  3813	[    0.904999] raid6: int64x4  xor()   733 MB/s
  3814	[    0.973065] raid6: int64x2  gen()  1362 MB/s
  3815	[    1.041138] raid6: int64x2  xor()   619 MB/s
  3816	[    1.109209] raid6: int64x1  gen()  1120 MB/s
  3817	[    1.177258] raid6: int64x1  xor()   462 MB/s
  3818	[    1.177261] raid6: using algorithm neonx8 gen() 2786 MB/s
  3819	[    1.177264] raid6: .... xor() 1601 MB/s, rmw enabled
  3820	[    1.177268] raid6: using neon recovery algorithm
  3821	[    1.177717] ACPI: Interpreter disabled.
  3822	[    1.178497] 5V: supplied by 12V
  3823	[    1.179400] VDDAO_3V3: supplied by 12V
  3824	[    1.179849] iommu: Default domain type: Translated
  3825	[    1.179975] vgaarb: loaded
  3826	[    1.180680] SCSI subsystem initialized
  3827	[    1.180950] usbcore: registered new interface driver usbfs
  3828	[    1.180993] usbcore: registered new interface driver hub
  3829	[    1.181029] usbcore: registered new device driver usb
  3830	[    1.181307] pps_core: LinuxPPS API ver. 1 registered
  3831	[    1.181312] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  3832	[    1.181328] PTP clock support registered
  3833	[    1.181546] EDAC MC: Ver: 3.0.0
  3834	[    1.183255] NetLabel: Initializing
  3835	[    1.183262] NetLabel:  domain hash size = 128
  3836	[    1.183265] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
  3837	[    1.183306] NetLabel:  unlabeled traffic allowed by default
  3838	[    1.183734] clocksource: Switched to clocksource arch_sys_counter
  3839	[    1.183939] VFS: Disk quotas dquot_6.6.0
  3840	[    1.183982] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  3841	[    1.184339] AppArmor: AppArmor Filesystem Enabled
  3842	[    1.184388] pnp: PnP ACPI: disabled
  3843	[    1.190191] NET: Registered protocol family 2
  3844	[    1.190649] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
  3845	[    1.190755] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
  3846	[    1.191011] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
  3847	[    1.191199] TCP: Hash tables configured (established 32768 bind 32768)
  3848	[    1.191349] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
  3849	[    1.191412] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
  3850	[    1.191459] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
  3851	[    1.191602] NET: Registered protocol family 1
  3852	[    1.191622] PCI: CLS 0 bytes, default 64
  3853	[    1.191836] Trying to unpack rootfs image as initramfs...
  3854	[    1.728301] Freeing initrd memory: 13544K
  3855	[    1.729242] kvm [1]: IPA Size Limit: 40 bits
  3856	[    1.729947] kvm [1]: vgic interrupt IRQ9
  3857	[    1.730091] kvm [1]: Hyp mode initialized successfully
  3858	[    1.733994] Initialise system trusted keyrings
  3859	[    1.734030] Key type blacklist registered
  3860	[    1.734145] workingset: timestamp_bits=44 max_order=20 bucket_order=0
  3861	[    1.737353] zbud: loaded
  3862	[    1.738342] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  3863	[    1.738783] fuse: init (API version 7.32)
  3864	[    1.739549] integrity: Platform Keyring initialized
  3865	[    1.767134] xor: measuring software checksum speed
  3866	[    1.769983]    8regs           :  3473 MB/sec
  3867	[    1.772439]    32regs          :  4020 MB/sec
  3868	[    1.775088]    arm64_neon      :  3719 MB/sec
  3869	[    1.775091] xor: using function: 32regs (4020 MB/sec)
  3870	[    1.775099] Key type asymmetric registered
  3871	[    1.775103] Asymmetric key parser 'x509' registered
  3872	[    1.775136] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
  3873	[    1.775219] io scheduler mq-deadline registered
  3874	[    1.775223] io scheduler kyber registered
  3875	[    1.775303] io scheduler bfq registered
  3876	[    1.777838] gpio-447 (usb-hub-reset): hogged as output/high
  3877	[    1.780855] EINJ: ACPI disabled.
  3878	[    1.787120] soc soc0: Amlogic Meson G12B (S922X) Revision 29:a (40:2) Detected
  3879	[    1.788651] VCC_3V3: supplied by VDDAO_3V3
  3880	[    1.788700] FLASH_1V8: supplied by VCC_3V3
  3881	[    1.788729] VCC_1V8: supplied by VCC_3V3
  3882	[    1.788758] VDDAO_1V8: supplied by VDDAO_3V3
  3883	[    1.788786] VDDCPU_A: supplied by regulator-dummy
  3884	[    1.789145] VDDCPU_B: supplied by regulator-dummy
  3885	[    1.789833] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
  3886	[    1.792408] Serial: AMBA driver
  3887	[    1.792702] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart
  3888	[    1.792784] printk: console [ttyAML0] enabled
  3889	[    1.793315] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 33, base_baud = 1500000) is a meson_uart
  3890	[    1.798905] loop: module loaded
  3891	[    1.800925] libphy: Fixed MDIO Bus: probed
  3892	[    1.802030] tun: Universal TUN/TAP device driver, 1.6
  3893	[    1.802687] thunder_xcv, ver 1.0
  3894	[    1.802716] thunder_bgx, ver 1.0
  3895	[    1.802745] nicpf, ver 1.0
  3896	[    1.803204] e1000e: Intel(R) PRO/1000 Network Driver
  3897	[    1.803208] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
  3898	[    1.803252] igb: Intel(R) Gigabit Ethernet Network Driver
  3899	[    1.803255] igb: Copyright (c) 2007-2014 Intel Corporation.
  3900	[    1.803286] igbvf: Intel(R) Gigabit Virtual Function Network Driver
  3901	[    1.803289] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
  3902	[    1.803412] sky2: driver version 1.30
  3903	[    1.803969] VFIO - User Level meta-driver version: 0.3
  3904	[    1.805495] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  3905	[    1.805517] ehci-pci: EHCI PCI platform driver
  3906	[    1.805546] ehci-platform: EHCI generic platform driver
  3907	[    1.805675] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  3908	[    1.805685] ohci-pci: OHCI PCI platform driver
  3909	[    1.805714] ohci-platform: OHCI generic platform driver
  3910	[    1.806128] usbcore: registered new interface driver usb-storage
  3911	[    1.807386] mousedev: PS/2 mouse device common for all mice
  3912	[    1.807711] i2c /dev entries driver
  3913	[    1.812661] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17
  3914	[    1.813332] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz
  3915	[    1.814008] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-1 failed:-17
  3916	[    1.814603] sdhci: Secure Digital Host Controller Interface driver
  3917	[    1.814608] sdhci: Copyright(c) Pierre Ossman
  3918	[    1.814713] Synopsys Designware Multimedia Card Interface Driver
  3919	[    1.815155] sdhci-pltfm: SDHCI platform and OF driver helper
  3920	[    1.815576] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq
  3921	[    1.816636] ledtrig-cpu: registered to indicate activity on CPUs
  3922	[    1.816975] meson-sm: secure-monitor enabled
  3923	[    1.817150] hid: raw HID events driver (C) Jiri Kosina
  3924	[    1.817230] usbcore: registered new interface driver usbhid
  3925	[    1.817233] usbhid: USB HID core driver
  3926	[    1.818212] NET: Registered protocol family 10
  3927	[    1.818604] Segment Routing with IPv6
  3928	[    1.818630] NET: Registered protocol family 17
  3929	[    1.818669] 8021q: 802.1Q VLAN Support v1.8
  3930	[    1.818690] Key type dns_resolver registered
  3931	[    1.818987] registered taskstats version 1
  3932	[    1.818993] Loading compiled-in X.509 certificates
  3933	[    1.820665] Loaded X.509 cert 'Build time autogenerated kernel key: f47c178852ca39740c3546b008122b65f5ed9bce'
  3934	[    1.822249] zswap: loaded using pool zstd/z3fold
  3935	[    1.822402] Key type ._fscrypt registered
  3936	[    1.822404] Key type .fscrypt registered
  3937	[    1.822406] Key type fscrypt-provisioning registered
  3938	[    1.823483] Btrfs loaded, crc32c=crc32c-generic
  3939	[    1.831993] Key type encrypted registered
  3940	[    1.832006] AppArmor: AppArmor sha1 policy hashing enabled
  3941	[    1.838273] HUB_5V: supplied by 5V
  3942	[    1.838479] USB_PWR_EN: supplied by 5V
  3943	[    1.840239] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2
  3944	[    1.840245] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1
  3945	[    1.842928] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator
  3946	[    1.842976] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator
  3947	[    1.843086] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM
  3948	[    1.843700] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  3949	[    1.843712] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
  3950	[    1.843823] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010
  3951	[    1.843846] xhci-hcd xhci-hcd.0.auto: irq 41, io mem 0xff500000
  3952	[    1.843967] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
  3953	[    1.843970] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  3954	[    1.843973] usb usb1: Product: xHCI Host Controller
  3955	[    1.843976] usb usb1: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
  3956	[    1.843978] usb usb1: SerialNumber: xhci-hcd.0.auto
  3957	[    1.844204] hub 1-0:1.0: USB hub found
  3958	[    1.844217] hub 1-0:1.0: 2 ports detected
  3959	[    1.844348] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  3960	[    1.844356] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  3961	[    1.844362] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  3962	[    1.844386] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
  3963	[    1.844416] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
  3964	[    1.844420] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  3965	[    1.844422] usb usb2: Product: xHCI Host Controller
  3966	[    1.844424] usb usb2: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
  3967	[    1.844426] usb usb2: SerialNumber: xhci-hcd.0.auto
  3968	[    1.844593] hub 2-0:1.0: USB hub found
  3969	[    1.844603] hub 2-0:1.0: 1 port detected
  3970	[    1.845716] meson-gx-mmc ffe05000.sd: Got CD GPIO
  3971	[    1.872755] Freeing unused kernel memory: 3328K
  3972	[    1.915819] Run /init as init process
  3973	[    1.915824]   with arguments:
  3974	[    1.915826]     /init
  3975	[    1.915828]   with environment:
  3976	[    1.915830]     HOME=/
  3977	[    1.915831]     TERM=linux
  3978	[    1.915833]     hdmimode=1080p60hz
  3979	[    1.915834]     cvbsmode=576cvbs
  3980	[    1.915836]     max_freq_a53=1896
  3981	[    1.915838]     max_freq_a73=1800
  3982	[    1.915839]     voutmode=hdmi
  3983	[    1.915840]     disablehpd=false
  3984	[    1.915842]     cvbscable=0
  3985	[    1.915843]     overscan=100
  3986	[    1.922453] mmc0: new high speed SDHC card at address b368
  3987	[    1.922987] mmcblk0: mmc0:b368 CBADS 30.0 GiB
  3988	[    1.924684]  mmcblk0: p1
  3989	[    2.053301] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found
  3990	[    2.053311] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found
  3991	[    2.053459] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock
  3992	[    2.054805] meson-vrtc ff8000a8.rtc: registered as rtc1
  3993	[    2.056736] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37
  3994	[    2.056746] meson8b-dwmac ff3f0000.ethernet: 	DWMAC1000
  3995	[    2.056750] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported
  3996	[    2.056753] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported
  3997	[    2.056755] meson8b-dwmac ff3f0000.ethernet: COE Type 2
  3998	[    2.056757] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported
  3999	[    2.056759] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported
  4000	[    2.056819] meson8b-dwmac ff3f0000.ethernet: Normal descriptors
  4001	[    2.056822] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled
  4002	[    2.056825] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
  4003	[    2.057057] libphy: stmmac: probed
  4004	[    2.058413] libphy: mdio_mux: probed
  4005	[    2.079026] rtc-pcf8563 1-0051: registered as rtc0
  4006	[    2.080262] rtc-pcf8563 1-0051: setting system clock to 2021-02-14T14:39:19 UTC (1613313559)
  4007	[    2.183746] usb 1-1: new high-speed USB device number 2 using xhci-hcd
  4008	[    2.264151] libphy: mdio_mux: probed
  4009	[    2.334081] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.04
  4010	[    2.334087] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  4011	[    2.334090] usb 1-1: Product: USB2.1 Hub
  4012	[    2.334092] usb 1-1: Manufacturer: GenesysLogic
  4013	[    2.388587] hub 1-1:1.0: USB hub found
  4014	[    2.388844] hub 1-1:1.0: 4 ports detected
  4015	[    2.453226] random: fast init done
  4016	[    2.459837] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
  4017	[    2.482318] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.04
  4018	[    2.482321] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  4019	[    2.482324] usb 2-1: Product: USB3.1 Hub
  4020	[    2.482326] usb 2-1: Manufacturer: GenesysLogic
  4021	[    2.500562] hub 2-1:1.0: USB hub found
  4022	[    2.500842] hub 2-1:1.0: 4 ports detected
  4023	[    2.607733] usb 1-2: new high-speed USB device number 3 using xhci-hcd
  4024	[    3.271738] usb 1-2: device descriptor read/64, error -71
  4025	[    4.211740] usb 1-2: device descriptor read/64, error -71
  4026	[    4.447726] usb 1-2: new high-speed USB device number 4 using xhci-hcd
  4027	[    5.171739] usb 1-2: device descriptor read/64, error -71
  4028	[    5.855737] usb 1-2: device descriptor read/64, error -71
  4029	[    5.963754] usb usb1-port2: attempt power cycle
  4030	[    6.615726] usb 1-2: new high-speed USB device number 5 using xhci-hcd
  4031	[    6.615854] usb 1-2: Device not responding to setup address.
  4032	[    6.823996] usb 1-2: Device not responding to setup address.
  4033	[    7.031724] usb 1-2: device not accepting address 5, error -71
  4034	[    7.159726] usb 1-2: new high-speed USB device number 6 using xhci-hcd
  4035	[    7.159820] usb 1-2: Device not responding to setup address.
  4036	[    7.367868] usb 1-2: Device not responding to setup address.
  4037	[    7.575724] usb 1-2: device not accepting address 6, error -71
  4038	[    7.575755] usb usb1-port2: unable to enumerate USB device
  4039	[    7.813614] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
  4040	[    8.636555] systemd[1]: Inserted module 'autofs4'
  4041	[    8.683074] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  4042	[    8.683291] systemd[1]: Detected architecture arm64.
  4043	[    8.705578] systemd[1]: Set hostname to <odroidn2>.
  4044	[    9.034843] random: systemd: uninitialized urandom read (16 bytes read)
  4045	[    9.038190] random: systemd: uninitialized urandom read (16 bytes read)
  4046	[    9.038480] systemd[1]: Listening on Journal Socket (/dev/log).
  4047	[    9.038683] random: systemd: uninitialized urandom read (16 bytes read)
  4048	[    9.039524] systemd[1]: Created slice User and Session Slice.
  4049	[    9.039639] systemd[1]: Reached target Swap.
  4050	[    9.039918] systemd[1]: Listening on fsck to fsckd communication Socket.
  4051	[    9.040117] systemd[1]: Listening on udev Kernel Socket.
  4052	[    9.040275] systemd[1]: Listening on initctl Compatibility Named Pipe.
  4053	[    9.040349] systemd[1]: Reached target System Time Synchronized.
  4054	[    9.142488] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
  4055	[    9.654843] zram: Added device: zram0
  4056	[    9.655117] zram: Added device: zram1
  4057	[    9.655315] zram: Added device: zram2
  4058	[    9.663794] pwm-gpio pwmgpio: 1 gpio pwms loaded
  4059	[    9.841039] mc: Linux media interface: v0.10
  4060	[    9.866049] panfrost ffe40000.gpu: clock rate = 24000000
  4061	[    9.866110] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19
  4062	[    9.873148] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0
  4063	[    9.873156] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400
  4064	[    9.873160] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
  4065	[    9.873162] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1
  4066	[    9.887117] meson-saradc ff809000.adc: supply vref not found, using dummy regulator
  4067	[    9.887571] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 0
  4068	[    9.898366] meson-drm ff900000.vpu: Queued 2 outputs on vpu
  4069	[    9.920275] videodev: Linux video capture interface: v2.00
  4070	[    9.955810] Registered IR keymap rc-odroid
  4071	[    9.971701] meson-drm ff900000.vpu: CVBS Output connector not available
  4072	[    9.978138] IR NEC protocol handler initialized
  4073	[    9.999824] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
  4074	[   10.001037] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
  4075	[   10.001456] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
  4076	[   10.001800] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 1
  4077	[   10.001882] meson-drm ff900000.vpu: [drm] Cannot find any crtc or sizes
  4078	[   10.003868] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0
  4079	[   10.004027] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
  4080	[   10.004148] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input0
  4081	[   10.004399] meson-ir ff808000.ir: receiver initialized
  4082	[   10.020517] zram0: detected capacity change from 0 to 1904500736
  4083	[   10.076250] axg-sound-card sound: ASoC: no DMI vendor name!
  4084	[   10.085194] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  4085	[   11.079752] Adding 1859860k swap on /dev/zram0.  Priority:5 extents:1 across:1859860k SSFS
  4086	[   11.142364] zram1: detected capacity change from 0 to 52428800
  4087	[   13.228097] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
  4088	[   13.228118] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
  4089	[   14.185990] systemd[1]: Started Armbian memory supported logging.
  4090	[   14.190073] systemd[1]: Starting Journal Service...
  4091	[   14.245059] systemd[1]: Started Journal Service.
  4092	[   14.272650] systemd-journald[1815]: Received request to flush runtime journal from PID 1
  4093
  4094	### armbian-release:
  4095
  4096	# PLEASE DO NOT EDIT THIS FILE
  4097	BOARD=odroidn2
  4098	BOARD_NAME="Odroid N2"
  4099	BOARDFAMILY=meson-g12b
  4100	BUILD_REPOSITORY_URL=https://github.com/armbian/build
  4101	BUILD_REPOSITORY_COMMIT=5f03d652
  4102	DISTRIBUTION_CODENAME=buster
  4103	DISTRIBUTION_STATUS=supported
  4104	VERSION=21.02.1
  4105	LINUXFAMILY=meson64
  4106	BRANCH=current
  4107	ARCH=arm64
  4108	IMAGE_TYPE=stable
  4109	BOARD_TYPE=conf
  4110	INITRD_ARCH=arm64
  4111	KERNEL_IMAGE_TYPE=Image
  4112
  4113	### boot environment:
  4114
  4115	verbosity=1
  4116	console=both
  4117	overlay_prefix=meson
  4118	rootdev=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c
  4119	rootfstype=ext4
  4120	usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
  4121
  4122	### lsusb:
  4123
  4124	Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc.
  4125	Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  4126	Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
  4127	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  4128
  4129	### lscpu:
  4130
  4131	Architecture:        aarch64
  4132	Byte Order:          Little Endian
  4133	CPU(s):              6
  4134	On-line CPU(s) list: 0-5
  4135	Thread(s) per core:  1
  4136	Core(s) per socket:  3
  4137	Socket(s):           2
  4138	NUMA node(s):        1
  4139	Vendor ID:           ARM
  4140	Model:               4
  4141	Model name:          Cortex-A53
  4142	Stepping:            r0p4
  4143	CPU max MHz:         1992.0000
  4144	CPU min MHz:         100.0000
  4145	BogoMIPS:            48.00
  4146	L1d cache:           unknown size
  4147	L1i cache:           unknown size
  4148	L2 cache:            unknown size
  4149	NUMA node0 CPU(s):   0-5
  4150	Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4151
  4152	### cpuinfo:
  4153
  4154	processor	: 0
  4155	BogoMIPS	: 48.00
  4156	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4157	CPU implementer	: 0x41
  4158	CPU architecture: 8
  4159	CPU variant	: 0x0
  4160	CPU part	: 0xd03
  4161	CPU revision	: 4
  4162
  4163	processor	: 1
  4164	BogoMIPS	: 48.00
  4165	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4166	CPU implementer	: 0x41
  4167	CPU architecture: 8
  4168	CPU variant	: 0x0
  4169	CPU part	: 0xd03
  4170	CPU revision	: 4
  4171
  4172	processor	: 2
  4173	BogoMIPS	: 48.00
  4174	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4175	CPU implementer	: 0x41
  4176	CPU architecture: 8
  4177	CPU variant	: 0x0
  4178	CPU part	: 0xd09
  4179	CPU revision	: 2
  4180
  4181	processor	: 3
  4182	BogoMIPS	: 48.00
  4183	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4184	CPU implementer	: 0x41
  4185	CPU architecture: 8
  4186	CPU variant	: 0x0
  4187	CPU part	: 0xd09
  4188	CPU revision	: 2
  4189
  4190	processor	: 4
  4191	BogoMIPS	: 48.00
  4192	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4193	CPU implementer	: 0x41
  4194	CPU architecture: 8
  4195	CPU variant	: 0x0
  4196	CPU part	: 0xd09
  4197	CPU revision	: 2
  4198
  4199	processor	: 5
  4200	BogoMIPS	: 48.00
  4201	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4202	CPU implementer	: 0x41
  4203	CPU architecture: 8
  4204	CPU variant	: 0x0
  4205	CPU part	: 0xd09
  4206	CPU revision	: 2
  4207
  4208
  4209	### meminfo:
  4210
  4211	MemTotal:        3719728 kB
  4212	MemFree:         3422452 kB
  4213	MemAvailable:    3374548 kB
  4214	Buffers:           11544 kB
  4215	Cached:            41396 kB
  4216	SwapCached:            0 kB
  4217	Active:            30428 kB
  4218	Inactive:         168048 kB
  4219	Active(anon):         88 kB
  4220	Inactive(anon):   150308 kB
  4221	Active(file):      30340 kB
  4222	Inactive(file):    17740 kB
  4223	Unevictable:           0 kB
  4224	Mlocked:               0 kB
  4225	SwapTotal:       1859860 kB
  4226	SwapFree:        1859860 kB
  4227	Dirty:              2244 kB
  4228	Writeback:             0 kB
  4229	AnonPages:        145256 kB
  4230	Mapped:            11048 kB
  4231	Shmem:              4864 kB
  4232	KReclaimable:      12832 kB
  4233	Slab:              38580 kB
  4234	SReclaimable:      12832 kB
  4235	SUnreclaim:        25748 kB
  4236	KernelStack:        2048 kB
  4237	PageTables:         4500 kB
  4238	NFS_Unstable:          0 kB
  4239	Bounce:                0 kB
  4240	WritebackTmp:          0 kB
  4241	CommitLimit:     3719724 kB
  4242	Committed_AS:    4210668 kB
  4243	VmallocTotal:   135290159040 kB
  4244	VmallocUsed:       30864 kB
  4245	VmallocChunk:          0 kB
  4246	Percpu:             1368 kB
  4247	HardwareCorrupted:     0 kB
  4248	AnonHugePages:         0 kB
  4249	ShmemHugePages:        0 kB
  4250	ShmemPmdMapped:        0 kB
  4251	FileHugePages:         0 kB
  4252	FilePmdMapped:         0 kB
  4253	CmaTotal:         917504 kB
  4254	CmaFree:          909824 kB
  4255	HugePages_Total:       0
  4256	HugePages_Free:        0
  4257	HugePages_Rsvd:        0
  4258	HugePages_Surp:        0
  4259	Hugepagesize:       2048 kB
  4260	Hugetlb:               0 kB
  4261
  4262	### virtual memory:
  4263
  4264	vm.admin_reserve_kbytes = 8192
  4265	vm.block_dump = 0
  4266	vm.compaction_proactiveness = 20
  4267	vm.compact_unevictable_allowed = 1
  4268	vm.dirty_background_bytes = 0
  4269	vm.dirty_background_ratio = 10
  4270	vm.dirty_bytes = 0
  4271	vm.dirty_expire_centisecs = 3000
  4272	vm.dirty_ratio = 20
  4273	vm.dirtytime_expire_seconds = 43200
  4274	vm.dirty_writeback_centisecs = 500
  4275	vm.extfrag_threshold = 500
  4276	vm.hugetlb_shm_group = 0
  4277	vm.laptop_mode = 0
  4278	vm.legacy_va_layout = 0
  4279	vm.lowmem_reserve_ratio = 256	256	32	0
  4280	vm.max_map_count = 65530
  4281	vm.memory_failure_early_kill = 0
  4282	vm.memory_failure_recovery = 1
  4283	vm.min_free_kbytes = 45056
  4284	vm.min_slab_ratio = 5
  4285	vm.min_unmapped_ratio = 1
  4286	vm.mmap_min_addr = 4096
  4287	vm.mmap_rnd_bits = 18
  4288	vm.mmap_rnd_compat_bits = 11
  4289	vm.nr_hugepages = 0
  4290	vm.nr_hugepages_mempolicy = 0
  4291	vm.nr_overcommit_hugepages = 0
  4292	vm.numa_stat = 1
  4293	vm.numa_zonelist_order = Node
  4294	vm.oom_dump_tasks = 1
  4295	vm.oom_kill_allocating_task = 0
  4296	vm.overcommit_kbytes = 0
  4297	vm.overcommit_memory = 0
  4298	vm.overcommit_ratio = 50
  4299	vm.page-cluster = 0
  4300	vm.page_lock_unfairness = 5
  4301	vm.panic_on_oom = 0
  4302	vm.percpu_pagelist_fraction = 0
  4303	vm.stat_interval = 1
  4304	vm.swappiness = 100
  4305	vm.user_reserve_kbytes = 115025
  4306	vm.vfs_cache_pressure = 100
  4307	vm.watermark_boost_factor = 15000
  4308	vm.watermark_scale_factor = 10
  4309	vm.zone_reclaim_mode = 0
  4310
  4311	### ip addr:
  4312
  4313	1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  4314	    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  4315	    inet XXX.XXX.0.1/8 scope host lo
  4316	       valid_lft forever preferred_lft forever
  4317	    inet6 ::1/128 scope host
  4318	       valid_lft forever preferred_lft forever
  4319	2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  4320	    link/ether 00:1e:06:42:03:f8 brd ff:ff:ff:ff:ff:ff
  4321
  4322	### partitions:
  4323
  4324	major minor  #blocks  name
  4325
  4326	 179        0   31464960 mmcblk0
  4327	 179        1   31146208 mmcblk0p1
  4328	 252        0    1859864 zram0
  4329	 252        1      51200 zram1
  4330
  4331	### df:
  4332
  4333	udev            1.4G     0  1.4G   0% /dev
  4334	tmpfs           364M  4.9M  359M   2% /run
  4335	/dev/mmcblk0p1   30G  1.7G   28G   6% /
  4336	tmpfs           1.8G     0  1.8G   0% /dev/shm
  4337	tmpfs           5.0M  4.0K  5.0M   1% /run/lock
  4338	tmpfs           1.8G     0  1.8G   0% /sys/fs/cgroup
  4339	tmpfs           1.8G     0  1.8G   0% /tmp
  4340	/dev/zram1       49M  2.3M   43M   5% /var/log
  4341
  4342	### lsblk:
  4343
  4344	NAME        FSTYPE  SIZE MOUNTPOINT UUID
  4345	mmcblk0              30G
  4346	└─mmcblk0p1 ext4   29.7G /          bd34953d-41be-49d6-b1c0-c0c28a5e239c
  4347	zram1                50M /var/log
  4348
  4349	### zramctl:
  4350
  4351	NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
  4352	/dev/zram1 zstd           50M  132K  698B   36K       6 /var/log
  4353	/dev/zram0 lzo-rle       1.8G    4K   74B   12K       6 [SWAP]
  4354
  4355	### mtab:
  4356
  4357	/dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  4358	/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  4359	/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
  4360
  4361	### mmc0:b368 info:
  4362
  4363	               fwrev: 0x0
  4364	              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=CBADS MODALIAS=mmc:block
  4365	                 cid: 6f0303434241445310aa002b4d013b00
  4366	                 rca: 0xb368
  4367	                 csd: 400e005a5b590000f00e7f800a404000
  4368	              manfid: 0x00006f
  4369	                 ocr: 0x00200000
  4370	preferred_erase_size: 2097152
  4371	                type: SD
  4372	               hwrev: 0x1
  4373	                date: 11/2019
  4374	                 dsr: 0x404
  4375	          erase_size: 512
  4376	               oemid: 0x0303
  4377	              serial: 0xaa002b4d
  4378	                 ssr: 00000000000000280402800100fd180a001e00000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  4379	                 scr: 02b5800300000000
  4380	                name: CBADS
  4381
  4382	### Boot system health:
  4383
  4384	Time       big.LITTLE   load %cpu %sys %usr %nice %io %irq   CPU  C.St.
  4385	14:39:32: 1908/1992MHz  1.56  15%   7%   3%   0%   4%   0% 33.3°C  0/11
  4386	14:39:33: 1908/1992MHz  1.56  79%  34%   6%   0%  36%   0% 33.2°C  0/11
  4387	14:39:33: 1908/1992MHz  1.56  66%  17%   1%   0%  45%   0% 30.4°C  0/11
  4388	14:39:33: 1908/1992MHz  1.56  55%   6%   7%   0%  41%   1% 30.1°C  0/11
  4389	14:39:34: 1908/1992MHz  1.56  55%   6%   4%   0%  44%   0% 29.5°C  0/11
  4390
  4391	### Activated 1 lzo-rle zram swap devices with 1816 MB each
  4392
  4393	### Activated Armbian ramlog partition with zstd compression
  4394
  4395	Sun 14 Feb 2021 02:45:08 PM GMT | Odroid N2 | 21.02.1 | arm64 | aarch64 | 5.10.12-meson64
  4396
  4397	### dmesg:
  4398
  4399	[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
  4400	[    0.000000] Linux version 5.10.12-meson64 (root@beast) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #21.02.1 SMP PREEMPT Wed Feb 3 21:06:36 CET 2021
  4401	[    0.000000] Machine model: Hardkernel ODROID-N2
  4402	[    0.000000] efi: UEFI not found.
  4403	[    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
  4404	[    0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB
  4405	[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
  4406	[    0.000000] NUMA: No NUMA configuration found
  4407	[    0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ed7fffff]
  4408	[    0.000000] NUMA: NODE_DATA [mem 0xb502f100-0xb5030fff]
  4409	[    0.000000] Zone ranges:
  4410	[    0.000000]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
  4411	[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000ed7fffff]
  4412	[    0.000000]   Normal   empty
  4413	[    0.000000] Movable zone start for each node
  4414	[    0.000000] Early memory node ranges
  4415	[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000004ffffff]
  4416	[    0.000000]   node   0: [mem 0x0000000005300000-0x00000000ed7fffff]
  4417	[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ed7fffff]
  4418	[    0.000000] On node 0 totalpages: 972032
  4419	[    0.000000]   DMA zone: 4096 pages used for memmap
  4420	[    0.000000]   DMA zone: 0 pages reserved
  4421	[    0.000000]   DMA zone: 261376 pages, LIFO batch:63
  4422	[    0.000000]   DMA32 zone: 11104 pages used for memmap
  4423	[    0.000000]   DMA32 zone: 710656 pages, LIFO batch:63
  4424	[    0.000000] psci: probing for conduit method from DT.
  4425	[    0.000000] psci: PSCIv1.0 detected in firmware.
  4426	[    0.000000] psci: Using standard PSCI v0.2 function IDs
  4427	[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
  4428	[    0.000000] psci: SMC Calling Convention v1.1
  4429	[    0.000000] percpu: Embedded 23 pages/cpu s56728 r8192 d29288 u94208
  4430	[    0.000000] pcpu-alloc: s56728 r8192 d29288 u94208 alloc=23*4096
  4431	[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
  4432	[    0.000000] Detected VIPT I-cache on CPU0
  4433	[    0.000000] CPU features: detected: ARM erratum 845719
  4434	[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 956832
  4435	[    0.000000] Policy zone: DMA32
  4436	[    0.000000] Kernel command line: root=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c rootwait rootfstype=ext4 console=ttyAML0,115200n8 console=tty1 loglevel=1  no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=1080p60hz cvbsmode=576cvbs max_freq_a53=1896 max_freq_a73=1800 maxcpus=6 voutmode=hdmi  disablehpd=false  cvbscable=0 overscan=100 consoleblank=0
  4437	[    0.000000] Kernel parameter elevator= does not have any effect anymore.
  4438	               Please use sysfs to set IO scheduler for individual devices.
  4439	[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
  4440	[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
  4441	[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
  4442	[    0.000000] software IO TLB: mapped [mem 0x0000000038ac5000-0x000000003cac5000] (64MB)
  4443	[    0.000000] Memory: 2785352K/3888128K available (14144K kernel code, 1760K rwdata, 5508K rodata, 3328K init, 592K bss, 185272K reserved, 917504K cma-reserved)
  4444	[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
  4445	[    0.000000] rcu: Preemptible hierarchical RCU implementation.
  4446	[    0.000000] rcu: 	RCU event tracing is enabled.
  4447	[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
  4448	[    0.000000] 	Trampoline variant of Tasks RCU enabled.
  4449	[    0.000000] 	Rude variant of Tasks RCU enabled.
  4450	[    0.000000] 	Tracing variant of Tasks RCU enabled.
  4451	[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  4452	[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
  4453	[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
  4454	[    0.000000] GIC: Using split EOI/Deactivate mode
  4455	[    0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized
  4456	[    0.000000] random: get_random_bytes called from start_kernel+0x378/0x538 with crng_init=0
  4457	[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
  4458	[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  4459	[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  4460	[    0.000246] Console: colour dummy device 80x25
  4461	[    0.000281] printk: console [tty1] enabled
  4462	[    0.000368] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
  4463	[    0.000380] pid_max: default: 32768 minimum: 301
  4464	[    0.000462] LSM: Security Framework initializing
  4465	[    0.000488] Yama: becoming mindful.
  4466	[    0.000579] AppArmor: AppArmor initialized
  4467	[    0.000629] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
  4468	[    0.000648] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
  4469	[    0.002641] rcu: Hierarchical SRCU implementation.
  4470	[    0.005107] EFI services will not be available.
  4471	[    0.005531] smp: Bringing up secondary CPUs ...
  4472	[    0.006207] Detected VIPT I-cache on CPU1
  4473	[    0.006265] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
  4474	[    0.007461] CPU features: detected: ARM erratum 858921
  4475	[    0.007469] CPU features: detected: Spectre-v2
  4476	[    0.007473] CPU features: detected: Spectre-v4
  4477	[    0.007479] Detected VIPT I-cache on CPU2
  4478	[    0.007504] arch_timer: Enabling local workaround for ARM erratum 858921
  4479	[    0.007519] arch_timer: CPU2: Trapping CNTVCT access
  4480	[    0.007533] CPU2: Booted secondary processor 0x0000000100 [0x410fd092]
  4481	[    0.008242] Detected VIPT I-cache on CPU3
  4482	[    0.008258] arch_timer: Enabling local workaround for ARM erratum 858921
  4483	[    0.008265] arch_timer: CPU3: Trapping CNTVCT access
  4484	[    0.008273] CPU3: Booted secondary processor 0x0000000101 [0x410fd092]
  4485	[    0.008899] Detected VIPT I-cache on CPU4
  4486	[    0.008916] arch_timer: Enabling local workaround for ARM erratum 858921
  4487	[    0.008923] arch_timer: CPU4: Trapping CNTVCT access
  4488	[    0.008931] CPU4: Booted secondary processor 0x0000000102 [0x410fd092]
  4489	[    0.009545] Detected VIPT I-cache on CPU5
  4490	[    0.009561] arch_timer: Enabling local workaround for ARM erratum 858921
  4491	[    0.009568] arch_timer: CPU5: Trapping CNTVCT access
  4492	[    0.009576] CPU5: Booted secondary processor 0x0000000103 [0x410fd092]
  4493	[    0.009657] smp: Brought up 1 node, 6 CPUs
  4494	[    0.009675] SMP: Total of 6 processors activated.
  4495	[    0.009683] CPU features: detected: 32-bit EL0 Support
  4496	[    0.009689] CPU features: detected: CRC32 instructions
  4497	[    0.009695] CPU features: detected: 32-bit EL1 Support
  4498	[    0.020982] CPU: All CPU(s) started at EL2
  4499	[    0.021032] alternatives: patching kernel code
  4500	[    0.022977] devtmpfs: initialized
  4501	[    0.030627] Registered cp15_barrier emulation handler
  4502	[    0.030641] Registered setend emulation handler
  4503	[    0.030774] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  4504	[    0.030812] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
  4505	[    0.044748] pinctrl core: initialized pinctrl subsystem
  4506	[    0.045493] DMI not present or invalid.
  4507	[    0.045868] NET: Registered protocol family 16
  4508	[    0.047348] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
  4509	[    0.047619] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
  4510	[    0.047848] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
  4511	[    0.047895] audit: initializing netlink subsys (disabled)
  4512	[    0.048003] audit: type=2000 audit(0.048:1): state=initialized audit_enabled=0 res=1
  4513	[    0.049312] thermal_sys: Registered thermal governor 'fair_share'
  4514	[    0.049322] thermal_sys: Registered thermal governor 'bang_bang'
  4515	[    0.049326] thermal_sys: Registered thermal governor 'step_wise'
  4516	[    0.049329] thermal_sys: Registered thermal governor 'user_space'
  4517	[    0.049766] cpuidle: using governor menu
  4518	[    0.050104] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  4519	[    0.050224] ASID allocator initialised with 65536 entries
  4520	[    0.051184] Serial: AMBA PL011 UART driver
  4521	[    0.084726] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
  4522	[    0.084738] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
  4523	[    0.084742] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
  4524	[    0.084746] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
  4525	[    0.086721] cryptd: max_cpu_qlen set to 1000
  4526	[    0.156256] raid6: neonx8   gen()  2782 MB/s
  4527	[    0.224294] raid6: neonx8   xor()  2041 MB/s
  4528	[    0.292360] raid6: neonx4   gen()  2994 MB/s
  4529	[    0.360426] raid6: neonx4   xor()  2349 MB/s
  4530	[    0.428494] raid6: neonx2   gen()  2581 MB/s
  4531	[    0.496556] raid6: neonx2   xor()  2144 MB/s
  4532	[    0.564620] raid6: neonx1   gen()  2016 MB/s
  4533	[    0.632689] raid6: neonx1   xor()  1720 MB/s
  4534	[    0.700759] raid6: int64x8  gen()  1375 MB/s
  4535	[    0.768818] raid6: int64x8  xor()   735 MB/s
  4536	[    0.836907] raid6: int64x4  gen()  1463 MB/s
  4537	[    0.904956] raid6: int64x4  xor()   733 MB/s
  4538	[    0.973027] raid6: int64x2  gen()  1363 MB/s
  4539	[    1.041091] raid6: int64x2  xor()   619 MB/s
  4540	[    1.109148] raid6: int64x1  gen()  1120 MB/s
  4541	[    1.177210] raid6: int64x1  xor()   462 MB/s
  4542	[    1.177214] raid6: using algorithm neonx4 gen() 2994 MB/s
  4543	[    1.177217] raid6: .... xor() 2349 MB/s, rmw enabled
  4544	[    1.177221] raid6: using neon recovery algorithm
  4545	[    1.177668] ACPI: Interpreter disabled.
  4546	[    1.178455] 5V: supplied by 12V
  4547	[    1.179359] VDDAO_3V3: supplied by 12V
  4548	[    1.179825] iommu: Default domain type: Translated
  4549	[    1.179953] vgaarb: loaded
  4550	[    1.180893] SCSI subsystem initialized
  4551	[    1.181180] usbcore: registered new interface driver usbfs
  4552	[    1.181222] usbcore: registered new interface driver hub
  4553	[    1.181259] usbcore: registered new device driver usb
  4554	[    1.181522] pps_core: LinuxPPS API ver. 1 registered
  4555	[    1.181526] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  4556	[    1.181550] PTP clock support registered
  4557	[    1.181765] EDAC MC: Ver: 3.0.0
  4558	[    1.183088] NetLabel: Initializing
  4559	[    1.183096] NetLabel:  domain hash size = 128
  4560	[    1.183099] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
  4561	[    1.183140] NetLabel:  unlabeled traffic allowed by default
  4562	[    1.183563] clocksource: Switched to clocksource arch_sys_counter
  4563	[    1.183769] VFS: Disk quotas dquot_6.6.0
  4564	[    1.183812] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  4565	[    1.184171] AppArmor: AppArmor Filesystem Enabled
  4566	[    1.184220] pnp: PnP ACPI: disabled
  4567	[    1.189544] NET: Registered protocol family 2
  4568	[    1.190003] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
  4569	[    1.190113] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
  4570	[    1.190369] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
  4571	[    1.190556] TCP: Hash tables configured (established 32768 bind 32768)
  4572	[    1.190708] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
  4573	[    1.190773] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
  4574	[    1.190820] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
  4575	[    1.190962] NET: Registered protocol family 1
  4576	[    1.190981] PCI: CLS 0 bytes, default 64
  4577	[    1.191103] Trying to unpack rootfs image as initramfs...
  4578	[    1.728150] Freeing initrd memory: 13544K
  4579	[    1.729083] kvm [1]: IPA Size Limit: 40 bits
  4580	[    1.729796] kvm [1]: vgic interrupt IRQ9
  4581	[    1.729929] kvm [1]: Hyp mode initialized successfully
  4582	[    1.733891] Initialise system trusted keyrings
  4583	[    1.733923] Key type blacklist registered
  4584	[    1.734025] workingset: timestamp_bits=44 max_order=20 bucket_order=0
  4585	[    1.737229] zbud: loaded
  4586	[    1.738200] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  4587	[    1.738633] fuse: init (API version 7.32)
  4588	[    1.739404] integrity: Platform Keyring initialized
  4589	[    1.766653] xor: measuring software checksum speed
  4590	[    1.769502]    8regs           :  3473 MB/sec
  4591	[    1.771958]    32regs          :  4021 MB/sec
  4592	[    1.774608]    arm64_neon      :  3719 MB/sec
  4593	[    1.774611] xor: using function: 32regs (4021 MB/sec)
  4594	[    1.774619] Key type asymmetric registered
  4595	[    1.774623] Asymmetric key parser 'x509' registered
  4596	[    1.774656] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
  4597	[    1.774782] io scheduler mq-deadline registered
  4598	[    1.774786] io scheduler kyber registered
  4599	[    1.774866] io scheduler bfq registered
  4600	[    1.777423] gpio-447 (usb-hub-reset): hogged as output/high
  4601	[    1.780380] EINJ: ACPI disabled.
  4602	[    1.786659] soc soc0: Amlogic Meson G12B (S922X) Revision 29:a (40:2) Detected
  4603	[    1.788113] VCC_3V3: supplied by VDDAO_3V3
  4604	[    1.788147] FLASH_1V8: supplied by VCC_3V3
  4605	[    1.788183] VCC_1V8: supplied by VCC_3V3
  4606	[    1.788211] VDDAO_1V8: supplied by VDDAO_3V3
  4607	[    1.788250] VDDCPU_A: supplied by regulator-dummy
  4608	[    1.788617] VDDCPU_B: supplied by regulator-dummy
  4609	[    1.789299] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
  4610	[    1.791644] Serial: AMBA driver
  4611	[    1.791941] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart
  4612	[    1.792031] printk: console [ttyAML0] enabled
  4613	[    1.792555] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 33, base_baud = 1500000) is a meson_uart
  4614	[    1.797800] loop: module loaded
  4615	[    1.799849] libphy: Fixed MDIO Bus: probed
  4616	[    1.800903] tun: Universal TUN/TAP device driver, 1.6
  4617	[    1.801535] thunder_xcv, ver 1.0
  4618	[    1.801567] thunder_bgx, ver 1.0
  4619	[    1.801592] nicpf, ver 1.0
  4620	[    1.802046] e1000e: Intel(R) PRO/1000 Network Driver
  4621	[    1.802049] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
  4622	[    1.802084] igb: Intel(R) Gigabit Ethernet Network Driver
  4623	[    1.802088] igb: Copyright (c) 2007-2014 Intel Corporation.
  4624	[    1.802116] igbvf: Intel(R) Gigabit Virtual Function Network Driver
  4625	[    1.802119] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
  4626	[    1.802238] sky2: driver version 1.30
  4627	[    1.802562] VFIO - User Level meta-driver version: 0.3
  4628	[    1.804005] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  4629	[    1.804028] ehci-pci: EHCI PCI platform driver
  4630	[    1.804065] ehci-platform: EHCI generic platform driver
  4631	[    1.804207] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  4632	[    1.804217] ohci-pci: OHCI PCI platform driver
  4633	[    1.804249] ohci-platform: OHCI generic platform driver
  4634	[    1.804674] usbcore: registered new interface driver usb-storage
  4635	[    1.805967] mousedev: PS/2 mouse device common for all mice
  4636	[    1.806337] i2c /dev entries driver
  4637	[    1.811440] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17
  4638	[    1.812144] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz
  4639	[    1.812825] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-1 failed:-17
  4640	[    1.813403] sdhci: Secure Digital Host Controller Interface driver
  4641	[    1.813409] sdhci: Copyright(c) Pierre Ossman
  4642	[    1.813892] Synopsys Designware Multimedia Card Interface Driver
  4643	[    1.814354] sdhci-pltfm: SDHCI platform and OF driver helper
  4644	[    1.814798] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq
  4645	[    1.815940] ledtrig-cpu: registered to indicate activity on CPUs
  4646	[    1.816223] meson-sm: secure-monitor enabled
  4647	[    1.816375] hid: raw HID events driver (C) Jiri Kosina
  4648	[    1.816454] usbcore: registered new interface driver usbhid
  4649	[    1.816455] usbhid: USB HID core driver
  4650	[    1.817335] NET: Registered protocol family 10
  4651	[    1.817752] Segment Routing with IPv6
  4652	[    1.817779] NET: Registered protocol family 17
  4653	[    1.817833] 8021q: 802.1Q VLAN Support v1.8
  4654	[    1.817855] Key type dns_resolver registered
  4655	[    1.818124] registered taskstats version 1
  4656	[    1.818129] Loading compiled-in X.509 certificates
  4657	[    1.819896] Loaded X.509 cert 'Build time autogenerated kernel key: f47c178852ca39740c3546b008122b65f5ed9bce'
  4658	[    1.821514] zswap: loaded using pool zstd/z3fold
  4659	[    1.821693] Key type ._fscrypt registered
  4660	[    1.821696] Key type .fscrypt registered
  4661	[    1.821698] Key type fscrypt-provisioning registered
  4662	[    1.822771] Btrfs loaded, crc32c=crc32c-generic
  4663	[    1.831825] Key type encrypted registered
  4664	[    1.831838] AppArmor: AppArmor sha1 policy hashing enabled
  4665	[    1.838078] HUB_5V: supplied by 5V
  4666	[    1.838293] USB_PWR_EN: supplied by 5V
  4667	[    1.840078] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2
  4668	[    1.840088] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1
  4669	[    1.842788] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator
  4670	[    1.842846] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator
  4671	[    1.842960] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM
  4672	[    1.843661] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  4673	[    1.843675] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
  4674	[    1.843765] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010
  4675	[    1.843788] xhci-hcd xhci-hcd.0.auto: irq 41, io mem 0xff500000
  4676	[    1.843917] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
  4677	[    1.843921] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  4678	[    1.843924] usb usb1: Product: xHCI Host Controller
  4679	[    1.843926] usb usb1: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
  4680	[    1.843928] usb usb1: SerialNumber: xhci-hcd.0.auto
  4681	[    1.844123] hub 1-0:1.0: USB hub found
  4682	[    1.844137] hub 1-0:1.0: 2 ports detected
  4683	[    1.844270] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  4684	[    1.844276] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  4685	[    1.844282] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  4686	[    1.844305] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
  4687	[    1.844335] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
  4688	[    1.844338] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  4689	[    1.844341] usb usb2: Product: xHCI Host Controller
  4690	[    1.844343] usb usb2: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
  4691	[    1.844345] usb usb2: SerialNumber: xhci-hcd.0.auto
  4692	[    1.844498] hub 2-0:1.0: USB hub found
  4693	[    1.844510] hub 2-0:1.0: 1 port detected
  4694	[    1.845616] meson-gx-mmc ffe05000.sd: Got CD GPIO
  4695	[    1.872580] Freeing unused kernel memory: 3328K
  4696	[    1.907635] Run /init as init process
  4697	[    1.907639]   with arguments:
  4698	[    1.907641]     /init
  4699	[    1.907643]   with environment:
  4700	[    1.907645]     HOME=/
  4701	[    1.907647]     TERM=linux
  4702	[    1.907649]     hdmimode=1080p60hz
  4703	[    1.907650]     cvbsmode=576cvbs
  4704	[    1.907652]     max_freq_a53=1896
  4705	[    1.907654]     max_freq_a73=1800
  4706	[    1.907655]     voutmode=hdmi
  4707	[    1.907656]     disablehpd=false
  4708	[    1.907658]     cvbscable=0
  4709	[    1.907659]     overscan=100
  4710	[    1.937743] mmc0: new ultra high speed SDR25 SDHC card at address b368
  4711	[    1.938323] mmcblk0: mmc0:b368 CBADS 30.0 GiB
  4712	[    1.940164]  mmcblk0: p1
  4713	[    2.063353] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found
  4714	[    2.063362] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found
  4715	[    2.063471] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock
  4716	[    2.067937] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37
  4717	[    2.067949] meson8b-dwmac ff3f0000.ethernet: 	DWMAC1000
  4718	[    2.067953] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported
  4719	[    2.067957] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported
  4720	[    2.067960] meson8b-dwmac ff3f0000.ethernet: COE Type 2
  4721	[    2.067963] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported
  4722	[    2.067965] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported
  4723	[    2.068058] meson8b-dwmac ff3f0000.ethernet: Normal descriptors
  4724	[    2.068061] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled
  4725	[    2.068065] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
  4726	[    2.068360] libphy: stmmac: probed
  4727	[    2.069206] meson-vrtc ff8000a8.rtc: registered as rtc1
  4728	[    2.076879] libphy: mdio_mux: probed
  4729	[    2.098889] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
  4730	[    2.099066] rtc-pcf8563 1-0051: registered as rtc0
  4731	[    2.100234] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
  4732	[    2.100242] rtc-pcf8563 1-0051: hctosys: unable to read the hardware clock
  4733	[    2.102996] random: fast init done
  4734	[    2.183574] usb 1-1: new high-speed USB device number 2 using xhci-hcd
  4735	[    2.292163] libphy: mdio_mux: probed
  4736	[    2.333962] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.04
  4737	[    2.333969] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  4738	[    2.333972] usb 1-1: Product: USB2.1 Hub
  4739	[    2.333974] usb 1-1: Manufacturer: GenesysLogic
  4740	[    2.388502] hub 1-1:1.0: USB hub found
  4741	[    2.388720] hub 1-1:1.0: 4 ports detected
  4742	[    2.459684] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
  4743	[    2.482160] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.04
  4744	[    2.482165] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  4745	[    2.482168] usb 2-1: Product: USB3.1 Hub
  4746	[    2.482171] usb 2-1: Manufacturer: GenesysLogic
  4747	[    2.500541] hub 2-1:1.0: USB hub found
  4748	[    2.500831] hub 2-1:1.0: 4 ports detected
  4749	[    2.607565] usb 1-2: new high-speed USB device number 3 using xhci-hcd
  4750	[    2.756006] usb 1-2: New USB device found, idVendor=2013, idProduct=025f, bcdDevice= 1.00
  4751	[    2.756009] usb 1-2: New USB device strings: Mfr=3, Product=1, SerialNumber=2
  4752	[    2.756012] usb 1-2: Product: PCTV 292e
  4753	[    2.756014] usb 1-2: Manufacturer: PCTV
  4754	[    2.756016] usb 1-2: SerialNumber: 0011356964
  4755	[    3.163492] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
  4756	[    3.967637] systemd[1]: System time before build time, advancing clock.
  4757	[    3.982491] systemd[1]: Inserted module 'autofs4'
  4758	[    4.029017] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  4759	[    4.029241] systemd[1]: Detected architecture arm64.
  4760	[    4.057405] systemd[1]: Set hostname to <odroidn2>.
  4761	[    4.384621] random: systemd: uninitialized urandom read (16 bytes read)
  4762	[    4.387957] random: systemd: uninitialized urandom read (16 bytes read)
  4763	[    4.388240] systemd[1]: Listening on udev Control Socket.
  4764	[    4.388564] random: systemd: uninitialized urandom read (16 bytes read)
  4765	[    4.388689] systemd[1]: Listening on Journal Audit Socket.
  4766	[    4.388855] systemd[1]: Listening on udev Kernel Socket.
  4767	[    4.389741] systemd[1]: Created slice User and Session Slice.
  4768	[    4.390571] systemd[1]: Created slice system-getty.slice.
  4769	[    4.390759] systemd[1]: Listening on initctl Compatibility Named Pipe.
  4770	[    4.391008] systemd[1]: Listening on fsck to fsckd communication Socket.
  4771	[    4.487915] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
  4772	[    4.966626] zram: Added device: zram0
  4773	[    4.966831] zram: Added device: zram1
  4774	[    4.967025] zram: Added device: zram2
  4775	[    5.072509] pwm-gpio pwmgpio: 1 gpio pwms loaded
  4776	[    5.203494] meson-saradc ff809000.adc: supply vref not found, using dummy regulator
  4777	[    5.223738] mc: Linux media interface: v0.10
  4778	[    5.250472] zram0: detected capacity change from 0 to 1904500736
  4779	[    5.275590] Registered IR keymap rc-odroid
  4780	[    5.285304] videodev: Linux video capture interface: v2.00
  4781	[    5.294083] panfrost ffe40000.gpu: clock rate = 24000000
  4782	[    5.294135] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19
  4783	[    5.294733] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0
  4784	[    5.294739] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400
  4785	[    5.294743] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
  4786	[    5.294745] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1
  4787	[    5.298580] IR NEC protocol handler initialized
  4788	[    5.309754] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 0
  4789	[    5.326417] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0
  4790	[    5.326510] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
  4791	[    5.326568] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input0
  4792	[    5.329003] meson-ir ff808000.ir: receiver initialized
  4793	[    5.340946] meson-drm ff900000.vpu: Queued 2 outputs on vpu
  4794	[    5.406987] meson-drm ff900000.vpu: CVBS Output connector not available
  4795	[    5.435623] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
  4796	[    5.435951] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
  4797	[    5.436194] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
  4798	[    5.436392] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 1
  4799	[    5.436445] meson-drm ff900000.vpu: [drm] Cannot find any crtc or sizes
  4800	[    5.441615] em28xx 1-2:1.0: New device PCTV PCTV 292e @ 480 Mbps (2013:025f, interface 0, class 0)
  4801	[    5.441622] em28xx 1-2:1.0: DVB interface 0 found: isoc
  4802	[    5.469573] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  4803	[    5.470988] axg-sound-card sound: ASoC: no DMI vendor name!
  4804	[    5.503744] em28xx 1-2:1.0: chip ID is em28178
  4805	[    6.363590] Adding 1859860k swap on /dev/zram0.  Priority:5 extents:1 across:1859860k SSFS
  4806	[    6.427252] zram1: detected capacity change from 0 to 52428800
  4807	[    7.525840] em28xx 1-2:1.0: EEPROM ID = 26 00 01 00, EEPROM hash = 0x8d0cfd04
  4808	[    7.525848] em28xx 1-2:1.0: EEPROM info:
  4809	[    7.525852] em28xx 1-2:1.0: 	microcode start address = 0x0004, boot configuration = 0x01
  4810	[    7.531952] em28xx 1-2:1.0: 	AC97 audio (5 sample rates)
  4811	[    7.531956] em28xx 1-2:1.0: 	500mA max power
  4812	[    7.531960] em28xx 1-2:1.0: 	Table at offset 0x27, strings=0x146a, 0x1888, 0x0a7e
  4813	[    7.591589] em28xx 1-2:1.0: Identified as PCTV tripleStick (292e) (card=94)
  4814	[    7.591599] em28xx 1-2:1.0: dvb set to isoc mode.
  4815	[    7.591824] usbcore: registered new interface driver em28xx
  4816	[    7.618032] em28xx 1-2:1.0: Binding DVB extension
  4817	[    7.631250] i2c i2c-4: Added multiplexed i2c bus 5
  4818	[    7.631258] si2168 4-0064: Silicon Labs Si2168-B40 successfully identified
  4819	[    7.631261] si2168 4-0064: firmware version: B 4.0.2
  4820	[    7.639603] si2157 5-0060: Silicon Labs Si2147/2148/2157/2158 successfully attached
  4821	[    7.639650] dvbdev: DVB: registering new adapter (1-2:1.0)
  4822	[    7.639657] em28xx 1-2:1.0: DVB: registering adapter 0 frontend 0 (Silicon Labs Si2168)...
  4823	[    7.639663] dvbdev: dvb_create_media_entity: media entity 'Silicon Labs Si2168' registered.
  4824	[    7.640299] dvbdev: dvb_create_media_entity: media entity 'dvb-demux' registered.
  4825	[    7.642589] em28xx 1-2:1.0: DVB extension successfully initialized
  4826	[    7.642598] em28xx: Registered (Em28xx dvb Extension) extension
  4827	[    7.649581] em28xx 1-2:1.0: Registering input extension
  4828	[    7.679566] Registered IR keymap rc-pinnacle-pctv-hd
  4829	[    7.679764] rc rc1: PCTV tripleStick (292e) as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-2/1-2:1.0/rc/rc1
  4830	[    7.679841] rc rc1: lirc_dev: driver em28xx registered at minor = 1, scancode receiver, no transmitter
  4831	[    7.679905] input: PCTV tripleStick (292e) as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-2/1-2:1.0/rc/rc1/input1
  4832	[    7.680022] em28xx 1-2:1.0: Input extension successfully initialized
  4833	[    7.680029] em28xx: Registered (Em28xx Input Extension) extension
  4834	[    8.510015] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
  4835	[    8.510035] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
  4836	[    9.474365] systemd[1]: Started Armbian memory supported logging.
  4837	[    9.476659] systemd[1]: Starting Journal Service...
  4838	[    9.544130] systemd[1]: Started Journal Service.
  4839	[    9.569191] systemd-journald[1823]: Received request to flush runtime journal from PID 1
  4840
  4841	### armbian-release:
  4842
  4843	# PLEASE DO NOT EDIT THIS FILE
  4844	BOARD=odroidn2
  4845	BOARD_NAME="Odroid N2"
  4846	BOARDFAMILY=meson-g12b
  4847	BUILD_REPOSITORY_URL=https://github.com/armbian/build
  4848	BUILD_REPOSITORY_COMMIT=5f03d652
  4849	DISTRIBUTION_CODENAME=buster
  4850	DISTRIBUTION_STATUS=supported
  4851	VERSION=21.02.1
  4852	LINUXFAMILY=meson64
  4853	BRANCH=current
  4854	ARCH=arm64
  4855	IMAGE_TYPE=stable
  4856	BOARD_TYPE=conf
  4857	INITRD_ARCH=arm64
  4858	KERNEL_IMAGE_TYPE=Image
  4859
  4860	### boot environment:
  4861
  4862	verbosity=1
  4863	console=both
  4864	overlay_prefix=meson
  4865	rootdev=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c
  4866	rootfstype=ext4
  4867	usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
  4868
  4869	### lsusb:
  4870
  4871	Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc.
  4872	Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  4873	Bus 001 Device 003: ID 2013:025f PCTV Systems
  4874	Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
  4875	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  4876
  4877	### lscpu:
  4878
  4879	Architecture:        aarch64
  4880	Byte Order:          Little Endian
  4881	CPU(s):              6
  4882	On-line CPU(s) list: 0-5
  4883	Thread(s) per core:  1
  4884	Core(s) per socket:  3
  4885	Socket(s):           2
  4886	NUMA node(s):        1
  4887	Vendor ID:           ARM
  4888	Model:               4
  4889	Model name:          Cortex-A53
  4890	Stepping:            r0p4
  4891	CPU max MHz:         1992.0000
  4892	CPU min MHz:         100.0000
  4893	BogoMIPS:            48.00
  4894	L1d cache:           unknown size
  4895	L1i cache:           unknown size
  4896	L2 cache:            unknown size
  4897	NUMA node0 CPU(s):   0-5
  4898	Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4899
  4900	### cpuinfo:
  4901
  4902	processor	: 0
  4903	BogoMIPS	: 48.00
  4904	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4905	CPU implementer	: 0x41
  4906	CPU architecture: 8
  4907	CPU variant	: 0x0
  4908	CPU part	: 0xd03
  4909	CPU revision	: 4
  4910
  4911	processor	: 1
  4912	BogoMIPS	: 48.00
  4913	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4914	CPU implementer	: 0x41
  4915	CPU architecture: 8
  4916	CPU variant	: 0x0
  4917	CPU part	: 0xd03
  4918	CPU revision	: 4
  4919
  4920	processor	: 2
  4921	BogoMIPS	: 48.00
  4922	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4923	CPU implementer	: 0x41
  4924	CPU architecture: 8
  4925	CPU variant	: 0x0
  4926	CPU part	: 0xd09
  4927	CPU revision	: 2
  4928
  4929	processor	: 3
  4930	BogoMIPS	: 48.00
  4931	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4932	CPU implementer	: 0x41
  4933	CPU architecture: 8
  4934	CPU variant	: 0x0
  4935	CPU part	: 0xd09
  4936	CPU revision	: 2
  4937
  4938	processor	: 4
  4939	BogoMIPS	: 48.00
  4940	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4941	CPU implementer	: 0x41
  4942	CPU architecture: 8
  4943	CPU variant	: 0x0
  4944	CPU part	: 0xd09
  4945	CPU revision	: 2
  4946
  4947	processor	: 5
  4948	BogoMIPS	: 48.00
  4949	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4950	CPU implementer	: 0x41
  4951	CPU architecture: 8
  4952	CPU variant	: 0x0
  4953	CPU part	: 0xd09
  4954	CPU revision	: 2
  4955
  4956
  4957	### meminfo:
  4958
  4959	MemTotal:        3719728 kB
  4960	MemFree:         3477076 kB
  4961	MemAvailable:    3429592 kB
  4962	Buffers:           11444 kB
  4963	Cached:            42136 kB
  4964	SwapCached:            0 kB
  4965	Active:            28816 kB
  4966	Inactive:         111868 kB
  4967	Active(anon):        120 kB
  4968	Inactive(anon):    91804 kB
  4969	Active(file):      28696 kB
  4970	Inactive(file):    20064 kB
  4971	Unevictable:           0 kB
  4972	Mlocked:               0 kB
  4973	SwapTotal:       1859860 kB
  4974	SwapFree:        1859860 kB
  4975	Dirty:              2532 kB
  4976	Writeback:             0 kB
  4977	AnonPages:         86960 kB
  4978	Mapped:            12984 kB
  4979	Shmem:              4972 kB
  4980	KReclaimable:      12992 kB
  4981	Slab:              39768 kB
  4982	SReclaimable:      12992 kB
  4983	SUnreclaim:        26776 kB
  4984	KernelStack:        2576 kB
  4985	PageTables:         4148 kB
  4986	NFS_Unstable:          0 kB
  4987	Bounce:                0 kB
  4988	WritebackTmp:          0 kB
  4989	CommitLimit:     3719724 kB
  4990	Committed_AS:    4240968 kB
  4991	VmallocTotal:   135290159040 kB
  4992	VmallocUsed:       33216 kB
  4993	VmallocChunk:          0 kB
  4994	Percpu:             1368 kB
  4995	HardwareCorrupted:     0 kB
  4996	AnonHugePages:         0 kB
  4997	ShmemHugePages:        0 kB
  4998	ShmemPmdMapped:        0 kB
  4999	FileHugePages:         0 kB
  5000	FilePmdMapped:         0 kB
  5001	CmaTotal:         917504 kB
  5002	CmaFree:          909824 kB
  5003	HugePages_Total:       0
  5004	HugePages_Free:        0
  5005	HugePages_Rsvd:        0
  5006	HugePages_Surp:        0
  5007	Hugepagesize:       2048 kB
  5008	Hugetlb:               0 kB
  5009
  5010	### virtual memory:
  5011
  5012	vm.admin_reserve_kbytes = 8192
  5013	vm.block_dump = 0
  5014	vm.compaction_proactiveness = 20
  5015	vm.compact_unevictable_allowed = 1
  5016	vm.dirty_background_bytes = 0
  5017	vm.dirty_background_ratio = 10
  5018	vm.dirty_bytes = 0
  5019	vm.dirty_expire_centisecs = 3000
  5020	vm.dirty_ratio = 20
  5021	vm.dirtytime_expire_seconds = 43200
  5022	vm.dirty_writeback_centisecs = 500
  5023	vm.extfrag_threshold = 500
  5024	vm.hugetlb_shm_group = 0
  5025	vm.laptop_mode = 0
  5026	vm.legacy_va_layout = 0
  5027	vm.lowmem_reserve_ratio = 256	256	32	0
  5028	vm.max_map_count = 65530
  5029	vm.memory_failure_early_kill = 0
  5030	vm.memory_failure_recovery = 1
  5031	vm.min_free_kbytes = 45056
  5032	vm.min_slab_ratio = 5
  5033	vm.min_unmapped_ratio = 1
  5034	vm.mmap_min_addr = 4096
  5035	vm.mmap_rnd_bits = 18
  5036	vm.mmap_rnd_compat_bits = 11
  5037	vm.nr_hugepages = 0
  5038	vm.nr_hugepages_mempolicy = 0
  5039	vm.nr_overcommit_hugepages = 0
  5040	vm.numa_stat = 1
  5041	vm.numa_zonelist_order = Node
  5042	vm.oom_dump_tasks = 1
  5043	vm.oom_kill_allocating_task = 0
  5044	vm.overcommit_kbytes = 0
  5045	vm.overcommit_memory = 0
  5046	vm.overcommit_ratio = 50
  5047	vm.page-cluster = 0
  5048	vm.page_lock_unfairness = 5
  5049	vm.panic_on_oom = 0
  5050	vm.percpu_pagelist_fraction = 0
  5051	vm.stat_interval = 1
  5052	vm.swappiness = 100
  5053	vm.user_reserve_kbytes = 115035
  5054	vm.vfs_cache_pressure = 100
  5055	vm.watermark_boost_factor = 15000
  5056	vm.watermark_scale_factor = 10
  5057	vm.zone_reclaim_mode = 0
  5058
  5059	### ip addr:
  5060
  5061	1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  5062	    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  5063	    inet XXX.XXX.0.1/8 scope host lo
  5064	       valid_lft forever preferred_lft forever
  5065	    inet6 ::1/128 scope host
  5066	       valid_lft forever preferred_lft forever
  5067	2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  5068	    link/ether 00:1e:06:42:03:f8 brd ff:ff:ff:ff:ff:ff
  5069
  5070	### partitions:
  5071
  5072	major minor  #blocks  name
  5073
  5074	 179        0   31464960 mmcblk0
  5075	 179        1   31146208 mmcblk0p1
  5076	 252        0    1859864 zram0
  5077	 252        1      51200 zram1
  5078
  5079	### df:
  5080
  5081	udev            1.4G     0  1.4G   0% /dev
  5082	tmpfs           364M  4.9M  359M   2% /run
  5083	/dev/mmcblk0p1   30G  1.7G   28G   6% /
  5084	tmpfs           1.8G     0  1.8G   0% /dev/shm
  5085	tmpfs           5.0M  4.0K  5.0M   1% /run/lock
  5086	tmpfs           1.8G     0  1.8G   0% /sys/fs/cgroup
  5087	tmpfs           1.8G     0  1.8G   0% /tmp
  5088	/dev/zram1       49M  2.5M   43M   6% /var/log
  5089
  5090	### lsblk:
  5091
  5092	NAME        FSTYPE  SIZE MOUNTPOINT UUID
  5093	mmcblk0              30G
  5094	└─mmcblk0p1 ext4   29.7G /          bd34953d-41be-49d6-b1c0-c0c28a5e239c
  5095	zram1                50M /var/log
  5096
  5097	### zramctl:
  5098
  5099	NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
  5100	/dev/zram1 zstd           50M  132K  698B   36K       6 /var/log
  5101	/dev/zram0 lzo-rle       1.8G    4K   74B   12K       6 [SWAP]
  5102
  5103	### mtab:
  5104
  5105	/dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  5106	/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  5107	/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
  5108
  5109	### mmc0:b368 info:
  5110
  5111	               fwrev: 0x0
  5112	              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=CBADS MODALIAS=mmc:block
  5113	                 cid: 6f0303434241445310aa002b4d013b00
  5114	                 rca: 0xb368
  5115	                 csd: 400e005a5b590000f00e7f800a404000
  5116	              manfid: 0x00006f
  5117	                 ocr: 0x00200000
  5118	preferred_erase_size: 2097152
  5119	                type: SD
  5120	               hwrev: 0x1
  5121	                date: 11/2019
  5122	                 dsr: 0x404
  5123	          erase_size: 512
  5124	               oemid: 0x0303
  5125	              serial: 0xaa002b4d
  5126	                 ssr: 00000000000000280402800100fd180a001e00000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  5127	                 scr: 02b5800300000000
  5128	                name: CBADS
  5129
  5130	### Boot system health:
  5131
  5132	Time       big.LITTLE   load %cpu %sys %usr %nice %io %irq   CPU  C.St.
  5133	14:45:09: 1908/1992MHz  2.67  23%  10%   5%   0%   6%   0% 33.6°C  0/11
  5134	14:45:09: 1908/1992MHz  2.67  87%  33%   6%   0%  44%   1% 31.6°C  0/11
  5135	14:45:09: 1908/1992MHz  2.67  63%  12%   0%   0%  48%   0% 30.3°C  0/11
  5136	14:45:10: 1908/1992MHz  2.67  57%   9%   5%   0%  39%   2% 30.5°C  0/11
  5137	14:45:10: 1908/1992MHz  2.67  49%   3%   5%   0%  36%   2% 29.8°C  0/11
  5138
  5139	### Activated 1 lzo-rle zram swap devices with 1816 MB each
  5140
  5141	### Activated Armbian ramlog partition with zstd compression
  5142
  5143	Sun 14 Feb 2021 03:31:27 PM GMT | Odroid N2 | 21.02.1 | arm64 | aarch64 | 5.10.12-meson64
  5144
  5145	### dmesg:
  5146
  5147	[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
  5148	[    0.000000] Linux version 5.10.12-meson64 (root@beast) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #21.02.1 SMP PREEMPT Wed Feb 3 21:06:36 CET 2021
  5149	[    0.000000] Machine model: Hardkernel ODROID-N2
  5150	[    0.000000] efi: UEFI not found.
  5151	[    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
  5152	[    0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB
  5153	[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
  5154	[    0.000000] NUMA: No NUMA configuration found
  5155	[    0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ed7fffff]
  5156	[    0.000000] NUMA: NODE_DATA [mem 0xb502f100-0xb5030fff]
  5157	[    0.000000] Zone ranges:
  5158	[    0.000000]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
  5159	[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000ed7fffff]
  5160	[    0.000000]   Normal   empty
  5161	[    0.000000] Movable zone start for each node
  5162	[    0.000000] Early memory node ranges
  5163	[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000004ffffff]
  5164	[    0.000000]   node   0: [mem 0x0000000005300000-0x00000000ed7fffff]
  5165	[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ed7fffff]
  5166	[    0.000000] On node 0 totalpages: 972032
  5167	[    0.000000]   DMA zone: 4096 pages used for memmap
  5168	[    0.000000]   DMA zone: 0 pages reserved
  5169	[    0.000000]   DMA zone: 261376 pages, LIFO batch:63
  5170	[    0.000000]   DMA32 zone: 11104 pages used for memmap
  5171	[    0.000000]   DMA32 zone: 710656 pages, LIFO batch:63
  5172	[    0.000000] psci: probing for conduit method from DT.
  5173	[    0.000000] psci: PSCIv1.0 detected in firmware.
  5174	[    0.000000] psci: Using standard PSCI v0.2 function IDs
  5175	[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
  5176	[    0.000000] psci: SMC Calling Convention v1.1
  5177	[    0.000000] percpu: Embedded 23 pages/cpu s56728 r8192 d29288 u94208
  5178	[    0.000000] pcpu-alloc: s56728 r8192 d29288 u94208 alloc=23*4096
  5179	[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
  5180	[    0.000000] Detected VIPT I-cache on CPU0
  5181	[    0.000000] CPU features: detected: ARM erratum 845719
  5182	[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 956832
  5183	[    0.000000] Policy zone: DMA32
  5184	[    0.000000] Kernel command line: root=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c rootwait rootfstype=ext4 console=ttyAML0,115200n8 console=tty1 loglevel=1  no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=custombuilt cvbsmode=576cvbs max_freq_a53=1896 max_freq_a73=1800 maxcpus=6 voutmode=hdmi modeline=1920,1080,148500,56250,50,1920,2448,2492,2640,1080,1084,1089,1125,1,1,1 disablehpd=false  cvbscable= overscan=100 consoleblank=0
  5185	[    0.000000] Kernel parameter elevator= does not have any effect anymore.
  5186	               Please use sysfs to set IO scheduler for individual devices.
  5187	[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
  5188	[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
  5189	[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
  5190	[    0.000000] software IO TLB: mapped [mem 0x0000000038ac5000-0x000000003cac5000] (64MB)
  5191	[    0.000000] Memory: 2785352K/3888128K available (14144K kernel code, 1760K rwdata, 5508K rodata, 3328K init, 592K bss, 185272K reserved, 917504K cma-reserved)
  5192	[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
  5193	[    0.000000] rcu: Preemptible hierarchical RCU implementation.
  5194	[    0.000000] rcu: 	RCU event tracing is enabled.
  5195	[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
  5196	[    0.000000] 	Trampoline variant of Tasks RCU enabled.
  5197	[    0.000000] 	Rude variant of Tasks RCU enabled.
  5198	[    0.000000] 	Tracing variant of Tasks RCU enabled.
  5199	[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  5200	[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
  5201	[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
  5202	[    0.000000] GIC: Using split EOI/Deactivate mode
  5203	[    0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized
  5204	[    0.000000] random: get_random_bytes called from start_kernel+0x378/0x538 with crng_init=0
  5205	[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
  5206	[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  5207	[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  5208	[    0.000242] Console: colour dummy device 80x25
  5209	[    0.000277] printk: console [tty1] enabled
  5210	[    0.000361] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
  5211	[    0.000373] pid_max: default: 32768 minimum: 301
  5212	[    0.000456] LSM: Security Framework initializing
  5213	[    0.000482] Yama: becoming mindful.
  5214	[    0.000573] AppArmor: AppArmor initialized
  5215	[    0.000624] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
  5216	[    0.000643] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
  5217	[    0.002637] rcu: Hierarchical SRCU implementation.
  5218	[    0.004997] EFI services will not be available.
  5219	[    0.005420] smp: Bringing up secondary CPUs ...
  5220	[    0.006092] Detected VIPT I-cache on CPU1
  5221	[    0.006154] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
  5222	[    0.007345] CPU features: detected: ARM erratum 858921
  5223	[    0.007353] CPU features: detected: Spectre-v2
  5224	[    0.007356] CPU features: detected: Spectre-v4
  5225	[    0.007363] Detected VIPT I-cache on CPU2
  5226	[    0.007388] arch_timer: Enabling local workaround for ARM erratum 858921
  5227	[    0.007402] arch_timer: CPU2: Trapping CNTVCT access
  5228	[    0.007415] CPU2: Booted secondary processor 0x0000000100 [0x410fd092]
  5229	[    0.008123] Detected VIPT I-cache on CPU3
  5230	[    0.008139] arch_timer: Enabling local workaround for ARM erratum 858921
  5231	[    0.008147] arch_timer: CPU3: Trapping CNTVCT access
  5232	[    0.008155] CPU3: Booted secondary processor 0x0000000101 [0x410fd092]
  5233	[    0.008780] Detected VIPT I-cache on CPU4
  5234	[    0.008796] arch_timer: Enabling local workaround for ARM erratum 858921
  5235	[    0.008803] arch_timer: CPU4: Trapping CNTVCT access
  5236	[    0.008811] CPU4: Booted secondary processor 0x0000000102 [0x410fd092]
  5237	[    0.009423] Detected VIPT I-cache on CPU5
  5238	[    0.009439] arch_timer: Enabling local workaround for ARM erratum 858921
  5239	[    0.009446] arch_timer: CPU5: Trapping CNTVCT access
  5240	[    0.009454] CPU5: Booted secondary processor 0x0000000103 [0x410fd092]
  5241	[    0.009534] smp: Brought up 1 node, 6 CPUs
  5242	[    0.009552] SMP: Total of 6 processors activated.
  5243	[    0.009560] CPU features: detected: 32-bit EL0 Support
  5244	[    0.009566] CPU features: detected: CRC32 instructions
  5245	[    0.009571] CPU features: detected: 32-bit EL1 Support
  5246	[    0.020804] CPU: All CPU(s) started at EL2
  5247	[    0.020853] alternatives: patching kernel code
  5248	[    0.022794] devtmpfs: initialized
  5249	[    0.030438] Registered cp15_barrier emulation handler
  5250	[    0.030452] Registered setend emulation handler
  5251	[    0.030616] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  5252	[    0.030661] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
  5253	[    0.044584] pinctrl core: initialized pinctrl subsystem
  5254	[    0.045319] DMI not present or invalid.
  5255	[    0.045684] NET: Registered protocol family 16
  5256	[    0.047240] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
  5257	[    0.047513] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
  5258	[    0.047738] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
  5259	[    0.047782] audit: initializing netlink subsys (disabled)
  5260	[    0.047888] audit: type=2000 audit(0.044:1): state=initialized audit_enabled=0 res=1
  5261	[    0.049110] thermal_sys: Registered thermal governor 'fair_share'
  5262	[    0.049118] thermal_sys: Registered thermal governor 'bang_bang'
  5263	[    0.049122] thermal_sys: Registered thermal governor 'step_wise'
  5264	[    0.049126] thermal_sys: Registered thermal governor 'user_space'
  5265	[    0.049546] cpuidle: using governor menu
  5266	[    0.049895] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  5267	[    0.050013] ASID allocator initialised with 65536 entries
  5268	[    0.050942] Serial: AMBA PL011 UART driver
  5269	[    0.084507] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
  5270	[    0.084521] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
  5271	[    0.084526] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
  5272	[    0.084530] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
  5273	[    0.086563] cryptd: max_cpu_qlen set to 1000
  5274	[    0.156194] raid6: neonx8   gen()  2780 MB/s
  5275	[    0.224355] raid6: neonx8   xor()  1603 MB/s
  5276	[    0.292375] raid6: neonx4   gen()  2197 MB/s
  5277	[    0.360419] raid6: neonx4   xor()  2399 MB/s
  5278	[    0.428485] raid6: neonx2   gen()  2560 MB/s
  5279	[    0.496547] raid6: neonx2   xor()  2201 MB/s
  5280	[    0.564619] raid6: neonx1   gen()  2065 MB/s
  5281	[    0.632680] raid6: neonx1   xor()  1726 MB/s
  5282	[    0.700756] raid6: int64x8  gen()  1375 MB/s
  5283	[    0.768807] raid6: int64x8  xor()   735 MB/s
  5284	[    0.836894] raid6: int64x4  gen()  1463 MB/s
  5285	[    0.904954] raid6: int64x4  xor()   733 MB/s
  5286	[    0.973009] raid6: int64x2  gen()  1362 MB/s
  5287	[    1.041087] raid6: int64x2  xor()   619 MB/s
  5288	[    1.109154] raid6: int64x1  gen()  1120 MB/s
  5289	[    1.177217] raid6: int64x1  xor()   462 MB/s
  5290	[    1.177221] raid6: using algorithm neonx8 gen() 2780 MB/s
  5291	[    1.177224] raid6: .... xor() 1603 MB/s, rmw enabled
  5292	[    1.177227] raid6: using neon recovery algorithm
  5293	[    1.177651] ACPI: Interpreter disabled.
  5294	[    1.178438] 5V: supplied by 12V
  5295	[    1.179313] VDDAO_3V3: supplied by 12V
  5296	[    1.179781] iommu: Default domain type: Translated
  5297	[    1.179908] vgaarb: loaded
  5298	[    1.180741] SCSI subsystem initialized
  5299	[    1.180929] usbcore: registered new interface driver usbfs
  5300	[    1.180968] usbcore: registered new interface driver hub
  5301	[    1.180999] usbcore: registered new device driver usb
  5302	[    1.181271] pps_core: LinuxPPS API ver. 1 registered
  5303	[    1.181276] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  5304	[    1.181294] PTP clock support registered
  5305	[    1.181538] EDAC MC: Ver: 3.0.0
  5306	[    1.182848] NetLabel: Initializing
  5307	[    1.182856] NetLabel:  domain hash size = 128
  5308	[    1.182858] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
  5309	[    1.182910] NetLabel:  unlabeled traffic allowed by default
  5310	[    1.183359] clocksource: Switched to clocksource arch_sys_counter
  5311	[    1.183566] VFS: Disk quotas dquot_6.6.0
  5312	[    1.183610] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  5313	[    1.183972] AppArmor: AppArmor Filesystem Enabled
  5314	[    1.184017] pnp: PnP ACPI: disabled
  5315	[    1.189861] NET: Registered protocol family 2
  5316	[    1.190306] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
  5317	[    1.190410] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
  5318	[    1.190667] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
  5319	[    1.190854] TCP: Hash tables configured (established 32768 bind 32768)
  5320	[    1.191006] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
  5321	[    1.191069] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
  5322	[    1.191116] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
  5323	[    1.191260] NET: Registered protocol family 1
  5324	[    1.191283] PCI: CLS 0 bytes, default 64
  5325	[    1.191453] Trying to unpack rootfs image as initramfs...
  5326	[    1.727376] Freeing initrd memory: 13544K
  5327	[    1.728278] kvm [1]: IPA Size Limit: 40 bits
  5328	[    1.728985] kvm [1]: vgic interrupt IRQ9
  5329	[    1.729117] kvm [1]: Hyp mode initialized successfully
  5330	[    1.734239] Initialise system trusted keyrings
  5331	[    1.734268] Key type blacklist registered
  5332	[    1.734400] workingset: timestamp_bits=44 max_order=20 bucket_order=0
  5333	[    1.737587] zbud: loaded
  5334	[    1.738571] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  5335	[    1.739035] fuse: init (API version 7.32)
  5336	[    1.739822] integrity: Platform Keyring initialized
  5337	[    1.767175] xor: measuring software checksum speed
  5338	[    1.770046]    8regs           :  3473 MB/sec
  5339	[    1.772502]    32regs          :  4020 MB/sec
  5340	[    1.775151]    arm64_neon      :  3719 MB/sec
  5341	[    1.775154] xor: using function: 32regs (4020 MB/sec)
  5342	[    1.775163] Key type asymmetric registered
  5343	[    1.775167] Asymmetric key parser 'x509' registered
  5344	[    1.775203] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
  5345	[    1.775315] io scheduler mq-deadline registered
  5346	[    1.775320] io scheduler kyber registered
  5347	[    1.775409] io scheduler bfq registered
  5348	[    1.777854] gpio-447 (usb-hub-reset): hogged as output/high
  5349	[    1.780791] EINJ: ACPI disabled.
  5350	[    1.786904] soc soc0: Amlogic Meson G12B (S922X) Revision 29:a (40:2) Detected
  5351	[    1.788407] VCC_3V3: supplied by VDDAO_3V3
  5352	[    1.788446] FLASH_1V8: supplied by VCC_3V3
  5353	[    1.788476] VCC_1V8: supplied by VCC_3V3
  5354	[    1.788504] VDDAO_1V8: supplied by VDDAO_3V3
  5355	[    1.788536] VDDCPU_A: supplied by regulator-dummy
  5356	[    1.788891] VDDCPU_B: supplied by regulator-dummy
  5357	[    1.789552] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
  5358	[    1.791893] Serial: AMBA driver
  5359	[    1.792177] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart
  5360	[    1.792273] printk: console [ttyAML0] enabled
  5361	[    1.792813] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 33, base_baud = 1500000) is a meson_uart
  5362	[    1.798113] loop: module loaded
  5363	[    1.800027] libphy: Fixed MDIO Bus: probed
  5364	[    1.800997] tun: Universal TUN/TAP device driver, 1.6
  5365	[    1.801598] thunder_xcv, ver 1.0
  5366	[    1.801627] thunder_bgx, ver 1.0
  5367	[    1.801653] nicpf, ver 1.0
  5368	[    1.802103] e1000e: Intel(R) PRO/1000 Network Driver
  5369	[    1.802107] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
  5370	[    1.802147] igb: Intel(R) Gigabit Ethernet Network Driver
  5371	[    1.802150] igb: Copyright (c) 2007-2014 Intel Corporation.
  5372	[    1.802186] igbvf: Intel(R) Gigabit Virtual Function Network Driver
  5373	[    1.802189] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
  5374	[    1.802316] sky2: driver version 1.30
  5375	[    1.802671] VFIO - User Level meta-driver version: 0.3
  5376	[    1.804056] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  5377	[    1.804078] ehci-pci: EHCI PCI platform driver
  5378	[    1.804114] ehci-platform: EHCI generic platform driver
  5379	[    1.804256] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  5380	[    1.804268] ohci-pci: OHCI PCI platform driver
  5381	[    1.804302] ohci-platform: OHCI generic platform driver
  5382	[    1.804683] usbcore: registered new interface driver usb-storage
  5383	[    1.805927] mousedev: PS/2 mouse device common for all mice
  5384	[    1.806327] i2c /dev entries driver
  5385	[    1.811338] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17
  5386	[    1.812031] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz
  5387	[    1.812713] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-1 failed:-17
  5388	[    1.813302] sdhci: Secure Digital Host Controller Interface driver
  5389	[    1.813309] sdhci: Copyright(c) Pierre Ossman
  5390	[    1.813424] Synopsys Designware Multimedia Card Interface Driver
  5391	[    1.813931] sdhci-pltfm: SDHCI platform and OF driver helper
  5392	[    1.814534] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq
  5393	[    1.814899] ledtrig-cpu: registered to indicate activity on CPUs
  5394	[    1.815553] meson-sm: secure-monitor enabled
  5395	[    1.815921] hid: raw HID events driver (C) Jiri Kosina
  5396	[    1.816018] usbcore: registered new interface driver usbhid
  5397	[    1.816021] usbhid: USB HID core driver
  5398	[    1.817820] NET: Registered protocol family 10
  5399	[    1.818475] Segment Routing with IPv6
  5400	[    1.818508] NET: Registered protocol family 17
  5401	[    1.818556] 8021q: 802.1Q VLAN Support v1.8
  5402	[    1.818579] Key type dns_resolver registered
  5403	[    1.818858] registered taskstats version 1
  5404	[    1.818864] Loading compiled-in X.509 certificates
  5405	[    1.820753] Loaded X.509 cert 'Build time autogenerated kernel key: f47c178852ca39740c3546b008122b65f5ed9bce'
  5406	[    1.822316] zswap: loaded using pool zstd/z3fold
  5407	[    1.822476] Key type ._fscrypt registered
  5408	[    1.822479] Key type .fscrypt registered
  5409	[    1.822481] Key type fscrypt-provisioning registered
  5410	[    1.823610] Btrfs loaded, crc32c=crc32c-generic
  5411	[    1.829870] Key type encrypted registered
  5412	[    1.829881] AppArmor: AppArmor sha1 policy hashing enabled
  5413	[    1.836314] HUB_5V: supplied by 5V
  5414	[    1.836521] USB_PWR_EN: supplied by 5V
  5415	[    1.838176] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2
  5416	[    1.838183] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1
  5417	[    1.840894] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator
  5418	[    1.840950] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator
  5419	[    1.841048] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM
  5420	[    1.841640] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  5421	[    1.841652] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
  5422	[    1.841745] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010
  5423	[    1.841770] xhci-hcd xhci-hcd.0.auto: irq 41, io mem 0xff500000
  5424	[    1.841895] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
  5425	[    1.841899] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  5426	[    1.841902] usb usb1: Product: xHCI Host Controller
  5427	[    1.841905] usb usb1: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
  5428	[    1.841907] usb usb1: SerialNumber: xhci-hcd.0.auto
  5429	[    1.842096] hub 1-0:1.0: USB hub found
  5430	[    1.842108] hub 1-0:1.0: 2 ports detected
  5431	[    1.842244] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  5432	[    1.842250] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  5433	[    1.842256] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  5434	[    1.842276] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
  5435	[    1.842310] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
  5436	[    1.842313] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  5437	[    1.842316] usb usb2: Product: xHCI Host Controller
  5438	[    1.842318] usb usb2: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
  5439	[    1.842320] usb usb2: SerialNumber: xhci-hcd.0.auto
  5440	[    1.842462] hub 2-0:1.0: USB hub found
  5441	[    1.842472] hub 2-0:1.0: 1 port detected
  5442	[    1.843560] meson-gx-mmc ffe05000.sd: Got CD GPIO
  5443	[    1.868391] Freeing unused kernel memory: 3328K
  5444	[    1.899426] Run /init as init process
  5445	[    1.899430]   with arguments:
  5446	[    1.899432]     /init
  5447	[    1.899434]   with environment:
  5448	[    1.899435]     HOME=/
  5449	[    1.899437]     TERM=linux
  5450	[    1.899439]     hdmimode=custombuilt
  5451	[    1.899440]     cvbsmode=576cvbs
  5452	[    1.899442]     max_freq_a53=1896
  5453	[    1.899444]     max_freq_a73=1800
  5454	[    1.899445]     voutmode=hdmi
  5455	[    1.899447]     modeline=1920,1080,148500,56250,50,1920,2448,2492,2640,1080,1084,1089,1125,1,1,1
  5456	[    1.899448]     disablehpd=false
  5457	[    1.899449]     cvbscable=
  5458	[    1.899451]     overscan=100
  5459	[    1.933534] mmc0: new ultra high speed SDR25 SDHC card at address b368
  5460	[    1.934136] mmcblk0: mmc0:b368 CBADS 30.0 GiB
  5461	[    1.935958]  mmcblk0: p1
  5462	[    2.061306] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found
  5463	[    2.061313] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found
  5464	[    2.061389] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock
  5465	[    2.063005] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37
  5466	[    2.063018] meson8b-dwmac ff3f0000.ethernet: 	DWMAC1000
  5467	[    2.063022] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported
  5468	[    2.063025] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported
  5469	[    2.063027] meson8b-dwmac ff3f0000.ethernet: COE Type 2
  5470	[    2.063030] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported
  5471	[    2.063032] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported
  5472	[    2.063112] meson8b-dwmac ff3f0000.ethernet: Normal descriptors
  5473	[    2.063115] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled
  5474	[    2.063119] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
  5475	[    2.063413] libphy: stmmac: probed
  5476	[    2.065154] libphy: mdio_mux: probed
  5477	[    2.083750] meson-vrtc ff8000a8.rtc: registered as rtc1
  5478	[    2.089761] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
  5479	[    2.090025] rtc-pcf8563 1-0051: registered as rtc0
  5480	[    2.091204] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
  5481	[    2.091213] rtc-pcf8563 1-0051: hctosys: unable to read the hardware clock
  5482	[    2.097435] random: fast init done
  5483	[    2.179488] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
  5484	[    2.204109] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.04
  5485	[    2.204117] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  5486	[    2.204120] usb 2-1: Product: USB3.1 Hub
  5487	[    2.204122] usb 2-1: Manufacturer: GenesysLogic
  5488	[    2.226471] hub 2-1:1.0: USB hub found
  5489	[    2.226755] hub 2-1:1.0: 4 ports detected
  5490	[    2.275826] libphy: mdio_mux: probed
  5491	[    2.327383] usb 1-1: new high-speed USB device number 2 using xhci-hcd
  5492	[    2.477681] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.04
  5493	[    2.477689] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  5494	[    2.477693] usb 1-1: Product: USB2.1 Hub
  5495	[    2.477696] usb 1-1: Manufacturer: GenesysLogic
  5496	[    2.514585] hub 1-1:1.0: USB hub found
  5497	[    2.514835] hub 1-1:1.0: 4 ports detected
  5498	[    2.817050] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
  5499	[    3.623797] systemd[1]: System time before build time, advancing clock.
  5500	[    3.638655] systemd[1]: Inserted module 'autofs4'
  5501	[    3.685040] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  5502	[    3.685266] systemd[1]: Detected architecture arm64.
  5503	[    3.717286] systemd[1]: Set hostname to <odroidn2>.
  5504	[    4.116648] random: systemd: uninitialized urandom read (16 bytes read)
  5505	[    4.122330] random: systemd: uninitialized urandom read (16 bytes read)
  5506	[    4.122571] systemd[1]: Listening on initctl Compatibility Named Pipe.
  5507	[    4.123078] random: systemd: uninitialized urandom read (16 bytes read)
  5508	[    4.125495] systemd[1]: Created slice system-serial\x2dgetty.slice.
  5509	[    4.126339] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
  5510	[    4.127021] systemd[1]: Listening on Syslog Socket.
  5511	[    4.127399] systemd[1]: Reached target Remote File Systems.
  5512	[    4.127831] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
  5513	[    4.128464] systemd[1]: Listening on fsck to fsckd communication Socket.
  5514	[    4.202981] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
  5515	[    4.739693] zram: Added device: zram0
  5516	[    4.740232] zram: Added device: zram1
  5517	[    4.742196] zram: Added device: zram2
  5518	[    4.757640] pwm-gpio pwmgpio: 1 gpio pwms loaded
  5519	[    4.912993] meson-saradc ff809000.adc: supply vref not found, using dummy regulator
  5520	[    4.928275] mc: Linux media interface: v0.10
  5521	[    5.000089] videodev: Linux video capture interface: v2.00
  5522	[    5.051385] Registered IR keymap rc-odroid
  5523	[    5.052948] meson-drm ff900000.vpu: Queued 2 outputs on vpu
  5524	[    5.078502] IR NEC protocol handler initialized
  5525	[    5.096913] panfrost ffe40000.gpu: clock rate = 24000000
  5526	[    5.096996] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19
  5527	[    5.099683] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0
  5528	[    5.099693] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400
  5529	[    5.099698] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
  5530	[    5.099702] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1
  5531	[    5.100015] meson-drm ff900000.vpu: CVBS Output connector not available
  5532	[    5.107478] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0
  5533	[    5.107590] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
  5534	[    5.107685] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input0
  5535	[    5.107866] meson-ir ff808000.ir: receiver initialized
  5536	[    5.117233] zram0: detected capacity change from 0 to 1904500736
  5537	[    5.118309] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 1
  5538	[    5.129159] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
  5539	[    5.129612] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
  5540	[    5.129873] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
  5541	[    5.130701] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 0
  5542	[    5.149419] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  5543	[    5.423519] Console: switching to colour frame buffer device 240x67
  5544	[    5.450037] meson-drm ff900000.vpu: [drm] fb0: mesondrmfb frame buffer device
  5545	[    5.495261] axg-sound-card sound: ASoC: no DMI vendor name!
  5546	[    6.175378] Adding 1859860k swap on /dev/zram0.  Priority:5 extents:1 across:1859860k SSFS
  5547	[    6.238314] zram1: detected capacity change from 0 to 52428800
  5548	[    8.322454] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
  5549	[    8.322472] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
  5550	[    9.301131] systemd[1]: Started Armbian memory supported logging.
  5551	[    9.303514] systemd[1]: Starting Journal Service...
  5552	[    9.358414] systemd[1]: Started Journal Service.
  5553	[    9.383517] systemd-journald[1841]: Received request to flush runtime journal from PID 1
  5554
  5555	### armbian-release:
  5556
  5557	# PLEASE DO NOT EDIT THIS FILE
  5558	BOARD=odroidn2
  5559	BOARD_NAME="Odroid N2"
  5560	BOARDFAMILY=meson-g12b
  5561	BUILD_REPOSITORY_URL=https://github.com/armbian/build
  5562	BUILD_REPOSITORY_COMMIT=5f03d652
  5563	DISTRIBUTION_CODENAME=buster
  5564	DISTRIBUTION_STATUS=supported
  5565	VERSION=21.02.1
  5566	LINUXFAMILY=meson64
  5567	BRANCH=current
  5568	ARCH=arm64
  5569	IMAGE_TYPE=stable
  5570	BOARD_TYPE=conf
  5571	INITRD_ARCH=arm64
  5572	KERNEL_IMAGE_TYPE=Image
  5573
  5574	### boot environment:
  5575
  5576	verbosity=1
  5577	console=both
  5578	overlay_prefix=meson
  5579	rootdev=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c
  5580	rootfstype=ext4
  5581	usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
  5582
  5583	### lsusb:
  5584
  5585	Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc.
  5586	Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  5587	Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
  5588	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  5589
  5590	### lscpu:
  5591
  5592	Architecture:        aarch64
  5593	Byte Order:          Little Endian
  5594	CPU(s):              6
  5595	On-line CPU(s) list: 0-5
  5596	Thread(s) per core:  1
  5597	Core(s) per socket:  3
  5598	Socket(s):           2
  5599	NUMA node(s):        1
  5600	Vendor ID:           ARM
  5601	Model:               4
  5602	Model name:          Cortex-A53
  5603	Stepping:            r0p4
  5604	CPU max MHz:         1992.0000
  5605	CPU min MHz:         100.0000
  5606	BogoMIPS:            48.00
  5607	L1d cache:           unknown size
  5608	L1i cache:           unknown size
  5609	L2 cache:            unknown size
  5610	NUMA node0 CPU(s):   0-5
  5611	Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  5612
  5613	### cpuinfo:
  5614
  5615	processor	: 0
  5616	BogoMIPS	: 48.00
  5617	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  5618	CPU implementer	: 0x41
  5619	CPU architecture: 8
  5620	CPU variant	: 0x0
  5621	CPU part	: 0xd03
  5622	CPU revision	: 4
  5623
  5624	processor	: 1
  5625	BogoMIPS	: 48.00
  5626	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  5627	CPU implementer	: 0x41
  5628	CPU architecture: 8
  5629	CPU variant	: 0x0
  5630	CPU part	: 0xd03
  5631	CPU revision	: 4
  5632
  5633	processor	: 2
  5634	BogoMIPS	: 48.00
  5635	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  5636	CPU implementer	: 0x41
  5637	CPU architecture: 8
  5638	CPU variant	: 0x0
  5639	CPU part	: 0xd09
  5640	CPU revision	: 2
  5641
  5642	processor	: 3
  5643	BogoMIPS	: 48.00
  5644	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  5645	CPU implementer	: 0x41
  5646	CPU architecture: 8
  5647	CPU variant	: 0x0
  5648	CPU part	: 0xd09
  5649	CPU revision	: 2
  5650
  5651	processor	: 4
  5652	BogoMIPS	: 48.00
  5653	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  5654	CPU implementer	: 0x41
  5655	CPU architecture: 8
  5656	CPU variant	: 0x0
  5657	CPU part	: 0xd09
  5658	CPU revision	: 2
  5659
  5660	processor	: 5
  5661	BogoMIPS	: 48.00
  5662	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  5663	CPU implementer	: 0x41
  5664	CPU architecture: 8
  5665	CPU variant	: 0x0
  5666	CPU part	: 0xd09
  5667	CPU revision	: 2
  5668
  5669
  5670	### meminfo:
  5671
  5672	MemTotal:        3719728 kB
  5673	MemFree:         3393120 kB
  5674	MemAvailable:    3345248 kB
  5675	Buffers:           11544 kB
  5676	Cached:            42060 kB
  5677	SwapCached:            0 kB
  5678	Active:            28944 kB
  5679	Inactive:         187684 kB
  5680	Active(anon):        100 kB
  5681	Inactive(anon):   167948 kB
  5682	Active(file):      28844 kB
  5683	Inactive(file):    19736 kB
  5684	Unevictable:           0 kB
  5685	Mlocked:               0 kB
  5686	SwapTotal:       1859860 kB
  5687	SwapFree:        1859860 kB
  5688	Dirty:              2796 kB
  5689	Writeback:             0 kB
  5690	AnonPages:        163196 kB
  5691	Mapped:            13640 kB
  5692	Shmem:              4864 kB
  5693	KReclaimable:      12896 kB
  5694	Slab:              39208 kB
  5695	SReclaimable:      12896 kB
  5696	SUnreclaim:        26312 kB
  5697	KernelStack:        2560 kB
  5698	PageTables:         5628 kB
  5699	NFS_Unstable:          0 kB
  5700	Bounce:                0 kB
  5701	WritebackTmp:          0 kB
  5702	CommitLimit:     3719724 kB
  5703	Committed_AS:    4239576 kB
  5704	VmallocTotal:   135290159040 kB
  5705	VmallocUsed:       31328 kB
  5706	VmallocChunk:          0 kB
  5707	Percpu:             1368 kB
  5708	HardwareCorrupted:     0 kB
  5709	AnonHugePages:     40960 kB
  5710	ShmemHugePages:        0 kB
  5711	ShmemPmdMapped:        0 kB
  5712	FileHugePages:         0 kB
  5713	FilePmdMapped:         0 kB
  5714	CmaTotal:         917504 kB
  5715	CmaFree:          901724 kB
  5716	HugePages_Total:       0
  5717	HugePages_Free:        0
  5718	HugePages_Rsvd:        0
  5719	HugePages_Surp:        0
  5720	Hugepagesize:       2048 kB
  5721	Hugetlb:               0 kB
  5722
  5723	### virtual memory:
  5724
  5725	vm.admin_reserve_kbytes = 8192
  5726	vm.block_dump = 0
  5727	vm.compaction_proactiveness = 20
  5728	vm.compact_unevictable_allowed = 1
  5729	vm.dirty_background_bytes = 0
  5730	vm.dirty_background_ratio = 10
  5731	vm.dirty_bytes = 0
  5732	vm.dirty_expire_centisecs = 3000
  5733	vm.dirty_ratio = 20
  5734	vm.dirtytime_expire_seconds = 43200
  5735	vm.dirty_writeback_centisecs = 500
  5736	vm.extfrag_threshold = 500
  5737	vm.hugetlb_shm_group = 0
  5738	vm.laptop_mode = 0
  5739	vm.legacy_va_layout = 0
  5740	vm.lowmem_reserve_ratio = 256	256	32	0
  5741	vm.max_map_count = 65530
  5742	vm.memory_failure_early_kill = 0
  5743	vm.memory_failure_recovery = 1
  5744	vm.min_free_kbytes = 45056
  5745	vm.min_slab_ratio = 5
  5746	vm.min_unmapped_ratio = 1
  5747	vm.mmap_min_addr = 4096
  5748	vm.mmap_rnd_bits = 18
  5749	vm.mmap_rnd_compat_bits = 11
  5750	vm.nr_hugepages = 0
  5751	vm.nr_hugepages_mempolicy = 0
  5752	vm.nr_overcommit_hugepages = 0
  5753	vm.numa_stat = 1
  5754	vm.numa_zonelist_order = Node
  5755	vm.oom_dump_tasks = 1
  5756	vm.oom_kill_allocating_task = 0
  5757	vm.overcommit_kbytes = 0
  5758	vm.overcommit_memory = 0
  5759	vm.overcommit_ratio = 50
  5760	vm.page-cluster = 0
  5761	vm.page_lock_unfairness = 5
  5762	vm.panic_on_oom = 0
  5763	vm.percpu_pagelist_fraction = 0
  5764	vm.stat_interval = 1
  5765	vm.swappiness = 100
  5766	vm.user_reserve_kbytes = 115051
  5767	vm.vfs_cache_pressure = 100
  5768	vm.watermark_boost_factor = 15000
  5769	vm.watermark_scale_factor = 10
  5770	vm.zone_reclaim_mode = 0
  5771
  5772	### ip addr:
  5773
  5774	1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  5775	    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  5776	    inet XXX.XXX.0.1/8 scope host lo
  5777	       valid_lft forever preferred_lft forever
  5778	    inet6 ::1/128 scope host
  5779	       valid_lft forever preferred_lft forever
  5780	2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  5781	    link/ether 00:1e:06:42:03:f8 brd ff:ff:ff:ff:ff:ff
  5782
  5783	### partitions:
  5784
  5785	major minor  #blocks  name
  5786
  5787	 179        0   31464960 mmcblk0
  5788	 179        1   31146208 mmcblk0p1
  5789	 252        0    1859864 zram0
  5790	 252        1      51200 zram1
  5791
  5792	### df:
  5793
  5794	udev            1.4G     0  1.4G   0% /dev
  5795	tmpfs           364M  4.9M  359M   2% /run
  5796	/dev/mmcblk0p1   30G  1.7G   28G   6% /
  5797	tmpfs           1.8G     0  1.8G   0% /dev/shm
  5798	tmpfs           5.0M  4.0K  5.0M   1% /run/lock
  5799	tmpfs           1.8G     0  1.8G   0% /sys/fs/cgroup
  5800	tmpfs           1.8G     0  1.8G   0% /tmp
  5801	/dev/zram1       49M  2.8M   43M   7% /var/log
  5802
  5803	### lsblk:
  5804
  5805	NAME        FSTYPE  SIZE MOUNTPOINT UUID
  5806	mmcblk0              30G
  5807	└─mmcblk0p1 ext4   29.7G /          bd34953d-41be-49d6-b1c0-c0c28a5e239c
  5808	zram1                50M /var/log
  5809
  5810	### zramctl:
  5811
  5812	NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
  5813	/dev/zram1 zstd           50M  132K  698B   36K       6 /var/log
  5814	/dev/zram0 lzo-rle       1.8G    4K   74B   12K       6 [SWAP]
  5815
  5816	### mtab:
  5817
  5818	/dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  5819	/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  5820	/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
  5821
  5822	### mmc0:b368 info:
  5823
  5824	               fwrev: 0x0
  5825	              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=CBADS MODALIAS=mmc:block
  5826	                 cid: 6f0303434241445310aa002b4d013b00
  5827	                 rca: 0xb368
  5828	                 csd: 400e005a5b590000f00e7f800a404000
  5829	              manfid: 0x00006f
  5830	                 ocr: 0x00200000
  5831	preferred_erase_size: 2097152
  5832	                type: SD
  5833	               hwrev: 0x1
  5834	                date: 11/2019
  5835	                 dsr: 0x404
  5836	          erase_size: 512
  5837	               oemid: 0x0303
  5838	              serial: 0xaa002b4d
  5839	                 ssr: 00000000000000280402800100fd180a001e00000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  5840	                 scr: 02b5800300000000
  5841	                name: CBADS
  5842
  5843	### Boot system health:
  5844
  5845	Time       big.LITTLE   load %cpu %sys %usr %nice %io %irq   CPU  C.St.
  5846	15:31:28: 1908/1992MHz  2.82  23%  11%   5%   0%   6%   0% 33.4°C  0/11
  5847	15:31:28: 1908/1992MHz  2.82  76%  33%   9%   0%  32%   0% 33.2°C  0/11
  5848	15:31:28: 1908/1992MHz  2.82  78%  15%   1%   0%  60%   0% 31.3°C  0/11
  5849	15:31:29: 1908/1992MHz  2.82  58%   8%   5%   0%  43%   1% 31.9°C  0/11
  5850	15:31:29: 1908/1000MHz  2.82  35%   3%   4%   0%  26%   0% 30.5°C  0/11
  5851
  5852	### Activated 1 lzo-rle zram swap devices with 1816 MB each
  5853
  5854	### Activated Armbian ramlog partition with zstd compression
  5855
  5856	Sun 14 Feb 2021 03:35:55 PM GMT | Odroid N2 | 21.02.1 | arm64 | aarch64 | 5.10.12-meson64
  5857
  5858	### dmesg:
  5859
  5860	[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
  5861	[    0.000000] Linux version 5.10.12-meson64 (root@beast) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #21.02.1 SMP PREEMPT Wed Feb 3 21:06:36 CET 2021
  5862	[    0.000000] Machine model: Hardkernel ODROID-N2
  5863	[    0.000000] efi: UEFI not found.
  5864	[    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
  5865	[    0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB
  5866	[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
  5867	[    0.000000] NUMA: No NUMA configuration found
  5868	[    0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ed7fffff]
  5869	[    0.000000] NUMA: NODE_DATA [mem 0xb502f100-0xb5030fff]
  5870	[    0.000000] Zone ranges:
  5871	[    0.000000]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
  5872	[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000ed7fffff]
  5873	[    0.000000]   Normal   empty
  5874	[    0.000000] Movable zone start for each node
  5875	[    0.000000] Early memory node ranges
  5876	[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000004ffffff]
  5877	[    0.000000]   node   0: [mem 0x0000000005300000-0x00000000ed7fffff]
  5878	[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ed7fffff]
  5879	[    0.000000] On node 0 totalpages: 972032
  5880	[    0.000000]   DMA zone: 4096 pages used for memmap
  5881	[    0.000000]   DMA zone: 0 pages reserved
  5882	[    0.000000]   DMA zone: 261376 pages, LIFO batch:63
  5883	[    0.000000]   DMA32 zone: 11104 pages used for memmap
  5884	[    0.000000]   DMA32 zone: 710656 pages, LIFO batch:63
  5885	[    0.000000] psci: probing for conduit method from DT.
  5886	[    0.000000] psci: PSCIv1.0 detected in firmware.
  5887	[    0.000000] psci: Using standard PSCI v0.2 function IDs
  5888	[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
  5889	[    0.000000] psci: SMC Calling Convention v1.1
  5890	[    0.000000] percpu: Embedded 23 pages/cpu s56728 r8192 d29288 u94208
  5891	[    0.000000] pcpu-alloc: s56728 r8192 d29288 u94208 alloc=23*4096
  5892	[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
  5893	[    0.000000] Detected VIPT I-cache on CPU0
  5894	[    0.000000] CPU features: detected: ARM erratum 845719
  5895	[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 956832
  5896	[    0.000000] Policy zone: DMA32
  5897	[    0.000000] Kernel command line: root=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c rootwait rootfstype=ext4 console=ttyAML0,115200n8 console=tty1 loglevel=1  no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=custombuilt cvbsmode=576cvbs max_freq_a53=1896 max_freq_a73=1800 maxcpus=6 voutmode=hdmi modeline=1920,1080,148500,56250,50,1920,2448,2492,2640,1080,1084,1089,1125,1,1,1 disablehpd=false  cvbscable= overscan=100 consoleblank=0
  5898	[    0.000000] Kernel parameter elevator= does not have any effect anymore.
  5899	               Please use sysfs to set IO scheduler for individual devices.
  5900	[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
  5901	[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
  5902	[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
  5903	[    0.000000] software IO TLB: mapped [mem 0x0000000038ac5000-0x000000003cac5000] (64MB)
  5904	[    0.000000] Memory: 2785352K/3888128K available (14144K kernel code, 1760K rwdata, 5508K rodata, 3328K init, 592K bss, 185272K reserved, 917504K cma-reserved)
  5905	[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
  5906	[    0.000000] rcu: Preemptible hierarchical RCU implementation.
  5907	[    0.000000] rcu: 	RCU event tracing is enabled.
  5908	[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
  5909	[    0.000000] 	Trampoline variant of Tasks RCU enabled.
  5910	[    0.000000] 	Rude variant of Tasks RCU enabled.
  5911	[    0.000000] 	Tracing variant of Tasks RCU enabled.
  5912	[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  5913	[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
  5914	[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
  5915	[    0.000000] GIC: Using split EOI/Deactivate mode
  5916	[    0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized
  5917	[    0.000000] random: get_random_bytes called from start_kernel+0x378/0x538 with crng_init=0
  5918	[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
  5919	[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  5920	[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  5921	[    0.000241] Console: colour dummy device 80x25
  5922	[    0.000276] printk: console [tty1] enabled
  5923	[    0.000364] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
  5924	[    0.000376] pid_max: default: 32768 minimum: 301
  5925	[    0.000459] LSM: Security Framework initializing
  5926	[    0.000485] Yama: becoming mindful.
  5927	[    0.000577] AppArmor: AppArmor initialized
  5928	[    0.000626] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
  5929	[    0.000645] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
  5930	[    0.002645] rcu: Hierarchical SRCU implementation.
  5931	[    0.005035] EFI services will not be available.
  5932	[    0.005452] smp: Bringing up secondary CPUs ...
  5933	[    0.006121] Detected VIPT I-cache on CPU1
  5934	[    0.006181] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
  5935	[    0.007376] CPU features: detected: ARM erratum 858921
  5936	[    0.007384] CPU features: detected: Spectre-v2
  5937	[    0.007388] CPU features: detected: Spectre-v4
  5938	[    0.007394] Detected VIPT I-cache on CPU2
  5939	[    0.007419] arch_timer: Enabling local workaround for ARM erratum 858921
  5940	[    0.007434] arch_timer: CPU2: Trapping CNTVCT access
  5941	[    0.007446] CPU2: Booted secondary processor 0x0000000100 [0x410fd092]
  5942	[    0.008151] Detected VIPT I-cache on CPU3
  5943	[    0.008167] arch_timer: Enabling local workaround for ARM erratum 858921
  5944	[    0.008174] arch_timer: CPU3: Trapping CNTVCT access
  5945	[    0.008182] CPU3: Booted secondary processor 0x0000000101 [0x410fd092]
  5946	[    0.008808] Detected VIPT I-cache on CPU4
  5947	[    0.008824] arch_timer: Enabling local workaround for ARM erratum 858921
  5948	[    0.008831] arch_timer: CPU4: Trapping CNTVCT access
  5949	[    0.008838] CPU4: Booted secondary processor 0x0000000102 [0x410fd092]
  5950	[    0.009451] Detected VIPT I-cache on CPU5
  5951	[    0.009467] arch_timer: Enabling local workaround for ARM erratum 858921
  5952	[    0.009474] arch_timer: CPU5: Trapping CNTVCT access
  5953	[    0.009482] CPU5: Booted secondary processor 0x0000000103 [0x410fd092]
  5954	[    0.009561] smp: Brought up 1 node, 6 CPUs
  5955	[    0.009579] SMP: Total of 6 processors activated.
  5956	[    0.009587] CPU features: detected: 32-bit EL0 Support
  5957	[    0.009593] CPU features: detected: CRC32 instructions
  5958	[    0.009599] CPU features: detected: 32-bit EL1 Support
  5959	[    0.020794] CPU: All CPU(s) started at EL2
  5960	[    0.020845] alternatives: patching kernel code
  5961	[    0.022786] devtmpfs: initialized
  5962	[    0.030436] Registered cp15_barrier emulation handler
  5963	[    0.030451] Registered setend emulation handler
  5964	[    0.030615] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  5965	[    0.030661] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
  5966	[    0.044580] pinctrl core: initialized pinctrl subsystem
  5967	[    0.045311] DMI not present or invalid.
  5968	[    0.045684] NET: Registered protocol family 16
  5969	[    0.047120] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
  5970	[    0.047391] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
  5971	[    0.047620] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
  5972	[    0.047664] audit: initializing netlink subsys (disabled)
  5973	[    0.047781] audit: type=2000 audit(0.044:1): state=initialized audit_enabled=0 res=1
  5974	[    0.049001] thermal_sys: Registered thermal governor 'fair_share'
  5975	[    0.049008] thermal_sys: Registered thermal governor 'bang_bang'
  5976	[    0.049012] thermal_sys: Registered thermal governor 'step_wise'
  5977	[    0.049015] thermal_sys: Registered thermal governor 'user_space'
  5978	[    0.049441] cpuidle: using governor menu
  5979	[    0.049792] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  5980	[    0.049908] ASID allocator initialised with 65536 entries
  5981	[    0.050819] Serial: AMBA PL011 UART driver
  5982	[    0.083298] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
  5983	[    0.083307] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
  5984	[    0.083312] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
  5985	[    0.083316] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
  5986	[    0.086294] cryptd: max_cpu_qlen set to 1000
  5987	[    0.156200] raid6: neonx8   gen()  2779 MB/s
  5988	[    0.224671] raid6: neonx8   xor()  1602 MB/s
  5989	[    0.292393] raid6: neonx4   gen()  2200 MB/s
  5990	[    0.360431] raid6: neonx4   xor()  2399 MB/s
  5991	[    0.428496] raid6: neonx2   gen()  2550 MB/s
  5992	[    0.496581] raid6: neonx2   xor()  2198 MB/s
  5993	[    0.564634] raid6: neonx1   gen()  2069 MB/s
  5994	[    0.632692] raid6: neonx1   xor()  1727 MB/s
  5995	[    0.700763] raid6: int64x8  gen()  1376 MB/s
  5996	[    0.768823] raid6: int64x8  xor()   735 MB/s
  5997	[    0.836911] raid6: int64x4  gen()  1463 MB/s
  5998	[    0.904964] raid6: int64x4  xor()   733 MB/s
  5999	[    0.973023] raid6: int64x2  gen()  1362 MB/s
  6000	[    1.041100] raid6: int64x2  xor()   619 MB/s
  6001	[    1.109169] raid6: int64x1  gen()  1120 MB/s
  6002	[    1.177228] raid6: int64x1  xor()   462 MB/s
  6003	[    1.177231] raid6: using algorithm neonx8 gen() 2779 MB/s
  6004	[    1.177234] raid6: .... xor() 1602 MB/s, rmw enabled
  6005	[    1.177238] raid6: using neon recovery algorithm
  6006	[    1.177690] ACPI: Interpreter disabled.
  6007	[    1.178520] 5V: supplied by 12V
  6008	[    1.179413] VDDAO_3V3: supplied by 12V
  6009	[    1.179867] iommu: Default domain type: Translated
  6010	[    1.179981] vgaarb: loaded
  6011	[    1.180711] SCSI subsystem initialized
  6012	[    1.180961] usbcore: registered new interface driver usbfs
  6013	[    1.181008] usbcore: registered new interface driver hub
  6014	[    1.181043] usbcore: registered new device driver usb
  6015	[    1.181305] pps_core: LinuxPPS API ver. 1 registered
  6016	[    1.181310] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  6017	[    1.181327] PTP clock support registered
  6018	[    1.181523] EDAC MC: Ver: 3.0.0
  6019	[    1.182970] NetLabel: Initializing
  6020	[    1.182977] NetLabel:  domain hash size = 128
  6021	[    1.182980] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
  6022	[    1.183021] NetLabel:  unlabeled traffic allowed by default
  6023	[    1.183461] clocksource: Switched to clocksource arch_sys_counter
  6024	[    1.183666] VFS: Disk quotas dquot_6.6.0
  6025	[    1.183711] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  6026	[    1.184078] AppArmor: AppArmor Filesystem Enabled
  6027	[    1.184125] pnp: PnP ACPI: disabled
  6028	[    1.189256] NET: Registered protocol family 2
  6029	[    1.189708] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
  6030	[    1.189814] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
  6031	[    1.190072] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
  6032	[    1.190259] TCP: Hash tables configured (established 32768 bind 32768)
  6033	[    1.190409] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
  6034	[    1.190477] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
  6035	[    1.190523] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
  6036	[    1.190667] NET: Registered protocol family 1
  6037	[    1.190687] PCI: CLS 0 bytes, default 64
  6038	[    1.190812] Trying to unpack rootfs image as initramfs...
  6039	[    1.727158] Freeing initrd memory: 13544K
  6040	[    1.728078] kvm [1]: IPA Size Limit: 40 bits
  6041	[    1.728787] kvm [1]: vgic interrupt IRQ9
  6042	[    1.728920] kvm [1]: Hyp mode initialized successfully
  6043	[    1.734026] Initialise system trusted keyrings
  6044	[    1.734063] Key type blacklist registered
  6045	[    1.734167] workingset: timestamp_bits=44 max_order=20 bucket_order=0
  6046	[    1.737371] zbud: loaded
  6047	[    1.738350] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  6048	[    1.738797] fuse: init (API version 7.32)
  6049	[    1.739581] integrity: Platform Keyring initialized
  6050	[    1.766039] xor: measuring software checksum speed
  6051	[    1.768887]    8regs           :  3473 MB/sec
  6052	[    1.771336]    32regs          :  4024 MB/sec
  6053	[    1.773989]    arm64_neon      :  3719 MB/sec
  6054	[    1.773993] xor: using function: 32regs (4024 MB/sec)
  6055	[    1.774000] Key type asymmetric registered
  6056	[    1.774004] Asymmetric key parser 'x509' registered
  6057	[    1.774036] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
  6058	[    1.774125] io scheduler mq-deadline registered
  6059	[    1.774130] io scheduler kyber registered
  6060	[    1.774217] io scheduler bfq registered
  6061	[    1.776716] gpio-447 (usb-hub-reset): hogged as output/high
  6062	[    1.779591] EINJ: ACPI disabled.
  6063	[    1.785628] soc soc0: Amlogic Meson G12B (S922X) Revision 29:a (40:2) Detected
  6064	[    1.786994] VCC_3V3: supplied by VDDAO_3V3
  6065	[    1.787029] FLASH_1V8: supplied by VCC_3V3
  6066	[    1.787060] VCC_1V8: supplied by VCC_3V3
  6067	[    1.787086] VDDAO_1V8: supplied by VDDAO_3V3
  6068	[    1.787130] VDDCPU_A: supplied by regulator-dummy
  6069	[    1.787510] VDDCPU_B: supplied by regulator-dummy
  6070	[    1.788176] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
  6071	[    1.790397] Serial: AMBA driver
  6072	[    1.790682] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart
  6073	[    1.790776] printk: console [ttyAML0] enabled
  6074	[    1.791334] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 33, base_baud = 1500000) is a meson_uart
  6075	[    1.796585] loop: module loaded
  6076	[    1.798438] libphy: Fixed MDIO Bus: probed
  6077	[    1.799373] tun: Universal TUN/TAP device driver, 1.6
  6078	[    1.800057] thunder_xcv, ver 1.0
  6079	[    1.800091] thunder_bgx, ver 1.0
  6080	[    1.800119] nicpf, ver 1.0
  6081	[    1.800564] e1000e: Intel(R) PRO/1000 Network Driver
  6082	[    1.800568] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
  6083	[    1.800611] igb: Intel(R) Gigabit Ethernet Network Driver
  6084	[    1.800614] igb: Copyright (c) 2007-2014 Intel Corporation.
  6085	[    1.800652] igbvf: Intel(R) Gigabit Virtual Function Network Driver
  6086	[    1.800656] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
  6087	[    1.800788] sky2: driver version 1.30
  6088	[    1.801141] VFIO - User Level meta-driver version: 0.3
  6089	[    1.802459] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  6090	[    1.802479] ehci-pci: EHCI PCI platform driver
  6091	[    1.802510] ehci-platform: EHCI generic platform driver
  6092	[    1.802648] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  6093	[    1.802658] ohci-pci: OHCI PCI platform driver
  6094	[    1.802695] ohci-platform: OHCI generic platform driver
  6095	[    1.803074] usbcore: registered new interface driver usb-storage
  6096	[    1.804478] mousedev: PS/2 mouse device common for all mice
  6097	[    1.804868] i2c /dev entries driver
  6098	[    1.809944] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17
  6099	[    1.810604] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz
  6100	[    1.811281] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-1 failed:-17
  6101	[    1.812523] sdhci: Secure Digital Host Controller Interface driver
  6102	[    1.812530] sdhci: Copyright(c) Pierre Ossman
  6103	[    1.812650] Synopsys Designware Multimedia Card Interface Driver
  6104	[    1.813081] sdhci-pltfm: SDHCI platform and OF driver helper
  6105	[    1.813545] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq
  6106	[    1.813986] ledtrig-cpu: registered to indicate activity on CPUs
  6107	[    1.814221] meson-sm: secure-monitor enabled
  6108	[    1.814451] hid: raw HID events driver (C) Jiri Kosina
  6109	[    1.814533] usbcore: registered new interface driver usbhid
  6110	[    1.814535] usbhid: USB HID core driver
  6111	[    1.815576] NET: Registered protocol family 10
  6112	[    1.815993] Segment Routing with IPv6
  6113	[    1.816020] NET: Registered protocol family 17
  6114	[    1.816063] 8021q: 802.1Q VLAN Support v1.8
  6115	[    1.816085] Key type dns_resolver registered
  6116	[    1.816379] registered taskstats version 1
  6117	[    1.816387] Loading compiled-in X.509 certificates
  6118	[    1.818048] Loaded X.509 cert 'Build time autogenerated kernel key: f47c178852ca39740c3546b008122b65f5ed9bce'
  6119	[    1.819896] zswap: loaded using pool zstd/z3fold
  6120	[    1.820108] Key type ._fscrypt registered
  6121	[    1.820111] Key type .fscrypt registered
  6122	[    1.820113] Key type fscrypt-provisioning registered
  6123	[    1.821193] Btrfs loaded, crc32c=crc32c-generic
  6124	[    1.827007] Key type encrypted registered
  6125	[    1.827018] AppArmor: AppArmor sha1 policy hashing enabled
  6126	[    1.833260] HUB_5V: supplied by 5V
  6127	[    1.833479] USB_PWR_EN: supplied by 5V
  6128	[    1.835081] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2
  6129	[    1.835088] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1
  6130	[    1.837780] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator
  6131	[    1.837828] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator
  6132	[    1.838114] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM
  6133	[    1.838696] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  6134	[    1.838708] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
  6135	[    1.838795] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010
  6136	[    1.838814] xhci-hcd xhci-hcd.0.auto: irq 41, io mem 0xff500000
  6137	[    1.838935] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
  6138	[    1.838939] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  6139	[    1.838942] usb usb1: Product: xHCI Host Controller
  6140	[    1.838944] usb usb1: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
  6141	[    1.838947] usb usb1: SerialNumber: xhci-hcd.0.auto
  6142	[    1.839152] hub 1-0:1.0: USB hub found
  6143	[    1.839165] hub 1-0:1.0: 2 ports detected
  6144	[    1.839295] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  6145	[    1.839300] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  6146	[    1.839305] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  6147	[    1.839325] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
  6148	[    1.839360] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
  6149	[    1.839363] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  6150	[    1.839365] usb usb2: Product: xHCI Host Controller
  6151	[    1.839367] usb usb2: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
  6152	[    1.839369] usb usb2: SerialNumber: xhci-hcd.0.auto
  6153	[    1.839639] hub 2-0:1.0: USB hub found
  6154	[    1.839652] hub 2-0:1.0: 1 port detected
  6155	[    1.840815] meson-gx-mmc ffe05000.sd: Got CD GPIO
  6156	[    1.868472] Freeing unused kernel memory: 3328K
  6157	[    1.895572] Run /init as init process
  6158	[    1.895576]   with arguments:
  6159	[    1.895578]     /init
  6160	[    1.895580]   with environment:
  6161	[    1.895582]     HOME=/
  6162	[    1.895583]     TERM=linux
  6163	[    1.895585]     hdmimode=custombuilt
  6164	[    1.895587]     cvbsmode=576cvbs
  6165	[    1.895588]     max_freq_a53=1896
  6166	[    1.895589]     max_freq_a73=1800
  6167	[    1.895591]     voutmode=hdmi
  6168	[    1.895593]     modeline=1920,1080,148500,56250,50,1920,2448,2492,2640,1080,1084,1089,1125,1,1,1
  6169	[    1.895594]     disablehpd=false
  6170	[    1.895595]     cvbscable=
  6171	[    1.895597]     overscan=100
  6172	[    1.918162] mmc0: new high speed SDHC card at address b368
  6173	[    1.918960] mmcblk0: mmc0:b368 CBADS 30.0 GiB
  6174	[    1.921406]  mmcblk0: p1
  6175	[    2.046518] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found
  6176	[    2.046524] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found
  6177	[    2.046632] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock
  6178	[    2.050202] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37
  6179	[    2.050213] meson8b-dwmac ff3f0000.ethernet: 	DWMAC1000
  6180	[    2.050216] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported
  6181	[    2.050219] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported
  6182	[    2.050221] meson8b-dwmac ff3f0000.ethernet: COE Type 2
  6183	[    2.050223] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported
  6184	[    2.050225] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported
  6185	[    2.050295] meson8b-dwmac ff3f0000.ethernet: Normal descriptors
  6186	[    2.050299] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled
  6187	[    2.050302] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
  6188	[    2.050555] libphy: stmmac: probed
  6189	[    2.052025] libphy: mdio_mux: probed
  6190	[    2.057629] meson-vrtc ff8000a8.rtc: registered as rtc1
  6191	[    2.086340] rtc-pcf8563 1-0051: registered as rtc0
  6192	[    2.086499] random: fast init done
  6193	[    2.087501] rtc-pcf8563 1-0051: setting system clock to 2021-02-14T15:35:48 UTC (1613316948)
  6194	[    2.179498] usb 1-1: new high-speed USB device number 2 using xhci-hcd
  6195	[    2.263931] libphy: mdio_mux: probed
  6196	[    2.329897] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.04
  6197	[    2.329906] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  6198	[    2.329911] usb 1-1: Product: USB2.1 Hub
  6199	[    2.329914] usb 1-1: Manufacturer: GenesysLogic
  6200	[    2.383643] hub 1-1:1.0: USB hub found
  6201	[    2.383891] hub 1-1:1.0: 4 ports detected
  6202	[    2.455601] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
  6203	[    2.478072] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.04
  6204	[    2.478078] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  6205	[    2.478081] usb 2-1: Product: USB3.1 Hub
  6206	[    2.478084] usb 2-1: Manufacturer: GenesysLogic
  6207	[    2.495583] hub 2-1:1.0: USB hub found
  6208	[    2.495874] hub 2-1:1.0: 4 ports detected
  6209	[    2.733524] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
  6210	[    3.551830] systemd[1]: Inserted module 'autofs4'
  6211	[    3.598411] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  6212	[    3.598626] systemd[1]: Detected architecture arm64.
  6213	[    3.621163] systemd[1]: Set hostname to <odroidn2>.
  6214	[    3.950447] random: systemd: uninitialized urandom read (16 bytes read)
  6215	[    3.953775] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
  6216	[    3.953817] random: systemd: uninitialized urandom read (16 bytes read)
  6217	[    3.954077] systemd[1]: Listening on udev Control Socket.
  6218	[    3.954278] random: systemd: uninitialized urandom read (16 bytes read)
  6219	[    3.954379] systemd[1]: Listening on udev Kernel Socket.
  6220	[    3.954611] systemd[1]: Listening on Journal Socket (/dev/log).
  6221	[    3.954765] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
  6222	[    3.954853] systemd[1]: Reached target Paths.
  6223	[    3.955068] systemd[1]: Listening on Journal Socket.
  6224	[    4.042461] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
  6225	[    4.531202] zram: Added device: zram0
  6226	[    4.531407] zram: Added device: zram1
  6227	[    4.531809] zram: Added device: zram2
  6228	[    4.638772] pwm-gpio pwmgpio: 1 gpio pwms loaded
  6229	[    4.788189] zram0: detected capacity change from 0 to 1904500736
  6230	[    4.794152] mc: Linux media interface: v0.10
  6231	[    4.829664] meson-saradc ff809000.adc: supply vref not found, using dummy regulator
  6232	[    4.849394] videodev: Linux video capture interface: v2.00
  6233	[    4.863932] panfrost ffe40000.gpu: clock rate = 24000000
  6234	[    4.863981] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19
  6235	[    4.864572] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0
  6236	[    4.864590] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400
  6237	[    4.864595] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
  6238	[    4.864598] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1
  6239	[    4.879291] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 0
  6240	[    4.895565] Registered IR keymap rc-odroid
  6241	[    4.918182] meson-drm ff900000.vpu: Queued 2 outputs on vpu
  6242	[    4.927807] IR NEC protocol handler initialized
  6243	[    4.955721] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0
  6244	[    4.955880] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
  6245	[    4.955978] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input0
  6246	[    4.956212] meson-ir ff808000.ir: receiver initialized
  6247	[    4.962178] meson-drm ff900000.vpu: CVBS Output connector not available
  6248	[    4.987546] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
  6249	[    4.988061] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
  6250	[    4.988636] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
  6251	[    4.989048] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 1
  6252	[    5.005575] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  6253	[    5.267623] Console: switching to colour frame buffer device 240x67
  6254	[    5.294133] meson-drm ff900000.vpu: [drm] fb0: mesondrmfb frame buffer device
  6255	[    5.343856] axg-sound-card sound: ASoC: no DMI vendor name!
  6256	[    5.855484] Adding 1859860k swap on /dev/zram0.  Priority:5 extents:1 across:1859860k SSFS
  6257	[    5.920174] zram1: detected capacity change from 0 to 52428800
  6258	[    8.005272] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
  6259	[    8.005293] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
  6260	[    8.998474] systemd[1]: Started Armbian memory supported logging.
  6261	[    9.000984] systemd[1]: Starting Journal Service...
  6262	[    9.060395] systemd[1]: Started Journal Service.
  6263	[    9.085554] systemd-journald[1839]: Received request to flush runtime journal from PID 1
  6264
  6265	### armbian-release:
  6266
  6267	# PLEASE DO NOT EDIT THIS FILE
  6268	BOARD=odroidn2
  6269	BOARD_NAME="Odroid N2"
  6270	BOARDFAMILY=meson-g12b
  6271	BUILD_REPOSITORY_URL=https://github.com/armbian/build
  6272	BUILD_REPOSITORY_COMMIT=5f03d652
  6273	DISTRIBUTION_CODENAME=buster
  6274	DISTRIBUTION_STATUS=supported
  6275	VERSION=21.02.1
  6276	LINUXFAMILY=meson64
  6277	BRANCH=current
  6278	ARCH=arm64
  6279	IMAGE_TYPE=stable
  6280	BOARD_TYPE=conf
  6281	INITRD_ARCH=arm64
  6282	KERNEL_IMAGE_TYPE=Image
  6283
  6284	### boot environment:
  6285
  6286	verbosity=1
  6287	console=both
  6288	overlay_prefix=meson
  6289	rootdev=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c
  6290	rootfstype=ext4
  6291	usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
  6292
  6293	### lsusb:
  6294
  6295	Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc.
  6296	Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  6297	Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
  6298	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  6299
  6300	### lscpu:
  6301
  6302	Architecture:        aarch64
  6303	Byte Order:          Little Endian
  6304	CPU(s):              6
  6305	On-line CPU(s) list: 0-5
  6306	Thread(s) per core:  1
  6307	Core(s) per socket:  3
  6308	Socket(s):           2
  6309	NUMA node(s):        1
  6310	Vendor ID:           ARM
  6311	Model:               4
  6312	Model name:          Cortex-A53
  6313	Stepping:            r0p4
  6314	CPU max MHz:         1992.0000
  6315	CPU min MHz:         100.0000
  6316	BogoMIPS:            48.00
  6317	L1d cache:           unknown size
  6318	L1i cache:           unknown size
  6319	L2 cache:            unknown size
  6320	NUMA node0 CPU(s):   0-5
  6321	Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  6322
  6323	### cpuinfo:
  6324
  6325	processor	: 0
  6326	BogoMIPS	: 48.00
  6327	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  6328	CPU implementer	: 0x41
  6329	CPU architecture: 8
  6330	CPU variant	: 0x0
  6331	CPU part	: 0xd03
  6332	CPU revision	: 4
  6333
  6334	processor	: 1
  6335	BogoMIPS	: 48.00
  6336	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  6337	CPU implementer	: 0x41
  6338	CPU architecture: 8
  6339	CPU variant	: 0x0
  6340	CPU part	: 0xd03
  6341	CPU revision	: 4
  6342
  6343	processor	: 2
  6344	BogoMIPS	: 48.00
  6345	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  6346	CPU implementer	: 0x41
  6347	CPU architecture: 8
  6348	CPU variant	: 0x0
  6349	CPU part	: 0xd09
  6350	CPU revision	: 2
  6351
  6352	processor	: 3
  6353	BogoMIPS	: 48.00
  6354	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  6355	CPU implementer	: 0x41
  6356	CPU architecture: 8
  6357	CPU variant	: 0x0
  6358	CPU part	: 0xd09
  6359	CPU revision	: 2
  6360
  6361	processor	: 4
  6362	BogoMIPS	: 48.00
  6363	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  6364	CPU implementer	: 0x41
  6365	CPU architecture: 8
  6366	CPU variant	: 0x0
  6367	CPU part	: 0xd09
  6368	CPU revision	: 2
  6369
  6370	processor	: 5
  6371	BogoMIPS	: 48.00
  6372	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  6373	CPU implementer	: 0x41
  6374	CPU architecture: 8
  6375	CPU variant	: 0x0
  6376	CPU part	: 0xd09
  6377	CPU revision	: 2
  6378
  6379
  6380	### meminfo:
  6381
  6382	MemTotal:        3719728 kB
  6383	MemFree:         3404044 kB
  6384	MemAvailable:    3356372 kB
  6385	Buffers:           11544 kB
  6386	Cached:            42116 kB
  6387	SwapCached:            0 kB
  6388	Active:            28568 kB
  6389	Inactive:         175588 kB
  6390	Active(anon):        104 kB
  6391	Inactive(anon):   155564 kB
  6392	Active(file):      28464 kB
  6393	Inactive(file):    20024 kB
  6394	Unevictable:           0 kB
  6395	Mlocked:               0 kB
  6396	SwapTotal:       1859860 kB
  6397	SwapFree:        1859860 kB
  6398	Dirty:              3036 kB
  6399	Writeback:             0 kB
  6400	AnonPages:        150872 kB
  6401	Mapped:            13644 kB
  6402	Shmem:              4868 kB
  6403	KReclaimable:      12884 kB
  6404	Slab:              39084 kB
  6405	SReclaimable:      12884 kB
  6406	SUnreclaim:        26200 kB
  6407	KernelStack:        2592 kB
  6408	PageTables:         6616 kB
  6409	NFS_Unstable:          0 kB
  6410	Bounce:                0 kB
  6411	WritebackTmp:          0 kB
  6412	CommitLimit:     3719724 kB
  6413	Committed_AS:    4240268 kB
  6414	VmallocTotal:   135290159040 kB
  6415	VmallocUsed:       31360 kB
  6416	VmallocChunk:          0 kB
  6417	Percpu:             1368 kB
  6418	HardwareCorrupted:     0 kB
  6419	AnonHugePages:         0 kB
  6420	ShmemHugePages:        0 kB
  6421	ShmemPmdMapped:        0 kB
  6422	FileHugePages:         0 kB
  6423	FilePmdMapped:         0 kB
  6424	CmaTotal:         917504 kB
  6425	CmaFree:          901724 kB
  6426	HugePages_Total:       0
  6427	HugePages_Free:        0
  6428	HugePages_Rsvd:        0
  6429	HugePages_Surp:        0
  6430	Hugepagesize:       2048 kB
  6431	Hugetlb:               0 kB
  6432
  6433	### virtual memory:
  6434
  6435	vm.admin_reserve_kbytes = 8192
  6436	vm.block_dump = 0
  6437	vm.compaction_proactiveness = 20
  6438	vm.compact_unevictable_allowed = 1
  6439	vm.dirty_background_bytes = 0
  6440	vm.dirty_background_ratio = 10
  6441	vm.dirty_bytes = 0
  6442	vm.dirty_expire_centisecs = 3000
  6443	vm.dirty_ratio = 20
  6444	vm.dirtytime_expire_seconds = 43200
  6445	vm.dirty_writeback_centisecs = 500
  6446	vm.extfrag_threshold = 500
  6447	vm.hugetlb_shm_group = 0
  6448	vm.laptop_mode = 0
  6449	vm.legacy_va_layout = 0
  6450	vm.lowmem_reserve_ratio = 256	256	32	0
  6451	vm.max_map_count = 65530
  6452	vm.memory_failure_early_kill = 0
  6453	vm.memory_failure_recovery = 1
  6454	vm.min_free_kbytes = 45056
  6455	vm.min_slab_ratio = 5
  6456	vm.min_unmapped_ratio = 1
  6457	vm.mmap_min_addr = 4096
  6458	vm.mmap_rnd_bits = 18
  6459	vm.mmap_rnd_compat_bits = 11
  6460	vm.nr_hugepages = 0
  6461	vm.nr_hugepages_mempolicy = 0
  6462	vm.nr_overcommit_hugepages = 0
  6463	vm.numa_stat = 1
  6464	vm.numa_zonelist_order = Node
  6465	vm.oom_dump_tasks = 1
  6466	vm.oom_kill_allocating_task = 0
  6467	vm.overcommit_kbytes = 0
  6468	vm.overcommit_memory = 0
  6469	vm.overcommit_ratio = 50
  6470	vm.page-cluster = 0
  6471	vm.page_lock_unfairness = 5
  6472	vm.panic_on_oom = 0
  6473	vm.percpu_pagelist_fraction = 0
  6474	vm.stat_interval = 1
  6475	vm.swappiness = 100
  6476	vm.user_reserve_kbytes = 115074
  6477	vm.vfs_cache_pressure = 100
  6478	vm.watermark_boost_factor = 15000
  6479	vm.watermark_scale_factor = 10
  6480	vm.zone_reclaim_mode = 0
  6481
  6482	### ip addr:
  6483
  6484	1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  6485	    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  6486	    inet XXX.XXX.0.1/8 scope host lo
  6487	       valid_lft forever preferred_lft forever
  6488	    inet6 ::1/128 scope host
  6489	       valid_lft forever preferred_lft forever
  6490	2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  6491	    link/ether 00:1e:06:42:03:f8 brd ff:ff:ff:ff:ff:ff
  6492
  6493	### partitions:
  6494
  6495	major minor  #blocks  name
  6496
  6497	 179        0   31464960 mmcblk0
  6498	 179        1   31146208 mmcblk0p1
  6499	 252        0    1859864 zram0
  6500	 252        1      51200 zram1
  6501
  6502	### df:
  6503
  6504	udev            1.4G     0  1.4G   0% /dev
  6505	tmpfs           364M  4.9M  359M   2% /run
  6506	/dev/mmcblk0p1   30G  1.7G   28G   6% /
  6507	tmpfs           1.8G     0  1.8G   0% /dev/shm
  6508	tmpfs           5.0M  4.0K  5.0M   1% /run/lock
  6509	tmpfs           1.8G     0  1.8G   0% /sys/fs/cgroup
  6510	tmpfs           1.8G     0  1.8G   0% /tmp
  6511	/dev/zram1       49M  3.0M   42M   7% /var/log
  6512
  6513	### lsblk:
  6514
  6515	NAME        FSTYPE  SIZE MOUNTPOINT UUID
  6516	mmcblk0              30G
  6517	└─mmcblk0p1 ext4   29.7G /          bd34953d-41be-49d6-b1c0-c0c28a5e239c
  6518	zram1                50M /var/log
  6519
  6520	### zramctl:
  6521
  6522	NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
  6523	/dev/zram1 zstd           50M  132K  698B   36K       6 /var/log
  6524	/dev/zram0 lzo-rle       1.8G    4K   74B   12K       6 [SWAP]
  6525
  6526	### mtab:
  6527
  6528	/dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  6529	/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  6530	/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
  6531
  6532	### mmc0:b368 info:
  6533
  6534	               fwrev: 0x0
  6535	              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=CBADS MODALIAS=mmc:block
  6536	                 cid: 6f0303434241445310aa002b4d013b00
  6537	                 rca: 0xb368
  6538	                 csd: 400e005a5b590000f00e7f800a404000
  6539	              manfid: 0x00006f
  6540	                 ocr: 0x00200000
  6541	preferred_erase_size: 2097152
  6542	                type: SD
  6543	               hwrev: 0x1
  6544	                date: 11/2019
  6545	                 dsr: 0x404
  6546	          erase_size: 512
  6547	               oemid: 0x0303
  6548	              serial: 0xaa002b4d
  6549	                 ssr: 00000000000000280402800100fd180a001e00000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  6550	                 scr: 02b5800300000000
  6551	                name: CBADS
  6552
  6553	### Boot system health:
  6554
  6555	Time       big.LITTLE   load %cpu %sys %usr %nice %io %irq   CPU  C.St.
  6556	15:35:56: 1908/1992MHz  1.05  25%  12%   5%   0%   7%   0% 34.7°C  0/11
  6557	15:35:57: 1908/1992MHz  1.05  84%  28%   3%   0%  50%   0% 33.7°C  0/11
  6558	15:35:57: 1908/1992MHz  1.05  63%   8%   8%   0%  45%   0% 31.6°C  0/11
  6559	15:35:57: 1908/1992MHz  1.05  55%   3%   2%   0%  50%   0% 30.7°C  0/11
  6560	15:35:58: 1908/1992MHz  1.05  52%   1%   3%   0%  44%   0% 31.0°C  0/11
  6561
  6562	### Activated 1 lzo-rle zram swap devices with 1816 MB each
  6563
  6564	### Activated Armbian ramlog partition with zstd compression
  6565
  6566	Sun 14 Feb 2021 03:40:26 PM GMT | Odroid N2 | 21.02.1 | arm64 | aarch64 | 5.10.12-meson64
  6567
  6568	### dmesg:
  6569
  6570	[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
  6571	[    0.000000] Linux version 5.10.12-meson64 (root@beast) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #21.02.1 SMP PREEMPT Wed Feb 3 21:06:36 CET 2021
  6572	[    0.000000] Machine model: Hardkernel ODROID-N2
  6573	[    0.000000] efi: UEFI not found.
  6574	[    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
  6575	[    0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB
  6576	[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
  6577	[    0.000000] NUMA: No NUMA configuration found
  6578	[    0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ed7fffff]
  6579	[    0.000000] NUMA: NODE_DATA [mem 0xb502f100-0xb5030fff]
  6580	[    0.000000] Zone ranges:
  6581	[    0.000000]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
  6582	[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000ed7fffff]
  6583	[    0.000000]   Normal   empty
  6584	[    0.000000] Movable zone start for each node
  6585	[    0.000000] Early memory node ranges
  6586	[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000004ffffff]
  6587	[    0.000000]   node   0: [mem 0x0000000005300000-0x00000000ed7fffff]
  6588	[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ed7fffff]
  6589	[    0.000000] On node 0 totalpages: 972032
  6590	[    0.000000]   DMA zone: 4096 pages used for memmap
  6591	[    0.000000]   DMA zone: 0 pages reserved
  6592	[    0.000000]   DMA zone: 261376 pages, LIFO batch:63
  6593	[    0.000000]   DMA32 zone: 11104 pages used for memmap
  6594	[    0.000000]   DMA32 zone: 710656 pages, LIFO batch:63
  6595	[    0.000000] psci: probing for conduit method from DT.
  6596	[    0.000000] psci: PSCIv1.0 detected in firmware.
  6597	[    0.000000] psci: Using standard PSCI v0.2 function IDs
  6598	[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
  6599	[    0.000000] psci: SMC Calling Convention v1.1
  6600	[    0.000000] percpu: Embedded 23 pages/cpu s56728 r8192 d29288 u94208
  6601	[    0.000000] pcpu-alloc: s56728 r8192 d29288 u94208 alloc=23*4096
  6602	[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
  6603	[    0.000000] Detected VIPT I-cache on CPU0
  6604	[    0.000000] CPU features: detected: ARM erratum 845719
  6605	[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 956832
  6606	[    0.000000] Policy zone: DMA32
  6607	[    0.000000] Kernel command line: root=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c rootwait rootfstype=ext4 console=ttyAML0,115200n8 console=tty1 loglevel=1  no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=custombuilt cvbsmode=576cvbs max_freq_a53=1896 max_freq_a73=1800 maxcpus=6 voutmode=hdmi modeline=1920,1080,148500,56250,50,1920,2448,2492,2640,1080,1084,1089,1125,1,1,1 disablehpd=false  cvbscable= overscan=100 consoleblank=0
  6608	[    0.000000] Kernel parameter elevator= does not have any effect anymore.
  6609	               Please use sysfs to set IO scheduler for individual devices.
  6610	[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
  6611	[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
  6612	[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
  6613	[    0.000000] software IO TLB: mapped [mem 0x0000000038ac5000-0x000000003cac5000] (64MB)
  6614	[    0.000000] Memory: 2785352K/3888128K available (14144K kernel code, 1760K rwdata, 5508K rodata, 3328K init, 592K bss, 185272K reserved, 917504K cma-reserved)
  6615	[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
  6616	[    0.000000] rcu: Preemptible hierarchical RCU implementation.
  6617	[    0.000000] rcu: 	RCU event tracing is enabled.
  6618	[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
  6619	[    0.000000] 	Trampoline variant of Tasks RCU enabled.
  6620	[    0.000000] 	Rude variant of Tasks RCU enabled.
  6621	[    0.000000] 	Tracing variant of Tasks RCU enabled.
  6622	[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  6623	[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
  6624	[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
  6625	[    0.000000] GIC: Using split EOI/Deactivate mode
  6626	[    0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized
  6627	[    0.000000] random: get_random_bytes called from start_kernel+0x378/0x538 with crng_init=0
  6628	[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
  6629	[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  6630	[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  6631	[    0.000240] Console: colour dummy device 80x25
  6632	[    0.000274] printk: console [tty1] enabled
  6633	[    0.000362] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
  6634	[    0.000374] pid_max: default: 32768 minimum: 301
  6635	[    0.000456] LSM: Security Framework initializing
  6636	[    0.000482] Yama: becoming mindful.
  6637	[    0.000572] AppArmor: AppArmor initialized
  6638	[    0.000623] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
  6639	[    0.000642] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
  6640	[    0.002639] rcu: Hierarchical SRCU implementation.
  6641	[    0.005043] EFI services will not be available.
  6642	[    0.005467] smp: Bringing up secondary CPUs ...
  6643	[    0.006138] Detected VIPT I-cache on CPU1
  6644	[    0.006199] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
  6645	[    0.007393] CPU features: detected: ARM erratum 858921
  6646	[    0.007401] CPU features: detected: Spectre-v2
  6647	[    0.007404] CPU features: detected: Spectre-v4
  6648	[    0.007410] Detected VIPT I-cache on CPU2
  6649	[    0.007436] arch_timer: Enabling local workaround for ARM erratum 858921
  6650	[    0.007450] arch_timer: CPU2: Trapping CNTVCT access
  6651	[    0.007463] CPU2: Booted secondary processor 0x0000000100 [0x410fd092]
  6652	[    0.008170] Detected VIPT I-cache on CPU3
  6653	[    0.008186] arch_timer: Enabling local workaround for ARM erratum 858921
  6654	[    0.008193] arch_timer: CPU3: Trapping CNTVCT access
  6655	[    0.008201] CPU3: Booted secondary processor 0x0000000101 [0x410fd092]
  6656	[    0.008829] Detected VIPT I-cache on CPU4
  6657	[    0.008846] arch_timer: Enabling local workaround for ARM erratum 858921
  6658	[    0.008853] arch_timer: CPU4: Trapping CNTVCT access
  6659	[    0.008861] CPU4: Booted secondary processor 0x0000000102 [0x410fd092]
  6660	[    0.009476] Detected VIPT I-cache on CPU5
  6661	[    0.009493] arch_timer: Enabling local workaround for ARM erratum 858921
  6662	[    0.009500] arch_timer: CPU5: Trapping CNTVCT access
  6663	[    0.009508] CPU5: Booted secondary processor 0x0000000103 [0x410fd092]
  6664	[    0.009588] smp: Brought up 1 node, 6 CPUs
  6665	[    0.009605] SMP: Total of 6 processors activated.
  6666	[    0.009613] CPU features: detected: 32-bit EL0 Support
  6667	[    0.009618] CPU features: detected: CRC32 instructions
  6668	[    0.009624] CPU features: detected: 32-bit EL1 Support
  6669	[    0.020896] CPU: All CPU(s) started at EL2
  6670	[    0.020945] alternatives: patching kernel code
  6671	[    0.022888] devtmpfs: initialized
  6672	[    0.030570] Registered cp15_barrier emulation handler
  6673	[    0.030584] Registered setend emulation handler
  6674	[    0.030718] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  6675	[    0.030756] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
  6676	[    0.044691] pinctrl core: initialized pinctrl subsystem
  6677	[    0.045404] DMI not present or invalid.
  6678	[    0.045768] NET: Registered protocol family 16
  6679	[    0.047296] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
  6680	[    0.047568] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
  6681	[    0.047796] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
  6682	[    0.047839] audit: initializing netlink subsys (disabled)
  6683	[    0.047935] audit: type=2000 audit(0.044:1): state=initialized audit_enabled=0 res=1
  6684	[    0.049256] thermal_sys: Registered thermal governor 'fair_share'
  6685	[    0.049263] thermal_sys: Registered thermal governor 'bang_bang'
  6686	[    0.049268] thermal_sys: Registered thermal governor 'step_wise'
  6687	[    0.049272] thermal_sys: Registered thermal governor 'user_space'
  6688	[    0.049724] cpuidle: using governor menu
  6689	[    0.050075] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  6690	[    0.050198] ASID allocator initialised with 65536 entries
  6691	[    0.051116] Serial: AMBA PL011 UART driver
  6692	[    0.086242] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
  6693	[    0.086251] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
  6694	[    0.086256] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
  6695	[    0.086260] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
  6696	[    0.087680] cryptd: max_cpu_qlen set to 1000
  6697	[    0.156193] raid6: neonx8   gen()  2785 MB/s
  6698	[    0.224254] raid6: neonx8   xor()  2041 MB/s
  6699	[    0.292347] raid6: neonx4   gen()  3000 MB/s
  6700	[    0.360390] raid6: neonx4   xor()  2399 MB/s
  6701	[    0.428459] raid6: neonx2   gen()  2564 MB/s
  6702	[    0.496536] raid6: neonx2   xor()  2206 MB/s
  6703	[    0.564595] raid6: neonx1   gen()  2014 MB/s
  6704	[    0.632660] raid6: neonx1   xor()  1719 MB/s
  6705	[    0.700730] raid6: int64x8  gen()  1376 MB/s
  6706	[    0.768787] raid6: int64x8  xor()   735 MB/s
  6707	[    0.836869] raid6: int64x4  gen()  1463 MB/s
  6708	[    0.904930] raid6: int64x4  xor()   733 MB/s
  6709	[    0.972998] raid6: int64x2  gen()  1363 MB/s
  6710	[    1.041066] raid6: int64x2  xor()   619 MB/s
  6711	[    1.109128] raid6: int64x1  gen()  1120 MB/s
  6712	[    1.177185] raid6: int64x1  xor()   462 MB/s
  6713	[    1.177189] raid6: using algorithm neonx4 gen() 3000 MB/s
  6714	[    1.177192] raid6: .... xor() 2399 MB/s, rmw enabled
  6715	[    1.177196] raid6: using neon recovery algorithm
  6716	[    1.177648] ACPI: Interpreter disabled.
  6717	[    1.178417] 5V: supplied by 12V
  6718	[    1.179315] VDDAO_3V3: supplied by 12V
  6719	[    1.179772] iommu: Default domain type: Translated
  6720	[    1.179899] vgaarb: loaded
  6721	[    1.180584] SCSI subsystem initialized
  6722	[    1.180998] usbcore: registered new interface driver usbfs
  6723	[    1.181045] usbcore: registered new interface driver hub
  6724	[    1.181082] usbcore: registered new device driver usb
  6725	[    1.181391] pps_core: LinuxPPS API ver. 1 registered
  6726	[    1.181398] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  6727	[    1.181426] PTP clock support registered
  6728	[    1.181605] EDAC MC: Ver: 3.0.0
  6729	[    1.182914] NetLabel: Initializing
  6730	[    1.182922] NetLabel:  domain hash size = 128
  6731	[    1.182925] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
  6732	[    1.182968] NetLabel:  unlabeled traffic allowed by default
  6733	[    1.183457] clocksource: Switched to clocksource arch_sys_counter
  6734	[    1.183674] VFS: Disk quotas dquot_6.6.0
  6735	[    1.183718] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  6736	[    1.184067] AppArmor: AppArmor Filesystem Enabled
  6737	[    1.184168] pnp: PnP ACPI: disabled
  6738	[    1.189759] NET: Registered protocol family 2
  6739	[    1.190213] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
  6740	[    1.190319] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
  6741	[    1.190576] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
  6742	[    1.190763] TCP: Hash tables configured (established 32768 bind 32768)
  6743	[    1.190914] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
  6744	[    1.190979] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
  6745	[    1.191026] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
  6746	[    1.191168] NET: Registered protocol family 1
  6747	[    1.191187] PCI: CLS 0 bytes, default 64
  6748	[    1.191315] Trying to unpack rootfs image as initramfs...
  6749	[    1.727262] Freeing initrd memory: 13544K
  6750	[    1.728192] kvm [1]: IPA Size Limit: 40 bits
  6751	[    1.728898] kvm [1]: vgic interrupt IRQ9
  6752	[    1.729029] kvm [1]: Hyp mode initialized successfully
  6753	[    1.734193] Initialise system trusted keyrings
  6754	[    1.734227] Key type blacklist registered
  6755	[    1.734363] workingset: timestamp_bits=44 max_order=20 bucket_order=0
  6756	[    1.737570] zbud: loaded
  6757	[    1.738543] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  6758	[    1.739005] fuse: init (API version 7.32)
  6759	[    1.739809] integrity: Platform Keyring initialized
  6760	[    1.767793] xor: measuring software checksum speed
  6761	[    1.770632]    8regs           :  3473 MB/sec
  6762	[    1.773091]    32regs          :  4021 MB/sec
  6763	[    1.775744]    arm64_neon      :  3719 MB/sec
  6764	[    1.775748] xor: using function: 32regs (4021 MB/sec)
  6765	[    1.775754] Key type asymmetric registered
  6766	[    1.775759] Asymmetric key parser 'x509' registered
  6767	[    1.775795] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
  6768	[    1.775904] io scheduler mq-deadline registered
  6769	[    1.775908] io scheduler kyber registered
  6770	[    1.775986] io scheduler bfq registered
  6771	[    1.778437] gpio-447 (usb-hub-reset): hogged as output/high
  6772	[    1.781309] EINJ: ACPI disabled.
  6773	[    1.787425] soc soc0: Amlogic Meson G12B (S922X) Revision 29:a (40:2) Detected
  6774	[    1.788914] VCC_3V3: supplied by VDDAO_3V3
  6775	[    1.788950] FLASH_1V8: supplied by VCC_3V3
  6776	[    1.788981] VCC_1V8: supplied by VCC_3V3
  6777	[    1.789012] VDDAO_1V8: supplied by VDDAO_3V3
  6778	[    1.789040] VDDCPU_A: supplied by regulator-dummy
  6779	[    1.789393] VDDCPU_B: supplied by regulator-dummy
  6780	[    1.790053] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
  6781	[    1.792340] Serial: AMBA driver
  6782	[    1.792639] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart
  6783	[    1.792733] printk: console [ttyAML0] enabled
  6784	[    1.793273] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 33, base_baud = 1500000) is a meson_uart
  6785	[    1.798544] loop: module loaded
  6786	[    1.800423] libphy: Fixed MDIO Bus: probed
  6787	[    1.801549] tun: Universal TUN/TAP device driver, 1.6
  6788	[    1.802163] thunder_xcv, ver 1.0
  6789	[    1.802196] thunder_bgx, ver 1.0
  6790	[    1.802225] nicpf, ver 1.0
  6791	[    1.802652] e1000e: Intel(R) PRO/1000 Network Driver
  6792	[    1.802655] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
  6793	[    1.802697] igb: Intel(R) Gigabit Ethernet Network Driver
  6794	[    1.802701] igb: Copyright (c) 2007-2014 Intel Corporation.
  6795	[    1.802734] igbvf: Intel(R) Gigabit Virtual Function Network Driver
  6796	[    1.802736] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
  6797	[    1.802860] sky2: driver version 1.30
  6798	[    1.803215] VFIO - User Level meta-driver version: 0.3
  6799	[    1.804586] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  6800	[    1.804606] ehci-pci: EHCI PCI platform driver
  6801	[    1.804635] ehci-platform: EHCI generic platform driver
  6802	[    1.804758] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  6803	[    1.804767] ohci-pci: OHCI PCI platform driver
  6804	[    1.804797] ohci-platform: OHCI generic platform driver
  6805	[    1.805176] usbcore: registered new interface driver usb-storage
  6806	[    1.806358] mousedev: PS/2 mouse device common for all mice
  6807	[    1.806676] i2c /dev entries driver
  6808	[    1.811710] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17
  6809	[    1.812386] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz
  6810	[    1.813064] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-1 failed:-17
  6811	[    1.813662] sdhci: Secure Digital Host Controller Interface driver
  6812	[    1.813666] sdhci: Copyright(c) Pierre Ossman
  6813	[    1.813772] Synopsys Designware Multimedia Card Interface Driver
  6814	[    1.814194] sdhci-pltfm: SDHCI platform and OF driver helper
  6815	[    1.814600] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq
  6816	[    1.815022] ledtrig-cpu: registered to indicate activity on CPUs
  6817	[    1.815247] meson-sm: secure-monitor enabled
  6818	[    1.815408] hid: raw HID events driver (C) Jiri Kosina
  6819	[    1.815509] usbcore: registered new interface driver usbhid
  6820	[    1.815512] usbhid: USB HID core driver
  6821	[    1.816477] NET: Registered protocol family 10
  6822	[    1.816880] Segment Routing with IPv6
  6823	[    1.816910] NET: Registered protocol family 17
  6824	[    1.816953] 8021q: 802.1Q VLAN Support v1.8
  6825	[    1.816976] Key type dns_resolver registered
  6826	[    1.817251] registered taskstats version 1
  6827	[    1.817257] Loading compiled-in X.509 certificates
  6828	[    1.818943] Loaded X.509 cert 'Build time autogenerated kernel key: f47c178852ca39740c3546b008122b65f5ed9bce'
  6829	[    1.821249] zswap: loaded using pool zstd/z3fold
  6830	[    1.821445] Key type ._fscrypt registered
  6831	[    1.821448] Key type .fscrypt registered
  6832	[    1.821449] Key type fscrypt-provisioning registered
  6833	[    1.822547] Btrfs loaded, crc32c=crc32c-generic
  6834	[    1.828699] Key type encrypted registered
  6835	[    1.828710] AppArmor: AppArmor sha1 policy hashing enabled
  6836	[    1.834923] HUB_5V: supplied by 5V
  6837	[    1.835147] USB_PWR_EN: supplied by 5V
  6838	[    1.836836] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2
  6839	[    1.836843] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1
  6840	[    1.839541] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator
  6841	[    1.839592] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator
  6842	[    1.839713] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM
  6843	[    1.840436] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  6844	[    1.840449] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
  6845	[    1.840540] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010
  6846	[    1.840561] xhci-hcd xhci-hcd.0.auto: irq 41, io mem 0xff500000
  6847	[    1.840687] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
  6848	[    1.840690] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  6849	[    1.840693] usb usb1: Product: xHCI Host Controller
  6850	[    1.840695] usb usb1: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
  6851	[    1.840697] usb usb1: SerialNumber: xhci-hcd.0.auto
  6852	[    1.840942] hub 1-0:1.0: USB hub found
  6853	[    1.840955] hub 1-0:1.0: 2 ports detected
  6854	[    1.841133] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  6855	[    1.841140] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  6856	[    1.841146] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  6857	[    1.841166] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
  6858	[    1.841198] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
  6859	[    1.841201] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  6860	[    1.841203] usb usb2: Product: xHCI Host Controller
  6861	[    1.841205] usb usb2: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
  6862	[    1.841208] usb usb2: SerialNumber: xhci-hcd.0.auto
  6863	[    1.841409] hub 2-0:1.0: USB hub found
  6864	[    1.841420] hub 2-0:1.0: 1 port detected
  6865	[    1.841743] dwc3-meson-g12a ffe09000.usb: switching to Device Mode
  6866	[    1.842694] meson-gx-mmc ffe05000.sd: Got CD GPIO
  6867	[    1.868494] Freeing unused kernel memory: 3328K
  6868	[    1.907560] Run /init as init process
  6869	[    1.907565]   with arguments:
  6870	[    1.907567]     /init
  6871	[    1.907569]   with environment:
  6872	[    1.907570]     HOME=/
  6873	[    1.907572]     TERM=linux
  6874	[    1.907574]     hdmimode=custombuilt
  6875	[    1.907576]     cvbsmode=576cvbs
  6876	[    1.907577]     max_freq_a53=1896
  6877	[    1.907578]     max_freq_a73=1800
  6878	[    1.907580]     voutmode=hdmi
  6879	[    1.907582]     modeline=1920,1080,148500,56250,50,1920,2448,2492,2640,1080,1084,1089,1125,1,1,1
  6880	[    1.907583]     disablehpd=false
  6881	[    1.907585]     cvbscable=
  6882	[    1.907586]     overscan=100
  6883	[    1.933631] mmc0: new ultra high speed SDR25 SDHC card at address b368
  6884	[    1.934233] mmcblk0: mmc0:b368 CBADS 30.0 GiB
  6885	[    1.936043]  mmcblk0: p1
  6886	[    2.060094] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found
  6887	[    2.060101] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found
  6888	[    2.060196] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock
  6889	[    2.063597] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37
  6890	[    2.063620] meson8b-dwmac ff3f0000.ethernet: 	DWMAC1000
  6891	[    2.063626] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported
  6892	[    2.063630] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported
  6893	[    2.063633] meson8b-dwmac ff3f0000.ethernet: COE Type 2
  6894	[    2.063636] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported
  6895	[    2.063639] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported
  6896	[    2.063777] meson8b-dwmac ff3f0000.ethernet: Normal descriptors
  6897	[    2.063781] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled
  6898	[    2.063785] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
  6899	[    2.064313] libphy: stmmac: probed
  6900	[    2.066880] libphy: mdio_mux: probed
  6901	[    2.082687] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
  6902	[    2.082973] rtc-pcf8563 1-0051: registered as rtc0
  6903	[    2.084245] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
  6904	[    2.084259] rtc-pcf8563 1-0051: hctosys: unable to read the hardware clock
  6905	[    2.087239] random: fast init done
  6906	[    2.094208] meson-vrtc ff8000a8.rtc: registered as rtc1
  6907	[    2.179602] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
  6908	[    2.204213] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.04
  6909	[    2.204223] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  6910	[    2.204226] usb 2-1: Product: USB3.1 Hub
  6911	[    2.204230] usb 2-1: Manufacturer: GenesysLogic
  6912	[    2.225416] hub 2-1:1.0: USB hub found
  6913	[    2.225708] hub 2-1:1.0: 4 ports detected
  6914	[    2.272060] libphy: mdio_mux: probed
  6915	[    2.327478] usb 1-1: new high-speed USB device number 2 using xhci-hcd
  6916	[    2.477754] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.04
  6917	[    2.477763] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  6918	[    2.477766] usb 1-1: Product: USB2.1 Hub
  6919	[    2.477769] usb 1-1: Manufacturer: GenesysLogic
  6920	[    2.513449] hub 1-1:1.0: USB hub found
  6921	[    2.513704] hub 1-1:1.0: 4 ports detected
  6922	[    2.997323] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
  6923	[    3.799827] systemd[1]: System time before build time, advancing clock.
  6924	[    3.814657] systemd[1]: Inserted module 'autofs4'
  6925	[    3.861020] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  6926	[    3.861236] systemd[1]: Detected architecture arm64.
  6927	[    3.897326] systemd[1]: Set hostname to <odroidn2>.
  6928	[    4.224425] random: systemd: uninitialized urandom read (16 bytes read)
  6929	[    4.227769] random: systemd: uninitialized urandom read (16 bytes read)
  6930	[    4.228031] systemd[1]: Listening on fsck to fsckd communication Socket.
  6931	[    4.228242] random: systemd: uninitialized urandom read (16 bytes read)
  6932	[    4.228425] systemd[1]: Listening on Journal Socket.
  6933	[    4.230589] systemd[1]: Starting Nameserver information manager...
  6934	[    4.232426] systemd[1]: Mounting POSIX Message Queue File System...
  6935	[    4.239565] systemd[1]: Starting Load Kernel Modules...
  6936	[    4.240104] systemd[1]: Listening on udev Control Socket.
  6937	[    4.240311] systemd[1]: Reached target Remote File Systems.
  6938	[    4.283670] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
  6939	[    4.835792] zram: Added device: zram0
  6940	[    4.836396] zram: Added device: zram1
  6941	[    4.837117] zram: Added device: zram2
  6942	[    4.869546] pwm-gpio pwmgpio: 1 gpio pwms loaded
  6943	[    5.006984] meson-saradc ff809000.adc: supply vref not found, using dummy regulator
  6944	[    5.010241] mc: Linux media interface: v0.10
  6945	[    5.104364] videodev: Linux video capture interface: v2.00
  6946	[    5.139502] Registered IR keymap rc-odroid
  6947	[    5.141106] meson-drm ff900000.vpu: Queued 2 outputs on vpu
  6948	[    5.157734] IR NEC protocol handler initialized
  6949	[    5.183532] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0
  6950	[    5.183664] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
  6951	[    5.183731] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input0
  6952	[    5.183997] meson-ir ff808000.ir: receiver initialized
  6953	[    5.187022] meson-drm ff900000.vpu: CVBS Output connector not available
  6954	[    5.190129] panfrost ffe40000.gpu: clock rate = 24000000
  6955	[    5.190184] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19
  6956	[    5.190845] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0
  6957	[    5.190853] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400
  6958	[    5.190857] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
  6959	[    5.190859] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1
  6960	[    5.204035] zram0: detected capacity change from 0 to 1904500736
  6961	[    5.205421] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 1
  6962	[    5.215608] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
  6963	[    5.216742] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
  6964	[    5.217267] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
  6965	[    5.217695] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 0
  6966	[    5.274077] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  6967	[    5.511639] Console: switching to colour frame buffer device 240x67
  6968	[    5.546366] meson-drm ff900000.vpu: [drm] fb0: mesondrmfb frame buffer device
  6969	[    5.583607] axg-sound-card sound: ASoC: no DMI vendor name!
  6970	[    6.259478] Adding 1859860k swap on /dev/zram0.  Priority:5 extents:1 across:1859860k SSFS
  6971	[    6.322574] zram1: detected capacity change from 0 to 52428800
  6972	[    8.408378] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
  6973	[    8.408398] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
  6974	[    9.425903] systemd[1]: Started Armbian memory supported logging.
  6975	[    9.430088] systemd[1]: Starting Journal Service...
  6976	[    9.484948] systemd[1]: Started Journal Service.
  6977	[    9.512729] systemd-journald[1843]: Received request to flush runtime journal from PID 1
  6978
  6979	### armbian-release:
  6980
  6981	# PLEASE DO NOT EDIT THIS FILE
  6982	BOARD=odroidn2
  6983	BOARD_NAME="Odroid N2"
  6984	BOARDFAMILY=meson-g12b
  6985	BUILD_REPOSITORY_URL=https://github.com/armbian/build
  6986	BUILD_REPOSITORY_COMMIT=5f03d652
  6987	DISTRIBUTION_CODENAME=buster
  6988	DISTRIBUTION_STATUS=supported
  6989	VERSION=21.02.1
  6990	LINUXFAMILY=meson64
  6991	BRANCH=current
  6992	ARCH=arm64
  6993	IMAGE_TYPE=stable
  6994	BOARD_TYPE=conf
  6995	INITRD_ARCH=arm64
  6996	KERNEL_IMAGE_TYPE=Image
  6997
  6998	### boot environment:
  6999
  7000	verbosity=1
  7001	console=both
  7002	overlay_prefix=meson
  7003	rootdev=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c
  7004	rootfstype=ext4
  7005	usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
  7006
  7007	### lsusb:
  7008
  7009	Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc.
  7010	Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  7011	Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
  7012	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  7013
  7014	### lscpu:
  7015
  7016	Architecture:        aarch64
  7017	Byte Order:          Little Endian
  7018	CPU(s):              6
  7019	On-line CPU(s) list: 0-5
  7020	Thread(s) per core:  1
  7021	Core(s) per socket:  3
  7022	Socket(s):           2
  7023	NUMA node(s):        1
  7024	Vendor ID:           ARM
  7025	Model:               4
  7026	Model name:          Cortex-A53
  7027	Stepping:            r0p4
  7028	CPU max MHz:         1992.0000
  7029	CPU min MHz:         100.0000
  7030	BogoMIPS:            48.00
  7031	L1d cache:           unknown size
  7032	L1i cache:           unknown size
  7033	L2 cache:            unknown size
  7034	NUMA node0 CPU(s):   0-5
  7035	Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  7036
  7037	### cpuinfo:
  7038
  7039	processor	: 0
  7040	BogoMIPS	: 48.00
  7041	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  7042	CPU implementer	: 0x41
  7043	CPU architecture: 8
  7044	CPU variant	: 0x0
  7045	CPU part	: 0xd03
  7046	CPU revision	: 4
  7047
  7048	processor	: 1
  7049	BogoMIPS	: 48.00
  7050	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  7051	CPU implementer	: 0x41
  7052	CPU architecture: 8
  7053	CPU variant	: 0x0
  7054	CPU part	: 0xd03
  7055	CPU revision	: 4
  7056
  7057	processor	: 2
  7058	BogoMIPS	: 48.00
  7059	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  7060	CPU implementer	: 0x41
  7061	CPU architecture: 8
  7062	CPU variant	: 0x0
  7063	CPU part	: 0xd09
  7064	CPU revision	: 2
  7065
  7066	processor	: 3
  7067	BogoMIPS	: 48.00
  7068	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  7069	CPU implementer	: 0x41
  7070	CPU architecture: 8
  7071	CPU variant	: 0x0
  7072	CPU part	: 0xd09
  7073	CPU revision	: 2
  7074
  7075	processor	: 4
  7076	BogoMIPS	: 48.00
  7077	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  7078	CPU implementer	: 0x41
  7079	CPU architecture: 8
  7080	CPU variant	: 0x0
  7081	CPU part	: 0xd09
  7082	CPU revision	: 2
  7083
  7084	processor	: 5
  7085	BogoMIPS	: 48.00
  7086	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  7087	CPU implementer	: 0x41
  7088	CPU architecture: 8
  7089	CPU variant	: 0x0
  7090	CPU part	: 0xd09
  7091	CPU revision	: 2
  7092
  7093
  7094	### meminfo:
  7095
  7096	MemTotal:        3719728 kB
  7097	MemFree:         3384152 kB
  7098	MemAvailable:    3336876 kB
  7099	Buffers:           11544 kB
  7100	Cached:            42336 kB
  7101	SwapCached:            0 kB
  7102	Active:            29568 kB
  7103	Inactive:         197080 kB
  7104	Active(anon):         96 kB
  7105	Inactive(anon):   177404 kB
  7106	Active(file):      29472 kB
  7107	Inactive(file):    19676 kB
  7108	Unevictable:           0 kB
  7109	Mlocked:               0 kB
  7110	SwapTotal:       1859860 kB
  7111	SwapFree:        1859860 kB
  7112	Dirty:              3316 kB
  7113	Writeback:             0 kB
  7114	AnonPages:        172388 kB
  7115	Mapped:            10748 kB
  7116	Shmem:              4868 kB
  7117	KReclaimable:      13016 kB
  7118	Slab:              39268 kB
  7119	SReclaimable:      13016 kB
  7120	SUnreclaim:        26252 kB
  7121	KernelStack:        2128 kB
  7122	PageTables:         4028 kB
  7123	NFS_Unstable:          0 kB
  7124	Bounce:                0 kB
  7125	WritebackTmp:          0 kB
  7126	CommitLimit:     3719724 kB
  7127	Committed_AS:    4210484 kB
  7128	VmallocTotal:   135290159040 kB
  7129	VmallocUsed:       30912 kB
  7130	VmallocChunk:          0 kB
  7131	Percpu:             1368 kB
  7132	HardwareCorrupted:     0 kB
  7133	AnonHugePages:         0 kB
  7134	ShmemHugePages:        0 kB
  7135	ShmemPmdMapped:        0 kB
  7136	FileHugePages:         0 kB
  7137	FilePmdMapped:         0 kB
  7138	CmaTotal:         917504 kB
  7139	CmaFree:          901724 kB
  7140	HugePages_Total:       0
  7141	HugePages_Free:        0
  7142	HugePages_Rsvd:        0
  7143	HugePages_Surp:        0
  7144	Hugepagesize:       2048 kB
  7145	Hugetlb:               0 kB
  7146
  7147	### virtual memory:
  7148
  7149	vm.admin_reserve_kbytes = 8192
  7150	vm.block_dump = 0
  7151	vm.compaction_proactiveness = 20
  7152	vm.compact_unevictable_allowed = 1
  7153	vm.dirty_background_bytes = 0
  7154	vm.dirty_background_ratio = 10
  7155	vm.dirty_bytes = 0
  7156	vm.dirty_expire_centisecs = 3000
  7157	vm.dirty_ratio = 20
  7158	vm.dirtytime_expire_seconds = 43200
  7159	vm.dirty_writeback_centisecs = 500
  7160	vm.extfrag_threshold = 500
  7161	vm.hugetlb_shm_group = 0
  7162	vm.laptop_mode = 0
  7163	vm.legacy_va_layout = 0
  7164	vm.lowmem_reserve_ratio = 256	256	32	0
  7165	vm.max_map_count = 65530
  7166	vm.memory_failure_early_kill = 0
  7167	vm.memory_failure_recovery = 1
  7168	vm.min_free_kbytes = 45056
  7169	vm.min_slab_ratio = 5
  7170	vm.min_unmapped_ratio = 1
  7171	vm.mmap_min_addr = 4096
  7172	vm.mmap_rnd_bits = 18
  7173	vm.mmap_rnd_compat_bits = 11
  7174	vm.nr_hugepages = 0
  7175	vm.nr_hugepages_mempolicy = 0
  7176	vm.nr_overcommit_hugepages = 0
  7177	vm.numa_stat = 1
  7178	vm.numa_zonelist_order = Node
  7179	vm.oom_dump_tasks = 1
  7180	vm.oom_kill_allocating_task = 0
  7181	vm.overcommit_kbytes = 0
  7182	vm.overcommit_memory = 0
  7183	vm.overcommit_ratio = 50
  7184	vm.page-cluster = 0
  7185	vm.page_lock_unfairness = 5
  7186	vm.panic_on_oom = 0
  7187	vm.percpu_pagelist_fraction = 0
  7188	vm.stat_interval = 1
  7189	vm.swappiness = 100
  7190	vm.user_reserve_kbytes = 115076
  7191	vm.vfs_cache_pressure = 100
  7192	vm.watermark_boost_factor = 15000
  7193	vm.watermark_scale_factor = 10
  7194	vm.zone_reclaim_mode = 0
  7195
  7196	### ip addr:
  7197
  7198	1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  7199	    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  7200	    inet XXX.XXX.0.1/8 scope host lo
  7201	       valid_lft forever preferred_lft forever
  7202	    inet6 ::1/128 scope host
  7203	       valid_lft forever preferred_lft forever
  7204	2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  7205	    link/ether 00:1e:06:42:03:f8 brd ff:ff:ff:ff:ff:ff
  7206
  7207	### partitions:
  7208
  7209	major minor  #blocks  name
  7210
  7211	 179        0   31464960 mmcblk0
  7212	 179        1   31146208 mmcblk0p1
  7213	 252        0    1859864 zram0
  7214	 252        1      51200 zram1
  7215
  7216	### df:
  7217
  7218	udev            1.4G     0  1.4G   0% /dev
  7219	tmpfs           364M  4.9M  359M   2% /run
  7220	/dev/mmcblk0p1   30G  1.7G   28G   6% /
  7221	tmpfs           1.8G     0  1.8G   0% /dev/shm
  7222	tmpfs           5.0M  4.0K  5.0M   1% /run/lock
  7223	tmpfs           1.8G     0  1.8G   0% /sys/fs/cgroup
  7224	tmpfs           1.8G     0  1.8G   0% /tmp
  7225	/dev/zram1       49M  3.3M   42M   8% /var/log
  7226
  7227	### lsblk:
  7228
  7229	NAME        FSTYPE  SIZE MOUNTPOINT UUID
  7230	mmcblk0              30G
  7231	└─mmcblk0p1 ext4   29.7G /          bd34953d-41be-49d6-b1c0-c0c28a5e239c
  7232	zram1                50M /var/log
  7233
  7234	### zramctl:
  7235
  7236	NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
  7237	/dev/zram1 zstd           50M  132K  698B   36K       6 /var/log
  7238	/dev/zram0 lzo-rle       1.8G    4K   74B   12K       6 [SWAP]
  7239
  7240	### mtab:
  7241
  7242	/dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  7243	/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  7244	/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
  7245
  7246	### mmc0:b368 info:
  7247
  7248	               fwrev: 0x0
  7249	              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=CBADS MODALIAS=mmc:block
  7250	                 cid: 6f0303434241445310aa002b4d013b00
  7251	                 rca: 0xb368
  7252	                 csd: 400e005a5b590000f00e7f800a404000
  7253	              manfid: 0x00006f
  7254	                 ocr: 0x00200000
  7255	preferred_erase_size: 2097152
  7256	                type: SD
  7257	               hwrev: 0x1
  7258	                date: 11/2019
  7259	                 dsr: 0x404
  7260	          erase_size: 512
  7261	               oemid: 0x0303
  7262	              serial: 0xaa002b4d
  7263	                 ssr: 00000000000000280402800100fd180a001e00000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  7264	                 scr: 02b5800300000000
  7265	                name: CBADS
  7266
  7267	### Boot system health:
  7268
  7269	Time       big.LITTLE   load %cpu %sys %usr %nice %io %irq   CPU  C.St.
  7270	15:40:27: 1908/1992MHz  2.52  23%  11%   5%   0%   6%   0% 34.4°C  0/11
  7271	15:40:27: 1908/1992MHz  2.52  84%  34%  10%   0%  36%   1% 34.6°C  0/11
  7272	15:40:27: 1908/ 250MHz  2.52  68%  16%   0%   0%  49%   0% 32.0°C  0/11
  7273	15:40:28: 1908/1992MHz  2.52  52%   5%   5%   0%  42%   0% 31.0°C  0/11
  7274	15:40:28: 1908/1992MHz  2.52  47%   7%   4%   0%  33%   0% 30.9°C  0/11
  7275
  7276	### Activated 1 lzo-rle zram swap devices with 1816 MB each
  7277
  7278	### Activated Armbian ramlog partition with zstd compression
  7279
  7280	Sun 14 Feb 2021 03:44:06 PM GMT | Odroid N2 | 21.02.1 | arm64 | aarch64 | 5.10.12-meson64
  7281
  7282	### dmesg:
  7283
  7284	[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
  7285	[    0.000000] Linux version 5.10.12-meson64 (root@beast) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #21.02.1 SMP PREEMPT Wed Feb 3 21:06:36 CET 2021
  7286	[    0.000000] Machine model: Hardkernel ODROID-N2
  7287	[    0.000000] efi: UEFI not found.
  7288	[    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
  7289	[    0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB
  7290	[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
  7291	[    0.000000] NUMA: No NUMA configuration found
  7292	[    0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ed7fffff]
  7293	[    0.000000] NUMA: NODE_DATA [mem 0xb502f100-0xb5030fff]
  7294	[    0.000000] Zone ranges:
  7295	[    0.000000]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
  7296	[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000ed7fffff]
  7297	[    0.000000]   Normal   empty
  7298	[    0.000000] Movable zone start for each node
  7299	[    0.000000] Early memory node ranges
  7300	[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000004ffffff]
  7301	[    0.000000]   node   0: [mem 0x0000000005300000-0x00000000ed7fffff]
  7302	[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ed7fffff]
  7303	[    0.000000] On node 0 totalpages: 972032
  7304	[    0.000000]   DMA zone: 4096 pages used for memmap
  7305	[    0.000000]   DMA zone: 0 pages reserved
  7306	[    0.000000]   DMA zone: 261376 pages, LIFO batch:63
  7307	[    0.000000]   DMA32 zone: 11104 pages used for memmap
  7308	[    0.000000]   DMA32 zone: 710656 pages, LIFO batch:63
  7309	[    0.000000] psci: probing for conduit method from DT.
  7310	[    0.000000] psci: PSCIv1.0 detected in firmware.
  7311	[    0.000000] psci: Using standard PSCI v0.2 function IDs
  7312	[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
  7313	[    0.000000] psci: SMC Calling Convention v1.1
  7314	[    0.000000] percpu: Embedded 23 pages/cpu s56728 r8192 d29288 u94208
  7315	[    0.000000] pcpu-alloc: s56728 r8192 d29288 u94208 alloc=23*4096
  7316	[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
  7317	[    0.000000] Detected VIPT I-cache on CPU0
  7318	[    0.000000] CPU features: detected: ARM erratum 845719
  7319	[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 956832
  7320	[    0.000000] Policy zone: DMA32
  7321	[    0.000000] Kernel command line: root=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c rootwait rootfstype=ext4 console=ttyAML0,115200n8 console=tty1 loglevel=1  no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=custombuilt cvbsmode=576cvbs max_freq_a53=1896 max_freq_a73=1800 maxcpus=6 voutmode=hdmi modeline=1920,1080,148500,56250,50,1920,2448,2492,2640,1080,1084,1089,1125,1,1,1 disablehpd=false  cvbscable= overscan=100 consoleblank=0
  7322	[    0.000000] Kernel parameter elevator= does not have any effect anymore.
  7323	               Please use sysfs to set IO scheduler for individual devices.
  7324	[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
  7325	[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
  7326	[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
  7327	[    0.000000] software IO TLB: mapped [mem 0x0000000038ac5000-0x000000003cac5000] (64MB)
  7328	[    0.000000] Memory: 2785352K/3888128K available (14144K kernel code, 1760K rwdata, 5508K rodata, 3328K init, 592K bss, 185272K reserved, 917504K cma-reserved)
  7329	[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
  7330	[    0.000000] rcu: Preemptible hierarchical RCU implementation.
  7331	[    0.000000] rcu: 	RCU event tracing is enabled.
  7332	[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
  7333	[    0.000000] 	Trampoline variant of Tasks RCU enabled.
  7334	[    0.000000] 	Rude variant of Tasks RCU enabled.
  7335	[    0.000000] 	Tracing variant of Tasks RCU enabled.
  7336	[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  7337	[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
  7338	[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
  7339	[    0.000000] GIC: Using split EOI/Deactivate mode
  7340	[    0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized
  7341	[    0.000000] random: get_random_bytes called from start_kernel+0x378/0x538 with crng_init=0
  7342	[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
  7343	[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  7344	[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  7345	[    0.000241] Console: colour dummy device 80x25
  7346	[    0.000274] printk: console [tty1] enabled
  7347	[    0.000362] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
  7348	[    0.000374] pid_max: default: 32768 minimum: 301
  7349	[    0.000458] LSM: Security Framework initializing
  7350	[    0.000484] Yama: becoming mindful.
  7351	[    0.000577] AppArmor: AppArmor initialized
  7352	[    0.000625] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
  7353	[    0.000644] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
  7354	[    0.002629] rcu: Hierarchical SRCU implementation.
  7355	[    0.004985] EFI services will not be available.
  7356	[    0.005404] smp: Bringing up secondary CPUs ...
  7357	[    0.006077] Detected VIPT I-cache on CPU1
  7358	[    0.006140] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
  7359	[    0.007338] CPU features: detected: ARM erratum 858921
  7360	[    0.007346] CPU features: detected: Spectre-v2
  7361	[    0.007350] CPU features: detected: Spectre-v4
  7362	[    0.007356] Detected VIPT I-cache on CPU2
  7363	[    0.007382] arch_timer: Enabling local workaround for ARM erratum 858921
  7364	[    0.007396] arch_timer: CPU2: Trapping CNTVCT access
  7365	[    0.007410] CPU2: Booted secondary processor 0x0000000100 [0x410fd092]
  7366	[    0.008115] Detected VIPT I-cache on CPU3
  7367	[    0.008131] arch_timer: Enabling local workaround for ARM erratum 858921
  7368	[    0.008138] arch_timer: CPU3: Trapping CNTVCT access
  7369	[    0.008146] CPU3: Booted secondary processor 0x0000000101 [0x410fd092]
  7370	[    0.008777] Detected VIPT I-cache on CPU4
  7371	[    0.008793] arch_timer: Enabling local workaround for ARM erratum 858921
  7372	[    0.008800] arch_timer: CPU4: Trapping CNTVCT access
  7373	[    0.008808] CPU4: Booted secondary processor 0x0000000102 [0x410fd092]
  7374	[    0.009424] Detected VIPT I-cache on CPU5
  7375	[    0.009440] arch_timer: Enabling local workaround for ARM erratum 858921
  7376	[    0.009447] arch_timer: CPU5: Trapping CNTVCT access
  7377	[    0.009454] CPU5: Booted secondary processor 0x0000000103 [0x410fd092]
  7378	[    0.009535] smp: Brought up 1 node, 6 CPUs
  7379	[    0.009552] SMP: Total of 6 processors activated.
  7380	[    0.009561] CPU features: detected: 32-bit EL0 Support
  7381	[    0.009567] CPU features: detected: CRC32 instructions
  7382	[    0.009572] CPU features: detected: 32-bit EL1 Support
  7383	[    0.020823] CPU: All CPU(s) started at EL2
  7384	[    0.020874] alternatives: patching kernel code
  7385	[    0.022814] devtmpfs: initialized
  7386	[    0.030481] Registered cp15_barrier emulation handler
  7387	[    0.030495] Registered setend emulation handler
  7388	[    0.030634] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  7389	[    0.030674] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
  7390	[    0.044535] pinctrl core: initialized pinctrl subsystem
  7391	[    0.045251] DMI not present or invalid.
  7392	[    0.045620] NET: Registered protocol family 16
  7393	[    0.047149] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
  7394	[    0.047422] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
  7395	[    0.047664] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
  7396	[    0.047703] audit: initializing netlink subsys (disabled)
  7397	[    0.047805] audit: type=2000 audit(0.044:1): state=initialized audit_enabled=0 res=1
  7398	[    0.048990] thermal_sys: Registered thermal governor 'fair_share'
  7399	[    0.048997] thermal_sys: Registered thermal governor 'bang_bang'
  7400	[    0.049001] thermal_sys: Registered thermal governor 'step_wise'
  7401	[    0.049005] thermal_sys: Registered thermal governor 'user_space'
  7402	[    0.049420] cpuidle: using governor menu
  7403	[    0.049774] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  7404	[    0.049896] ASID allocator initialised with 65536 entries
  7405	[    0.050804] Serial: AMBA PL011 UART driver
  7406	[    0.085662] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
  7407	[    0.085672] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
  7408	[    0.085677] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
  7409	[    0.085681] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
  7410	[    0.087361] cryptd: max_cpu_qlen set to 1000
  7411	[    0.156119] raid6: neonx8   gen()  2786 MB/s
  7412	[    0.224183] raid6: neonx8   xor()  2042 MB/s
  7413	[    0.292285] raid6: neonx4   gen()  2992 MB/s
  7414	[    0.360495] raid6: neonx4   xor()  1586 MB/s
  7415	[    0.428462] raid6: neonx2   gen()  2080 MB/s
  7416	[    0.496509] raid6: neonx2   xor()  2206 MB/s
  7417	[    0.564574] raid6: neonx1   gen()  2010 MB/s
  7418	[    0.632639] raid6: neonx1   xor()  1718 MB/s
  7419	[    0.700713] raid6: int64x8  gen()  1377 MB/s
  7420	[    0.768784] raid6: int64x8  xor()   736 MB/s
  7421	[    0.836855] raid6: int64x4  gen()  1463 MB/s
  7422	[    0.904906] raid6: int64x4  xor()   733 MB/s
  7423	[    0.972974] raid6: int64x2  gen()  1362 MB/s
  7424	[    1.041044] raid6: int64x2  xor()   619 MB/s
  7425	[    1.109114] raid6: int64x1  gen()  1120 MB/s
  7426	[    1.177178] raid6: int64x1  xor()   462 MB/s
  7427	[    1.177182] raid6: using algorithm neonx4 gen() 2992 MB/s
  7428	[    1.177185] raid6: .... xor() 1586 MB/s, rmw enabled
  7429	[    1.177188] raid6: using neon recovery algorithm
  7430	[    1.177620] ACPI: Interpreter disabled.
  7431	[    1.178381] 5V: supplied by 12V
  7432	[    1.179285] VDDAO_3V3: supplied by 12V
  7433	[    1.179748] iommu: Default domain type: Translated
  7434	[    1.179879] vgaarb: loaded
  7435	[    1.180641] SCSI subsystem initialized
  7436	[    1.180953] usbcore: registered new interface driver usbfs
  7437	[    1.181004] usbcore: registered new interface driver hub
  7438	[    1.181042] usbcore: registered new device driver usb
  7439	[    1.181303] pps_core: LinuxPPS API ver. 1 registered
  7440	[    1.181308] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  7441	[    1.181333] PTP clock support registered
  7442	[    1.181526] EDAC MC: Ver: 3.0.0
  7443	[    1.182875] NetLabel: Initializing
  7444	[    1.182882] NetLabel:  domain hash size = 128
  7445	[    1.182885] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
  7446	[    1.182928] NetLabel:  unlabeled traffic allowed by default
  7447	[    1.183371] clocksource: Switched to clocksource arch_sys_counter
  7448	[    1.183574] VFS: Disk quotas dquot_6.6.0
  7449	[    1.183617] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  7450	[    1.183975] AppArmor: AppArmor Filesystem Enabled
  7451	[    1.184019] pnp: PnP ACPI: disabled
  7452	[    1.189625] NET: Registered protocol family 2
  7453	[    1.190085] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
  7454	[    1.190190] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
  7455	[    1.190446] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
  7456	[    1.190633] TCP: Hash tables configured (established 32768 bind 32768)
  7457	[    1.190787] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
  7458	[    1.190854] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
  7459	[    1.190901] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
  7460	[    1.191047] NET: Registered protocol family 1
  7461	[    1.191066] PCI: CLS 0 bytes, default 64
  7462	[    1.191190] Trying to unpack rootfs image as initramfs...
  7463	[    1.726875] Freeing initrd memory: 13544K
  7464	[    1.727781] kvm [1]: IPA Size Limit: 40 bits
  7465	[    1.728495] kvm [1]: vgic interrupt IRQ9
  7466	[    1.728629] kvm [1]: Hyp mode initialized successfully
  7467	[    1.732519] Initialise system trusted keyrings
  7468	[    1.732554] Key type blacklist registered
  7469	[    1.732653] workingset: timestamp_bits=44 max_order=20 bucket_order=0
  7470	[    1.735862] zbud: loaded
  7471	[    1.736833] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  7472	[    1.737287] fuse: init (API version 7.32)
  7473	[    1.738066] integrity: Platform Keyring initialized
  7474	[    1.765644] xor: measuring software checksum speed
  7475	[    1.768489]    8regs           :  3473 MB/sec
  7476	[    1.770938]    32regs          :  4022 MB/sec
  7477	[    1.773593]    arm64_neon      :  3719 MB/sec
  7478	[    1.773596] xor: using function: 32regs (4022 MB/sec)
  7479	[    1.773602] Key type asymmetric registered
  7480	[    1.773606] Asymmetric key parser 'x509' registered
  7481	[    1.773639] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
  7482	[    1.773769] io scheduler mq-deadline registered
  7483	[    1.773774] io scheduler kyber registered
  7484	[    1.773852] io scheduler bfq registered
  7485	[    1.776340] gpio-447 (usb-hub-reset): hogged as output/high
  7486	[    1.779139] EINJ: ACPI disabled.
  7487	[    1.785338] soc soc0: Amlogic Meson G12B (S922X) Revision 29:a (40:2) Detected
  7488	[    1.786697] VCC_3V3: supplied by VDDAO_3V3
  7489	[    1.786752] FLASH_1V8: supplied by VCC_3V3
  7490	[    1.786782] VCC_1V8: supplied by VCC_3V3
  7491	[    1.786808] VDDAO_1V8: supplied by VDDAO_3V3
  7492	[    1.786835] VDDCPU_A: supplied by regulator-dummy
  7493	[    1.787201] VDDCPU_B: supplied by regulator-dummy
  7494	[    1.787896] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
  7495	[    1.790096] Serial: AMBA driver
  7496	[    1.790390] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart
  7497	[    1.790484] printk: console [ttyAML0] enabled
  7498	[    1.791009] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 33, base_baud = 1500000) is a meson_uart
  7499	[    1.796638] loop: module loaded
  7500	[    1.798469] libphy: Fixed MDIO Bus: probed
  7501	[    1.799762] tun: Universal TUN/TAP device driver, 1.6
  7502	[    1.800372] thunder_xcv, ver 1.0
  7503	[    1.800399] thunder_bgx, ver 1.0
  7504	[    1.800425] nicpf, ver 1.0
  7505	[    1.800864] e1000e: Intel(R) PRO/1000 Network Driver
  7506	[    1.800868] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
  7507	[    1.800907] igb: Intel(R) Gigabit Ethernet Network Driver
  7508	[    1.800910] igb: Copyright (c) 2007-2014 Intel Corporation.
  7509	[    1.800944] igbvf: Intel(R) Gigabit Virtual Function Network Driver
  7510	[    1.800947] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
  7511	[    1.801074] sky2: driver version 1.30
  7512	[    1.801430] VFIO - User Level meta-driver version: 0.3
  7513	[    1.802789] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  7514	[    1.802813] ehci-pci: EHCI PCI platform driver
  7515	[    1.802850] ehci-platform: EHCI generic platform driver
  7516	[    1.802972] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  7517	[    1.802982] ohci-pci: OHCI PCI platform driver
  7518	[    1.803013] ohci-platform: OHCI generic platform driver
  7519	[    1.803466] usbcore: registered new interface driver usb-storage
  7520	[    1.804696] mousedev: PS/2 mouse device common for all mice
  7521	[    1.805084] i2c /dev entries driver
  7522	[    1.810088] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17
  7523	[    1.810747] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz
  7524	[    1.811448] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-1 failed:-17
  7525	[    1.812057] sdhci: Secure Digital Host Controller Interface driver
  7526	[    1.812062] sdhci: Copyright(c) Pierre Ossman
  7527	[    1.812159] Synopsys Designware Multimedia Card Interface Driver
  7528	[    1.812572] sdhci-pltfm: SDHCI platform and OF driver helper
  7529	[    1.813011] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq
  7530	[    1.813417] ledtrig-cpu: registered to indicate activity on CPUs
  7531	[    1.813841] meson-sm: secure-monitor enabled
  7532	[    1.814035] hid: raw HID events driver (C) Jiri Kosina
  7533	[    1.814143] usbcore: registered new interface driver usbhid
  7534	[    1.814146] usbhid: USB HID core driver
  7535	[    1.815143] NET: Registered protocol family 10
  7536	[    1.815630] Segment Routing with IPv6
  7537	[    1.815659] NET: Registered protocol family 17
  7538	[    1.815712] 8021q: 802.1Q VLAN Support v1.8
  7539	[    1.815734] Key type dns_resolver registered
  7540	[    1.816033] registered taskstats version 1
  7541	[    1.816038] Loading compiled-in X.509 certificates
  7542	[    1.817785] Loaded X.509 cert 'Build time autogenerated kernel key: f47c178852ca39740c3546b008122b65f5ed9bce'
  7543	[    1.819753] zswap: loaded using pool zstd/z3fold
  7544	[    1.819935] Key type ._fscrypt registered
  7545	[    1.819937] Key type .fscrypt registered
  7546	[    1.819939] Key type fscrypt-provisioning registered
  7547	[    1.821014] Btrfs loaded, crc32c=crc32c-generic
  7548	[    1.827199] Key type encrypted registered
  7549	[    1.827211] AppArmor: AppArmor sha1 policy hashing enabled
  7550	[    1.833678] HUB_5V: supplied by 5V
  7551	[    1.833866] USB_PWR_EN: supplied by 5V
  7552	[    1.835537] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2
  7553	[    1.835545] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1
  7554	[    1.838220] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator
  7555	[    1.838264] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator
  7556	[    1.838369] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM
  7557	[    1.838947] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  7558	[    1.838958] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
  7559	[    1.839043] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010
  7560	[    1.839066] xhci-hcd xhci-hcd.0.auto: irq 41, io mem 0xff500000
  7561	[    1.839189] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
  7562	[    1.839192] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  7563	[    1.839195] usb usb1: Product: xHCI Host Controller
  7564	[    1.839197] usb usb1: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
  7565	[    1.839199] usb usb1: SerialNumber: xhci-hcd.0.auto
  7566	[    1.839541] hub 1-0:1.0: USB hub found
  7567	[    1.839561] hub 1-0:1.0: 2 ports detected
  7568	[    1.839705] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  7569	[    1.839713] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  7570	[    1.839720] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  7571	[    1.839743] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
  7572	[    1.839787] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
  7573	[    1.839790] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  7574	[    1.839793] usb usb2: Product: xHCI Host Controller
  7575	[    1.839796] usb usb2: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
  7576	[    1.839798] usb usb2: SerialNumber: xhci-hcd.0.auto
  7577	[    1.839988] hub 2-0:1.0: USB hub found
  7578	[    1.839999] hub 2-0:1.0: 1 port detected
  7579	[    1.841098] meson-gx-mmc ffe05000.sd: Got CD GPIO
  7580	[    1.868424] Freeing unused kernel memory: 3328K
  7581	[    1.903438] Run /init as init process
  7582	[    1.903442]   with arguments:
  7583	[    1.903444]     /init
  7584	[    1.903446]   with environment:
  7585	[    1.903448]     HOME=/
  7586	[    1.903450]     TERM=linux
  7587	[    1.903451]     hdmimode=custombuilt
  7588	[    1.903453]     cvbsmode=576cvbs
  7589	[    1.903454]     max_freq_a53=1896
  7590	[    1.903456]     max_freq_a73=1800
  7591	[    1.903457]     voutmode=hdmi
  7592	[    1.903459]     modeline=1920,1080,148500,56250,50,1920,2448,2492,2640,1080,1084,1089,1125,1,1,1
  7593	[    1.903460]     disablehpd=false
  7594	[    1.903461]     cvbscable=
  7595	[    1.903463]     overscan=100
  7596	[    1.934835] mmc0: new ultra high speed SDR25 SDHC card at address b368
  7597	[    1.935742] mmcblk0: mmc0:b368 CBADS 30.0 GiB
  7598	[    1.937746]  mmcblk0: p1
  7599	[    2.062994] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found
  7600	[    2.063002] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found
  7601	[    2.063112] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock
  7602	[    2.063580] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37
  7603	[    2.063587] meson8b-dwmac ff3f0000.ethernet: 	DWMAC1000
  7604	[    2.063590] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported
  7605	[    2.063592] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported
  7606	[    2.063595] meson8b-dwmac ff3f0000.ethernet: COE Type 2
  7607	[    2.063597] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported
  7608	[    2.063598] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported
  7609	[    2.063660] meson8b-dwmac ff3f0000.ethernet: Normal descriptors
  7610	[    2.063662] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled
  7611	[    2.063665] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
  7612	[    2.063868] libphy: stmmac: probed
  7613	[    2.067816] libphy: mdio_mux: probed
  7614	[    2.079029] meson-vrtc ff8000a8.rtc: registered as rtc1
  7615	[    2.095750] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
  7616	[    2.096215] rtc-pcf8563 1-0051: registered as rtc0
  7617	[    2.097403] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
  7618	[    2.097411] rtc-pcf8563 1-0051: hctosys: unable to read the hardware clock
  7619	[    2.101899] random: fast init done
  7620	[    2.179382] usb 1-1: new high-speed USB device number 2 using xhci-hcd
  7621	[    2.271831] libphy: mdio_mux: probed
  7622	[    2.329757] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.04
  7623	[    2.329764] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  7624	[    2.329767] usb 1-1: Product: USB2.1 Hub
  7625	[    2.329769] usb 1-1: Manufacturer: GenesysLogic
  7626	[    2.383935] hub 1-1:1.0: USB hub found
  7627	[    2.384156] hub 1-1:1.0: 4 ports detected
  7628	[    2.455477] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
  7629	[    2.477958] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.04
  7630	[    2.477961] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  7631	[    2.477964] usb 2-1: Product: USB3.1 Hub
  7632	[    2.477967] usb 2-1: Manufacturer: GenesysLogic
  7633	[    2.495920] hub 2-1:1.0: USB hub found
  7634	[    2.496203] hub 2-1:1.0: 4 ports detected
  7635	[    2.603371] usb 1-2: new high-speed USB device number 3 using xhci-hcd
  7636	[    2.752394] usb 1-2: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice= 7.02
  7637	[    2.752398] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
  7638	[    2.752400] usb 1-2: Product: USB2.0 Hub
  7639	[    2.799979] hub 1-2:1.0: USB hub found
  7640	[    2.800213] hub 1-2:1.0: 4 ports detected
  7641	[    3.087378] usb 1-2.3: new high-speed USB device number 4 using xhci-hcd
  7642	[    3.108038] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
  7643	[    3.188479] usb 1-2.3: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice= 7.02
  7644	[    3.188486] usb 1-2.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
  7645	[    3.188489] usb 1-2.3: Product: USB2.0 Hub
  7646	[    3.248032] hub 1-2.3:1.0: USB hub found
  7647	[    3.248271] hub 1-2.3:1.0: 4 ports detected
  7648	[    3.327383] usb 1-2.4: new high-speed USB device number 5 using xhci-hcd
  7649	[    3.427840] usb 1-2.4: New USB device found, idVendor=2013, idProduct=025f, bcdDevice= 1.00
  7650	[    3.427847] usb 1-2.4: New USB device strings: Mfr=3, Product=1, SerialNumber=2
  7651	[    3.427850] usb 1-2.4: Product: PCTV 292e
  7652	[    3.427853] usb 1-2.4: Manufacturer: PCTV
  7653	[    3.427855] usb 1-2.4: SerialNumber: 0011356964
  7654	[    3.911533] systemd[1]: System time before build time, advancing clock.
  7655	[    3.926319] systemd[1]: Inserted module 'autofs4'
  7656	[    3.972806] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  7657	[    3.973035] systemd[1]: Detected architecture arm64.
  7658	[    3.997873] systemd[1]: Set hostname to <odroidn2>.
  7659	[    4.324781] random: systemd: uninitialized urandom read (16 bytes read)
  7660	[    4.328074] random: systemd: uninitialized urandom read (16 bytes read)
  7661	[    4.328105] systemd[1]: Reached target Swap.
  7662	[    4.328345] random: systemd: uninitialized urandom read (16 bytes read)
  7663	[    4.329194] systemd[1]: Created slice User and Session Slice.
  7664	[    4.329574] systemd[1]: Listening on Journal Socket.
  7665	[    4.329695] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
  7666	[    4.329836] systemd[1]: Listening on fsck to fsckd communication Socket.
  7667	[    4.330050] systemd[1]: Listening on udev Control Socket.
  7668	[    4.330134] systemd[1]: Reached target System Time Synchronized.
  7669	[    4.418179] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
  7670	[    4.878088] zram: Added device: zram0
  7671	[    4.878295] zram: Added device: zram1
  7672	[    4.878469] zram: Added device: zram2
  7673	[    5.032348] pwm-gpio pwmgpio: 1 gpio pwms loaded
  7674	[    5.070667] zram0: detected capacity change from 0 to 1904500736
  7675	[    5.178878] mc: Linux media interface: v0.10
  7676	[    5.209317] panfrost ffe40000.gpu: clock rate = 24000000
  7677	[    5.209378] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19
  7678	[    5.209969] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0
  7679	[    5.209976] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400
  7680	[    5.209980] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
  7681	[    5.209982] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1
  7682	[    5.225725] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 0
  7683	[    5.238255] videodev: Linux video capture interface: v2.00
  7684	[    5.249186] meson-saradc ff809000.adc: supply vref not found, using dummy regulator
  7685	[    5.253819] meson-drm ff900000.vpu: Queued 2 outputs on vpu
  7686	[    5.303434] Registered IR keymap rc-odroid
  7687	[    5.305177] meson-drm ff900000.vpu: CVBS Output connector not available
  7688	[    5.325014] IR NEC protocol handler initialized
  7689	[    5.331615] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
  7690	[    5.334087] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
  7691	[    5.334645] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
  7692	[    5.335274] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 1
  7693	[    5.359457] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0
  7694	[    5.359550] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
  7695	[    5.359615] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input0
  7696	[    5.361487] meson-ir ff808000.ir: receiver initialized
  7697	[    5.396466] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  7698	[    5.414433] em28xx 1-2.4:1.0: New device PCTV PCTV 292e @ 480 Mbps (2013:025f, interface 0, class 0)
  7699	[    5.414441] em28xx 1-2.4:1.0: DVB interface 0 found: isoc
  7700	[    5.471438] em28xx 1-2.4:1.0: chip ID is em28178
  7701	[    5.623528] Console: switching to colour frame buffer device 240x67
  7702	[    5.650081] meson-drm ff900000.vpu: [drm] fb0: mesondrmfb frame buffer device
  7703	[    5.682389] axg-sound-card sound: ASoC: no DMI vendor name!
  7704	[    6.167383] Adding 1859860k swap on /dev/zram0.  Priority:5 extents:1 across:1859860k SSFS
  7705	[    6.233636] zram1: detected capacity change from 0 to 52428800
  7706	[    7.493570] em28xx 1-2.4:1.0: EEPROM ID = 26 00 01 00, EEPROM hash = 0x8d0cfd04
  7707	[    7.493574] em28xx 1-2.4:1.0: EEPROM info:
  7708	[    7.493577] em28xx 1-2.4:1.0: 	microcode start address = 0x0004, boot configuration = 0x01
  7709	[    7.499690] em28xx 1-2.4:1.0: 	AC97 audio (5 sample rates)
  7710	[    7.499693] em28xx 1-2.4:1.0: 	500mA max power
  7711	[    7.499696] em28xx 1-2.4:1.0: 	Table at offset 0x27, strings=0x146a, 0x1888, 0x0a7e
  7712	[    7.559369] em28xx 1-2.4:1.0: Identified as PCTV tripleStick (292e) (card=94)
  7713	[    7.559373] em28xx 1-2.4:1.0: dvb set to isoc mode.
  7714	[    7.559574] usbcore: registered new interface driver em28xx
  7715	[    7.585707] em28xx 1-2.4:1.0: Binding DVB extension
  7716	[    7.599073] i2c i2c-4: Added multiplexed i2c bus 5
  7717	[    7.599081] si2168 4-0064: Silicon Labs Si2168-B40 successfully identified
  7718	[    7.599084] si2168 4-0064: firmware version: B 4.0.2
  7719	[    7.607574] si2157 5-0060: Silicon Labs Si2147/2148/2157/2158 successfully attached
  7720	[    7.607604] dvbdev: DVB: registering new adapter (1-2.4:1.0)
  7721	[    7.607611] em28xx 1-2.4:1.0: DVB: registering adapter 0 frontend 0 (Silicon Labs Si2168)...
  7722	[    7.607617] dvbdev: dvb_create_media_entity: media entity 'Silicon Labs Si2168' registered.
  7723	[    7.608262] dvbdev: dvb_create_media_entity: media entity 'dvb-demux' registered.
  7724	[    7.631876] em28xx 1-2.4:1.0: DVB extension successfully initialized
  7725	[    7.631884] em28xx: Registered (Em28xx dvb Extension) extension
  7726	[    7.638753] em28xx 1-2.4:1.0: Registering input extension
  7727	[    7.671370] Registered IR keymap rc-pinnacle-pctv-hd
  7728	[    7.671548] rc rc1: PCTV tripleStick (292e) as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-2/1-2.4/1-2.4:1.0/rc/rc1
  7729	[    7.671621] rc rc1: lirc_dev: driver em28xx registered at minor = 1, scancode receiver, no transmitter
  7730	[    7.671682] input: PCTV tripleStick (292e) as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-2/1-2.4/1-2.4:1.0/rc/rc1/input1
  7731	[    7.671749] em28xx 1-2.4:1.0: Input extension successfully initialized
  7732	[    7.671752] em28xx: Registered (Em28xx Input Extension) extension
  7733	[    8.317860] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
  7734	[    8.317881] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
  7735	[    9.331622] systemd[1]: Started Armbian memory supported logging.
  7736	[    9.333967] systemd[1]: Starting Journal Service...
  7737	[    9.401266] systemd[1]: Started Journal Service.
  7738	[    9.426296] systemd-journald[1843]: Received request to flush runtime journal from PID 1
  7739
  7740	### armbian-release:
  7741
  7742	# PLEASE DO NOT EDIT THIS FILE
  7743	BOARD=odroidn2
  7744	BOARD_NAME="Odroid N2"
  7745	BOARDFAMILY=meson-g12b
  7746	BUILD_REPOSITORY_URL=https://github.com/armbian/build
  7747	BUILD_REPOSITORY_COMMIT=5f03d652
  7748	DISTRIBUTION_CODENAME=buster
  7749	DISTRIBUTION_STATUS=supported
  7750	VERSION=21.02.1
  7751	LINUXFAMILY=meson64
  7752	BRANCH=current
  7753	ARCH=arm64
  7754	IMAGE_TYPE=stable
  7755	BOARD_TYPE=conf
  7756	INITRD_ARCH=arm64
  7757	KERNEL_IMAGE_TYPE=Image
  7758
  7759	### boot environment:
  7760
  7761	verbosity=1
  7762	console=both
  7763	overlay_prefix=meson
  7764	rootdev=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c
  7765	rootfstype=ext4
  7766	usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
  7767
  7768	### lsusb:
  7769
  7770	Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc.
  7771	Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  7772	Bus 001 Device 005: ID 2013:025f PCTV Systems
  7773	Bus 001 Device 004: ID 05e3:0608 Genesys Logic, Inc. Hub
  7774	Bus 001 Device 003: ID 05e3:0608 Genesys Logic, Inc. Hub
  7775	Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
  7776	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  7777
  7778	### lscpu:
  7779
  7780	Architecture:        aarch64
  7781	Byte Order:          Little Endian
  7782	CPU(s):              6
  7783	On-line CPU(s) list: 0-5
  7784	Thread(s) per core:  1
  7785	Core(s) per socket:  3
  7786	Socket(s):           2
  7787	NUMA node(s):        1
  7788	Vendor ID:           ARM
  7789	Model:               4
  7790	Model name:          Cortex-A53
  7791	Stepping:            r0p4
  7792	CPU max MHz:         1992.0000
  7793	CPU min MHz:         100.0000
  7794	BogoMIPS:            48.00
  7795	L1d cache:           unknown size
  7796	L1i cache:           unknown size
  7797	L2 cache:            unknown size
  7798	NUMA node0 CPU(s):   0-5
  7799	Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  7800
  7801	### cpuinfo:
  7802
  7803	processor	: 0
  7804	BogoMIPS	: 48.00
  7805	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  7806	CPU implementer	: 0x41
  7807	CPU architecture: 8
  7808	CPU variant	: 0x0
  7809	CPU part	: 0xd03
  7810	CPU revision	: 4
  7811
  7812	processor	: 1
  7813	BogoMIPS	: 48.00
  7814	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  7815	CPU implementer	: 0x41
  7816	CPU architecture: 8
  7817	CPU variant	: 0x0
  7818	CPU part	: 0xd03
  7819	CPU revision	: 4
  7820
  7821	processor	: 2
  7822	BogoMIPS	: 48.00
  7823	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  7824	CPU implementer	: 0x41
  7825	CPU architecture: 8
  7826	CPU variant	: 0x0
  7827	CPU part	: 0xd09
  7828	CPU revision	: 2
  7829
  7830	processor	: 3
  7831	BogoMIPS	: 48.00
  7832	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  7833	CPU implementer	: 0x41
  7834	CPU architecture: 8
  7835	CPU variant	: 0x0
  7836	CPU part	: 0xd09
  7837	CPU revision	: 2
  7838
  7839	processor	: 4
  7840	BogoMIPS	: 48.00
  7841	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  7842	CPU implementer	: 0x41
  7843	CPU architecture: 8
  7844	CPU variant	: 0x0
  7845	CPU part	: 0xd09
  7846	CPU revision	: 2
  7847
  7848	processor	: 5
  7849	BogoMIPS	: 48.00
  7850	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  7851	CPU implementer	: 0x41
  7852	CPU architecture: 8
  7853	CPU variant	: 0x0
  7854	CPU part	: 0xd09
  7855	CPU revision	: 2
  7856
  7857
  7858	### meminfo:
  7859
  7860	MemTotal:        3719728 kB
  7861	MemFree:         3405160 kB
  7862	MemAvailable:    3358320 kB
  7863	Buffers:           11568 kB
  7864	Cached:            43268 kB
  7865	SwapCached:            0 kB
  7866	Active:            28840 kB
  7867	Inactive:         175020 kB
  7868	Active(anon):        108 kB
  7869	Inactive(anon):   153688 kB
  7870	Active(file):      28732 kB
  7871	Inactive(file):    21332 kB
  7872	Unevictable:           0 kB
  7873	Mlocked:               0 kB
  7874	SwapTotal:       1859860 kB
  7875	SwapFree:        1859860 kB
  7876	Dirty:              3560 kB
  7877	Writeback:             0 kB
  7878	AnonPages:        148736 kB
  7879	Mapped:            13328 kB
  7880	Shmem:              4916 kB
  7881	KReclaimable:      12972 kB
  7882	Slab:              40548 kB
  7883	SReclaimable:      12972 kB
  7884	SUnreclaim:        27576 kB
  7885	KernelStack:        2528 kB
  7886	PageTables:         5344 kB
  7887	NFS_Unstable:          0 kB
  7888	Bounce:                0 kB
  7889	WritebackTmp:          0 kB
  7890	CommitLimit:     3719724 kB
  7891	Committed_AS:    4241156 kB
  7892	VmallocTotal:   135290159040 kB
  7893	VmallocUsed:       33152 kB
  7894	VmallocChunk:          0 kB
  7895	Percpu:             1368 kB
  7896	HardwareCorrupted:     0 kB
  7897	AnonHugePages:         0 kB
  7898	ShmemHugePages:        0 kB
  7899	ShmemPmdMapped:        0 kB
  7900	FileHugePages:         0 kB
  7901	FilePmdMapped:         0 kB
  7902	CmaTotal:         917504 kB
  7903	CmaFree:          901724 kB
  7904	HugePages_Total:       0
  7905	HugePages_Free:        0
  7906	HugePages_Rsvd:        0
  7907	HugePages_Surp:        0
  7908	Hugepagesize:       2048 kB
  7909	Hugetlb:               0 kB
  7910
  7911	### virtual memory:
  7912
  7913	vm.admin_reserve_kbytes = 8192
  7914	vm.block_dump = 0
  7915	vm.compaction_proactiveness = 20
  7916	vm.compact_unevictable_allowed = 1
  7917	vm.dirty_background_bytes = 0
  7918	vm.dirty_background_ratio = 10
  7919	vm.dirty_bytes = 0
  7920	vm.dirty_expire_centisecs = 3000
  7921	vm.dirty_ratio = 20
  7922	vm.dirtytime_expire_seconds = 43200
  7923	vm.dirty_writeback_centisecs = 500
  7924	vm.extfrag_threshold = 500
  7925	vm.hugetlb_shm_group = 0
  7926	vm.laptop_mode = 0
  7927	vm.legacy_va_layout = 0
  7928	vm.lowmem_reserve_ratio = 256	256	32	0
  7929	vm.max_map_count = 65530
  7930	vm.memory_failure_early_kill = 0
  7931	vm.memory_failure_recovery = 1
  7932	vm.min_free_kbytes = 45056
  7933	vm.min_slab_ratio = 5
  7934	vm.min_unmapped_ratio = 1
  7935	vm.mmap_min_addr = 4096
  7936	vm.mmap_rnd_bits = 18
  7937	vm.mmap_rnd_compat_bits = 11
  7938	vm.nr_hugepages = 0
  7939	vm.nr_hugepages_mempolicy = 0
  7940	vm.nr_overcommit_hugepages = 0
  7941	vm.numa_stat = 1
  7942	vm.numa_zonelist_order = Node
  7943	vm.oom_dump_tasks = 1
  7944	vm.oom_kill_allocating_task = 0
  7945	vm.overcommit_kbytes = 0
  7946	vm.overcommit_memory = 0
  7947	vm.overcommit_ratio = 50
  7948	vm.page-cluster = 0
  7949	vm.page_lock_unfairness = 5
  7950	vm.panic_on_oom = 0
  7951	vm.percpu_pagelist_fraction = 0
  7952	vm.stat_interval = 1
  7953	vm.swappiness = 100
  7954	vm.user_reserve_kbytes = 115012
  7955	vm.vfs_cache_pressure = 100
  7956	vm.watermark_boost_factor = 15000
  7957	vm.watermark_scale_factor = 10
  7958	vm.zone_reclaim_mode = 0
  7959
  7960	### ip addr:
  7961
  7962	1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  7963	    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  7964	    inet XXX.XXX.0.1/8 scope host lo
  7965	       valid_lft forever preferred_lft forever
  7966	    inet6 ::1/128 scope host
  7967	       valid_lft forever preferred_lft forever
  7968	2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  7969	    link/ether 00:1e:06:42:03:f8 brd ff:ff:ff:ff:ff:ff
  7970
  7971	### partitions:
  7972
  7973	major minor  #blocks  name
  7974
  7975	 179        0   31464960 mmcblk0
  7976	 179        1   31146208 mmcblk0p1
  7977	 252        0    1859864 zram0
  7978	 252        1      51200 zram1
  7979
  7980	### df:
  7981
  7982	udev            1.4G     0  1.4G   0% /dev
  7983	tmpfs           364M  4.9M  359M   2% /run
  7984	/dev/mmcblk0p1   30G  1.7G   28G   6% /
  7985	tmpfs           1.8G     0  1.8G   0% /dev/shm
  7986	tmpfs           5.0M  4.0K  5.0M   1% /run/lock
  7987	tmpfs           1.8G     0  1.8G   0% /sys/fs/cgroup
  7988	tmpfs           1.8G     0  1.8G   0% /tmp
  7989	/dev/zram1       49M  3.5M   42M   8% /var/log
  7990
  7991	### lsblk:
  7992
  7993	NAME        FSTYPE  SIZE MOUNTPOINT UUID
  7994	mmcblk0              30G
  7995	└─mmcblk0p1 ext4   29.7G /          bd34953d-41be-49d6-b1c0-c0c28a5e239c
  7996	zram1                50M /var/log
  7997
  7998	### zramctl:
  7999
  8000	NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
  8001	/dev/zram1 zstd           50M  132K  698B   36K       6 /var/log
  8002	/dev/zram0 lzo-rle       1.8G    4K   74B   12K       6 [SWAP]
  8003
  8004	### mtab:
  8005
  8006	/dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  8007	/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  8008	/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
  8009
  8010	### mmc0:b368 info:
  8011
  8012	               fwrev: 0x0
  8013	              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=CBADS MODALIAS=mmc:block
  8014	                 cid: 6f0303434241445310aa002b4d013b00
  8015	                 rca: 0xb368
  8016	                 csd: 400e005a5b590000f00e7f800a404000
  8017	              manfid: 0x00006f
  8018	                 ocr: 0x00200000
  8019	preferred_erase_size: 2097152
  8020	                type: SD
  8021	               hwrev: 0x1
  8022	                date: 11/2019
  8023	                 dsr: 0x404
  8024	          erase_size: 512
  8025	               oemid: 0x0303
  8026	              serial: 0xaa002b4d
  8027	                 ssr: 00000000000000280402800100fd180a001e00000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  8028	                 scr: 02b5800300000000
  8029	                name: CBADS
  8030
  8031	### Boot system health:
  8032
  8033	Time       big.LITTLE   load %cpu %sys %usr %nice %io %irq   CPU  C.St.
  8034	15:44:06: 1908/1992MHz  2.82  23%  10%   5%   0%   6%   0% 33.4°C  0/11
  8035	15:44:07: 1908/1992MHz  2.82  47%  27%   8%   0%   9%   0% 33.5°C  0/11
  8036	15:44:07: 1908/1992MHz  2.82  78%  24%   1%   0%  51%   0% 31.6°C  0/11
  8037	15:44:07: 1908/1992MHz  2.82  51%   7%   4%   0%  39%   0% 31.5°C  0/11
  8038	15:44:08: 1908/1992MHz  2.82  65%  10%   5%   0%  46%   1% 32.2°C  0/11
  8039
  8040	### Activated 1 lzo-rle zram swap devices with 1816 MB each
  8041
  8042	### Activated Armbian ramlog partition with zstd compression
  8043
  8044	Sun 14 Feb 2021 03:45:32 PM GMT | Odroid N2 | 21.02.1 | arm64 | aarch64 | 5.10.12-meson64
  8045
  8046	### dmesg:
  8047
  8048	[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
  8049	[    0.000000] Linux version 5.10.12-meson64 (root@beast) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #21.02.1 SMP PREEMPT Wed Feb 3 21:06:36 CET 2021
  8050	[    0.000000] Machine model: Hardkernel ODROID-N2
  8051	[    0.000000] efi: UEFI not found.
  8052	[    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
  8053	[    0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB
  8054	[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
  8055	[    0.000000] NUMA: No NUMA configuration found
  8056	[    0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ed7fffff]
  8057	[    0.000000] NUMA: NODE_DATA [mem 0xb502f100-0xb5030fff]
  8058	[    0.000000] Zone ranges:
  8059	[    0.000000]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
  8060	[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000ed7fffff]
  8061	[    0.000000]   Normal   empty
  8062	[    0.000000] Movable zone start for each node
  8063	[    0.000000] Early memory node ranges
  8064	[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000004ffffff]
  8065	[    0.000000]   node   0: [mem 0x0000000005300000-0x00000000ed7fffff]
  8066	[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ed7fffff]
  8067	[    0.000000] On node 0 totalpages: 972032
  8068	[    0.000000]   DMA zone: 4096 pages used for memmap
  8069	[    0.000000]   DMA zone: 0 pages reserved
  8070	[    0.000000]   DMA zone: 261376 pages, LIFO batch:63
  8071	[    0.000000]   DMA32 zone: 11104 pages used for memmap
  8072	[    0.000000]   DMA32 zone: 710656 pages, LIFO batch:63
  8073	[    0.000000] psci: probing for conduit method from DT.
  8074	[    0.000000] psci: PSCIv1.0 detected in firmware.
  8075	[    0.000000] psci: Using standard PSCI v0.2 function IDs
  8076	[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
  8077	[    0.000000] psci: SMC Calling Convention v1.1
  8078	[    0.000000] percpu: Embedded 23 pages/cpu s56728 r8192 d29288 u94208
  8079	[    0.000000] pcpu-alloc: s56728 r8192 d29288 u94208 alloc=23*4096
  8080	[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
  8081	[    0.000000] Detected VIPT I-cache on CPU0
  8082	[    0.000000] CPU features: detected: ARM erratum 845719
  8083	[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 956832
  8084	[    0.000000] Policy zone: DMA32
  8085	[    0.000000] Kernel command line: root=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c rootwait rootfstype=ext4 console=ttyAML0,115200n8 console=tty1 loglevel=1  no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=custombuilt cvbsmode=576cvbs max_freq_a53=1896 max_freq_a73=1800 maxcpus=6 voutmode=hdmi modeline=1920,1080,148500,56250,50,1920,2448,2492,2640,1080,1084,1089,1125,1,1,1 disablehpd=false  cvbscable= overscan=100 consoleblank=0
  8086	[    0.000000] Kernel parameter elevator= does not have any effect anymore.
  8087	               Please use sysfs to set IO scheduler for individual devices.
  8088	[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
  8089	[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
  8090	[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
  8091	[    0.000000] software IO TLB: mapped [mem 0x0000000038ac5000-0x000000003cac5000] (64MB)
  8092	[    0.000000] Memory: 2785352K/3888128K available (14144K kernel code, 1760K rwdata, 5508K rodata, 3328K init, 592K bss, 185272K reserved, 917504K cma-reserved)
  8093	[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
  8094	[    0.000000] rcu: Preemptible hierarchical RCU implementation.
  8095	[    0.000000] rcu: 	RCU event tracing is enabled.
  8096	[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
  8097	[    0.000000] 	Trampoline variant of Tasks RCU enabled.
  8098	[    0.000000] 	Rude variant of Tasks RCU enabled.
  8099	[    0.000000] 	Tracing variant of Tasks RCU enabled.
  8100	[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  8101	[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
  8102	[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
  8103	[    0.000000] GIC: Using split EOI/Deactivate mode
  8104	[    0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized
  8105	[    0.000000] random: get_random_bytes called from start_kernel+0x378/0x538 with crng_init=0
  8106	[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
  8107	[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  8108	[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  8109	[    0.000239] Console: colour dummy device 80x25
  8110	[    0.000273] printk: console [tty1] enabled
  8111	[    0.000359] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
  8112	[    0.000371] pid_max: default: 32768 minimum: 301
  8113	[    0.000456] LSM: Security Framework initializing
  8114	[    0.000482] Yama: becoming mindful.
  8115	[    0.000574] AppArmor: AppArmor initialized
  8116	[    0.000623] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
  8117	[    0.000641] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
  8118	[    0.002631] rcu: Hierarchical SRCU implementation.
  8119	[    0.004981] EFI services will not be available.
  8120	[    0.005405] smp: Bringing up secondary CPUs ...
  8121	[    0.006077] Detected VIPT I-cache on CPU1
  8122	[    0.006138] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
  8123	[    0.007334] CPU features: detected: ARM erratum 858921
  8124	[    0.007342] CPU features: detected: Spectre-v2
  8125	[    0.007346] CPU features: detected: Spectre-v4
  8126	[    0.007353] Detected VIPT I-cache on CPU2
  8127	[    0.007379] arch_timer: Enabling local workaround for ARM erratum 858921
  8128	[    0.007393] arch_timer: CPU2: Trapping CNTVCT access
  8129	[    0.007407] CPU2: Booted secondary processor 0x0000000100 [0x410fd092]
  8130	[    0.008114] Detected VIPT I-cache on CPU3
  8131	[    0.008130] arch_timer: Enabling local workaround for ARM erratum 858921
  8132	[    0.008138] arch_timer: CPU3: Trapping CNTVCT access
  8133	[    0.008145] CPU3: Booted secondary processor 0x0000000101 [0x410fd092]
  8134	[    0.008770] Detected VIPT I-cache on CPU4
  8135	[    0.008788] arch_timer: Enabling local workaround for ARM erratum 858921
  8136	[    0.008794] arch_timer: CPU4: Trapping CNTVCT access
  8137	[    0.008802] CPU4: Booted secondary processor 0x0000000102 [0x410fd092]
  8138	[    0.009414] Detected VIPT I-cache on CPU5
  8139	[    0.009430] arch_timer: Enabling local workaround for ARM erratum 858921
  8140	[    0.009437] arch_timer: CPU5: Trapping CNTVCT access
  8141	[    0.009445] CPU5: Booted secondary processor 0x0000000103 [0x410fd092]
  8142	[    0.009525] smp: Brought up 1 node, 6 CPUs
  8143	[    0.009541] SMP: Total of 6 processors activated.
  8144	[    0.009549] CPU features: detected: 32-bit EL0 Support
  8145	[    0.009555] CPU features: detected: CRC32 instructions
  8146	[    0.009561] CPU features: detected: 32-bit EL1 Support
  8147	[    0.020801] CPU: All CPU(s) started at EL2
  8148	[    0.020850] alternatives: patching kernel code
  8149	[    0.022791] devtmpfs: initialized
  8150	[    0.030451] Registered cp15_barrier emulation handler
  8151	[    0.030464] Registered setend emulation handler
  8152	[    0.030599] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  8153	[    0.030637] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
  8154	[    0.044579] pinctrl core: initialized pinctrl subsystem
  8155	[    0.045311] DMI not present or invalid.
  8156	[    0.045684] NET: Registered protocol family 16
  8157	[    0.047203] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
  8158	[    0.047477] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
  8159	[    0.047703] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
  8160	[    0.047742] audit: initializing netlink subsys (disabled)
  8161	[    0.047845] audit: type=2000 audit(0.044:1): state=initialized audit_enabled=0 res=1
  8162	[    0.049187] thermal_sys: Registered thermal governor 'fair_share'
  8163	[    0.049193] thermal_sys: Registered thermal governor 'bang_bang'
  8164	[    0.049197] thermal_sys: Registered thermal governor 'step_wise'
  8165	[    0.049200] thermal_sys: Registered thermal governor 'user_space'
  8166	[    0.049615] cpuidle: using governor menu
  8167	[    0.049961] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  8168	[    0.050080] ASID allocator initialised with 65536 entries
  8169	[    0.051000] Serial: AMBA PL011 UART driver
  8170	[    0.085825] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
  8171	[    0.085838] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
  8172	[    0.085844] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
  8173	[    0.085849] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
  8174	[    0.087365] cryptd: max_cpu_qlen set to 1000
  8175	[    0.156125] raid6: neonx8   gen()  2781 MB/s
  8176	[    0.224183] raid6: neonx8   xor()  2044 MB/s
  8177	[    0.292249] raid6: neonx4   gen()  3011 MB/s
  8178	[    0.360316] raid6: neonx4   xor()  2255 MB/s
  8179	[    0.428379] raid6: neonx2   gen()  2578 MB/s
  8180	[    0.496447] raid6: neonx2   xor()  2146 MB/s
  8181	[    0.564510] raid6: neonx1   gen()  2008 MB/s
  8182	[    0.632578] raid6: neonx1   xor()  1723 MB/s
  8183	[    0.700660] raid6: int64x8  gen()  1377 MB/s
  8184	[    0.768717] raid6: int64x8  xor()   735 MB/s
  8185	[    0.836803] raid6: int64x4  gen()  1463 MB/s
  8186	[    0.904855] raid6: int64x4  xor()   733 MB/s
  8187	[    0.972913] raid6: int64x2  gen()  1362 MB/s
  8188	[    1.040992] raid6: int64x2  xor()   619 MB/s
  8189	[    1.109040] raid6: int64x1  gen()  1120 MB/s
  8190	[    1.177130] raid6: int64x1  xor()   462 MB/s
  8191	[    1.177134] raid6: using algorithm neonx4 gen() 3011 MB/s
  8192	[    1.177137] raid6: .... xor() 2255 MB/s, rmw enabled
  8193	[    1.177141] raid6: using neon recovery algorithm
  8194	[    1.177565] ACPI: Interpreter disabled.
  8195	[    1.178351] 5V: supplied by 12V
  8196	[    1.179270] VDDAO_3V3: supplied by 12V
  8197	[    1.179741] iommu: Default domain type: Translated
  8198	[    1.179868] vgaarb: loaded
  8199	[    1.180595] SCSI subsystem initialized
  8200	[    1.180896] usbcore: registered new interface driver usbfs
  8201	[    1.181009] usbcore: registered new interface driver hub
  8202	[    1.181051] usbcore: registered new device driver usb
  8203	[    1.181305] pps_core: LinuxPPS API ver. 1 registered
  8204	[    1.181310] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  8205	[    1.181343] PTP clock support registered
  8206	[    1.181534] EDAC MC: Ver: 3.0.0
  8207	[    1.182930] NetLabel: Initializing
  8208	[    1.182938] NetLabel:  domain hash size = 128
  8209	[    1.182941] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
  8210	[    1.182980] NetLabel:  unlabeled traffic allowed by default
  8211	[    1.183420] clocksource: Switched to clocksource arch_sys_counter
  8212	[    1.183625] VFS: Disk quotas dquot_6.6.0
  8213	[    1.183669] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  8214	[    1.184033] AppArmor: AppArmor Filesystem Enabled
  8215	[    1.184084] pnp: PnP ACPI: disabled
  8216	[    1.189822] NET: Registered protocol family 2
  8217	[    1.190267] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
  8218	[    1.190371] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
  8219	[    1.190628] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
  8220	[    1.190815] TCP: Hash tables configured (established 32768 bind 32768)
  8221	[    1.190969] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
  8222	[    1.191032] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
  8223	[    1.191078] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
  8224	[    1.191215] NET: Registered protocol family 1
  8225	[    1.191236] PCI: CLS 0 bytes, default 64
  8226	[    1.191363] Trying to unpack rootfs image as initramfs...
  8227	[    1.726912] Freeing initrd memory: 13544K
  8228	[    1.727835] kvm [1]: IPA Size Limit: 40 bits
  8229	[    1.728545] kvm [1]: vgic interrupt IRQ9
  8230	[    1.728678] kvm [1]: Hyp mode initialized successfully
  8231	[    1.732578] Initialise system trusted keyrings
  8232	[    1.732612] Key type blacklist registered
  8233	[    1.732712] workingset: timestamp_bits=44 max_order=20 bucket_order=0
  8234	[    1.735918] zbud: loaded
  8235	[    1.736896] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  8236	[    1.737362] fuse: init (API version 7.32)
  8237	[    1.738114] integrity: Platform Keyring initialized
  8238	[    1.765831] xor: measuring software checksum speed
  8239	[    1.768678]    8regs           :  3473 MB/sec
  8240	[    1.771127]    32regs          :  4021 MB/sec
  8241	[    1.773782]    arm64_neon      :  3719 MB/sec
  8242	[    1.773786] xor: using function: 32regs (4021 MB/sec)
  8243	[    1.773793] Key type asymmetric registered
  8244	[    1.773797] Asymmetric key parser 'x509' registered
  8245	[    1.773829] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
  8246	[    1.773926] io scheduler mq-deadline registered
  8247	[    1.773931] io scheduler kyber registered
  8248	[    1.774020] io scheduler bfq registered
  8249	[    1.776514] gpio-447 (usb-hub-reset): hogged as output/high
  8250	[    1.779388] EINJ: ACPI disabled.
  8251	[    1.785572] soc soc0: Amlogic Meson G12B (S922X) Revision 29:a (40:2) Detected
  8252	[    1.786936] VCC_3V3: supplied by VDDAO_3V3
  8253	[    1.786971] FLASH_1V8: supplied by VCC_3V3
  8254	[    1.787005] VCC_1V8: supplied by VCC_3V3
  8255	[    1.787033] VDDAO_1V8: supplied by VDDAO_3V3
  8256	[    1.787075] VDDCPU_A: supplied by regulator-dummy
  8257	[    1.787455] VDDCPU_B: supplied by regulator-dummy
  8258	[    1.788129] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
  8259	[    1.790337] Serial: AMBA driver
  8260	[    1.790621] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart
  8261	[    1.790715] printk: console [ttyAML0] enabled
  8262	[    1.791237] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 33, base_baud = 1500000) is a meson_uart
  8263	[    1.796533] loop: module loaded
  8264	[    1.798470] libphy: Fixed MDIO Bus: probed
  8265	[    1.799677] tun: Universal TUN/TAP device driver, 1.6
  8266	[    1.800277] thunder_xcv, ver 1.0
  8267	[    1.800304] thunder_bgx, ver 1.0
  8268	[    1.800330] nicpf, ver 1.0
  8269	[    1.800741] e1000e: Intel(R) PRO/1000 Network Driver
  8270	[    1.800744] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
  8271	[    1.800783] igb: Intel(R) Gigabit Ethernet Network Driver
  8272	[    1.800786] igb: Copyright (c) 2007-2014 Intel Corporation.
  8273	[    1.800815] igbvf: Intel(R) Gigabit Virtual Function Network Driver
  8274	[    1.800818] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
  8275	[    1.800935] sky2: driver version 1.30
  8276	[    1.801282] VFIO - User Level meta-driver version: 0.3
  8277	[    1.802592] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  8278	[    1.802609] ehci-pci: EHCI PCI platform driver
  8279	[    1.802638] ehci-platform: EHCI generic platform driver
  8280	[    1.802758] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  8281	[    1.802767] ohci-pci: OHCI PCI platform driver
  8282	[    1.802801] ohci-platform: OHCI generic platform driver
  8283	[    1.803169] usbcore: registered new interface driver usb-storage
  8284	[    1.804483] mousedev: PS/2 mouse device common for all mice
  8285	[    1.804851] i2c /dev entries driver
  8286	[    1.809979] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17
  8287	[    1.810624] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz
  8288	[    1.811292] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-1 failed:-17
  8289	[    1.811958] sdhci: Secure Digital Host Controller Interface driver
  8290	[    1.811966] sdhci: Copyright(c) Pierre Ossman
  8291	[    1.812119] Synopsys Designware Multimedia Card Interface Driver
  8292	[    1.812565] sdhci-pltfm: SDHCI platform and OF driver helper
  8293	[    1.813041] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq
  8294	[    1.814241] ledtrig-cpu: registered to indicate activity on CPUs
  8295	[    1.814499] meson-sm: secure-monitor enabled
  8296	[    1.814657] hid: raw HID events driver (C) Jiri Kosina
  8297	[    1.814745] usbcore: registered new interface driver usbhid
  8298	[    1.814747] usbhid: USB HID core driver
  8299	[    1.815769] NET: Registered protocol family 10
  8300	[    1.816156] Segment Routing with IPv6
  8301	[    1.816186] NET: Registered protocol family 17
  8302	[    1.816227] 8021q: 802.1Q VLAN Support v1.8
  8303	[    1.816250] Key type dns_resolver registered
  8304	[    1.816523] registered taskstats version 1
  8305	[    1.816528] Loading compiled-in X.509 certificates
  8306	[    1.818187] Loaded X.509 cert 'Build time autogenerated kernel key: f47c178852ca39740c3546b008122b65f5ed9bce'
  8307	[    1.819817] zswap: loaded using pool zstd/z3fold
  8308	[    1.819980] Key type ._fscrypt registered
  8309	[    1.819982] Key type .fscrypt registered
  8310	[    1.819984] Key type fscrypt-provisioning registered
  8311	[    1.821061] Btrfs loaded, crc32c=crc32c-generic
  8312	[    1.827020] Key type encrypted registered
  8313	[    1.827032] AppArmor: AppArmor sha1 policy hashing enabled
  8314	[    1.833224] HUB_5V: supplied by 5V
  8315	[    1.833432] USB_PWR_EN: supplied by 5V
  8316	[    1.835061] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2
  8317	[    1.835069] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1
  8318	[    1.837746] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator
  8319	[    1.837794] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator
  8320	[    1.837886] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM
  8321	[    1.838439] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  8322	[    1.838450] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
  8323	[    1.838534] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010
  8324	[    1.838558] xhci-hcd xhci-hcd.0.auto: irq 41, io mem 0xff500000
  8325	[    1.838685] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
  8326	[    1.838688] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  8327	[    1.838691] usb usb1: Product: xHCI Host Controller
  8328	[    1.838693] usb usb1: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
  8329	[    1.838696] usb usb1: SerialNumber: xhci-hcd.0.auto
  8330	[    1.838881] hub 1-0:1.0: USB hub found
  8331	[    1.838894] hub 1-0:1.0: 2 ports detected
  8332	[    1.839027] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  8333	[    1.839034] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  8334	[    1.839039] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  8335	[    1.839061] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
  8336	[    1.839093] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
  8337	[    1.839096] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  8338	[    1.839098] usb usb2: Product: xHCI Host Controller
  8339	[    1.839100] usb usb2: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
  8340	[    1.839103] usb usb2: SerialNumber: xhci-hcd.0.auto
  8341	[    1.839248] hub 2-0:1.0: USB hub found
  8342	[    1.839259] hub 2-0:1.0: 1 port detected
  8343	[    1.840694] meson-gx-mmc ffe05000.sd: Got CD GPIO
  8344	[    1.868168] Freeing unused kernel memory: 3328K
  8345	[    1.919477] Run /init as init process
  8346	[    1.919480]   with arguments:
  8347	[    1.919483]     /init
  8348	[    1.919484]   with environment:
  8349	[    1.919486]     HOME=/
  8350	[    1.919488]     TERM=linux
  8351	[    1.919490]     hdmimode=custombuilt
  8352	[    1.919491]     cvbsmode=576cvbs
  8353	[    1.919492]     max_freq_a53=1896
  8354	[    1.919494]     max_freq_a73=1800
  8355	[    1.919495]     voutmode=hdmi
  8356	[    1.919497]     modeline=1920,1080,148500,56250,50,1920,2448,2492,2640,1080,1084,1089,1125,1,1,1
  8357	[    1.919498]     disablehpd=false
  8358	[    1.919500]     cvbscable=
  8359	[    1.919501]     overscan=100
  8360	[    1.933573] mmc0: new ultra high speed SDR25 SDHC card at address b368
  8361	[    1.934071] mmcblk0: mmc0:b368 CBADS 30.0 GiB
  8362	[    1.936059]  mmcblk0: p1
  8363	[    2.063147] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found
  8364	[    2.063154] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found
  8365	[    2.063238] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock
  8366	[    2.063634] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37
  8367	[    2.063641] meson8b-dwmac ff3f0000.ethernet: 	DWMAC1000
  8368	[    2.063644] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported
  8369	[    2.063646] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported
  8370	[    2.063648] meson8b-dwmac ff3f0000.ethernet: COE Type 2
  8371	[    2.063651] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported
  8372	[    2.063653] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported
  8373	[    2.063690] meson8b-dwmac ff3f0000.ethernet: Normal descriptors
  8374	[    2.063692] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled
  8375	[    2.063695] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
  8376	[    2.063879] libphy: stmmac: probed
  8377	[    2.065180] libphy: mdio_mux: probed
  8378	[    2.065385] meson-vrtc ff8000a8.rtc: registered as rtc1
  8379	[    2.091722] random: fast init done
  8380	[    2.095522] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
  8381	[    2.096009] rtc-pcf8563 1-0051: registered as rtc0
  8382	[    2.097569] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
  8383	[    2.097582] rtc-pcf8563 1-0051: hctosys: unable to read the hardware clock
  8384	[    2.175437] usb 1-1: new high-speed USB device number 2 using xhci-hcd
  8385	[    2.272069] libphy: mdio_mux: probed
  8386	[    2.325754] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.04
  8387	[    2.325761] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  8388	[    2.325764] usb 1-1: Product: USB2.1 Hub
  8389	[    2.325766] usb 1-1: Manufacturer: GenesysLogic
  8390	[    2.383249] hub 1-1:1.0: USB hub found
  8391	[    2.383468] hub 1-1:1.0: 4 ports detected
  8392	[    2.451521] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
  8393	[    2.474005] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.04
  8394	[    2.474008] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  8395	[    2.474011] usb 2-1: Product: USB3.1 Hub
  8396	[    2.474014] usb 2-1: Manufacturer: GenesysLogic
  8397	[    2.495236] hub 2-1:1.0: USB hub found
  8398	[    2.495517] hub 2-1:1.0: 4 ports detected
  8399	[    2.599420] usb 1-2: new high-speed USB device number 3 using xhci-hcd
  8400	[    2.747860] usb 1-2: New USB device found, idVendor=2013, idProduct=025f, bcdDevice= 1.00
  8401	[    2.747863] usb 1-2: New USB device strings: Mfr=3, Product=1, SerialNumber=2
  8402	[    2.747865] usb 1-2: Product: PCTV 292e
  8403	[    2.747867] usb 1-2: Manufacturer: PCTV
  8404	[    2.747870] usb 1-2: SerialNumber: 0011356964
  8405	[    3.145478] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
  8406	[    3.939028] systemd[1]: System time before build time, advancing clock.
  8407	[    3.953926] systemd[1]: Inserted module 'autofs4'
  8408	[    4.004456] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  8409	[    4.004834] systemd[1]: Detected architecture arm64.
  8410	[    4.055254] systemd[1]: Set hostname to <odroidn2>.
  8411	[    4.391989] random: systemd: uninitialized urandom read (16 bytes read)
  8412	[    4.395322] random: systemd: uninitialized urandom read (16 bytes read)
  8413	[    4.395354] systemd[1]: Reached target Swap.
  8414	[    4.395645] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
  8415	[    4.395665] random: systemd: uninitialized urandom read (16 bytes read)
  8416	[    4.396903] systemd[1]: Created slice system-serial\x2dgetty.slice.
  8417	[    4.397134] systemd[1]: Listening on initctl Compatibility Named Pipe.
  8418	[    4.397216] systemd[1]: Reached target System Time Synchronized.
  8419	[    4.397616] systemd[1]: Created slice User and Session Slice.
  8420	[    4.397698] systemd[1]: Reached target Slices.
  8421	[    4.460211] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
  8422	[    5.019759] zram: Added device: zram0
  8423	[    5.020264] zram: Added device: zram1
  8424	[    5.020582] zram: Added device: zram2
  8425	[    5.028598] pwm-gpio pwmgpio: 1 gpio pwms loaded
  8426	[    5.165684] mc: Linux media interface: v0.10
  8427	[    5.196498] meson-saradc ff809000.adc: supply vref not found, using dummy regulator
  8428	[    5.211748] videodev: Linux video capture interface: v2.00
  8429	[    5.255592] panfrost ffe40000.gpu: clock rate = 24000000
  8430	[    5.255643] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19
  8431	[    5.256183] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0
  8432	[    5.256187] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400
  8433	[    5.256190] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
  8434	[    5.256193] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1
  8435	[    5.270796] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 0
  8436	[    5.279597] Registered IR keymap rc-odroid
  8437	[    5.296479] meson-drm ff900000.vpu: Queued 2 outputs on vpu
  8438	[    5.304600] IR NEC protocol handler initialized
  8439	[    5.335526] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0
  8440	[    5.335654] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
  8441	[    5.335739] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input0
  8442	[    5.335974] meson-ir ff808000.ir: receiver initialized
  8443	[    5.353851] meson-drm ff900000.vpu: CVBS Output connector not available
  8444	[    5.379507] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
  8445	[    5.380038] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
  8446	[    5.380410] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
  8447	[    5.383681] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 1
  8448	[    5.415479] zram0: detected capacity change from 0 to 1904500736
  8449	[    5.436660] em28xx 1-2:1.0: New device PCTV PCTV 292e @ 480 Mbps (2013:025f, interface 0, class 0)
  8450	[    5.436668] em28xx 1-2:1.0: DVB interface 0 found: isoc
  8451	[    5.445553] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  8452	[    5.495650] em28xx 1-2:1.0: chip ID is em28178
  8453	[    5.683578] Console: switching to colour frame buffer device 240x67
  8454	[    5.710122] meson-drm ff900000.vpu: [drm] fb0: mesondrmfb frame buffer device
  8455	[    5.742557] axg-sound-card sound: ASoC: no DMI vendor name!
  8456	[    6.463437] Adding 1859860k swap on /dev/zram0.  Priority:5 extents:1 across:1859860k SSFS
  8457	[    6.530381] zram1: detected capacity change from 0 to 52428800
  8458	[    7.526990] em28xx 1-2:1.0: EEPROM ID = 26 00 01 00, EEPROM hash = 0xc2b3eb9b
  8459	[    7.526995] em28xx 1-2:1.0: EEPROM info:
  8460	[    7.526998] em28xx 1-2:1.0: 	microcode start address = 0x0004, boot configuration = 0x01
  8461	[    7.533105] em28xx 1-2:1.0: 	AC97 audio (5 sample rates)
  8462	[    7.533108] em28xx 1-2:1.0: 	500mA max power
  8463	[    7.533112] em28xx 1-2:1.0: 	Table at offset 0x27, strings=0x146a, 0x1888, 0x0a7e
  8464	[    7.591416] em28xx 1-2:1.0: Identified as PCTV tripleStick (292e) (card=94)
  8465	[    7.591421] em28xx 1-2:1.0: dvb set to isoc mode.
  8466	[    7.591559] usbcore: registered new interface driver em28xx
  8467	[    7.617780] em28xx 1-2:1.0: Binding DVB extension
  8468	[    7.631034] i2c i2c-4: Added multiplexed i2c bus 5
  8469	[    7.631042] si2168 4-0064: Silicon Labs Si2168-B40 successfully identified
  8470	[    7.631045] si2168 4-0064: firmware version: B 4.0.2
  8471	[    7.639643] si2157 5-0060: Silicon Labs Si2147/2148/2157/2158 successfully attached
  8472	[    7.639722] dvbdev: DVB: registering new adapter (1-2:1.0)
  8473	[    7.639731] em28xx 1-2:1.0: DVB: registering adapter 0 frontend 0 (Silicon Labs Si2168)...
  8474	[    7.639740] dvbdev: dvb_create_media_entity: media entity 'Silicon Labs Si2168' registered.
  8475	[    7.640797] dvbdev: dvb_create_media_entity: media entity 'dvb-demux' registered.
  8476	[    7.643019] em28xx 1-2:1.0: DVB extension successfully initialized
  8477	[    7.643030] em28xx: Registered (Em28xx dvb Extension) extension
  8478	[    7.650381] em28xx 1-2:1.0: Registering input extension
  8479	[    7.683417] Registered IR keymap rc-pinnacle-pctv-hd
  8480	[    7.683592] rc rc1: PCTV tripleStick (292e) as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-2/1-2:1.0/rc/rc1
  8481	[    7.683671] rc rc1: lirc_dev: driver em28xx registered at minor = 1, scancode receiver, no transmitter
  8482	[    7.683733] input: PCTV tripleStick (292e) as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-2/1-2:1.0/rc/rc1/input1
  8483	[    7.683811] em28xx 1-2:1.0: Input extension successfully initialized
  8484	[    7.683815] em28xx: Registered (Em28xx Input Extension) extension
  8485	[    8.614907] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
  8486	[    8.614926] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
  8487	[    9.640132] systemd[1]: Started Armbian memory supported logging.
  8488	[    9.642499] systemd[1]: Starting Journal Service...
  8489	[    9.705707] systemd[1]: Started Journal Service.
  8490	[    9.730652] systemd-journald[1846]: Received request to flush runtime journal from PID 1
  8491
  8492	### armbian-release:
  8493
  8494	# PLEASE DO NOT EDIT THIS FILE
  8495	BOARD=odroidn2
  8496	BOARD_NAME="Odroid N2"
  8497	BOARDFAMILY=meson-g12b
  8498	BUILD_REPOSITORY_URL=https://github.com/armbian/build
  8499	BUILD_REPOSITORY_COMMIT=5f03d652
  8500	DISTRIBUTION_CODENAME=buster
  8501	DISTRIBUTION_STATUS=supported
  8502	VERSION=21.02.1
  8503	LINUXFAMILY=meson64
  8504	BRANCH=current
  8505	ARCH=arm64
  8506	IMAGE_TYPE=stable
  8507	BOARD_TYPE=conf
  8508	INITRD_ARCH=arm64
  8509	KERNEL_IMAGE_TYPE=Image
  8510
  8511	### boot environment:
  8512
  8513	verbosity=1
  8514	console=both
  8515	overlay_prefix=meson
  8516	rootdev=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c
  8517	rootfstype=ext4
  8518	usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
  8519
  8520	### lsusb:
  8521
  8522	Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc.
  8523	Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  8524	Bus 001 Device 003: ID 2013:025f PCTV Systems
  8525	Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
  8526	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  8527
  8528	### lscpu:
  8529
  8530	Architecture:        aarch64
  8531	Byte Order:          Little Endian
  8532	CPU(s):              6
  8533	On-line CPU(s) list: 0-5
  8534	Thread(s) per core:  1
  8535	Core(s) per socket:  3
  8536	Socket(s):           2
  8537	NUMA node(s):        1
  8538	Vendor ID:           ARM
  8539	Model:               4
  8540	Model name:          Cortex-A53
  8541	Stepping:            r0p4
  8542	CPU max MHz:         1992.0000
  8543	CPU min MHz:         100.0000
  8544	BogoMIPS:            48.00
  8545	L1d cache:           unknown size
  8546	L1i cache:           unknown size
  8547	L2 cache:            unknown size
  8548	NUMA node0 CPU(s):   0-5
  8549	Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  8550
  8551	### cpuinfo:
  8552
  8553	processor	: 0
  8554	BogoMIPS	: 48.00
  8555	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  8556	CPU implementer	: 0x41
  8557	CPU architecture: 8
  8558	CPU variant	: 0x0
  8559	CPU part	: 0xd03
  8560	CPU revision	: 4
  8561
  8562	processor	: 1
  8563	BogoMIPS	: 48.00
  8564	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  8565	CPU implementer	: 0x41
  8566	CPU architecture: 8
  8567	CPU variant	: 0x0
  8568	CPU part	: 0xd03
  8569	CPU revision	: 4
  8570
  8571	processor	: 2
  8572	BogoMIPS	: 48.00
  8573	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  8574	CPU implementer	: 0x41
  8575	CPU architecture: 8
  8576	CPU variant	: 0x0
  8577	CPU part	: 0xd09
  8578	CPU revision	: 2
  8579
  8580	processor	: 3
  8581	BogoMIPS	: 48.00
  8582	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  8583	CPU implementer	: 0x41
  8584	CPU architecture: 8
  8585	CPU variant	: 0x0
  8586	CPU part	: 0xd09
  8587	CPU revision	: 2
  8588
  8589	processor	: 4
  8590	BogoMIPS	: 48.00
  8591	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  8592	CPU implementer	: 0x41
  8593	CPU architecture: 8
  8594	CPU variant	: 0x0
  8595	CPU part	: 0xd09
  8596	CPU revision	: 2
  8597
  8598	processor	: 5
  8599	BogoMIPS	: 48.00
  8600	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  8601	CPU implementer	: 0x41
  8602	CPU architecture: 8
  8603	CPU variant	: 0x0
  8604	CPU part	: 0xd09
  8605	CPU revision	: 2
  8606
  8607
  8608	### meminfo:
  8609
  8610	MemTotal:        3719728 kB
  8611	MemFree:         3436856 kB
  8612	MemAvailable:    3390088 kB
  8613	Buffers:           11444 kB
  8614	Cached:            43724 kB
  8615	SwapCached:            0 kB
  8616	Active:            29060 kB
  8617	Inactive:         141492 kB
  8618	Active(anon):        156 kB
  8619	Inactive(anon):   120508 kB
  8620	Active(file):      28904 kB
  8621	Inactive(file):    20984 kB
  8622	Unevictable:           0 kB
  8623	Mlocked:               0 kB
  8624	SwapTotal:       1859860 kB
  8625	SwapFree:        1859860 kB
  8626	Dirty:              3816 kB
  8627	Writeback:             0 kB
  8628	AnonPages:        115916 kB
  8629	Mapped:            13168 kB
  8630	Shmem:              4984 kB
  8631	KReclaimable:      13292 kB
  8632	Slab:              40728 kB
  8633	SReclaimable:      13292 kB
  8634	SUnreclaim:        27436 kB
  8635	KernelStack:        2544 kB
  8636	PageTables:         4640 kB
  8637	NFS_Unstable:          0 kB
  8638	Bounce:                0 kB
  8639	WritebackTmp:          0 kB
  8640	CommitLimit:     3719724 kB
  8641	Committed_AS:    4240076 kB
  8642	VmallocTotal:   135290159040 kB
  8643	VmallocUsed:       33248 kB
  8644	VmallocChunk:          0 kB
  8645	Percpu:             1368 kB
  8646	HardwareCorrupted:     0 kB
  8647	AnonHugePages:         0 kB
  8648	ShmemHugePages:        0 kB
  8649	ShmemPmdMapped:        0 kB
  8650	FileHugePages:         0 kB
  8651	FilePmdMapped:         0 kB
  8652	CmaTotal:         917504 kB
  8653	CmaFree:          901724 kB
  8654	HugePages_Total:       0
  8655	HugePages_Free:        0
  8656	HugePages_Rsvd:        0
  8657	HugePages_Surp:        0
  8658	Hugepagesize:       2048 kB
  8659	Hugetlb:               0 kB
  8660
  8661	### virtual memory:
  8662
  8663	vm.admin_reserve_kbytes = 8192
  8664	vm.block_dump = 0
  8665	vm.compaction_proactiveness = 20
  8666	vm.compact_unevictable_allowed = 1
  8667	vm.dirty_background_bytes = 0
  8668	vm.dirty_background_ratio = 10
  8669	vm.dirty_bytes = 0
  8670	vm.dirty_expire_centisecs = 3000
  8671	vm.dirty_ratio = 20
  8672	vm.dirtytime_expire_seconds = 43200
  8673	vm.dirty_writeback_centisecs = 500
  8674	vm.extfrag_threshold = 500
  8675	vm.hugetlb_shm_group = 0
  8676	vm.laptop_mode = 0
  8677	vm.legacy_va_layout = 0
  8678	vm.lowmem_reserve_ratio = 256	256	32	0
  8679	vm.max_map_count = 65530
  8680	vm.memory_failure_early_kill = 0
  8681	vm.memory_failure_recovery = 1
  8682	vm.min_free_kbytes = 45056
  8683	vm.min_slab_ratio = 5
  8684	vm.min_unmapped_ratio = 1
  8685	vm.mmap_min_addr = 4096
  8686	vm.mmap_rnd_bits = 18
  8687	vm.mmap_rnd_compat_bits = 11
  8688	vm.nr_hugepages = 0
  8689	vm.nr_hugepages_mempolicy = 0
  8690	vm.nr_overcommit_hugepages = 0
  8691	vm.numa_stat = 1
  8692	vm.numa_zonelist_order = Node
  8693	vm.oom_dump_tasks = 1
  8694	vm.oom_kill_allocating_task = 0
  8695	vm.overcommit_kbytes = 0
  8696	vm.overcommit_memory = 0
  8697	vm.overcommit_ratio = 50
  8698	vm.page-cluster = 0
  8699	vm.page_lock_unfairness = 5
  8700	vm.panic_on_oom = 0
  8701	vm.percpu_pagelist_fraction = 0
  8702	vm.stat_interval = 1
  8703	vm.swappiness = 100
  8704	vm.user_reserve_kbytes = 115057
  8705	vm.vfs_cache_pressure = 100
  8706	vm.watermark_boost_factor = 15000
  8707	vm.watermark_scale_factor = 10
  8708	vm.zone_reclaim_mode = 0
  8709
  8710	### ip addr:
  8711
  8712	1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  8713	    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  8714	    inet XXX.XXX.0.1/8 scope host lo
  8715	       valid_lft forever preferred_lft forever
  8716	    inet6 ::1/128 scope host
  8717	       valid_lft forever preferred_lft forever
  8718	2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  8719	    link/ether 00:1e:06:42:03:f8 brd ff:ff:ff:ff:ff:ff
  8720
  8721	### partitions:
  8722
  8723	major minor  #blocks  name
  8724
  8725	 179        0   31464960 mmcblk0
  8726	 179        1   31146208 mmcblk0p1
  8727	 252        0    1859864 zram0
  8728	 252        1      51200 zram1
  8729
  8730	### df:
  8731
  8732	udev            1.4G     0  1.4G   0% /dev
  8733	tmpfs           364M  4.9M  359M   2% /run
  8734	/dev/mmcblk0p1   30G  1.7G   28G   6% /
  8735	tmpfs           1.8G     0  1.8G   0% /dev/shm
  8736	tmpfs           5.0M  4.0K  5.0M   1% /run/lock
  8737	tmpfs           1.8G     0  1.8G   0% /sys/fs/cgroup
  8738	tmpfs           1.8G     0  1.8G   0% /tmp
  8739	/dev/zram1       49M  3.8M   42M   9% /var/log
  8740
  8741	### lsblk:
  8742
  8743	NAME        FSTYPE  SIZE MOUNTPOINT UUID
  8744	mmcblk0              30G
  8745	└─mmcblk0p1 ext4   29.7G /          bd34953d-41be-49d6-b1c0-c0c28a5e239c
  8746	zram1                50M /var/log
  8747
  8748	### zramctl:
  8749
  8750	NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
  8751	/dev/zram1 zstd           50M  132K  698B   36K       6 /var/log
  8752	/dev/zram0 lzo-rle       1.8G    4K   74B   12K       6 [SWAP]
  8753
  8754	### mtab:
  8755
  8756	/dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  8757	/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  8758	/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
  8759
  8760	### mmc0:b368 info:
  8761
  8762	               fwrev: 0x0
  8763	              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=CBADS MODALIAS=mmc:block
  8764	                 cid: 6f0303434241445310aa002b4d013b00
  8765	                 rca: 0xb368
  8766	                 csd: 400e005a5b590000f00e7f800a404000
  8767	              manfid: 0x00006f
  8768	                 ocr: 0x00200000
  8769	preferred_erase_size: 2097152
  8770	                type: SD
  8771	               hwrev: 0x1
  8772	                date: 11/2019
  8773	                 dsr: 0x404
  8774	          erase_size: 512
  8775	               oemid: 0x0303
  8776	              serial: 0xaa002b4d
  8777	                 ssr: 00000000000000280402800100fd180a001e00000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  8778	                 scr: 02b5800300000000
  8779	                name: CBADS
  8780
  8781	### Boot system health:
  8782
  8783	Time       big.LITTLE   load %cpu %sys %usr %nice %io %irq   CPU  C.St.
  8784	15:45:33: 1908/1992MHz  1.71  23%  11%   5%   0%   6%   0% 34.6°C  0/11
  8785	15:45:33: 1908/1992MHz  1.71  71%  37%  10%   0%  21%   1% 33.0°C  0/11
  8786	15:45:33: 1908/1992MHz  1.71  78%  20%   3%   0%  52%   0% 32.3°C  0/11
  8787	15:45:34: 1908/1992MHz  1.71  63%   8%   4%   0%  48%   1% 31.3°C  0/11
  8788	15:45:34: 1908/1992MHz  1.71  35%   3%   1%   0%  30%   0% 30.3°C  0/11
  8789
  8790	### Activated 1 lzo-rle zram swap devices with 1816 MB each
  8791
  8792	### Activated Armbian ramlog partition with zstd compression
  8793
  8794	Sun 14 Feb 2021 03:49:19 PM GMT | Odroid N2 | 21.02.1 | arm64 | aarch64 | 5.10.12-meson64
  8795
  8796	### dmesg:
  8797
  8798	[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
  8799	[    0.000000] Linux version 5.10.12-meson64 (root@beast) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #21.02.1 SMP PREEMPT Wed Feb 3 21:06:36 CET 2021
  8800	[    0.000000] Machine model: Hardkernel ODROID-N2
  8801	[    0.000000] efi: UEFI not found.
  8802	[    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
  8803	[    0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB
  8804	[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
  8805	[    0.000000] NUMA: No NUMA configuration found
  8806	[    0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ed7fffff]
  8807	[    0.000000] NUMA: NODE_DATA [mem 0xb502f100-0xb5030fff]
  8808	[    0.000000] Zone ranges:
  8809	[    0.000000]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
  8810	[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000ed7fffff]
  8811	[    0.000000]   Normal   empty
  8812	[    0.000000] Movable zone start for each node
  8813	[    0.000000] Early memory node ranges
  8814	[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000004ffffff]
  8815	[    0.000000]   node   0: [mem 0x0000000005300000-0x00000000ed7fffff]
  8816	[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ed7fffff]
  8817	[    0.000000] On node 0 totalpages: 972032
  8818	[    0.000000]   DMA zone: 4096 pages used for memmap
  8819	[    0.000000]   DMA zone: 0 pages reserved
  8820	[    0.000000]   DMA zone: 261376 pages, LIFO batch:63
  8821	[    0.000000]   DMA32 zone: 11104 pages used for memmap
  8822	[    0.000000]   DMA32 zone: 710656 pages, LIFO batch:63
  8823	[    0.000000] psci: probing for conduit method from DT.
  8824	[    0.000000] psci: PSCIv1.0 detected in firmware.
  8825	[    0.000000] psci: Using standard PSCI v0.2 function IDs
  8826	[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
  8827	[    0.000000] psci: SMC Calling Convention v1.1
  8828	[    0.000000] percpu: Embedded 23 pages/cpu s56728 r8192 d29288 u94208
  8829	[    0.000000] pcpu-alloc: s56728 r8192 d29288 u94208 alloc=23*4096
  8830	[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
  8831	[    0.000000] Detected VIPT I-cache on CPU0
  8832	[    0.000000] CPU features: detected: ARM erratum 845719
  8833	[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 956832
  8834	[    0.000000] Policy zone: DMA32
  8835	[    0.000000] Kernel command line: root=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c rootwait rootfstype=ext4 console=ttyAML0,115200n8 console=tty1 loglevel=1  no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=custombuilt cvbsmode=576cvbs max_freq_a53=1896 max_freq_a73=1800 maxcpus=6 voutmode=hdmi modeline=1920,1080,148500,56250,50,1920,2448,2492,2640,1080,1084,1089,1125,1,1,1 disablehpd=false  cvbscable= overscan=100 consoleblank=0
  8836	[    0.000000] Kernel parameter elevator= does not have any effect anymore.
  8837	               Please use sysfs to set IO scheduler for individual devices.
  8838	[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
  8839	[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
  8840	[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
  8841	[    0.000000] software IO TLB: mapped [mem 0x0000000038ac5000-0x000000003cac5000] (64MB)
  8842	[    0.000000] Memory: 2785352K/3888128K available (14144K kernel code, 1760K rwdata, 5508K rodata, 3328K init, 592K bss, 185272K reserved, 917504K cma-reserved)
  8843	[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
  8844	[    0.000000] rcu: Preemptible hierarchical RCU implementation.
  8845	[    0.000000] rcu: 	RCU event tracing is enabled.
  8846	[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
  8847	[    0.000000] 	Trampoline variant of Tasks RCU enabled.
  8848	[    0.000000] 	Rude variant of Tasks RCU enabled.
  8849	[    0.000000] 	Tracing variant of Tasks RCU enabled.
  8850	[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  8851	[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
  8852	[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
  8853	[    0.000000] GIC: Using split EOI/Deactivate mode
  8854	[    0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized
  8855	[    0.000000] random: get_random_bytes called from start_kernel+0x378/0x538 with crng_init=0
  8856	[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
  8857	[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  8858	[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  8859	[    0.000238] Console: colour dummy device 80x25
  8860	[    0.000272] printk: console [tty1] enabled
  8861	[    0.000359] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
  8862	[    0.000371] pid_max: default: 32768 minimum: 301
  8863	[    0.000454] LSM: Security Framework initializing
  8864	[    0.000481] Yama: becoming mindful.
  8865	[    0.000572] AppArmor: AppArmor initialized
  8866	[    0.000622] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
  8867	[    0.000641] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
  8868	[    0.002638] rcu: Hierarchical SRCU implementation.
  8869	[    0.005005] EFI services will not be available.
  8870	[    0.005423] smp: Bringing up secondary CPUs ...
  8871	[    0.006091] Detected VIPT I-cache on CPU1
  8872	[    0.006153] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
  8873	[    0.007345] CPU features: detected: ARM erratum 858921
  8874	[    0.007352] CPU features: detected: Spectre-v2
  8875	[    0.007356] CPU features: detected: Spectre-v4
  8876	[    0.007363] Detected VIPT I-cache on CPU2
  8877	[    0.007388] arch_timer: Enabling local workaround for ARM erratum 858921
  8878	[    0.007403] arch_timer: CPU2: Trapping CNTVCT access
  8879	[    0.007416] CPU2: Booted secondary processor 0x0000000100 [0x410fd092]
  8880	[    0.008128] Detected VIPT I-cache on CPU3
  8881	[    0.008145] arch_timer: Enabling local workaround for ARM erratum 858921
  8882	[    0.008153] arch_timer: CPU3: Trapping CNTVCT access
  8883	[    0.008160] CPU3: Booted secondary processor 0x0000000101 [0x410fd092]
  8884	[    0.008790] Detected VIPT I-cache on CPU4
  8885	[    0.008807] arch_timer: Enabling local workaround for ARM erratum 858921
  8886	[    0.008814] arch_timer: CPU4: Trapping CNTVCT access
  8887	[    0.008821] CPU4: Booted secondary processor 0x0000000102 [0x410fd092]
  8888	[    0.009438] Detected VIPT I-cache on CPU5
  8889	[    0.009454] arch_timer: Enabling local workaround for ARM erratum 858921
  8890	[    0.009461] arch_timer: CPU5: Trapping CNTVCT access
  8891	[    0.009468] CPU5: Booted secondary processor 0x0000000103 [0x410fd092]
  8892	[    0.009550] smp: Brought up 1 node, 6 CPUs
  8893	[    0.009567] SMP: Total of 6 processors activated.
  8894	[    0.009575] CPU features: detected: 32-bit EL0 Support
  8895	[    0.009581] CPU features: detected: CRC32 instructions
  8896	[    0.009587] CPU features: detected: 32-bit EL1 Support
  8897	[    0.020883] CPU: All CPU(s) started at EL2
  8898	[    0.020933] alternatives: patching kernel code
  8899	[    0.022877] devtmpfs: initialized
  8900	[    0.030551] Registered cp15_barrier emulation handler
  8901	[    0.030565] Registered setend emulation handler
  8902	[    0.030703] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  8903	[    0.030742] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
  8904	[    0.044678] pinctrl core: initialized pinctrl subsystem
  8905	[    0.045410] DMI not present or invalid.
  8906	[    0.045779] NET: Registered protocol family 16
  8907	[    0.047352] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
  8908	[    0.047625] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
  8909	[    0.047851] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
  8910	[    0.047893] audit: initializing netlink subsys (disabled)
  8911	[    0.047997] audit: type=2000 audit(0.048:1): state=initialized audit_enabled=0 res=1
  8912	[    0.049247] thermal_sys: Registered thermal governor 'fair_share'
  8913	[    0.049255] thermal_sys: Registered thermal governor 'bang_bang'
  8914	[    0.049259] thermal_sys: Registered thermal governor 'step_wise'
  8915	[    0.049262] thermal_sys: Registered thermal governor 'user_space'
  8916	[    0.049699] cpuidle: using governor menu
  8917	[    0.050049] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  8918	[    0.050166] ASID allocator initialised with 65536 entries
  8919	[    0.051093] Serial: AMBA PL011 UART driver
  8920	[    0.084892] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
  8921	[    0.084903] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
  8922	[    0.084908] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
  8923	[    0.084912] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
  8924	[    0.086959] cryptd: max_cpu_qlen set to 1000
  8925	[    0.156157] raid6: neonx8   gen()  2787 MB/s
  8926	[    0.224220] raid6: neonx8   xor()  2042 MB/s
  8927	[    0.292295] raid6: neonx4   gen()  2999 MB/s
  8928	[    0.360368] raid6: neonx4   xor()  2346 MB/s
  8929	[    0.428472] raid6: neonx2   gen()  2575 MB/s
  8930	[    0.496611] raid6: neonx2   xor()  1455 MB/s
  8931	[    0.564660] raid6: neonx1   gen()  1820 MB/s
  8932	[    0.632697] raid6: neonx1   xor()  1727 MB/s
  8933	[    0.700773] raid6: int64x8  gen()  1379 MB/s
  8934	[    0.768828] raid6: int64x8  xor()   735 MB/s
  8935	[    0.836913] raid6: int64x4  gen()  1463 MB/s
  8936	[    0.904965] raid6: int64x4  xor()   733 MB/s
  8937	[    0.973025] raid6: int64x2  gen()  1362 MB/s
  8938	[    1.041106] raid6: int64x2  xor()   619 MB/s
  8939	[    1.109158] raid6: int64x1  gen()  1120 MB/s
  8940	[    1.177228] raid6: int64x1  xor()   462 MB/s
  8941	[    1.177231] raid6: using algorithm neonx4 gen() 2999 MB/s
  8942	[    1.177234] raid6: .... xor() 2346 MB/s, rmw enabled
  8943	[    1.177238] raid6: using neon recovery algorithm
  8944	[    1.177683] ACPI: Interpreter disabled.
  8945	[    1.178450] 5V: supplied by 12V
  8946	[    1.179339] VDDAO_3V3: supplied by 12V
  8947	[    1.179805] iommu: Default domain type: Translated
  8948	[    1.179918] vgaarb: loaded
  8949	[    1.180644] SCSI subsystem initialized
  8950	[    1.181023] usbcore: registered new interface driver usbfs
  8951	[    1.181060] usbcore: registered new interface driver hub
  8952	[    1.181098] usbcore: registered new device driver usb
  8953	[    1.181410] pps_core: LinuxPPS API ver. 1 registered
  8954	[    1.181414] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  8955	[    1.181433] PTP clock support registered
  8956	[    1.181632] EDAC MC: Ver: 3.0.0
  8957	[    1.182968] NetLabel: Initializing
  8958	[    1.182976] NetLabel:  domain hash size = 128
  8959	[    1.182978] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
  8960	[    1.183021] NetLabel:  unlabeled traffic allowed by default
  8961	[    1.183498] clocksource: Switched to clocksource arch_sys_counter
  8962	[    1.183713] VFS: Disk quotas dquot_6.6.0
  8963	[    1.183758] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  8964	[    1.184105] AppArmor: AppArmor Filesystem Enabled
  8965	[    1.184152] pnp: PnP ACPI: disabled
  8966	[    1.189684] NET: Registered protocol family 2
  8967	[    1.190147] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
  8968	[    1.190252] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
  8969	[    1.190508] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
  8970	[    1.190696] TCP: Hash tables configured (established 32768 bind 32768)
  8971	[    1.190848] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
  8972	[    1.190914] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
  8973	[    1.190961] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
  8974	[    1.191106] NET: Registered protocol family 1
  8975	[    1.191125] PCI: CLS 0 bytes, default 64
  8976	[    1.191251] Trying to unpack rootfs image as initramfs...
  8977	[    1.727226] Freeing initrd memory: 13544K
  8978	[    1.728149] kvm [1]: IPA Size Limit: 40 bits
  8979	[    1.728852] kvm [1]: vgic interrupt IRQ9
  8980	[    1.728985] kvm [1]: Hyp mode initialized successfully
  8981	[    1.734075] Initialise system trusted keyrings
  8982	[    1.734114] Key type blacklist registered
  8983	[    1.734240] workingset: timestamp_bits=44 max_order=20 bucket_order=0
  8984	[    1.737431] zbud: loaded
  8985	[    1.738416] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  8986	[    1.738901] fuse: init (API version 7.32)
  8987	[    1.739700] integrity: Platform Keyring initialized
  8988	[    1.767881] xor: measuring software checksum speed
  8989	[    1.770719]    8regs           :  3473 MB/sec
  8990	[    1.773200]    32regs          :  4024 MB/sec
  8991	[    1.775860]    arm64_neon      :  3718 MB/sec
  8992	[    1.775863] xor: using function: 32regs (4024 MB/sec)
  8993	[    1.775872] Key type asymmetric registered
  8994	[    1.775876] Asymmetric key parser 'x509' registered
  8995	[    1.775912] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
  8996	[    1.776023] io scheduler mq-deadline registered
  8997	[    1.776028] io scheduler kyber registered
  8998	[    1.776105] io scheduler bfq registered
  8999	[    1.778569] gpio-447 (usb-hub-reset): hogged as output/high
  9000	[    1.781461] EINJ: ACPI disabled.
  9001	[    1.787661] soc soc0: Amlogic Meson G12B (S922X) Revision 29:a (40:2) Detected
  9002	[    1.789022] VCC_3V3: supplied by VDDAO_3V3
  9003	[    1.789055] FLASH_1V8: supplied by VCC_3V3
  9004	[    1.789100] VCC_1V8: supplied by VCC_3V3
  9005	[    1.789126] VDDAO_1V8: supplied by VDDAO_3V3
  9006	[    1.789156] VDDCPU_A: supplied by regulator-dummy
  9007	[    1.789510] VDDCPU_B: supplied by regulator-dummy
  9008	[    1.790177] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
  9009	[    1.792636] Serial: AMBA driver
  9010	[    1.792916] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart
  9011	[    1.793010] printk: console [ttyAML0] enabled
  9012	[    1.793552] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 33, base_baud = 1500000) is a meson_uart
  9013	[    1.798845] loop: module loaded
  9014	[    1.800746] libphy: Fixed MDIO Bus: probed
  9015	[    1.801871] tun: Universal TUN/TAP device driver, 1.6
  9016	[    1.802489] thunder_xcv, ver 1.0
  9017	[    1.802521] thunder_bgx, ver 1.0
  9018	[    1.802554] nicpf, ver 1.0
  9019	[    1.802990] e1000e: Intel(R) PRO/1000 Network Driver
  9020	[    1.802993] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
  9021	[    1.803034] igb: Intel(R) Gigabit Ethernet Network Driver
  9022	[    1.803037] igb: Copyright (c) 2007-2014 Intel Corporation.
  9023	[    1.803072] igbvf: Intel(R) Gigabit Virtual Function Network Driver
  9024	[    1.803075] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
  9025	[    1.803196] sky2: driver version 1.30
  9026	[    1.803707] VFIO - User Level meta-driver version: 0.3
  9027	[    1.805058] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  9028	[    1.805079] ehci-pci: EHCI PCI platform driver
  9029	[    1.805111] ehci-platform: EHCI generic platform driver
  9030	[    1.805239] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  9031	[    1.805250] ohci-pci: OHCI PCI platform driver
  9032	[    1.805286] ohci-platform: OHCI generic platform driver
  9033	[    1.805662] usbcore: registered new interface driver usb-storage
  9034	[    1.806882] mousedev: PS/2 mouse device common for all mice
  9035	[    1.807263] i2c /dev entries driver
  9036	[    1.812505] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17
  9037	[    1.813167] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz
  9038	[    1.813852] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-1 failed:-17
  9039	[    1.814452] sdhci: Secure Digital Host Controller Interface driver
  9040	[    1.814460] sdhci: Copyright(c) Pierre Ossman
  9041	[    1.814582] Synopsys Designware Multimedia Card Interface Driver
  9042	[    1.815077] sdhci-pltfm: SDHCI platform and OF driver helper
  9043	[    1.816148] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq
  9044	[    1.816898] ledtrig-cpu: registered to indicate activity on CPUs
  9045	[    1.817210] meson-sm: secure-monitor enabled
  9046	[    1.817394] hid: raw HID events driver (C) Jiri Kosina
  9047	[    1.817476] usbcore: registered new interface driver usbhid
  9048	[    1.817478] usbhid: USB HID core driver
  9049	[    1.818448] NET: Registered protocol family 10
  9050	[    1.818878] Segment Routing with IPv6
  9051	[    1.818908] NET: Registered protocol family 17
  9052	[    1.818962] 8021q: 802.1Q VLAN Support v1.8
  9053	[    1.818985] Key type dns_resolver registered
  9054	[    1.819258] registered taskstats version 1
  9055	[    1.819264] Loading compiled-in X.509 certificates
  9056	[    1.821090] Loaded X.509 cert 'Build time autogenerated kernel key: f47c178852ca39740c3546b008122b65f5ed9bce'
  9057	[    1.822708] zswap: loaded using pool zstd/z3fold
  9058	[    1.822889] Key type ._fscrypt registered
  9059	[    1.822890] Key type .fscrypt registered
  9060	[    1.822892] Key type fscrypt-provisioning registered
  9061	[    1.824052] Btrfs loaded, crc32c=crc32c-generic
  9062	[    1.830084] Key type encrypted registered
  9063	[    1.830096] AppArmor: AppArmor sha1 policy hashing enabled
  9064	[    1.836612] HUB_5V: supplied by 5V
  9065	[    1.836812] USB_PWR_EN: supplied by 5V
  9066	[    1.838434] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2
  9067	[    1.838441] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1
  9068	[    1.841163] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator
  9069	[    1.841215] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator
  9070	[    1.841333] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM
  9071	[    1.841942] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  9072	[    1.841954] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
  9073	[    1.842041] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010
  9074	[    1.842060] xhci-hcd xhci-hcd.0.auto: irq 41, io mem 0xff500000
  9075	[    1.842181] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
  9076	[    1.842185] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  9077	[    1.842188] usb usb1: Product: xHCI Host Controller
  9078	[    1.842190] usb usb1: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
  9079	[    1.842192] usb usb1: SerialNumber: xhci-hcd.0.auto
  9080	[    1.842386] hub 1-0:1.0: USB hub found
  9081	[    1.842399] hub 1-0:1.0: 2 ports detected
  9082	[    1.842529] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  9083	[    1.842536] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  9084	[    1.842541] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  9085	[    1.842560] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
  9086	[    1.842590] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
  9087	[    1.842593] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  9088	[    1.842596] usb usb2: Product: xHCI Host Controller
  9089	[    1.842598] usb usb2: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
  9090	[    1.842600] usb usb2: SerialNumber: xhci-hcd.0.auto
  9091	[    1.842749] hub 2-0:1.0: USB hub found
  9092	[    1.842760] hub 2-0:1.0: 1 port detected
  9093	[    1.844367] meson-gx-mmc ffe05000.sd: Got CD GPIO
  9094	[    1.868658] Freeing unused kernel memory: 3328K
  9095	[    1.919566] Run /init as init process
  9096	[    1.919571]   with arguments:
  9097	[    1.919573]     /init
  9098	[    1.919575]   with environment:
  9099	[    1.919576]     HOME=/
  9100	[    1.919578]     TERM=linux
  9101	[    1.919580]     hdmimode=custombuilt
  9102	[    1.919581]     cvbsmode=576cvbs
  9103	[    1.919582]     max_freq_a53=1896
  9104	[    1.919584]     max_freq_a73=1800
  9105	[    1.919585]     voutmode=hdmi
  9106	[    1.919587]     modeline=1920,1080,148500,56250,50,1920,2448,2492,2640,1080,1084,1089,1125,1,1,1
  9107	[    1.919588]     disablehpd=false
  9108	[    1.919590]     cvbscable=
  9109	[    1.919591]     overscan=100
  9110	[    1.933653] mmc1: new ultra high speed SDR25 SDHC card at address b368
  9111	[    1.934456] mmcblk1: mmc1:b368 CBADS 30.0 GiB
  9112	[    1.936464]  mmcblk1: p1
  9113	[    2.060778] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found
  9114	[    2.060785] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found
  9115	[    2.060886] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock
  9116	[    2.061325] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37
  9117	[    2.061331] meson8b-dwmac ff3f0000.ethernet: 	DWMAC1000
  9118	[    2.061334] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported
  9119	[    2.061337] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported
  9120	[    2.061339] meson8b-dwmac ff3f0000.ethernet: COE Type 2
  9121	[    2.061341] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported
  9122	[    2.061343] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported
  9123	[    2.061381] meson8b-dwmac ff3f0000.ethernet: Normal descriptors
  9124	[    2.061384] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled
  9125	[    2.061386] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
  9126	[    2.061566] libphy: stmmac: probed
  9127	[    2.062746] libphy: mdio_mux: probed
  9128	[    2.089916] meson-vrtc ff8000a8.rtc: registered as rtc1
  9129	[    2.090738] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
  9130	[    2.090883] rtc-pcf8563 1-0051: registered as rtc0
  9131	[    2.092069] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
  9132	[    2.092077] rtc-pcf8563 1-0051: hctosys: unable to read the hardware clock
  9133	[    2.099899] random: fast init done
  9134	[    2.179627] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
  9135	[    2.204233] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.04
  9136	[    2.204239] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  9137	[    2.204242] usb 2-1: Product: USB3.1 Hub
  9138	[    2.204245] usb 2-1: Manufacturer: GenesysLogic
  9139	[    2.226804] hub 2-1:1.0: USB hub found
  9140	[    2.227091] hub 2-1:1.0: 4 ports detected
  9141	[    2.263959] libphy: mdio_mux: probed
  9142	[    2.327527] usb 1-1: new high-speed USB device number 2 using xhci-hcd
  9143	[    2.477801] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.04
  9144	[    2.477808] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  9145	[    2.477812] usb 1-1: Product: USB2.1 Hub
  9146	[    2.477816] usb 1-1: Manufacturer: GenesysLogic
  9147	[    2.514838] hub 1-1:1.0: USB hub found
  9148	[    2.515107] hub 1-1:1.0: 4 ports detected
  9149	[    2.707509] usb 1-2: new high-speed USB device number 3 using xhci-hcd
  9150	[    2.856572] usb 1-2: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice= 7.02
  9151	[    2.856579] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
  9152	[    2.856583] usb 1-2: Product: USB2.0 Hub
  9153	[    2.898883] hub 1-2:1.0: USB hub found
  9154	[    2.899144] hub 1-2:1.0: 4 ports detected
  9155	[    3.187507] usb 1-2.3: new high-speed USB device number 4 using xhci-hcd
  9156	[    3.203178] EXT4-fs (mmcblk1p1): mounted filesystem with writeback data mode. Opts: (null)
  9157	[    3.292662] usb 1-2.3: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice= 7.02
  9158	[    3.292671] usb 1-2.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
  9159	[    3.292675] usb 1-2.3: Product: USB2.0 Hub
  9160	[    3.346873] hub 1-2.3:1.0: USB hub found
  9161	[    3.347120] hub 1-2.3:1.0: 4 ports detected
  9162	[    3.427508] usb 1-2.4: new high-speed USB device number 5 using xhci-hcd
  9163	[    3.528085] usb 1-2.4: New USB device found, idVendor=2013, idProduct=025f, bcdDevice= 1.00
  9164	[    3.528093] usb 1-2.4: New USB device strings: Mfr=3, Product=1, SerialNumber=2
  9165	[    3.528097] usb 1-2.4: Product: PCTV 292e
  9166	[    3.528100] usb 1-2.4: Manufacturer: PCTV
  9167	[    3.528104] usb 1-2.4: SerialNumber: 0011356964
  9168	[    4.003442] systemd[1]: System time before build time, advancing clock.
  9169	[    4.018265] systemd[1]: Inserted module 'autofs4'
  9170	[    4.064719] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  9171	[    4.064934] systemd[1]: Detected architecture arm64.
  9172	[    4.089901] systemd[1]: Set hostname to <odroidn2>.
  9173	[    4.417284] random: systemd: uninitialized urandom read (16 bytes read)
  9174	[    4.420622] random: systemd: uninitialized urandom read (16 bytes read)
  9175	[    4.420858] systemd[1]: Listening on Syslog Socket.
  9176	[    4.421203] random: systemd: uninitialized urandom read (16 bytes read)
  9177	[    4.421380] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
  9178	[    4.421665] systemd[1]: Listening on udev Control Socket.
  9179	[    4.422934] systemd[1]: Created slice system-serial\x2dgetty.slice.
  9180	[    4.423362] systemd[1]: Created slice User and Session Slice.
  9181	[    4.423754] systemd[1]: Listening on Journal Audit Socket.
  9182	[    4.423842] systemd[1]: Reached target Swap.
  9183	[    4.485537] EXT4-fs (mmcblk1p1): re-mounted. Opts: commit=600,errors=remount-ro
  9184	[    5.042710] zram: Added device: zram0
  9185	[    5.043164] zram: Added device: zram1
  9186	[    5.043963] zram: Added device: zram2
  9187	[    5.050821] pwm-gpio pwmgpio: 1 gpio pwms loaded
  9188	[    5.206246] mc: Linux media interface: v0.10
  9189	[    5.255377] meson-saradc ff809000.adc: supply vref not found, using dummy regulator
  9190	[    5.294985] videodev: Linux video capture interface: v2.00
  9191	[    5.323805] meson-drm ff900000.vpu: Queued 2 outputs on vpu
  9192	[    5.339648] Registered IR keymap rc-odroid
  9193	[    5.397303] IR NEC protocol handler initialized
  9194	[    5.404965] meson-drm ff900000.vpu: CVBS Output connector not available
  9195	[    5.423649] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0
  9196	[    5.423795] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
  9197	[    5.423883] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input0
  9198	[    5.424052] meson-ir ff808000.ir: receiver initialized
  9199	[    5.426462] panfrost ffe40000.gpu: clock rate = 24000000
  9200	[    5.426519] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19
  9201	[    5.427130] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0
  9202	[    5.427137] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400
  9203	[    5.427141] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
  9204	[    5.427143] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1
  9205	[    5.443774] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
  9206	[    5.445327] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
  9207	[    5.450255] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 1
  9208	[    5.453183] zram0: detected capacity change from 0 to 1904500736
  9209	[    5.456435] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
  9210	[    5.456891] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 0
  9211	[    5.490233] em28xx 1-2.4:1.0: New device PCTV PCTV 292e @ 480 Mbps (2013:025f, interface 0, class 0)
  9212	[    5.490241] em28xx 1-2.4:1.0: DVB interface 0 found: isoc
  9213	[    5.497160] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  9214	[    5.547567] em28xx 1-2.4:1.0: chip ID is em28178
  9215	[    5.743650] Console: switching to colour frame buffer device 240x67
  9216	[    5.770222] meson-drm ff900000.vpu: [drm] fb0: mesondrmfb frame buffer device
  9217	[    5.808399] axg-sound-card sound: ASoC: no DMI vendor name!
  9218	[    6.511515] Adding 1859860k swap on /dev/zram0.  Priority:5 extents:1 across:1859860k SSFS
  9219	[    6.578256] zram1: detected capacity change from 0 to 52428800
  9220	[    7.589717] em28xx 1-2.4:1.0: EEPROM ID = 26 00 01 00, EEPROM hash = 0x8d0cfd04
  9221	[    7.589722] em28xx 1-2.4:1.0: EEPROM info:
  9222	[    7.589724] em28xx 1-2.4:1.0: 	microcode start address = 0x0004, boot configuration = 0x01
  9223	[    7.595835] em28xx 1-2.4:1.0: 	AC97 audio (5 sample rates)
  9224	[    7.595838] em28xx 1-2.4:1.0: 	500mA max power
  9225	[    7.595841] em28xx 1-2.4:1.0: 	Table at offset 0x27, strings=0x146a, 0x1888, 0x0a7e
  9226	[    7.655495] em28xx 1-2.4:1.0: Identified as PCTV tripleStick (292e) (card=94)
  9227	[    7.655499] em28xx 1-2.4:1.0: dvb set to isoc mode.
  9228	[    7.655664] usbcore: registered new interface driver em28xx
  9229	[    7.681874] em28xx 1-2.4:1.0: Binding DVB extension
  9230	[    7.695226] i2c i2c-4: Added multiplexed i2c bus 5
  9231	[    7.695233] si2168 4-0064: Silicon Labs Si2168-B40 successfully identified
  9232	[    7.695236] si2168 4-0064: firmware version: B 4.0.2
  9233	[    7.703753] si2157 5-0060: Silicon Labs Si2147/2148/2157/2158 successfully attached
  9234	[    7.703789] dvbdev: DVB: registering new adapter (1-2.4:1.0)
  9235	[    7.703795] em28xx 1-2.4:1.0: DVB: registering adapter 0 frontend 0 (Silicon Labs Si2168)...
  9236	[    7.703801] dvbdev: dvb_create_media_entity: media entity 'Silicon Labs Si2168' registered.
  9237	[    7.704466] dvbdev: dvb_create_media_entity: media entity 'dvb-demux' registered.
  9238	[    7.730694] em28xx 1-2.4:1.0: DVB extension successfully initialized
  9239	[    7.730702] em28xx: Registered (Em28xx dvb Extension) extension
  9240	[    7.737624] em28xx 1-2.4:1.0: Registering input extension
  9241	[    7.771495] Registered IR keymap rc-pinnacle-pctv-hd
  9242	[    7.771668] rc rc1: PCTV tripleStick (292e) as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-2/1-2.4/1-2.4:1.0/rc/rc1
  9243	[    7.771766] rc rc1: lirc_dev: driver em28xx registered at minor = 1, scancode receiver, no transmitter
  9244	[    7.771825] input: PCTV tripleStick (292e) as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-2/1-2.4/1-2.4:1.0/rc/rc1/input1
  9245	[    7.771911] em28xx 1-2.4:1.0: Input extension successfully initialized
  9246	[    7.771914] em28xx: Registered (Em28xx Input Extension) extension
  9247	[    8.663254] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
  9248	[    8.663274] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
  9249	[    9.704236] systemd[1]: Started Armbian memory supported logging.
  9250	[    9.708388] systemd[1]: Starting Journal Service...
  9251	[    9.774882] systemd[1]: Started Journal Service.
  9252	[    9.802823] systemd-journald[1849]: Received request to flush runtime journal from PID 1
  9253
  9254	### armbian-release:
  9255
  9256	# PLEASE DO NOT EDIT THIS FILE
  9257	BOARD=odroidn2
  9258	BOARD_NAME="Odroid N2"
  9259	BOARDFAMILY=meson-g12b
  9260	BUILD_REPOSITORY_URL=https://github.com/armbian/build
  9261	BUILD_REPOSITORY_COMMIT=5f03d652
  9262	DISTRIBUTION_CODENAME=buster
  9263	DISTRIBUTION_STATUS=supported
  9264	VERSION=21.02.1
  9265	LINUXFAMILY=meson64
  9266	BRANCH=current
  9267	ARCH=arm64
  9268	IMAGE_TYPE=stable
  9269	BOARD_TYPE=conf
  9270	INITRD_ARCH=arm64
  9271	KERNEL_IMAGE_TYPE=Image
  9272
  9273	### boot environment:
  9274
  9275	verbosity=1
  9276	console=both
  9277	overlay_prefix=meson
  9278	rootdev=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c
  9279	rootfstype=ext4
  9280	usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
  9281
  9282	### lsusb:
  9283
  9284	Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc.
  9285	Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  9286	Bus 001 Device 005: ID 2013:025f PCTV Systems
  9287	Bus 001 Device 004: ID 05e3:0608 Genesys Logic, Inc. Hub
  9288	Bus 001 Device 003: ID 05e3:0608 Genesys Logic, Inc. Hub
  9289	Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
  9290	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  9291
  9292	### lscpu:
  9293
  9294	Architecture:        aarch64
  9295	Byte Order:          Little Endian
  9296	CPU(s):              6
  9297	On-line CPU(s) list: 0-5
  9298	Thread(s) per core:  1
  9299	Core(s) per socket:  3
  9300	Socket(s):           2
  9301	NUMA node(s):        1
  9302	Vendor ID:           ARM
  9303	Model:               4
  9304	Model name:          Cortex-A53
  9305	Stepping:            r0p4
  9306	CPU max MHz:         1992.0000
  9307	CPU min MHz:         100.0000
  9308	BogoMIPS:            48.00
  9309	L1d cache:           unknown size
  9310	L1i cache:           unknown size
  9311	L2 cache:            unknown size
  9312	NUMA node0 CPU(s):   0-5
  9313	Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  9314
  9315	### cpuinfo:
  9316
  9317	processor	: 0
  9318	BogoMIPS	: 48.00
  9319	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  9320	CPU implementer	: 0x41
  9321	CPU architecture: 8
  9322	CPU variant	: 0x0
  9323	CPU part	: 0xd03
  9324	CPU revision	: 4
  9325
  9326	processor	: 1
  9327	BogoMIPS	: 48.00
  9328	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  9329	CPU implementer	: 0x41
  9330	CPU architecture: 8
  9331	CPU variant	: 0x0
  9332	CPU part	: 0xd03
  9333	CPU revision	: 4
  9334
  9335	processor	: 2
  9336	BogoMIPS	: 48.00
  9337	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  9338	CPU implementer	: 0x41
  9339	CPU architecture: 8
  9340	CPU variant	: 0x0
  9341	CPU part	: 0xd09
  9342	CPU revision	: 2
  9343
  9344	processor	: 3
  9345	BogoMIPS	: 48.00
  9346	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  9347	CPU implementer	: 0x41
  9348	CPU architecture: 8
  9349	CPU variant	: 0x0
  9350	CPU part	: 0xd09
  9351	CPU revision	: 2
  9352
  9353	processor	: 4
  9354	BogoMIPS	: 48.00
  9355	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  9356	CPU implementer	: 0x41
  9357	CPU architecture: 8
  9358	CPU variant	: 0x0
  9359	CPU part	: 0xd09
  9360	CPU revision	: 2
  9361
  9362	processor	: 5
  9363	BogoMIPS	: 48.00
  9364	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  9365	CPU implementer	: 0x41
  9366	CPU architecture: 8
  9367	CPU variant	: 0x0
  9368	CPU part	: 0xd09
  9369	CPU revision	: 2
  9370
  9371
  9372	### meminfo:
  9373
  9374	MemTotal:        3719728 kB
  9375	MemFree:         3392288 kB
  9376	MemAvailable:    3345556 kB
  9377	Buffers:           11444 kB
  9378	Cached:            43752 kB
  9379	SwapCached:            0 kB
  9380	Active:            29240 kB
  9381	Inactive:         183780 kB
  9382	Active(anon):        148 kB
  9383	Inactive(anon):   162516 kB
  9384	Active(file):      29092 kB
  9385	Inactive(file):    21264 kB
  9386	Unevictable:           0 kB
  9387	Mlocked:               0 kB
  9388	SwapTotal:       1859860 kB
  9389	SwapFree:        1859860 kB
  9390	Dirty:              4076 kB
  9391	Writeback:             0 kB
  9392	AnonPages:        157808 kB
  9393	Mapped:            12932 kB
  9394	Shmem:              4992 kB
  9395	KReclaimable:      12892 kB
  9396	Slab:              40300 kB
  9397	SReclaimable:      12892 kB
  9398	SUnreclaim:        27408 kB
  9399	KernelStack:        2544 kB
  9400	PageTables:         5732 kB
  9401	NFS_Unstable:          0 kB
  9402	Bounce:                0 kB
  9403	WritebackTmp:          0 kB
  9404	CommitLimit:     3719724 kB
  9405	Committed_AS:    4240956 kB
  9406	VmallocTotal:   135290159040 kB
  9407	VmallocUsed:       33216 kB
  9408	VmallocChunk:          0 kB
  9409	Percpu:             1368 kB
  9410	HardwareCorrupted:     0 kB
  9411	AnonHugePages:         0 kB
  9412	ShmemHugePages:        0 kB
  9413	ShmemPmdMapped:        0 kB
  9414	FileHugePages:         0 kB
  9415	FilePmdMapped:         0 kB
  9416	CmaTotal:         917504 kB
  9417	CmaFree:          901724 kB
  9418	HugePages_Total:       0
  9419	HugePages_Free:        0
  9420	HugePages_Rsvd:        0
  9421	HugePages_Surp:        0
  9422	Hugepagesize:       2048 kB
  9423	Hugetlb:               0 kB
  9424
  9425	### virtual memory:
  9426
  9427	vm.admin_reserve_kbytes = 8192
  9428	vm.block_dump = 0
  9429	vm.compaction_proactiveness = 20
  9430	vm.compact_unevictable_allowed = 1
  9431	vm.dirty_background_bytes = 0
  9432	vm.dirty_background_ratio = 10
  9433	vm.dirty_bytes = 0
  9434	vm.dirty_expire_centisecs = 3000
  9435	vm.dirty_ratio = 20
  9436	vm.dirtytime_expire_seconds = 43200
  9437	vm.dirty_writeback_centisecs = 500
  9438	vm.extfrag_threshold = 500
  9439	vm.hugetlb_shm_group = 0
  9440	vm.laptop_mode = 0
  9441	vm.legacy_va_layout = 0
  9442	vm.lowmem_reserve_ratio = 256	256	32	0
  9443	vm.max_map_count = 65530
  9444	vm.memory_failure_early_kill = 0
  9445	vm.memory_failure_recovery = 1
  9446	vm.min_free_kbytes = 45056
  9447	vm.min_slab_ratio = 5
  9448	vm.min_unmapped_ratio = 1
  9449	vm.mmap_min_addr = 4096
  9450	vm.mmap_rnd_bits = 18
  9451	vm.mmap_rnd_compat_bits = 11
  9452	vm.nr_hugepages = 0
  9453	vm.nr_hugepages_mempolicy = 0
  9454	vm.nr_overcommit_hugepages = 0
  9455	vm.numa_stat = 1
  9456	vm.numa_zonelist_order = Node
  9457	vm.oom_dump_tasks = 1
  9458	vm.oom_kill_allocating_task = 0
  9459	vm.overcommit_kbytes = 0
  9460	vm.overcommit_memory = 0
  9461	vm.overcommit_ratio = 50
  9462	vm.page-cluster = 0
  9463	vm.page_lock_unfairness = 5
  9464	vm.panic_on_oom = 0
  9465	vm.percpu_pagelist_fraction = 0
  9466	vm.stat_interval = 1
  9467	vm.swappiness = 100
  9468	vm.user_reserve_kbytes = 115017
  9469	vm.vfs_cache_pressure = 100
  9470	vm.watermark_boost_factor = 15000
  9471	vm.watermark_scale_factor = 10
  9472	vm.zone_reclaim_mode = 0
  9473
  9474	### ip addr:
  9475
  9476	1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  9477	    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  9478	    inet XXX.XXX.0.1/8 scope host lo
  9479	       valid_lft forever preferred_lft forever
  9480	    inet6 ::1/128 scope host
  9481	       valid_lft forever preferred_lft forever
  9482	2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  9483	    link/ether 00:1e:06:42:03:f8 brd ff:ff:ff:ff:ff:ff
  9484
  9485	### partitions:
  9486
  9487	major minor  #blocks  name
  9488
  9489	 179        0   31464960 mmcblk1
  9490	 179        1   31146208 mmcblk1p1
  9491	 252        0    1859864 zram0
  9492	 252        1      51200 zram1
  9493
  9494	### df:
  9495
  9496	udev            1.4G     0  1.4G   0% /dev
  9497	tmpfs           364M  4.9M  359M   2% /run
  9498	/dev/mmcblk1p1   30G  1.7G   28G   6% /
  9499	tmpfs           1.8G     0  1.8G   0% /dev/shm
  9500	tmpfs           5.0M  4.0K  5.0M   1% /run/lock
  9501	tmpfs           1.8G     0  1.8G   0% /sys/fs/cgroup
  9502	tmpfs           1.8G     0  1.8G   0% /tmp
  9503	/dev/zram1       49M  4.0M   41M   9% /var/log
  9504
  9505	### lsblk:
  9506
  9507	NAME        FSTYPE  SIZE MOUNTPOINT UUID
  9508	mmcblk1              30G
  9509	└─mmcblk1p1 ext4   29.7G /          bd34953d-41be-49d6-b1c0-c0c28a5e239c
  9510	zram1                50M /var/log
  9511
  9512	### zramctl:
  9513
  9514	NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
  9515	/dev/zram1 zstd           50M  132K  698B   36K       6 /var/log
  9516	/dev/zram0 lzo-rle       1.8G    4K   74B   12K       6 [SWAP]
  9517
  9518	### mtab:
  9519
  9520	/dev/mmcblk1p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  9521	/dev/mmcblk1p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  9522	/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
  9523
  9524	### mmc1:b368 info:
  9525
  9526	               fwrev: 0x0
  9527	              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=CBADS MODALIAS=mmc:block
  9528	                 cid: 6f0303434241445310aa002b4d013b00
  9529	                 rca: 0xb368
  9530	                 csd: 400e005a5b590000f00e7f800a404000
  9531	              manfid: 0x00006f
  9532	                 ocr: 0x00200000
  9533	preferred_erase_size: 2097152
  9534	                type: SD
  9535	               hwrev: 0x1
  9536	                date: 11/2019
  9537	                 dsr: 0x404
  9538	          erase_size: 512
  9539	               oemid: 0x0303
  9540	              serial: 0xaa002b4d
  9541	                 ssr: 00000000000000280402800100fd180a001e00000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  9542	                 scr: 02b5800300000000
  9543	                name: CBADS
  9544
  9545	### Boot system health:
  9546
  9547	Time       big.LITTLE   load %cpu %sys %usr %nice %io %irq   CPU  C.St.
  9548	15:49:20: 1908/1992MHz  2.67  25%  11%   5%   0%   7%   0% 32.9°C  0/11
  9549	15:49:21: 1908/ 250MHz  2.67  64%  16%   1%   0%  44%   1% 31.1°C  0/11
  9550	15:49:21: 1908/1992MHz  2.67  51%  10%   4%   0%  34%   1% 31.2°C  0/11
  9551	15:49:21: 1908/1992MHz  2.67  58%   5%   5%   1%  45%   1% 30.6°C  0/11
  9552	15:49:22: 1908/1992MHz  2.67  61%   4%   5%   0%  50%   1% 30.9°C  0/11
  9553
  9554	### Activated 1 lzo-rle zram swap devices with 1816 MB each
  9555
  9556	### Activated Armbian ramlog partition with zstd compression
  9557
  9558	Sun 14 Feb 2021 04:00:43 PM GMT | Odroid N2 | 21.02.1 | arm64 | aarch64 | 5.10.12-meson64
  9559
  9560	### dmesg:
  9561
  9562	[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
  9563	[    0.000000] Linux version 5.10.12-meson64 (root@beast) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #21.02.1 SMP PREEMPT Wed Feb 3 21:06:36 CET 2021
  9564	[    0.000000] Machine model: Hardkernel ODROID-N2
  9565	[    0.000000] efi: UEFI not found.
  9566	[    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
  9567	[    0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB
  9568	[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
  9569	[    0.000000] NUMA: No NUMA configuration found
  9570	[    0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ed7fffff]
  9571	[    0.000000] NUMA: NODE_DATA [mem 0xb502f100-0xb5030fff]
  9572	[    0.000000] Zone ranges:
  9573	[    0.000000]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
  9574	[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000ed7fffff]
  9575	[    0.000000]   Normal   empty
  9576	[    0.000000] Movable zone start for each node
  9577	[    0.000000] Early memory node ranges
  9578	[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000004ffffff]
  9579	[    0.000000]   node   0: [mem 0x0000000005300000-0x00000000ed7fffff]
  9580	[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ed7fffff]
  9581	[    0.000000] On node 0 totalpages: 972032
  9582	[    0.000000]   DMA zone: 4096 pages used for memmap
  9583	[    0.000000]   DMA zone: 0 pages reserved
  9584	[    0.000000]   DMA zone: 261376 pages, LIFO batch:63
  9585	[    0.000000]   DMA32 zone: 11104 pages used for memmap
  9586	[    0.000000]   DMA32 zone: 710656 pages, LIFO batch:63
  9587	[    0.000000] psci: probing for conduit method from DT.
  9588	[    0.000000] psci: PSCIv1.0 detected in firmware.
  9589	[    0.000000] psci: Using standard PSCI v0.2 function IDs
  9590	[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
  9591	[    0.000000] psci: SMC Calling Convention v1.1
  9592	[    0.000000] percpu: Embedded 23 pages/cpu s56728 r8192 d29288 u94208
  9593	[    0.000000] pcpu-alloc: s56728 r8192 d29288 u94208 alloc=23*4096
  9594	[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
  9595	[    0.000000] Detected VIPT I-cache on CPU0
  9596	[    0.000000] CPU features: detected: ARM erratum 845719
  9597	[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 956832
  9598	[    0.000000] Policy zone: DMA32
  9599	[    0.000000] Kernel command line: root=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c rootwait rootfstype=ext4 console=ttyAML0,115200n8 console=tty1 loglevel=1  no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=custombuilt cvbsmode=576cvbs max_freq_a53=1896 max_freq_a73=1800 maxcpus=6 voutmode=hdmi modeline=1920,1080,148500,56250,50,1920,2448,2492,2640,1080,1084,1089,1125,1,1,1 disablehpd=false  cvbscable= overscan=100 consoleblank=0
  9600	[    0.000000] Kernel parameter elevator= does not have any effect anymore.
  9601	               Please use sysfs to set IO scheduler for individual devices.
  9602	[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
  9603	[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
  9604	[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
  9605	[    0.000000] software IO TLB: mapped [mem 0x0000000038ac5000-0x000000003cac5000] (64MB)
  9606	[    0.000000] Memory: 2785352K/3888128K available (14144K kernel code, 1760K rwdata, 5508K rodata, 3328K init, 592K bss, 185272K reserved, 917504K cma-reserved)
  9607	[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
  9608	[    0.000000] rcu: Preemptible hierarchical RCU implementation.
  9609	[    0.000000] rcu: 	RCU event tracing is enabled.
  9610	[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
  9611	[    0.000000] 	Trampoline variant of Tasks RCU enabled.
  9612	[    0.000000] 	Rude variant of Tasks RCU enabled.
  9613	[    0.000000] 	Tracing variant of Tasks RCU enabled.
  9614	[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  9615	[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
  9616	[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
  9617	[    0.000000] GIC: Using split EOI/Deactivate mode
  9618	[    0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized
  9619	[    0.000000] random: get_random_bytes called from start_kernel+0x378/0x538 with crng_init=0
  9620	[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
  9621	[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  9622	[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  9623	[    0.000241] Console: colour dummy device 80x25
  9624	[    0.000275] printk: console [tty1] enabled
  9625	[    0.000364] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
  9626	[    0.000376] pid_max: default: 32768 minimum: 301
  9627	[    0.000461] LSM: Security Framework initializing
  9628	[    0.000487] Yama: becoming mindful.
  9629	[    0.000578] AppArmor: AppArmor initialized
  9630	[    0.000629] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
  9631	[    0.000647] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
  9632	[    0.002644] rcu: Hierarchical SRCU implementation.
  9633	[    0.005001] EFI services will not be available.
  9634	[    0.005425] smp: Bringing up secondary CPUs ...
  9635	[    0.006093] Detected VIPT I-cache on CPU1
  9636	[    0.006155] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
  9637	[    0.007348] CPU features: detected: ARM erratum 858921
  9638	[    0.007356] CPU features: detected: Spectre-v2
  9639	[    0.007360] CPU features: detected: Spectre-v4
  9640	[    0.007367] Detected VIPT I-cache on CPU2
  9641	[    0.007393] arch_timer: Enabling local workaround for ARM erratum 858921
  9642	[    0.007407] arch_timer: CPU2: Trapping CNTVCT access
  9643	[    0.007420] CPU2: Booted secondary processor 0x0000000100 [0x410fd092]
  9644	[    0.008127] Detected VIPT I-cache on CPU3
  9645	[    0.008143] arch_timer: Enabling local workaround for ARM erratum 858921
  9646	[    0.008151] arch_timer: CPU3: Trapping CNTVCT access
  9647	[    0.008159] CPU3: Booted secondary processor 0x0000000101 [0x410fd092]
  9648	[    0.008782] Detected VIPT I-cache on CPU4
  9649	[    0.008799] arch_timer: Enabling local workaround for ARM erratum 858921
  9650	[    0.008805] arch_timer: CPU4: Trapping CNTVCT access
  9651	[    0.008814] CPU4: Booted secondary processor 0x0000000102 [0x410fd092]
  9652	[    0.009426] Detected VIPT I-cache on CPU5
  9653	[    0.009443] arch_timer: Enabling local workaround for ARM erratum 858921
  9654	[    0.009449] arch_timer: CPU5: Trapping CNTVCT access
  9655	[    0.009457] CPU5: Booted secondary processor 0x0000000103 [0x410fd092]
  9656	[    0.009536] smp: Brought up 1 node, 6 CPUs
  9657	[    0.009554] SMP: Total of 6 processors activated.
  9658	[    0.009561] CPU features: detected: 32-bit EL0 Support
  9659	[    0.009567] CPU features: detected: CRC32 instructions
  9660	[    0.009573] CPU features: detected: 32-bit EL1 Support
  9661	[    0.020782] CPU: All CPU(s) started at EL2
  9662	[    0.020832] alternatives: patching kernel code
  9663	[    0.022768] devtmpfs: initialized
  9664	[    0.030429] Registered cp15_barrier emulation handler
  9665	[    0.030443] Registered setend emulation handler
  9666	[    0.030578] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  9667	[    0.030617] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
  9668	[    0.044519] pinctrl core: initialized pinctrl subsystem
  9669	[    0.045246] DMI not present or invalid.
  9670	[    0.045623] NET: Registered protocol family 16
  9671	[    0.047164] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
  9672	[    0.047436] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
  9673	[    0.047662] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
  9674	[    0.047702] audit: initializing netlink subsys (disabled)
  9675	[    0.047816] audit: type=2000 audit(0.044:1): state=initialized audit_enabled=0 res=1
  9676	[    0.049120] thermal_sys: Registered thermal governor 'fair_share'
  9677	[    0.049127] thermal_sys: Registered thermal governor 'bang_bang'
  9678	[    0.049131] thermal_sys: Registered thermal governor 'step_wise'
  9679	[    0.049134] thermal_sys: Registered thermal governor 'user_space'
  9680	[    0.049550] cpuidle: using governor menu
  9681	[    0.049899] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  9682	[    0.050022] ASID allocator initialised with 65536 entries
  9683	[    0.050937] Serial: AMBA PL011 UART driver
  9684	[    0.086708] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
  9685	[    0.086717] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
  9686	[    0.086722] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
  9687	[    0.086726] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
  9688	[    0.088126] cryptd: max_cpu_qlen set to 1000
  9689	[    0.156149] raid6: neonx8   gen()  2783 MB/s
  9690	[    0.224213] raid6: neonx8   xor()  2042 MB/s
  9691	[    0.292281] raid6: neonx4   gen()  2999 MB/s
  9692	[    0.360345] raid6: neonx4   xor()  2346 MB/s
  9693	[    0.428416] raid6: neonx2   gen()  2580 MB/s
  9694	[    0.496481] raid6: neonx2   xor()  2131 MB/s
  9695	[    0.564549] raid6: neonx1   gen()  2017 MB/s
  9696	[    0.632614] raid6: neonx1   xor()  1718 MB/s
  9697	[    0.700688] raid6: int64x8  gen()  1377 MB/s
  9698	[    0.768752] raid6: int64x8  xor()   735 MB/s
  9699	[    0.836843] raid6: int64x4  gen()  1463 MB/s
  9700	[    0.904890] raid6: int64x4  xor()   733 MB/s
  9701	[    0.972945] raid6: int64x2  gen()  1362 MB/s
  9702	[    1.041022] raid6: int64x2  xor()   619 MB/s
  9703	[    1.109090] raid6: int64x1  gen()  1120 MB/s
  9704	[    1.177142] raid6: int64x1  xor()   462 MB/s
  9705	[    1.177146] raid6: using algorithm neonx4 gen() 2999 MB/s
  9706	[    1.177149] raid6: .... xor() 2346 MB/s, rmw enabled
  9707	[    1.177153] raid6: using neon recovery algorithm
  9708	[    1.177591] ACPI: Interpreter disabled.
  9709	[    1.178371] 5V: supplied by 12V
  9710	[    1.179274] VDDAO_3V3: supplied by 12V
  9711	[    1.179726] iommu: Default domain type: Translated
  9712	[    1.179852] vgaarb: loaded
  9713	[    1.180790] SCSI subsystem initialized
  9714	[    1.181056] usbcore: registered new interface driver usbfs
  9715	[    1.181112] usbcore: registered new interface driver hub
  9716	[    1.181148] usbcore: registered new device driver usb
  9717	[    1.181449] pps_core: LinuxPPS API ver. 1 registered
  9718	[    1.181455] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  9719	[    1.181526] PTP clock support registered
  9720	[    1.181708] EDAC MC: Ver: 3.0.0
  9721	[    1.182998] NetLabel: Initializing
  9722	[    1.183005] NetLabel:  domain hash size = 128
  9723	[    1.183008] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
  9724	[    1.183049] NetLabel:  unlabeled traffic allowed by default
  9725	[    1.183512] clocksource: Switched to clocksource arch_sys_counter
  9726	[    1.183734] VFS: Disk quotas dquot_6.6.0
  9727	[    1.183779] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  9728	[    1.184128] AppArmor: AppArmor Filesystem Enabled
  9729	[    1.184173] pnp: PnP ACPI: disabled
  9730	[    1.189825] NET: Registered protocol family 2
  9731	[    1.190281] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
  9732	[    1.190385] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
  9733	[    1.190642] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
  9734	[    1.190829] TCP: Hash tables configured (established 32768 bind 32768)
  9735	[    1.190985] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
  9736	[    1.191052] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
  9737	[    1.191098] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
  9738	[    1.191241] NET: Registered protocol family 1
  9739	[    1.191261] PCI: CLS 0 bytes, default 64
  9740	[    1.191381] Trying to unpack rootfs image as initramfs...
  9741	[    1.727304] Freeing initrd memory: 13544K
  9742	[    1.728203] kvm [1]: IPA Size Limit: 40 bits
  9743	[    1.728911] kvm [1]: vgic interrupt IRQ9
  9744	[    1.729044] kvm [1]: Hyp mode initialized successfully
  9745	[    1.734118] Initialise system trusted keyrings
  9746	[    1.734153] Key type blacklist registered
  9747	[    1.734295] workingset: timestamp_bits=44 max_order=20 bucket_order=0
  9748	[    1.737506] zbud: loaded
  9749	[    1.738490] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  9750	[    1.738979] fuse: init (API version 7.32)
  9751	[    1.739780] integrity: Platform Keyring initialized
  9752	[    1.767818] xor: measuring software checksum speed
  9753	[    1.770656]    8regs           :  3473 MB/sec
  9754	[    1.773118]    32regs          :  4020 MB/sec
  9755	[    1.775774]    arm64_neon      :  3719 MB/sec
  9756	[    1.775778] xor: using function: 32regs (4020 MB/sec)
  9757	[    1.775784] Key type asymmetric registered
  9758	[    1.775789] Asymmetric key parser 'x509' registered
  9759	[    1.775823] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
  9760	[    1.775929] io scheduler mq-deadline registered
  9761	[    1.775935] io scheduler kyber registered
  9762	[    1.776017] io scheduler bfq registered
  9763	[    1.778474] gpio-447 (usb-hub-reset): hogged as output/high
  9764	[    1.781388] EINJ: ACPI disabled.
  9765	[    1.787579] soc soc0: Amlogic Meson G12B (S922X) Revision 29:a (40:2) Detected
  9766	[    1.788966] VCC_3V3: supplied by VDDAO_3V3
  9767	[    1.789019] FLASH_1V8: supplied by VCC_3V3
  9768	[    1.789050] VCC_1V8: supplied by VCC_3V3
  9769	[    1.789076] VDDAO_1V8: supplied by VDDAO_3V3
  9770	[    1.789104] VDDCPU_A: supplied by regulator-dummy
  9771	[    1.789472] VDDCPU_B: supplied by regulator-dummy
  9772	[    1.790164] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
  9773	[    1.792468] Serial: AMBA driver
  9774	[    1.792754] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart
  9775	[    1.792849] printk: console [ttyAML0] enabled
  9776	[    1.793367] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 33, base_baud = 1500000) is a meson_uart
  9777	[    1.798671] loop: module loaded
  9778	[    1.800452] libphy: Fixed MDIO Bus: probed
  9779	[    1.801383] tun: Universal TUN/TAP device driver, 1.6
  9780	[    1.801980] thunder_xcv, ver 1.0
  9781	[    1.802010] thunder_bgx, ver 1.0
  9782	[    1.802036] nicpf, ver 1.0
  9783	[    1.802452] e1000e: Intel(R) PRO/1000 Network Driver
  9784	[    1.802455] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
  9785	[    1.802488] igb: Intel(R) Gigabit Ethernet Network Driver
  9786	[    1.802492] igb: Copyright (c) 2007-2014 Intel Corporation.
  9787	[    1.802521] igbvf: Intel(R) Gigabit Virtual Function Network Driver
  9788	[    1.802524] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
  9789	[    1.802640] sky2: driver version 1.30
  9790	[    1.802988] VFIO - User Level meta-driver version: 0.3
  9791	[    1.804372] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  9792	[    1.804389] ehci-pci: EHCI PCI platform driver
  9793	[    1.804418] ehci-platform: EHCI generic platform driver
  9794	[    1.804536] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  9795	[    1.804546] ohci-pci: OHCI PCI platform driver
  9796	[    1.804581] ohci-platform: OHCI generic platform driver
  9797	[    1.804950] usbcore: registered new interface driver usb-storage
  9798	[    1.806123] mousedev: PS/2 mouse device common for all mice
  9799	[    1.806451] i2c /dev entries driver
  9800	[    1.812170] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17
  9801	[    1.812868] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz
  9802	[    1.813561] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-1 failed:-17
  9803	[    1.814155] sdhci: Secure Digital Host Controller Interface driver
  9804	[    1.814160] sdhci: Copyright(c) Pierre Ossman
  9805	[    1.814261] Synopsys Designware Multimedia Card Interface Driver
  9806	[    1.814683] sdhci-pltfm: SDHCI platform and OF driver helper
  9807	[    1.815117] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq
  9808	[    1.816325] ledtrig-cpu: registered to indicate activity on CPUs
  9809	[    1.816597] meson-sm: secure-monitor enabled
  9810	[    1.816768] hid: raw HID events driver (C) Jiri Kosina
  9811	[    1.816853] usbcore: registered new interface driver usbhid
  9812	[    1.816856] usbhid: USB HID core driver
  9813	[    1.817820] NET: Registered protocol family 10
  9814	[    1.818282] Segment Routing with IPv6
  9815	[    1.818312] NET: Registered protocol family 17
  9816	[    1.818369] 8021q: 802.1Q VLAN Support v1.8
  9817	[    1.818392] Key type dns_resolver registered
  9818	[    1.818667] registered taskstats version 1
  9819	[    1.818672] Loading compiled-in X.509 certificates
  9820	[    1.820395] Loaded X.509 cert 'Build time autogenerated kernel key: f47c178852ca39740c3546b008122b65f5ed9bce'
  9821	[    1.822013] zswap: loaded using pool zstd/z3fold
  9822	[    1.822204] Key type ._fscrypt registered
  9823	[    1.822206] Key type .fscrypt registered
  9824	[    1.822208] Key type fscrypt-provisioning registered
  9825	[    1.823297] Btrfs loaded, crc32c=crc32c-generic
  9826	[    1.829497] Key type encrypted registered
  9827	[    1.829509] AppArmor: AppArmor sha1 policy hashing enabled
  9828	[    1.835832] HUB_5V: supplied by 5V
  9829	[    1.836040] USB_PWR_EN: supplied by 5V
  9830	[    1.837662] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2
  9831	[    1.837669] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1
  9832	[    1.840386] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator
  9833	[    1.840442] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator
  9834	[    1.840545] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM
  9835	[    1.841131] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  9836	[    1.841141] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
  9837	[    1.841305] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010
  9838	[    1.841324] xhci-hcd xhci-hcd.0.auto: irq 41, io mem 0xff500000
  9839	[    1.841446] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
  9840	[    1.841450] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  9841	[    1.841453] usb usb1: Product: xHCI Host Controller
  9842	[    1.841455] usb usb1: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
  9843	[    1.841458] usb usb1: SerialNumber: xhci-hcd.0.auto
  9844	[    1.841646] hub 1-0:1.0: USB hub found
  9845	[    1.841659] hub 1-0:1.0: 2 ports detected
  9846	[    1.841794] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  9847	[    1.841801] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  9848	[    1.841806] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  9849	[    1.841826] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
  9850	[    1.841859] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
  9851	[    1.841862] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  9852	[    1.841865] usb usb2: Product: xHCI Host Controller
  9853	[    1.841867] usb usb2: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
  9854	[    1.841869] usb usb2: SerialNumber: xhci-hcd.0.auto
  9855	[    1.842017] hub 2-0:1.0: USB hub found
  9856	[    1.842028] hub 2-0:1.0: 1 port detected
  9857	[    1.843563] meson-gx-mmc ffe05000.sd: Got CD GPIO
  9858	[    1.868599] Freeing unused kernel memory: 3328K
  9859	[    1.899564] Run /init as init process
  9860	[    1.899568]   with arguments:
  9861	[    1.899570]     /init
  9862	[    1.899572]   with environment:
  9863	[    1.899574]     HOME=/
  9864	[    1.899575]     TERM=linux
  9865	[    1.899577]     hdmimode=custombuilt
  9866	[    1.899578]     cvbsmode=576cvbs
  9867	[    1.899579]     max_freq_a53=1896
  9868	[    1.899581]     max_freq_a73=1800
  9869	[    1.899582]     voutmode=hdmi
  9870	[    1.899584]     modeline=1920,1080,148500,56250,50,1920,2448,2492,2640,1080,1084,1089,1125,1,1,1
  9871	[    1.899586]     disablehpd=false
  9872	[    1.899587]     cvbscable=
  9873	[    1.899589]     overscan=100
  9874	[    1.920535] mmc0: new high speed SDHC card at address b368
  9875	[    1.921372] mmcblk0: mmc0:b368 CBADS 30.0 GiB
  9876	[    1.923273]  mmcblk0: p1
  9877	[    2.047404] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found
  9878	[    2.047410] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found
  9879	[    2.047494] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock
  9880	[    2.048014] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37
  9881	[    2.048020] meson8b-dwmac ff3f0000.ethernet: 	DWMAC1000
  9882	[    2.048024] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported
  9883	[    2.048026] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported
  9884	[    2.048029] meson8b-dwmac ff3f0000.ethernet: COE Type 2
  9885	[    2.048031] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported
  9886	[    2.048033] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported
  9887	[    2.048080] meson8b-dwmac ff3f0000.ethernet: Normal descriptors
  9888	[    2.048083] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled
  9889	[    2.048086] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
  9890	[    2.048274] libphy: stmmac: probed
  9891	[    2.052323] libphy: mdio_mux: probed
  9892	[    2.066234] meson-vrtc ff8000a8.rtc: registered as rtc1
  9893	[    2.083534] rtc-pcf8563 1-0051: registered as rtc0
  9894	[    2.083544] random: fast init done
  9895	[    2.085364] rtc-pcf8563 1-0051: setting system clock to 2021-02-14T16:00:35 UTC (1613318435)
  9896	[    2.179639] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
  9897	[    2.204249] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.04
  9898	[    2.204256] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  9899	[    2.204259] usb 2-1: Product: USB3.1 Hub
  9900	[    2.204261] usb 2-1: Manufacturer: GenesysLogic
  9901	[    2.226019] hub 2-1:1.0: USB hub found
  9902	[    2.226302] hub 2-1:1.0: 4 ports detected
  9903	[    2.255979] libphy: mdio_mux: probed
  9904	[    2.327517] usb 1-1: new high-speed USB device number 2 using xhci-hcd
  9905	[    2.477800] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.04
  9906	[    2.477804] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  9907	[    2.477807] usb 1-1: Product: USB2.1 Hub
  9908	[    2.477809] usb 1-1: Manufacturer: GenesysLogic
  9909	[    2.514018] hub 1-1:1.0: USB hub found
  9910	[    2.514256] hub 1-1:1.0: 4 ports detected
  9911	[    2.703508] usb 1-2: new high-speed USB device number 3 using xhci-hcd
  9912	[    2.852536] usb 1-2: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice= 7.02
  9913	[    2.852540] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
  9914	[    2.852542] usb 1-2: Product: USB2.0 Hub
  9915	[    2.898054] hub 1-2:1.0: USB hub found
  9916	[    2.898290] hub 1-2:1.0: 4 ports detected
  9917	[    3.142023] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
  9918	[    3.191560] usb 1-2.3: new high-speed USB device number 4 using xhci-hcd
  9919	[    3.296615] usb 1-2.3: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice= 7.02
  9920	[    3.296621] usb 1-2.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
  9921	[    3.296625] usb 1-2.3: Product: USB2.0 Hub
  9922	[    3.346111] hub 1-2.3:1.0: USB hub found
  9923	[    3.346349] hub 1-2.3:1.0: 4 ports detected
  9924	[    3.427516] usb 1-2.4: new high-speed USB device number 5 using xhci-hcd
  9925	[    3.527987] usb 1-2.4: New USB device found, idVendor=2013, idProduct=025f, bcdDevice= 1.00
  9926	[    3.527994] usb 1-2.4: New USB device strings: Mfr=3, Product=1, SerialNumber=2
  9927	[    3.527996] usb 1-2.4: Product: PCTV 292e
  9928	[    3.527999] usb 1-2.4: Manufacturer: PCTV
  9929	[    3.528001] usb 1-2.4: SerialNumber: 0011356964
  9930	[    3.952277] systemd[1]: Inserted module 'autofs4'
  9931	[    3.998798] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  9932	[    3.999011] systemd[1]: Detected architecture arm64.
  9933	[    4.025845] systemd[1]: Set hostname to <odroidn2>.
  9934	[    4.354856] random: systemd: uninitialized urandom read (16 bytes read)
  9935	[    4.358145] random: systemd: uninitialized urandom read (16 bytes read)
  9936	[    4.358448] systemd[1]: Listening on Journal Socket (/dev/log).
  9937	[    4.358643] random: systemd: uninitialized urandom read (16 bytes read)
  9938	[    4.358782] systemd[1]: Listening on fsck to fsckd communication Socket.
  9939	[    4.358869] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
  9940	[    4.359108] systemd[1]: Listening on Journal Audit Socket.
  9941	[    4.360430] systemd[1]: Created slice system-getty.slice.
  9942	[    4.360706] systemd[1]: Listening on udev Kernel Socket.
  9943	[    4.360795] systemd[1]: Reached target Remote File Systems.
  9944	[    4.441033] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
  9945	[    4.992888] zram: Added device: zram0
  9946	[    4.993044] zram: Added device: zram1
  9947	[    4.993196] zram: Added device: zram2
  9948	[    4.993533] pwm-gpio pwmgpio: 1 gpio pwms loaded
  9949	[    5.120423] mc: Linux media interface: v0.10
  9950	[    5.157569] meson-saradc ff809000.adc: supply vref not found, using dummy regulator
  9951	[    5.173444] videodev: Linux video capture interface: v2.00
  9952	[    5.255682] Registered IR keymap rc-odroid
  9953	[    5.279921] IR NEC protocol handler initialized
  9954	[    5.308353] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0
  9955	[    5.308627] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
  9956	[    5.308750] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input0
  9957	[    5.309046] meson-ir ff808000.ir: receiver initialized
  9958	[    5.316451] meson-drm ff900000.vpu: Queued 2 outputs on vpu
  9959	[    5.332468] panfrost ffe40000.gpu: clock rate = 24000000
  9960	[    5.332520] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19
  9961	[    5.339054] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0
  9962	[    5.339064] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400
  9963	[    5.339070] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
  9964	[    5.339074] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1
  9965	[    5.353931] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 0
  9966	[    5.355290] meson-drm ff900000.vpu: CVBS Output connector not available
  9967	[    5.382954] zram0: detected capacity change from 0 to 1904500736
  9968	[    5.386352] em28xx 1-2.4:1.0: New device PCTV PCTV 292e @ 480 Mbps (2013:025f, interface 0, class 0)
  9969	[    5.386361] em28xx 1-2.4:1.0: DVB interface 0 found: isoc
  9970	[    5.389417] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
  9971	[    5.390301] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
  9972	[    5.401865] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  9973	[    5.403533] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
  9974	[    5.403849] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 1
  9975	[    5.443607] em28xx 1-2.4:1.0: chip ID is em28178
  9976	[    5.687672] Console: switching to colour frame buffer device 240x67
  9977	[    5.714184] meson-drm ff900000.vpu: [drm] fb0: mesondrmfb frame buffer device
  9978	[    5.750725] axg-sound-card sound: ASoC: no DMI vendor name!
  9979	[    6.423521] Adding 1859860k swap on /dev/zram0.  Priority:5 extents:1 across:1859860k SSFS
  9980	[    6.487630] zram1: detected capacity change from 0 to 52428800
  9981	[    7.493702] em28xx 1-2.4:1.0: EEPROM ID = 26 00 01 00, EEPROM hash = 0x8d0cfd04
  9982	[    7.493705] em28xx 1-2.4:1.0: EEPROM info:
  9983	[    7.493708] em28xx 1-2.4:1.0: 	microcode start address = 0x0004, boot configuration = 0x01
  9984	[    7.499818] em28xx 1-2.4:1.0: 	AC97 audio (5 sample rates)
  9985	[    7.499821] em28xx 1-2.4:1.0: 	500mA max power
  9986	[    7.499824] em28xx 1-2.4:1.0: 	Table at offset 0x27, strings=0x146a, 0x1888, 0x0a7e
  9987	[    7.559508] em28xx 1-2.4:1.0: Identified as PCTV tripleStick (292e) (card=94)
  9988	[    7.559514] em28xx 1-2.4:1.0: dvb set to isoc mode.
  9989	[    7.559633] usbcore: registered new interface driver em28xx
  9990	[    7.585941] em28xx 1-2.4:1.0: Binding DVB extension
  9991	[    7.599234] i2c i2c-4: Added multiplexed i2c bus 5
  9992	[    7.599243] si2168 4-0064: Silicon Labs Si2168-B40 successfully identified
  9993	[    7.599246] si2168 4-0064: firmware version: B 4.0.2
  9994	[    7.607608] si2157 5-0060: Silicon Labs Si2147/2148/2157/2158 successfully attached
  9995	[    7.607648] dvbdev: DVB: registering new adapter (1-2.4:1.0)
  9996	[    7.607654] em28xx 1-2.4:1.0: DVB: registering adapter 0 frontend 0 (Silicon Labs Si2168)...
  9997	[    7.607660] dvbdev: dvb_create_media_entity: media entity 'Silicon Labs Si2168' registered.
  9998	[    7.608316] dvbdev: dvb_create_media_entity: media entity 'dvb-demux' registered.
  9999	[    7.633965] em28xx 1-2.4:1.0: DVB extension successfully initialized
 10000	[    7.633973] em28xx: Registered (Em28xx dvb Extension) extension
 10001	[    7.641015] em28xx 1-2.4:1.0: Registering input extension
 10002	[    7.671508] Registered IR keymap rc-pinnacle-pctv-hd
 10003	[    7.671687] rc rc1: PCTV tripleStick (292e) as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-2/1-2.4/1-2.4:1.0/rc/rc1
 10004	[    7.671760] rc rc1: lirc_dev: driver em28xx registered at minor = 1, scancode receiver, no transmitter
 10005	[    7.671820] input: PCTV tripleStick (292e) as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-2/1-2.4/1-2.4:1.0/rc/rc1/input1
 10006	[    7.671896] em28xx 1-2.4:1.0: Input extension successfully initialized
 10007	[    7.671899] em28xx: Registered (Em28xx Input Extension) extension
 10008	[    8.573726] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
 10009	[    8.573746] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
 10010	[    9.622524] systemd[1]: Started Armbian memory supported logging.
 10011	[    9.626661] systemd[1]: Starting Journal Service...
 10012	[    9.692546] systemd[1]: Started Journal Service.
 10013	[    9.720161] systemd-journald[1847]: Received request to flush runtime journal from PID 1
 10014
 10015	### armbian-release:
 10016
 10017	# PLEASE DO NOT EDIT THIS FILE
 10018	BOARD=odroidn2
 10019	BOARD_NAME="Odroid N2"
 10020	BOARDFAMILY=meson-g12b
 10021	BUILD_REPOSITORY_URL=https://github.com/armbian/build
 10022	BUILD_REPOSITORY_COMMIT=5f03d652
 10023	DISTRIBUTION_CODENAME=buster
 10024	DISTRIBUTION_STATUS=supported
 10025	VERSION=21.02.1
 10026	LINUXFAMILY=meson64
 10027	BRANCH=current
 10028	ARCH=arm64
 10029	IMAGE_TYPE=stable
 10030	BOARD_TYPE=conf
 10031	INITRD_ARCH=arm64
 10032	KERNEL_IMAGE_TYPE=Image
 10033
 10034	### boot environment:
 10035
 10036	verbosity=1
 10037	console=both
 10038	overlay_prefix=meson
 10039	rootdev=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c
 10040	rootfstype=ext4
 10041	usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
 10042
 10043	### lsusb:
 10044
 10045	Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc.
 10046	Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
 10047	Bus 001 Device 005: ID 2013:025f PCTV Systems
 10048	Bus 001 Device 004: ID 05e3:0608 Genesys Logic, Inc. Hub
 10049	Bus 001 Device 003: ID 05e3:0608 Genesys Logic, Inc. Hub
 10050	Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
 10051	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
 10052
 10053	### lscpu:
 10054
 10055	Architecture:        aarch64
 10056	Byte Order:          Little Endian
 10057	CPU(s):              6
 10058	On-line CPU(s) list: 0-5
 10059	Thread(s) per core:  1
 10060	Core(s) per socket:  3
 10061	Socket(s):           2
 10062	NUMA node(s):        1
 10063	Vendor ID:           ARM
 10064	Model:               4
 10065	Model name:          Cortex-A53
 10066	Stepping:            r0p4
 10067	CPU max MHz:         1992.0000
 10068	CPU min MHz:         100.0000
 10069	BogoMIPS:            48.00
 10070	L1d cache:           unknown size
 10071	L1i cache:           unknown size
 10072	L2 cache:            unknown size
 10073	NUMA node0 CPU(s):   0-5
 10074	Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 10075
 10076	### cpuinfo:
 10077
 10078	processor	: 0
 10079	BogoMIPS	: 48.00
 10080	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 10081	CPU implementer	: 0x41
 10082	CPU architecture: 8
 10083	CPU variant	: 0x0
 10084	CPU part	: 0xd03
 10085	CPU revision	: 4
 10086
 10087	processor	: 1
 10088	BogoMIPS	: 48.00
 10089	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 10090	CPU implementer	: 0x41
 10091	CPU architecture: 8
 10092	CPU variant	: 0x0
 10093	CPU part	: 0xd03
 10094	CPU revision	: 4
 10095
 10096	processor	: 2
 10097	BogoMIPS	: 48.00
 10098	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 10099	CPU implementer	: 0x41
 10100	CPU architecture: 8
 10101	CPU variant	: 0x0
 10102	CPU part	: 0xd09
 10103	CPU revision	: 2
 10104
 10105	processor	: 3
 10106	BogoMIPS	: 48.00
 10107	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 10108	CPU implementer	: 0x41
 10109	CPU architecture: 8
 10110	CPU variant	: 0x0
 10111	CPU part	: 0xd09
 10112	CPU revision	: 2
 10113
 10114	processor	: 4
 10115	BogoMIPS	: 48.00
 10116	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 10117	CPU implementer	: 0x41
 10118	CPU architecture: 8
 10119	CPU variant	: 0x0
 10120	CPU part	: 0xd09
 10121	CPU revision	: 2
 10122
 10123	processor	: 5
 10124	BogoMIPS	: 48.00
 10125	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 10126	CPU implementer	: 0x41
 10127	CPU architecture: 8
 10128	CPU variant	: 0x0
 10129	CPU part	: 0xd09
 10130	CPU revision	: 2
 10131
 10132
 10133	### meminfo:
 10134
 10135	MemTotal:        3719728 kB
 10136	MemFree:         3401444 kB
 10137	MemAvailable:    3354928 kB
 10138	Buffers:           11444 kB
 10139	Cached:            44188 kB
 10140	SwapCached:            0 kB
 10141	Active:            29104 kB
 10142	Inactive:         176912 kB
 10143	Active(anon):        152 kB
 10144	Inactive(anon):   155400 kB
 10145	Active(file):      28952 kB
 10146	Inactive(file):    21512 kB
 10147	Unevictable:           0 kB
 10148	Mlocked:               0 kB
 10149	SwapTotal:       1859860 kB
 10150	SwapFree:        1859860 kB
 10151	Dirty:              4348 kB
 10152	Writeback:             0 kB
 10153	AnonPages:        150672 kB
 10154	Mapped:            13388 kB
 10155	Shmem:              5008 kB
 10156	KReclaimable:      13220 kB
 10157	Slab:              40792 kB
 10158	SReclaimable:      13220 kB
 10159	SUnreclaim:        27572 kB
 10160	KernelStack:        2496 kB
 10161	PageTables:         5996 kB
 10162	NFS_Unstable:          0 kB
 10163	Bounce:                0 kB
 10164	WritebackTmp:          0 kB
 10165	CommitLimit:     3719724 kB
 10166	Committed_AS:    4240456 kB
 10167	VmallocTotal:   135290159040 kB
 10168	VmallocUsed:       33200 kB
 10169	VmallocChunk:          0 kB
 10170	Percpu:             1368 kB
 10171	HardwareCorrupted:     0 kB
 10172	AnonHugePages:         0 kB
 10173	ShmemHugePages:        0 kB
 10174	ShmemPmdMapped:        0 kB
 10175	FileHugePages:         0 kB
 10176	FilePmdMapped:         0 kB
 10177	CmaTotal:         917504 kB
 10178	CmaFree:          901724 kB
 10179	HugePages_Total:       0
 10180	HugePages_Free:        0
 10181	HugePages_Rsvd:        0
 10182	HugePages_Surp:        0
 10183	Hugepagesize:       2048 kB
 10184	Hugetlb:               0 kB
 10185
 10186	### virtual memory:
 10187
 10188	vm.admin_reserve_kbytes = 8192
 10189	vm.block_dump = 0
 10190	vm.compaction_proactiveness = 20
 10191	vm.compact_unevictable_allowed = 1
 10192	vm.dirty_background_bytes = 0
 10193	vm.dirty_background_ratio = 10
 10194	vm.dirty_bytes = 0
 10195	vm.dirty_expire_centisecs = 3000
 10196	vm.dirty_ratio = 20
 10197	vm.dirtytime_expire_seconds = 43200
 10198	vm.dirty_writeback_centisecs = 500
 10199	vm.extfrag_threshold = 500
 10200	vm.hugetlb_shm_group = 0
 10201	vm.laptop_mode = 0
 10202	vm.legacy_va_layout = 0
 10203	vm.lowmem_reserve_ratio = 256	256	32	0
 10204	vm.max_map_count = 65530
 10205	vm.memory_failure_early_kill = 0
 10206	vm.memory_failure_recovery = 1
 10207	vm.min_free_kbytes = 45056
 10208	vm.min_slab_ratio = 5
 10209	vm.min_unmapped_ratio = 1
 10210	vm.mmap_min_addr = 4096
 10211	vm.mmap_rnd_bits = 18
 10212	vm.mmap_rnd_compat_bits = 11
 10213	vm.nr_hugepages = 0
 10214	vm.nr_hugepages_mempolicy = 0
 10215	vm.nr_overcommit_hugepages = 0
 10216	vm.numa_stat = 1
 10217	vm.numa_zonelist_order = Node
 10218	vm.oom_dump_tasks = 1
 10219	vm.oom_kill_allocating_task = 0
 10220	vm.overcommit_kbytes = 0
 10221	vm.overcommit_memory = 0
 10222	vm.overcommit_ratio = 50
 10223	vm.page-cluster = 0
 10224	vm.page_lock_unfairness = 5
 10225	vm.panic_on_oom = 0
 10226	vm.percpu_pagelist_fraction = 0
 10227	vm.stat_interval = 1
 10228	vm.swappiness = 100
 10229	vm.user_reserve_kbytes = 115063
 10230	vm.vfs_cache_pressure = 100
 10231	vm.watermark_boost_factor = 15000
 10232	vm.watermark_scale_factor = 10
 10233	vm.zone_reclaim_mode = 0
 10234
 10235	### ip addr:
 10236
 10237	1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
 10238	    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
 10239	    inet XXX.XXX.0.1/8 scope host lo
 10240	       valid_lft forever preferred_lft forever
 10241	    inet6 ::1/128 scope host
 10242	       valid_lft forever preferred_lft forever
 10243	2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
 10244	    link/ether 00:1e:06:42:03:f8 brd ff:ff:ff:ff:ff:ff
 10245
 10246	### partitions:
 10247
 10248	major minor  #blocks  name
 10249
 10250	 179        0   31464960 mmcblk0
 10251	 179        1   31146208 mmcblk0p1
 10252	 252        0    1859864 zram0
 10253	 252        1      51200 zram1
 10254
 10255	### df:
 10256
 10257	udev            1.4G     0  1.4G   0% /dev
 10258	tmpfs           364M  4.9M  359M   2% /run
 10259	/dev/mmcblk0p1   30G  1.7G   28G   6% /
 10260	tmpfs           1.8G     0  1.8G   0% /dev/shm
 10261	tmpfs           5.0M  4.0K  5.0M   1% /run/lock
 10262	tmpfs           1.8G     0  1.8G   0% /sys/fs/cgroup
 10263	tmpfs           1.8G     0  1.8G   0% /tmp
 10264	/dev/zram1       49M  4.3M   41M  10% /var/log
 10265
 10266	### lsblk:
 10267
 10268	NAME        FSTYPE  SIZE MOUNTPOINT UUID
 10269	mmcblk0              30G
 10270	└─mmcblk0p1 ext4   29.7G /          bd34953d-41be-49d6-b1c0-c0c28a5e239c
 10271	zram1                50M /var/log
 10272
 10273	### zramctl:
 10274
 10275	NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
 10276	/dev/zram1 zstd           50M  132K  698B   36K       6 /var/log
 10277	/dev/zram0 lzo-rle       1.8G    4K   74B   12K       6 [SWAP]
 10278
 10279	### mtab:
 10280
 10281	/dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
 10282	/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
 10283	/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
 10284
 10285	### mmc0:b368 info:
 10286
 10287	               fwrev: 0x0
 10288	              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=CBADS MODALIAS=mmc:block
 10289	                 cid: 6f0303434241445310aa002b4d013b00
 10290	                 rca: 0xb368
 10291	                 csd: 400e005a5b590000f00e7f800a404000
 10292	              manfid: 0x00006f
 10293	                 ocr: 0x00200000
 10294	preferred_erase_size: 2097152
 10295	                type: SD
 10296	               hwrev: 0x1
 10297	                date: 11/2019
 10298	                 dsr: 0x404
 10299	          erase_size: 512
 10300	               oemid: 0x0303
 10301	              serial: 0xaa002b4d
 10302	                 ssr: 00000000000000280402800100fd180a001e00000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
 10303	                 scr: 02b5800300000000
 10304	                name: CBADS
 10305
 10306	### Boot system health:
 10307
 10308	Time       big.LITTLE   load %cpu %sys %usr %nice %io %irq   CPU  C.St.
 10309	16:00:44: 1908/1992MHz  2.67  23%  11%   5%   0%   6%   0% 34.7°C  0/11
 10310	16:00:44: 1908/1992MHz  2.67  85%  38%   9%   0%  35%   1% 34.8°C  0/11
 10311	16:00:44: 1908/1992MHz  2.67  60%  11%   0%   0%  45%   1% 31.1°C  0/11
 10312	16:00:45: 1908/ 250MHz  2.67  49%  10%   6%   0%  30%   2% 31.3°C  0/11
 10313	16:00:45: 1908/1992MHz  2.67  60%   7%   4%   0%  45%   1% 30.9°C  0/11
 10314
 10315	### Activated 1 lzo-rle zram swap devices with 1816 MB each
 10316
 10317	### Activated Armbian ramlog partition with zstd compression
 10318
 10319	Sun 14 Feb 2021 04:01:50 PM GMT | Odroid N2 | 21.02.1 | arm64 | aarch64 | 5.10.12-meson64
 10320
 10321	### dmesg:
 10322
 10323	[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
 10324	[    0.000000] Linux version 5.10.12-meson64 (root@beast) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #21.02.1 SMP PREEMPT Wed Feb 3 21:06:36 CET 2021
 10325	[    0.000000] Machine model: Hardkernel ODROID-N2
 10326	[    0.000000] efi: UEFI not found.
 10327	[    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
 10328	[    0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB
 10329	[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
 10330	[    0.000000] NUMA: No NUMA configuration found
 10331	[    0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ed7fffff]
 10332	[    0.000000] NUMA: NODE_DATA [mem 0xb502f100-0xb5030fff]
 10333	[    0.000000] Zone ranges:
 10334	[    0.000000]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
 10335	[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000ed7fffff]
 10336	[    0.000000]   Normal   empty
 10337	[    0.000000] Movable zone start for each node
 10338	[    0.000000] Early memory node ranges
 10339	[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000004ffffff]
 10340	[    0.000000]   node   0: [mem 0x0000000005300000-0x00000000ed7fffff]
 10341	[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ed7fffff]
 10342	[    0.000000] On node 0 totalpages: 972032
 10343	[    0.000000]   DMA zone: 4096 pages used for memmap
 10344	[    0.000000]   DMA zone: 0 pages reserved
 10345	[    0.000000]   DMA zone: 261376 pages, LIFO batch:63
 10346	[    0.000000]   DMA32 zone: 11104 pages used for memmap
 10347	[    0.000000]   DMA32 zone: 710656 pages, LIFO batch:63
 10348	[    0.000000] psci: probing for conduit method from DT.
 10349	[    0.000000] psci: PSCIv1.0 detected in firmware.
 10350	[    0.000000] psci: Using standard PSCI v0.2 function IDs
 10351	[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
 10352	[    0.000000] psci: SMC Calling Convention v1.1
 10353	[    0.000000] percpu: Embedded 23 pages/cpu s56728 r8192 d29288 u94208
 10354	[    0.000000] pcpu-alloc: s56728 r8192 d29288 u94208 alloc=23*4096
 10355	[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
 10356	[    0.000000] Detected VIPT I-cache on CPU0
 10357	[    0.000000] CPU features: detected: ARM erratum 845719
 10358	[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 956832
 10359	[    0.000000] Policy zone: DMA32
 10360	[    0.000000] Kernel command line: root=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c rootwait rootfstype=ext4 console=ttyAML0,115200n8 console=tty1 loglevel=1  no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=custombuilt cvbsmode=576cvbs max_freq_a53=1896 max_freq_a73=1800 maxcpus=6 voutmode=hdmi modeline=1920,1080,148500,56250,50,1920,2448,2492,2640,1080,1084,1089,1125,1,1,1 disablehpd=false  cvbscable= overscan=100 consoleblank=0
 10361	[    0.000000] Kernel parameter elevator= does not have any effect anymore.
 10362	               Please use sysfs to set IO scheduler for individual devices.
 10363	[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
 10364	[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
 10365	[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
 10366	[    0.000000] software IO TLB: mapped [mem 0x0000000038ac5000-0x000000003cac5000] (64MB)
 10367	[    0.000000] Memory: 2785352K/3888128K available (14144K kernel code, 1760K rwdata, 5508K rodata, 3328K init, 592K bss, 185272K reserved, 917504K cma-reserved)
 10368	[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
 10369	[    0.000000] rcu: Preemptible hierarchical RCU implementation.
 10370	[    0.000000] rcu: 	RCU event tracing is enabled.
 10371	[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
 10372	[    0.000000] 	Trampoline variant of Tasks RCU enabled.
 10373	[    0.000000] 	Rude variant of Tasks RCU enabled.
 10374	[    0.000000] 	Tracing variant of Tasks RCU enabled.
 10375	[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
 10376	[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
 10377	[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
 10378	[    0.000000] GIC: Using split EOI/Deactivate mode
 10379	[    0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized
 10380	[    0.000000] random: get_random_bytes called from start_kernel+0x378/0x538 with crng_init=0
 10381	[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
 10382	[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
 10383	[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
 10384	[    0.000242] Console: colour dummy device 80x25
 10385	[    0.000276] printk: console [tty1] enabled
 10386	[    0.000365] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
 10387	[    0.000377] pid_max: default: 32768 minimum: 301
 10388	[    0.000460] LSM: Security Framework initializing
 10389	[    0.000485] Yama: becoming mindful.
 10390	[    0.000572] AppArmor: AppArmor initialized
 10391	[    0.000624] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
 10392	[    0.000643] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
 10393	[    0.002641] rcu: Hierarchical SRCU implementation.
 10394	[    0.005029] EFI services will not be available.
 10395	[    0.005451] smp: Bringing up secondary CPUs ...
 10396	[    0.006126] Detected VIPT I-cache on CPU1
 10397	[    0.006187] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
 10398	[    0.007379] CPU features: detected: ARM erratum 858921
 10399	[    0.007387] CPU features: detected: Spectre-v2
 10400	[    0.007391] CPU features: detected: Spectre-v4
 10401	[    0.007397] Detected VIPT I-cache on CPU2
 10402	[    0.007423] arch_timer: Enabling local workaround for ARM erratum 858921
 10403	[    0.007438] arch_timer: CPU2: Trapping CNTVCT access
 10404	[    0.007451] CPU2: Booted secondary processor 0x0000000100 [0x410fd092]
 10405	[    0.008157] Detected VIPT I-cache on CPU3
 10406	[    0.008174] arch_timer: Enabling local workaround for ARM erratum 858921
 10407	[    0.008181] arch_timer: CPU3: Trapping CNTVCT access
 10408	[    0.008188] CPU3: Booted secondary processor 0x0000000101 [0x410fd092]
 10409	[    0.008813] Detected VIPT I-cache on CPU4
 10410	[    0.008830] arch_timer: Enabling local workaround for ARM erratum 858921
 10411	[    0.008837] arch_timer: CPU4: Trapping CNTVCT access
 10412	[    0.008845] CPU4: Booted secondary processor 0x0000000102 [0x410fd092]
 10413	[    0.009459] Detected VIPT I-cache on CPU5
 10414	[    0.009476] arch_timer: Enabling local workaround for ARM erratum 858921
 10415	[    0.009483] arch_timer: CPU5: Trapping CNTVCT access
 10416	[    0.009491] CPU5: Booted secondary processor 0x0000000103 [0x410fd092]
 10417	[    0.009572] smp: Brought up 1 node, 6 CPUs
 10418	[    0.009589] SMP: Total of 6 processors activated.
 10419	[    0.009597] CPU features: detected: 32-bit EL0 Support
 10420	[    0.009603] CPU features: detected: CRC32 instructions
 10421	[    0.009609] CPU features: detected: 32-bit EL1 Support
 10422	[    0.020890] CPU: All CPU(s) started at EL2
 10423	[    0.020939] alternatives: patching kernel code
 10424	[    0.022879] devtmpfs: initialized
 10425	[    0.030560] Registered cp15_barrier emulation handler
 10426	[    0.030573] Registered setend emulation handler
 10427	[    0.030710] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
 10428	[    0.030748] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
 10429	[    0.044687] pinctrl core: initialized pinctrl subsystem
 10430	[    0.045237] DMI not present or invalid.
 10431	[    0.045633] NET: Registered protocol family 16
 10432	[    0.047269] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
 10433	[    0.047542] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
 10434	[    0.047767] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
 10435	[    0.047808] audit: initializing netlink subsys (disabled)
 10436	[    0.047900] audit: type=2000 audit(0.044:1): state=initialized audit_enabled=0 res=1
 10437	[    0.049308] thermal_sys: Registered thermal governor 'fair_share'
 10438	[    0.049316] thermal_sys: Registered thermal governor 'bang_bang'
 10439	[    0.049320] thermal_sys: Registered thermal governor 'step_wise'
 10440	[    0.049323] thermal_sys: Registered thermal governor 'user_space'
 10441	[    0.049742] cpuidle: using governor menu
 10442	[    0.050093] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
 10443	[    0.050213] ASID allocator initialised with 65536 entries
 10444	[    0.051129] Serial: AMBA PL011 UART driver
 10445	[    0.084815] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
 10446	[    0.084824] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
 10447	[    0.084829] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
 10448	[    0.084833] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
 10449	[    0.086783] cryptd: max_cpu_qlen set to 1000
 10450	[    0.156198] raid6: neonx8   gen()  2786 MB/s
 10451	[    0.224256] raid6: neonx8   xor()  2042 MB/s
 10452	[    0.292347] raid6: neonx4   gen()  2994 MB/s
 10453	[    0.360391] raid6: neonx4   xor()  2399 MB/s
 10454	[    0.428455] raid6: neonx2   gen()  2560 MB/s
 10455	[    0.496537] raid6: neonx2   xor()  2200 MB/s
 10456	[    0.564589] raid6: neonx1   gen()  2077 MB/s
 10457	[    0.632659] raid6: neonx1   xor()  1727 MB/s
 10458	[    0.700754] raid6: int64x8  gen()  1375 MB/s
 10459	[    0.768834] raid6: int64x8  xor()   784 MB/s
 10460	[    0.836938] raid6: int64x4  gen()  1657 MB/s
 10461	[    0.904991] raid6: int64x4  xor()   733 MB/s
 10462	[    0.973051] raid6: int64x2  gen()  1362 MB/s
 10463	[    1.041120] raid6: int64x2  xor()   619 MB/s
 10464	[    1.109176] raid6: int64x1  gen()  1120 MB/s
 10465	[    1.177233] raid6: int64x1  xor()   462 MB/s
 10466	[    1.177237] raid6: using algorithm neonx4 gen() 2994 MB/s
 10467	[    1.177240] raid6: .... xor() 2399 MB/s, rmw enabled
 10468	[    1.177244] raid6: using neon recovery algorithm
 10469	[    1.177675] ACPI: Interpreter disabled.
 10470	[    1.178449] 5V: supplied by 12V
 10471	[    1.179353] VDDAO_3V3: supplied by 12V
 10472	[    1.179828] iommu: Default domain type: Translated
 10473	[    1.179953] vgaarb: loaded
 10474	[    1.180875] SCSI subsystem initialized
 10475	[    1.181089] usbcore: registered new interface driver usbfs
 10476	[    1.181132] usbcore: registered new interface driver hub
 10477	[    1.181166] usbcore: registered new device driver usb
 10478	[    1.181441] pps_core: LinuxPPS API ver. 1 registered
 10479	[    1.181446] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
 10480	[    1.181471] PTP clock support registered
 10481	[    1.181665] EDAC MC: Ver: 3.0.0
 10482	[    1.182976] NetLabel: Initializing
 10483	[    1.182983] NetLabel:  domain hash size = 128
 10484	[    1.182986] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
 10485	[    1.183028] NetLabel:  unlabeled traffic allowed by default
 10486	[    1.183474] clocksource: Switched to clocksource arch_sys_counter
 10487	[    1.183678] VFS: Disk quotas dquot_6.6.0
 10488	[    1.183724] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
 10489	[    1.184088] AppArmor: AppArmor Filesystem Enabled
 10490	[    1.184138] pnp: PnP ACPI: disabled
 10491	[    1.189552] NET: Registered protocol family 2
 10492	[    1.190037] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
 10493	[    1.190141] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
 10494	[    1.190398] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
 10495	[    1.190585] TCP: Hash tables configured (established 32768 bind 32768)
 10496	[    1.190742] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
 10497	[    1.190808] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
 10498	[    1.190859] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
 10499	[    1.191005] NET: Registered protocol family 1
 10500	[    1.191025] PCI: CLS 0 bytes, default 64
 10501	[    1.191147] Trying to unpack rootfs image as initramfs...
 10502	[    1.727039] Freeing initrd memory: 13544K
 10503	[    1.727964] kvm [1]: IPA Size Limit: 40 bits
 10504	[    1.728666] kvm [1]: vgic interrupt IRQ9
 10505	[    1.728797] kvm [1]: Hyp mode initialized successfully
 10506	[    1.732771] Initialise system trusted keyrings
 10507	[    1.732805] Key type blacklist registered
 10508	[    1.732908] workingset: timestamp_bits=44 max_order=20 bucket_order=0
 10509	[    1.736134] zbud: loaded
 10510	[    1.737114] squashfs: version 4.0 (2009/01/31) Phillip Lougher
 10511	[    1.737568] fuse: init (API version 7.32)
 10512	[    1.738338] integrity: Platform Keyring initialized
 10513	[    1.766287] xor: measuring software checksum speed
 10514	[    1.769135]    8regs           :  3473 MB/sec
 10515	[    1.771617]    32regs          :  4018 MB/sec
 10516	[    1.774267]    arm64_neon      :  3719 MB/sec
 10517	[    1.774270] xor: using function: 32regs (4018 MB/sec)
 10518	[    1.774276] Key type asymmetric registered
 10519	[    1.774280] Asymmetric key parser 'x509' registered
 10520	[    1.774314] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
 10521	[    1.774391] io scheduler mq-deadline registered
 10522	[    1.774395] io scheduler kyber registered
 10523	[    1.774478] io scheduler bfq registered
 10524	[    1.776967] gpio-447 (usb-hub-reset): hogged as output/high
 10525	[    1.779821] EINJ: ACPI disabled.
 10526	[    1.785965] soc soc0: Amlogic Meson G12B (S922X) Revision 29:a (40:2) Detected
 10527	[    1.787303] VCC_3V3: supplied by VDDAO_3V3
 10528	[    1.787349] FLASH_1V8: supplied by VCC_3V3
 10529	[    1.787381] VCC_1V8: supplied by VCC_3V3
 10530	[    1.787408] VDDAO_1V8: supplied by VDDAO_3V3
 10531	[    1.787439] VDDCPU_A: supplied by regulator-dummy
 10532	[    1.787862] VDDCPU_B: supplied by regulator-dummy
 10533	[    1.788521] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
 10534	[    1.790645] Serial: AMBA driver
 10535	[    1.790917] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart
 10536	[    1.791011] printk: console [ttyAML0] enabled
 10537	[    1.791592] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 33, base_baud = 1500000) is a meson_uart
 10538	[    1.797003] loop: module loaded
 10539	[    1.798965] libphy: Fixed MDIO Bus: probed
 10540	[    1.800209] tun: Universal TUN/TAP device driver, 1.6
 10541	[    1.800815] thunder_xcv, ver 1.0
 10542	[    1.800847] thunder_bgx, ver 1.0
 10543	[    1.800874] nicpf, ver 1.0
 10544	[    1.801299] e1000e: Intel(R) PRO/1000 Network Driver
 10545	[    1.801303] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
 10546	[    1.801344] igb: Intel(R) Gigabit Ethernet Network Driver
 10547	[    1.801347] igb: Copyright (c) 2007-2014 Intel Corporation.
 10548	[    1.801384] igbvf: Intel(R) Gigabit Virtual Function Network Driver
 10549	[    1.801387] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
 10550	[    1.801507] sky2: driver version 1.30
 10551	[    1.801879] VFIO - User Level meta-driver version: 0.3
 10552	[    1.803213] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
 10553	[    1.803235] ehci-pci: EHCI PCI platform driver
 10554	[    1.803267] ehci-platform: EHCI generic platform driver
 10555	[    1.803393] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
 10556	[    1.803403] ohci-pci: OHCI PCI platform driver
 10557	[    1.803436] ohci-platform: OHCI generic platform driver
 10558	[    1.803860] usbcore: registered new interface driver usb-storage
 10559	[    1.805082] mousedev: PS/2 mouse device common for all mice
 10560	[    1.805462] i2c /dev entries driver
 10561	[    1.810585] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17
 10562	[    1.811243] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz
 10563	[    1.811939] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-1 failed:-17
 10564	[    1.812511] sdhci: Secure Digital Host Controller Interface driver
 10565	[    1.812517] sdhci: Copyright(c) Pierre Ossman
 10566	[    1.812624] Synopsys Designware Multimedia Card Interface Driver
 10567	[    1.813047] sdhci-pltfm: SDHCI platform and OF driver helper
 10568	[    1.813465] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq
 10569	[    1.813806] ledtrig-cpu: registered to indicate activity on CPUs
 10570	[    1.814057] meson-sm: secure-monitor enabled
 10571	[    1.814515] hid: raw HID events driver (C) Jiri Kosina
 10572	[    1.814595] usbcore: registered new interface driver usbhid
 10573	[    1.814597] usbhid: USB HID core driver
 10574	[    1.815678] NET: Registered protocol family 10
 10575	[    1.816130] Segment Routing with IPv6
 10576	[    1.816164] NET: Registered protocol family 17
 10577	[    1.816210] 8021q: 802.1Q VLAN Support v1.8
 10578	[    1.816232] Key type dns_resolver registered
 10579	[    1.816515] registered taskstats version 1
 10580	[    1.816521] Loading compiled-in X.509 certificates
 10581	[    1.818203] Loaded X.509 cert 'Build time autogenerated kernel key: f47c178852ca39740c3546b008122b65f5ed9bce'
 10582	[    1.819812] zswap: loaded using pool zstd/z3fold
 10583	[    1.819974] Key type ._fscrypt registered
 10584	[    1.819976] Key type .fscrypt registered
 10585	[    1.819979] Key type fscrypt-provisioning registered
 10586	[    1.821054] Btrfs loaded, crc32c=crc32c-generic
 10587	[    1.826988] Key type encrypted registered
 10588	[    1.827001] AppArmor: AppArmor sha1 policy hashing enabled
 10589	[    1.833424] HUB_5V: supplied by 5V
 10590	[    1.833630] USB_PWR_EN: supplied by 5V
 10591	[    1.835250] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2
 10592	[    1.835257] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1
 10593	[    1.837966] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator
 10594	[    1.838024] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator
 10595	[    1.838166] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM
 10596	[    1.838760] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
 10597	[    1.838771] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
 10598	[    1.838853] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010
 10599	[    1.838877] xhci-hcd xhci-hcd.0.auto: irq 41, io mem 0xff500000
 10600	[    1.838999] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
 10601	[    1.839003] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 10602	[    1.839006] usb usb1: Product: xHCI Host Controller
 10603	[    1.839008] usb usb1: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
 10604	[    1.839010] usb usb1: SerialNumber: xhci-hcd.0.auto
 10605	[    1.839198] hub 1-0:1.0: USB hub found
 10606	[    1.839213] hub 1-0:1.0: 2 ports detected
 10607	[    1.839341] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
 10608	[    1.839347] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
 10609	[    1.839352] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
 10610	[    1.839372] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
 10611	[    1.839402] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
 10612	[    1.839405] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 10613	[    1.839407] usb usb2: Product: xHCI Host Controller
 10614	[    1.839409] usb usb2: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
 10615	[    1.839411] usb usb2: SerialNumber: xhci-hcd.0.auto
 10616	[    1.839766] hub 2-0:1.0: USB hub found
 10617	[    1.839778] hub 2-0:1.0: 1 port detected
 10618	[    1.840884] meson-gx-mmc ffe05000.sd: Got CD GPIO
 10619	[    1.868288] Freeing unused kernel memory: 3328K
 10620	[    1.907543] Run /init as init process
 10621	[    1.907547]   with arguments:
 10622	[    1.907549]     /init
 10623	[    1.907551]   with environment:
 10624	[    1.907553]     HOME=/
 10625	[    1.907554]     TERM=linux
 10626	[    1.907556]     hdmimode=custombuilt
 10627	[    1.907557]     cvbsmode=576cvbs
 10628	[    1.907559]     max_freq_a53=1896
 10629	[    1.907560]     max_freq_a73=1800
 10630	[    1.907562]     voutmode=hdmi
 10631	[    1.907563]     modeline=1920,1080,148500,56250,50,1920,2448,2492,2640,1080,1084,1089,1125,1,1,1
 10632	[    1.907565]     disablehpd=false
 10633	[    1.907566]     cvbscable=
 10634	[    1.907567]     overscan=100
 10635	[    1.934941] mmc0: new ultra high speed SDR25 SDHC card at address b368
 10636	[    1.935791] mmcblk0: mmc0:b368 CBADS 30.0 GiB
 10637	[    1.937783]  mmcblk0: p1
 10638	[    2.068508] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found
 10639	[    2.068515] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found
 10640	[    2.068604] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock
 10641	[    2.069223] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37
 10642	[    2.069230] meson8b-dwmac ff3f0000.ethernet: 	DWMAC1000
 10643	[    2.069234] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported
 10644	[    2.069236] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported
 10645	[    2.069238] meson8b-dwmac ff3f0000.ethernet: COE Type 2
 10646	[    2.069240] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported
 10647	[    2.069242] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported
 10648	[    2.069285] meson8b-dwmac ff3f0000.ethernet: Normal descriptors
 10649	[    2.069288] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled
 10650	[    2.069290] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
 10651	[    2.069505] libphy: stmmac: probed
 10652	[    2.070580] libphy: mdio_mux: probed
 10653	[    2.094253] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
 10654	[    2.094385] rtc-pcf8563 1-0051: registered as rtc0
 10655	[    2.095818] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
 10656	[    2.095827] rtc-pcf8563 1-0051: hctosys: unable to read the hardware clock
 10657	[    2.097110] meson-vrtc ff8000a8.rtc: registered as rtc1
 10658	[    2.109629] random: fast init done
 10659	[    2.171485] usb 1-1: new high-speed USB device number 2 using xhci-hcd
 10660	[    2.279887] libphy: mdio_mux: probed
 10661	[    2.325839] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.04
 10662	[    2.325845] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
 10663	[    2.325848] usb 1-1: Product: USB2.1 Hub
 10664	[    2.325850] usb 1-1: Manufacturer: GenesysLogic
 10665	[    2.383566] hub 1-1:1.0: USB hub found
 10666	[    2.383817] hub 1-1:1.0: 4 ports detected
 10667	[    2.451595] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
 10668	[    2.474074] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.04
 10669	[    2.474079] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
 10670	[    2.474082] usb 2-1: Product: USB3.1 Hub
 10671	[    2.474086] usb 2-1: Manufacturer: GenesysLogic
 10672	[    2.495610] hub 2-1:1.0: USB hub found
 10673	[    2.495902] hub 2-1:1.0: 4 ports detected
 10674	[    2.599477] usb 1-2: new high-speed USB device number 3 using xhci-hcd
 10675	[    2.748503] usb 1-2: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice= 7.02
 10676	[    2.748506] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
 10677	[    2.748509] usb 1-2: Product: USB2.0 Hub
 10678	[    2.799612] hub 1-2:1.0: USB hub found
 10679	[    2.799843] hub 1-2:1.0: 4 ports detected
 10680	[    3.087489] usb 1-2.3: new high-speed USB device number 4 using xhci-hcd
 10681	[    3.188569] usb 1-2.3: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice= 7.02
 10682	[    3.188575] usb 1-2.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
 10683	[    3.188578] usb 1-2.3: Product: USB2.0 Hub
 10684	[    3.202118] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
 10685	[    3.247745] hub 1-2.3:1.0: USB hub found
 10686	[    3.248006] hub 1-2.3:1.0: 4 ports detected
 10687	[    3.539482] usb 1-2.3.4: new high-speed USB device number 5 using xhci-hcd
 10688	[    3.639944] usb 1-2.3.4: New USB device found, idVendor=2013, idProduct=025f, bcdDevice= 1.00
 10689	[    3.639951] usb 1-2.3.4: New USB device strings: Mfr=3, Product=1, SerialNumber=2
 10690	[    3.639955] usb 1-2.3.4: Product: PCTV 292e
 10691	[    3.639957] usb 1-2.3.4: Manufacturer: PCTV
 10692	[    3.639959] usb 1-2.3.4: SerialNumber: 0011356964
 10693	[    4.007641] systemd[1]: System time before build time, advancing clock.
 10694	[    4.022439] systemd[1]: Inserted module 'autofs4'
 10695	[    4.068937] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
 10696	[    4.069163] systemd[1]: Detected architecture arm64.
 10697	[    4.093832] systemd[1]: Set hostname to <odroidn2>.
 10698	[    4.420756] random: systemd: uninitialized urandom read (16 bytes read)
 10699	[    4.424089] random: systemd: uninitialized urandom read (16 bytes read)
 10700	[    4.424229] systemd[1]: Listening on initctl Compatibility Named Pipe.
 10701	[    4.424465] random: systemd: uninitialized urandom read (16 bytes read)
 10702	[    4.424678] systemd[1]: Listening on Journal Socket (/dev/log).
 10703	[    4.424869] systemd[1]: Listening on Syslog Socket.
 10704	[    4.424944] systemd[1]: Reached target Swap.
 10705	[    4.425131] systemd[1]: Listening on fsck to fsckd communication Socket.
 10706	[    4.425313] systemd[1]: Listening on udev Kernel Socket.
 10707	[    4.425461] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
 10708	[    4.492190] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
 10709	[    5.059293] pwm-gpio pwmgpio: 1 gpio pwms loaded
 10710	[    5.066036] zram: Added device: zram0
 10711	[    5.066815] zram: Added device: zram1
 10712	[    5.067276] zram: Added device: zram2
 10713	[    5.217121] mc: Linux media interface: v0.10
 10714	[    5.228229] meson-saradc ff809000.adc: supply vref not found, using dummy regulator
 10715	[    5.267130] panfrost ffe40000.gpu: clock rate = 24000000
 10716	[    5.267183] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19
 10717	[    5.267768] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0
 10718	[    5.267773] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400
 10719	[    5.267777] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
 10720	[    5.267780] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1
 10721	[    5.282362] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 0
 10722	[    5.282663] videodev: Linux video capture interface: v2.00
 10723	[    5.315540] Registered IR keymap rc-odroid
 10724	[    5.323095] meson-drm ff900000.vpu: Queued 2 outputs on vpu
 10725	[    5.352638] IR NEC protocol handler initialized
 10726	[    5.379611] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0
 10727	[    5.379722] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
 10728	[    5.379778] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input0
 10729	[    5.379935] meson-ir ff808000.ir: receiver initialized
 10730	[    5.398204] meson-drm ff900000.vpu: CVBS Output connector not available
 10731	[    5.423548] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
 10732	[    5.423927] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
 10733	[    5.424133] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
 10734	[    5.424321] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 1
 10735	[    5.470460] zram0: detected capacity change from 0 to 1904500736
 10736	[    5.494497] em28xx 1-2.3.4:1.0: New device PCTV PCTV 292e @ 480 Mbps (2013:025f, interface 0, class 0)
 10737	[    5.494504] em28xx 1-2.3.4:1.0: DVB interface 0 found: isoc
 10738	[    5.509011] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
 10739	[    5.551677] em28xx 1-2.3.4:1.0: chip ID is em28178
 10740	[    5.707629] Console: switching to colour frame buffer device 240x67
 10741	[    5.734213] meson-drm ff900000.vpu: [drm] fb0: mesondrmfb frame buffer device
 10742	[    5.779503] axg-sound-card sound: ASoC: no DMI vendor name!
 10743	[    6.527494] Adding 1859860k swap on /dev/zram0.  Priority:5 extents:1 across:1859860k SSFS
 10744	[    6.593046] zram1: detected capacity change from 0 to 52428800
 10745	[    7.589723] em28xx 1-2.3.4:1.0: EEPROM ID = 26 00 01 00, EEPROM hash = 0x8d0cfd04
 10746	[    7.589727] em28xx 1-2.3.4:1.0: EEPROM info:
 10747	[    7.589729] em28xx 1-2.3.4:1.0: 	microcode start address = 0x0004, boot configuration = 0x01
 10748	[    7.595842] em28xx 1-2.3.4:1.0: 	AC97 audio (5 sample rates)
 10749	[    7.595844] em28xx 1-2.3.4:1.0: 	500mA max power
 10750	[    7.595848] em28xx 1-2.3.4:1.0: 	Table at offset 0x27, strings=0x146a, 0x1888, 0x0a7e
 10751	[    7.655472] em28xx 1-2.3.4:1.0: Identified as PCTV tripleStick (292e) (card=94)
 10752	[    7.655476] em28xx 1-2.3.4:1.0: dvb set to isoc mode.
 10753	[    7.655595] usbcore: registered new interface driver em28xx
 10754	[    7.681971] em28xx 1-2.3.4:1.0: Binding DVB extension
 10755	[    7.695223] i2c i2c-4: Added multiplexed i2c bus 5
 10756	[    7.695231] si2168 4-0064: Silicon Labs Si2168-B40 successfully identified
 10757	[    7.695234] si2168 4-0064: firmware version: B 4.0.2
 10758	[    7.703736] si2157 5-0060: Silicon Labs Si2147/2148/2157/2158 successfully attached
 10759	[    7.703817] dvbdev: DVB: registering new adapter (1-2.3.4:1.0)
 10760	[    7.703829] em28xx 1-2.3.4:1.0: DVB: registering adapter 0 frontend 0 (Silicon Labs Si2168)...
 10761	[    7.703841] dvbdev: dvb_create_media_entity: media entity 'Silicon Labs Si2168' registered.
 10762	[    7.704915] dvbdev: dvb_create_media_entity: media entity 'dvb-demux' registered.
 10763	[    7.727575] em28xx 1-2.3.4:1.0: DVB extension successfully initialized
 10764	[    7.727586] em28xx: Registered (Em28xx dvb Extension) extension
 10765	[    7.734860] em28xx 1-2.3.4:1.0: Registering input extension
 10766	[    7.771469] Registered IR keymap rc-pinnacle-pctv-hd
 10767	[    7.771648] rc rc1: PCTV tripleStick (292e) as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-2/1-2.3/1-2.3.4/1-2.3.4:1.0/rc/rc1
 10768	[    7.771721] rc rc1: lirc_dev: driver em28xx registered at minor = 1, scancode receiver, no transmitter
 10769	[    7.771783] input: PCTV tripleStick (292e) as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-2/1-2.3/1-2.3.4/1-2.3.4:1.0/rc/rc1/input1
 10770	[    7.771863] em28xx 1-2.3.4:1.0: Input extension successfully initialized
 10771	[    7.771866] em28xx: Registered (Em28xx Input Extension) extension
 10772	[    8.676144] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
 10773	[    8.676163] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
 10774	[    9.740233] systemd[1]: Started Armbian memory supported logging.
 10775	[    9.742534] systemd[1]: Starting Journal Service...
 10776	[    9.809869] systemd[1]: Started Journal Service.
 10777	[    9.834959] systemd-journald[1844]: Received request to flush runtime journal from PID 1
 10778
 10779	### armbian-release:
 10780
 10781	# PLEASE DO NOT EDIT THIS FILE
 10782	BOARD=odroidn2
 10783	BOARD_NAME="Odroid N2"
 10784	BOARDFAMILY=meson-g12b
 10785	BUILD_REPOSITORY_URL=https://github.com/armbian/build
 10786	BUILD_REPOSITORY_COMMIT=5f03d652
 10787	DISTRIBUTION_CODENAME=buster
 10788	DISTRIBUTION_STATUS=supported
 10789	VERSION=21.02.1
 10790	LINUXFAMILY=meson64
 10791	BRANCH=current
 10792	ARCH=arm64
 10793	IMAGE_TYPE=stable
 10794	BOARD_TYPE=conf
 10795	INITRD_ARCH=arm64
 10796	KERNEL_IMAGE_TYPE=Image
 10797
 10798	### boot environment:
 10799
 10800	verbosity=1
 10801	console=both
 10802	overlay_prefix=meson
 10803	rootdev=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c
 10804	rootfstype=ext4
 10805	usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
 10806
 10807	### lsusb:
 10808
 10809	Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc.
 10810	Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
 10811	Bus 001 Device 005: ID 2013:025f PCTV Systems
 10812	Bus 001 Device 004: ID 05e3:0608 Genesys Logic, Inc. Hub
 10813	Bus 001 Device 003: ID 05e3:0608 Genesys Logic, Inc. Hub
 10814	Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
 10815	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
 10816
 10817	### lscpu:
 10818
 10819	Architecture:        aarch64
 10820	Byte Order:          Little Endian
 10821	CPU(s):              6
 10822	On-line CPU(s) list: 0-5
 10823	Thread(s) per core:  1
 10824	Core(s) per socket:  3
 10825	Socket(s):           2
 10826	NUMA node(s):        1
 10827	Vendor ID:           ARM
 10828	Model:               4
 10829	Model name:          Cortex-A53
 10830	Stepping:            r0p4
 10831	CPU max MHz:         1992.0000
 10832	CPU min MHz:         100.0000
 10833	BogoMIPS:            48.00
 10834	L1d cache:           unknown size
 10835	L1i cache:           unknown size
 10836	L2 cache:            unknown size
 10837	NUMA node0 CPU(s):   0-5
 10838	Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 10839
 10840	### cpuinfo:
 10841
 10842	processor	: 0
 10843	BogoMIPS	: 48.00
 10844	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 10845	CPU implementer	: 0x41
 10846	CPU architecture: 8
 10847	CPU variant	: 0x0
 10848	CPU part	: 0xd03
 10849	CPU revision	: 4
 10850
 10851	processor	: 1
 10852	BogoMIPS	: 48.00
 10853	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 10854	CPU implementer	: 0x41
 10855	CPU architecture: 8
 10856	CPU variant	: 0x0
 10857	CPU part	: 0xd03
 10858	CPU revision	: 4
 10859
 10860	processor	: 2
 10861	BogoMIPS	: 48.00
 10862	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 10863	CPU implementer	: 0x41
 10864	CPU architecture: 8
 10865	CPU variant	: 0x0
 10866	CPU part	: 0xd09
 10867	CPU revision	: 2
 10868
 10869	processor	: 3
 10870	BogoMIPS	: 48.00
 10871	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 10872	CPU implementer	: 0x41
 10873	CPU architecture: 8
 10874	CPU variant	: 0x0
 10875	CPU part	: 0xd09
 10876	CPU revision	: 2
 10877
 10878	processor	: 4
 10879	BogoMIPS	: 48.00
 10880	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 10881	CPU implementer	: 0x41
 10882	CPU architecture: 8
 10883	CPU variant	: 0x0
 10884	CPU part	: 0xd09
 10885	CPU revision	: 2
 10886
 10887	processor	: 5
 10888	BogoMIPS	: 48.00
 10889	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 10890	CPU implementer	: 0x41
 10891	CPU architecture: 8
 10892	CPU variant	: 0x0
 10893	CPU part	: 0xd09
 10894	CPU revision	: 2
 10895
 10896
 10897	### meminfo:
 10898
 10899	MemTotal:        3719728 kB
 10900	MemFree:         3388724 kB
 10901	MemAvailable:    3342020 kB
 10902	Buffers:           11568 kB
 10903	Cached:            44372 kB
 10904	SwapCached:            0 kB
 10905	Active:            29036 kB
 10906	Inactive:         188068 kB
 10907	Active(anon):        140 kB
 10908	Inactive(anon):   166308 kB
 10909	Active(file):      28896 kB
 10910	Inactive(file):    21760 kB
 10911	Unevictable:           0 kB
 10912	Mlocked:               0 kB
 10913	SwapTotal:       1859860 kB
 10914	SwapFree:        1859860 kB
 10915	Dirty:              4592 kB
 10916	Writeback:             0 kB
 10917	AnonPages:        161404 kB
 10918	Mapped:            13444 kB
 10919	Shmem:              4992 kB
 10920	KReclaimable:      13156 kB
 10921	Slab:              40544 kB
 10922	SReclaimable:      13156 kB
 10923	SUnreclaim:        27388 kB
 10924	KernelStack:        2608 kB
 10925	PageTables:         6068 kB
 10926	NFS_Unstable:          0 kB
 10927	Bounce:                0 kB
 10928	WritebackTmp:          0 kB
 10929	CommitLimit:     3719724 kB
 10930	Committed_AS:    4240040 kB
 10931	VmallocTotal:   135290159040 kB
 10932	VmallocUsed:       33200 kB
 10933	VmallocChunk:          0 kB
 10934	Percpu:             1368 kB
 10935	HardwareCorrupted:     0 kB
 10936	AnonHugePages:         0 kB
 10937	ShmemHugePages:        0 kB
 10938	ShmemPmdMapped:        0 kB
 10939	FileHugePages:         0 kB
 10940	FilePmdMapped:         0 kB
 10941	CmaTotal:         917504 kB
 10942	CmaFree:          901724 kB
 10943	HugePages_Total:       0
 10944	HugePages_Free:        0
 10945	HugePages_Rsvd:        0
 10946	HugePages_Surp:        0
 10947	Hugepagesize:       2048 kB
 10948	Hugetlb:               0 kB
 10949
 10950	### virtual memory:
 10951
 10952	vm.admin_reserve_kbytes = 8192
 10953	vm.block_dump = 0
 10954	vm.compaction_proactiveness = 20
 10955	vm.compact_unevictable_allowed = 1
 10956	vm.dirty_background_bytes = 0
 10957	vm.dirty_background_ratio = 10
 10958	vm.dirty_bytes = 0
 10959	vm.dirty_expire_centisecs = 3000
 10960	vm.dirty_ratio = 20
 10961	vm.dirtytime_expire_seconds = 43200
 10962	vm.dirty_writeback_centisecs = 500
 10963	vm.extfrag_threshold = 500
 10964	vm.hugetlb_shm_group = 0
 10965	vm.laptop_mode = 0
 10966	vm.legacy_va_layout = 0
 10967	vm.lowmem_reserve_ratio = 256	256	32	0
 10968	vm.max_map_count = 65530
 10969	vm.memory_failure_early_kill = 0
 10970	vm.memory_failure_recovery = 1
 10971	vm.min_free_kbytes = 45056
 10972	vm.min_slab_ratio = 5
 10973	vm.min_unmapped_ratio = 1
 10974	vm.mmap_min_addr = 4096
 10975	vm.mmap_rnd_bits = 18
 10976	vm.mmap_rnd_compat_bits = 11
 10977	vm.nr_hugepages = 0
 10978	vm.nr_hugepages_mempolicy = 0
 10979	vm.nr_overcommit_hugepages = 0
 10980	vm.numa_stat = 1
 10981	vm.numa_zonelist_order = Node
 10982	vm.oom_dump_tasks = 1
 10983	vm.oom_kill_allocating_task = 0
 10984	vm.overcommit_kbytes = 0
 10985	vm.overcommit_memory = 0
 10986	vm.overcommit_ratio = 50
 10987	vm.page-cluster = 0
 10988	vm.page_lock_unfairness = 5
 10989	vm.panic_on_oom = 0
 10990	vm.percpu_pagelist_fraction = 0
 10991	vm.stat_interval = 1
 10992	vm.swappiness = 100
 10993	vm.user_reserve_kbytes = 115005
 10994	vm.vfs_cache_pressure = 100
 10995	vm.watermark_boost_factor = 15000
 10996	vm.watermark_scale_factor = 10
 10997	vm.zone_reclaim_mode = 0
 10998
 10999	### ip addr:
 11000
 11001	1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
 11002	    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
 11003	    inet XXX.XXX.0.1/8 scope host lo
 11004	       valid_lft forever preferred_lft forever
 11005	    inet6 ::1/128 scope host
 11006	       valid_lft forever preferred_lft forever
 11007	2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
 11008	    link/ether 00:1e:06:42:03:f8 brd ff:ff:ff:ff:ff:ff
 11009
 11010	### partitions:
 11011
 11012	major minor  #blocks  name
 11013
 11014	 179        0   31464960 mmcblk0
 11015	 179        1   31146208 mmcblk0p1
 11016	 252        0    1859864 zram0
 11017	 252        1      51200 zram1
 11018
 11019	### df:
 11020
 11021	udev            1.4G     0  1.4G   0% /dev
 11022	tmpfs           364M  4.9M  359M   2% /run
 11023	/dev/mmcblk0p1   30G  1.7G   28G   6% /
 11024	tmpfs           1.8G     0  1.8G   0% /dev/shm
 11025	tmpfs           5.0M  4.0K  5.0M   1% /run/lock
 11026	tmpfs           1.8G     0  1.8G   0% /sys/fs/cgroup
 11027	tmpfs           1.8G     0  1.8G   0% /tmp
 11028	/dev/zram1       49M  4.5M   41M  10% /var/log
 11029
 11030	### lsblk:
 11031
 11032	NAME        FSTYPE  SIZE MOUNTPOINT UUID
 11033	mmcblk0              30G
 11034	└─mmcblk0p1 ext4   29.7G /          bd34953d-41be-49d6-b1c0-c0c28a5e239c
 11035	zram1                50M /var/log
 11036
 11037	### zramctl:
 11038
 11039	NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
 11040	/dev/zram1 zstd           50M  132K  698B   36K       6 /var/log
 11041	/dev/zram0 lzo-rle       1.8G    4K   74B   12K       6 [SWAP]
 11042
 11043	### mtab:
 11044
 11045	/dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
 11046	/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
 11047	/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
 11048
 11049	### mmc0:b368 info:
 11050
 11051	               fwrev: 0x0
 11052	              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=CBADS MODALIAS=mmc:block
 11053	                 cid: 6f0303434241445310aa002b4d013b00
 11054	                 rca: 0xb368
 11055	                 csd: 400e005a5b590000f00e7f800a404000
 11056	              manfid: 0x00006f
 11057	                 ocr: 0x00200000
 11058	preferred_erase_size: 2097152
 11059	                type: SD
 11060	               hwrev: 0x1
 11061	                date: 11/2019
 11062	                 dsr: 0x404
 11063	          erase_size: 512
 11064	               oemid: 0x0303
 11065	              serial: 0xaa002b4d
 11066	                 ssr: 00000000000000280402800100fd180a001e00000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
 11067	                 scr: 02b5800300000000
 11068	                name: CBADS
 11069
 11070	### Boot system health:
 11071
 11072	Time       big.LITTLE   load %cpu %sys %usr %nice %io %irq   CPU  C.St.
 11073	16:01:51: 1908/1992MHz  2.75  23%  10%   5%   0%   6%   0% 34.8°C  0/11
 11074	16:01:51: 1908/1992MHz  2.75  84%  32%   7%   0%  42%   1% 34.5°C  0/11
 11075	16:01:52: 1908/ 250MHz  2.75  47%   9%   2%   0%  33%   1% 31.5°C  0/11
 11076	16:01:52: 1908/1992MHz  2.75  61%  12%   6%   0%  37%   2% 31.5°C  0/11
 11077	16:01:52: 1908/1992MHz  2.75  42%   3%   4%   0%  33%   1% 31.1°C  0/11
 11078
 11079	### Activated 1 lzo-rle zram swap devices with 1816 MB each
 11080
 11081	### Activated Armbian ramlog partition with zstd compression
 11082
 11083	Sun 14 Feb 2021 04:14:52 PM GMT | Odroid N2 | 21.02.1 | arm64 | aarch64 | 5.10.12-meson64
 11084
 11085	### dmesg:
 11086
 11087	[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
 11088	[    0.000000] Linux version 5.10.12-meson64 (root@beast) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #21.02.1 SMP PREEMPT Wed Feb 3 21:06:36 CET 2021
 11089	[    0.000000] Machine model: Hardkernel ODROID-N2
 11090	[    0.000000] efi: UEFI not found.
 11091	[    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
 11092	[    0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB
 11093	[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
 11094	[    0.000000] NUMA: No NUMA configuration found
 11095	[    0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ed7fffff]
 11096	[    0.000000] NUMA: NODE_DATA [mem 0xb502f100-0xb5030fff]
 11097	[    0.000000] Zone ranges:
 11098	[    0.000000]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
 11099	[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000ed7fffff]
 11100	[    0.000000]   Normal   empty
 11101	[    0.000000] Movable zone start for each node
 11102	[    0.000000] Early memory node ranges
 11103	[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000004ffffff]
 11104	[    0.000000]   node   0: [mem 0x0000000005300000-0x00000000ed7fffff]
 11105	[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ed7fffff]
 11106	[    0.000000] On node 0 totalpages: 972032
 11107	[    0.000000]   DMA zone: 4096 pages used for memmap
 11108	[    0.000000]   DMA zone: 0 pages reserved
 11109	[    0.000000]   DMA zone: 261376 pages, LIFO batch:63
 11110	[    0.000000]   DMA32 zone: 11104 pages used for memmap
 11111	[    0.000000]   DMA32 zone: 710656 pages, LIFO batch:63
 11112	[    0.000000] psci: probing for conduit method from DT.
 11113	[    0.000000] psci: PSCIv1.0 detected in firmware.
 11114	[    0.000000] psci: Using standard PSCI v0.2 function IDs
 11115	[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
 11116	[    0.000000] psci: SMC Calling Convention v1.1
 11117	[    0.000000] percpu: Embedded 23 pages/cpu s56728 r8192 d29288 u94208
 11118	[    0.000000] pcpu-alloc: s56728 r8192 d29288 u94208 alloc=23*4096
 11119	[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
 11120	[    0.000000] Detected VIPT I-cache on CPU0
 11121	[    0.000000] CPU features: detected: ARM erratum 845719
 11122	[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 956832
 11123	[    0.000000] Policy zone: DMA32
 11124	[    0.000000] Kernel command line: root=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c rootwait rootfstype=ext4 console=ttyAML0,115200n8 console=tty1 loglevel=1  no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=custombuilt cvbsmode=576cvbs max_freq_a53=1896 max_freq_a73=1800 maxcpus=6 voutmode=hdmi modeline=1920,1080,148500,56250,50,1920,2448,2492,2640,1080,1084,1089,1125,1,1,1 disablehpd=false  cvbscable= overscan=100 consoleblank=0
 11125	[    0.000000] Kernel parameter elevator= does not have any effect anymore.
 11126	               Please use sysfs to set IO scheduler for individual devices.
 11127	[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
 11128	[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
 11129	[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
 11130	[    0.000000] software IO TLB: mapped [mem 0x0000000038ac5000-0x000000003cac5000] (64MB)
 11131	[    0.000000] Memory: 2785352K/3888128K available (14144K kernel code, 1760K rwdata, 5508K rodata, 3328K init, 592K bss, 185272K reserved, 917504K cma-reserved)
 11132	[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
 11133	[    0.000000] rcu: Preemptible hierarchical RCU implementation.
 11134	[    0.000000] rcu: 	RCU event tracing is enabled.
 11135	[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
 11136	[    0.000000] 	Trampoline variant of Tasks RCU enabled.
 11137	[    0.000000] 	Rude variant of Tasks RCU enabled.
 11138	[    0.000000] 	Tracing variant of Tasks RCU enabled.
 11139	[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
 11140	[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
 11141	[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
 11142	[    0.000000] GIC: Using split EOI/Deactivate mode
 11143	[    0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized
 11144	[    0.000000] random: get_random_bytes called from start_kernel+0x378/0x538 with crng_init=0
 11145	[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
 11146	[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
 11147	[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
 11148	[    0.000243] Console: colour dummy device 80x25
 11149	[    0.000277] printk: console [tty1] enabled
 11150	[    0.000365] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
 11151	[    0.000378] pid_max: default: 32768 minimum: 301
 11152	[    0.000462] LSM: Security Framework initializing
 11153	[    0.000487] Yama: becoming mindful.
 11154	[    0.000577] AppArmor: AppArmor initialized
 11155	[    0.000628] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
 11156	[    0.000646] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
 11157	[    0.002640] rcu: Hierarchical SRCU implementation.
 11158	[    0.005061] EFI services will not be available.
 11159	[    0.005478] smp: Bringing up secondary CPUs ...
 11160	[    0.006152] Detected VIPT I-cache on CPU1
 11161	[    0.006214] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
 11162	[    0.007403] CPU features: detected: ARM erratum 858921
 11163	[    0.007412] CPU features: detected: Spectre-v2
 11164	[    0.007416] CPU features: detected: Spectre-v4
 11165	[    0.007422] Detected VIPT I-cache on CPU2
 11166	[    0.007447] arch_timer: Enabling local workaround for ARM erratum 858921
 11167	[    0.007462] arch_timer: CPU2: Trapping CNTVCT access
 11168	[    0.007475] CPU2: Booted secondary processor 0x0000000100 [0x410fd092]
 11169	[    0.008177] Detected VIPT I-cache on CPU3
 11170	[    0.008193] arch_timer: Enabling local workaround for ARM erratum 858921
 11171	[    0.008200] arch_timer: CPU3: Trapping CNTVCT access
 11172	[    0.008207] CPU3: Booted secondary processor 0x0000000101 [0x410fd092]
 11173	[    0.008832] Detected VIPT I-cache on CPU4
 11174	[    0.008848] arch_timer: Enabling local workaround for ARM erratum 858921
 11175	[    0.008855] arch_timer: CPU4: Trapping CNTVCT access
 11176	[    0.008863] CPU4: Booted secondary processor 0x0000000102 [0x410fd092]
 11177	[    0.009474] Detected VIPT I-cache on CPU5
 11178	[    0.009490] arch_timer: Enabling local workaround for ARM erratum 858921
 11179	[    0.009497] arch_timer: CPU5: Trapping CNTVCT access
 11180	[    0.009505] CPU5: Booted secondary processor 0x0000000103 [0x410fd092]
 11181	[    0.009586] smp: Brought up 1 node, 6 CPUs
 11182	[    0.009604] SMP: Total of 6 processors activated.
 11183	[    0.009611] CPU features: detected: 32-bit EL0 Support
 11184	[    0.009617] CPU features: detected: CRC32 instructions
 11185	[    0.009622] CPU features: detected: 32-bit EL1 Support
 11186	[    0.020853] CPU: All CPU(s) started at EL2
 11187	[    0.020903] alternatives: patching kernel code
 11188	[    0.022843] devtmpfs: initialized
 11189	[    0.030508] Registered cp15_barrier emulation handler
 11190	[    0.030522] Registered setend emulation handler
 11191	[    0.030656] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
 11192	[    0.030694] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
 11193	[    0.044580] pinctrl core: initialized pinctrl subsystem
 11194	[    0.045324] DMI not present or invalid.
 11195	[    0.045699] NET: Registered protocol family 16
 11196	[    0.047199] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
 11197	[    0.047474] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
 11198	[    0.047700] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
 11199	[    0.047745] audit: initializing netlink subsys (disabled)
 11200	[    0.047864] audit: type=2000 audit(0.044:1): state=initialized audit_enabled=0 res=1
 11201	[    0.049145] thermal_sys: Registered thermal governor 'fair_share'
 11202	[    0.049153] thermal_sys: Registered thermal governor 'bang_bang'
 11203	[    0.049157] thermal_sys: Registered thermal governor 'step_wise'
 11204	[    0.049160] thermal_sys: Registered thermal governor 'user_space'
 11205	[    0.049604] cpuidle: using governor menu
 11206	[    0.049953] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
 11207	[    0.050071] ASID allocator initialised with 65536 entries
 11208	[    0.050992] Serial: AMBA PL011 UART driver
 11209	[    0.085548] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
 11210	[    0.085561] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
 11211	[    0.085567] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
 11212	[    0.085572] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
 11213	[    0.087734] cryptd: max_cpu_qlen set to 1000
 11214	[    0.156263] raid6: neonx8   gen()  2780 MB/s
 11215	[    0.224328] raid6: neonx8   xor()  2042 MB/s
 11216	[    0.292425] raid6: neonx4   gen()  2199 MB/s
 11217	[    0.360467] raid6: neonx4   xor()  2349 MB/s
 11218	[    0.428539] raid6: neonx2   gen()  2579 MB/s
 11219	[    0.496618] raid6: neonx2   xor()  2142 MB/s
 11220	[    0.564675] raid6: neonx1   gen()  2010 MB/s
 11221	[    0.632736] raid6: neonx1   xor()  1723 MB/s
 11222	[    0.700816] raid6: int64x8  gen()  1376 MB/s
 11223	[    0.768867] raid6: int64x8  xor()   735 MB/s
 11224	[    0.836957] raid6: int64x4  gen()  1463 MB/s
 11225	[    0.905010] raid6: int64x4  xor()   733 MB/s
 11226	[    0.973066] raid6: int64x2  gen()  1362 MB/s
 11227	[    1.041145] raid6: int64x2  xor()   619 MB/s
 11228	[    1.109195] raid6: int64x1  gen()  1120 MB/s
 11229	[    1.177273] raid6: int64x1  xor()   462 MB/s
 11230	[    1.177276] raid6: using algorithm neonx8 gen() 2780 MB/s
 11231	[    1.177279] raid6: .... xor() 2042 MB/s, rmw enabled
 11232	[    1.177284] raid6: using neon recovery algorithm
 11233	[    1.177731] ACPI: Interpreter disabled.
 11234	[    1.178497] 5V: supplied by 12V
 11235	[    1.179384] VDDAO_3V3: supplied by 12V
 11236	[    1.179852] iommu: Default domain type: Translated
 11237	[    1.179978] vgaarb: loaded
 11238	[    1.180999] SCSI subsystem initialized
 11239	[    1.181208] usbcore: registered new interface driver usbfs
 11240	[    1.181248] usbcore: registered new interface driver hub
 11241	[    1.181285] usbcore: registered new device driver usb
 11242	[    1.181619] pps_core: LinuxPPS API ver. 1 registered
 11243	[    1.181626] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
 11244	[    1.181645] PTP clock support registered
 11245	[    1.181834] EDAC MC: Ver: 3.0.0
 11246	[    1.183109] NetLabel: Initializing
 11247	[    1.183117] NetLabel:  domain hash size = 128
 11248	[    1.183119] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
 11249	[    1.183161] NetLabel:  unlabeled traffic allowed by default
 11250	[    1.183598] clocksource: Switched to clocksource arch_sys_counter
 11251	[    1.183796] VFS: Disk quotas dquot_6.6.0
 11252	[    1.183838] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
 11253	[    1.184212] AppArmor: AppArmor Filesystem Enabled
 11254	[    1.184263] pnp: PnP ACPI: disabled
 11255	[    1.190007] NET: Registered protocol family 2
 11256	[    1.190506] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
 11257	[    1.190610] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
 11258	[    1.190868] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
 11259	[    1.191055] TCP: Hash tables configured (established 32768 bind 32768)
 11260	[    1.191211] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
 11261	[    1.191276] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
 11262	[    1.191322] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
 11263	[    1.191466] NET: Registered protocol family 1
 11264	[    1.191490] PCI: CLS 0 bytes, default 64
 11265	[    1.191679] Trying to unpack rootfs image as initramfs...
 11266	[    1.727228] Freeing initrd memory: 13544K
 11267	[    1.728130] kvm [1]: IPA Size Limit: 40 bits
 11268	[    1.728836] kvm [1]: vgic interrupt IRQ9
 11269	[    1.728971] kvm [1]: Hyp mode initialized successfully
 11270	[    1.733976] Initialise system trusted keyrings
 11271	[    1.734005] Key type blacklist registered
 11272	[    1.734136] workingset: timestamp_bits=44 max_order=20 bucket_order=0
 11273	[    1.737339] zbud: loaded
 11274	[    1.738309] squashfs: version 4.0 (2009/01/31) Phillip Lougher
 11275	[    1.738779] fuse: init (API version 7.32)
 11276	[    1.739610] integrity: Platform Keyring initialized
 11277	[    1.768156] xor: measuring software checksum speed
 11278	[    1.770994]    8regs           :  3473 MB/sec
 11279	[    1.773573]    32regs          :  4023 MB/sec
 11280	[    1.776228]    arm64_neon      :  3719 MB/sec
 11281	[    1.776231] xor: using function: 32regs (4023 MB/sec)
 11282	[    1.776238] Key type asymmetric registered
 11283	[    1.776242] Asymmetric key parser 'x509' registered
 11284	[    1.776279] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
 11285	[    1.776388] io scheduler mq-deadline registered
 11286	[    1.776391] io scheduler kyber registered
 11287	[    1.776474] io scheduler bfq registered
 11288	[    1.778959] gpio-447 (usb-hub-reset): hogged as output/high
 11289	[    1.781851] EINJ: ACPI disabled.
 11290	[    1.788126] soc soc0: Amlogic Meson G12B (S922X) Revision 29:a (40:2) Detected
 11291	[    1.789487] VCC_3V3: supplied by VDDAO_3V3
 11292	[    1.789536] FLASH_1V8: supplied by VCC_3V3
 11293	[    1.789569] VCC_1V8: supplied by VCC_3V3
 11294	[    1.789595] VDDAO_1V8: supplied by VDDAO_3V3
 11295	[    1.789625] VDDCPU_A: supplied by regulator-dummy
 11296	[    1.789980] VDDCPU_B: supplied by regulator-dummy
 11297	[    1.790644] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
 11298	[    1.792922] Serial: AMBA driver
 11299	[    1.793207] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart
 11300	[    1.793301] printk: console [ttyAML0] enabled
 11301	[    1.793814] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 33, base_baud = 1500000) is a meson_uart
 11302	[    1.799166] loop: module loaded
 11303	[    1.801145] libphy: Fixed MDIO Bus: probed
 11304	[    1.802286] tun: Universal TUN/TAP device driver, 1.6
 11305	[    1.802922] thunder_xcv, ver 1.0
 11306	[    1.802956] thunder_bgx, ver 1.0
 11307	[    1.802987] nicpf, ver 1.0
 11308	[    1.803440] e1000e: Intel(R) PRO/1000 Network Driver
 11309	[    1.803444] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
 11310	[    1.803490] igb: Intel(R) Gigabit Ethernet Network Driver
 11311	[    1.803493] igb: Copyright (c) 2007-2014 Intel Corporation.
 11312	[    1.803525] igbvf: Intel(R) Gigabit Virtual Function Network Driver
 11313	[    1.803528] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
 11314	[    1.803984] sky2: driver version 1.30
 11315	[    1.804406] VFIO - User Level meta-driver version: 0.3
 11316	[    1.805715] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
 11317	[    1.805736] ehci-pci: EHCI PCI platform driver
 11318	[    1.805768] ehci-platform: EHCI generic platform driver
 11319	[    1.805894] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
 11320	[    1.805905] ohci-pci: OHCI PCI platform driver
 11321	[    1.805936] ohci-platform: OHCI generic platform driver
 11322	[    1.806323] usbcore: registered new interface driver usb-storage
 11323	[    1.807625] mousedev: PS/2 mouse device common for all mice
 11324	[    1.808054] i2c /dev entries driver
 11325	[    1.813203] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17
 11326	[    1.813869] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz
 11327	[    1.814544] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-1 failed:-17
 11328	[    1.815164] sdhci: Secure Digital Host Controller Interface driver
 11329	[    1.815172] sdhci: Copyright(c) Pierre Ossman
 11330	[    1.815271] Synopsys Designware Multimedia Card Interface Driver
 11331	[    1.815704] sdhci-pltfm: SDHCI platform and OF driver helper
 11332	[    1.816155] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq
 11333	[    1.816543] ledtrig-cpu: registered to indicate activity on CPUs
 11334	[    1.817004] meson-sm: secure-monitor enabled
 11335	[    1.817197] hid: raw HID events driver (C) Jiri Kosina
 11336	[    1.817296] usbcore: registered new interface driver usbhid
 11337	[    1.817299] usbhid: USB HID core driver
 11338	[    1.818300] NET: Registered protocol family 10
 11339	[    1.818758] Segment Routing with IPv6
 11340	[    1.818788] NET: Registered protocol family 17
 11341	[    1.818851] 8021q: 802.1Q VLAN Support v1.8
 11342	[    1.818874] Key type dns_resolver registered
 11343	[    1.819149] registered taskstats version 1
 11344	[    1.819155] Loading compiled-in X.509 certificates
 11345	[    1.820921] Loaded X.509 cert 'Build time autogenerated kernel key: f47c178852ca39740c3546b008122b65f5ed9bce'
 11346	[    1.822523] zswap: loaded using pool zstd/z3fold
 11347	[    1.822706] Key type ._fscrypt registered
 11348	[    1.822708] Key type .fscrypt registered
 11349	[    1.822710] Key type fscrypt-provisioning registered
 11350	[    1.823845] Btrfs loaded, crc32c=crc32c-generic
 11351	[    1.829735] Key type encrypted registered
 11352	[    1.829746] AppArmor: AppArmor sha1 policy hashing enabled
 11353	[    1.836381] HUB_5V: supplied by 5V
 11354	[    1.836565] USB_PWR_EN: supplied by 5V
 11355	[    1.838164] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2
 11356	[    1.838172] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1
 11357	[    1.840921] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator
 11358	[    1.840977] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator
 11359	[    1.841085] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM
 11360	[    1.841675] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
 11361	[    1.841687] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
 11362	[    1.841809] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010
 11363	[    1.841852] xhci-hcd xhci-hcd.0.auto: irq 41, io mem 0xff500000
 11364	[    1.841983] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
 11365	[    1.841987] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 11366	[    1.841990] usb usb1: Product: xHCI Host Controller
 11367	[    1.841992] usb usb1: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
 11368	[    1.841995] usb usb1: SerialNumber: xhci-hcd.0.auto
 11369	[    1.842189] hub 1-0:1.0: USB hub found
 11370	[    1.842203] hub 1-0:1.0: 2 ports detected
 11371	[    1.842330] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
 11372	[    1.842337] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
 11373	[    1.842349] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
 11374	[    1.842371] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
 11375	[    1.842402] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
 11376	[    1.842406] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 11377	[    1.842408] usb usb2: Product: xHCI Host Controller
 11378	[    1.842411] usb usb2: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
 11379	[    1.842413] usb usb2: SerialNumber: xhci-hcd.0.auto
 11380	[    1.842563] hub 2-0:1.0: USB hub found
 11381	[    1.842574] hub 2-0:1.0: 1 port detected
 11382	[    1.844282] meson-gx-mmc ffe05000.sd: Got CD GPIO
 11383	[    1.868678] Freeing unused kernel memory: 3328K
 11384	[    1.915653] Run /init as init process
 11385	[    1.915657]   with arguments:
 11386	[    1.915659]     /init
 11387	[    1.915661]   with environment:
 11388	[    1.915663]     HOME=/
 11389	[    1.915664]     TERM=linux
 11390	[    1.915666]     hdmimode=custombuilt
 11391	[    1.915667]     cvbsmode=576cvbs
 11392	[    1.915668]     max_freq_a53=1896
 11393	[    1.915670]     max_freq_a73=1800
 11394	[    1.915672]     voutmode=hdmi
 11395	[    1.915674]     modeline=1920,1080,148500,56250,50,1920,2448,2492,2640,1080,1084,1089,1125,1,1,1
 11396	[    1.915675]     disablehpd=false
 11397	[    1.915677]     cvbscable=
 11398	[    1.915678]     overscan=100
 11399	[    1.933801] mmc0: new ultra high speed SDR25 SDHC card at address b368
 11400	[    1.934373] mmcblk0: mmc0:b368 CBADS 30.0 GiB
 11401	[    1.936281]  mmcblk0: p1
 11402	[    2.067075] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found
 11403	[    2.067083] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found
 11404	[    2.067184] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock
 11405	[    2.068505] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37
 11406	[    2.068517] meson8b-dwmac ff3f0000.ethernet: 	DWMAC1000
 11407	[    2.068521] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported
 11408	[    2.068524] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported
 11409	[    2.068527] meson8b-dwmac ff3f0000.ethernet: COE Type 2
 11410	[    2.068529] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported
 11411	[    2.068531] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported
 11412	[    2.068576] meson8b-dwmac ff3f0000.ethernet: Normal descriptors
 11413	[    2.068578] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled
 11414	[    2.068581] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
 11415	[    2.068814] libphy: stmmac: probed
 11416	[    2.069937] libphy: mdio_mux: probed
 11417	[    2.077661] meson-vrtc ff8000a8.rtc: registered as rtc1
 11418	[    2.090849] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
 11419	[    2.091389] rtc-pcf8563 1-0051: registered as rtc0
 11420	[    2.092615] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
 11421	[    2.092624] rtc-pcf8563 1-0051: hctosys: unable to read the hardware clock
 11422	[    2.101266] random: fast init done
 11423	[    2.175719] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
 11424	[    2.200345] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.04
 11425	[    2.200351] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
 11426	[    2.200354] usb 2-1: Product: USB3.1 Hub
 11427	[    2.200357] usb 2-1: Manufacturer: GenesysLogic
 11428	[    2.226613] hub 2-1:1.0: USB hub found
 11429	[    2.226901] hub 2-1:1.0: 4 ports detected
 11430	[    2.276066] libphy: mdio_mux: probed
 11431	[    2.323607] usb 1-1: new high-speed USB device number 2 using xhci-hcd
 11432	[    2.473901] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.04
 11433	[    2.473905] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
 11434	[    2.473908] usb 1-1: Product: USB2.1 Hub
 11435	[    2.473910] usb 1-1: Manufacturer: GenesysLogic
 11436	[    2.514562] hub 1-1:1.0: USB hub found
 11437	[    2.514805] hub 1-1:1.0: 4 ports detected
 11438	[    2.703595] usb 1-2: new high-speed USB device number 3 using xhci-hcd
 11439	[    2.852024] usb 1-2: New USB device found, idVendor=2013, idProduct=025f, bcdDevice= 1.00
 11440	[    2.852027] usb 1-2: New USB device strings: Mfr=3, Product=1, SerialNumber=2
 11441	[    2.852030] usb 1-2: Product: PCTV 292e
 11442	[    2.852032] usb 1-2: Manufacturer: PCTV
 11443	[    2.852035] usb 1-2: SerialNumber: 0011356964
 11444	[    3.165425] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
 11445	[    3.967889] systemd[1]: System time before build time, advancing clock.
 11446	[    3.982713] systemd[1]: Inserted module 'autofs4'
 11447	[    4.029161] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
 11448	[    4.029377] systemd[1]: Detected architecture arm64.
 11449	[    4.062216] systemd[1]: Set hostname to <odroidn2>.
 11450	[    4.389632] random: systemd: uninitialized urandom read (16 bytes read)
 11451	[    4.392934] random: systemd: uninitialized urandom read (16 bytes read)
 11452	[    4.393251] systemd[1]: Listening on Journal Socket.
 11453	[    4.393470] random: systemd: uninitialized urandom read (16 bytes read)
 11454	[    4.393595] systemd[1]: Listening on udev Kernel Socket.
 11455	[    4.394873] systemd[1]: Created slice system-serial\x2dgetty.slice.
 11456	[    4.395312] systemd[1]: Created slice User and Session Slice.
 11457	[    4.396716] systemd[1]: Starting Nameserver information manager...
 11458	[    4.397068] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
 11459	[    4.397241] systemd[1]: Reached target Swap.
 11460	[    4.493010] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
 11461	[    4.969191] zram: Added device: zram0
 11462	[    4.969717] zram: Added device: zram1
 11463	[    4.970030] zram: Added device: zram2
 11464	[    5.037925] pwm-gpio pwmgpio: 1 gpio pwms loaded
 11465	[    5.202129] mc: Linux media interface: v0.10
 11466	[    5.213531] meson-saradc ff809000.adc: supply vref not found, using dummy regulator
 11467	[    5.289369] videodev: Linux video capture interface: v2.00
 11468	[    5.307981] panfrost ffe40000.gpu: clock rate = 24000000
 11469	[    5.308054] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19
 11470	[    5.310701] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0
 11471	[    5.310711] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400
 11472	[    5.310716] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
 11473	[    5.310719] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1
 11474	[    5.326542] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 0
 11475	[    5.339636] Registered IR keymap rc-odroid
 11476	[    5.356099] zram0: detected capacity change from 0 to 1904500736
 11477	[    5.358453] meson-drm ff900000.vpu: Queued 2 outputs on vpu
 11478	[    5.381076] IR NEC protocol handler initialized
 11479	[    5.403199] meson-drm ff900000.vpu: CVBS Output connector not available
 11480	[    5.409173] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0
 11481	[    5.409369] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
 11482	[    5.409444] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input0
 11483	[    5.413196] meson-ir ff808000.ir: receiver initialized
 11484	[    5.431691] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
 11485	[    5.432139] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
 11486	[    5.432594] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
 11487	[    5.432953] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 1
 11488	[    5.440656] em28xx 1-2:1.0: New device PCTV PCTV 292e @ 480 Mbps (2013:025f, interface 0, class 0)
 11489	[    5.440664] em28xx 1-2:1.0: DVB interface 0 found: isoc
 11490	[    5.472251] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
 11491	[    5.499681] em28xx 1-2:1.0: chip ID is em28178
 11492	[    5.735758] Console: switching to colour frame buffer device 240x67
 11493	[    5.762283] meson-drm ff900000.vpu: [drm] fb0: mesondrmfb frame buffer device
 11494	[    5.794819] axg-sound-card sound: ASoC: no DMI vendor name!
 11495	[    6.443618] Adding 1859860k swap on /dev/zram0.  Priority:5 extents:1 across:1859860k SSFS
 11496	[    6.510476] zram1: detected capacity change from 0 to 52428800
 11497	[    7.525825] em28xx 1-2:1.0: EEPROM ID = 26 00 01 00, EEPROM hash = 0x8d0cfd04
 11498	[    7.525830] em28xx 1-2:1.0: EEPROM info:
 11499	[    7.525833] em28xx 1-2:1.0: 	microcode start address = 0x0004, boot configuration = 0x01
 11500	[    7.531939] em28xx 1-2:1.0: 	AC97 audio (5 sample rates)
 11501	[    7.531941] em28xx 1-2:1.0: 	500mA max power
 11502	[    7.531945] em28xx 1-2:1.0: 	Table at offset 0x27, strings=0x146a, 0x1888, 0x0a7e
 11503	[    7.591593] em28xx 1-2:1.0: Identified as PCTV tripleStick (292e) (card=94)
 11504	[    7.591598] em28xx 1-2:1.0: dvb set to isoc mode.
 11505	[    7.591735] usbcore: registered new interface driver em28xx
 11506	[    7.617995] em28xx 1-2:1.0: Binding DVB extension
 11507	[    7.631323] i2c i2c-4: Added multiplexed i2c bus 5
 11508	[    7.631331] si2168 4-0064: Silicon Labs Si2168-B40 successfully identified
 11509	[    7.631333] si2168 4-0064: firmware version: B 4.0.2
 11510	[    7.642427] si2157 5-0060: Silicon Labs Si2147/2148/2157/2158 successfully attached
 11511	[    7.642464] dvbdev: DVB: registering new adapter (1-2:1.0)
 11512	[    7.642470] em28xx 1-2:1.0: DVB: registering adapter 0 frontend 0 (Silicon Labs Si2168)...
 11513	[    7.642476] dvbdev: dvb_create_media_entity: media entity 'Silicon Labs Si2168' registered.
 11514	[    7.643120] dvbdev: dvb_create_media_entity: media entity 'dvb-demux' registered.
 11515	[    7.644552] em28xx 1-2:1.0: DVB extension successfully initialized
 11516	[    7.644561] em28xx: Registered (Em28xx dvb Extension) extension
 11517	[    7.651675] em28xx 1-2:1.0: Registering input extension
 11518	[    7.683612] Registered IR keymap rc-pinnacle-pctv-hd
 11519	[    7.683795] rc rc1: PCTV tripleStick (292e) as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-2/1-2:1.0/rc/rc1
 11520	[    7.683895] rc rc1: lirc_dev: driver em28xx registered at minor = 1, scancode receiver, no transmitter
 11521	[    7.683957] input: PCTV tripleStick (292e) as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-2/1-2:1.0/rc/rc1/input1
 11522	[    7.684037] em28xx 1-2:1.0: Input extension successfully initialized
 11523	[    7.684040] em28xx: Registered (Em28xx Input Extension) extension
 11524	[    8.594186] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
 11525	[    8.594206] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
 11526	[    9.669553] systemd[1]: Started Armbian memory supported logging.
 11527	[    9.671912] systemd[1]: Starting Journal Service...
 11528	[    9.734745] systemd[1]: Started Journal Service.
 11529	[    9.759818] systemd-journald[1843]: Received request to flush runtime journal from PID 1
 11530
 11531	### armbian-release:
 11532
 11533	# PLEASE DO NOT EDIT THIS FILE
 11534	BOARD=odroidn2
 11535	BOARD_NAME="Odroid N2"
 11536	BOARDFAMILY=meson-g12b
 11537	BUILD_REPOSITORY_URL=https://github.com/armbian/build
 11538	BUILD_REPOSITORY_COMMIT=5f03d652
 11539	DISTRIBUTION_CODENAME=buster
 11540	DISTRIBUTION_STATUS=supported
 11541	VERSION=21.02.1
 11542	LINUXFAMILY=meson64
 11543	BRANCH=current
 11544	ARCH=arm64
 11545	IMAGE_TYPE=stable
 11546	BOARD_TYPE=conf
 11547	INITRD_ARCH=arm64
 11548	KERNEL_IMAGE_TYPE=Image
 11549
 11550	### boot environment:
 11551
 11552	verbosity=1
 11553	console=both
 11554	overlay_prefix=meson
 11555	rootdev=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c
 11556	rootfstype=ext4
 11557	usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
 11558
 11559	### lsusb:
 11560
 11561	Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc.
 11562	Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
 11563	Bus 001 Device 003: ID 2013:025f PCTV Systems
 11564	Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
 11565	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
 11566
 11567	### lscpu:
 11568
 11569	Architecture:        aarch64
 11570	Byte Order:          Little Endian
 11571	CPU(s):              6
 11572	On-line CPU(s) list: 0-5
 11573	Thread(s) per core:  1
 11574	Core(s) per socket:  3
 11575	Socket(s):           2
 11576	NUMA node(s):        1
 11577	Vendor ID:           ARM
 11578	Model:               4
 11579	Model name:          Cortex-A53
 11580	Stepping:            r0p4
 11581	CPU max MHz:         1992.0000
 11582	CPU min MHz:         100.0000
 11583	BogoMIPS:            48.00
 11584	L1d cache:           unknown size
 11585	L1i cache:           unknown size
 11586	L2 cache:            unknown size
 11587	NUMA node0 CPU(s):   0-5
 11588	Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 11589
 11590	### cpuinfo:
 11591
 11592	processor	: 0
 11593	BogoMIPS	: 48.00
 11594	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 11595	CPU implementer	: 0x41
 11596	CPU architecture: 8
 11597	CPU variant	: 0x0
 11598	CPU part	: 0xd03
 11599	CPU revision	: 4
 11600
 11601	processor	: 1
 11602	BogoMIPS	: 48.00
 11603	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 11604	CPU implementer	: 0x41
 11605	CPU architecture: 8
 11606	CPU variant	: 0x0
 11607	CPU part	: 0xd03
 11608	CPU revision	: 4
 11609
 11610	processor	: 2
 11611	BogoMIPS	: 48.00
 11612	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 11613	CPU implementer	: 0x41
 11614	CPU architecture: 8
 11615	CPU variant	: 0x0
 11616	CPU part	: 0xd09
 11617	CPU revision	: 2
 11618
 11619	processor	: 3
 11620	BogoMIPS	: 48.00
 11621	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 11622	CPU implementer	: 0x41
 11623	CPU architecture: 8
 11624	CPU variant	: 0x0
 11625	CPU part	: 0xd09
 11626	CPU revision	: 2
 11627
 11628	processor	: 4
 11629	BogoMIPS	: 48.00
 11630	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 11631	CPU implementer	: 0x41
 11632	CPU architecture: 8
 11633	CPU variant	: 0x0
 11634	CPU part	: 0xd09
 11635	CPU revision	: 2
 11636
 11637	processor	: 5
 11638	BogoMIPS	: 48.00
 11639	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 11640	CPU implementer	: 0x41
 11641	CPU architecture: 8
 11642	CPU variant	: 0x0
 11643	CPU part	: 0xd09
 11644	CPU revision	: 2
 11645
 11646
 11647	### meminfo:
 11648
 11649	MemTotal:        3719728 kB
 11650	MemFree:         3387708 kB
 11651	MemAvailable:    3341416 kB
 11652	Buffers:           11444 kB
 11653	Cached:            44648 kB
 11654	SwapCached:            0 kB
 11655	Active:            28856 kB
 11656	Inactive:         189808 kB
 11657	Active(anon):        132 kB
 11658	Inactive(anon):   167428 kB
 11659	Active(file):      28724 kB
 11660	Inactive(file):    22380 kB
 11661	Unevictable:           0 kB
 11662	Mlocked:               0 kB
 11663	SwapTotal:       1859860 kB
 11664	SwapFree:        1859860 kB
 11665	Dirty:              4916 kB
 11666	Writeback:             0 kB
 11667	AnonPages:        162660 kB
 11668	Mapped:            13696 kB
 11669	Shmem:              4976 kB
 11670	KReclaimable:      13028 kB
 11671	Slab:              40732 kB
 11672	SReclaimable:      13028 kB
 11673	SUnreclaim:        27704 kB
 11674	KernelStack:        2544 kB
 11675	PageTables:         6396 kB
 11676	NFS_Unstable:          0 kB
 11677	Bounce:                0 kB
 11678	WritebackTmp:          0 kB
 11679	CommitLimit:     3719724 kB
 11680	Committed_AS:    4240552 kB
 11681	VmallocTotal:   135290159040 kB
 11682	VmallocUsed:       33200 kB
 11683	VmallocChunk:          0 kB
 11684	Percpu:             1368 kB
 11685	HardwareCorrupted:     0 kB
 11686	AnonHugePages:         0 kB
 11687	ShmemHugePages:        0 kB
 11688	ShmemPmdMapped:        0 kB
 11689	FileHugePages:         0 kB
 11690	FilePmdMapped:         0 kB
 11691	CmaTotal:         917504 kB
 11692	CmaFree:          901724 kB
 11693	HugePages_Total:       0
 11694	HugePages_Free:        0
 11695	HugePages_Rsvd:        0
 11696	HugePages_Surp:        0
 11697	Hugepagesize:       2048 kB
 11698	Hugetlb:               0 kB
 11699
 11700	### virtual memory:
 11701
 11702	vm.admin_reserve_kbytes = 8192
 11703	vm.block_dump = 0
 11704	vm.compaction_proactiveness = 20
 11705	vm.compact_unevictable_allowed = 1
 11706	vm.dirty_background_bytes = 0
 11707	vm.dirty_background_ratio = 10
 11708	vm.dirty_bytes = 0
 11709	vm.dirty_expire_centisecs = 3000
 11710	vm.dirty_ratio = 20
 11711	vm.dirtytime_expire_seconds = 43200
 11712	vm.dirty_writeback_centisecs = 500
 11713	vm.extfrag_threshold = 500
 11714	vm.hugetlb_shm_group = 0
 11715	vm.laptop_mode = 0
 11716	vm.legacy_va_layout = 0
 11717	vm.lowmem_reserve_ratio = 256	256	32	0
 11718	vm.max_map_count = 65530
 11719	vm.memory_failure_early_kill = 0
 11720	vm.memory_failure_recovery = 1
 11721	vm.min_free_kbytes = 45056
 11722	vm.min_slab_ratio = 5
 11723	vm.min_unmapped_ratio = 1
 11724	vm.mmap_min_addr = 4096
 11725	vm.mmap_rnd_bits = 18
 11726	vm.mmap_rnd_compat_bits = 11
 11727	vm.nr_hugepages = 0
 11728	vm.nr_hugepages_mempolicy = 0
 11729	vm.nr_overcommit_hugepages = 0
 11730	vm.numa_stat = 1
 11731	vm.numa_zonelist_order = Node
 11732	vm.oom_dump_tasks = 1
 11733	vm.oom_kill_allocating_task = 0
 11734	vm.overcommit_kbytes = 0
 11735	vm.overcommit_memory = 0
 11736	vm.overcommit_ratio = 50
 11737	vm.page-cluster = 0
 11738	vm.page_lock_unfairness = 5
 11739	vm.panic_on_oom = 0
 11740	vm.percpu_pagelist_fraction = 0
 11741	vm.stat_interval = 1
 11742	vm.swappiness = 100
 11743	vm.user_reserve_kbytes = 115049
 11744	vm.vfs_cache_pressure = 100
 11745	vm.watermark_boost_factor = 15000
 11746	vm.watermark_scale_factor = 10
 11747	vm.zone_reclaim_mode = 0
 11748
 11749	### ip addr:
 11750
 11751	1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
 11752	    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
 11753	    inet XXX.XXX.0.1/8 scope host lo
 11754	       valid_lft forever preferred_lft forever
 11755	    inet6 ::1/128 scope host
 11756	       valid_lft forever preferred_lft forever
 11757	2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
 11758	    link/ether 00:1e:06:42:03:f8 brd ff:ff:ff:ff:ff:ff
 11759
 11760	### partitions:
 11761
 11762	major minor  #blocks  name
 11763
 11764	 179        0   31464960 mmcblk0
 11765	 179        1   31146208 mmcblk0p1
 11766	 252        0    1859864 zram0
 11767	 252        1      51200 zram1
 11768
 11769	### df:
 11770
 11771	udev            1.4G     0  1.4G   0% /dev
 11772	tmpfs           364M  4.9M  359M   2% /run
 11773	/dev/mmcblk0p1   30G  1.7G   28G   6% /
 11774	tmpfs           1.8G     0  1.8G   0% /dev/shm
 11775	tmpfs           5.0M  4.0K  5.0M   1% /run/lock
 11776	tmpfs           1.8G     0  1.8G   0% /sys/fs/cgroup
 11777	tmpfs           1.8G     0  1.8G   0% /tmp
 11778	/dev/zram1       49M  4.8M   41M  11% /var/log
 11779
 11780	### lsblk:
 11781
 11782	NAME        FSTYPE  SIZE MOUNTPOINT UUID
 11783	mmcblk0              30G
 11784	└─mmcblk0p1 ext4   29.7G /          bd34953d-41be-49d6-b1c0-c0c28a5e239c
 11785	zram1                50M /var/log
 11786
 11787	### zramctl:
 11788
 11789	NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
 11790	/dev/zram1 zstd           50M  132K  698B   36K       6 /var/log
 11791	/dev/zram0 lzo-rle       1.8G    4K   74B   12K       6 [SWAP]
 11792
 11793	### mtab:
 11794
 11795	/dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
 11796	/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
 11797	/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
 11798
 11799	### mmc0:b368 info:
 11800
 11801	               fwrev: 0x0
 11802	              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=CBADS MODALIAS=mmc:block
 11803	                 cid: 6f0303434241445310aa002b4d013b00
 11804	                 rca: 0xb368
 11805	                 csd: 400e005a5b590000f00e7f800a404000
 11806	              manfid: 0x00006f
 11807	                 ocr: 0x00200000
 11808	preferred_erase_size: 2097152
 11809	                type: SD
 11810	               hwrev: 0x1
 11811	                date: 11/2019
 11812	                 dsr: 0x404
 11813	          erase_size: 512
 11814	               oemid: 0x0303
 11815	              serial: 0xaa002b4d
 11816	                 ssr: 00000000000000280402800100fd180a001e00000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
 11817	                 scr: 02b5800300000000
 11818	                name: CBADS
 11819
 11820	### Boot system health:
 11821
 11822	Time       big.LITTLE   load %cpu %sys %usr %nice %io %irq   CPU  C.St.
 11823	16:14:53: 1908/1992MHz  2.01  23%  10%   4%   0%   6%   0% 33.3°C  0/11
 11824	16:14:53: 1908/1992MHz  2.01  74%  26%  11%   0%  34%   0% 32.8°C  0/11
 11825	16:14:53: 1908/1992MHz  2.01  83%  20%   1%   0%  60%   0% 30.8°C  0/11
 11826	16:14:54: 1908/1992MHz  2.01  74%  10%   4%   0%  58%   1% 30.7°C  0/11
 11827	16:14:54: 1908/1992MHz  2.01  58%   6%   4%   0%  47%   0% 30.4°C  0/11
 11828
 11829	### Activated 1 lzo-rle zram swap devices with 1816 MB each
 11830
 11831	### Activated Armbian ramlog partition with zstd compression
 11832
 11833	Sun 14 Feb 2021 04:19:55 PM GMT | Odroid N2 | 21.02.1 | arm64 | aarch64 | 5.10.12-meson64
 11834
 11835	### dmesg:
 11836
 11837	[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
 11838	[    0.000000] Linux version 5.10.12-meson64 (root@beast) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #21.02.1 SMP PREEMPT Wed Feb 3 21:06:36 CET 2021
 11839	[    0.000000] Machine model: Hardkernel ODROID-N2
 11840	[    0.000000] efi: UEFI not found.
 11841	[    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
 11842	[    0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB
 11843	[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
 11844	[    0.000000] NUMA: No NUMA configuration found
 11845	[    0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ed7fffff]
 11846	[    0.000000] NUMA: NODE_DATA [mem 0xb502f100-0xb5030fff]
 11847	[    0.000000] Zone ranges:
 11848	[    0.000000]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
 11849	[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000ed7fffff]
 11850	[    0.000000]   Normal   empty
 11851	[    0.000000] Movable zone start for each node
 11852	[    0.000000] Early memory node ranges
 11853	[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000004ffffff]
 11854	[    0.000000]   node   0: [mem 0x0000000005300000-0x00000000ed7fffff]
 11855	[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ed7fffff]
 11856	[    0.000000] On node 0 totalpages: 972032
 11857	[    0.000000]   DMA zone: 4096 pages used for memmap
 11858	[    0.000000]   DMA zone: 0 pages reserved
 11859	[    0.000000]   DMA zone: 261376 pages, LIFO batch:63
 11860	[    0.000000]   DMA32 zone: 11104 pages used for memmap
 11861	[    0.000000]   DMA32 zone: 710656 pages, LIFO batch:63
 11862	[    0.000000] psci: probing for conduit method from DT.
 11863	[    0.000000] psci: PSCIv1.0 detected in firmware.
 11864	[    0.000000] psci: Using standard PSCI v0.2 function IDs
 11865	[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
 11866	[    0.000000] psci: SMC Calling Convention v1.1
 11867	[    0.000000] percpu: Embedded 23 pages/cpu s56728 r8192 d29288 u94208
 11868	[    0.000000] pcpu-alloc: s56728 r8192 d29288 u94208 alloc=23*4096
 11869	[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
 11870	[    0.000000] Detected VIPT I-cache on CPU0
 11871	[    0.000000] CPU features: detected: ARM erratum 845719
 11872	[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 956832
 11873	[    0.000000] Policy zone: DMA32
 11874	[    0.000000] Kernel command line: root=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c rootwait rootfstype=ext4 console=ttyAML0,115200n8 console=tty1 loglevel=1  no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=custombuilt cvbsmode=576cvbs max_freq_a53=1896 max_freq_a73=1800 maxcpus=6 voutmode=hdmi modeline=1920,1080,148500,56250,50,1920,2448,2492,2640,1080,1084,1089,1125,1,1,1 disablehpd=false  cvbscable= overscan=100 consoleblank=0
 11875	[    0.000000] Kernel parameter elevator= does not have any effect anymore.
 11876	               Please use sysfs to set IO scheduler for individual devices.
 11877	[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
 11878	[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
 11879	[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
 11880	[    0.000000] software IO TLB: mapped [mem 0x0000000038ac5000-0x000000003cac5000] (64MB)
 11881	[    0.000000] Memory: 2785352K/3888128K available (14144K kernel code, 1760K rwdata, 5508K rodata, 3328K init, 592K bss, 185272K reserved, 917504K cma-reserved)
 11882	[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
 11883	[    0.000000] rcu: Preemptible hierarchical RCU implementation.
 11884	[    0.000000] rcu: 	RCU event tracing is enabled.
 11885	[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
 11886	[    0.000000] 	Trampoline variant of Tasks RCU enabled.
 11887	[    0.000000] 	Rude variant of Tasks RCU enabled.
 11888	[    0.000000] 	Tracing variant of Tasks RCU enabled.
 11889	[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
 11890	[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
 11891	[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
 11892	[    0.000000] GIC: Using split EOI/Deactivate mode
 11893	[    0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized
 11894	[    0.000000] random: get_random_bytes called from start_kernel+0x378/0x538 with crng_init=0
 11895	[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
 11896	[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
 11897	[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
 11898	[    0.000238] Console: colour dummy device 80x25
 11899	[    0.000273] printk: console [tty1] enabled
 11900	[    0.000362] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
 11901	[    0.000374] pid_max: default: 32768 minimum: 301
 11902	[    0.000458] LSM: Security Framework initializing
 11903	[    0.000485] Yama: becoming mindful.
 11904	[    0.000574] AppArmor: AppArmor initialized
 11905	[    0.000625] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
 11906	[    0.000644] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
 11907	[    0.002640] rcu: Hierarchical SRCU implementation.
 11908	[    0.005020] EFI services will not be available.
 11909	[    0.005441] smp: Bringing up secondary CPUs ...
 11910	[    0.006106] Detected VIPT I-cache on CPU1
 11911	[    0.006168] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
 11912	[    0.007359] CPU features: detected: ARM erratum 858921
 11913	[    0.007367] CPU features: detected: Spectre-v2
 11914	[    0.007370] CPU features: detected: Spectre-v4
 11915	[    0.007377] Detected VIPT I-cache on CPU2
 11916	[    0.007402] arch_timer: Enabling local workaround for ARM erratum 858921
 11917	[    0.007416] arch_timer: CPU2: Trapping CNTVCT access
 11918	[    0.007430] CPU2: Booted secondary processor 0x0000000100 [0x410fd092]
 11919	[    0.008137] Detected VIPT I-cache on CPU3
 11920	[    0.008153] arch_timer: Enabling local workaround for ARM erratum 858921
 11921	[    0.008161] arch_timer: CPU3: Trapping CNTVCT access
 11922	[    0.008168] CPU3: Booted secondary processor 0x0000000101 [0x410fd092]
 11923	[    0.008794] Detected VIPT I-cache on CPU4
 11924	[    0.008811] arch_timer: Enabling local workaround for ARM erratum 858921
 11925	[    0.008818] arch_timer: CPU4: Trapping CNTVCT access
 11926	[    0.008825] CPU4: Booted secondary processor 0x0000000102 [0x410fd092]
 11927	[    0.009441] Detected VIPT I-cache on CPU5
 11928	[    0.009458] arch_timer: Enabling local workaround for ARM erratum 858921
 11929	[    0.009465] arch_timer: CPU5: Trapping CNTVCT access
 11930	[    0.009473] CPU5: Booted secondary processor 0x0000000103 [0x410fd092]
 11931	[    0.009554] smp: Brought up 1 node, 6 CPUs
 11932	[    0.009572] SMP: Total of 6 processors activated.
 11933	[    0.009579] CPU features: detected: 32-bit EL0 Support
 11934	[    0.009585] CPU features: detected: CRC32 instructions
 11935	[    0.009591] CPU features: detected: 32-bit EL1 Support
 11936	[    0.020864] CPU: All CPU(s) started at EL2
 11937	[    0.020912] alternatives: patching kernel code
 11938	[    0.022854] devtmpfs: initialized
 11939	[    0.030542] Registered cp15_barrier emulation handler
 11940	[    0.030556] Registered setend emulation handler
 11941	[    0.030691] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
 11942	[    0.030731] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
 11943	[    0.044674] pinctrl core: initialized pinctrl subsystem
 11944	[    0.045400] DMI not present or invalid.
 11945	[    0.045774] NET: Registered protocol family 16
 11946	[    0.047199] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
 11947	[    0.047471] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
 11948	[    0.047713] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
 11949	[    0.047754] audit: initializing netlink subsys (disabled)
 11950	[    0.047851] audit: type=2000 audit(0.044:1): state=initialized audit_enabled=0 res=1
 11951	[    0.049085] thermal_sys: Registered thermal governor 'fair_share'
 11952	[    0.049092] thermal_sys: Registered thermal governor 'bang_bang'
 11953	[    0.049095] thermal_sys: Registered thermal governor 'step_wise'
 11954	[    0.049099] thermal_sys: Registered thermal governor 'user_space'
 11955	[    0.049502] cpuidle: using governor menu
 11956	[    0.049849] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
 11957	[    0.049974] ASID allocator initialised with 65536 entries
 11958	[    0.050889] Serial: AMBA PL011 UART driver
 11959	[    0.086297] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
 11960	[    0.086306] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
 11961	[    0.086311] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
 11962	[    0.086315] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
 11963	[    0.087746] cryptd: max_cpu_qlen set to 1000
 11964	[    0.156170] raid6: neonx8   gen()  2785 MB/s
 11965	[    0.224232] raid6: neonx8   xor()  2042 MB/s
 11966	[    0.292298] raid6: neonx4   gen()  2976 MB/s
 11967	[    0.360362] raid6: neonx4   xor()  2342 MB/s
 11968	[    0.428428] raid6: neonx2   gen()  2572 MB/s
 11969	[    0.496491] raid6: neonx2   xor()  2139 MB/s
 11970	[    0.564560] raid6: neonx1   gen()  2006 MB/s
 11971	[    0.632626] raid6: neonx1   xor()  1716 MB/s
 11972	[    0.700701] raid6: int64x8  gen()  1363 MB/s
 11973	[    0.768761] raid6: int64x8  xor()   735 MB/s
 11974	[    0.836854] raid6: int64x4  gen()  1462 MB/s
 11975	[    0.904904] raid6: int64x4  xor()   733 MB/s
 11976	[    0.972960] raid6: int64x2  gen()  1362 MB/s
 11977	[    1.041038] raid6: int64x2  xor()   619 MB/s
 11978	[    1.109097] raid6: int64x1  gen()  1120 MB/s
 11979	[    1.177162] raid6: int64x1  xor()   462 MB/s
 11980	[    1.177165] raid6: using algorithm neonx4 gen() 2976 MB/s
 11981	[    1.177168] raid6: .... xor() 2342 MB/s, rmw enabled
 11982	[    1.177172] raid6: using neon recovery algorithm
 11983	[    1.177612] ACPI: Interpreter disabled.
 11984	[    1.178380] 5V: supplied by 12V
 11985	[    1.179280] VDDAO_3V3: supplied by 12V
 11986	[    1.179739] iommu: Default domain type: Translated
 11987	[    1.179865] vgaarb: loaded
 11988	[    1.180797] SCSI subsystem initialized
 11989	[    1.181109] usbcore: registered new interface driver usbfs
 11990	[    1.181146] usbcore: registered new interface driver hub
 11991	[    1.181188] usbcore: registered new device driver usb
 11992	[    1.181521] pps_core: LinuxPPS API ver. 1 registered
 11993	[    1.181527] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
 11994	[    1.181547] PTP clock support registered
 11995	[    1.181736] EDAC MC: Ver: 3.0.0
 11996	[    1.183065] NetLabel: Initializing
 11997	[    1.183073] NetLabel:  domain hash size = 128
 11998	[    1.183076] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
 11999	[    1.183117] NetLabel:  unlabeled traffic allowed by default
 12000	[    1.183606] clocksource: Switched to clocksource arch_sys_counter
 12001	[    1.183830] VFS: Disk quotas dquot_6.6.0
 12002	[    1.183874] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
 12003	[    1.184218] AppArmor: AppArmor Filesystem Enabled
 12004	[    1.184265] pnp: PnP ACPI: disabled
 12005	[    1.189832] NET: Registered protocol family 2
 12006	[    1.190294] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
 12007	[    1.190398] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
 12008	[    1.190654] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
 12009	[    1.190841] TCP: Hash tables configured (established 32768 bind 32768)
 12010	[    1.190993] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
 12011	[    1.191056] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
 12012	[    1.191104] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
 12013	[    1.191244] NET: Registered protocol family 1
 12014	[    1.191268] PCI: CLS 0 bytes, default 64
 12015	[    1.191393] Trying to unpack rootfs image as initramfs...
 12016	[    1.727778] Freeing initrd memory: 13544K
 12017	[    1.728675] kvm [1]: IPA Size Limit: 40 bits
 12018	[    1.729383] kvm [1]: vgic interrupt IRQ9
 12019	[    1.729528] kvm [1]: Hyp mode initialized successfully
 12020	[    1.734620] Initialise system trusted keyrings
 12021	[    1.734655] Key type blacklist registered
 12022	[    1.734757] workingset: timestamp_bits=44 max_order=20 bucket_order=0
 12023	[    1.737934] zbud: loaded
 12024	[    1.738897] squashfs: version 4.0 (2009/01/31) Phillip Lougher
 12025	[    1.739353] fuse: init (API version 7.32)
 12026	[    1.740149] integrity: Platform Keyring initialized
 12027	[    1.768446] xor: measuring software checksum speed
 12028	[    1.771285]    8regs           :  3473 MB/sec
 12029	[    1.773744]    32regs          :  4021 MB/sec
 12030	[    1.776395]    arm64_neon      :  3723 MB/sec
 12031	[    1.776399] xor: using function: 32regs (4021 MB/sec)
 12032	[    1.776405] Key type asymmetric registered
 12033	[    1.776409] Asymmetric key parser 'x509' registered
 12034	[    1.776442] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
 12035	[    1.776527] io scheduler mq-deadline registered
 12036	[    1.776531] io scheduler kyber registered
 12037	[    1.776611] io scheduler bfq registered
 12038	[    1.779103] gpio-447 (usb-hub-reset): hogged as output/high
 12039	[    1.781967] EINJ: ACPI disabled.
 12040	[    1.788280] soc soc0: Amlogic Meson G12B (S922X) Revision 29:a (40:2) Detected
 12041	[    1.789606] VCC_3V3: supplied by VDDAO_3V3
 12042	[    1.789656] FLASH_1V8: supplied by VCC_3V3
 12043	[    1.789686] VCC_1V8: supplied by VCC_3V3
 12044	[    1.789713] VDDAO_1V8: supplied by VDDAO_3V3
 12045	[    1.789742] VDDCPU_A: supplied by regulator-dummy
 12046	[    1.790107] VDDCPU_B: supplied by regulator-dummy
 12047	[    1.790787] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
 12048	[    1.793045] Serial: AMBA driver
 12049	[    1.793328] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart
 12050	[    1.793424] printk: console [ttyAML0] enabled
 12051	[    1.793943] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 33, base_baud = 1500000) is a meson_uart
 12052	[    1.799351] loop: module loaded
 12053	[    1.801224] libphy: Fixed MDIO Bus: probed
 12054	[    1.802175] tun: Universal TUN/TAP device driver, 1.6
 12055	[    1.802798] thunder_xcv, ver 1.0
 12056	[    1.802827] thunder_bgx, ver 1.0
 12057	[    1.802860] nicpf, ver 1.0
 12058	[    1.803295] e1000e: Intel(R) PRO/1000 Network Driver
 12059	[    1.803298] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
 12060	[    1.803342] igb: Intel(R) Gigabit Ethernet Network Driver
 12061	[    1.803346] igb: Copyright (c) 2007-2014 Intel Corporation.
 12062	[    1.803378] igbvf: Intel(R) Gigabit Virtual Function Network Driver
 12063	[    1.803381] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
 12064	[    1.803500] sky2: driver version 1.30
 12065	[    1.803916] VFIO - User Level meta-driver version: 0.3
 12066	[    1.805257] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
 12067	[    1.805274] ehci-pci: EHCI PCI platform driver
 12068	[    1.805303] ehci-platform: EHCI generic platform driver
 12069	[    1.805423] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
 12070	[    1.805433] ohci-pci: OHCI PCI platform driver
 12071	[    1.805462] ohci-platform: OHCI generic platform driver
 12072	[    1.805835] usbcore: registered new interface driver usb-storage
 12073	[    1.807011] mousedev: PS/2 mouse device common for all mice
 12074	[    1.807338] i2c /dev entries driver
 12075	[    1.812503] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17
 12076	[    1.813186] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz
 12077	[    1.813870] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-1 failed:-17
 12078	[    1.814454] sdhci: Secure Digital Host Controller Interface driver
 12079	[    1.814458] sdhci: Copyright(c) Pierre Ossman
 12080	[    1.814564] Synopsys Designware Multimedia Card Interface Driver
 12081	[    1.814976] sdhci-pltfm: SDHCI platform and OF driver helper
 12082	[    1.815420] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq
 12083	[    1.816529] ledtrig-cpu: registered to indicate activity on CPUs
 12084	[    1.816770] meson-sm: secure-monitor enabled
 12085	[    1.816913] hid: raw HID events driver (C) Jiri Kosina
 12086	[    1.816982] usbcore: registered new interface driver usbhid
 12087	[    1.816984] usbhid: USB HID core driver
 12088	[    1.817878] NET: Registered protocol family 10
 12089	[    1.818270] Segment Routing with IPv6
 12090	[    1.818302] NET: Registered protocol family 17
 12091	[    1.818356] 8021q: 802.1Q VLAN Support v1.8
 12092	[    1.818380] Key type dns_resolver registered
 12093	[    1.818650] registered taskstats version 1
 12094	[    1.818657] Loading compiled-in X.509 certificates
 12095	[    1.820454] Loaded X.509 cert 'Build time autogenerated kernel key: f47c178852ca39740c3546b008122b65f5ed9bce'
 12096	[    1.822021] zswap: loaded using pool zstd/z3fold
 12097	[    1.822176] Key type ._fscrypt registered
 12098	[    1.822178] Key type .fscrypt registered
 12099	[    1.822180] Key type fscrypt-provisioning registered
 12100	[    1.823267] Btrfs loaded, crc32c=crc32c-generic
 12101	[    1.829413] Key type encrypted registered
 12102	[    1.829423] AppArmor: AppArmor sha1 policy hashing enabled
 12103	[    1.835671] HUB_5V: supplied by 5V
 12104	[    1.835908] USB_PWR_EN: supplied by 5V
 12105	[    1.837604] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2
 12106	[    1.837611] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1
 12107	[    1.840316] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator
 12108	[    1.840370] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator
 12109	[    1.840474] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM
 12110	[    1.841047] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
 12111	[    1.841058] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
 12112	[    1.841145] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010
 12113	[    1.841166] xhci-hcd xhci-hcd.0.auto: irq 41, io mem 0xff500000
 12114	[    1.841286] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
 12115	[    1.841289] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 12116	[    1.841293] usb usb1: Product: xHCI Host Controller
 12117	[    1.841295] usb usb1: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
 12118	[    1.841297] usb usb1: SerialNumber: xhci-hcd.0.auto
 12119	[    1.841487] hub 1-0:1.0: USB hub found
 12120	[    1.841503] hub 1-0:1.0: 2 ports detected
 12121	[    1.841633] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
 12122	[    1.841639] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
 12123	[    1.841646] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
 12124	[    1.841667] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
 12125	[    1.841698] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
 12126	[    1.841701] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 12127	[    1.841703] usb usb2: Product: xHCI Host Controller
 12128	[    1.841705] usb usb2: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
 12129	[    1.841708] usb usb2: SerialNumber: xhci-hcd.0.auto
 12130	[    1.841894] hub 2-0:1.0: USB hub found
 12131	[    1.841904] hub 2-0:1.0: 1 port detected
 12132	[    1.843005] meson-gx-mmc ffe05000.sd: Got CD GPIO
 12133	[    1.868637] Freeing unused kernel memory: 3328K
 12134	[    1.907725] Run /init as init process
 12135	[    1.907729]   with arguments:
 12136	[    1.907731]     /init
 12137	[    1.907733]   with environment:
 12138	[    1.907735]     HOME=/
 12139	[    1.907737]     TERM=linux
 12140	[    1.907738]     hdmimode=custombuilt
 12141	[    1.907740]     cvbsmode=576cvbs
 12142	[    1.907741]     max_freq_a53=1896
 12143	[    1.907743]     max_freq_a73=1800
 12144	[    1.907744]     voutmode=hdmi
 12145	[    1.907746]     modeline=1920,1080,148500,56250,50,1920,2448,2492,2640,1080,1084,1089,1125,1,1,1
 12146	[    1.907747]     disablehpd=false
 12147	[    1.907749]     cvbscable=
 12148	[    1.907750]     overscan=100
 12149	[    1.933815] mmc0: new ultra high speed SDR25 SDHC card at address b368
 12150	[    1.934392] mmcblk0: mmc0:b368 CBADS 30.0 GiB
 12151	[    1.936413]  mmcblk0: p1
 12152	[    2.060593] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found
 12153	[    2.060600] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found
 12154	[    2.060681] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock
 12155	[    2.064811] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37
 12156	[    2.064824] meson8b-dwmac ff3f0000.ethernet: 	DWMAC1000
 12157	[    2.064827] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported
 12158	[    2.064831] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported
 12159	[    2.064833] meson8b-dwmac ff3f0000.ethernet: COE Type 2
 12160	[    2.064836] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported
 12161	[    2.064838] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported
 12162	[    2.064903] meson8b-dwmac ff3f0000.ethernet: Normal descriptors
 12163	[    2.064906] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled
 12164	[    2.064908] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
 12165	[    2.065130] libphy: stmmac: probed
 12166	[    2.066721] libphy: mdio_mux: probed
 12167	[    2.074428] meson-vrtc ff8000a8.rtc: registered as rtc1
 12168	[    2.092258] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
 12169	[    2.092421] rtc-pcf8563 1-0051: registered as rtc0
 12170	[    2.093806] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
 12171	[    2.093818] rtc-pcf8563 1-0051: hctosys: unable to read the hardware clock
 12172	[    2.098146] random: fast init done
 12173	[    2.179633] usb 1-1: new high-speed USB device number 2 using xhci-hcd
 12174	[    2.272024] libphy: mdio_mux: probed
 12175	[    2.329981] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.04
 12176	[    2.329991] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
 12177	[    2.329994] usb 1-1: Product: USB2.1 Hub
 12178	[    2.329998] usb 1-1: Manufacturer: GenesysLogic
 12179	[    2.385947] hub 1-1:1.0: USB hub found
 12180	[    2.386174] hub 1-1:1.0: 4 ports detected
 12181	[    2.455739] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
 12182	[    2.478216] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.04
 12183	[    2.478222] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
 12184	[    2.478226] usb 2-1: Product: USB3.1 Hub
 12185	[    2.478230] usb 2-1: Manufacturer: GenesysLogic
 12186	[    2.497921] hub 2-1:1.0: USB hub found
 12187	[    2.498215] hub 2-1:1.0: 4 ports detected
 12188	[    2.603616] usb 1-2: new high-speed USB device number 3 using xhci-hcd
 12189	[    2.752647] usb 1-2: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice= 7.02
 12190	[    2.752654] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
 12191	[    2.752657] usb 1-2: Product: USB2.0 Hub
 12192	[    2.801982] hub 1-2:1.0: USB hub found
 12193	[    2.802230] hub 1-2:1.0: 4 ports detected
 12194	[    3.095609] usb 1-2.3: new high-speed USB device number 4 using xhci-hcd
 12195	[    3.196700] usb 1-2.3: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice= 7.02
 12196	[    3.196707] usb 1-2.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
 12197	[    3.196709] usb 1-2.3: Product: USB2.0 Hub
 12198	[    3.203324] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
 12199	[    3.249979] hub 1-2.3:1.0: USB hub found
 12200	[    3.250216] hub 1-2.3:1.0: 4 ports detected
 12201	[    3.335620] usb 1-2.4: new high-speed USB device number 5 using xhci-hcd
 12202	[    3.436077] usb 1-2.4: New USB device found, idVendor=2013, idProduct=025f, bcdDevice= 1.00
 12203	[    3.436084] usb 1-2.4: New USB device strings: Mfr=3, Product=1, SerialNumber=2
 12204	[    3.436087] usb 1-2.4: Product: PCTV 292e
 12205	[    3.436090] usb 1-2.4: Manufacturer: PCTV
 12206	[    3.436092] usb 1-2.4: SerialNumber: 0011356964
 12207	[    4.004221] systemd[1]: System time before build time, advancing clock.
 12208	[    4.019041] systemd[1]: Inserted module 'autofs4'
 12209	[    4.065501] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
 12210	[    4.065726] systemd[1]: Detected architecture arm64.
 12211	[    4.086058] systemd[1]: Set hostname to <odroidn2>.
 12212	[    4.413418] random: systemd: uninitialized urandom read (16 bytes read)
 12213	[    4.416745] random: systemd: uninitialized urandom read (16 bytes read)
 12214	[    4.416957] systemd[1]: Listening on udev Kernel Socket.
 12215	[    4.417293] random: systemd: uninitialized urandom read (16 bytes read)
 12216	[    4.417472] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
 12217	[    4.417651] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
 12218	[    4.418904] systemd[1]: Created slice system-serial\x2dgetty.slice.
 12219	[    4.419292] systemd[1]: Listening on Journal Audit Socket.
 12220	[    4.419390] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
 12221	[    4.419424] systemd[1]: Reached target Paths.
 12222	[    4.479439] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
 12223	[    4.994769] zram: Added device: zram0
 12224	[    4.995025] zram: Added device: zram1
 12225	[    4.995257] zram: Added device: zram2
 12226	[    5.065903] pwm-gpio pwmgpio: 1 gpio pwms loaded
 12227	[    5.226140] meson-saradc ff809000.adc: supply vref not found, using dummy regulator
 12228	[    5.234239] mc: Linux media interface: v0.10
 12229	[    5.299629] Registered IR keymap rc-odroid
 12230	[    5.320594] videodev: Linux video capture interface: v2.00
 12231	[    5.341487] meson-drm ff900000.vpu: Queued 2 outputs on vpu
 12232	[    5.348569] IR NEC protocol handler initialized
 12233	[    5.378177] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0
 12234	[    5.378382] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
 12235	[    5.378495] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input0
 12236	[    5.378768] meson-ir ff808000.ir: receiver initialized
 12237	[    5.388218] meson-drm ff900000.vpu: CVBS Output connector not available
 12238	[    5.392800] panfrost ffe40000.gpu: clock rate = 24000000
 12239	[    5.392884] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19
 12240	[    5.393804] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0
 12241	[    5.393814] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400
 12242	[    5.393819] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
 12243	[    5.393823] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1
 12244	[    5.412878] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 1
 12245	[    5.414510] zram0: detected capacity change from 0 to 1904500736
 12246	[    5.415723] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
 12247	[    5.416087] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
 12248	[    5.416291] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
 12249	[    5.416475] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 0
 12250	[    5.462981] em28xx 1-2.4:1.0: New device PCTV PCTV 292e @ 480 Mbps (2013:025f, interface 0, class 0)
 12251	[    5.462992] em28xx 1-2.4:1.0: DVB interface 0 found: isoc
 12252	[    5.484786] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
 12253	[    5.519758] em28xx 1-2.4:1.0: chip ID is em28178
 12254	[    5.723766] Console: switching to colour frame buffer device 240x67
 12255	[    5.750297] meson-drm ff900000.vpu: [drm] fb0: mesondrmfb frame buffer device
 12256	[    5.783057] axg-sound-card sound: ASoC: no DMI vendor name!
 12257	[    6.475656] Adding 1859860k swap on /dev/zram0.  Priority:5 extents:1 across:1859860k SSFS
 12258	[    6.542233] zram1: detected capacity change from 0 to 52428800
 12259	[    7.557822] em28xx 1-2.4:1.0: EEPROM ID = 26 00 01 00, EEPROM hash = 0x8d0cfd04
 12260	[    7.557826] em28xx 1-2.4:1.0: EEPROM info:
 12261	[    7.557829] em28xx 1-2.4:1.0: 	microcode start address = 0x0004, boot configuration = 0x01
 12262	[    7.563942] em28xx 1-2.4:1.0: 	AC97 audio (5 sample rates)
 12263	[    7.563944] em28xx 1-2.4:1.0: 	500mA max power
 12264	[    7.563947] em28xx 1-2.4:1.0: 	Table at offset 0x27, strings=0x146a, 0x1888, 0x0a7e
 12265	[    7.623605] em28xx 1-2.4:1.0: Identified as PCTV tripleStick (292e) (card=94)
 12266	[    7.623609] em28xx 1-2.4:1.0: dvb set to isoc mode.
 12267	[    7.623720] usbcore: registered new interface driver em28xx
 12268	[    7.650022] em28xx 1-2.4:1.0: Binding DVB extension
 12269	[    7.663304] i2c i2c-4: Added multiplexed i2c bus 5
 12270	[    7.663313] si2168 4-0064: Silicon Labs Si2168-B40 successfully identified
 12271	[    7.663316] si2168 4-0064: firmware version: B 4.0.2
 12272	[    7.671856] si2157 5-0060: Silicon Labs Si2147/2148/2157/2158 successfully attached
 12273	[    7.671939] dvbdev: DVB: registering new adapter (1-2.4:1.0)
 12274	[    7.671949] em28xx 1-2.4:1.0: DVB: registering adapter 0 frontend 0 (Silicon Labs Si2168)...
 12275	[    7.671961] dvbdev: dvb_create_media_entity: media entity 'Silicon Labs Si2168' registered.
 12276	[    7.672994] dvbdev: dvb_create_media_entity: media entity 'dvb-demux' registered.
 12277	[    7.697864] em28xx 1-2.4:1.0: DVB extension successfully initialized
 12278	[    7.697875] em28xx: Registered (Em28xx dvb Extension) extension
 12279	[    7.705192] em28xx 1-2.4:1.0: Registering input extension
 12280	[    7.735606] Registered IR keymap rc-pinnacle-pctv-hd
 12281	[    7.735800] rc rc1: PCTV tripleStick (292e) as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-2/1-2.4/1-2.4:1.0/rc/rc1
 12282	[    7.735895] rc rc1: lirc_dev: driver em28xx registered at minor = 1, scancode receiver, no transmitter
 12283	[    7.735958] input: PCTV tripleStick (292e) as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-2/1-2.4/1-2.4:1.0/rc/rc1/input1
 12284	[    7.736032] em28xx 1-2.4:1.0: Input extension successfully initialized
 12285	[    7.736035] em28xx: Registered (Em28xx Input Extension) extension
 12286	[    8.630269] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
 12287	[    8.630288] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
 12288	[    9.717249] systemd[1]: Started Armbian memory supported logging.
 12289	[    9.719556] systemd[1]: Starting Journal Service...
 12290	[    9.786651] systemd[1]: Started Journal Service.
 12291	[    9.811783] systemd-journald[1847]: Received request to flush runtime journal from PID 1
 12292
 12293	### armbian-release:
 12294
 12295	# PLEASE DO NOT EDIT THIS FILE
 12296	BOARD=odroidn2
 12297	BOARD_NAME="Odroid N2"
 12298	BOARDFAMILY=meson-g12b
 12299	BUILD_REPOSITORY_URL=https://github.com/armbian/build
 12300	BUILD_REPOSITORY_COMMIT=5f03d652
 12301	DISTRIBUTION_CODENAME=buster
 12302	DISTRIBUTION_STATUS=supported
 12303	VERSION=21.02.1
 12304	LINUXFAMILY=meson64
 12305	BRANCH=current
 12306	ARCH=arm64
 12307	IMAGE_TYPE=stable
 12308	BOARD_TYPE=conf
 12309	INITRD_ARCH=arm64
 12310	KERNEL_IMAGE_TYPE=Image
 12311
 12312	### boot environment:
 12313
 12314	verbosity=1
 12315	console=both
 12316	overlay_prefix=meson
 12317	rootdev=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c
 12318	rootfstype=ext4
 12319	usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
 12320
 12321	### lsusb:
 12322
 12323	Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc.
 12324	Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
 12325	Bus 001 Device 005: ID 2013:025f PCTV Systems
 12326	Bus 001 Device 004: ID 05e3:0608 Genesys Logic, Inc. Hub
 12327	Bus 001 Device 003: ID 05e3:0608 Genesys Logic, Inc. Hub
 12328	Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
 12329	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
 12330
 12331	### lscpu:
 12332
 12333	Architecture:        aarch64
 12334	Byte Order:          Little Endian
 12335	CPU(s):              6
 12336	On-line CPU(s) list: 0-5
 12337	Thread(s) per core:  1
 12338	Core(s) per socket:  3
 12339	Socket(s):           2
 12340	NUMA node(s):        1
 12341	Vendor ID:           ARM
 12342	Model:               4
 12343	Model name:          Cortex-A53
 12344	Stepping:            r0p4
 12345	CPU max MHz:         1992.0000
 12346	CPU min MHz:         100.0000
 12347	BogoMIPS:            48.00
 12348	L1d cache:           unknown size
 12349	L1i cache:           unknown size
 12350	L2 cache:            unknown size
 12351	NUMA node0 CPU(s):   0-5
 12352	Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 12353
 12354	### cpuinfo:
 12355
 12356	processor	: 0
 12357	BogoMIPS	: 48.00
 12358	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 12359	CPU implementer	: 0x41
 12360	CPU architecture: 8
 12361	CPU variant	: 0x0
 12362	CPU part	: 0xd03
 12363	CPU revision	: 4
 12364
 12365	processor	: 1
 12366	BogoMIPS	: 48.00
 12367	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 12368	CPU implementer	: 0x41
 12369	CPU architecture: 8
 12370	CPU variant	: 0x0
 12371	CPU part	: 0xd03
 12372	CPU revision	: 4
 12373
 12374	processor	: 2
 12375	BogoMIPS	: 48.00
 12376	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 12377	CPU implementer	: 0x41
 12378	CPU architecture: 8
 12379	CPU variant	: 0x0
 12380	CPU part	: 0xd09
 12381	CPU revision	: 2
 12382
 12383	processor	: 3
 12384	BogoMIPS	: 48.00
 12385	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 12386	CPU implementer	: 0x41
 12387	CPU architecture: 8
 12388	CPU variant	: 0x0
 12389	CPU part	: 0xd09
 12390	CPU revision	: 2
 12391
 12392	processor	: 4
 12393	BogoMIPS	: 48.00
 12394	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 12395	CPU implementer	: 0x41
 12396	CPU architecture: 8
 12397	CPU variant	: 0x0
 12398	CPU part	: 0xd09
 12399	CPU revision	: 2
 12400
 12401	processor	: 5
 12402	BogoMIPS	: 48.00
 12403	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 12404	CPU implementer	: 0x41
 12405	CPU architecture: 8
 12406	CPU variant	: 0x0
 12407	CPU part	: 0xd09
 12408	CPU revision	: 2
 12409
 12410
 12411	### meminfo:
 12412
 12413	MemTotal:        3719728 kB
 12414	MemFree:         3399136 kB
 12415	MemAvailable:    3352944 kB
 12416	Buffers:           11444 kB
 12417	Cached:            44860 kB
 12418	SwapCached:            0 kB
 12419	Active:            28272 kB
 12420	Inactive:         177540 kB
 12421	Active(anon):        144 kB
 12422	Inactive(anon):   154352 kB
 12423	Active(file):      28128 kB
 12424	Inactive(file):    23188 kB
 12425	Unevictable:           0 kB
 12426	Mlocked:               0 kB
 12427	SwapTotal:       1859860 kB
 12428	SwapFree:        1859860 kB
 12429	Dirty:              5184 kB
 12430	Writeback:             0 kB
 12431	AnonPages:        149724 kB
 12432	Mapped:            13392 kB
 12433	Shmem:              4992 kB
 12434	KReclaimable:      13016 kB
 12435	Slab:              40408 kB
 12436	SReclaimable:      13016 kB
 12437	SUnreclaim:        27392 kB
 12438	KernelStack:        2496 kB
 12439	PageTables:         5764 kB
 12440	NFS_Unstable:          0 kB
 12441	Bounce:                0 kB
 12442	WritebackTmp:          0 kB
 12443	CommitLimit:     3719724 kB
 12444	Committed_AS:    4240132 kB
 12445	VmallocTotal:   135290159040 kB
 12446	VmallocUsed:       33152 kB
 12447	VmallocChunk:          0 kB
 12448	Percpu:             1368 kB
 12449	HardwareCorrupted:     0 kB
 12450	AnonHugePages:         0 kB
 12451	ShmemHugePages:        0 kB
 12452	ShmemPmdMapped:        0 kB
 12453	FileHugePages:         0 kB
 12454	FilePmdMapped:         0 kB
 12455	CmaTotal:         917504 kB
 12456	CmaFree:          901724 kB
 12457	HugePages_Total:       0
 12458	HugePages_Free:        0
 12459	HugePages_Rsvd:        0
 12460	HugePages_Surp:        0
 12461	Hugepagesize:       2048 kB
 12462	Hugetlb:               0 kB
 12463
 12464	### virtual memory:
 12465
 12466	vm.admin_reserve_kbytes = 8192
 12467	vm.block_dump = 0
 12468	vm.compaction_proactiveness = 20
 12469	vm.compact_unevictable_allowed = 1
 12470	vm.dirty_background_bytes = 0
 12471	vm.dirty_background_ratio = 10
 12472	vm.dirty_bytes = 0
 12473	vm.dirty_expire_centisecs = 3000
 12474	vm.dirty_ratio = 20
 12475	vm.dirtytime_expire_seconds = 43200
 12476	vm.dirty_writeback_centisecs = 500
 12477	vm.extfrag_threshold = 500
 12478	vm.hugetlb_shm_group = 0
 12479	vm.laptop_mode = 0
 12480	vm.legacy_va_layout = 0
 12481	vm.lowmem_reserve_ratio = 256	256	32	0
 12482	vm.max_map_count = 65530
 12483	vm.memory_failure_early_kill = 0
 12484	vm.memory_failure_recovery = 1
 12485	vm.min_free_kbytes = 45056
 12486	vm.min_slab_ratio = 5
 12487	vm.min_unmapped_ratio = 1
 12488	vm.mmap_min_addr = 4096
 12489	vm.mmap_rnd_bits = 18
 12490	vm.mmap_rnd_compat_bits = 11
 12491	vm.nr_hugepages = 0
 12492	vm.nr_hugepages_mempolicy = 0
 12493	vm.nr_overcommit_hugepages = 0
 12494	vm.numa_stat = 1
 12495	vm.numa_zonelist_order = Node
 12496	vm.oom_dump_tasks = 1
 12497	vm.oom_kill_allocating_task = 0
 12498	vm.overcommit_kbytes = 0
 12499	vm.overcommit_memory = 0
 12500	vm.overcommit_ratio = 50
 12501	vm.page-cluster = 0
 12502	vm.page_lock_unfairness = 5
 12503	vm.panic_on_oom = 0
 12504	vm.percpu_pagelist_fraction = 0
 12505	vm.stat_interval = 1
 12506	vm.swappiness = 100
 12507	vm.user_reserve_kbytes = 115067
 12508	vm.vfs_cache_pressure = 100
 12509	vm.watermark_boost_factor = 15000
 12510	vm.watermark_scale_factor = 10
 12511	vm.zone_reclaim_mode = 0
 12512
 12513	### ip addr:
 12514
 12515	1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
 12516	    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
 12517	    inet XXX.XXX.0.1/8 scope host lo
 12518	       valid_lft forever preferred_lft forever
 12519	    inet6 ::1/128 scope host
 12520	       valid_lft forever preferred_lft forever
 12521	2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
 12522	    link/ether 00:1e:06:42:03:f8 brd ff:ff:ff:ff:ff:ff
 12523
 12524	### partitions:
 12525
 12526	major minor  #blocks  name
 12527
 12528	 179        0   31464960 mmcblk0
 12529	 179        1   31146208 mmcblk0p1
 12530	 252        0    1859864 zram0
 12531	 252        1      51200 zram1
 12532
 12533	### df:
 12534
 12535	udev            1.4G     0  1.4G   0% /dev
 12536	tmpfs           364M  4.9M  359M   2% /run
 12537	/dev/mmcblk0p1   30G  1.7G   28G   6% /
 12538	tmpfs           1.8G     0  1.8G   0% /dev/shm
 12539	tmpfs           5.0M  4.0K  5.0M   1% /run/lock
 12540	tmpfs           1.8G     0  1.8G   0% /sys/fs/cgroup
 12541	tmpfs           1.8G     0  1.8G   0% /tmp
 12542	/dev/zram1       49M  5.1M   40M  12% /var/log
 12543
 12544	### lsblk:
 12545
 12546	NAME        FSTYPE  SIZE MOUNTPOINT UUID
 12547	mmcblk0              30G
 12548	└─mmcblk0p1 ext4   29.7G /          bd34953d-41be-49d6-b1c0-c0c28a5e239c
 12549	zram1                50M /var/log
 12550
 12551	### zramctl:
 12552
 12553	NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
 12554	/dev/zram1 zstd           50M  132K  698B   36K       6 /var/log
 12555	/dev/zram0 lzo-rle       1.8G    4K   74B   12K       6 [SWAP]
 12556
 12557	### mtab:
 12558
 12559	/dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
 12560	/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
 12561	/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
 12562
 12563	### mmc0:b368 info:
 12564
 12565	               fwrev: 0x0
 12566	              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=CBADS MODALIAS=mmc:block
 12567	                 cid: 6f0303434241445310aa002b4d013b00
 12568	                 rca: 0xb368
 12569	                 csd: 400e005a5b590000f00e7f800a404000
 12570	              manfid: 0x00006f
 12571	                 ocr: 0x00200000
 12572	preferred_erase_size: 2097152
 12573	                type: SD
 12574	               hwrev: 0x1
 12575	                date: 11/2019
 12576	                 dsr: 0x404
 12577	          erase_size: 512
 12578	               oemid: 0x0303
 12579	              serial: 0xaa002b4d
 12580	                 ssr: 00000000000000280402800100fd180a001e00000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
 12581	                 scr: 02b5800300000000
 12582	                name: CBADS
 12583
 12584	### Boot system health:
 12585
 12586	Time       big.LITTLE   load %cpu %sys %usr %nice %io %irq   CPU  C.St.
 12587	16:19:56: 1908/1992MHz  2.83  23%  11%   5%   0%   6%   0% 34.0°C  0/11
 12588	16:19:56: 1908/1992MHz  2.83  93%  29%   6%   0%  56%   1% 32.7°C  0/11
 12589	16:19:57: 1908/ 500MHz  2.83  63%   9%   5%   0%  45%   0% 31.5°C  0/11
 12590	16:19:57: 1908/1992MHz  2.83  55%  10%   6%   0%  36%   1% 30.6°C  0/11
 12591	16:19:57: 1908/1992MHz  2.83  38%   2%   4%   0%  30%   0% 30.2°C  0/11
 12592
 12593	### Activated 1 lzo-rle zram swap devices with 1816 MB each
 12594
 12595	### Activated Armbian ramlog partition with zstd compression
 12596
 12597	Sun 14 Feb 2021 04:34:48 PM GMT | Odroid N2 | 21.02.1 | arm64 | aarch64 | 5.10.12-meson64
 12598
 12599	### dmesg:
 12600
 12601	[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
 12602	[    0.000000] Linux version 5.10.12-meson64 (root@beast) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #21.02.1 SMP PREEMPT Wed Feb 3 21:06:36 CET 2021
 12603	[    0.000000] Machine model: Hardkernel ODROID-N2
 12604	[    0.000000] efi: UEFI not found.
 12605	[    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
 12606	[    0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB
 12607	[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
 12608	[    0.000000] NUMA: No NUMA configuration found
 12609	[    0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ed7fffff]
 12610	[    0.000000] NUMA: NODE_DATA [mem 0xb502f100-0xb5030fff]
 12611	[    0.000000] Zone ranges:
 12612	[    0.000000]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
 12613	[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000ed7fffff]
 12614	[    0.000000]   Normal   empty
 12615	[    0.000000] Movable zone start for each node
 12616	[    0.000000] Early memory node ranges
 12617	[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000004ffffff]
 12618	[    0.000000]   node   0: [mem 0x0000000005300000-0x00000000ed7fffff]
 12619	[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ed7fffff]
 12620	[    0.000000] On node 0 totalpages: 972032
 12621	[    0.000000]   DMA zone: 4096 pages used for memmap
 12622	[    0.000000]   DMA zone: 0 pages reserved
 12623	[    0.000000]   DMA zone: 261376 pages, LIFO batch:63
 12624	[    0.000000]   DMA32 zone: 11104 pages used for memmap
 12625	[    0.000000]   DMA32 zone: 710656 pages, LIFO batch:63
 12626	[    0.000000] psci: probing for conduit method from DT.
 12627	[    0.000000] psci: PSCIv1.0 detected in firmware.
 12628	[    0.000000] psci: Using standard PSCI v0.2 function IDs
 12629	[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
 12630	[    0.000000] psci: SMC Calling Convention v1.1
 12631	[    0.000000] percpu: Embedded 23 pages/cpu s56728 r8192 d29288 u94208
 12632	[    0.000000] pcpu-alloc: s56728 r8192 d29288 u94208 alloc=23*4096
 12633	[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
 12634	[    0.000000] Detected VIPT I-cache on CPU0
 12635	[    0.000000] CPU features: detected: ARM erratum 845719
 12636	[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 956832
 12637	[    0.000000] Policy zone: DMA32
 12638	[    0.000000] Kernel command line: root=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c rootwait rootfstype=ext4 console=ttyAML0,115200n8 console=tty1 loglevel=1  no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=1080p60hz cvbsmode=576cvbs max_freq_a53=1896 max_freq_a73=1800 maxcpus=6 voutmode=hdmi  disablehpd=false  cvbscable=0 overscan=100 consoleblank=0
 12639	[    0.000000] Kernel parameter elevator= does not have any effect anymore.
 12640	               Please use sysfs to set IO scheduler for individual devices.
 12641	[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
 12642	[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
 12643	[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
 12644	[    0.000000] software IO TLB: mapped [mem 0x0000000038ac5000-0x000000003cac5000] (64MB)
 12645	[    0.000000] Memory: 2785352K/3888128K available (14144K kernel code, 1760K rwdata, 5508K rodata, 3328K init, 592K bss, 185272K reserved, 917504K cma-reserved)
 12646	[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
 12647	[    0.000000] rcu: Preemptible hierarchical RCU implementation.
 12648	[    0.000000] rcu: 	RCU event tracing is enabled.
 12649	[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
 12650	[    0.000000] 	Trampoline variant of Tasks RCU enabled.
 12651	[    0.000000] 	Rude variant of Tasks RCU enabled.
 12652	[    0.000000] 	Tracing variant of Tasks RCU enabled.
 12653	[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
 12654	[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
 12655	[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
 12656	[    0.000000] GIC: Using split EOI/Deactivate mode
 12657	[    0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized
 12658	[    0.000000] random: get_random_bytes called from start_kernel+0x378/0x538 with crng_init=0
 12659	[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
 12660	[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
 12661	[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
 12662	[    0.000245] Console: colour dummy device 80x25
 12663	[    0.000280] printk: console [tty1] enabled
 12664	[    0.000366] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
 12665	[    0.000378] pid_max: default: 32768 minimum: 301
 12666	[    0.000462] LSM: Security Framework initializing
 12667	[    0.000487] Yama: becoming mindful.
 12668	[    0.000579] AppArmor: AppArmor initialized
 12669	[    0.000630] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
 12670	[    0.000649] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
 12671	[    0.002638] rcu: Hierarchical SRCU implementation.
 12672	[    0.005097] EFI services will not be available.
 12673	[    0.005514] smp: Bringing up secondary CPUs ...
 12674	[    0.006178] Detected VIPT I-cache on CPU1
 12675	[    0.006240] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
 12676	[    0.007433] CPU features: detected: ARM erratum 858921
 12677	[    0.007441] CPU features: detected: Spectre-v2
 12678	[    0.007444] CPU features: detected: Spectre-v4
 12679	[    0.007450] Detected VIPT I-cache on CPU2
 12680	[    0.007478] arch_timer: Enabling local workaround for ARM erratum 858921
 12681	[    0.007492] arch_timer: CPU2: Trapping CNTVCT access
 12682	[    0.007505] CPU2: Booted secondary processor 0x0000000100 [0x410fd092]
 12683	[    0.008215] Detected VIPT I-cache on CPU3
 12684	[    0.008231] arch_timer: Enabling local workaround for ARM erratum 858921
 12685	[    0.008238] arch_timer: CPU3: Trapping CNTVCT access
 12686	[    0.008245] CPU3: Booted secondary processor 0x0000000101 [0x410fd092]
 12687	[    0.008869] Detected VIPT I-cache on CPU4
 12688	[    0.008886] arch_timer: Enabling local workaround for ARM erratum 858921
 12689	[    0.008892] arch_timer: CPU4: Trapping CNTVCT access
 12690	[    0.008900] CPU4: Booted secondary processor 0x0000000102 [0x410fd092]
 12691	[    0.009512] Detected VIPT I-cache on CPU5
 12692	[    0.009529] arch_timer: Enabling local workaround for ARM erratum 858921
 12693	[    0.009535] arch_timer: CPU5: Trapping CNTVCT access
 12694	[    0.009543] CPU5: Booted secondary processor 0x0000000103 [0x410fd092]
 12695	[    0.009624] smp: Brought up 1 node, 6 CPUs
 12696	[    0.009640] SMP: Total of 6 processors activated.
 12697	[    0.009648] CPU features: detected: 32-bit EL0 Support
 12698	[    0.009654] CPU features: detected: CRC32 instructions
 12699	[    0.009660] CPU features: detected: 32-bit EL1 Support
 12700	[    0.020858] CPU: All CPU(s) started at EL2
 12701	[    0.020907] alternatives: patching kernel code
 12702	[    0.022827] devtmpfs: initialized
 12703	[    0.030444] Registered cp15_barrier emulation handler
 12704	[    0.030459] Registered setend emulation handler
 12705	[    0.030623] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
 12706	[    0.030666] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
 12707	[    0.044630] pinctrl core: initialized pinctrl subsystem
 12708	[    0.045381] DMI not present or invalid.
 12709	[    0.045748] NET: Registered protocol family 16
 12710	[    0.047277] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
 12711	[    0.047564] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
 12712	[    0.047794] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
 12713	[    0.047831] audit: initializing netlink subsys (disabled)
 12714	[    0.047944] audit: type=2000 audit(0.044:1): state=initialized audit_enabled=0 res=1
 12715	[    0.049132] thermal_sys: Registered thermal governor 'fair_share'
 12716	[    0.049139] thermal_sys: Registered thermal governor 'bang_bang'
 12717	[    0.049143] thermal_sys: Registered thermal governor 'step_wise'
 12718	[    0.049147] thermal_sys: Registered thermal governor 'user_space'
 12719	[    0.049579] cpuidle: using governor menu
 12720	[    0.049921] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
 12721	[    0.050042] ASID allocator initialised with 65536 entries
 12722	[    0.050991] Serial: AMBA PL011 UART driver
 12723	[    0.084775] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
 12724	[    0.084789] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
 12725	[    0.084794] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
 12726	[    0.084800] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
 12727	[    0.087143] cryptd: max_cpu_qlen set to 1000
 12728	[    0.156196] raid6: neonx8   gen()  2781 MB/s
 12729	[    0.224257] raid6: neonx8   xor()  2042 MB/s
 12730	[    0.292350] raid6: neonx4   gen()  3008 MB/s
 12731	[    0.360409] raid6: neonx4   xor()  2399 MB/s
 12732	[    0.428467] raid6: neonx2   gen()  2532 MB/s
 12733	[    0.496529] raid6: neonx2   xor()  2208 MB/s
 12734	[    0.564616] raid6: neonx1   gen()  2082 MB/s
 12735	[    0.632662] raid6: neonx1   xor()  1726 MB/s
 12736	[    0.700741] raid6: int64x8  gen()  1380 MB/s
 12737	[    0.768808] raid6: int64x8  xor()   735 MB/s
 12738	[    0.836882] raid6: int64x4  gen()  1463 MB/s
 12739	[    0.904934] raid6: int64x4  xor()   733 MB/s
 12740	[    0.973005] raid6: int64x2  gen()  1363 MB/s
 12741	[    1.041077] raid6: int64x2  xor()   619 MB/s
 12742	[    1.109144] raid6: int64x1  gen()  1120 MB/s
 12743	[    1.177215] raid6: int64x1  xor()   462 MB/s
 12744	[    1.177218] raid6: using algorithm neonx4 gen() 3008 MB/s
 12745	[    1.177221] raid6: .... xor() 2399 MB/s, rmw enabled
 12746	[    1.177225] raid6: using neon recovery algorithm
 12747	[    1.177685] ACPI: Interpreter disabled.
 12748	[    1.178530] 5V: supplied by 12V
 12749	[    1.179430] VDDAO_3V3: supplied by 12V
 12750	[    1.179903] iommu: Default domain type: Translated
 12751	[    1.180022] vgaarb: loaded
 12752	[    1.181045] SCSI subsystem initialized
 12753	[    1.181333] usbcore: registered new interface driver usbfs
 12754	[    1.181375] usbcore: registered new interface driver hub
 12755	[    1.181414] usbcore: registered new device driver usb
 12756	[    1.181674] pps_core: LinuxPPS API ver. 1 registered
 12757	[    1.181678] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
 12758	[    1.181698] PTP clock support registered
 12759	[    1.181904] EDAC MC: Ver: 3.0.0
 12760	[    1.183304] NetLabel: Initializing
 12761	[    1.183311] NetLabel:  domain hash size = 128
 12762	[    1.183314] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
 12763	[    1.183356] NetLabel:  unlabeled traffic allowed by default
 12764	[    1.183811] clocksource: Switched to clocksource arch_sys_counter
 12765	[    1.184027] VFS: Disk quotas dquot_6.6.0
 12766	[    1.184072] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
 12767	[    1.184421] AppArmor: AppArmor Filesystem Enabled
 12768	[    1.184479] pnp: PnP ACPI: disabled
 12769	[    1.190259] NET: Registered protocol family 2
 12770	[    1.190719] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
 12771	[    1.190822] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
 12772	[    1.191078] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
 12773	[    1.191265] TCP: Hash tables configured (established 32768 bind 32768)
 12774	[    1.191418] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
 12775	[    1.191482] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
 12776	[    1.191528] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
 12777	[    1.191672] NET: Registered protocol family 1
 12778	[    1.191691] PCI: CLS 0 bytes, default 64
 12779	[    1.191848] Trying to unpack rootfs image as initramfs...
 12780	[    1.728335] Freeing initrd memory: 13544K
 12781	[    1.729251] kvm [1]: IPA Size Limit: 40 bits
 12782	[    1.729957] kvm [1]: vgic interrupt IRQ9
 12783	[    1.730090] kvm [1]: Hyp mode initialized successfully
 12784	[    1.734052] Initialise system trusted keyrings
 12785	[    1.734086] Key type blacklist registered
 12786	[    1.734189] workingset: timestamp_bits=44 max_order=20 bucket_order=0
 12787	[    1.737384] zbud: loaded
 12788	[    1.738359] squashfs: version 4.0 (2009/01/31) Phillip Lougher
 12789	[    1.738797] fuse: init (API version 7.32)
 12790	[    1.739570] integrity: Platform Keyring initialized
 12791	[    1.766674] xor: measuring software checksum speed
 12792	[    1.769524]    8regs           :  3473 MB/sec
 12793	[    1.771979]    32regs          :  4024 MB/sec
 12794	[    1.774628]    arm64_neon      :  3719 MB/sec
 12795	[    1.774631] xor: using function: 32regs (4024 MB/sec)
 12796	[    1.774638] Key type asymmetric registered
 12797	[    1.774642] Asymmetric key parser 'x509' registered
 12798	[    1.774679] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
 12799	[    1.774762] io scheduler mq-deadline registered
 12800	[    1.774766] io scheduler kyber registered
 12801	[    1.774849] io scheduler bfq registered
 12802	[    1.777389] gpio-447 (usb-hub-reset): hogged as output/high
 12803	[    1.780383] EINJ: ACPI disabled.
 12804	[    1.786575] soc soc0: Amlogic Meson G12B (S922X) Revision 29:a (40:2) Detected
 12805	[    1.787998] VCC_3V3: supplied by VDDAO_3V3
 12806	[    1.788050] FLASH_1V8: supplied by VCC_3V3
 12807	[    1.788081] VCC_1V8: supplied by VCC_3V3
 12808	[    1.788112] VDDAO_1V8: supplied by VDDAO_3V3
 12809	[    1.788140] VDDCPU_A: supplied by regulator-dummy
 12810	[    1.788513] VDDCPU_B: supplied by regulator-dummy
 12811	[    1.789207] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
 12812	[    1.791364] Serial: AMBA driver
 12813	[    1.791656] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart
 12814	[    1.791751] printk: console [ttyAML0] enabled
 12815	[    1.792357] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 33, base_baud = 1500000) is a meson_uart
 12816	[    1.797736] loop: module loaded
 12817	[    1.799725] libphy: Fixed MDIO Bus: probed
 12818	[    1.800987] tun: Universal TUN/TAP device driver, 1.6
 12819	[    1.801656] thunder_xcv, ver 1.0
 12820	[    1.801684] thunder_bgx, ver 1.0
 12821	[    1.801718] nicpf, ver 1.0
 12822	[    1.802176] e1000e: Intel(R) PRO/1000 Network Driver
 12823	[    1.802180] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
 12824	[    1.802225] igb: Intel(R) Gigabit Ethernet Network Driver
 12825	[    1.802228] igb: Copyright (c) 2007-2014 Intel Corporation.
 12826	[    1.802260] igbvf: Intel(R) Gigabit Virtual Function Network Driver
 12827	[    1.802263] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
 12828	[    1.802389] sky2: driver version 1.30
 12829	[    1.802750] VFIO - User Level meta-driver version: 0.3
 12830	[    1.804209] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
 12831	[    1.804232] ehci-pci: EHCI PCI platform driver
 12832	[    1.804262] ehci-platform: EHCI generic platform driver
 12833	[    1.804405] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
 12834	[    1.804416] ohci-pci: OHCI PCI platform driver
 12835	[    1.804449] ohci-platform: OHCI generic platform driver
 12836	[    1.804879] usbcore: registered new interface driver usb-storage
 12837	[    1.806207] mousedev: PS/2 mouse device common for all mice
 12838	[    1.806605] i2c /dev entries driver
 12839	[    1.811785] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17
 12840	[    1.812477] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz
 12841	[    1.813167] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-1 failed:-17
 12842	[    1.813796] sdhci: Secure Digital Host Controller Interface driver
 12843	[    1.813803] sdhci: Copyright(c) Pierre Ossman
 12844	[    1.813928] Synopsys Designware Multimedia Card Interface Driver
 12845	[    1.814457] sdhci-pltfm: SDHCI platform and OF driver helper
 12846	[    1.815382] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq
 12847	[    1.815892] ledtrig-cpu: registered to indicate activity on CPUs
 12848	[    1.816229] meson-sm: secure-monitor enabled
 12849	[    1.816435] hid: raw HID events driver (C) Jiri Kosina
 12850	[    1.816528] usbcore: registered new interface driver usbhid
 12851	[    1.816531] usbhid: USB HID core driver
 12852	[    1.817531] NET: Registered protocol family 10
 12853	[    1.818130] Segment Routing with IPv6
 12854	[    1.818167] NET: Registered protocol family 17
 12855	[    1.818236] 8021q: 802.1Q VLAN Support v1.8
 12856	[    1.818263] Key type dns_resolver registered
 12857	[    1.818534] registered taskstats version 1
 12858	[    1.818540] Loading compiled-in X.509 certificates
 12859	[    1.820228] Loaded X.509 cert 'Build time autogenerated kernel key: f47c178852ca39740c3546b008122b65f5ed9bce'
 12860	[    1.821815] zswap: loaded using pool zstd/z3fold
 12861	[    1.821988] Key type ._fscrypt registered
 12862	[    1.821990] Key type .fscrypt registered
 12863	[    1.821992] Key type fscrypt-provisioning registered
 12864	[    1.823082] Btrfs loaded, crc32c=crc32c-generic
 12865	[    1.829159] Key type encrypted registered
 12866	[    1.829171] AppArmor: AppArmor sha1 policy hashing enabled
 12867	[    1.835368] HUB_5V: supplied by 5V
 12868	[    1.835583] USB_PWR_EN: supplied by 5V
 12869	[    1.837288] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2
 12870	[    1.837295] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1
 12871	[    1.839998] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator
 12872	[    1.840050] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator
 12873	[    1.840155] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM
 12874	[    1.840742] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
 12875	[    1.840754] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
 12876	[    1.840840] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010
 12877	[    1.840861] xhci-hcd xhci-hcd.0.auto: irq 41, io mem 0xff500000
 12878	[    1.840981] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
 12879	[    1.840985] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 12880	[    1.840988] usb usb1: Product: xHCI Host Controller
 12881	[    1.840990] usb usb1: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
 12882	[    1.840993] usb usb1: SerialNumber: xhci-hcd.0.auto
 12883	[    1.841181] hub 1-0:1.0: USB hub found
 12884	[    1.841195] hub 1-0:1.0: 2 ports detected
 12885	[    1.841328] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
 12886	[    1.841333] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
 12887	[    1.841340] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
 12888	[    1.841364] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
 12889	[    1.841395] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
 12890	[    1.841398] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 12891	[    1.841401] usb usb2: Product: xHCI Host Controller
 12892	[    1.841403] usb usb2: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
 12893	[    1.841406] usb usb2: SerialNumber: xhci-hcd.0.auto
 12894	[    1.841544] hub 2-0:1.0: USB hub found
 12895	[    1.841553] hub 2-0:1.0: 1 port detected
 12896	[    1.841819] dwc3-meson-g12a ffe09000.usb: switching to Device Mode
 12897	[    1.842671] meson-gx-mmc ffe05000.sd: Got CD GPIO
 12898	[    1.868897] Freeing unused kernel memory: 3328K
 12899	[    1.907935] Run /init as init process
 12900	[    1.907939]   with arguments:
 12901	[    1.907941]     /init
 12902	[    1.907943]   with environment:
 12903	[    1.907945]     HOME=/
 12904	[    1.907946]     TERM=linux
 12905	[    1.907948]     hdmimode=1080p60hz
 12906	[    1.907950]     cvbsmode=576cvbs
 12907	[    1.907951]     max_freq_a53=1896
 12908	[    1.907953]     max_freq_a73=1800
 12909	[    1.907954]     voutmode=hdmi
 12910	[    1.907956]     disablehpd=false
 12911	[    1.907957]     cvbscable=0
 12912	[    1.907958]     overscan=100
 12913	[    1.934009] mmc1: new ultra high speed SDR25 SDHC card at address b368
 12914	[    1.934527] mmcblk1: mmc1:b368 CBADS 30.0 GiB
 12915	[    1.936611]  mmcblk1: p1
 12916	[    2.071318] meson-vrtc ff8000a8.rtc: registered as rtc1
 12917	[    2.074601] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found
 12918	[    2.074612] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found
 12919	[    2.074826] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock
 12920	[    2.077192] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37
 12921	[    2.077206] meson8b-dwmac ff3f0000.ethernet: 	DWMAC1000
 12922	[    2.077211] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported
 12923	[    2.077215] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported
 12924	[    2.077218] meson8b-dwmac ff3f0000.ethernet: COE Type 2
 12925	[    2.077221] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported
 12926	[    2.077224] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported
 12927	[    2.077314] meson8b-dwmac ff3f0000.ethernet: Normal descriptors
 12928	[    2.077320] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled
 12929	[    2.077324] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
 12930	[    2.077752] libphy: stmmac: probed
 12931	[    2.079649] libphy: mdio_mux: probed
 12932	[    2.081427] random: fast init done
 12933	[    2.086198] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
 12934	[    2.086735] rtc-pcf8563 1-0051: registered as rtc0
 12935	[    2.087989] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
 12936	[    2.087998] rtc-pcf8563 1-0051: hctosys: unable to read the hardware clock
 12937	[    2.179943] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
 12938	[    2.204545] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.04
 12939	[    2.204552] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
 12940	[    2.204555] usb 2-1: Product: USB3.1 Hub
 12941	[    2.204557] usb 2-1: Manufacturer: GenesysLogic
 12942	[    2.225550] hub 2-1:1.0: USB hub found
 12943	[    2.225833] hub 2-1:1.0: 4 ports detected
 12944	[    2.284402] libphy: mdio_mux: probed
 12945	[    2.327824] usb 1-1: new high-speed USB device number 2 using xhci-hcd
 12946	[    2.478099] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.04
 12947	[    2.478103] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
 12948	[    2.478106] usb 1-1: Product: USB2.1 Hub
 12949	[    2.478108] usb 1-1: Manufacturer: GenesysLogic
 12950	[    2.513548] hub 1-1:1.0: USB hub found
 12951	[    2.513788] hub 1-1:1.0: 4 ports detected
 12952	[    2.892644] EXT4-fs (mmcblk1p1): mounted filesystem with writeback data mode. Opts: (null)
 12953	[    3.696081] systemd[1]: System time before build time, advancing clock.
 12954	[    3.710860] systemd[1]: Inserted module 'autofs4'
 12955	[    3.757337] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
 12956	[    3.757552] systemd[1]: Detected architecture arm64.
 12957	[    3.782455] systemd[1]: Set hostname to <odroidn2>.
 12958	[    4.109591] random: systemd: uninitialized urandom read (16 bytes read)
 12959	[    4.112945] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
 12960	[    4.112976] random: systemd: uninitialized urandom read (16 bytes read)
 12961	[    4.112994] systemd[1]: Reached target Swap.
 12962	[    4.113238] random: systemd: uninitialized urandom read (16 bytes read)
 12963	[    4.113453] systemd[1]: Listening on Syslog Socket.
 12964	[    4.113812] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
 12965	[    4.113990] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
 12966	[    4.114065] systemd[1]: Reached target Paths.
 12967	[    4.114335] systemd[1]: Listening on Journal Socket.
 12968	[    4.205028] EXT4-fs (mmcblk1p1): re-mounted. Opts: commit=600,errors=remount-ro
 12969	[    4.724389] zram: Added device: zram0
 12970	[    4.724804] zram: Added device: zram1
 12971	[    4.725144] zram: Added device: zram2
 12972	[    4.737369] pwm-gpio pwmgpio: 1 gpio pwms loaded
 12973	[    4.931172] meson-saradc ff809000.adc: supply vref not found, using dummy regulator
 12974	[    4.944565] mc: Linux media interface: v0.10
 12975	[    4.953402] panfrost ffe40000.gpu: clock rate = 24000000
 12976	[    4.953476] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19
 12977	[    4.954366] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0
 12978	[    4.954378] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400
 12979	[    4.954383] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
 12980	[    4.954386] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1
 12981	[    4.968816] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 0
 12982	[    5.015930] Registered IR keymap rc-odroid
 12983	[    5.033725] meson-drm ff900000.vpu: Queued 2 outputs on vpu
 12984	[    5.049204] videodev: Linux video capture interface: v2.00
 12985	[    5.068694] IR NEC protocol handler initialized
 12986	[    5.093142] meson-drm ff900000.vpu: CVBS Output connector not available
 12987	[    5.095947] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0
 12988	[    5.096099] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
 12989	[    5.096216] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input0
 12990	[    5.099103] meson-ir ff808000.ir: receiver initialized
 12991	[    5.119392] zram0: detected capacity change from 0 to 1904500736
 12992	[    5.119937] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
 12993	[    5.120490] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
 12994	[    5.120740] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
 12995	[    5.120988] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 1
 12996	[    5.121048] meson-drm ff900000.vpu: [drm] Cannot find any crtc or sizes
 12997	[    5.162999] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
 12998	[    5.173878] axg-sound-card sound: ASoC: no DMI vendor name!
 12999	[    6.171833] Adding 1859860k swap on /dev/zram0.  Priority:5 extents:1 across:1859860k SSFS
 13000	[    6.234652] zram1: detected capacity change from 0 to 52428800
 13001	[    8.318760] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
 13002	[    8.318778] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
 13003	[    9.416233] systemd[1]: Started Armbian memory supported logging.
 13004	[    9.418496] systemd[1]: Starting Journal Service...
 13005	[    9.473559] systemd[1]: Started Journal Service.
 13006	[    9.498344] systemd-journald[1816]: Received request to flush runtime journal from PID 1
 13007
 13008	### armbian-release:
 13009
 13010	# PLEASE DO NOT EDIT THIS FILE
 13011	BOARD=odroidn2
 13012	BOARD_NAME="Odroid N2"
 13013	BOARDFAMILY=meson-g12b
 13014	BUILD_REPOSITORY_URL=https://github.com/armbian/build
 13015	BUILD_REPOSITORY_COMMIT=5f03d652
 13016	DISTRIBUTION_CODENAME=buster
 13017	DISTRIBUTION_STATUS=supported
 13018	VERSION=21.02.1
 13019	LINUXFAMILY=meson64
 13020	BRANCH=current
 13021	ARCH=arm64
 13022	IMAGE_TYPE=stable
 13023	BOARD_TYPE=conf
 13024	INITRD_ARCH=arm64
 13025	KERNEL_IMAGE_TYPE=Image
 13026
 13027	### boot environment:
 13028
 13029	verbosity=1
 13030	console=both
 13031	overlay_prefix=meson
 13032	rootdev=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c
 13033	rootfstype=ext4
 13034	usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
 13035
 13036	### lsusb:
 13037
 13038	Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc.
 13039	Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
 13040	Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
 13041	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
 13042
 13043	### lscpu:
 13044
 13045	Architecture:        aarch64
 13046	Byte Order:          Little Endian
 13047	CPU(s):              6
 13048	On-line CPU(s) list: 0-5
 13049	Thread(s) per core:  1
 13050	Core(s) per socket:  3
 13051	Socket(s):           2
 13052	NUMA node(s):        1
 13053	Vendor ID:           ARM
 13054	Model:               4
 13055	Model name:          Cortex-A53
 13056	Stepping:            r0p4
 13057	CPU max MHz:         1992.0000
 13058	CPU min MHz:         100.0000
 13059	BogoMIPS:            48.00
 13060	L1d cache:           unknown size
 13061	L1i cache:           unknown size
 13062	L2 cache:            unknown size
 13063	NUMA node0 CPU(s):   0-5
 13064	Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 13065
 13066	### cpuinfo:
 13067
 13068	processor	: 0
 13069	BogoMIPS	: 48.00
 13070	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 13071	CPU implementer	: 0x41
 13072	CPU architecture: 8
 13073	CPU variant	: 0x0
 13074	CPU part	: 0xd03
 13075	CPU revision	: 4
 13076
 13077	processor	: 1
 13078	BogoMIPS	: 48.00
 13079	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 13080	CPU implementer	: 0x41
 13081	CPU architecture: 8
 13082	CPU variant	: 0x0
 13083	CPU part	: 0xd03
 13084	CPU revision	: 4
 13085
 13086	processor	: 2
 13087	BogoMIPS	: 48.00
 13088	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 13089	CPU implementer	: 0x41
 13090	CPU architecture: 8
 13091	CPU variant	: 0x0
 13092	CPU part	: 0xd09
 13093	CPU revision	: 2
 13094
 13095	processor	: 3
 13096	BogoMIPS	: 48.00
 13097	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 13098	CPU implementer	: 0x41
 13099	CPU architecture: 8
 13100	CPU variant	: 0x0
 13101	CPU part	: 0xd09
 13102	CPU revision	: 2
 13103
 13104	processor	: 4
 13105	BogoMIPS	: 48.00
 13106	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 13107	CPU implementer	: 0x41
 13108	CPU architecture: 8
 13109	CPU variant	: 0x0
 13110	CPU part	: 0xd09
 13111	CPU revision	: 2
 13112
 13113	processor	: 5
 13114	BogoMIPS	: 48.00
 13115	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 13116	CPU implementer	: 0x41
 13117	CPU architecture: 8
 13118	CPU variant	: 0x0
 13119	CPU part	: 0xd09
 13120	CPU revision	: 2
 13121
 13122
 13123	### meminfo:
 13124
 13125	MemTotal:        3719728 kB
 13126	MemFree:         3414428 kB
 13127	MemAvailable:    3368056 kB
 13128	Buffers:           11544 kB
 13129	Cached:            44552 kB
 13130	SwapCached:            0 kB
 13131	Active:            30408 kB
 13132	Inactive:         176556 kB
 13133	Active(anon):        116 kB
 13134	Inactive(anon):   155688 kB
 13135	Active(file):      30292 kB
 13136	Inactive(file):    20868 kB
 13137	Unevictable:           0 kB
 13138	Mlocked:               0 kB
 13139	SwapTotal:       1859860 kB
 13140	SwapFree:        1859860 kB
 13141	Dirty:              5480 kB
 13142	Writeback:             0 kB
 13143	AnonPages:        151028 kB
 13144	Mapped:            11000 kB
 13145	Shmem:              4940 kB
 13146	KReclaimable:      12812 kB
 13147	Slab:              38720 kB
 13148	SReclaimable:      12812 kB
 13149	SUnreclaim:        25908 kB
 13150	KernelStack:        2096 kB
 13151	PageTables:         3784 kB
 13152	NFS_Unstable:          0 kB
 13153	Bounce:                0 kB
 13154	WritebackTmp:          0 kB
 13155	CommitLimit:     3719724 kB
 13156	Committed_AS:    4210668 kB
 13157	VmallocTotal:   135290159040 kB
 13158	VmallocUsed:       30928 kB
 13159	VmallocChunk:          0 kB
 13160	Percpu:             1368 kB
 13161	HardwareCorrupted:     0 kB
 13162	AnonHugePages:         0 kB
 13163	ShmemHugePages:        0 kB
 13164	ShmemPmdMapped:        0 kB
 13165	FileHugePages:         0 kB
 13166	FilePmdMapped:         0 kB
 13167	CmaTotal:         917504 kB
 13168	CmaFree:          909824 kB
 13169	HugePages_Total:       0
 13170	HugePages_Free:        0
 13171	HugePages_Rsvd:        0
 13172	HugePages_Surp:        0
 13173	Hugepagesize:       2048 kB
 13174	Hugetlb:               0 kB
 13175
 13176	### virtual memory:
 13177
 13178	vm.admin_reserve_kbytes = 8192
 13179	vm.block_dump = 0
 13180	vm.compaction_proactiveness = 20
 13181	vm.compact_unevictable_allowed = 1
 13182	vm.dirty_background_bytes = 0
 13183	vm.dirty_background_ratio = 10
 13184	vm.dirty_bytes = 0
 13185	vm.dirty_expire_centisecs = 3000
 13186	vm.dirty_ratio = 20
 13187	vm.dirtytime_expire_seconds = 43200
 13188	vm.dirty_writeback_centisecs = 500
 13189	vm.extfrag_threshold = 500
 13190	vm.hugetlb_shm_group = 0
 13191	vm.laptop_mode = 0
 13192	vm.legacy_va_layout = 0
 13193	vm.lowmem_reserve_ratio = 256	256	32	0
 13194	vm.max_map_count = 65530
 13195	vm.memory_failure_early_kill = 0
 13196	vm.memory_failure_recovery = 1
 13197	vm.min_free_kbytes = 45056
 13198	vm.min_slab_ratio = 5
 13199	vm.min_unmapped_ratio = 1
 13200	vm.mmap_min_addr = 4096
 13201	vm.mmap_rnd_bits = 18
 13202	vm.mmap_rnd_compat_bits = 11
 13203	vm.nr_hugepages = 0
 13204	vm.nr_hugepages_mempolicy = 0
 13205	vm.nr_overcommit_hugepages = 0
 13206	vm.numa_stat = 1
 13207	vm.numa_zonelist_order = Node
 13208	vm.oom_dump_tasks = 1
 13209	vm.oom_kill_allocating_task = 0
 13210	vm.overcommit_kbytes = 0
 13211	vm.overcommit_memory = 0
 13212	vm.overcommit_ratio = 50
 13213	vm.page-cluster = 0
 13214	vm.page_lock_unfairness = 5
 13215	vm.panic_on_oom = 0
 13216	vm.percpu_pagelist_fraction = 0
 13217	vm.stat_interval = 1
 13218	vm.swappiness = 100
 13219	vm.user_reserve_kbytes = 115006
 13220	vm.vfs_cache_pressure = 100
 13221	vm.watermark_boost_factor = 15000
 13222	vm.watermark_scale_factor = 10
 13223	vm.zone_reclaim_mode = 0
 13224
 13225	### ip addr:
 13226
 13227	1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
 13228	    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
 13229	    inet XXX.XXX.0.1/8 scope host lo
 13230	       valid_lft forever preferred_lft forever
 13231	    inet6 ::1/128 scope host
 13232	       valid_lft forever preferred_lft forever
 13233	2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
 13234	    link/ether 00:1e:06:42:03:f8 brd ff:ff:ff:ff:ff:ff
 13235
 13236	### partitions:
 13237
 13238	major minor  #blocks  name
 13239
 13240	 179        0   31464960 mmcblk1
 13241	 179        1   31146208 mmcblk1p1
 13242	 252        0    1859864 zram0
 13243	 252        1      51200 zram1
 13244
 13245	### df:
 13246
 13247	udev            1.4G     0  1.4G   0% /dev
 13248	tmpfs           364M  4.9M  359M   2% /run
 13249	/dev/mmcblk1p1   30G  1.7G   28G   6% /
 13250	tmpfs           1.8G     0  1.8G   0% /dev/shm
 13251	tmpfs           5.0M  4.0K  5.0M   1% /run/lock
 13252	tmpfs           1.8G     0  1.8G   0% /sys/fs/cgroup
 13253	tmpfs           1.8G     0  1.8G   0% /tmp
 13254	/dev/zram1       49M  5.4M   40M  12% /var/log
 13255
 13256	### lsblk:
 13257
 13258	NAME        FSTYPE  SIZE MOUNTPOINT UUID
 13259	mmcblk1              30G
 13260	└─mmcblk1p1 ext4   29.7G /          bd34953d-41be-49d6-b1c0-c0c28a5e239c
 13261	zram1                50M /var/log
 13262
 13263	### zramctl:
 13264
 13265	NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
 13266	/dev/zram1 zstd           50M  132K  698B   36K       6 /var/log
 13267	/dev/zram0 lzo-rle       1.8G    4K   74B   12K       6 [SWAP]
 13268
 13269	### mtab:
 13270
 13271	/dev/mmcblk1p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
 13272	/dev/mmcblk1p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
 13273	/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
 13274
 13275	### mmc1:b368 info:
 13276
 13277	               fwrev: 0x0
 13278	              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=CBADS MODALIAS=mmc:block
 13279	                 cid: 6f0303434241445310aa002b4d013b00
 13280	                 rca: 0xb368
 13281	                 csd: 400e005a5b590000f00e7f800a404000
 13282	              manfid: 0x00006f
 13283	                 ocr: 0x00200000
 13284	preferred_erase_size: 2097152
 13285	                type: SD
 13286	               hwrev: 0x1
 13287	                date: 11/2019
 13288	                 dsr: 0x404
 13289	          erase_size: 512
 13290	               oemid: 0x0303
 13291	              serial: 0xaa002b4d
 13292	                 ssr: 00000000000000280402800100fd180a001e00000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
 13293	                 scr: 02b5800300000000
 13294	                name: CBADS
 13295
 13296	### Boot system health:
 13297
 13298	Time       big.LITTLE   load %cpu %sys %usr %nice %io %irq   CPU  C.St.
 13299	16:34:49: 1908/1992MHz  2.67  23%  10%   5%   0%   6%   0% 21.7°C  0/11
 13300	16:34:49: 1908/1992MHz  2.67  63%  32%   8%   0%  21%   0% 21.5°C  0/11
 13301	16:34:49: 1908/1992MHz  2.67  68%  21%   1%   0%  43%   0% 19.8°C  0/11
 13302	16:34:50: 1908/1992MHz  2.67  61%  11%   7%   0%  41%   1% 19.7°C  0/11
 13303	16:34:50: 1908/1992MHz  2.67  50%   3%   2%   0%  45%   0% 18.5°C  0/11
 13304
 13305	### Activated 1 lzo-rle zram swap devices with 1816 MB each
 13306
 13307	### Activated Armbian ramlog partition with zstd compression
 13308
 13309	Mon 15 Feb 2021 05:19:39 PM GMT | Odroid N2 | 21.02.1 | arm64 | aarch64 | 5.10.12-meson64
 13310
 13311	### dmesg:
 13312
 13313	[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
 13314	[    0.000000] Linux version 5.10.12-meson64 (root@beast) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #21.02.1 SMP PREEMPT Wed Feb 3 21:06:36 CET 2021
 13315	[    0.000000] Machine model: Hardkernel ODROID-N2
 13316	[    0.000000] efi: UEFI not found.
 13317	[    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
 13318	[    0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB
 13319	[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
 13320	[    0.000000] NUMA: No NUMA configuration found
 13321	[    0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ed7fffff]
 13322	[    0.000000] NUMA: NODE_DATA [mem 0xb502f100-0xb5030fff]
 13323	[    0.000000] Zone ranges:
 13324	[    0.000000]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
 13325	[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000ed7fffff]
 13326	[    0.000000]   Normal   empty
 13327	[    0.000000] Movable zone start for each node
 13328	[    0.000000] Early memory node ranges
 13329	[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000004ffffff]
 13330	[    0.000000]   node   0: [mem 0x0000000005300000-0x00000000ed7fffff]
 13331	[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ed7fffff]
 13332	[    0.000000] On node 0 totalpages: 972032
 13333	[    0.000000]   DMA zone: 4096 pages used for memmap
 13334	[    0.000000]   DMA zone: 0 pages reserved
 13335	[    0.000000]   DMA zone: 261376 pages, LIFO batch:63
 13336	[    0.000000]   DMA32 zone: 11104 pages used for memmap
 13337	[    0.000000]   DMA32 zone: 710656 pages, LIFO batch:63
 13338	[    0.000000] psci: probing for conduit method from DT.
 13339	[    0.000000] psci: PSCIv1.0 detected in firmware.
 13340	[    0.000000] psci: Using standard PSCI v0.2 function IDs
 13341	[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
 13342	[    0.000000] psci: SMC Calling Convention v1.1
 13343	[    0.000000] percpu: Embedded 23 pages/cpu s56728 r8192 d29288 u94208
 13344	[    0.000000] pcpu-alloc: s56728 r8192 d29288 u94208 alloc=23*4096
 13345	[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
 13346	[    0.000000] Detected VIPT I-cache on CPU0
 13347	[    0.000000] CPU features: detected: ARM erratum 845719
 13348	[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 956832
 13349	[    0.000000] Policy zone: DMA32
 13350	[    0.000000] Kernel command line: root=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c rootwait rootfstype=ext4 console=ttyAML0,115200n8 console=tty1 loglevel=1  no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=1080p60hz cvbsmode=576cvbs max_freq_a53=1896 max_freq_a73=1800 maxcpus=6 voutmode=hdmi  disablehpd=false  cvbscable=0 overscan=100 consoleblank=0
 13351	[    0.000000] Kernel parameter elevator= does not have any effect anymore.
 13352	               Please use sysfs to set IO scheduler for individual devices.
 13353	[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
 13354	[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
 13355	[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
 13356	[    0.000000] software IO TLB: mapped [mem 0x0000000038ac5000-0x000000003cac5000] (64MB)
 13357	[    0.000000] Memory: 2785352K/3888128K available (14144K kernel code, 1760K rwdata, 5508K rodata, 3328K init, 592K bss, 185272K reserved, 917504K cma-reserved)
 13358	[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
 13359	[    0.000000] rcu: Preemptible hierarchical RCU implementation.
 13360	[    0.000000] rcu: 	RCU event tracing is enabled.
 13361	[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
 13362	[    0.000000] 	Trampoline variant of Tasks RCU enabled.
 13363	[    0.000000] 	Rude variant of Tasks RCU enabled.
 13364	[    0.000000] 	Tracing variant of Tasks RCU enabled.
 13365	[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
 13366	[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
 13367	[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
 13368	[    0.000000] GIC: Using split EOI/Deactivate mode
 13369	[    0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized
 13370	[    0.000000] random: get_random_bytes called from start_kernel+0x378/0x538 with crng_init=0
 13371	[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
 13372	[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
 13373	[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
 13374	[    0.000249] Console: colour dummy device 80x25
 13375	[    0.000285] printk: console [tty1] enabled
 13376	[    0.000373] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
 13377	[    0.000385] pid_max: default: 32768 minimum: 301
 13378	[    0.000468] LSM: Security Framework initializing
 13379	[    0.000494] Yama: becoming mindful.
 13380	[    0.000586] AppArmor: AppArmor initialized
 13381	[    0.000637] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
 13382	[    0.000655] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
 13383	[    0.002655] rcu: Hierarchical SRCU implementation.
 13384	[    0.005125] EFI services will not be available.
 13385	[    0.005548] smp: Bringing up secondary CPUs ...
 13386	[    0.006222] Detected VIPT I-cache on CPU1
 13387	[    0.006283] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
 13388	[    0.007476] CPU features: detected: ARM erratum 858921
 13389	[    0.007484] CPU features: detected: Spectre-v2
 13390	[    0.007487] CPU features: detected: Spectre-v4
 13391	[    0.007493] Detected VIPT I-cache on CPU2
 13392	[    0.007518] arch_timer: Enabling local workaround for ARM erratum 858921
 13393	[    0.007532] arch_timer: CPU2: Trapping CNTVCT access
 13394	[    0.007545] CPU2: Booted secondary processor 0x0000000100 [0x410fd092]
 13395	[    0.008253] Detected VIPT I-cache on CPU3
 13396	[    0.008269] arch_timer: Enabling local workaround for ARM erratum 858921
 13397	[    0.008276] arch_timer: CPU3: Trapping CNTVCT access
 13398	[    0.008284] CPU3: Booted secondary processor 0x0000000101 [0x410fd092]
 13399	[    0.008910] Detected VIPT I-cache on CPU4
 13400	[    0.008927] arch_timer: Enabling local workaround for ARM erratum 858921
 13401	[    0.008934] arch_timer: CPU4: Trapping CNTVCT access
 13402	[    0.008942] CPU4: Booted secondary processor 0x0000000102 [0x410fd092]
 13403	[    0.009558] Detected VIPT I-cache on CPU5
 13404	[    0.009574] arch_timer: Enabling local workaround for ARM erratum 858921
 13405	[    0.009581] arch_timer: CPU5: Trapping CNTVCT access
 13406	[    0.009589] CPU5: Booted secondary processor 0x0000000103 [0x410fd092]
 13407	[    0.009672] smp: Brought up 1 node, 6 CPUs
 13408	[    0.009689] SMP: Total of 6 processors activated.
 13409	[    0.009697] CPU features: detected: 32-bit EL0 Support
 13410	[    0.009702] CPU features: detected: CRC32 instructions
 13411	[    0.009708] CPU features: detected: 32-bit EL1 Support
 13412	[    0.021002] CPU: All CPU(s) started at EL2
 13413	[    0.021052] alternatives: patching kernel code
 13414	[    0.022994] devtmpfs: initialized
 13415	[    0.030659] Registered cp15_barrier emulation handler
 13416	[    0.030673] Registered setend emulation handler
 13417	[    0.030809] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
 13418	[    0.030848] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
 13419	[    0.044786] pinctrl core: initialized pinctrl subsystem
 13420	[    0.045336] DMI not present or invalid.
 13421	[    0.045737] NET: Registered protocol family 16
 13422	[    0.047358] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
 13423	[    0.047633] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
 13424	[    0.047856] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
 13425	[    0.047901] audit: initializing netlink subsys (disabled)
 13426	[    0.048012] audit: type=2000 audit(0.048:1): state=initialized audit_enabled=0 res=1
 13427	[    0.049374] thermal_sys: Registered thermal governor 'fair_share'
 13428	[    0.049382] thermal_sys: Registered thermal governor 'bang_bang'
 13429	[    0.049387] thermal_sys: Registered thermal governor 'step_wise'
 13430	[    0.049390] thermal_sys: Registered thermal governor 'user_space'
 13431	[    0.049813] cpuidle: using governor menu
 13432	[    0.050154] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
 13433	[    0.050276] ASID allocator initialised with 65536 entries
 13434	[    0.051244] Serial: AMBA PL011 UART driver
 13435	[    0.084952] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
 13436	[    0.084961] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
 13437	[    0.084967] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
 13438	[    0.084971] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
 13439	[    0.087563] cryptd: max_cpu_qlen set to 1000
 13440	[    0.156227] raid6: neonx8   gen()  2785 MB/s
 13441	[    0.224313] raid6: neonx8   xor()  1603 MB/s
 13442	[    0.292346] raid6: neonx4   gen()  3150 MB/s
 13443	[    0.360413] raid6: neonx4   xor()  2399 MB/s
 13444	[    0.428482] raid6: neonx2   gen()  2572 MB/s
 13445	[    0.496550] raid6: neonx2   xor()  2193 MB/s
 13446	[    0.564616] raid6: neonx1   gen()  2064 MB/s
 13447	[    0.632678] raid6: neonx1   xor()  1727 MB/s
 13448	[    0.700756] raid6: int64x8  gen()  1375 MB/s
 13449	[    0.768811] raid6: int64x8  xor()   735 MB/s
 13450	[    0.836892] raid6: int64x4  gen()  1463 MB/s
 13451	[    0.904949] raid6: int64x4  xor()   733 MB/s
 13452	[    0.973009] raid6: int64x2  gen()  1362 MB/s
 13453	[    1.041085] raid6: int64x2  xor()   619 MB/s
 13454	[    1.109136] raid6: int64x1  gen()  1120 MB/s
 13455	[    1.177221] raid6: int64x1  xor()   462 MB/s
 13456	[    1.177224] raid6: using algorithm neonx4 gen() 3150 MB/s
 13457	[    1.177228] raid6: .... xor() 2399 MB/s, rmw enabled
 13458	[    1.177231] raid6: using neon recovery algorithm
 13459	[    1.177698] ACPI: Interpreter disabled.
 13460	[    1.178551] 5V: supplied by 12V
 13461	[    1.179454] VDDAO_3V3: supplied by 12V
 13462	[    1.179950] iommu: Default domain type: Translated
 13463	[    1.180066] vgaarb: loaded
 13464	[    1.180857] SCSI subsystem initialized
 13465	[    1.181200] usbcore: registered new interface driver usbfs
 13466	[    1.181240] usbcore: registered new interface driver hub
 13467	[    1.181279] usbcore: registered new device driver usb
 13468	[    1.181583] pps_core: LinuxPPS API ver. 1 registered
 13469	[    1.181588] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
 13470	[    1.181610] PTP clock support registered
 13471	[    1.181803] EDAC MC: Ver: 3.0.0
 13472	[    1.183104] NetLabel: Initializing
 13473	[    1.183111] NetLabel:  domain hash size = 128
 13474	[    1.183113] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
 13475	[    1.183156] NetLabel:  unlabeled traffic allowed by default
 13476	[    1.183581] clocksource: Switched to clocksource arch_sys_counter
 13477	[    1.183798] VFS: Disk quotas dquot_6.6.0
 13478	[    1.183841] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
 13479	[    1.184205] AppArmor: AppArmor Filesystem Enabled
 13480	[    1.184253] pnp: PnP ACPI: disabled
 13481	[    1.189971] NET: Registered protocol family 2
 13482	[    1.190433] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
 13483	[    1.190537] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
 13484	[    1.190794] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
 13485	[    1.190982] TCP: Hash tables configured (established 32768 bind 32768)
 13486	[    1.191131] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
 13487	[    1.191199] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
 13488	[    1.191246] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
 13489	[    1.191389] NET: Registered protocol family 1
 13490	[    1.191412] PCI: CLS 0 bytes, default 64
 13491	[    1.191534] Trying to unpack rootfs image as initramfs...
 13492	[    1.728034] Freeing initrd memory: 13544K
 13493	[    1.728949] kvm [1]: IPA Size Limit: 40 bits
 13494	[    1.729658] kvm [1]: vgic interrupt IRQ9
 13495	[    1.729792] kvm [1]: Hyp mode initialized successfully
 13496	[    1.733692] Initialise system trusted keyrings
 13497	[    1.733725] Key type blacklist registered
 13498	[    1.733818] workingset: timestamp_bits=44 max_order=20 bucket_order=0
 13499	[    1.737033] zbud: loaded
 13500	[    1.738015] squashfs: version 4.0 (2009/01/31) Phillip Lougher
 13501	[    1.738469] fuse: init (API version 7.32)
 13502	[    1.739228] integrity: Platform Keyring initialized
 13503	[    1.766787] xor: measuring software checksum speed
 13504	[    1.769636]    8regs           :  3473 MB/sec
 13505	[    1.772091]    32regs          :  4026 MB/sec
 13506	[    1.774737]    arm64_neon      :  3723 MB/sec
 13507	[    1.774741] xor: using function: 32regs (4026 MB/sec)
 13508	[    1.774747] Key type asymmetric registered
 13509	[    1.774751] Asymmetric key parser 'x509' registered
 13510	[    1.774783] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
 13511	[    1.774867] io scheduler mq-deadline registered
 13512	[    1.774871] io scheduler kyber registered
 13513	[    1.774952] io scheduler bfq registered
 13514	[    1.777510] gpio-447 (usb-hub-reset): hogged as output/high
 13515	[    1.780478] EINJ: ACPI disabled.
 13516	[    1.786770] soc soc0: Amlogic Meson G12B (S922X) Revision 29:a (40:2) Detected
 13517	[    1.788286] VCC_3V3: supplied by VDDAO_3V3
 13518	[    1.788320] FLASH_1V8: supplied by VCC_3V3
 13519	[    1.788351] VCC_1V8: supplied by VCC_3V3
 13520	[    1.788393] VDDAO_1V8: supplied by VDDAO_3V3
 13521	[    1.788422] VDDCPU_A: supplied by regulator-dummy
 13522	[    1.788783] VDDCPU_B: supplied by regulator-dummy
 13523	[    1.789448] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
 13524	[    1.791733] Serial: AMBA driver
 13525	[    1.792026] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart
 13526	[    1.792116] printk: console [ttyAML0] enabled
 13527	[    1.792628] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 33, base_baud = 1500000) is a meson_uart
 13528	[    1.797862] loop: module loaded
 13529	[    1.799958] libphy: Fixed MDIO Bus: probed
 13530	[    1.801115] tun: Universal TUN/TAP device driver, 1.6
 13531	[    1.801809] thunder_xcv, ver 1.0
 13532	[    1.801837] thunder_bgx, ver 1.0
 13533	[    1.801866] nicpf, ver 1.0
 13534	[    1.802332] e1000e: Intel(R) PRO/1000 Network Driver
 13535	[    1.802337] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
 13536	[    1.802377] igb: Intel(R) Gigabit Ethernet Network Driver
 13537	[    1.802380] igb: Copyright (c) 2007-2014 Intel Corporation.
 13538	[    1.802414] igbvf: Intel(R) Gigabit Virtual Function Network Driver
 13539	[    1.802417] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
 13540	[    1.802545] sky2: driver version 1.30
 13541	[    1.802932] VFIO - User Level meta-driver version: 0.3
 13542	[    1.804401] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
 13543	[    1.804421] ehci-pci: EHCI PCI platform driver
 13544	[    1.804457] ehci-platform: EHCI generic platform driver
 13545	[    1.804604] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
 13546	[    1.804614] ohci-pci: OHCI PCI platform driver
 13547	[    1.804647] ohci-platform: OHCI generic platform driver
 13548	[    1.805067] usbcore: registered new interface driver usb-storage
 13549	[    1.806385] mousedev: PS/2 mouse device common for all mice
 13550	[    1.806761] i2c /dev entries driver
 13551	[    1.811882] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17
 13552	[    1.812577] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz
 13553	[    1.813568] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-1 failed:-17
 13554	[    1.814179] sdhci: Secure Digital Host Controller Interface driver
 13555	[    1.814185] sdhci: Copyright(c) Pierre Ossman
 13556	[    1.814287] Synopsys Designware Multimedia Card Interface Driver
 13557	[    1.814726] sdhci-pltfm: SDHCI platform and OF driver helper
 13558	[    1.815139] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq
 13559	[    1.815499] ledtrig-cpu: registered to indicate activity on CPUs
 13560	[    1.816018] meson-sm: secure-monitor enabled
 13561	[    1.816183] hid: raw HID events driver (C) Jiri Kosina
 13562	[    1.816255] usbcore: registered new interface driver usbhid
 13563	[    1.816257] usbhid: USB HID core driver
 13564	[    1.817204] NET: Registered protocol family 10
 13565	[    1.817622] Segment Routing with IPv6
 13566	[    1.817649] NET: Registered protocol family 17
 13567	[    1.817704] 8021q: 802.1Q VLAN Support v1.8
 13568	[    1.817728] Key type dns_resolver registered
 13569	[    1.818000] registered taskstats version 1
 13570	[    1.818006] Loading compiled-in X.509 certificates
 13571	[    1.819754] Loaded X.509 cert 'Build time autogenerated kernel key: f47c178852ca39740c3546b008122b65f5ed9bce'
 13572	[    1.821387] zswap: loaded using pool zstd/z3fold
 13573	[    1.821586] Key type ._fscrypt registered
 13574	[    1.821588] Key type .fscrypt registered
 13575	[    1.821590] Key type fscrypt-provisioning registered
 13576	[    1.822664] Btrfs loaded, crc32c=crc32c-generic
 13577	[    1.828880] Key type encrypted registered
 13578	[    1.828891] AppArmor: AppArmor sha1 policy hashing enabled
 13579	[    1.835189] HUB_5V: supplied by 5V
 13580	[    1.835375] USB_PWR_EN: supplied by 5V
 13581	[    1.837035] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2
 13582	[    1.837043] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1
 13583	[    1.839809] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator
 13584	[    1.839871] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator
 13585	[    1.840010] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM
 13586	[    1.840603] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
 13587	[    1.840615] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
 13588	[    1.840698] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010
 13589	[    1.840721] xhci-hcd xhci-hcd.0.auto: irq 41, io mem 0xff500000
 13590	[    1.840842] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
 13591	[    1.840845] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 13592	[    1.840848] usb usb1: Product: xHCI Host Controller
 13593	[    1.840851] usb usb1: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
 13594	[    1.840853] usb usb1: SerialNumber: xhci-hcd.0.auto
 13595	[    1.841088] hub 1-0:1.0: USB hub found
 13596	[    1.841101] hub 1-0:1.0: 2 ports detected
 13597	[    1.841230] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
 13598	[    1.841236] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
 13599	[    1.841241] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
 13600	[    1.841261] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
 13601	[    1.841293] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
 13602	[    1.841296] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 13603	[    1.841299] usb usb2: Product: xHCI Host Controller
 13604	[    1.841301] usb usb2: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
 13605	[    1.841303] usb usb2: SerialNumber: xhci-hcd.0.auto
 13606	[    1.841455] hub 2-0:1.0: USB hub found
 13607	[    1.841466] hub 2-0:1.0: 1 port detected
 13608	[    1.841755] dwc3-meson-g12a ffe09000.usb: switching to Device Mode
 13609	[    1.842603] meson-gx-mmc ffe05000.sd: Got CD GPIO
 13610	[    1.868613] Freeing unused kernel memory: 3328K
 13611	[    1.903724] Run /init as init process
 13612	[    1.903728]   with arguments:
 13613	[    1.903730]     /init
 13614	[    1.903732]   with environment:
 13615	[    1.903734]     HOME=/
 13616	[    1.903735]     TERM=linux
 13617	[    1.903737]     hdmimode=1080p60hz
 13618	[    1.903739]     cvbsmode=576cvbs
 13619	[    1.903740]     max_freq_a53=1896
 13620	[    1.903742]     max_freq_a73=1800
 13621	[    1.903743]     voutmode=hdmi
 13622	[    1.903745]     disablehpd=false
 13623	[    1.903746]     cvbscable=0
 13624	[    1.903747]     overscan=100
 13625	[    1.933751] mmc0: new ultra high speed SDR25 SDHC card at address b368
 13626	[    1.934349] mmcblk0: mmc0:b368 CBADS 30.0 GiB
 13627	[    1.936171]  mmcblk0: p1
 13628	[    2.060404] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found
 13629	[    2.060413] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found
 13630	[    2.060556] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock
 13631	[    2.061088] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37
 13632	[    2.061103] meson8b-dwmac ff3f0000.ethernet: 	DWMAC1000
 13633	[    2.061106] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported
 13634	[    2.061110] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported
 13635	[    2.061112] meson8b-dwmac ff3f0000.ethernet: COE Type 2
 13636	[    2.061114] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported
 13637	[    2.061116] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported
 13638	[    2.061170] meson8b-dwmac ff3f0000.ethernet: Normal descriptors
 13639	[    2.061174] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled
 13640	[    2.061177] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
 13641	[    2.061400] libphy: stmmac: probed
 13642	[    2.064183] libphy: mdio_mux: probed
 13643	[    2.074270] meson-vrtc ff8000a8.rtc: registered as rtc1
 13644	[    2.094052] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
 13645	[    2.094183] rtc-pcf8563 1-0051: registered as rtc0
 13646	[    2.095354] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
 13647	[    2.095360] rtc-pcf8563 1-0051: hctosys: unable to read the hardware clock
 13648	[    2.101740] random: fast init done
 13649	[    2.179595] usb 1-1: new high-speed USB device number 2 using xhci-hcd
 13650	[    2.276004] libphy: mdio_mux: probed
 13651	[    2.333935] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.04
 13652	[    2.333941] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
 13653	[    2.333944] usb 1-1: Product: USB2.1 Hub
 13654	[    2.333947] usb 1-1: Manufacturer: GenesysLogic
 13655	[    2.385448] hub 1-1:1.0: USB hub found
 13656	[    2.385673] hub 1-1:1.0: 4 ports detected
 13657	[    2.459710] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
 13658	[    2.482190] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.04
 13659	[    2.482193] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
 13660	[    2.482196] usb 2-1: Product: USB3.1 Hub
 13661	[    2.482198] usb 2-1: Manufacturer: GenesysLogic
 13662	[    2.513445] hub 2-1:1.0: USB hub found
 13663	[    2.513726] hub 2-1:1.0: 4 ports detected
 13664	[    2.902644] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
 13665	[    3.711302] systemd[1]: System time before build time, advancing clock.
 13666	[    3.726098] systemd[1]: Inserted module 'autofs4'
 13667	[    3.772590] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
 13668	[    3.772809] systemd[1]: Detected architecture arm64.
 13669	[    3.793881] systemd[1]: Set hostname to <odroidn2>.
 13670	[    4.121031] random: systemd: uninitialized urandom read (16 bytes read)
 13671	[    4.124491] random: systemd: uninitialized urandom read (16 bytes read)
 13672	[    4.124711] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
 13673	[    4.124918] random: systemd: uninitialized urandom read (16 bytes read)
 13674	[    4.126147] systemd[1]: Created slice system-getty.slice.
 13675	[    4.126548] systemd[1]: Listening on Journal Socket.
 13676	[    4.129253] systemd[1]: Starting Load Kernel Modules...
 13677	[    4.131051] systemd[1]: Starting Create list of required static device nodes for the current kernel...
 13678	[    4.131968] systemd[1]: Created slice User and Session Slice.
 13679	[    4.133434] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
 13680	[    4.223668] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
 13681	[    4.728318] zram: Added device: zram0
 13682	[    4.728503] zram: Added device: zram1
 13683	[    4.728914] zram: Added device: zram2
 13684	[    4.766657] pwm-gpio pwmgpio: 1 gpio pwms loaded
 13685	[    4.937470] mc: Linux media interface: v0.10
 13686	[    4.948567] meson-saradc ff809000.adc: supply vref not found, using dummy regulator
 13687	[    4.983632] Registered IR keymap rc-odroid
 13688	[    4.991977] videodev: Linux video capture interface: v2.00
 13689	[    5.024303] IR NEC protocol handler initialized
 13690	[    5.051665] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0
 13691	[    5.051755] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
 13692	[    5.051814] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input0
 13693	[    5.052052] meson-ir ff808000.ir: receiver initialized
 13694	[    5.078215] meson-drm ff900000.vpu: Queued 2 outputs on vpu
 13695	[    5.117060] zram0: detected capacity change from 0 to 1904500736
 13696	[    5.121778] meson-drm ff900000.vpu: CVBS Output connector not available
 13697	[    5.135419] panfrost ffe40000.gpu: clock rate = 24000000
 13698	[    5.135473] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19
 13699	[    5.136107] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0
 13700	[    5.136116] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400
 13701	[    5.136120] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
 13702	[    5.136124] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1
 13703	[    5.147756] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
 13704	[    5.152133] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
 13705	[    5.152548] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
 13706	[    5.152949] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 0
 13707	[    5.153043] meson-drm ff900000.vpu: [drm] Cannot find any crtc or sizes
 13708	[    5.163534] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 1
 13709	[    5.169725] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
 13710	[    5.220688] axg-sound-card sound: ASoC: no DMI vendor name!
 13711	[    6.175638] Adding 1859860k swap on /dev/zram0.  Priority:5 extents:1 across:1859860k SSFS
 13712	[    6.239300] zram1: detected capacity change from 0 to 52428800
 13713	[    8.325717] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
 13714	[    8.325736] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
 13715	[    9.441816] systemd[1]: Started Armbian memory supported logging.
 13716	[    9.445923] systemd[1]: Starting Journal Service...
 13717	[    9.501092] systemd[1]: Started Journal Service.
 13718	[    9.529089] systemd-journald[1815]: Received request to flush runtime journal from PID 1
 13719
 13720	### armbian-release:
 13721
 13722	# PLEASE DO NOT EDIT THIS FILE
 13723	BOARD=odroidn2
 13724	BOARD_NAME="Odroid N2"
 13725	BOARDFAMILY=meson-g12b
 13726	BUILD_REPOSITORY_URL=https://github.com/armbian/build
 13727	BUILD_REPOSITORY_COMMIT=5f03d652
 13728	DISTRIBUTION_CODENAME=buster
 13729	DISTRIBUTION_STATUS=supported
 13730	VERSION=21.02.1
 13731	LINUXFAMILY=meson64
 13732	BRANCH=current
 13733	ARCH=arm64
 13734	IMAGE_TYPE=stable
 13735	BOARD_TYPE=conf
 13736	INITRD_ARCH=arm64
 13737	KERNEL_IMAGE_TYPE=Image
 13738
 13739	### boot environment:
 13740
 13741	verbosity=1
 13742	console=both
 13743	overlay_prefix=meson
 13744	rootdev=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c
 13745	rootfstype=ext4
 13746	usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
 13747
 13748	### lsusb:
 13749
 13750	Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc.
 13751	Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
 13752	Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
 13753	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
 13754
 13755	### lscpu:
 13756
 13757	Architecture:        aarch64
 13758	Byte Order:          Little Endian
 13759	CPU(s):              6
 13760	On-line CPU(s) list: 0-5
 13761	Thread(s) per core:  1
 13762	Core(s) per socket:  3
 13763	Socket(s):           2
 13764	NUMA node(s):        1
 13765	Vendor ID:           ARM
 13766	Model:               4
 13767	Model name:          Cortex-A53
 13768	Stepping:            r0p4
 13769	CPU max MHz:         1992.0000
 13770	CPU min MHz:         100.0000
 13771	BogoMIPS:            48.00
 13772	L1d cache:           unknown size
 13773	L1i cache:           unknown size
 13774	L2 cache:            unknown size
 13775	NUMA node0 CPU(s):   0-5
 13776	Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 13777
 13778	### cpuinfo:
 13779
 13780	processor	: 0
 13781	BogoMIPS	: 48.00
 13782	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 13783	CPU implementer	: 0x41
 13784	CPU architecture: 8
 13785	CPU variant	: 0x0
 13786	CPU part	: 0xd03
 13787	CPU revision	: 4
 13788
 13789	processor	: 1
 13790	BogoMIPS	: 48.00
 13791	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 13792	CPU implementer	: 0x41
 13793	CPU architecture: 8
 13794	CPU variant	: 0x0
 13795	CPU part	: 0xd03
 13796	CPU revision	: 4
 13797
 13798	processor	: 2
 13799	BogoMIPS	: 48.00
 13800	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 13801	CPU implementer	: 0x41
 13802	CPU architecture: 8
 13803	CPU variant	: 0x0
 13804	CPU part	: 0xd09
 13805	CPU revision	: 2
 13806
 13807	processor	: 3
 13808	BogoMIPS	: 48.00
 13809	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 13810	CPU implementer	: 0x41
 13811	CPU architecture: 8
 13812	CPU variant	: 0x0
 13813	CPU part	: 0xd09
 13814	CPU revision	: 2
 13815
 13816	processor	: 4
 13817	BogoMIPS	: 48.00
 13818	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 13819	CPU implementer	: 0x41
 13820	CPU architecture: 8
 13821	CPU variant	: 0x0
 13822	CPU part	: 0xd09
 13823	CPU revision	: 2
 13824
 13825	processor	: 5
 13826	BogoMIPS	: 48.00
 13827	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 13828	CPU implementer	: 0x41
 13829	CPU architecture: 8
 13830	CPU variant	: 0x0
 13831	CPU part	: 0xd09
 13832	CPU revision	: 2
 13833
 13834
 13835	### meminfo:
 13836
 13837	MemTotal:        3719728 kB
 13838	MemFree:         3408868 kB
 13839	MemAvailable:    3362564 kB
 13840	Buffers:           11548 kB
 13841	Cached:            44680 kB
 13842	SwapCached:            0 kB
 13843	Active:            30116 kB
 13844	Inactive:         182760 kB
 13845	Active(anon):         84 kB
 13846	Inactive(anon):   161432 kB
 13847	Active(file):      30032 kB
 13848	Inactive(file):    21328 kB
 13849	Unevictable:           0 kB
 13850	Mlocked:               0 kB
 13851	SwapTotal:       1859860 kB
 13852	SwapFree:        1859860 kB
 13853	Dirty:              5532 kB
 13854	Writeback:             0 kB
 13855	AnonPages:        156524 kB
 13856	Mapped:            10764 kB
 13857	Shmem:              4864 kB
 13858	KReclaimable:      12748 kB
 13859	Slab:              38048 kB
 13860	SReclaimable:      12748 kB
 13861	SUnreclaim:        25300 kB
 13862	KernelStack:        2096 kB
 13863	PageTables:         3992 kB
 13864	NFS_Unstable:          0 kB
 13865	Bounce:                0 kB
 13866	WritebackTmp:          0 kB
 13867	CommitLimit:     3719724 kB
 13868	Committed_AS:    4210536 kB
 13869	VmallocTotal:   135290159040 kB
 13870	VmallocUsed:       30896 kB
 13871	VmallocChunk:          0 kB
 13872	Percpu:             1368 kB
 13873	HardwareCorrupted:     0 kB
 13874	AnonHugePages:         0 kB
 13875	ShmemHugePages:        0 kB
 13876	ShmemPmdMapped:        0 kB
 13877	FileHugePages:         0 kB
 13878	FilePmdMapped:         0 kB
 13879	CmaTotal:         917504 kB
 13880	CmaFree:          909824 kB
 13881	HugePages_Total:       0
 13882	HugePages_Free:        0
 13883	HugePages_Rsvd:        0
 13884	HugePages_Surp:        0
 13885	Hugepagesize:       2048 kB
 13886	Hugetlb:               0 kB
 13887
 13888	### virtual memory:
 13889
 13890	vm.admin_reserve_kbytes = 8192
 13891	vm.block_dump = 0
 13892	vm.compaction_proactiveness = 20
 13893	vm.compact_unevictable_allowed = 1
 13894	vm.dirty_background_bytes = 0
 13895	vm.dirty_background_ratio = 10
 13896	vm.dirty_bytes = 0
 13897	vm.dirty_expire_centisecs = 3000
 13898	vm.dirty_ratio = 20
 13899	vm.dirtytime_expire_seconds = 43200
 13900	vm.dirty_writeback_centisecs = 500
 13901	vm.extfrag_threshold = 500
 13902	vm.hugetlb_shm_group = 0
 13903	vm.laptop_mode = 0
 13904	vm.legacy_va_layout = 0
 13905	vm.lowmem_reserve_ratio = 256	256	32	0
 13906	vm.max_map_count = 65530
 13907	vm.memory_failure_early_kill = 0
 13908	vm.memory_failure_recovery = 1
 13909	vm.min_free_kbytes = 45056
 13910	vm.min_slab_ratio = 5
 13911	vm.min_unmapped_ratio = 1
 13912	vm.mmap_min_addr = 4096
 13913	vm.mmap_rnd_bits = 18
 13914	vm.mmap_rnd_compat_bits = 11
 13915	vm.nr_hugepages = 0
 13916	vm.nr_hugepages_mempolicy = 0
 13917	vm.nr_overcommit_hugepages = 0
 13918	vm.numa_stat = 1
 13919	vm.numa_zonelist_order = Node
 13920	vm.oom_dump_tasks = 1
 13921	vm.oom_kill_allocating_task = 0
 13922	vm.overcommit_kbytes = 0
 13923	vm.overcommit_memory = 0
 13924	vm.overcommit_ratio = 50
 13925	vm.page-cluster = 0
 13926	vm.page_lock_unfairness = 5
 13927	vm.panic_on_oom = 0
 13928	vm.percpu_pagelist_fraction = 0
 13929	vm.stat_interval = 1
 13930	vm.swappiness = 100
 13931	vm.user_reserve_kbytes = 115051
 13932	vm.vfs_cache_pressure = 100
 13933	vm.watermark_boost_factor = 15000
 13934	vm.watermark_scale_factor = 10
 13935	vm.zone_reclaim_mode = 0
 13936
 13937	### ip addr:
 13938
 13939	1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
 13940	    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
 13941	    inet XXX.XXX.0.1/8 scope host lo
 13942	       valid_lft forever preferred_lft forever
 13943	    inet6 ::1/128 scope host
 13944	       valid_lft forever preferred_lft forever
 13945	2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
 13946	    link/ether 00:1e:06:42:03:f8 brd ff:ff:ff:ff:ff:ff
 13947
 13948	### partitions:
 13949
 13950	major minor  #blocks  name
 13951
 13952	 179        0   31464960 mmcblk0
 13953	 179        1   31146208 mmcblk0p1
 13954	 252        0    1859864 zram0
 13955	 252        1      51200 zram1
 13956
 13957	### df:
 13958
 13959	udev            1.4G     0  1.4G   0% /dev
 13960	tmpfs           364M  4.9M  359M   2% /run
 13961	/dev/mmcblk0p1   30G  1.7G   28G   6% /
 13962	tmpfs           1.8G     0  1.8G   0% /dev/shm
 13963	tmpfs           5.0M  4.0K  5.0M   1% /run/lock
 13964	tmpfs           1.8G     0  1.8G   0% /sys/fs/cgroup
 13965	tmpfs           1.8G     0  1.8G   0% /tmp
 13966	/dev/zram1       49M  5.6M   40M  13% /var/log
 13967
 13968	### lsblk:
 13969
 13970	NAME        FSTYPE  SIZE MOUNTPOINT UUID
 13971	mmcblk0              30G
 13972	└─mmcblk0p1 ext4   29.7G /          bd34953d-41be-49d6-b1c0-c0c28a5e239c
 13973	zram1                50M /var/log
 13974
 13975	### zramctl:
 13976
 13977	NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
 13978	/dev/zram1 zstd           50M  132K  698B   36K       6 /var/log
 13979	/dev/zram0 lzo-rle       1.8G    4K   74B   12K       6 [SWAP]
 13980
 13981	### mtab:
 13982
 13983	/dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
 13984	/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
 13985	/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
 13986
 13987	### mmc0:b368 info:
 13988
 13989	               fwrev: 0x0
 13990	              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=CBADS MODALIAS=mmc:block
 13991	                 cid: 6f0303434241445310aa002b4d013b00
 13992	                 rca: 0xb368
 13993	                 csd: 400e005a5b590000f00e7f800a404000
 13994	              manfid: 0x00006f
 13995	                 ocr: 0x00200000
 13996	preferred_erase_size: 2097152
 13997	                type: SD
 13998	               hwrev: 0x1
 13999	                date: 11/2019
 14000	                 dsr: 0x404
 14001	          erase_size: 512
 14002	               oemid: 0x0303
 14003	              serial: 0xaa002b4d
 14004	                 ssr: 00000000000000280402800100fd180a001e00000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
 14005	                 scr: 02b5800300000000
 14006	                name: CBADS
 14007
 14008	### Boot system health:
 14009
 14010	Time       big.LITTLE   load %cpu %sys %usr %nice %io %irq   CPU  C.St.
 14011	17:19:40: 1908/1992MHz  2.82  23%  11%   5%   0%   7%   0% 23.3°C  0/11
 14012	17:19:40: 1908/1992MHz  2.82  71%  35%   7%   0%  26%   1% 23.6°C  0/11
 14013	17:19:40: 1908/1992MHz  2.82  70%  20%   4%   0%  44%   0% 20.3°C  0/11
 14014	17:19:41: 1908/1992MHz  2.82  47%   5%   3%   0%  37%   1% 20.1°C  0/11
 14015	17:19:41: 1908/1992MHz  2.82  60%   8%   5%   0%  45%   0% 19.3°C  0/11
 14016
 14017	### Activated 1 lzo-rle zram swap devices with 1816 MB each
 14018
 14019	### Activated Armbian ramlog partition with zstd compression
 14020
 14021	Mon 15 Feb 2021 05:52:50 PM GMT | Odroid N2 | 21.02.1 | arm64 | aarch64 | 5.10.12-meson64
 14022
 14023	### dmesg:
 14024
 14025	[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
 14026	[    0.000000] Linux version 5.10.12-meson64 (root@beast) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #21.02.1 SMP PREEMPT Wed Feb 3 21:06:36 CET 2021
 14027	[    0.000000] Machine model: Hardkernel ODROID-N2
 14028	[    0.000000] efi: UEFI not found.
 14029	[    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
 14030	[    0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB
 14031	[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
 14032	[    0.000000] NUMA: No NUMA configuration found
 14033	[    0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ed7fffff]
 14034	[    0.000000] NUMA: NODE_DATA [mem 0xb502f100-0xb5030fff]
 14035	[    0.000000] Zone ranges:
 14036	[    0.000000]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
 14037	[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000ed7fffff]
 14038	[    0.000000]   Normal   empty
 14039	[    0.000000] Movable zone start for each node
 14040	[    0.000000] Early memory node ranges
 14041	[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000004ffffff]
 14042	[    0.000000]   node   0: [mem 0x0000000005300000-0x00000000ed7fffff]
 14043	[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ed7fffff]
 14044	[    0.000000] On node 0 totalpages: 972032
 14045	[    0.000000]   DMA zone: 4096 pages used for memmap
 14046	[    0.000000]   DMA zone: 0 pages reserved
 14047	[    0.000000]   DMA zone: 261376 pages, LIFO batch:63
 14048	[    0.000000]   DMA32 zone: 11104 pages used for memmap
 14049	[    0.000000]   DMA32 zone: 710656 pages, LIFO batch:63
 14050	[    0.000000] psci: probing for conduit method from DT.
 14051	[    0.000000] psci: PSCIv1.0 detected in firmware.
 14052	[    0.000000] psci: Using standard PSCI v0.2 function IDs
 14053	[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
 14054	[    0.000000] psci: SMC Calling Convention v1.1
 14055	[    0.000000] percpu: Embedded 23 pages/cpu s56728 r8192 d29288 u94208
 14056	[    0.000000] pcpu-alloc: s56728 r8192 d29288 u94208 alloc=23*4096
 14057	[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
 14058	[    0.000000] Detected VIPT I-cache on CPU0
 14059	[    0.000000] CPU features: detected: ARM erratum 845719
 14060	[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 956832
 14061	[    0.000000] Policy zone: DMA32
 14062	[    0.000000] Kernel command line: root=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c rootwait rootfstype=ext4 console=ttyAML0,115200n8 console=tty1 loglevel=1  no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=1080p60hz cvbsmode=576cvbs max_freq_a53=1896 max_freq_a73=1800 maxcpus=6 voutmode=hdmi  disablehpd=false  cvbscable=0 overscan=100 consoleblank=0
 14063	[    0.000000] Kernel parameter elevator= does not have any effect anymore.
 14064	               Please use sysfs to set IO scheduler for individual devices.
 14065	[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
 14066	[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
 14067	[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
 14068	[    0.000000] software IO TLB: mapped [mem 0x0000000038ac5000-0x000000003cac5000] (64MB)
 14069	[    0.000000] Memory: 2785352K/3888128K available (14144K kernel code, 1760K rwdata, 5508K rodata, 3328K init, 592K bss, 185272K reserved, 917504K cma-reserved)
 14070	[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
 14071	[    0.000000] rcu: Preemptible hierarchical RCU implementation.
 14072	[    0.000000] rcu: 	RCU event tracing is enabled.
 14073	[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
 14074	[    0.000000] 	Trampoline variant of Tasks RCU enabled.
 14075	[    0.000000] 	Rude variant of Tasks RCU enabled.
 14076	[    0.000000] 	Tracing variant of Tasks RCU enabled.
 14077	[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
 14078	[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
 14079	[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
 14080	[    0.000000] GIC: Using split EOI/Deactivate mode
 14081	[    0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized
 14082	[    0.000000] random: get_random_bytes called from start_kernel+0x378/0x538 with crng_init=0
 14083	[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
 14084	[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
 14085	[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
 14086	[    0.000248] Console: colour dummy device 80x25
 14087	[    0.000282] printk: console [tty1] enabled
 14088	[    0.000369] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
 14089	[    0.000380] pid_max: default: 32768 minimum: 301
 14090	[    0.000463] LSM: Security Framework initializing
 14091	[    0.000490] Yama: becoming mindful.
 14092	[    0.000580] AppArmor: AppArmor initialized
 14093	[    0.000631] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
 14094	[    0.000650] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
 14095	[    0.002650] rcu: Hierarchical SRCU implementation.
 14096	[    0.005096] EFI services will not be available.
 14097	[    0.005515] smp: Bringing up secondary CPUs ...
 14098	[    0.006188] Detected VIPT I-cache on CPU1
 14099	[    0.006250] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
 14100	[    0.007443] CPU features: detected: ARM erratum 858921
 14101	[    0.007451] CPU features: detected: Spectre-v2
 14102	[    0.007454] CPU features: detected: Spectre-v4
 14103	[    0.007461] Detected VIPT I-cache on CPU2
 14104	[    0.007486] arch_timer: Enabling local workaround for ARM erratum 858921
 14105	[    0.007500] arch_timer: CPU2: Trapping CNTVCT access
 14106	[    0.007514] CPU2: Booted secondary processor 0x0000000100 [0x410fd092]
 14107	[    0.008219] Detected VIPT I-cache on CPU3
 14108	[    0.008235] arch_timer: Enabling local workaround for ARM erratum 858921
 14109	[    0.008243] arch_timer: CPU3: Trapping CNTVCT access
 14110	[    0.008251] CPU3: Booted secondary processor 0x0000000101 [0x410fd092]
 14111	[    0.008873] Detected VIPT I-cache on CPU4
 14112	[    0.008890] arch_timer: Enabling local workaround for ARM erratum 858921
 14113	[    0.008896] arch_timer: CPU4: Trapping CNTVCT access
 14114	[    0.008904] CPU4: Booted secondary processor 0x0000000102 [0x410fd092]
 14115	[    0.009520] Detected VIPT I-cache on CPU5
 14116	[    0.009537] arch_timer: Enabling local workaround for ARM erratum 858921
 14117	[    0.009544] arch_timer: CPU5: Trapping CNTVCT access
 14118	[    0.009552] CPU5: Booted secondary processor 0x0000000103 [0x410fd092]
 14119	[    0.009632] smp: Brought up 1 node, 6 CPUs
 14120	[    0.009650] SMP: Total of 6 processors activated.
 14121	[    0.009658] CPU features: detected: 32-bit EL0 Support
 14122	[    0.009663] CPU features: detected: CRC32 instructions
 14123	[    0.009669] CPU features: detected: 32-bit EL1 Support
 14124	[    0.020876] CPU: All CPU(s) started at EL2
 14125	[    0.020927] alternatives: patching kernel code
 14126	[    0.022868] devtmpfs: initialized
 14127	[    0.030515] Registered cp15_barrier emulation handler
 14128	[    0.030528] Registered setend emulation handler
 14129	[    0.030662] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
 14130	[    0.030702] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
 14131	[    0.044633] pinctrl core: initialized pinctrl subsystem
 14132	[    0.045363] DMI not present or invalid.
 14133	[    0.045730] NET: Registered protocol family 16
 14134	[    0.047231] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
 14135	[    0.047503] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
 14136	[    0.047731] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
 14137	[    0.047771] audit: initializing netlink subsys (disabled)
 14138	[    0.047868] audit: type=2000 audit(0.044:1): state=initialized audit_enabled=0 res=1
 14139	[    0.049267] thermal_sys: Registered thermal governor 'fair_share'
 14140	[    0.049274] thermal_sys: Registered thermal governor 'bang_bang'
 14141	[    0.049278] thermal_sys: Registered thermal governor 'step_wise'
 14142	[    0.049282] thermal_sys: Registered thermal governor 'user_space'
 14143	[    0.049688] cpuidle: using governor menu
 14144	[    0.050024] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
 14145	[    0.050145] ASID allocator initialised with 65536 entries
 14146	[    0.051090] Serial: AMBA PL011 UART driver
 14147	[    0.086064] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
 14148	[    0.086077] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
 14149	[    0.086082] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
 14150	[    0.086087] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
 14151	[    0.087692] cryptd: max_cpu_qlen set to 1000
 14152	[    0.156182] raid6: neonx8   gen()  2785 MB/s
 14153	[    0.224245] raid6: neonx8   xor()  2042 MB/s
 14154	[    0.292295] raid6: neonx4   gen()  3153 MB/s
 14155	[    0.360361] raid6: neonx4   xor()  2399 MB/s
 14156	[    0.428429] raid6: neonx2   gen()  2547 MB/s
 14157	[    0.496492] raid6: neonx2   xor()  2200 MB/s
 14158	[    0.564564] raid6: neonx1   gen()  2059 MB/s
 14159	[    0.632631] raid6: neonx1   xor()  1727 MB/s
 14160	[    0.700693] raid6: int64x8  gen()  1376 MB/s
 14161	[    0.768769] raid6: int64x8  xor()   735 MB/s
 14162	[    0.836853] raid6: int64x4  gen()  1463 MB/s
 14163	[    0.904906] raid6: int64x4  xor()   733 MB/s
 14164	[    0.972967] raid6: int64x2  gen()  1363 MB/s
 14165	[    1.041025] raid6: int64x2  xor()   619 MB/s
 14166	[    1.109109] raid6: int64x1  gen()  1120 MB/s
 14167	[    1.177169] raid6: int64x1  xor()   462 MB/s
 14168	[    1.177172] raid6: using algorithm neonx4 gen() 3153 MB/s
 14169	[    1.177175] raid6: .... xor() 2399 MB/s, rmw enabled
 14170	[    1.177179] raid6: using neon recovery algorithm
 14171	[    1.177635] ACPI: Interpreter disabled.
 14172	[    1.178407] 5V: supplied by 12V
 14173	[    1.179329] VDDAO_3V3: supplied by 12V
 14174	[    1.179840] iommu: Default domain type: Translated
 14175	[    1.179950] vgaarb: loaded
 14176	[    1.180696] SCSI subsystem initialized
 14177	[    1.181106] usbcore: registered new interface driver usbfs
 14178	[    1.181141] usbcore: registered new interface driver hub
 14179	[    1.181179] usbcore: registered new device driver usb
 14180	[    1.181425] pps_core: LinuxPPS API ver. 1 registered
 14181	[    1.181430] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
 14182	[    1.181457] PTP clock support registered
 14183	[    1.181682] EDAC MC: Ver: 3.0.0
 14184	[    1.183054] NetLabel: Initializing
 14185	[    1.183061] NetLabel:  domain hash size = 128
 14186	[    1.183064] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
 14187	[    1.183107] NetLabel:  unlabeled traffic allowed by default
 14188	[    1.183556] clocksource: Switched to clocksource arch_sys_counter
 14189	[    1.183774] VFS: Disk quotas dquot_6.6.0
 14190	[    1.183819] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
 14191	[    1.184165] AppArmor: AppArmor Filesystem Enabled
 14192	[    1.184220] pnp: PnP ACPI: disabled
 14193	[    1.189905] NET: Registered protocol family 2
 14194	[    1.190401] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
 14195	[    1.190476] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
 14196	[    1.190732] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
 14197	[    1.190919] TCP: Hash tables configured (established 32768 bind 32768)
 14198	[    1.191070] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
 14199	[    1.191135] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
 14200	[    1.191182] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
 14201	[    1.191328] NET: Registered protocol family 1
 14202	[    1.191347] PCI: CLS 0 bytes, default 64
 14203	[    1.191469] Trying to unpack rootfs image as initramfs...
 14204	[    1.727241] Freeing initrd memory: 13544K
 14205	[    1.728191] kvm [1]: IPA Size Limit: 40 bits
 14206	[    1.728901] kvm [1]: vgic interrupt IRQ9
 14207	[    1.729034] kvm [1]: Hyp mode initialized successfully
 14208	[    1.734068] Initialise system trusted keyrings
 14209	[    1.734108] Key type blacklist registered
 14210	[    1.734236] workingset: timestamp_bits=44 max_order=20 bucket_order=0
 14211	[    1.737425] zbud: loaded
 14212	[    1.738398] squashfs: version 4.0 (2009/01/31) Phillip Lougher
 14213	[    1.738880] fuse: init (API version 7.32)
 14214	[    1.739677] integrity: Platform Keyring initialized
 14215	[    1.767413] xor: measuring software checksum speed
 14216	[    1.770262]    8regs           :  3473 MB/sec
 14217	[    1.772717]    32regs          :  4022 MB/sec
 14218	[    1.775364]    arm64_neon      :  3722 MB/sec
 14219	[    1.775368] xor: using function: 32regs (4022 MB/sec)
 14220	[    1.775375] Key type asymmetric registered
 14221	[    1.775378] Asymmetric key parser 'x509' registered
 14222	[    1.775413] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
 14223	[    1.775525] io scheduler mq-deadline registered
 14224	[    1.775530] io scheduler kyber registered
 14225	[    1.775616] io scheduler bfq registered
 14226	[    1.778130] gpio-447 (usb-hub-reset): hogged as output/high
 14227	[    1.781111] EINJ: ACPI disabled.
 14228	[    1.787265] soc soc0: Amlogic Meson G12B (S922X) Revision 29:a (40:2) Detected
 14229	[    1.788761] VCC_3V3: supplied by VDDAO_3V3
 14230	[    1.788795] FLASH_1V8: supplied by VCC_3V3
 14231	[    1.788826] VCC_1V8: supplied by VCC_3V3
 14232	[    1.788870] VDDAO_1V8: supplied by VDDAO_3V3
 14233	[    1.788899] VDDCPU_A: supplied by regulator-dummy
 14234	[    1.789244] VDDCPU_B: supplied by regulator-dummy
 14235	[    1.789922] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
 14236	[    1.792271] Serial: AMBA driver
 14237	[    1.792566] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart
 14238	[    1.792660] printk: console [ttyAML0] enabled
 14239	[    1.793183] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 33, base_baud = 1500000) is a meson_uart
 14240	[    1.798732] loop: module loaded
 14241	[    1.800715] libphy: Fixed MDIO Bus: probed
 14242	[    1.801896] tun: Universal TUN/TAP device driver, 1.6
 14243	[    1.802579] thunder_xcv, ver 1.0
 14244	[    1.802609] thunder_bgx, ver 1.0
 14245	[    1.802638] nicpf, ver 1.0
 14246	[    1.803103] e1000e: Intel(R) PRO/1000 Network Driver
 14247	[    1.803106] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
 14248	[    1.803147] igb: Intel(R) Gigabit Ethernet Network Driver
 14249	[    1.803150] igb: Copyright (c) 2007-2014 Intel Corporation.
 14250	[    1.803186] igbvf: Intel(R) Gigabit Virtual Function Network Driver
 14251	[    1.803189] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
 14252	[    1.803317] sky2: driver version 1.30
 14253	[    1.804038] VFIO - User Level meta-driver version: 0.3
 14254	[    1.805510] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
 14255	[    1.805532] ehci-pci: EHCI PCI platform driver
 14256	[    1.805565] ehci-platform: EHCI generic platform driver
 14257	[    1.805701] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
 14258	[    1.805712] ohci-pci: OHCI PCI platform driver
 14259	[    1.805743] ohci-platform: OHCI generic platform driver
 14260	[    1.806172] usbcore: registered new interface driver usb-storage
 14261	[    1.807516] mousedev: PS/2 mouse device common for all mice
 14262	[    1.807987] i2c /dev entries driver
 14263	[    1.813127] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17
 14264	[    1.813785] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz
 14265	[    1.814465] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-1 failed:-17
 14266	[    1.815063] sdhci: Secure Digital Host Controller Interface driver
 14267	[    1.815070] sdhci: Copyright(c) Pierre Ossman
 14268	[    1.815197] Synopsys Designware Multimedia Card Interface Driver
 14269	[    1.815717] sdhci-pltfm: SDHCI platform and OF driver helper
 14270	[    1.816694] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq
 14271	[    1.817112] ledtrig-cpu: registered to indicate activity on CPUs
 14272	[    1.817362] meson-sm: secure-monitor enabled
 14273	[    1.817548] hid: raw HID events driver (C) Jiri Kosina
 14274	[    1.817650] usbcore: registered new interface driver usbhid
 14275	[    1.817653] usbhid: USB HID core driver
 14276	[    1.818638] NET: Registered protocol family 10
 14277	[    1.819221] Segment Routing with IPv6
 14278	[    1.819251] NET: Registered protocol family 17
 14279	[    1.819343] 8021q: 802.1Q VLAN Support v1.8
 14280	[    1.819386] Key type dns_resolver registered
 14281	[    1.819704] registered taskstats version 1
 14282	[    1.819710] Loading compiled-in X.509 certificates
 14283	[    1.821422] Loaded X.509 cert 'Build time autogenerated kernel key: f47c178852ca39740c3546b008122b65f5ed9bce'
 14284	[    1.823051] zswap: loaded using pool zstd/z3fold
 14285	[    1.823226] Key type ._fscrypt registered
 14286	[    1.823228] Key type .fscrypt registered
 14287	[    1.823230] Key type fscrypt-provisioning registered
 14288	[    1.824477] Btrfs loaded, crc32c=crc32c-generic
 14289	[    1.830470] Key type encrypted registered
 14290	[    1.830482] AppArmor: AppArmor sha1 policy hashing enabled
 14291	[    1.836850] HUB_5V: supplied by 5V
 14292	[    1.837078] USB_PWR_EN: supplied by 5V
 14293	[    1.838714] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2
 14294	[    1.838720] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1
 14295	[    1.841405] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator
 14296	[    1.841454] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator
 14297	[    1.841564] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM
 14298	[    1.842162] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
 14299	[    1.842174] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
 14300	[    1.842262] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010
 14301	[    1.842282] xhci-hcd xhci-hcd.0.auto: irq 41, io mem 0xff500000
 14302	[    1.842406] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
 14303	[    1.842409] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 14304	[    1.842412] usb usb1: Product: xHCI Host Controller
 14305	[    1.842414] usb usb1: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
 14306	[    1.842416] usb usb1: SerialNumber: xhci-hcd.0.auto
 14307	[    1.842634] hub 1-0:1.0: USB hub found
 14308	[    1.842650] hub 1-0:1.0: 2 ports detected
 14309	[    1.842780] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
 14310	[    1.842786] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
 14311	[    1.842791] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
 14312	[    1.842815] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
 14313	[    1.842845] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
 14314	[    1.842848] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 14315	[    1.842851] usb usb2: Product: xHCI Host Controller
 14316	[    1.842853] usb usb2: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
 14317	[    1.842855] usb usb2: SerialNumber: xhci-hcd.0.auto
 14318	[    1.843017] hub 2-0:1.0: USB hub found
 14319	[    1.843027] hub 2-0:1.0: 1 port detected
 14320	[    1.844295] meson-gx-mmc ffe05000.sd: Got CD GPIO
 14321	[    1.868636] Freeing unused kernel memory: 3328K
 14322	[    1.915606] Run /init as init process
 14323	[    1.915610]   with arguments:
 14324	[    1.915612]     /init
 14325	[    1.915614]   with environment:
 14326	[    1.915616]     HOME=/
 14327	[    1.915617]     TERM=linux
 14328	[    1.915619]     hdmimode=1080p60hz
 14329	[    1.915620]     cvbsmode=576cvbs
 14330	[    1.915622]     max_freq_a53=1896
 14331	[    1.915623]     max_freq_a73=1800
 14332	[    1.915625]     voutmode=hdmi
 14333	[    1.915626]     disablehpd=false
 14334	[    1.915627]     cvbscable=0
 14335	[    1.915629]     overscan=100
 14336	[    1.933702] mmc0: new ultra high speed SDR25 SDHC card at address b368
 14337	[    1.934543] mmcblk0: mmc0:b368 CBADS 30.0 GiB
 14338	[    1.936887]  mmcblk0: p1
 14339	[    2.067689] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found
 14340	[    2.067700] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found
 14341	[    2.067852] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock
 14342	[    2.068544] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37
 14343	[    2.068557] meson8b-dwmac ff3f0000.ethernet: 	DWMAC1000
 14344	[    2.068561] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported
 14345	[    2.068565] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported
 14346	[    2.068568] meson8b-dwmac ff3f0000.ethernet: COE Type 2
 14347	[    2.068571] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported
 14348	[    2.068574] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported
 14349	[    2.068657] meson8b-dwmac ff3f0000.ethernet: Normal descriptors
 14350	[    2.068661] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled
 14351	[    2.068664] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
 14352	[    2.069002] libphy: stmmac: probed
 14353	[    2.072701] libphy: mdio_mux: probed
 14354	[    2.076345] meson-vrtc ff8000a8.rtc: registered as rtc1
 14355	[    2.094389] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
 14356	[    2.094522] rtc-pcf8563 1-0051: registered as rtc0
 14357	[    2.095914] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
 14358	[    2.095923] rtc-pcf8563 1-0051: hctosys: unable to read the hardware clock
 14359	[    2.100664] random: fast init done
 14360	[    2.175583] usb 1-1: new high-speed USB device number 2 using xhci-hcd
 14361	[    2.276169] libphy: mdio_mux: probed
 14362	[    2.325977] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.04
 14363	[    2.325987] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
 14364	[    2.325990] usb 1-1: Product: USB2.1 Hub
 14365	[    2.325994] usb 1-1: Manufacturer: GenesysLogic
 14366	[    2.387066] hub 1-1:1.0: USB hub found
 14367	[    2.387294] hub 1-1:1.0: 4 ports detected
 14368	[    2.451695] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
 14369	[    2.474174] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.04
 14370	[    2.474183] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
 14371	[    2.474187] usb 2-1: Product: USB3.1 Hub
 14372	[    2.474190] usb 2-1: Manufacturer: GenesysLogic
 14373	[    2.499076] hub 2-1:1.0: USB hub found
 14374	[    2.499374] hub 2-1:1.0: 4 ports detected
 14375	[    2.599572] usb 1-2: new high-speed USB device number 3 using xhci-hcd
 14376	[    2.748041] usb 1-2: New USB device found, idVendor=2013, idProduct=025f, bcdDevice= 1.00
 14377	[    2.748050] usb 1-2: New USB device strings: Mfr=3, Product=1, SerialNumber=2
 14378	[    2.748054] usb 1-2: Product: PCTV 292e
 14379	[    2.748057] usb 1-2: Manufacturer: PCTV
 14380	[    2.748060] usb 1-2: SerialNumber: 0011356964
 14381	[    3.060030] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
 14382	[    3.863723] systemd[1]: System time before build time, advancing clock.
 14383	[    3.878535] systemd[1]: Inserted module 'autofs4'
 14384	[    3.924956] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
 14385	[    3.925184] systemd[1]: Detected architecture arm64.
 14386	[    3.958208] systemd[1]: Set hostname to <odroidn2>.
 14387	[    4.285395] random: systemd: uninitialized urandom read (16 bytes read)
 14388	[    4.288708] random: systemd: uninitialized urandom read (16 bytes read)
 14389	[    4.290029] systemd[1]: Created slice system-serial\x2dgetty.slice.
 14390	[    4.290233] random: systemd: uninitialized urandom read (16 bytes read)
 14391	[    4.290444] systemd[1]: Listening on fsck to fsckd communication Socket.
 14392	[    4.290711] systemd[1]: Listening on Journal Socket.
 14393	[    4.290872] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
 14394	[    4.291366] systemd[1]: Created slice system-getty.slice.
 14395	[    4.291448] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
 14396	[    4.292863] systemd[1]: Starting Remount Root and Kernel File Systems...
 14397	[    4.358991] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
 14398	[    4.862904] zram: Added device: zram0
 14399	[    4.863074] zram: Added device: zram1
 14400	[    4.863243] zram: Added device: zram2
 14401	[    4.978738] pwm-gpio pwmgpio: 1 gpio pwms loaded
 14402	[    5.135835] meson-saradc ff809000.adc: supply vref not found, using dummy regulator
 14403	[    5.138501] zram0: detected capacity change from 0 to 1904500736
 14404	[    5.166839] mc: Linux media interface: v0.10
 14405	[    5.212410] Registered IR keymap rc-odroid
 14406	[    5.232750] videodev: Linux video capture interface: v2.00
 14407	[    5.251317] IR NEC protocol handler initialized
 14408	[    5.261933] meson-drm ff900000.vpu: Queued 2 outputs on vpu
 14409	[    5.288746] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0
 14410	[    5.289710] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
 14411	[    5.289832] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input0
 14412	[    5.290345] meson-ir ff808000.ir: receiver initialized
 14413	[    5.296154] meson-drm ff900000.vpu: CVBS Output connector not available
 14414	[    5.305501] panfrost ffe40000.gpu: clock rate = 24000000
 14415	[    5.305553] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19
 14416	[    5.306165] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0
 14417	[    5.306170] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400
 14418	[    5.306174] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
 14419	[    5.306176] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1
 14420	[    5.325156] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
 14421	[    5.331305] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
 14422	[    5.332024] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 1
 14423	[    5.332728] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
 14424	[    5.333239] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 0
 14425	[    5.333292] meson-drm ff900000.vpu: [drm] Cannot find any crtc or sizes
 14426	[    5.339480] em28xx 1-2:1.0: New device PCTV PCTV 292e @ 480 Mbps (2013:025f, interface 0, class 0)
 14427	[    5.339491] em28xx 1-2:1.0: DVB interface 0 found: isoc
 14428	[    5.355159] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
 14429	[    5.403663] em28xx 1-2:1.0: chip ID is em28178
 14430	[    5.409071] axg-sound-card sound: ASoC: no DMI vendor name!
 14431	[    6.211578] Adding 1859860k swap on /dev/zram0.  Priority:5 extents:1 across:1859860k SSFS
 14432	[    6.276220] zram1: detected capacity change from 0 to 52428800
 14433	[    7.429817] em28xx 1-2:1.0: EEPROM ID = 26 00 01 00, EEPROM hash = 0x8d0cfd04
 14434	[    7.429825] em28xx 1-2:1.0: EEPROM info:
 14435	[    7.429829] em28xx 1-2:1.0: 	microcode start address = 0x0004, boot configuration = 0x01
 14436	[    7.435926] em28xx 1-2:1.0: 	AC97 audio (5 sample rates)
 14437	[    7.435929] em28xx 1-2:1.0: 	500mA max power
 14438	[    7.435934] em28xx 1-2:1.0: 	Table at offset 0x27, strings=0x146a, 0x1888, 0x0a7e
 14439	[    7.495572] em28xx 1-2:1.0: Identified as PCTV tripleStick (292e) (card=94)
 14440	[    7.495580] em28xx 1-2:1.0: dvb set to isoc mode.
 14441	[    7.495786] usbcore: registered new interface driver em28xx
 14442	[    7.521959] em28xx 1-2:1.0: Binding DVB extension
 14443	[    7.535292] i2c i2c-4: Added multiplexed i2c bus 5
 14444	[    7.535300] si2168 4-0064: Silicon Labs Si2168-B40 successfully identified
 14445	[    7.535303] si2168 4-0064: firmware version: B 4.0.2
 14446	[    7.543646] si2157 5-0060: Silicon Labs Si2147/2148/2157/2158 successfully attached
 14447	[    7.543679] dvbdev: DVB: registering new adapter (1-2:1.0)
 14448	[    7.543685] em28xx 1-2:1.0: DVB: registering adapter 0 frontend 0 (Silicon Labs Si2168)...
 14449	[    7.543691] dvbdev: dvb_create_media_entity: media entity 'Silicon Labs Si2168' registered.
 14450	[    7.544383] dvbdev: dvb_create_media_entity: media entity 'dvb-demux' registered.
 14451	[    7.545777] em28xx 1-2:1.0: DVB extension successfully initialized
 14452	[    7.545786] em28xx: Registered (Em28xx dvb Extension) extension
 14453	[    7.553028] em28xx 1-2:1.0: Registering input extension
 14454	[    7.587562] Registered IR keymap rc-pinnacle-pctv-hd
 14455	[    7.587741] rc rc1: PCTV tripleStick (292e) as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-2/1-2:1.0/rc/rc1
 14456	[    7.587821] rc rc1: lirc_dev: driver em28xx registered at minor = 1, scancode receiver, no transmitter
 14457	[    7.587881] input: PCTV tripleStick (292e) as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-2/1-2:1.0/rc/rc1/input1
 14458	[    7.587960] em28xx 1-2:1.0: Input extension successfully initialized
 14459	[    7.587963] em28xx: Registered (Em28xx Input Extension) extension
 14460	[    8.359501] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
 14461	[    8.359520] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
 14462	[    9.476426] systemd[1]: Started Armbian memory supported logging.
 14463	[    9.478693] systemd[1]: Starting Journal Service...
 14464	[    9.541660] systemd[1]: Started Journal Service.
 14465	[    9.566543] systemd-journald[1821]: Received request to flush runtime journal from PID 1
 14466
 14467	### armbian-release:
 14468
 14469	# PLEASE DO NOT EDIT THIS FILE
 14470	BOARD=odroidn2
 14471	BOARD_NAME="Odroid N2"
 14472	BOARDFAMILY=meson-g12b
 14473	BUILD_REPOSITORY_URL=https://github.com/armbian/build
 14474	BUILD_REPOSITORY_COMMIT=5f03d652
 14475	DISTRIBUTION_CODENAME=buster
 14476	DISTRIBUTION_STATUS=supported
 14477	VERSION=21.02.1
 14478	LINUXFAMILY=meson64
 14479	BRANCH=current
 14480	ARCH=arm64
 14481	IMAGE_TYPE=stable
 14482	BOARD_TYPE=conf
 14483	INITRD_ARCH=arm64
 14484	KERNEL_IMAGE_TYPE=Image
 14485
 14486	### boot environment:
 14487
 14488	verbosity=1
 14489	console=both
 14490	overlay_prefix=meson
 14491	rootdev=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c
 14492	rootfstype=ext4
 14493	usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
 14494
 14495	### lsusb:
 14496
 14497	Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc.
 14498	Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
 14499	Bus 001 Device 003: ID 2013:025f PCTV Systems
 14500	Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
 14501	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
 14502
 14503	### lscpu:
 14504
 14505	Architecture:        aarch64
 14506	Byte Order:          Little Endian
 14507	CPU(s):              6
 14508	On-line CPU(s) list: 0-5
 14509	Thread(s) per core:  1
 14510	Core(s) per socket:  3
 14511	Socket(s):           2
 14512	NUMA node(s):        1
 14513	Vendor ID:           ARM
 14514	Model:               4
 14515	Model name:          Cortex-A53
 14516	Stepping:            r0p4
 14517	CPU max MHz:         1992.0000
 14518	CPU min MHz:         100.0000
 14519	BogoMIPS:            48.00
 14520	L1d cache:           unknown size
 14521	L1i cache:           unknown size
 14522	L2 cache:            unknown size
 14523	NUMA node0 CPU(s):   0-5
 14524	Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 14525
 14526	### cpuinfo:
 14527
 14528	processor	: 0
 14529	BogoMIPS	: 48.00
 14530	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 14531	CPU implementer	: 0x41
 14532	CPU architecture: 8
 14533	CPU variant	: 0x0
 14534	CPU part	: 0xd03
 14535	CPU revision	: 4
 14536
 14537	processor	: 1
 14538	BogoMIPS	: 48.00
 14539	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 14540	CPU implementer	: 0x41
 14541	CPU architecture: 8
 14542	CPU variant	: 0x0
 14543	CPU part	: 0xd03
 14544	CPU revision	: 4
 14545
 14546	processor	: 2
 14547	BogoMIPS	: 48.00
 14548	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 14549	CPU implementer	: 0x41
 14550	CPU architecture: 8
 14551	CPU variant	: 0x0
 14552	CPU part	: 0xd09
 14553	CPU revision	: 2
 14554
 14555	processor	: 3
 14556	BogoMIPS	: 48.00
 14557	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 14558	CPU implementer	: 0x41
 14559	CPU architecture: 8
 14560	CPU variant	: 0x0
 14561	CPU part	: 0xd09
 14562	CPU revision	: 2
 14563
 14564	processor	: 4
 14565	BogoMIPS	: 48.00
 14566	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 14567	CPU implementer	: 0x41
 14568	CPU architecture: 8
 14569	CPU variant	: 0x0
 14570	CPU part	: 0xd09
 14571	CPU revision	: 2
 14572
 14573	processor	: 5
 14574	BogoMIPS	: 48.00
 14575	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 14576	CPU implementer	: 0x41
 14577	CPU architecture: 8
 14578	CPU variant	: 0x0
 14579	CPU part	: 0xd09
 14580	CPU revision	: 2
 14581
 14582
 14583	### meminfo:
 14584
 14585	MemTotal:        3719728 kB
 14586	MemFree:         3403240 kB
 14587	MemAvailable:    3357568 kB
 14588	Buffers:           11572 kB
 14589	Cached:            45876 kB
 14590	SwapCached:            0 kB
 14591	Active:            27936 kB
 14592	Inactive:         185304 kB
 14593	Active(anon):        136 kB
 14594	Inactive(anon):   160920 kB
 14595	Active(file):      27800 kB
 14596	Inactive(file):    24384 kB
 14597	Unevictable:           0 kB
 14598	Mlocked:               0 kB
 14599	SwapTotal:       1859860 kB
 14600	SwapFree:        1859860 kB
 14601	Dirty:              5980 kB
 14602	Writeback:             0 kB
 14603	AnonPages:        156172 kB
 14604	Mapped:            13548 kB
 14605	Shmem:              4972 kB
 14606	KReclaimable:      13192 kB
 14607	Slab:              40276 kB
 14608	SReclaimable:      13192 kB
 14609	SUnreclaim:        27084 kB
 14610	KernelStack:        2560 kB
 14611	PageTables:         5712 kB
 14612	NFS_Unstable:          0 kB
 14613	Bounce:                0 kB
 14614	WritebackTmp:          0 kB
 14615	CommitLimit:     3719724 kB
 14616	Committed_AS:    4240288 kB
 14617	VmallocTotal:   135290159040 kB
 14618	VmallocUsed:       33216 kB
 14619	VmallocChunk:          0 kB
 14620	Percpu:             1368 kB
 14621	HardwareCorrupted:     0 kB
 14622	AnonHugePages:         0 kB
 14623	ShmemHugePages:        0 kB
 14624	ShmemPmdMapped:        0 kB
 14625	FileHugePages:         0 kB
 14626	FilePmdMapped:         0 kB
 14627	CmaTotal:         917504 kB
 14628	CmaFree:          909824 kB
 14629	HugePages_Total:       0
 14630	HugePages_Free:        0
 14631	HugePages_Rsvd:        0
 14632	HugePages_Surp:        0
 14633	Hugepagesize:       2048 kB
 14634	Hugetlb:               0 kB
 14635
 14636	### virtual memory:
 14637
 14638	vm.admin_reserve_kbytes = 8192
 14639	vm.block_dump = 0
 14640	vm.compaction_proactiveness = 20
 14641	vm.compact_unevictable_allowed = 1
 14642	vm.dirty_background_bytes = 0
 14643	vm.dirty_background_ratio = 10
 14644	vm.dirty_bytes = 0
 14645	vm.dirty_expire_centisecs = 3000
 14646	vm.dirty_ratio = 20
 14647	vm.dirtytime_expire_seconds = 43200
 14648	vm.dirty_writeback_centisecs = 500
 14649	vm.extfrag_threshold = 500
 14650	vm.hugetlb_shm_group = 0
 14651	vm.laptop_mode = 0
 14652	vm.legacy_va_layout = 0
 14653	vm.lowmem_reserve_ratio = 256	256	32	0
 14654	vm.max_map_count = 65530
 14655	vm.memory_failure_early_kill = 0
 14656	vm.memory_failure_recovery = 1
 14657	vm.min_free_kbytes = 45056
 14658	vm.min_slab_ratio = 5
 14659	vm.min_unmapped_ratio = 1
 14660	vm.mmap_min_addr = 4096
 14661	vm.mmap_rnd_bits = 18
 14662	vm.mmap_rnd_compat_bits = 11
 14663	vm.nr_hugepages = 0
 14664	vm.nr_hugepages_mempolicy = 0
 14665	vm.nr_overcommit_hugepages = 0
 14666	vm.numa_stat = 1
 14667	vm.numa_zonelist_order = Node
 14668	vm.oom_dump_tasks = 1
 14669	vm.oom_kill_allocating_task = 0
 14670	vm.overcommit_kbytes = 0
 14671	vm.overcommit_memory = 0
 14672	vm.overcommit_ratio = 50
 14673	vm.page-cluster = 0
 14674	vm.page_lock_unfairness = 5
 14675	vm.panic_on_oom = 0
 14676	vm.percpu_pagelist_fraction = 0
 14677	vm.stat_interval = 1
 14678	vm.swappiness = 100
 14679	vm.user_reserve_kbytes = 115066
 14680	vm.vfs_cache_pressure = 100
 14681	vm.watermark_boost_factor = 15000
 14682	vm.watermark_scale_factor = 10
 14683	vm.zone_reclaim_mode = 0
 14684
 14685	### ip addr:
 14686
 14687	1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
 14688	    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
 14689	    inet XXX.XXX.0.1/8 scope host lo
 14690	       valid_lft forever preferred_lft forever
 14691	    inet6 ::1/128 scope host
 14692	       valid_lft forever preferred_lft forever
 14693	2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
 14694	    link/ether 00:1e:06:42:03:f8 brd ff:ff:ff:ff:ff:ff
 14695
 14696	### partitions:
 14697
 14698	major minor  #blocks  name
 14699
 14700	 179        0   31464960 mmcblk0
 14701	 179        1   31146208 mmcblk0p1
 14702	 252        0    1859864 zram0
 14703	 252        1      51200 zram1
 14704
 14705	### df:
 14706
 14707	udev            1.4G     0  1.4G   0% /dev
 14708	tmpfs           364M  4.9M  359M   2% /run
 14709	/dev/mmcblk0p1   30G  1.7G   28G   6% /
 14710	tmpfs           1.8G     0  1.8G   0% /dev/shm
 14711	tmpfs           5.0M  4.0K  5.0M   1% /run/lock
 14712	tmpfs           1.8G     0  1.8G   0% /sys/fs/cgroup
 14713	tmpfs           1.8G     0  1.8G   0% /tmp
 14714	/dev/zram1       49M  5.9M   40M  13% /var/log
 14715
 14716	### lsblk:
 14717
 14718	NAME        FSTYPE  SIZE MOUNTPOINT UUID
 14719	mmcblk0              30G
 14720	└─mmcblk0p1 ext4   29.7G /          bd34953d-41be-49d6-b1c0-c0c28a5e239c
 14721	zram1                50M /var/log
 14722
 14723	### zramctl:
 14724
 14725	NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
 14726	/dev/zram1 zstd           50M  132K  698B   36K       6 /var/log
 14727	/dev/zram0 lzo-rle       1.8G    4K   74B   12K       6 [SWAP]
 14728
 14729	### mtab:
 14730
 14731	/dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
 14732	/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
 14733	/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
 14734
 14735	### mmc0:b368 info:
 14736
 14737	               fwrev: 0x0
 14738	              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=CBADS MODALIAS=mmc:block
 14739	                 cid: 6f0303434241445310aa002b4d013b00
 14740	                 rca: 0xb368
 14741	                 csd: 400e005a5b590000f00e7f800a404000
 14742	              manfid: 0x00006f
 14743	                 ocr: 0x00200000
 14744	preferred_erase_size: 2097152
 14745	                type: SD
 14746	               hwrev: 0x1
 14747	                date: 11/2019
 14748	                 dsr: 0x404
 14749	          erase_size: 512
 14750	               oemid: 0x0303
 14751	              serial: 0xaa002b4d
 14752	                 ssr: 00000000000000280402800100fd180a001e00000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
 14753	                 scr: 02b5800300000000
 14754	                name: CBADS
 14755
 14756	### Boot system health:
 14757
 14758	Time       big.LITTLE   load %cpu %sys %usr %nice %io %irq   CPU  C.St.
 14759	17:52:51: 1908/1992MHz  2.89  27%  12%   5%   0%   9%   0% 22.1°C  0/11
 14760	17:52:52: 1908/1992MHz  2.89  56%   7%   6%   0%  40%   1% 20.3°C  0/11
 14761	17:52:52: 1908/1992MHz  2.89  56%   6%   8%   0%  40%   1% 20.3°C  0/11
 14762	17:52:52: 1908/1992MHz  2.89  46%   2%   6%   0%  36%   1% 19.8°C  0/11
 14763	17:52:53: 1908/1992MHz  2.89  65%   7%   5%   0%  50%   1% 21.6°C  0/11
 14764
 14765	### Activated 1 lzo-rle zram swap devices with 1816 MB each
 14766
 14767	### Activated Armbian ramlog partition with zstd compression
 14768
 14769	Mon 15 Feb 2021 06:14:20 PM GMT | Odroid N2 | 21.02.1 | arm64 | aarch64 | 5.10.12-meson64
 14770
 14771	### dmesg:
 14772
 14773	[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
 14774	[    0.000000] Linux version 5.10.12-meson64 (root@beast) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #21.02.1 SMP PREEMPT Wed Feb 3 21:06:36 CET 2021
 14775	[    0.000000] Machine model: Hardkernel ODROID-N2
 14776	[    0.000000] efi: UEFI not found.
 14777	[    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
 14778	[    0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB
 14779	[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
 14780	[    0.000000] NUMA: No NUMA configuration found
 14781	[    0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ed7fffff]
 14782	[    0.000000] NUMA: NODE_DATA [mem 0xb502f100-0xb5030fff]
 14783	[    0.000000] Zone ranges:
 14784	[    0.000000]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
 14785	[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000ed7fffff]
 14786	[    0.000000]   Normal   empty
 14787	[    0.000000] Movable zone start for each node
 14788	[    0.000000] Early memory node ranges
 14789	[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000004ffffff]
 14790	[    0.000000]   node   0: [mem 0x0000000005300000-0x00000000ed7fffff]
 14791	[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ed7fffff]
 14792	[    0.000000] On node 0 totalpages: 972032
 14793	[    0.000000]   DMA zone: 4096 pages used for memmap
 14794	[    0.000000]   DMA zone: 0 pages reserved
 14795	[    0.000000]   DMA zone: 261376 pages, LIFO batch:63
 14796	[    0.000000]   DMA32 zone: 11104 pages used for memmap
 14797	[    0.000000]   DMA32 zone: 710656 pages, LIFO batch:63
 14798	[    0.000000] psci: probing for conduit method from DT.
 14799	[    0.000000] psci: PSCIv1.0 detected in firmware.
 14800	[    0.000000] psci: Using standard PSCI v0.2 function IDs
 14801	[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
 14802	[    0.000000] psci: SMC Calling Convention v1.1
 14803	[    0.000000] percpu: Embedded 23 pages/cpu s56728 r8192 d29288 u94208
 14804	[    0.000000] pcpu-alloc: s56728 r8192 d29288 u94208 alloc=23*4096
 14805	[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
 14806	[    0.000000] Detected VIPT I-cache on CPU0
 14807	[    0.000000] CPU features: detected: ARM erratum 845719
 14808	[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 956832
 14809	[    0.000000] Policy zone: DMA32
 14810	[    0.000000] Kernel command line: root=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c rootwait rootfstype=ext4 console=ttyAML0,115200n8 console=tty1 loglevel=1  no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=1080p60hz cvbsmode=576cvbs max_freq_a53=1896 max_freq_a73=1800 maxcpus=6 voutmode=hdmi  disablehpd=false  cvbscable=0 overscan=100 consoleblank=0
 14811	[    0.000000] Kernel parameter elevator= does not have any effect anymore.
 14812	               Please use sysfs to set IO scheduler for individual devices.
 14813	[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
 14814	[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
 14815	[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
 14816	[    0.000000] software IO TLB: mapped [mem 0x0000000038ac5000-0x000000003cac5000] (64MB)
 14817	[    0.000000] Memory: 2785352K/3888128K available (14144K kernel code, 1760K rwdata, 5508K rodata, 3328K init, 592K bss, 185272K reserved, 917504K cma-reserved)
 14818	[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
 14819	[    0.000000] rcu: Preemptible hierarchical RCU implementation.
 14820	[    0.000000] rcu: 	RCU event tracing is enabled.
 14821	[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
 14822	[    0.000000] 	Trampoline variant of Tasks RCU enabled.
 14823	[    0.000000] 	Rude variant of Tasks RCU enabled.
 14824	[    0.000000] 	Tracing variant of Tasks RCU enabled.
 14825	[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
 14826	[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
 14827	[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
 14828	[    0.000000] GIC: Using split EOI/Deactivate mode
 14829	[    0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized
 14830	[    0.000000] random: get_random_bytes called from start_kernel+0x378/0x538 with crng_init=0
 14831	[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
 14832	[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
 14833	[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
 14834	[    0.000249] Console: colour dummy device 80x25
 14835	[    0.000283] printk: console [tty1] enabled
 14836	[    0.000368] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
 14837	[    0.000380] pid_max: default: 32768 minimum: 301
 14838	[    0.000464] LSM: Security Framework initializing
 14839	[    0.000489] Yama: becoming mindful.
 14840	[    0.000580] AppArmor: AppArmor initialized
 14841	[    0.000631] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
 14842	[    0.000651] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
 14843	[    0.002642] rcu: Hierarchical SRCU implementation.
 14844	[    0.005072] EFI services will not be available.
 14845	[    0.005495] smp: Bringing up secondary CPUs ...
 14846	[    0.006163] Detected VIPT I-cache on CPU1
 14847	[    0.006222] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
 14848	[    0.007409] CPU features: detected: ARM erratum 858921
 14849	[    0.007417] CPU features: detected: Spectre-v2
 14850	[    0.007421] CPU features: detected: Spectre-v4
 14851	[    0.007428] Detected VIPT I-cache on CPU2
 14852	[    0.007452] arch_timer: Enabling local workaround for ARM erratum 858921
 14853	[    0.007466] arch_timer: CPU2: Trapping CNTVCT access
 14854	[    0.007479] CPU2: Booted secondary processor 0x0000000100 [0x410fd092]
 14855	[    0.008189] Detected VIPT I-cache on CPU3
 14856	[    0.008204] arch_timer: Enabling local workaround for ARM erratum 858921
 14857	[    0.008212] arch_timer: CPU3: Trapping CNTVCT access
 14858	[    0.008219] CPU3: Booted secondary processor 0x0000000101 [0x410fd092]
 14859	[    0.008845] Detected VIPT I-cache on CPU4
 14860	[    0.008861] arch_timer: Enabling local workaround for ARM erratum 858921
 14861	[    0.008868] arch_timer: CPU4: Trapping CNTVCT access
 14862	[    0.008875] CPU4: Booted secondary processor 0x0000000102 [0x410fd092]
 14863	[    0.009490] Detected VIPT I-cache on CPU5
 14864	[    0.009507] arch_timer: Enabling local workaround for ARM erratum 858921
 14865	[    0.009514] arch_timer: CPU5: Trapping CNTVCT access
 14866	[    0.009521] CPU5: Booted secondary processor 0x0000000103 [0x410fd092]
 14867	[    0.009603] smp: Brought up 1 node, 6 CPUs
 14868	[    0.009620] SMP: Total of 6 processors activated.
 14869	[    0.009628] CPU features: detected: 32-bit EL0 Support
 14870	[    0.009634] CPU features: detected: CRC32 instructions
 14871	[    0.009639] CPU features: detected: 32-bit EL1 Support
 14872	[    0.020888] CPU: All CPU(s) started at EL2
 14873	[    0.020938] alternatives: patching kernel code
 14874	[    0.022879] devtmpfs: initialized
 14875	[    0.030539] Registered cp15_barrier emulation handler
 14876	[    0.030553] Registered setend emulation handler
 14877	[    0.030689] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
 14878	[    0.030728] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
 14879	[    0.044648] pinctrl core: initialized pinctrl subsystem
 14880	[    0.045189] DMI not present or invalid.
 14881	[    0.045591] NET: Registered protocol family 16
 14882	[    0.047201] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
 14883	[    0.047474] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
 14884	[    0.047700] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
 14885	[    0.047744] audit: initializing netlink subsys (disabled)
 14886	[    0.047853] audit: type=2000 audit(0.044:1): state=initialized audit_enabled=0 res=1
 14887	[    0.049167] thermal_sys: Registered thermal governor 'fair_share'
 14888	[    0.049175] thermal_sys: Registered thermal governor 'bang_bang'
 14889	[    0.049180] thermal_sys: Registered thermal governor 'step_wise'
 14890	[    0.049183] thermal_sys: Registered thermal governor 'user_space'
 14891	[    0.049597] cpuidle: using governor menu
 14892	[    0.049935] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
 14893	[    0.050054] ASID allocator initialised with 65536 entries
 14894	[    0.051012] Serial: AMBA PL011 UART driver
 14895	[    0.085226] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
 14896	[    0.085238] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
 14897	[    0.085244] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
 14898	[    0.085249] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
 14899	[    0.087110] cryptd: max_cpu_qlen set to 1000
 14900	[    0.156147] raid6: neonx8   gen()  2781 MB/s
 14901	[    0.224203] raid6: neonx8   xor()  2042 MB/s
 14902	[    0.292276] raid6: neonx4   gen()  2994 MB/s
 14903	[    0.360334] raid6: neonx4   xor()  2348 MB/s
 14904	[    0.428427] raid6: neonx2   gen()  2578 MB/s
 14905	[    0.496471] raid6: neonx2   xor()  2185 MB/s
 14906	[    0.564541] raid6: neonx1   gen()  2078 MB/s
 14907	[    0.632601] raid6: neonx1   xor()  1726 MB/s
 14908	[    0.700677] raid6: int64x8  gen()  1377 MB/s
 14909	[    0.768740] raid6: int64x8  xor()   735 MB/s
 14910	[    0.836826] raid6: int64x4  gen()  1463 MB/s
 14911	[    0.904870] raid6: int64x4  xor()   733 MB/s
 14912	[    0.972941] raid6: int64x2  gen()  1363 MB/s
 14913	[    1.041014] raid6: int64x2  xor()   619 MB/s
 14914	[    1.109074] raid6: int64x1  gen()  1120 MB/s
 14915	[    1.177138] raid6: int64x1  xor()   462 MB/s
 14916	[    1.177141] raid6: using algorithm neonx4 gen() 2994 MB/s
 14917	[    1.177144] raid6: .... xor() 2348 MB/s, rmw enabled
 14918	[    1.177148] raid6: using neon recovery algorithm
 14919	[    1.177586] ACPI: Interpreter disabled.
 14920	[    1.178384] 5V: supplied by 12V
 14921	[    1.179292] VDDAO_3V3: supplied by 12V
 14922	[    1.179764] iommu: Default domain type: Translated
 14923	[    1.179912] vgaarb: loaded
 14924	[    1.180645] SCSI subsystem initialized
 14925	[    1.181032] usbcore: registered new interface driver usbfs
 14926	[    1.181081] usbcore: registered new interface driver hub
 14927	[    1.181116] usbcore: registered new device driver usb
 14928	[    1.181355] pps_core: LinuxPPS API ver. 1 registered
 14929	[    1.181359] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
 14930	[    1.181377] PTP clock support registered
 14931	[    1.181564] EDAC MC: Ver: 3.0.0
 14932	[    1.182898] NetLabel: Initializing
 14933	[    1.182905] NetLabel:  domain hash size = 128
 14934	[    1.182908] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
 14935	[    1.182950] NetLabel:  unlabeled traffic allowed by default
 14936	[    1.183401] clocksource: Switched to clocksource arch_sys_counter
 14937	[    1.183604] VFS: Disk quotas dquot_6.6.0
 14938	[    1.183648] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
 14939	[    1.184014] AppArmor: AppArmor Filesystem Enabled
 14940	[    1.184059] pnp: PnP ACPI: disabled
 14941	[    1.189855] NET: Registered protocol family 2
 14942	[    1.190323] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
 14943	[    1.190427] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
 14944	[    1.190683] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
 14945	[    1.190870] TCP: Hash tables configured (established 32768 bind 32768)
 14946	[    1.191018] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
 14947	[    1.191082] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
 14948	[    1.191128] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
 14949	[    1.191270] NET: Registered protocol family 1
 14950	[    1.191293] PCI: CLS 0 bytes, default 64
 14951	[    1.191465] Trying to unpack rootfs image as initramfs...
 14952	[    1.727643] Freeing initrd memory: 13544K
 14953	[    1.728562] kvm [1]: IPA Size Limit: 40 bits
 14954	[    1.729266] kvm [1]: vgic interrupt IRQ9
 14955	[    1.729400] kvm [1]: Hyp mode initialized successfully
 14956	[    1.734504] Initialise system trusted keyrings
 14957	[    1.734540] Key type blacklist registered
 14958	[    1.734648] workingset: timestamp_bits=44 max_order=20 bucket_order=0
 14959	[    1.737847] zbud: loaded
 14960	[    1.738831] squashfs: version 4.0 (2009/01/31) Phillip Lougher
 14961	[    1.739289] fuse: init (API version 7.32)
 14962	[    1.740069] integrity: Platform Keyring initialized
 14963	[    1.767795] xor: measuring software checksum speed
 14964	[    1.770634]    8regs           :  3473 MB/sec
 14965	[    1.773129]    32regs          :  4021 MB/sec
 14966	[    1.775783]    arm64_neon      :  3719 MB/sec
 14967	[    1.775787] xor: using function: 32regs (4021 MB/sec)
 14968	[    1.775793] Key type asymmetric registered
 14969	[    1.775797] Asymmetric key parser 'x509' registered
 14970	[    1.775830] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
 14971	[    1.775919] io scheduler mq-deadline registered
 14972	[    1.775923] io scheduler kyber registered
 14973	[    1.776002] io scheduler bfq registered
 14974	[    1.778514] gpio-447 (usb-hub-reset): hogged as output/high
 14975	[    1.781499] EINJ: ACPI disabled.
 14976	[    1.787787] soc soc0: Amlogic Meson G12B (S922X) Revision 29:a (40:2) Detected
 14977	[    1.789187] VCC_3V3: supplied by VDDAO_3V3
 14978	[    1.789235] FLASH_1V8: supplied by VCC_3V3
 14979	[    1.789266] VCC_1V8: supplied by VCC_3V3
 14980	[    1.789296] VDDAO_1V8: supplied by VDDAO_3V3
 14981	[    1.789327] VDDCPU_A: supplied by regulator-dummy
 14982	[    1.789699] VDDCPU_B: supplied by regulator-dummy
 14983	[    1.790377] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
 14984	[    1.792691] Serial: AMBA driver
 14985	[    1.792989] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart
 14986	[    1.793083] printk: console [ttyAML0] enabled
 14987	[    1.793605] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 33, base_baud = 1500000) is a meson_uart
 14988	[    1.798971] loop: module loaded
 14989	[    1.800848] libphy: Fixed MDIO Bus: probed
 14990	[    1.801968] tun: Universal TUN/TAP device driver, 1.6
 14991	[    1.802625] thunder_xcv, ver 1.0
 14992	[    1.802658] thunder_bgx, ver 1.0
 14993	[    1.802684] nicpf, ver 1.0
 14994	[    1.803152] e1000e: Intel(R) PRO/1000 Network Driver
 14995	[    1.803156] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
 14996	[    1.803195] igb: Intel(R) Gigabit Ethernet Network Driver
 14997	[    1.803198] igb: Copyright (c) 2007-2014 Intel Corporation.
 14998	[    1.803228] igbvf: Intel(R) Gigabit Virtual Function Network Driver
 14999	[    1.803232] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
 15000	[    1.803362] sky2: driver version 1.30
 15001	[    1.803813] VFIO - User Level meta-driver version: 0.3
 15002	[    1.805214] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
 15003	[    1.805232] ehci-pci: EHCI PCI platform driver
 15004	[    1.805260] ehci-platform: EHCI generic platform driver
 15005	[    1.805388] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
 15006	[    1.805397] ohci-pci: OHCI PCI platform driver
 15007	[    1.805431] ohci-platform: OHCI generic platform driver
 15008	[    1.805843] usbcore: registered new interface driver usb-storage
 15009	[    1.807096] mousedev: PS/2 mouse device common for all mice
 15010	[    1.807457] i2c /dev entries driver
 15011	[    1.812858] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17
 15012	[    1.813525] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz
 15013	[    1.814200] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-1 failed:-17
 15014	[    1.814813] sdhci: Secure Digital Host Controller Interface driver
 15015	[    1.814818] sdhci: Copyright(c) Pierre Ossman
 15016	[    1.814936] Synopsys Designware Multimedia Card Interface Driver
 15017	[    1.815380] sdhci-pltfm: SDHCI platform and OF driver helper
 15018	[    1.815991] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq
 15019	[    1.817079] ledtrig-cpu: registered to indicate activity on CPUs
 15020	[    1.817350] meson-sm: secure-monitor enabled
 15021	[    1.817506] hid: raw HID events driver (C) Jiri Kosina
 15022	[    1.817581] usbcore: registered new interface driver usbhid
 15023	[    1.817584] usbhid: USB HID core driver
 15024	[    1.818569] NET: Registered protocol family 10
 15025	[    1.818987] Segment Routing with IPv6
 15026	[    1.819017] NET: Registered protocol family 17
 15027	[    1.819056] 8021q: 802.1Q VLAN Support v1.8
 15028	[    1.819083] Key type dns_resolver registered
 15029	[    1.819372] registered taskstats version 1
 15030	[    1.819377] Loading compiled-in X.509 certificates
 15031	[    1.821065] Loaded X.509 cert 'Build time autogenerated kernel key: f47c178852ca39740c3546b008122b65f5ed9bce'
 15032	[    1.822626] zswap: loaded using pool zstd/z3fold
 15033	[    1.822781] Key type ._fscrypt registered
 15034	[    1.822784] Key type .fscrypt registered
 15035	[    1.822785] Key type fscrypt-provisioning registered
 15036	[    1.823921] Btrfs loaded, crc32c=crc32c-generic
 15037	[    1.829981] Key type encrypted registered
 15038	[    1.829992] AppArmor: AppArmor sha1 policy hashing enabled
 15039	[    1.836398] HUB_5V: supplied by 5V
 15040	[    1.836604] USB_PWR_EN: supplied by 5V
 15041	[    1.838234] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2
 15042	[    1.838240] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1
 15043	[    1.840961] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator
 15044	[    1.841015] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator
 15045	[    1.841146] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM
 15046	[    1.841733] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
 15047	[    1.841746] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
 15048	[    1.841847] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010
 15049	[    1.841870] xhci-hcd xhci-hcd.0.auto: irq 41, io mem 0xff500000
 15050	[    1.841994] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
 15051	[    1.841998] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 15052	[    1.842001] usb usb1: Product: xHCI Host Controller
 15053	[    1.842003] usb usb1: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
 15054	[    1.842005] usb usb1: SerialNumber: xhci-hcd.0.auto
 15055	[    1.842223] hub 1-0:1.0: USB hub found
 15056	[    1.842235] hub 1-0:1.0: 2 ports detected
 15057	[    1.842363] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
 15058	[    1.842369] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
 15059	[    1.842374] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
 15060	[    1.842394] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
 15061	[    1.842426] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
 15062	[    1.842430] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 15063	[    1.842433] usb usb2: Product: xHCI Host Controller
 15064	[    1.842435] usb usb2: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
 15065	[    1.842438] usb usb2: SerialNumber: xhci-hcd.0.auto
 15066	[    1.842604] hub 2-0:1.0: USB hub found
 15067	[    1.842615] hub 2-0:1.0: 1 port detected
 15068	[    1.842848] dwc3-meson-g12a ffe09000.usb: switching to Device Mode
 15069	[    1.843727] meson-gx-mmc ffe05000.sd: Got CD GPIO
 15070	[    1.868475] Freeing unused kernel memory: 3328K
 15071	[    1.911455] Run /init as init process
 15072	[    1.911459]   with arguments:
 15073	[    1.911461]     /init
 15074	[    1.911463]   with environment:
 15075	[    1.911465]     HOME=/
 15076	[    1.911466]     TERM=linux
 15077	[    1.911468]     hdmimode=1080p60hz
 15078	[    1.911470]     cvbsmode=576cvbs
 15079	[    1.911471]     max_freq_a53=1896
 15080	[    1.911473]     max_freq_a73=1800
 15081	[    1.911474]     voutmode=hdmi
 15082	[    1.911475]     disablehpd=false
 15083	[    1.911477]     cvbscable=0
 15084	[    1.911478]     overscan=100
 15085	[    1.920451] mmc0: new high speed SDHC card at address b368
 15086	[    1.921158] mmcblk0: mmc0:b368 CBADS 30.0 GiB
 15087	[    1.922974]  mmcblk0: p1
 15088	[    2.034365] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found
 15089	[    2.034373] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found
 15090	[    2.035547] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock
 15091	[    2.036843] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37
 15092	[    2.036853] meson8b-dwmac ff3f0000.ethernet: 	DWMAC1000
 15093	[    2.036856] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported
 15094	[    2.036859] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported
 15095	[    2.036861] meson8b-dwmac ff3f0000.ethernet: COE Type 2
 15096	[    2.036863] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported
 15097	[    2.036865] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported
 15098	[    2.036915] meson8b-dwmac ff3f0000.ethernet: Normal descriptors
 15099	[    2.036918] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled
 15100	[    2.036920] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
 15101	[    2.037117] libphy: stmmac: probed
 15102	[    2.038199] libphy: mdio_mux: probed
 15103	[    2.051604] meson-vrtc ff8000a8.rtc: registered as rtc1
 15104	[    2.066843] rtc-pcf8563 1-0051: registered as rtc0
 15105	[    2.068034] rtc-pcf8563 1-0051: setting system clock to 2021-02-15T18:14:12 UTC (1613412852)
 15106	[    2.175550] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
 15107	[    2.200161] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.04
 15108	[    2.200170] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
 15109	[    2.200174] usb 2-1: Product: USB3.1 Hub
 15110	[    2.200177] usb 2-1: Manufacturer: GenesysLogic
 15111	[    2.226665] hub 2-1:1.0: USB hub found
 15112	[    2.226960] hub 2-1:1.0: 4 ports detected
 15113	[    2.243861] libphy: mdio_mux: probed
 15114	[    2.323423] usb 1-1: new high-speed USB device number 2 using xhci-hcd
 15115	[    2.331917] random: fast init done
 15116	[    2.473777] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.04
 15117	[    2.473783] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
 15118	[    2.473786] usb 1-1: Product: USB2.1 Hub
 15119	[    2.473789] usb 1-1: Manufacturer: GenesysLogic
 15120	[    2.514676] hub 1-1:1.0: USB hub found
 15121	[    2.514944] hub 1-1:1.0: 4 ports detected
 15122	[    2.817539] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
 15123	[    2.891432] usb 1-1.4: new high-speed USB device number 3 using xhci-hcd
 15124	[    3.015878] usb 1-1.4: New USB device found, idVendor=2013, idProduct=025f, bcdDevice= 1.00
 15125	[    3.015888] usb 1-1.4: New USB device strings: Mfr=3, Product=1, SerialNumber=2
 15126	[    3.015892] usb 1-1.4: Product: PCTV 292e
 15127	[    3.015895] usb 1-1.4: Manufacturer: PCTV
 15128	[    3.015898] usb 1-1.4: SerialNumber: 0011356964
 15129	[    3.631998] systemd[1]: Inserted module 'autofs4'
 15130	[    3.678627] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
 15131	[    3.678851] systemd[1]: Detected architecture arm64.
 15132	[    3.709612] systemd[1]: Set hostname to <odroidn2>.
 15133	[    4.037574] random: systemd: uninitialized urandom read (16 bytes read)
 15134	[    4.040877] random: systemd: uninitialized urandom read (16 bytes read)
 15135	[    4.041040] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
 15136	[    4.041222] random: systemd: uninitialized urandom read (16 bytes read)
 15137	[    4.041238] systemd[1]: Reached target Swap.
 15138	[    4.041306] systemd[1]: Reached target System Time Synchronized.
 15139	[    4.041487] systemd[1]: Listening on initctl Compatibility Named Pipe.
 15140	[    4.042752] systemd[1]: Created slice system-serial\x2dgetty.slice.
 15141	[    4.043153] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
 15142	[    4.043460] systemd[1]: Listening on Syslog Socket.
 15143	[    4.143869] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
 15144	[    4.632407] zram: Added device: zram0
 15145	[    4.632575] zram: Added device: zram1
 15146	[    4.632723] zram: Added device: zram2
 15147	[    4.668264] pwm-gpio pwmgpio: 1 gpio pwms loaded
 15148	[    4.848314] meson-saradc ff809000.adc: supply vref not found, using dummy regulator
 15149	[    4.851987] mc: Linux media interface: v0.10
 15150	[    4.946211] videodev: Linux video capture interface: v2.00
 15151	[    4.974006] meson-drm ff900000.vpu: Queued 2 outputs on vpu
 15152	[    4.979454] Registered IR keymap rc-odroid
 15153	[    4.997176] IR NEC protocol handler initialized
 15154	[    5.004314] panfrost ffe40000.gpu: clock rate = 24000000
 15155	[    5.004390] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19
 15156	[    5.005237] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0
 15157	[    5.005247] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400
 15158	[    5.005252] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
 15159	[    5.005255] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1
 15160	[    5.013957] meson-drm ff900000.vpu: CVBS Output connector not available
 15161	[    5.020006] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 0
 15162	[    5.023515] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0
 15163	[    5.023596] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
 15164	[    5.023656] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input0
 15165	[    5.023854] meson-ir ff808000.ir: receiver initialized
 15166	[    5.038396] zram0: detected capacity change from 0 to 1904500736
 15167	[    5.047506] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
 15168	[    5.049627] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
 15169	[    5.049881] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
 15170	[    5.050081] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 1
 15171	[    5.050126] meson-drm ff900000.vpu: [drm] Cannot find any crtc or sizes
 15172	[    5.064045] em28xx 1-1.4:1.0: New device PCTV PCTV 292e @ 480 Mbps (2013:025f, interface 0, class 0)
 15173	[    5.064053] em28xx 1-1.4:1.0: DVB interface 0 found: isoc
 15174	[    5.093412] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
 15175	[    5.125227] axg-sound-card sound: ASoC: no DMI vendor name!
 15176	[    5.128419] em28xx 1-1.4:1.0: chip ID is em28178
 15177	[    6.079423] Adding 1859860k swap on /dev/zram0.  Priority:5 extents:1 across:1859860k SSFS
 15178	[    6.143632] zram1: detected capacity change from 0 to 52428800
 15179	[    7.173620] em28xx 1-1.4:1.0: EEPROM ID = 26 00 01 00, EEPROM hash = 0x8d0cfd04
 15180	[    7.173626] em28xx 1-1.4:1.0: EEPROM info:
 15181	[    7.173629] em28xx 1-1.4:1.0: 	microcode start address = 0x0004, boot configuration = 0x01
 15182	[    7.179735] em28xx 1-1.4:1.0: 	AC97 audio (5 sample rates)
 15183	[    7.179738] em28xx 1-1.4:1.0: 	500mA max power
 15184	[    7.179741] em28xx 1-1.4:1.0: 	Table at offset 0x27, strings=0x146a, 0x1888, 0x0a7e
 15185	[    7.239397] em28xx 1-1.4:1.0: Identified as PCTV tripleStick (292e) (card=94)
 15186	[    7.239401] em28xx 1-1.4:1.0: dvb set to isoc mode.
 15187	[    7.239541] usbcore: registered new interface driver em28xx
 15188	[    7.265820] em28xx 1-1.4:1.0: Binding DVB extension
 15189	[    7.279068] i2c i2c-4: Added multiplexed i2c bus 5
 15190	[    7.279077] si2168 4-0064: Silicon Labs Si2168-B40 successfully identified
 15191	[    7.279079] si2168 4-0064: firmware version: B 4.0.2
 15192	[    7.290008] si2157 5-0060: Silicon Labs Si2147/2148/2157/2158 successfully attached
 15193	[    7.290040] dvbdev: DVB: registering new adapter (1-1.4:1.0)
 15194	[    7.290046] em28xx 1-1.4:1.0: DVB: registering adapter 0 frontend 0 (Silicon Labs Si2168)...
 15195	[    7.290058] dvbdev: dvb_create_media_entity: media entity 'Silicon Labs Si2168' registered.
 15196	[    7.290733] dvbdev: dvb_create_media_entity: media entity 'dvb-demux' registered.
 15197	[    7.314528] em28xx 1-1.4:1.0: DVB extension successfully initialized
 15198	[    7.314536] em28xx: Registered (Em28xx dvb Extension) extension
 15199	[    7.321432] em28xx 1-1.4:1.0: Registering input extension
 15200	[    7.351399] Registered IR keymap rc-pinnacle-pctv-hd
 15201	[    7.351574] rc rc1: PCTV tripleStick (292e) as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.4/1-1.4:1.0/rc/rc1
 15202	[    7.351680] rc rc1: lirc_dev: driver em28xx registered at minor = 1, scancode receiver, no transmitter
 15203	[    7.351739] input: PCTV tripleStick (292e) as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.4/1-1.4:1.0/rc/rc1/input1
 15204	[    7.351824] em28xx 1-1.4:1.0: Input extension successfully initialized
 15205	[    7.351828] em28xx: Registered (Em28xx Input Extension) extension
 15206	[    8.226839] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
 15207	[    8.226859] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
 15208	[    9.359304] systemd[1]: Started Armbian memory supported logging.
 15209	[    9.363279] systemd[1]: Starting Journal Service...
 15210	[    9.426462] systemd[1]: Started Journal Service.
 15211	[    9.454154] systemd-journald[1821]: Received request to flush runtime journal from PID 1
 15212
 15213	### armbian-release:
 15214
 15215	# PLEASE DO NOT EDIT THIS FILE
 15216	BOARD=odroidn2
 15217	BOARD_NAME="Odroid N2"
 15218	BOARDFAMILY=meson-g12b
 15219	BUILD_REPOSITORY_URL=https://github.com/armbian/build
 15220	BUILD_REPOSITORY_COMMIT=5f03d652
 15221	DISTRIBUTION_CODENAME=buster
 15222	DISTRIBUTION_STATUS=supported
 15223	VERSION=21.02.1
 15224	LINUXFAMILY=meson64
 15225	BRANCH=current
 15226	ARCH=arm64
 15227	IMAGE_TYPE=stable
 15228	BOARD_TYPE=conf
 15229	INITRD_ARCH=arm64
 15230	KERNEL_IMAGE_TYPE=Image
 15231
 15232	### boot environment:
 15233
 15234	verbosity=1
 15235	console=both
 15236	overlay_prefix=meson
 15237	rootdev=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c
 15238	rootfstype=ext4
 15239	usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
 15240
 15241	### lsusb:
 15242
 15243	Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc.
 15244	Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
 15245	Bus 001 Device 003: ID 2013:025f PCTV Systems
 15246	Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
 15247	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
 15248
 15249	### lscpu:
 15250
 15251	Architecture:        aarch64
 15252	Byte Order:          Little Endian
 15253	CPU(s):              6
 15254	On-line CPU(s) list: 0-5
 15255	Thread(s) per core:  1
 15256	Core(s) per socket:  3
 15257	Socket(s):           2
 15258	NUMA node(s):        1
 15259	Vendor ID:           ARM
 15260	Model:               4
 15261	Model name:          Cortex-A53
 15262	Stepping:            r0p4
 15263	CPU max MHz:         1992.0000
 15264	CPU min MHz:         100.0000
 15265	BogoMIPS:            48.00
 15266	L1d cache:           unknown size
 15267	L1i cache:           unknown size
 15268	L2 cache:            unknown size
 15269	NUMA node0 CPU(s):   0-5
 15270	Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 15271
 15272	### cpuinfo:
 15273
 15274	processor	: 0
 15275	BogoMIPS	: 48.00
 15276	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 15277	CPU implementer	: 0x41
 15278	CPU architecture: 8
 15279	CPU variant	: 0x0
 15280	CPU part	: 0xd03
 15281	CPU revision	: 4
 15282
 15283	processor	: 1
 15284	BogoMIPS	: 48.00
 15285	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 15286	CPU implementer	: 0x41
 15287	CPU architecture: 8
 15288	CPU variant	: 0x0
 15289	CPU part	: 0xd03
 15290	CPU revision	: 4
 15291
 15292	processor	: 2
 15293	BogoMIPS	: 48.00
 15294	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 15295	CPU implementer	: 0x41
 15296	CPU architecture: 8
 15297	CPU variant	: 0x0
 15298	CPU part	: 0xd09
 15299	CPU revision	: 2
 15300
 15301	processor	: 3
 15302	BogoMIPS	: 48.00
 15303	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 15304	CPU implementer	: 0x41
 15305	CPU architecture: 8
 15306	CPU variant	: 0x0
 15307	CPU part	: 0xd09
 15308	CPU revision	: 2
 15309
 15310	processor	: 4
 15311	BogoMIPS	: 48.00
 15312	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 15313	CPU implementer	: 0x41
 15314	CPU architecture: 8
 15315	CPU variant	: 0x0
 15316	CPU part	: 0xd09
 15317	CPU revision	: 2
 15318
 15319	processor	: 5
 15320	BogoMIPS	: 48.00
 15321	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 15322	CPU implementer	: 0x41
 15323	CPU architecture: 8
 15324	CPU variant	: 0x0
 15325	CPU part	: 0xd09
 15326	CPU revision	: 2
 15327
 15328
 15329	### meminfo:
 15330
 15331	MemTotal:        3719728 kB
 15332	MemFree:         3366400 kB
 15333	MemAvailable:    3320852 kB
 15334	Buffers:           11572 kB
 15335	Cached:            45948 kB
 15336	SwapCached:            0 kB
 15337	Active:            28244 kB
 15338	Inactive:         219324 kB
 15339	Active(anon):        100 kB
 15340	Inactive(anon):   194856 kB
 15341	Active(file):      28144 kB
 15342	Inactive(file):    24468 kB
 15343	Unevictable:           0 kB
 15344	Mlocked:               0 kB
 15345	SwapTotal:       1859860 kB
 15346	SwapFree:        1859860 kB
 15347	Dirty:              6120 kB
 15348	Writeback:             0 kB
 15349	AnonPages:        190120 kB
 15350	Mapped:            13516 kB
 15351	Shmem:              4896 kB
 15352	KReclaimable:      13004 kB
 15353	Slab:              40396 kB
 15354	SReclaimable:      13004 kB
 15355	SUnreclaim:        27392 kB
 15356	KernelStack:        2496 kB
 15357	PageTables:         6292 kB
 15358	NFS_Unstable:          0 kB
 15359	Bounce:                0 kB
 15360	WritebackTmp:          0 kB
 15361	CommitLimit:     3719724 kB
 15362	Committed_AS:    4239092 kB
 15363	VmallocTotal:   135290159040 kB
 15364	VmallocUsed:       33168 kB
 15365	VmallocChunk:          0 kB
 15366	Percpu:             1368 kB
 15367	HardwareCorrupted:     0 kB
 15368	AnonHugePages:         0 kB
 15369	ShmemHugePages:        0 kB
 15370	ShmemPmdMapped:        0 kB
 15371	FileHugePages:         0 kB
 15372	FilePmdMapped:         0 kB
 15373	CmaTotal:         917504 kB
 15374	CmaFree:          909824 kB
 15375	HugePages_Total:       0
 15376	HugePages_Free:        0
 15377	HugePages_Rsvd:        0
 15378	HugePages_Surp:        0
 15379	Hugepagesize:       2048 kB
 15380	Hugetlb:               0 kB
 15381
 15382	### virtual memory:
 15383
 15384	vm.admin_reserve_kbytes = 8192
 15385	vm.block_dump = 0
 15386	vm.compaction_proactiveness = 20
 15387	vm.compact_unevictable_allowed = 1
 15388	vm.dirty_background_bytes = 0
 15389	vm.dirty_background_ratio = 10
 15390	vm.dirty_bytes = 0
 15391	vm.dirty_expire_centisecs = 3000
 15392	vm.dirty_ratio = 20
 15393	vm.dirtytime_expire_seconds = 43200
 15394	vm.dirty_writeback_centisecs = 500
 15395	vm.extfrag_threshold = 500
 15396	vm.hugetlb_shm_group = 0
 15397	vm.laptop_mode = 0
 15398	vm.legacy_va_layout = 0
 15399	vm.lowmem_reserve_ratio = 256	256	32	0
 15400	vm.max_map_count = 65530
 15401	vm.memory_failure_early_kill = 0
 15402	vm.memory_failure_recovery = 1
 15403	vm.min_free_kbytes = 45056
 15404	vm.min_slab_ratio = 5
 15405	vm.min_unmapped_ratio = 1
 15406	vm.mmap_min_addr = 4096
 15407	vm.mmap_rnd_bits = 18
 15408	vm.mmap_rnd_compat_bits = 11
 15409	vm.nr_hugepages = 0
 15410	vm.nr_hugepages_mempolicy = 0
 15411	vm.nr_overcommit_hugepages = 0
 15412	vm.numa_stat = 1
 15413	vm.numa_zonelist_order = Node
 15414	vm.oom_dump_tasks = 1
 15415	vm.oom_kill_allocating_task = 0
 15416	vm.overcommit_kbytes = 0
 15417	vm.overcommit_memory = 0
 15418	vm.overcommit_ratio = 50
 15419	vm.page-cluster = 0
 15420	vm.page_lock_unfairness = 5
 15421	vm.panic_on_oom = 0
 15422	vm.percpu_pagelist_fraction = 0
 15423	vm.stat_interval = 1
 15424	vm.swappiness = 100
 15425	vm.user_reserve_kbytes = 115024
 15426	vm.vfs_cache_pressure = 100
 15427	vm.watermark_boost_factor = 15000
 15428	vm.watermark_scale_factor = 10
 15429	vm.zone_reclaim_mode = 0
 15430
 15431	### ip addr:
 15432
 15433	1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
 15434	    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
 15435	    inet XXX.XXX.0.1/8 scope host lo
 15436	       valid_lft forever preferred_lft forever
 15437	    inet6 ::1/128 scope host
 15438	       valid_lft forever preferred_lft forever
 15439	2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
 15440	    link/ether 00:1e:06:42:03:f8 brd ff:ff:ff:ff:ff:ff
 15441
 15442	### partitions:
 15443
 15444	major minor  #blocks  name
 15445
 15446	 179        0   31464960 mmcblk0
 15447	 179        1   31146208 mmcblk0p1
 15448	 252        0    1859864 zram0
 15449	 252        1      51200 zram1
 15450
 15451	### df:
 15452
 15453	udev            1.4G     0  1.4G   0% /dev
 15454	tmpfs           364M  4.9M  359M   2% /run
 15455	/dev/mmcblk0p1   30G  1.7G   28G   6% /
 15456	tmpfs           1.8G     0  1.8G   0% /dev/shm
 15457	tmpfs           5.0M  4.0K  5.0M   1% /run/lock
 15458	tmpfs           1.8G     0  1.8G   0% /sys/fs/cgroup
 15459	tmpfs           1.8G     0  1.8G   0% /tmp
 15460	/dev/zram1       49M  6.2M   39M  14% /var/log
 15461
 15462	### lsblk:
 15463
 15464	NAME        FSTYPE  SIZE MOUNTPOINT UUID
 15465	mmcblk0              30G
 15466	└─mmcblk0p1 ext4   29.7G /          bd34953d-41be-49d6-b1c0-c0c28a5e239c
 15467	zram1                50M /var/log
 15468
 15469	### zramctl:
 15470
 15471	NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
 15472	/dev/zram1 zstd           50M  132K  698B   36K       6 /var/log
 15473	/dev/zram0 lzo-rle       1.8G    4K   74B   12K       6 [SWAP]
 15474
 15475	### mtab:
 15476
 15477	/dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
 15478	/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
 15479	/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
 15480
 15481	### mmc0:b368 info:
 15482
 15483	               fwrev: 0x0
 15484	              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=CBADS MODALIAS=mmc:block
 15485	                 cid: 6f0303434241445310aa002b4d013b00
 15486	                 rca: 0xb368
 15487	                 csd: 400e005a5b590000f00e7f800a404000
 15488	              manfid: 0x00006f
 15489	                 ocr: 0x00200000
 15490	preferred_erase_size: 2097152
 15491	                type: SD
 15492	               hwrev: 0x1
 15493	                date: 11/2019
 15494	                 dsr: 0x404
 15495	          erase_size: 512
 15496	               oemid: 0x0303
 15497	              serial: 0xaa002b4d
 15498	                 ssr: 00000000000000280402800100fd180a001e00000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
 15499	                 scr: 02b5800300000000
 15500	                name: CBADS
 15501
 15502	### Boot system health:
 15503
 15504	Time       big.LITTLE   load %cpu %sys %usr %nice %io %irq   CPU  C.St.
 15505	18:14:21: 1908/1992MHz  2.52  25%  12%   5%   0%   7%   0% 25.9°C  0/11
 15506	18:14:21: 1908/1992MHz  2.52  70%  13%   4%   0%  50%   1% 25.0°C  0/11
 15507	18:14:22: 1908/1992MHz  2.52  42%   2%   2%   0%  35%   1% 23.3°C  0/11
 15508	18:14:22: 1908/1992MHz  2.52  52%   2%   3%   0%  44%   1% 23.5°C  0/11
 15509	18:14:22: 1908/1992MHz  2.52  68%  10%  10%   0%  45%   1% 24.4°C  0/11
 15510
 15511	### Activated 1 lzo-rle zram swap devices with 1816 MB each
 15512
 15513	### Activated Armbian ramlog partition with zstd compression
 15514
 15515	Mon 15 Feb 2021 06:28:43 PM GMT | Odroid N2 | 21.02.1 | arm64 | aarch64 | 5.10.12-meson64
 15516
 15517	### dmesg:
 15518
 15519	[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
 15520	[    0.000000] Linux version 5.10.12-meson64 (root@beast) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #21.02.1 SMP PREEMPT Wed Feb 3 21:06:36 CET 2021
 15521	[    0.000000] Machine model: Hardkernel ODROID-N2
 15522	[    0.000000] efi: UEFI not found.
 15523	[    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
 15524	[    0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB
 15525	[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
 15526	[    0.000000] NUMA: No NUMA configuration found
 15527	[    0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ed7fffff]
 15528	[    0.000000] NUMA: NODE_DATA [mem 0xb502f100-0xb5030fff]
 15529	[    0.000000] Zone ranges:
 15530	[    0.000000]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
 15531	[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000ed7fffff]
 15532	[    0.000000]   Normal   empty
 15533	[    0.000000] Movable zone start for each node
 15534	[    0.000000] Early memory node ranges
 15535	[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000004ffffff]
 15536	[    0.000000]   node   0: [mem 0x0000000005300000-0x00000000ed7fffff]
 15537	[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ed7fffff]
 15538	[    0.000000] On node 0 totalpages: 972032
 15539	[    0.000000]   DMA zone: 4096 pages used for memmap
 15540	[    0.000000]   DMA zone: 0 pages reserved
 15541	[    0.000000]   DMA zone: 261376 pages, LIFO batch:63
 15542	[    0.000000]   DMA32 zone: 11104 pages used for memmap
 15543	[    0.000000]   DMA32 zone: 710656 pages, LIFO batch:63
 15544	[    0.000000] psci: probing for conduit method from DT.
 15545	[    0.000000] psci: PSCIv1.0 detected in firmware.
 15546	[    0.000000] psci: Using standard PSCI v0.2 function IDs
 15547	[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
 15548	[    0.000000] psci: SMC Calling Convention v1.1
 15549	[    0.000000] percpu: Embedded 23 pages/cpu s56728 r8192 d29288 u94208
 15550	[    0.000000] pcpu-alloc: s56728 r8192 d29288 u94208 alloc=23*4096
 15551	[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
 15552	[    0.000000] Detected VIPT I-cache on CPU0
 15553	[    0.000000] CPU features: detected: ARM erratum 845719
 15554	[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 956832
 15555	[    0.000000] Policy zone: DMA32
 15556	[    0.000000] Kernel command line: root=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c rootwait rootfstype=ext4 console=ttyAML0,115200n8 console=tty1 loglevel=1  no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=custombuilt cvbsmode=576cvbs max_freq_a53=1896 max_freq_a73=1800 maxcpus=6 voutmode=hdmi modeline=1920,1080,148500,56250,50,1920,2448,2492,2640,1080,1084,1089,1125,1,1,1 disablehpd=false  cvbscable= overscan=100 consoleblank=0
 15557	[    0.000000] Kernel parameter elevator= does not have any effect anymore.
 15558	               Please use sysfs to set IO scheduler for individual devices.
 15559	[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
 15560	[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
 15561	[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
 15562	[    0.000000] software IO TLB: mapped [mem 0x0000000038ac5000-0x000000003cac5000] (64MB)
 15563	[    0.000000] Memory: 2785352K/3888128K available (14144K kernel code, 1760K rwdata, 5508K rodata, 3328K init, 592K bss, 185272K reserved, 917504K cma-reserved)
 15564	[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
 15565	[    0.000000] rcu: Preemptible hierarchical RCU implementation.
 15566	[    0.000000] rcu: 	RCU event tracing is enabled.
 15567	[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
 15568	[    0.000000] 	Trampoline variant of Tasks RCU enabled.
 15569	[    0.000000] 	Rude variant of Tasks RCU enabled.
 15570	[    0.000000] 	Tracing variant of Tasks RCU enabled.
 15571	[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
 15572	[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
 15573	[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
 15574	[    0.000000] GIC: Using split EOI/Deactivate mode
 15575	[    0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized
 15576	[    0.000000] random: get_random_bytes called from start_kernel+0x378/0x538 with crng_init=0
 15577	[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
 15578	[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
 15579	[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
 15580	[    0.000238] Console: colour dummy device 80x25
 15581	[    0.000272] printk: console [tty1] enabled
 15582	[    0.000357] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
 15583	[    0.000369] pid_max: default: 32768 minimum: 301
 15584	[    0.000453] LSM: Security Framework initializing
 15585	[    0.000479] Yama: becoming mindful.
 15586	[    0.000571] AppArmor: AppArmor initialized
 15587	[    0.000620] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
 15588	[    0.000639] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
 15589	[    0.002629] rcu: Hierarchical SRCU implementation.
 15590	[    0.004995] EFI services will not be available.
 15591	[    0.005416] smp: Bringing up secondary CPUs ...
 15592	[    0.006088] Detected VIPT I-cache on CPU1
 15593	[    0.006149] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
 15594	[    0.007344] CPU features: detected: ARM erratum 858921
 15595	[    0.007352] CPU features: detected: Spectre-v2
 15596	[    0.007356] CPU features: detected: Spectre-v4
 15597	[    0.007363] Detected VIPT I-cache on CPU2
 15598	[    0.007387] arch_timer: Enabling local workaround for ARM erratum 858921
 15599	[    0.007401] arch_timer: CPU2: Trapping CNTVCT access
 15600	[    0.007414] CPU2: Booted secondary processor 0x0000000100 [0x410fd092]
 15601	[    0.008122] Detected VIPT I-cache on CPU3
 15602	[    0.008138] arch_timer: Enabling local workaround for ARM erratum 858921
 15603	[    0.008145] arch_timer: CPU3: Trapping CNTVCT access
 15604	[    0.008153] CPU3: Booted secondary processor 0x0000000101 [0x410fd092]
 15605	[    0.008780] Detected VIPT I-cache on CPU4
 15606	[    0.008796] arch_timer: Enabling local workaround for ARM erratum 858921
 15607	[    0.008803] arch_timer: CPU4: Trapping CNTVCT access
 15608	[    0.008811] CPU4: Booted secondary processor 0x0000000102 [0x410fd092]
 15609	[    0.009427] Detected VIPT I-cache on CPU5
 15610	[    0.009443] arch_timer: Enabling local workaround for ARM erratum 858921
 15611	[    0.009450] arch_timer: CPU5: Trapping CNTVCT access
 15612	[    0.009457] CPU5: Booted secondary processor 0x0000000103 [0x410fd092]
 15613	[    0.009538] smp: Brought up 1 node, 6 CPUs
 15614	[    0.009556] SMP: Total of 6 processors activated.
 15615	[    0.009563] CPU features: detected: 32-bit EL0 Support
 15616	[    0.009569] CPU features: detected: CRC32 instructions
 15617	[    0.009575] CPU features: detected: 32-bit EL1 Support
 15618	[    0.020848] CPU: All CPU(s) started at EL2
 15619	[    0.020899] alternatives: patching kernel code
 15620	[    0.022843] devtmpfs: initialized
 15621	[    0.030521] Registered cp15_barrier emulation handler
 15622	[    0.030535] Registered setend emulation handler
 15623	[    0.030669] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
 15624	[    0.030707] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
 15625	[    0.044621] pinctrl core: initialized pinctrl subsystem
 15626	[    0.045355] DMI not present or invalid.
 15627	[    0.045719] NET: Registered protocol family 16
 15628	[    0.047265] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
 15629	[    0.047555] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
 15630	[    0.047781] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
 15631	[    0.047827] audit: initializing netlink subsys (disabled)
 15632	[    0.047951] audit: type=2000 audit(0.048:1): state=initialized audit_enabled=0 res=1
 15633	[    0.049252] thermal_sys: Registered thermal governor 'fair_share'
 15634	[    0.049260] thermal_sys: Registered thermal governor 'bang_bang'
 15635	[    0.049264] thermal_sys: Registered thermal governor 'step_wise'
 15636	[    0.049268] thermal_sys: Registered thermal governor 'user_space'
 15637	[    0.049702] cpuidle: using governor menu
 15638	[    0.050050] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
 15639	[    0.050168] ASID allocator initialised with 65536 entries
 15640	[    0.051090] Serial: AMBA PL011 UART driver
 15641	[    0.085483] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
 15642	[    0.085492] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
 15643	[    0.085497] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
 15644	[    0.085501] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
 15645	[    0.087257] cryptd: max_cpu_qlen set to 1000
 15646	[    0.156138] raid6: neonx8   gen()  2781 MB/s
 15647	[    0.224208] raid6: neonx8   xor()  2041 MB/s
 15648	[    0.292263] raid6: neonx4   gen()  3153 MB/s
 15649	[    0.360327] raid6: neonx4   xor()  2399 MB/s
 15650	[    0.428396] raid6: neonx2   gen()  2564 MB/s
 15651	[    0.496463] raid6: neonx2   xor()  2194 MB/s
 15652	[    0.564531] raid6: neonx1   gen()  2074 MB/s
 15653	[    0.632601] raid6: neonx1   xor()  1727 MB/s
 15654	[    0.700662] raid6: int64x8  gen()  1374 MB/s
 15655	[    0.768728] raid6: int64x8  xor()   735 MB/s
 15656	[    0.836816] raid6: int64x4  gen()  1463 MB/s
 15657	[    0.904872] raid6: int64x4  xor()   733 MB/s
 15658	[    0.972942] raid6: int64x2  gen()  1363 MB/s
 15659	[    1.041009] raid6: int64x2  xor()   619 MB/s
 15660	[    1.109064] raid6: int64x1  gen()  1120 MB/s
 15661	[    1.177134] raid6: int64x1  xor()   462 MB/s
 15662	[    1.177138] raid6: using algorithm neonx4 gen() 3153 MB/s
 15663	[    1.177141] raid6: .... xor() 2399 MB/s, rmw enabled
 15664	[    1.177144] raid6: using neon recovery algorithm
 15665	[    1.177603] ACPI: Interpreter disabled.
 15666	[    1.178381] 5V: supplied by 12V
 15667	[    1.179279] VDDAO_3V3: supplied by 12V
 15668	[    1.179798] iommu: Default domain type: Translated
 15669	[    1.179911] vgaarb: loaded
 15670	[    1.180624] SCSI subsystem initialized
 15671	[    1.180869] usbcore: registered new interface driver usbfs
 15672	[    1.180913] usbcore: registered new interface driver hub
 15673	[    1.180955] usbcore: registered new device driver usb
 15674	[    1.181222] pps_core: LinuxPPS API ver. 1 registered
 15675	[    1.181226] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
 15676	[    1.181245] PTP clock support registered
 15677	[    1.181444] EDAC MC: Ver: 3.0.0
 15678	[    1.182839] NetLabel: Initializing
 15679	[    1.182846] NetLabel:  domain hash size = 128
 15680	[    1.182848] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
 15681	[    1.182890] NetLabel:  unlabeled traffic allowed by default
 15682	[    1.183354] clocksource: Switched to clocksource arch_sys_counter
 15683	[    1.183562] VFS: Disk quotas dquot_6.6.0
 15684	[    1.183606] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
 15685	[    1.183968] AppArmor: AppArmor Filesystem Enabled
 15686	[    1.184017] pnp: PnP ACPI: disabled
 15687	[    1.189459] NET: Registered protocol family 2
 15688	[    1.189906] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
 15689	[    1.190012] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
 15690	[    1.190269] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
 15691	[    1.190455] TCP: Hash tables configured (established 32768 bind 32768)
 15692	[    1.190605] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
 15693	[    1.190668] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
 15694	[    1.190715] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
 15695	[    1.190864] NET: Registered protocol family 1
 15696	[    1.190884] PCI: CLS 0 bytes, default 64
 15697	[    1.191011] Trying to unpack rootfs image as initramfs...
 15698	[    1.727995] Freeing initrd memory: 13544K
 15699	[    1.728903] kvm [1]: IPA Size Limit: 40 bits
 15700	[    1.729608] kvm [1]: vgic interrupt IRQ9
 15701	[    1.729742] kvm [1]: Hyp mode initialized successfully
 15702	[    1.734671] Initialise system trusted keyrings
 15703	[    1.734703] Key type blacklist registered
 15704	[    1.734814] workingset: timestamp_bits=44 max_order=20 bucket_order=0
 15705	[    1.737995] zbud: loaded
 15706	[    1.738958] squashfs: version 4.0 (2009/01/31) Phillip Lougher
 15707	[    1.739419] fuse: init (API version 7.32)
 15708	[    1.740189] integrity: Platform Keyring initialized
 15709	[    1.768142] xor: measuring software checksum speed
 15710	[    1.770982]    8regs           :  3473 MB/sec
 15711	[    1.773442]    32regs          :  4021 MB/sec
 15712	[    1.776096]    arm64_neon      :  3719 MB/sec
 15713	[    1.776099] xor: using function: 32regs (4021 MB/sec)
 15714	[    1.776107] Key type asymmetric registered
 15715	[    1.776110] Asymmetric key parser 'x509' registered
 15716	[    1.776144] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
 15717	[    1.776232] io scheduler mq-deadline registered
 15718	[    1.776236] io scheduler kyber registered
 15719	[    1.776328] io scheduler bfq registered
 15720	[    1.778803] gpio-447 (usb-hub-reset): hogged as output/high
 15721	[    1.781707] EINJ: ACPI disabled.
 15722	[    1.787875] soc soc0: Amlogic Meson G12B (S922X) Revision 29:a (40:2) Detected
 15723	[    1.789315] VCC_3V3: supplied by VDDAO_3V3
 15724	[    1.789362] FLASH_1V8: supplied by VCC_3V3
 15725	[    1.789395] VCC_1V8: supplied by VCC_3V3
 15726	[    1.789422] VDDAO_1V8: supplied by VDDAO_3V3
 15727	[    1.789449] VDDCPU_A: supplied by regulator-dummy
 15728	[    1.789808] VDDCPU_B: supplied by regulator-dummy
 15729	[    1.790473] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
 15730	[    1.792729] Serial: AMBA driver
 15731	[    1.793014] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart
 15732	[    1.793109] printk: console [ttyAML0] enabled
 15733	[    1.793632] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 33, base_baud = 1500000) is a meson_uart
 15734	[    1.799028] loop: module loaded
 15735	[    1.801107] libphy: Fixed MDIO Bus: probed
 15736	[    1.802095] tun: Universal TUN/TAP device driver, 1.6
 15737	[    1.802733] thunder_xcv, ver 1.0
 15738	[    1.802768] thunder_bgx, ver 1.0
 15739	[    1.802796] nicpf, ver 1.0
 15740	[    1.803235] e1000e: Intel(R) PRO/1000 Network Driver
 15741	[    1.803239] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
 15742	[    1.803278] igb: Intel(R) Gigabit Ethernet Network Driver
 15743	[    1.803281] igb: Copyright (c) 2007-2014 Intel Corporation.
 15744	[    1.803312] igbvf: Intel(R) Gigabit Virtual Function Network Driver
 15745	[    1.803315] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
 15746	[    1.803531] sky2: driver version 1.30
 15747	[    1.803898] VFIO - User Level meta-driver version: 0.3
 15748	[    1.805206] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
 15749	[    1.805224] ehci-pci: EHCI PCI platform driver
 15750	[    1.805253] ehci-platform: EHCI generic platform driver
 15751	[    1.805372] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
 15752	[    1.805382] ohci-pci: OHCI PCI platform driver
 15753	[    1.805415] ohci-platform: OHCI generic platform driver
 15754	[    1.805785] usbcore: registered new interface driver usb-storage
 15755	[    1.806964] mousedev: PS/2 mouse device common for all mice
 15756	[    1.807287] i2c /dev entries driver
 15757	[    1.812336] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17
 15758	[    1.813009] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz
 15759	[    1.813688] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-1 failed:-17
 15760	[    1.814271] sdhci: Secure Digital Host Controller Interface driver
 15761	[    1.814277] sdhci: Copyright(c) Pierre Ossman
 15762	[    1.814376] Synopsys Designware Multimedia Card Interface Driver
 15763	[    1.814789] sdhci-pltfm: SDHCI platform and OF driver helper
 15764	[    1.815227] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq
 15765	[    1.815748] ledtrig-cpu: registered to indicate activity on CPUs
 15766	[    1.816312] meson-sm: secure-monitor enabled
 15767	[    1.816508] hid: raw HID events driver (C) Jiri Kosina
 15768	[    1.816584] usbcore: registered new interface driver usbhid
 15769	[    1.816587] usbhid: USB HID core driver
 15770	[    1.817569] NET: Registered protocol family 10
 15771	[    1.818027] Segment Routing with IPv6
 15772	[    1.818057] NET: Registered protocol family 17
 15773	[    1.818096] 8021q: 802.1Q VLAN Support v1.8
 15774	[    1.818118] Key type dns_resolver registered
 15775	[    1.818415] registered taskstats version 1
 15776	[    1.818422] Loading compiled-in X.509 certificates
 15777	[    1.820113] Loaded X.509 cert 'Build time autogenerated kernel key: f47c178852ca39740c3546b008122b65f5ed9bce'
 15778	[    1.821675] zswap: loaded using pool zstd/z3fold
 15779	[    1.821835] Key type ._fscrypt registered
 15780	[    1.821838] Key type .fscrypt registered
 15781	[    1.821840] Key type fscrypt-provisioning registered
 15782	[    1.822928] Btrfs loaded, crc32c=crc32c-generic
 15783	[    1.829154] Key type encrypted registered
 15784	[    1.829164] AppArmor: AppArmor sha1 policy hashing enabled
 15785	[    1.835486] HUB_5V: supplied by 5V
 15786	[    1.835693] USB_PWR_EN: supplied by 5V
 15787	[    1.837313] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2
 15788	[    1.837320] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1
 15789	[    1.840014] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator
 15790	[    1.840067] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator
 15791	[    1.840450] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM
 15792	[    1.841022] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
 15793	[    1.841033] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
 15794	[    1.841121] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010
 15795	[    1.841143] xhci-hcd xhci-hcd.0.auto: irq 41, io mem 0xff500000
 15796	[    1.841270] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
 15797	[    1.841273] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 15798	[    1.841276] usb usb1: Product: xHCI Host Controller
 15799	[    1.841278] usb usb1: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
 15800	[    1.841281] usb usb1: SerialNumber: xhci-hcd.0.auto
 15801	[    1.841550] hub 1-0:1.0: USB hub found
 15802	[    1.841564] hub 1-0:1.0: 2 ports detected
 15803	[    1.841696] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
 15804	[    1.841703] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
 15805	[    1.841708] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
 15806	[    1.841728] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
 15807	[    1.841761] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
 15808	[    1.841764] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 15809	[    1.841767] usb usb2: Product: xHCI Host Controller
 15810	[    1.841769] usb usb2: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
 15811	[    1.841771] usb usb2: SerialNumber: xhci-hcd.0.auto
 15812	[    1.841918] hub 2-0:1.0: USB hub found
 15813	[    1.841930] hub 2-0:1.0: 1 port detected
 15814	[    1.842180] dwc3-meson-g12a ffe09000.usb: switching to Device Mode
 15815	[    1.843042] meson-gx-mmc ffe05000.sd: Got CD GPIO
 15816	[    1.868403] Freeing unused kernel memory: 3328K
 15817	[    1.907466] Run /init as init process
 15818	[    1.907471]   with arguments:
 15819	[    1.907473]     /init
 15820	[    1.907475]   with environment:
 15821	[    1.907477]     HOME=/
 15822	[    1.907479]     TERM=linux
 15823	[    1.907481]     hdmimode=custombuilt
 15824	[    1.907482]     cvbsmode=576cvbs
 15825	[    1.907484]     max_freq_a53=1896
 15826	[    1.907485]     max_freq_a73=1800
 15827	[    1.907487]     voutmode=hdmi
 15828	[    1.907488]     modeline=1920,1080,148500,56250,50,1920,2448,2492,2640,1080,1084,1089,1125,1,1,1
 15829	[    1.907490]     disablehpd=false
 15830	[    1.907492]     cvbscable=
 15831	[    1.907493]     overscan=100
 15832	[    1.933495] mmc0: new ultra high speed SDR25 SDHC card at address b368
 15833	[    1.934370] mmcblk0: mmc0:b368 CBADS 30.0 GiB
 15834	[    1.936322]  mmcblk0: p1
 15835	[    2.060909] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found
 15836	[    2.060916] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found
 15837	[    2.061004] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock
 15838	[    2.061407] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37
 15839	[    2.061415] meson8b-dwmac ff3f0000.ethernet: 	DWMAC1000
 15840	[    2.061418] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported
 15841	[    2.061420] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported
 15842	[    2.061422] meson8b-dwmac ff3f0000.ethernet: COE Type 2
 15843	[    2.061424] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported
 15844	[    2.061426] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported
 15845	[    2.061466] meson8b-dwmac ff3f0000.ethernet: Normal descriptors
 15846	[    2.061469] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled
 15847	[    2.061471] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
 15848	[    2.061649] libphy: stmmac: probed
 15849	[    2.065961] libphy: mdio_mux: probed
 15850	[    2.080648] meson-vrtc ff8000a8.rtc: registered as rtc1
 15851	[    2.098210] random: fast init done
 15852	[    2.098626] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
 15853	[    2.098755] rtc-pcf8563 1-0051: registered as rtc0
 15854	[    2.099965] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
 15855	[    2.099972] rtc-pcf8563 1-0051: hctosys: unable to read the hardware clock
 15856	[    2.175494] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
 15857	[    2.200099] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.04
 15858	[    2.200106] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
 15859	[    2.200110] usb 2-1: Product: USB3.1 Hub
 15860	[    2.200113] usb 2-1: Manufacturer: GenesysLogic
 15861	[    2.226026] hub 2-1:1.0: USB hub found
 15862	[    2.226324] hub 2-1:1.0: 4 ports detected
 15863	[    2.271815] libphy: mdio_mux: probed
 15864	[    2.323360] usb 1-1: new high-speed USB device number 2 using xhci-hcd
 15865	[    2.473652] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.04
 15866	[    2.473656] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
 15867	[    2.473659] usb 1-1: Product: USB2.1 Hub
 15868	[    2.473661] usb 1-1: Manufacturer: GenesysLogic
 15869	[    2.513933] hub 1-1:1.0: USB hub found
 15870	[    2.514176] hub 1-1:1.0: 4 ports detected
 15871	[    2.987877] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
 15872	[    3.796408] systemd[1]: System time before build time, advancing clock.
 15873	[    3.811226] systemd[1]: Inserted module 'autofs4'
 15874	[    3.857755] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
 15875	[    3.857970] systemd[1]: Detected architecture arm64.
 15876	[    3.885724] systemd[1]: Set hostname to <odroidn2>.
 15877	[    4.213145] random: systemd: uninitialized urandom read (16 bytes read)
 15878	[    4.216463] random: systemd: uninitialized urandom read (16 bytes read)
 15879	[    4.216694] systemd[1]: Listening on Syslog Socket.
 15880	[    4.217040] random: systemd: uninitialized urandom read (16 bytes read)
 15881	[    4.217225] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
 15882	[    4.217424] systemd[1]: Listening on initctl Compatibility Named Pipe.
 15883	[    4.217567] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
 15884	[    4.218458] systemd[1]: Created slice User and Session Slice.
 15885	[    4.218565] systemd[1]: Reached target Remote File Systems.
 15886	[    4.218863] systemd[1]: Listening on udev Control Socket.
 15887	[    4.312924] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
 15888	[    4.848369] pwm-gpio pwmgpio: 1 gpio pwms loaded
 15889	[    4.853178] zram: Added device: zram0
 15890	[    4.853487] zram: Added device: zram1
 15891	[    4.853717] zram: Added device: zram2
 15892	[    4.988860] meson-saradc ff809000.adc: supply vref not found, using dummy regulator
 15893	[    5.007185] mc: Linux media interface: v0.10
 15894	[    5.032661] panfrost ffe40000.gpu: clock rate = 24000000
 15895	[    5.032718] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19
 15896	[    5.033280] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0
 15897	[    5.033285] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400
 15898	[    5.033289] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
 15899	[    5.033292] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1
 15900	[    5.058400] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 0
 15901	[    5.063408] Registered IR keymap rc-odroid
 15902	[    5.084643] videodev: Linux video capture interface: v2.00
 15903	[    5.098240] IR NEC protocol handler initialized
 15904	[    5.123429] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0
 15905	[    5.123552] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
 15906	[    5.123609] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input0
 15907	[    5.124681] meson-ir ff808000.ir: receiver initialized
 15908	[    5.142709] meson-drm ff900000.vpu: Queued 2 outputs on vpu
 15909	[    5.205599] meson-drm ff900000.vpu: CVBS Output connector not available
 15910	[    5.231683] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
 15911	[    5.235577] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
 15912	[    5.236150] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
 15913	[    5.237224] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 1
 15914	[    5.254280] zram0: detected capacity change from 0 to 1904500736
 15915	[    5.280006] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
 15916	[    5.519513] Console: switching to colour frame buffer device 240x67
 15917	[    5.546051] meson-drm ff900000.vpu: [drm] fb0: mesondrmfb frame buffer device
 15918	[    5.596715] axg-sound-card sound: ASoC: no DMI vendor name!
 15919	[    6.303376] Adding 1859860k swap on /dev/zram0.  Priority:5 extents:1 across:1859860k SSFS
 15920	[    6.368364] zram1: detected capacity change from 0 to 52428800
 15921	[    8.453358] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
 15922	[    8.453378] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
 15923	[    9.613763] systemd[1]: Started Armbian memory supported logging.
 15924	[    9.616134] systemd[1]: Starting Journal Service...
 15925	[    9.677638] systemd[1]: Started Journal Service.
 15926	[    9.702801] systemd-journald[1837]: Received request to flush runtime journal from PID 1
 15927
 15928	### armbian-release:
 15929
 15930	# PLEASE DO NOT EDIT THIS FILE
 15931	BOARD=odroidn2
 15932	BOARD_NAME="Odroid N2"
 15933	BOARDFAMILY=meson-g12b
 15934	BUILD_REPOSITORY_URL=https://github.com/armbian/build
 15935	BUILD_REPOSITORY_COMMIT=5f03d652
 15936	DISTRIBUTION_CODENAME=buster
 15937	DISTRIBUTION_STATUS=supported
 15938	VERSION=21.02.1
 15939	LINUXFAMILY=meson64
 15940	BRANCH=current
 15941	ARCH=arm64
 15942	IMAGE_TYPE=stable
 15943	BOARD_TYPE=conf
 15944	INITRD_ARCH=arm64
 15945	KERNEL_IMAGE_TYPE=Image
 15946
 15947	### boot environment:
 15948
 15949	verbosity=1
 15950	console=both
 15951	overlay_prefix=meson
 15952	rootdev=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c
 15953	rootfstype=ext4
 15954	usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
 15955
 15956	### lsusb:
 15957
 15958	Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc.
 15959	Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
 15960	Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
 15961	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
 15962
 15963	### lscpu:
 15964
 15965	Architecture:        aarch64
 15966	Byte Order:          Little Endian
 15967	CPU(s):              6
 15968	On-line CPU(s) list: 0-5
 15969	Thread(s) per core:  1
 15970	Core(s) per socket:  3
 15971	Socket(s):           2
 15972	NUMA node(s):        1
 15973	Vendor ID:           ARM
 15974	Model:               4
 15975	Model name:          Cortex-A53
 15976	Stepping:            r0p4
 15977	CPU max MHz:         1992.0000
 15978	CPU min MHz:         100.0000
 15979	BogoMIPS:            48.00
 15980	L1d cache:           unknown size
 15981	L1i cache:           unknown size
 15982	L2 cache:            unknown size
 15983	NUMA node0 CPU(s):   0-5
 15984	Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 15985
 15986	### cpuinfo:
 15987
 15988	processor	: 0
 15989	BogoMIPS	: 48.00
 15990	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 15991	CPU implementer	: 0x41
 15992	CPU architecture: 8
 15993	CPU variant	: 0x0
 15994	CPU part	: 0xd03
 15995	CPU revision	: 4
 15996
 15997	processor	: 1
 15998	BogoMIPS	: 48.00
 15999	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 16000	CPU implementer	: 0x41
 16001	CPU architecture: 8
 16002	CPU variant	: 0x0
 16003	CPU part	: 0xd03
 16004	CPU revision	: 4
 16005
 16006	processor	: 2
 16007	BogoMIPS	: 48.00
 16008	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 16009	CPU implementer	: 0x41
 16010	CPU architecture: 8
 16011	CPU variant	: 0x0
 16012	CPU part	: 0xd09
 16013	CPU revision	: 2
 16014
 16015	processor	: 3
 16016	BogoMIPS	: 48.00
 16017	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 16018	CPU implementer	: 0x41
 16019	CPU architecture: 8
 16020	CPU variant	: 0x0
 16021	CPU part	: 0xd09
 16022	CPU revision	: 2
 16023
 16024	processor	: 4
 16025	BogoMIPS	: 48.00
 16026	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 16027	CPU implementer	: 0x41
 16028	CPU architecture: 8
 16029	CPU variant	: 0x0
 16030	CPU part	: 0xd09
 16031	CPU revision	: 2
 16032
 16033	processor	: 5
 16034	BogoMIPS	: 48.00
 16035	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 16036	CPU implementer	: 0x41
 16037	CPU architecture: 8
 16038	CPU variant	: 0x0
 16039	CPU part	: 0xd09
 16040	CPU revision	: 2
 16041
 16042
 16043	### meminfo:
 16044
 16045	MemTotal:        3719728 kB
 16046	MemFree:         3427184 kB
 16047	MemAvailable:    3381812 kB
 16048	Buffers:           11548 kB
 16049	Cached:            45852 kB
 16050	SwapCached:            0 kB
 16051	Active:            30948 kB
 16052	Inactive:         154300 kB
 16053	Active(anon):        136 kB
 16054	Inactive(anon):   132528 kB
 16055	Active(file):      30812 kB
 16056	Inactive(file):    21772 kB
 16057	Unevictable:           0 kB
 16058	Mlocked:               0 kB
 16059	SwapTotal:       1859860 kB
 16060	SwapFree:        1859860 kB
 16061	Dirty:              6652 kB
 16062	Writeback:             0 kB
 16063	AnonPages:        128000 kB
 16064	Mapped:            10932 kB
 16065	Shmem:              4964 kB
 16066	KReclaimable:      13388 kB
 16067	Slab:              39348 kB
 16068	SReclaimable:      13388 kB
 16069	SUnreclaim:        25960 kB
 16070	KernelStack:        2016 kB
 16071	PageTables:         4032 kB
 16072	NFS_Unstable:          0 kB
 16073	Bounce:                0 kB
 16074	WritebackTmp:          0 kB
 16075	CommitLimit:     3719724 kB
 16076	Committed_AS:    4210540 kB
 16077	VmallocTotal:   135290159040 kB
 16078	VmallocUsed:       30864 kB
 16079	VmallocChunk:          0 kB
 16080	Percpu:             1368 kB
 16081	HardwareCorrupted:     0 kB
 16082	AnonHugePages:         0 kB
 16083	ShmemHugePages:        0 kB
 16084	ShmemPmdMapped:        0 kB
 16085	FileHugePages:         0 kB
 16086	FilePmdMapped:         0 kB
 16087	CmaTotal:         917504 kB
 16088	CmaFree:          901724 kB
 16089	HugePages_Total:       0
 16090	HugePages_Free:        0
 16091	HugePages_Rsvd:        0
 16092	HugePages_Surp:        0
 16093	Hugepagesize:       2048 kB
 16094	Hugetlb:               0 kB
 16095
 16096	### virtual memory:
 16097
 16098	vm.admin_reserve_kbytes = 8192
 16099	vm.block_dump = 0
 16100	vm.compaction_proactiveness = 20
 16101	vm.compact_unevictable_allowed = 1
 16102	vm.dirty_background_bytes = 0
 16103	vm.dirty_background_ratio = 10
 16104	vm.dirty_bytes = 0
 16105	vm.dirty_expire_centisecs = 3000
 16106	vm.dirty_ratio = 20
 16107	vm.dirtytime_expire_seconds = 43200
 16108	vm.dirty_writeback_centisecs = 500
 16109	vm.extfrag_threshold = 500
 16110	vm.hugetlb_shm_group = 0
 16111	vm.laptop_mode = 0
 16112	vm.legacy_va_layout = 0
 16113	vm.lowmem_reserve_ratio = 256	256	32	0
 16114	vm.max_map_count = 65530
 16115	vm.memory_failure_early_kill = 0
 16116	vm.memory_failure_recovery = 1
 16117	vm.min_free_kbytes = 45056
 16118	vm.min_slab_ratio = 5
 16119	vm.min_unmapped_ratio = 1
 16120	vm.mmap_min_addr = 4096
 16121	vm.mmap_rnd_bits = 18
 16122	vm.mmap_rnd_compat_bits = 11
 16123	vm.nr_hugepages = 0
 16124	vm.nr_hugepages_mempolicy = 0
 16125	vm.nr_overcommit_hugepages = 0
 16126	vm.numa_stat = 1
 16127	vm.numa_zonelist_order = Node
 16128	vm.oom_dump_tasks = 1
 16129	vm.oom_kill_allocating_task = 0
 16130	vm.overcommit_kbytes = 0
 16131	vm.overcommit_memory = 0
 16132	vm.overcommit_ratio = 50
 16133	vm.page-cluster = 0
 16134	vm.page_lock_unfairness = 5
 16135	vm.panic_on_oom = 0
 16136	vm.percpu_pagelist_fraction = 0
 16137	vm.stat_interval = 1
 16138	vm.swappiness = 100
 16139	vm.user_reserve_kbytes = 115005
 16140	vm.vfs_cache_pressure = 100
 16141	vm.watermark_boost_factor = 15000
 16142	vm.watermark_scale_factor = 10
 16143	vm.zone_reclaim_mode = 0
 16144
 16145	### ip addr:
 16146
 16147	1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
 16148	    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
 16149	    inet XXX.XXX.0.1/8 scope host lo
 16150	       valid_lft forever preferred_lft forever
 16151	    inet6 ::1/128 scope host
 16152	       valid_lft forever preferred_lft forever
 16153	2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
 16154	    link/ether 00:1e:06:42:03:f8 brd ff:ff:ff:ff:ff:ff
 16155
 16156	### partitions:
 16157
 16158	major minor  #blocks  name
 16159
 16160	 179        0   31464960 mmcblk0
 16161	 179        1   31146208 mmcblk0p1
 16162	 252        0    1859864 zram0
 16163	 252        1      51200 zram1
 16164
 16165	### df:
 16166
 16167	udev            1.4G     0  1.4G   0% /dev
 16168	tmpfs           364M  4.9M  359M   2% /run
 16169	/dev/mmcblk0p1   30G  1.7G   28G   6% /
 16170	tmpfs           1.8G     0  1.8G   0% /dev/shm
 16171	tmpfs           5.0M  4.0K  5.0M   1% /run/lock
 16172	tmpfs           1.8G     0  1.8G   0% /sys/fs/cgroup
 16173	tmpfs           1.8G     0  1.8G   0% /tmp
 16174	/dev/zram1       49M  6.5M   39M  15% /var/log
 16175
 16176	### lsblk:
 16177
 16178	NAME        FSTYPE  SIZE MOUNTPOINT UUID
 16179	mmcblk0              30G
 16180	└─mmcblk0p1 ext4   29.7G /          bd34953d-41be-49d6-b1c0-c0c28a5e239c
 16181	zram1                50M /var/log
 16182
 16183	### zramctl:
 16184
 16185	NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
 16186	/dev/zram1 zstd           50M  132K  698B   36K       6 /var/log
 16187	/dev/zram0 lzo-rle       1.8G    4K   74B   12K       6 [SWAP]
 16188
 16189	### mtab:
 16190
 16191	/dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
 16192	/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
 16193	/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
 16194
 16195	### mmc0:b368 info:
 16196
 16197	               fwrev: 0x0
 16198	              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=CBADS MODALIAS=mmc:block
 16199	                 cid: 6f0303434241445310aa002b4d013b00
 16200	                 rca: 0xb368
 16201	                 csd: 400e005a5b590000f00e7f800a404000
 16202	              manfid: 0x00006f
 16203	                 ocr: 0x00200000
 16204	preferred_erase_size: 2097152
 16205	                type: SD
 16206	               hwrev: 0x1
 16207	                date: 11/2019
 16208	                 dsr: 0x404
 16209	          erase_size: 512
 16210	               oemid: 0x0303
 16211	              serial: 0xaa002b4d
 16212	                 ssr: 00000000000000280402800100fd180a001e00000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
 16213	                 scr: 02b5800300000000
 16214	                name: CBADS
 16215
 16216	### Boot system health:
 16217
 16218	Time       big.LITTLE   load %cpu %sys %usr %nice %io %irq   CPU  C.St.
 16219	18:28:44: 1908/1992MHz  2.75  23%  10%   5%   0%   6%   0% 25.7°C  0/11
 16220	18:28:44: 1908/1992MHz  2.75  61%  36%   8%   0%  14%   0% 25.6°C  0/11
 16221	18:28:44: 1908/1992MHz  2.75  84%  31%   2%   0%  47%   1% 23.4°C  0/11
 16222	18:28:45: 1908/1992MHz  2.75  38%   5%   4%   0%  25%   1% 23.2°C  0/11
 16223	18:28:45: 1908/1992MHz  2.75  57%   7%   5%   0%  41%   1% 22.1°C  0/11
 16224
 16225	### Activated 1 lzo-rle zram swap devices with 1816 MB each
 16226
 16227	### Activated Armbian ramlog partition with zstd compression
 16228
 16229	Sun 21 Feb 2021 02:44:20 PM GMT | Odroid N2 | 21.02.1 | arm64 | aarch64 | 5.10.12-meson64
 16230
 16231	### dmesg:
 16232
 16233	[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
 16234	[    0.000000] Linux version 5.10.12-meson64 (root@beast) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #21.02.1 SMP PREEMPT Wed Feb 3 21:06:36 CET 2021
 16235	[    0.000000] Machine model: Hardkernel ODROID-N2
 16236	[    0.000000] efi: UEFI not found.
 16237	[    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
 16238	[    0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB
 16239	[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
 16240	[    0.000000] NUMA: No NUMA configuration found
 16241	[    0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ed7fffff]
 16242	[    0.000000] NUMA: NODE_DATA [mem 0xb502f100-0xb5030fff]
 16243	[    0.000000] Zone ranges:
 16244	[    0.000000]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
 16245	[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000ed7fffff]
 16246	[    0.000000]   Normal   empty
 16247	[    0.000000] Movable zone start for each node
 16248	[    0.000000] Early memory node ranges
 16249	[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000004ffffff]
 16250	[    0.000000]   node   0: [mem 0x0000000005300000-0x00000000ed7fffff]
 16251	[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ed7fffff]
 16252	[    0.000000] On node 0 totalpages: 972032
 16253	[    0.000000]   DMA zone: 4096 pages used for memmap
 16254	[    0.000000]   DMA zone: 0 pages reserved
 16255	[    0.000000]   DMA zone: 261376 pages, LIFO batch:63
 16256	[    0.000000]   DMA32 zone: 11104 pages used for memmap
 16257	[    0.000000]   DMA32 zone: 710656 pages, LIFO batch:63
 16258	[    0.000000] psci: probing for conduit method from DT.
 16259	[    0.000000] psci: PSCIv1.0 detected in firmware.
 16260	[    0.000000] psci: Using standard PSCI v0.2 function IDs
 16261	[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
 16262	[    0.000000] psci: SMC Calling Convention v1.1
 16263	[    0.000000] percpu: Embedded 23 pages/cpu s56728 r8192 d29288 u94208
 16264	[    0.000000] pcpu-alloc: s56728 r8192 d29288 u94208 alloc=23*4096
 16265	[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
 16266	[    0.000000] Detected VIPT I-cache on CPU0
 16267	[    0.000000] CPU features: detected: ARM erratum 845719
 16268	[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 956832
 16269	[    0.000000] Policy zone: DMA32
 16270	[    0.000000] Kernel command line: root=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c rootwait rootfstype=ext4 console=ttyAML0,115200n8 console=tty1 loglevel=1  no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=custombuilt cvbsmode=576cvbs max_freq_a53=1896 max_freq_a73=1800 maxcpus=6 voutmode=hdmi modeline=1920,1080,148500,56250,50,1920,2448,2492,2640,1080,1084,1089,1125,1,1,1 disablehpd=false  cvbscable= overscan=100 consoleblank=0
 16271	[    0.000000] Kernel parameter elevator= does not have any effect anymore.
 16272	               Please use sysfs to set IO scheduler for individual devices.
 16273	[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
 16274	[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
 16275	[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
 16276	[    0.000000] software IO TLB: mapped [mem 0x0000000038ac5000-0x000000003cac5000] (64MB)
 16277	[    0.000000] Memory: 2785352K/3888128K available (14144K kernel code, 1760K rwdata, 5508K rodata, 3328K init, 592K bss, 185272K reserved, 917504K cma-reserved)
 16278	[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
 16279	[    0.000000] rcu: Preemptible hierarchical RCU implementation.
 16280	[    0.000000] rcu: 	RCU event tracing is enabled.
 16281	[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
 16282	[    0.000000] 	Trampoline variant of Tasks RCU enabled.
 16283	[    0.000000] 	Rude variant of Tasks RCU enabled.
 16284	[    0.000000] 	Tracing variant of Tasks RCU enabled.
 16285	[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
 16286	[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
 16287	[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
 16288	[    0.000000] GIC: Using split EOI/Deactivate mode
 16289	[    0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized
 16290	[    0.000000] random: get_random_bytes called from start_kernel+0x378/0x538 with crng_init=0
 16291	[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
 16292	[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
 16293	[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
 16294	[    0.000241] Console: colour dummy device 80x25
 16295	[    0.000275] printk: console [tty1] enabled
 16296	[    0.000363] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
 16297	[    0.000374] pid_max: default: 32768 minimum: 301
 16298	[    0.000457] LSM: Security Framework initializing
 16299	[    0.000484] Yama: becoming mindful.
 16300	[    0.000575] AppArmor: AppArmor initialized
 16301	[    0.000625] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
 16302	[    0.000644] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
 16303	[    0.002641] rcu: Hierarchical SRCU implementation.
 16304	[    0.005014] EFI services will not be available.
 16305	[    0.005436] smp: Bringing up secondary CPUs ...
 16306	[    0.006103] Detected VIPT I-cache on CPU1
 16307	[    0.006164] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
 16308	[    0.007356] CPU features: detected: ARM erratum 858921
 16309	[    0.007364] CPU features: detected: Spectre-v2
 16310	[    0.007368] CPU features: detected: Spectre-v4
 16311	[    0.007375] Detected VIPT I-cache on CPU2
 16312	[    0.007401] arch_timer: Enabling local workaround for ARM erratum 858921
 16313	[    0.007414] arch_timer: CPU2: Trapping CNTVCT access
 16314	[    0.007427] CPU2: Booted secondary processor 0x0000000100 [0x410fd092]
 16315	[    0.008136] Detected VIPT I-cache on CPU3
 16316	[    0.008152] arch_timer: Enabling local workaround for ARM erratum 858921
 16317	[    0.008160] arch_timer: CPU3: Trapping CNTVCT access
 16318	[    0.008168] CPU3: Booted secondary processor 0x0000000101 [0x410fd092]
 16319	[    0.008794] Detected VIPT I-cache on CPU4
 16320	[    0.008811] arch_timer: Enabling local workaround for ARM erratum 858921
 16321	[    0.008817] arch_timer: CPU4: Trapping CNTVCT access
 16322	[    0.008825] CPU4: Booted secondary processor 0x0000000102 [0x410fd092]
 16323	[    0.009441] Detected VIPT I-cache on CPU5
 16324	[    0.009458] arch_timer: Enabling local workaround for ARM erratum 858921
 16325	[    0.009464] arch_timer: CPU5: Trapping CNTVCT access
 16326	[    0.009472] CPU5: Booted secondary processor 0x0000000103 [0x410fd092]
 16327	[    0.009553] smp: Brought up 1 node, 6 CPUs
 16328	[    0.009570] SMP: Total of 6 processors activated.
 16329	[    0.009578] CPU features: detected: 32-bit EL0 Support
 16330	[    0.009583] CPU features: detected: CRC32 instructions
 16331	[    0.009589] CPU features: detected: 32-bit EL1 Support
 16332	[    0.020876] CPU: All CPU(s) started at EL2
 16333	[    0.020925] alternatives: patching kernel code
 16334	[    0.022870] devtmpfs: initialized
 16335	[    0.030536] Registered cp15_barrier emulation handler
 16336	[    0.030550] Registered setend emulation handler
 16337	[    0.030687] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
 16338	[    0.030727] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
 16339	[    0.044673] pinctrl core: initialized pinctrl subsystem
 16340	[    0.045225] DMI not present or invalid.
 16341	[    0.045624] NET: Registered protocol family 16
 16342	[    0.047221] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
 16343	[    0.047495] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
 16344	[    0.047723] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
 16345	[    0.047768] audit: initializing netlink subsys (disabled)
 16346	[    0.047871] audit: type=2000 audit(0.044:1): state=initialized audit_enabled=0 res=1
 16347	[    0.049157] thermal_sys: Registered thermal governor 'fair_share'
 16348	[    0.049164] thermal_sys: Registered thermal governor 'bang_bang'
 16349	[    0.049168] thermal_sys: Registered thermal governor 'step_wise'
 16350	[    0.049171] thermal_sys: Registered thermal governor 'user_space'
 16351	[    0.049583] cpuidle: using governor menu
 16352	[    0.049932] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
 16353	[    0.050055] ASID allocator initialised with 65536 entries
 16354	[    0.050979] Serial: AMBA PL011 UART driver
 16355	[    0.085445] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
 16356	[    0.085456] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
 16357	[    0.085460] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
 16358	[    0.085464] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
 16359	[    0.087000] cryptd: max_cpu_qlen set to 1000
 16360	[    0.156188] raid6: neonx8   gen()  2780 MB/s
 16361	[    0.224240] raid6: neonx8   xor()  2041 MB/s
 16362	[    0.292289] raid6: neonx4   gen()  3153 MB/s
 16363	[    0.360356] raid6: neonx4   xor()  2399 MB/s
 16364	[    0.428433] raid6: neonx2   gen()  2530 MB/s
 16365	[    0.496488] raid6: neonx2   xor()  2205 MB/s
 16366	[    0.564561] raid6: neonx1   gen()  2015 MB/s
 16367	[    0.632622] raid6: neonx1   xor()  1721 MB/s
 16368	[    0.700691] raid6: int64x8  gen()  1376 MB/s
 16369	[    0.768759] raid6: int64x8  xor()   735 MB/s
 16370	[    0.836837] raid6: int64x4  gen()  1463 MB/s
 16371	[    0.904897] raid6: int64x4  xor()   733 MB/s
 16372	[    0.972956] raid6: int64x2  gen()  1362 MB/s
 16373	[    1.041014] raid6: int64x2  xor()   619 MB/s
 16374	[    1.109096] raid6: int64x1  gen()  1120 MB/s
 16375	[    1.177156] raid6: int64x1  xor()   462 MB/s
 16376	[    1.177160] raid6: using algorithm neonx4 gen() 3153 MB/s
 16377	[    1.177163] raid6: .... xor() 2399 MB/s, rmw enabled
 16378	[    1.177167] raid6: using neon recovery algorithm
 16379	[    1.177614] ACPI: Interpreter disabled.
 16380	[    1.178405] 5V: supplied by 12V
 16381	[    1.179303] VDDAO_3V3: supplied by 12V
 16382	[    1.179751] iommu: Default domain type: Translated
 16383	[    1.179872] vgaarb: loaded
 16384	[    1.180565] SCSI subsystem initialized
 16385	[    1.180971] usbcore: registered new interface driver usbfs
 16386	[    1.181012] usbcore: registered new interface driver hub
 16387	[    1.181050] usbcore: registered new device driver usb
 16388	[    1.181370] pps_core: LinuxPPS API ver. 1 registered
 16389	[    1.181376] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
 16390	[    1.181402] PTP clock support registered
 16391	[    1.181590] EDAC MC: Ver: 3.0.0
 16392	[    1.182954] NetLabel: Initializing
 16393	[    1.182961] NetLabel:  domain hash size = 128
 16394	[    1.182964] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
 16395	[    1.183004] NetLabel:  unlabeled traffic allowed by default
 16396	[    1.183496] clocksource: Switched to clocksource arch_sys_counter
 16397	[    1.183712] VFS: Disk quotas dquot_6.6.0
 16398	[    1.183755] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
 16399	[    1.184162] AppArmor: AppArmor Filesystem Enabled
 16400	[    1.184208] pnp: PnP ACPI: disabled
 16401	[    1.189842] NET: Registered protocol family 2
 16402	[    1.190307] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
 16403	[    1.190412] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
 16404	[    1.190669] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
 16405	[    1.190857] TCP: Hash tables configured (established 32768 bind 32768)
 16406	[    1.191010] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
 16407	[    1.191074] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
 16408	[    1.191120] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
 16409	[    1.191258] NET: Registered protocol family 1
 16410	[    1.191277] PCI: CLS 0 bytes, default 64
 16411	[    1.191404] Trying to unpack rootfs image as initramfs...
 16412	[    1.727843] Freeing initrd memory: 13544K
 16413	[    1.728748] kvm [1]: IPA Size Limit: 40 bits
 16414	[    1.729456] kvm [1]: vgic interrupt IRQ9
 16415	[    1.729592] kvm [1]: Hyp mode initialized successfully
 16416	[    1.734582] Initialise system trusted keyrings
 16417	[    1.734615] Key type blacklist registered
 16418	[    1.734720] workingset: timestamp_bits=44 max_order=20 bucket_order=0
 16419	[    1.737911] zbud: loaded
 16420	[    1.738879] squashfs: version 4.0 (2009/01/31) Phillip Lougher
 16421	[    1.739344] fuse: init (API version 7.32)
 16422	[    1.740140] integrity: Platform Keyring initialized
 16423	[    1.768179] xor: measuring software checksum speed
 16424	[    1.771018]    8regs           :  3473 MB/sec
 16425	[    1.773475]    32regs          :  4020 MB/sec
 16426	[    1.776130]    arm64_neon      :  3719 MB/sec
 16427	[    1.776133] xor: using function: 32regs (4020 MB/sec)
 16428	[    1.776140] Key type asymmetric registered
 16429	[    1.776145] Asymmetric key parser 'x509' registered
 16430	[    1.776178] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
 16431	[    1.776272] io scheduler mq-deadline registered
 16432	[    1.776276] io scheduler kyber registered
 16433	[    1.776358] io scheduler bfq registered
 16434	[    1.778815] gpio-447 (usb-hub-reset): hogged as output/high
 16435	[    1.781698] EINJ: ACPI disabled.
 16436	[    1.787836] soc soc0: Amlogic Meson G12B (S922X) Revision 29:a (40:2) Detected
 16437	[    1.789214] VCC_3V3: supplied by VDDAO_3V3
 16438	[    1.789249] FLASH_1V8: supplied by VCC_3V3
 16439	[    1.789281] VCC_1V8: supplied by VCC_3V3
 16440	[    1.789314] VDDAO_1V8: supplied by VDDAO_3V3
 16441	[    1.789355] VDDCPU_A: supplied by regulator-dummy
 16442	[    1.789713] VDDCPU_B: supplied by regulator-dummy
 16443	[    1.790383] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
 16444	[    1.792777] Serial: AMBA driver
 16445	[    1.793063] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart
 16446	[    1.793159] printk: console [ttyAML0] enabled
 16447	[    1.793667] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 33, base_baud = 1500000) is a meson_uart
 16448	[    1.799423] loop: module loaded
 16449	[    1.801380] libphy: Fixed MDIO Bus: probed
 16450	[    1.802435] tun: Universal TUN/TAP device driver, 1.6
 16451	[    1.803053] thunder_xcv, ver 1.0
 16452	[    1.803082] thunder_bgx, ver 1.0
 16453	[    1.803109] nicpf, ver 1.0
 16454	[    1.803593] e1000e: Intel(R) PRO/1000 Network Driver
 16455	[    1.803597] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
 16456	[    1.803641] igb: Intel(R) Gigabit Ethernet Network Driver
 16457	[    1.803644] igb: Copyright (c) 2007-2014 Intel Corporation.
 16458	[    1.803680] igbvf: Intel(R) Gigabit Virtual Function Network Driver
 16459	[    1.803683] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
 16460	[    1.803809] sky2: driver version 1.30
 16461	[    1.804194] VFIO - User Level meta-driver version: 0.3
 16462	[    1.805514] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
 16463	[    1.805535] ehci-pci: EHCI PCI platform driver
 16464	[    1.805565] ehci-platform: EHCI generic platform driver
 16465	[    1.805687] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
 16466	[    1.805699] ohci-pci: OHCI PCI platform driver
 16467	[    1.805734] ohci-platform: OHCI generic platform driver
 16468	[    1.806106] usbcore: registered new interface driver usb-storage
 16469	[    1.807366] mousedev: PS/2 mouse device common for all mice
 16470	[    1.807814] i2c /dev entries driver
 16471	[    1.813291] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17
 16472	[    1.813967] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz
 16473	[    1.814647] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-1 failed:-17
 16474	[    1.815255] sdhci: Secure Digital Host Controller Interface driver
 16475	[    1.815261] sdhci: Copyright(c) Pierre Ossman
 16476	[    1.815373] Synopsys Designware Multimedia Card Interface Driver
 16477	[    1.815894] sdhci-pltfm: SDHCI platform and OF driver helper
 16478	[    1.816805] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq
 16479	[    1.817279] ledtrig-cpu: registered to indicate activity on CPUs
 16480	[    1.817563] meson-sm: secure-monitor enabled
 16481	[    1.817739] hid: raw HID events driver (C) Jiri Kosina
 16482	[    1.817812] usbcore: registered new interface driver usbhid
 16483	[    1.817815] usbhid: USB HID core driver
 16484	[    1.818776] NET: Registered protocol family 10
 16485	[    1.819326] Segment Routing with IPv6
 16486	[    1.819353] NET: Registered protocol family 17
 16487	[    1.819428] 8021q: 802.1Q VLAN Support v1.8
 16488	[    1.819465] Key type dns_resolver registered
 16489	[    1.819803] registered taskstats version 1
 16490	[    1.819809] Loading compiled-in X.509 certificates
 16491	[    1.821565] Loaded X.509 cert 'Build time autogenerated kernel key: f47c178852ca39740c3546b008122b65f5ed9bce'
 16492	[    1.823162] zswap: loaded using pool zstd/z3fold
 16493	[    1.823336] Key type ._fscrypt registered
 16494	[    1.823338] Key type .fscrypt registered
 16495	[    1.823340] Key type fscrypt-provisioning registered
 16496	[    1.824580] Btrfs loaded, crc32c=crc32c-generic
 16497	[    1.830488] Key type encrypted registered
 16498	[    1.830501] AppArmor: AppArmor sha1 policy hashing enabled
 16499	[    1.836717] HUB_5V: supplied by 5V
 16500	[    1.836954] USB_PWR_EN: supplied by 5V
 16501	[    1.838585] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2
 16502	[    1.838592] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1
 16503	[    1.841584] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator
 16504	[    1.841639] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator
 16505	[    1.841750] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM
 16506	[    1.842339] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
 16507	[    1.842352] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
 16508	[    1.842437] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010
 16509	[    1.842457] xhci-hcd xhci-hcd.0.auto: irq 41, io mem 0xff500000
 16510	[    1.842586] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
 16511	[    1.842589] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 16512	[    1.842593] usb usb1: Product: xHCI Host Controller
 16513	[    1.842595] usb usb1: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
 16514	[    1.842597] usb usb1: SerialNumber: xhci-hcd.0.auto
 16515	[    1.842788] hub 1-0:1.0: USB hub found
 16516	[    1.842802] hub 1-0:1.0: 2 ports detected
 16517	[    1.842937] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
 16518	[    1.842943] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
 16519	[    1.842948] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
 16520	[    1.842971] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
 16521	[    1.843005] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
 16522	[    1.843008] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 16523	[    1.843010] usb usb2: Product: xHCI Host Controller
 16524	[    1.843012] usb usb2: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
 16525	[    1.843014] usb usb2: SerialNumber: xhci-hcd.0.auto
 16526	[    1.843159] hub 2-0:1.0: USB hub found
 16527	[    1.843169] hub 2-0:1.0: 1 port detected
 16528	[    1.844803] meson-gx-mmc ffe05000.sd: Got CD GPIO
 16529	[    1.872382] Freeing unused kernel memory: 3328K
 16530	[    1.899626] Run /init as init process
 16531	[    1.899630]   with arguments:
 16532	[    1.899632]     /init
 16533	[    1.899634]   with environment:
 16534	[    1.899636]     HOME=/
 16535	[    1.899637]     TERM=linux
 16536	[    1.899639]     hdmimode=custombuilt
 16537	[    1.899641]     cvbsmode=576cvbs
 16538	[    1.899642]     max_freq_a53=1896
 16539	[    1.899645]     max_freq_a73=1800
 16540	[    1.899646]     voutmode=hdmi
 16541	[    1.899648]     modeline=1920,1080,148500,56250,50,1920,2448,2492,2640,1080,1084,1089,1125,1,1,1
 16542	[    1.899649]     disablehpd=false
 16543	[    1.899650]     cvbscable=
 16544	[    1.899652]     overscan=100
 16545	[    1.923542] mmc1: new high speed SDHC card at address b368
 16546	[    1.924420] mmcblk1: mmc1:b368 CBADS 30.0 GiB
 16547	[    1.926398]  mmcblk1: p1
 16548	[    2.050780] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found
 16549	[    2.050787] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found
 16550	[    2.050865] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock
 16551	[    2.052650] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37
 16552	[    2.052659] meson8b-dwmac ff3f0000.ethernet: 	DWMAC1000
 16553	[    2.052664] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported
 16554	[    2.052666] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported
 16555	[    2.052669] meson8b-dwmac ff3f0000.ethernet: COE Type 2
 16556	[    2.052671] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported
 16557	[    2.052673] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported
 16558	[    2.052729] meson8b-dwmac ff3f0000.ethernet: Normal descriptors
 16559	[    2.052732] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled
 16560	[    2.052735] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
 16561	[    2.052947] libphy: stmmac: probed
 16562	[    2.060446] libphy: mdio_mux: probed
 16563	[    2.062542] meson-vrtc ff8000a8.rtc: registered as rtc1
 16564	[    2.084853] rtc-pcf8563 1-0051: registered as rtc0
 16565	[    2.085913] random: fast init done
 16566	[    2.086045] rtc-pcf8563 1-0051: setting system clock to 2021-02-21T14:44:10 UTC (1613918650)
 16567	[    2.179507] usb 1-1: new high-speed USB device number 2 using xhci-hcd
 16568	[    2.263964] libphy: mdio_mux: probed
 16569	[    2.333853] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.04
 16570	[    2.333861] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
 16571	[    2.333863] usb 1-1: Product: USB2.1 Hub
 16572	[    2.333865] usb 1-1: Manufacturer: GenesysLogic
 16573	[    2.387156] hub 1-1:1.0: USB hub found
 16574	[    2.387375] hub 1-1:1.0: 4 ports detected
 16575	[    2.459600] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
 16576	[    2.482078] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.04
 16577	[    2.482082] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
 16578	[    2.482085] usb 2-1: Product: USB3.1 Hub
 16579	[    2.482087] usb 2-1: Manufacturer: GenesysLogic
 16580	[    2.499144] hub 2-1:1.0: USB hub found
 16581	[    2.499427] hub 2-1:1.0: 4 ports detected
 16582	[    2.607495] usb 1-2: new high-speed USB device number 3 using xhci-hcd
 16583	[    2.735504] usb 1-2: device descriptor read/64, error -71
 16584	[    2.971504] usb 1-2: device descriptor read/64, error -71
 16585	[    3.207491] usb 1-2: new high-speed USB device number 4 using xhci-hcd
 16586	[    3.335501] usb 1-2: device descriptor read/64, error -71
 16587	[    3.571500] usb 1-2: device descriptor read/64, error -71
 16588	[    3.679517] usb usb1-port2: attempt power cycle
 16589	[    4.331488] usb 1-2: new high-speed USB device number 5 using xhci-hcd
 16590	[    4.331515] usb 1-2: Device not responding to setup address.
 16591	[    4.539512] usb 1-2: Device not responding to setup address.
 16592	[    4.747489] usb 1-2: device not accepting address 5, error -71
 16593	[    4.875491] usb 1-2: new high-speed USB device number 6 using xhci-hcd
 16594	[    4.875519] usb 1-2: Device not responding to setup address.
 16595	[    5.083514] usb 1-2: Device not responding to setup address.
 16596	[    5.291490] usb 1-2: device not accepting address 6, error -71
 16597	[    5.291521] usb usb1-port2: unable to enumerate USB device
 16598	[    5.595212] EXT4-fs (mmcblk1p1): mounted filesystem with writeback data mode. Opts: (null)
 16599	[    6.389237] systemd[1]: Inserted module 'autofs4'
 16600	[    6.435919] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
 16601	[    6.436132] systemd[1]: Detected architecture arm64.
 16602	[    6.465504] systemd[1]: Set hostname to <odroidn2>.
 16603	[    6.796257] random: systemd: uninitialized urandom read (16 bytes read)
 16604	[    6.799574] random: systemd: uninitialized urandom read (16 bytes read)
 16605	[    6.800904] systemd[1]: Created slice system-serial\x2dgetty.slice.
 16606	[    6.801120] random: systemd: uninitialized urandom read (16 bytes read)
 16607	[    6.801468] systemd[1]: Created slice User and Session Slice.
 16608	[    6.801625] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
 16609	[    6.801935] systemd[1]: Listening on udev Kernel Socket.
 16610	[    6.802290] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
 16611	[    6.802455] systemd[1]: Listening on initctl Compatibility Named Pipe.
 16612	[    6.802696] systemd[1]: Listening on Journal Socket (/dev/log).
 16613	[    6.883128] EXT4-fs (mmcblk1p1): re-mounted. Opts: commit=600,errors=remount-ro
 16614	[    7.416831] pwm-gpio pwmgpio: 1 gpio pwms loaded
 16615	[    7.419751] zram: Added device: zram0
 16616	[    7.419929] zram: Added device: zram1
 16617	[    7.420093] zram: Added device: zram2
 16618	[    7.586758] meson-saradc ff809000.adc: supply vref not found, using dummy regulator
 16619	[    7.595957] mc: Linux media interface: v0.10
 16620	[    7.683965] videodev: Linux video capture interface: v2.00
 16621	[    7.708910] meson-drm ff900000.vpu: Queued 2 outputs on vpu
 16622	[    7.744843] meson-drm ff900000.vpu: CVBS Output connector not available
 16623	[    7.747559] Registered IR keymap rc-odroid
 16624	[    7.767470] IR NEC protocol handler initialized
 16625	[    7.777488] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
 16626	[    7.778769] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
 16627	[    7.778972] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
 16628	[    7.779180] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 0
 16629	[    7.780874] panfrost ffe40000.gpu: clock rate = 24000000
 16630	[    7.780925] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19
 16631	[    7.783795] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0
 16632	[    7.783801] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400
 16633	[    7.783805] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
 16634	[    7.783808] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1
 16635	[    7.799635] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0
 16636	[    7.799773] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
 16637	[    7.799874] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input0
 16638	[    7.800040] meson-ir ff808000.ir: receiver initialized
 16639	[    7.800084] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 1
 16640	[    7.810773] zram0: detected capacity change from 0 to 1904500736
 16641	[    7.901972] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
 16642	[    8.087691] Console: switching to colour frame buffer device 240x67
 16643	[    8.122401] meson-drm ff900000.vpu: [drm] fb0: mesondrmfb frame buffer device
 16644	[    8.164026] axg-sound-card sound: ASoC: no DMI vendor name!
 16645	[    8.843545] Adding 1859860k swap on /dev/zram0.  Priority:5 extents:1 across:1859860k SSFS
 16646	[    8.907361] zram1: detected capacity change from 0 to 52428800
 16647	[   10.993743] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
 16648	[   10.993762] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
 16649	[   12.171627] systemd[1]: Started Armbian memory supported logging.
 16650	[   12.175803] systemd[1]: Starting Journal Service...
 16651	[   12.232832] systemd[1]: Started Journal Service.
 16652	[   12.260842] systemd-journald[1842]: Received request to flush runtime journal from PID 1
 16653
 16654	### armbian-release:
 16655
 16656	# PLEASE DO NOT EDIT THIS FILE
 16657	BOARD=odroidn2
 16658	BOARD_NAME="Odroid N2"
 16659	BOARDFAMILY=meson-g12b
 16660	BUILD_REPOSITORY_URL=https://github.com/armbian/build
 16661	BUILD_REPOSITORY_COMMIT=5f03d652
 16662	DISTRIBUTION_CODENAME=buster
 16663	DISTRIBUTION_STATUS=supported
 16664	VERSION=21.02.1
 16665	LINUXFAMILY=meson64
 16666	BRANCH=current
 16667	ARCH=arm64
 16668	IMAGE_TYPE=stable
 16669	BOARD_TYPE=conf
 16670	INITRD_ARCH=arm64
 16671	KERNEL_IMAGE_TYPE=Image
 16672
 16673	### boot environment:
 16674
 16675	verbosity=1
 16676	console=both
 16677	overlay_prefix=meson
 16678	rootdev=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c
 16679	rootfstype=ext4
 16680	usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
 16681
 16682	### lsusb:
 16683
 16684	Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc.
 16685	Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
 16686	Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
 16687	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
 16688
 16689	### lscpu:
 16690
 16691	Architecture:        aarch64
 16692	Byte Order:          Little Endian
 16693	CPU(s):              6
 16694	On-line CPU(s) list: 0-5
 16695	Thread(s) per core:  1
 16696	Core(s) per socket:  3
 16697	Socket(s):           2
 16698	NUMA node(s):        1
 16699	Vendor ID:           ARM
 16700	Model:               4
 16701	Model name:          Cortex-A53
 16702	Stepping:            r0p4
 16703	CPU max MHz:         1992.0000
 16704	CPU min MHz:         100.0000
 16705	BogoMIPS:            48.00
 16706	L1d cache:           unknown size
 16707	L1i cache:           unknown size
 16708	L2 cache:            unknown size
 16709	NUMA node0 CPU(s):   0-5
 16710	Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 16711
 16712	### cpuinfo:
 16713
 16714	processor	: 0
 16715	BogoMIPS	: 48.00
 16716	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 16717	CPU implementer	: 0x41
 16718	CPU architecture: 8
 16719	CPU variant	: 0x0
 16720	CPU part	: 0xd03
 16721	CPU revision	: 4
 16722
 16723	processor	: 1
 16724	BogoMIPS	: 48.00
 16725	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 16726	CPU implementer	: 0x41
 16727	CPU architecture: 8
 16728	CPU variant	: 0x0
 16729	CPU part	: 0xd03
 16730	CPU revision	: 4
 16731
 16732	processor	: 2
 16733	BogoMIPS	: 48.00
 16734	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 16735	CPU implementer	: 0x41
 16736	CPU architecture: 8
 16737	CPU variant	: 0x0
 16738	CPU part	: 0xd09
 16739	CPU revision	: 2
 16740
 16741	processor	: 3
 16742	BogoMIPS	: 48.00
 16743	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 16744	CPU implementer	: 0x41
 16745	CPU architecture: 8
 16746	CPU variant	: 0x0
 16747	CPU part	: 0xd09
 16748	CPU revision	: 2
 16749
 16750	processor	: 4
 16751	BogoMIPS	: 48.00
 16752	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 16753	CPU implementer	: 0x41
 16754	CPU architecture: 8
 16755	CPU variant	: 0x0
 16756	CPU part	: 0xd09
 16757	CPU revision	: 2
 16758
 16759	processor	: 5
 16760	BogoMIPS	: 48.00
 16761	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 16762	CPU implementer	: 0x41
 16763	CPU architecture: 8
 16764	CPU variant	: 0x0
 16765	CPU part	: 0xd09
 16766	CPU revision	: 2
 16767
 16768
 16769	### meminfo:
 16770
 16771	MemTotal:        3719728 kB
 16772	MemFree:         3407628 kB
 16773	MemAvailable:    3362020 kB
 16774	Buffers:           11676 kB
 16775	Cached:            45972 kB
 16776	SwapCached:            0 kB
 16777	Active:            29500 kB
 16778	Inactive:         174156 kB
 16779	Active(anon):         92 kB
 16780	Inactive(anon):   150928 kB
 16781	Active(file):      29408 kB
 16782	Inactive(file):    23228 kB
 16783	Unevictable:           0 kB
 16784	Mlocked:               0 kB
 16785	SwapTotal:       1859860 kB
 16786	SwapFree:        1859860 kB
 16787	Dirty:              6864 kB
 16788	Writeback:             0 kB
 16789	AnonPages:        146304 kB
 16790	Mapped:            10904 kB
 16791	Shmem:              4868 kB
 16792	KReclaimable:      12860 kB
 16793	Slab:              38528 kB
 16794	SReclaimable:      12860 kB
 16795	SUnreclaim:        25668 kB
 16796	KernelStack:        2112 kB
 16797	PageTables:         5196 kB
 16798	NFS_Unstable:          0 kB
 16799	Bounce:                0 kB
 16800	WritebackTmp:          0 kB
 16801	CommitLimit:     3719724 kB
 16802	Committed_AS:    4210540 kB
 16803	VmallocTotal:   135290159040 kB
 16804	VmallocUsed:       30944 kB
 16805	VmallocChunk:          0 kB
 16806	Percpu:             1368 kB
 16807	HardwareCorrupted:     0 kB
 16808	AnonHugePages:     40960 kB
 16809	ShmemHugePages:        0 kB
 16810	ShmemPmdMapped:        0 kB
 16811	FileHugePages:         0 kB
 16812	FilePmdMapped:         0 kB
 16813	CmaTotal:         917504 kB
 16814	CmaFree:          901724 kB
 16815	HugePages_Total:       0
 16816	HugePages_Free:        0
 16817	HugePages_Rsvd:        0
 16818	HugePages_Surp:        0
 16819	Hugepagesize:       2048 kB
 16820	Hugetlb:               0 kB
 16821
 16822	### virtual memory:
 16823
 16824	vm.admin_reserve_kbytes = 8192
 16825	vm.block_dump = 0
 16826	vm.compaction_proactiveness = 20
 16827	vm.compact_unevictable_allowed = 1
 16828	vm.dirty_background_bytes = 0
 16829	vm.dirty_background_ratio = 10
 16830	vm.dirty_bytes = 0
 16831	vm.dirty_expire_centisecs = 3000
 16832	vm.dirty_ratio = 20
 16833	vm.dirtytime_expire_seconds = 43200
 16834	vm.dirty_writeback_centisecs = 500
 16835	vm.extfrag_threshold = 500
 16836	vm.hugetlb_shm_group = 0
 16837	vm.laptop_mode = 0
 16838	vm.legacy_va_layout = 0
 16839	vm.lowmem_reserve_ratio = 256	256	32	0
 16840	vm.max_map_count = 65530
 16841	vm.memory_failure_early_kill = 0
 16842	vm.memory_failure_recovery = 1
 16843	vm.min_free_kbytes = 45056
 16844	vm.min_slab_ratio = 5
 16845	vm.min_unmapped_ratio = 1
 16846	vm.mmap_min_addr = 4096
 16847	vm.mmap_rnd_bits = 18
 16848	vm.mmap_rnd_compat_bits = 11
 16849	vm.nr_hugepages = 0
 16850	vm.nr_hugepages_mempolicy = 0
 16851	vm.nr_overcommit_hugepages = 0
 16852	vm.numa_stat = 1
 16853	vm.numa_zonelist_order = Node
 16854	vm.oom_dump_tasks = 1
 16855	vm.oom_kill_allocating_task = 0
 16856	vm.overcommit_kbytes = 0
 16857	vm.overcommit_memory = 0
 16858	vm.overcommit_ratio = 50
 16859	vm.page-cluster = 0
 16860	vm.page_lock_unfairness = 5
 16861	vm.panic_on_oom = 0
 16862	vm.percpu_pagelist_fraction = 0
 16863	vm.stat_interval = 1
 16864	vm.swappiness = 100
 16865	vm.user_reserve_kbytes = 115058
 16866	vm.vfs_cache_pressure = 100
 16867	vm.watermark_boost_factor = 15000
 16868	vm.watermark_scale_factor = 10
 16869	vm.zone_reclaim_mode = 0
 16870
 16871	### ip addr:
 16872
 16873	1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
 16874	    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
 16875	    inet XXX.XXX.0.1/8 scope host lo
 16876	       valid_lft forever preferred_lft forever
 16877	    inet6 ::1/128 scope host
 16878	       valid_lft forever preferred_lft forever
 16879	2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
 16880	    link/ether 00:1e:06:42:03:f8 brd ff:ff:ff:ff:ff:ff
 16881
 16882	### partitions:
 16883
 16884	major minor  #blocks  name
 16885
 16886	 179        0   31464960 mmcblk1
 16887	 179        1   31146208 mmcblk1p1
 16888	 252        0    1859864 zram0
 16889	 252        1      51200 zram1
 16890
 16891	### df:
 16892
 16893	udev            1.4G     0  1.4G   0% /dev
 16894	tmpfs           364M  4.9M  359M   2% /run
 16895	/dev/mmcblk1p1   30G  1.7G   28G   6% /
 16896	tmpfs           1.8G     0  1.8G   0% /dev/shm
 16897	tmpfs           5.0M  4.0K  5.0M   1% /run/lock
 16898	tmpfs           1.8G     0  1.8G   0% /sys/fs/cgroup
 16899	tmpfs           1.8G     0  1.8G   0% /tmp
 16900	/dev/zram1       49M  6.8M   39M  15% /var/log
 16901
 16902	### lsblk:
 16903
 16904	NAME        FSTYPE  SIZE MOUNTPOINT UUID
 16905	mmcblk1              30G
 16906	└─mmcblk1p1 ext4   29.7G /          bd34953d-41be-49d6-b1c0-c0c28a5e239c
 16907	zram1                50M /var/log
 16908
 16909	### zramctl:
 16910
 16911	NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
 16912	/dev/zram1 zstd           50M  132K  698B   36K       6 /var/log
 16913	/dev/zram0 lzo-rle       1.8G    4K   74B   12K       6 [SWAP]
 16914
 16915	### mtab:
 16916
 16917	/dev/mmcblk1p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
 16918	/dev/mmcblk1p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
 16919	/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
 16920
 16921	### mmc1:b368 info:
 16922
 16923	               fwrev: 0x0
 16924	              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=CBADS MODALIAS=mmc:block
 16925	                 cid: 6f0303434241445310aa002b4d013b00
 16926	                 rca: 0xb368
 16927	                 csd: 400e005a5b590000f00e7f800a404000
 16928	              manfid: 0x00006f
 16929	                 ocr: 0x00200000
 16930	preferred_erase_size: 2097152
 16931	                type: SD
 16932	               hwrev: 0x1
 16933	                date: 11/2019
 16934	                 dsr: 0x404
 16935	          erase_size: 512
 16936	               oemid: 0x0303
 16937	              serial: 0xaa002b4d
 16938	                 ssr: 00000000000000280402800100fd180a001e00000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
 16939	                 scr: 02b5800300000000
 16940	                name: CBADS
 16941
 16942	### Boot system health:
 16943
 16944	Time       big.LITTLE   load %cpu %sys %usr %nice %io %irq   CPU  C.St.
 16945	14:44:22: 1908/1992MHz  0.07  20%   9%   4%   0%   6%   0% 31.7°C  0/11
 16946	14:44:22: 1908/1992MHz  0.07  64%  21%   2%   0%  39%   0% 29.1°C  0/11
 16947	14:44:22: 1908/1992MHz  0.07  57%  11%   5%   0%  39%   0% 29.3°C  0/11
 16948	14:44:23: 1908/1992MHz  0.07  46%   3%   2%   0%  39%   1% 28.7°C  0/11
 16949	14:44:23: 1908/1992MHz  0.07  61%   2%   6%   0%  52%   0% 28.3°C  0/11
 16950
 16951	### Activated 1 lzo-rle zram swap devices with 1816 MB each
 16952
 16953	### Activated Armbian ramlog partition with zstd compression
 16954
 16955	Sun 21 Feb 2021 02:45:41 PM GMT | Odroid N2 | 21.02.1 | arm64 | aarch64 | 5.10.12-meson64
 16956
 16957	### dmesg:
 16958
 16959	[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
 16960	[    0.000000] Linux version 5.10.12-meson64 (root@beast) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #21.02.1 SMP PREEMPT Wed Feb 3 21:06:36 CET 2021
 16961	[    0.000000] Machine model: Hardkernel ODROID-N2
 16962	[    0.000000] efi: UEFI not found.
 16963	[    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
 16964	[    0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB
 16965	[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
 16966	[    0.000000] NUMA: No NUMA configuration found
 16967	[    0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ed7fffff]
 16968	[    0.000000] NUMA: NODE_DATA [mem 0xb502f100-0xb5030fff]
 16969	[    0.000000] Zone ranges:
 16970	[    0.000000]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
 16971	[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000ed7fffff]
 16972	[    0.000000]   Normal   empty
 16973	[    0.000000] Movable zone start for each node
 16974	[    0.000000] Early memory node ranges
 16975	[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000004ffffff]
 16976	[    0.000000]   node   0: [mem 0x0000000005300000-0x00000000ed7fffff]
 16977	[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ed7fffff]
 16978	[    0.000000] On node 0 totalpages: 972032
 16979	[    0.000000]   DMA zone: 4096 pages used for memmap
 16980	[    0.000000]   DMA zone: 0 pages reserved
 16981	[    0.000000]   DMA zone: 261376 pages, LIFO batch:63
 16982	[    0.000000]   DMA32 zone: 11104 pages used for memmap
 16983	[    0.000000]   DMA32 zone: 710656 pages, LIFO batch:63
 16984	[    0.000000] psci: probing for conduit method from DT.
 16985	[    0.000000] psci: PSCIv1.0 detected in firmware.
 16986	[    0.000000] psci: Using standard PSCI v0.2 function IDs
 16987	[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
 16988	[    0.000000] psci: SMC Calling Convention v1.1
 16989	[    0.000000] percpu: Embedded 23 pages/cpu s56728 r8192 d29288 u94208
 16990	[    0.000000] pcpu-alloc: s56728 r8192 d29288 u94208 alloc=23*4096
 16991	[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
 16992	[    0.000000] Detected VIPT I-cache on CPU0
 16993	[    0.000000] CPU features: detected: ARM erratum 845719
 16994	[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 956832
 16995	[    0.000000] Policy zone: DMA32
 16996	[    0.000000] Kernel command line: root=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c rootwait rootfstype=ext4 console=ttyAML0,115200n8 console=tty1 loglevel=1  no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=custombuilt cvbsmode=576cvbs max_freq_a53=1896 max_freq_a73=1800 maxcpus=6 voutmode=hdmi modeline=1920,1080,148500,56250,50,1920,2448,2492,2640,1080,1084,1089,1125,1,1,1 disablehpd=false  cvbscable= overscan=100 consoleblank=0
 16997	[    0.000000] Kernel parameter elevator= does not have any effect anymore.
 16998	               Please use sysfs to set IO scheduler for individual devices.
 16999	[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
 17000	[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
 17001	[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
 17002	[    0.000000] software IO TLB: mapped [mem 0x0000000038ac5000-0x000000003cac5000] (64MB)
 17003	[    0.000000] Memory: 2785352K/3888128K available (14144K kernel code, 1760K rwdata, 5508K rodata, 3328K init, 592K bss, 185272K reserved, 917504K cma-reserved)
 17004	[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
 17005	[    0.000000] rcu: Preemptible hierarchical RCU implementation.
 17006	[    0.000000] rcu: 	RCU event tracing is enabled.
 17007	[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
 17008	[    0.000000] 	Trampoline variant of Tasks RCU enabled.
 17009	[    0.000000] 	Rude variant of Tasks RCU enabled.
 17010	[    0.000000] 	Tracing variant of Tasks RCU enabled.
 17011	[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
 17012	[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
 17013	[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
 17014	[    0.000000] GIC: Using split EOI/Deactivate mode
 17015	[    0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized
 17016	[    0.000000] random: get_random_bytes called from start_kernel+0x378/0x538 with crng_init=0
 17017	[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
 17018	[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
 17019	[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
 17020	[    0.000242] Console: colour dummy device 80x25
 17021	[    0.000277] printk: console [tty1] enabled
 17022	[    0.000367] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
 17023	[    0.000378] pid_max: default: 32768 minimum: 301
 17024	[    0.000462] LSM: Security Framework initializing
 17025	[    0.000488] Yama: becoming mindful.
 17026	[    0.000579] AppArmor: AppArmor initialized
 17027	[    0.000630] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
 17028	[    0.000649] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
 17029	[    0.002644] rcu: Hierarchical SRCU implementation.
 17030	[    0.004998] EFI services will not be available.
 17031	[    0.005422] smp: Bringing up secondary CPUs ...
 17032	[    0.006096] Detected VIPT I-cache on CPU1
 17033	[    0.006157] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
 17034	[    0.007350] CPU features: detected: ARM erratum 858921
 17035	[    0.007358] CPU features: detected: Spectre-v2
 17036	[    0.007362] CPU features: detected: Spectre-v4
 17037	[    0.007369] Detected VIPT I-cache on CPU2
 17038	[    0.007394] arch_timer: Enabling local workaround for ARM erratum 858921
 17039	[    0.007408] arch_timer: CPU2: Trapping CNTVCT access
 17040	[    0.007421] CPU2: Booted secondary processor 0x0000000100 [0x410fd092]
 17041	[    0.008125] Detected VIPT I-cache on CPU3
 17042	[    0.008141] arch_timer: Enabling local workaround for ARM erratum 858921
 17043	[    0.008149] arch_timer: CPU3: Trapping CNTVCT access
 17044	[    0.008157] CPU3: Booted secondary processor 0x0000000101 [0x410fd092]
 17045	[    0.008784] Detected VIPT I-cache on CPU4
 17046	[    0.008801] arch_timer: Enabling local workaround for ARM erratum 858921
 17047	[    0.008808] arch_timer: CPU4: Trapping CNTVCT access
 17048	[    0.008815] CPU4: Booted secondary processor 0x0000000102 [0x410fd092]
 17049	[    0.009431] Detected VIPT I-cache on CPU5
 17050	[    0.009447] arch_timer: Enabling local workaround for ARM erratum 858921
 17051	[    0.009454] arch_timer: CPU5: Trapping CNTVCT access
 17052	[    0.009462] CPU5: Booted secondary processor 0x0000000103 [0x410fd092]
 17053	[    0.009544] smp: Brought up 1 node, 6 CPUs
 17054	[    0.009561] SMP: Total of 6 processors activated.
 17055	[    0.009569] CPU features: detected: 32-bit EL0 Support
 17056	[    0.009575] CPU features: detected: CRC32 instructions
 17057	[    0.009580] CPU features: detected: 32-bit EL1 Support
 17058	[    0.020867] CPU: All CPU(s) started at EL2
 17059	[    0.020917] alternatives: patching kernel code
 17060	[    0.022859] devtmpfs: initialized
 17061	[    0.030530] Registered cp15_barrier emulation handler
 17062	[    0.030544] Registered setend emulation handler
 17063	[    0.030679] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
 17064	[    0.030718] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
 17065	[    0.044640] pinctrl core: initialized pinctrl subsystem
 17066	[    0.045374] DMI not present or invalid.
 17067	[    0.045748] NET: Registered protocol family 16
 17068	[    0.047219] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
 17069	[    0.047507] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
 17070	[    0.047734] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
 17071	[    0.047776] audit: initializing netlink subsys (disabled)
 17072	[    0.047871] audit: type=2000 audit(0.044:1): state=initialized audit_enabled=0 res=1
 17073	[    0.049065] thermal_sys: Registered thermal governor 'fair_share'
 17074	[    0.049072] thermal_sys: Registered thermal governor 'bang_bang'
 17075	[    0.049076] thermal_sys: Registered thermal governor 'step_wise'
 17076	[    0.049079] thermal_sys: Registered thermal governor 'user_space'
 17077	[    0.049490] cpuidle: using governor menu
 17078	[    0.049838] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
 17079	[    0.049959] ASID allocator initialised with 65536 entries
 17080	[    0.050861] Serial: AMBA PL011 UART driver
 17081	[    0.084434] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
 17082	[    0.084445] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
 17083	[    0.084451] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
 17084	[    0.084455] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
 17085	[    0.086607] cryptd: max_cpu_qlen set to 1000
 17086	[    0.156149] raid6: neonx8   gen()  2787 MB/s
 17087	[    0.224210] raid6: neonx8   xor()  2041 MB/s
 17088	[    0.292321] raid6: neonx4   gen()  2998 MB/s
 17089	[    0.360356] raid6: neonx4   xor()  2396 MB/s
 17090	[    0.428424] raid6: neonx2   gen()  2541 MB/s
 17091	[    0.496487] raid6: neonx2   xor()  2197 MB/s
 17092	[    0.564558] raid6: neonx1   gen()  2060 MB/s
 17093	[    0.632617] raid6: neonx1   xor()  1725 MB/s
 17094	[    0.700684] raid6: int64x8  gen()  1376 MB/s
 17095	[    0.768756] raid6: int64x8  xor()   735 MB/s
 17096	[    0.836845] raid6: int64x4  gen()  1463 MB/s
 17097	[    0.904890] raid6: int64x4  xor()   733 MB/s
 17098	[    0.972949] raid6: int64x2  gen()  1362 MB/s
 17099	[    1.041031] raid6: int64x2  xor()   619 MB/s
 17100	[    1.109094] raid6: int64x1  gen()  1120 MB/s
 17101	[    1.177165] raid6: int64x1  xor()   462 MB/s
 17102	[    1.177169] raid6: using algorithm neonx4 gen() 2998 MB/s
 17103	[    1.177172] raid6: .... xor() 2396 MB/s, rmw enabled
 17104	[    1.177176] raid6: using neon recovery algorithm
 17105	[    1.177645] ACPI: Interpreter disabled.
 17106	[    1.178433] 5V: supplied by 12V
 17107	[    1.179343] VDDAO_3V3: supplied by 12V
 17108	[    1.179833] iommu: Default domain type: Translated
 17109	[    1.179959] vgaarb: loaded
 17110	[    1.180844] SCSI subsystem initialized
 17111	[    1.181175] usbcore: registered new interface driver usbfs
 17112	[    1.181219] usbcore: registered new interface driver hub
 17113	[    1.181258] usbcore: registered new device driver usb
 17114	[    1.181609] pps_core: LinuxPPS API ver. 1 registered
 17115	[    1.181613] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
 17116	[    1.181629] PTP clock support registered
 17117	[    1.181809] EDAC MC: Ver: 3.0.0
 17118	[    1.183176] NetLabel: Initializing
 17119	[    1.183184] NetLabel:  domain hash size = 128
 17120	[    1.183187] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
 17121	[    1.183230] NetLabel:  unlabeled traffic allowed by default
 17122	[    1.183694] clocksource: Switched to clocksource arch_sys_counter
 17123	[    1.183903] VFS: Disk quotas dquot_6.6.0
 17124	[    1.183947] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
 17125	[    1.184370] AppArmor: AppArmor Filesystem Enabled
 17126	[    1.184416] pnp: PnP ACPI: disabled
 17127	[    1.189912] NET: Registered protocol family 2
 17128	[    1.190379] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
 17129	[    1.190483] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
 17130	[    1.190739] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
 17131	[    1.190927] TCP: Hash tables configured (established 32768 bind 32768)
 17132	[    1.191078] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
 17133	[    1.191144] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
 17134	[    1.191190] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
 17135	[    1.191334] NET: Registered protocol family 1
 17136	[    1.191353] PCI: CLS 0 bytes, default 64
 17137	[    1.191480] Trying to unpack rootfs image as initramfs...
 17138	[    1.727038] Freeing initrd memory: 13544K
 17139	[    1.727985] kvm [1]: IPA Size Limit: 40 bits
 17140	[    1.728686] kvm [1]: vgic interrupt IRQ9
 17141	[    1.728822] kvm [1]: Hyp mode initialized successfully
 17142	[    1.733807] Initialise system trusted keyrings
 17143	[    1.733842] Key type blacklist registered
 17144	[    1.733943] workingset: timestamp_bits=44 max_order=20 bucket_order=0
 17145	[    1.737180] zbud: loaded
 17146	[    1.738144] squashfs: version 4.0 (2009/01/31) Phillip Lougher
 17147	[    1.738604] fuse: init (API version 7.32)
 17148	[    1.739395] integrity: Platform Keyring initialized
 17149	[    1.767080] xor: measuring software checksum speed
 17150	[    1.769927]    8regs           :  3473 MB/sec
 17151	[    1.772382]    32regs          :  4024 MB/sec
 17152	[    1.775025]    arm64_neon      :  3727 MB/sec
 17153	[    1.775028] xor: using function: 32regs (4024 MB/sec)
 17154	[    1.775036] Key type asymmetric registered
 17155	[    1.775040] Asymmetric key parser 'x509' registered
 17156	[    1.775073] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
 17157	[    1.775157] io scheduler mq-deadline registered
 17158	[    1.775162] io scheduler kyber registered
 17159	[    1.775243] io scheduler bfq registered
 17160	[    1.777743] gpio-447 (usb-hub-reset): hogged as output/high
 17161	[    1.780644] EINJ: ACPI disabled.
 17162	[    1.786823] soc soc0: Amlogic Meson G12B (S922X) Revision 29:a (40:2) Detected
 17163	[    1.788258] VCC_3V3: supplied by VDDAO_3V3
 17164	[    1.788295] FLASH_1V8: supplied by VCC_3V3
 17165	[    1.788325] VCC_1V8: supplied by VCC_3V3
 17166	[    1.788355] VDDAO_1V8: supplied by VDDAO_3V3
 17167	[    1.788395] VDDCPU_A: supplied by regulator-dummy
 17168	[    1.788756] VDDCPU_B: supplied by regulator-dummy
 17169	[    1.789456] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
 17170	[    1.791764] Serial: AMBA driver
 17171	[    1.792061] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart
 17172	[    1.792152] printk: console [ttyAML0] enabled
 17173	[    1.792678] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 33, base_baud = 1500000) is a meson_uart
 17174	[    1.798107] loop: module loaded
 17175	[    1.799949] libphy: Fixed MDIO Bus: probed
 17176	[    1.801132] tun: Universal TUN/TAP device driver, 1.6
 17177	[    1.801772] thunder_xcv, ver 1.0
 17178	[    1.801805] thunder_bgx, ver 1.0
 17179	[    1.801833] nicpf, ver 1.0
 17180	[    1.802280] e1000e: Intel(R) PRO/1000 Network Driver
 17181	[    1.802283] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
 17182	[    1.802322] igb: Intel(R) Gigabit Ethernet Network Driver
 17183	[    1.802325] igb: Copyright (c) 2007-2014 Intel Corporation.
 17184	[    1.802356] igbvf: Intel(R) Gigabit Virtual Function Network Driver
 17185	[    1.802359] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
 17186	[    1.802494] sky2: driver version 1.30
 17187	[    1.802887] VFIO - User Level meta-driver version: 0.3
 17188	[    1.804500] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
 17189	[    1.804537] ehci-pci: EHCI PCI platform driver
 17190	[    1.804572] ehci-platform: EHCI generic platform driver
 17191	[    1.804697] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
 17192	[    1.804713] ohci-pci: OHCI PCI platform driver
 17193	[    1.804748] ohci-platform: OHCI generic platform driver
 17194	[    1.805128] usbcore: registered new interface driver usb-storage
 17195	[    1.806389] mousedev: PS/2 mouse device common for all mice
 17196	[    1.806753] i2c /dev entries driver
 17197	[    1.811832] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17
 17198	[    1.812513] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz
 17199	[    1.813283] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-1 failed:-17
 17200	[    1.813944] sdhci: Secure Digital Host Controller Interface driver
 17201	[    1.813951] sdhci: Copyright(c) Pierre Ossman
 17202	[    1.814076] Synopsys Designware Multimedia Card Interface Driver
 17203	[    1.814581] sdhci-pltfm: SDHCI platform and OF driver helper
 17204	[    1.815366] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq
 17205	[    1.816006] ledtrig-cpu: registered to indicate activity on CPUs
 17206	[    1.816257] meson-sm: secure-monitor enabled
 17207	[    1.816448] hid: raw HID events driver (C) Jiri Kosina
 17208	[    1.816521] usbcore: registered new interface driver usbhid
 17209	[    1.816523] usbhid: USB HID core driver
 17210	[    1.817530] NET: Registered protocol family 10
 17211	[    1.818041] Segment Routing with IPv6
 17212	[    1.818072] NET: Registered protocol family 17
 17213	[    1.818116] 8021q: 802.1Q VLAN Support v1.8
 17214	[    1.818140] Key type dns_resolver registered
 17215	[    1.818417] registered taskstats version 1
 17216	[    1.818422] Loading compiled-in X.509 certificates
 17217	[    1.820118] Loaded X.509 cert 'Build time autogenerated kernel key: f47c178852ca39740c3546b008122b65f5ed9bce'
 17218	[    1.821699] zswap: loaded using pool zstd/z3fold
 17219	[    1.821865] Key type ._fscrypt registered
 17220	[    1.821868] Key type .fscrypt registered
 17221	[    1.821870] Key type fscrypt-provisioning registered
 17222	[    1.822955] Btrfs loaded, crc32c=crc32c-generic
 17223	[    1.828954] Key type encrypted registered
 17224	[    1.828966] AppArmor: AppArmor sha1 policy hashing enabled
 17225	[    1.835234] HUB_5V: supplied by 5V
 17226	[    1.835435] USB_PWR_EN: supplied by 5V
 17227	[    1.837087] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2
 17228	[    1.837094] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1
 17229	[    1.839907] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator
 17230	[    1.839964] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator
 17231	[    1.840073] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM
 17232	[    1.840675] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
 17233	[    1.840687] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
 17234	[    1.840772] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010
 17235	[    1.840793] xhci-hcd xhci-hcd.0.auto: irq 41, io mem 0xff500000
 17236	[    1.840922] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
 17237	[    1.840926] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 17238	[    1.840929] usb usb1: Product: xHCI Host Controller
 17239	[    1.840932] usb usb1: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
 17240	[    1.840934] usb usb1: SerialNumber: xhci-hcd.0.auto
 17241	[    1.841127] hub 1-0:1.0: USB hub found
 17242	[    1.841140] hub 1-0:1.0: 2 ports detected
 17243	[    1.841271] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
 17244	[    1.841281] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
 17245	[    1.841286] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
 17246	[    1.841310] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
 17247	[    1.841340] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
 17248	[    1.841344] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 17249	[    1.841347] usb usb2: Product: xHCI Host Controller
 17250	[    1.841349] usb usb2: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
 17251	[    1.841351] usb usb2: SerialNumber: xhci-hcd.0.auto
 17252	[    1.841491] hub 2-0:1.0: USB hub found
 17253	[    1.841501] hub 2-0:1.0: 1 port detected
 17254	[    1.842952] meson-gx-mmc ffe05000.sd: Got CD GPIO
 17255	[    1.868815] Freeing unused kernel memory: 3328K
 17256	[    1.903752] Run /init as init process
 17257	[    1.903755]   with arguments:
 17258	[    1.903757]     /init
 17259	[    1.903759]   with environment:
 17260	[    1.903761]     HOME=/
 17261	[    1.903763]     TERM=linux
 17262	[    1.903764]     hdmimode=custombuilt
 17263	[    1.903766]     cvbsmode=576cvbs
 17264	[    1.903767]     max_freq_a53=1896
 17265	[    1.903769]     max_freq_a73=1800
 17266	[    1.903770]     voutmode=hdmi
 17267	[    1.903772]     modeline=1920,1080,148500,56250,50,1920,2448,2492,2640,1080,1084,1089,1125,1,1,1
 17268	[    1.903773]     disablehpd=false
 17269	[    1.903775]     cvbscable=
 17270	[    1.903776]     overscan=100
 17271	[    1.935142] mmc1: new ultra high speed SDR25 SDHC card at address b368
 17272	[    1.936051] mmcblk1: mmc1:b368 CBADS 30.0 GiB
 17273	[    1.938045]  mmcblk1: p1
 17274	[    2.065228] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found
 17275	[    2.065235] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found
 17276	[    2.065315] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock
 17277	[    2.065713] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37
 17278	[    2.065719] meson8b-dwmac ff3f0000.ethernet: 	DWMAC1000
 17279	[    2.065723] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported
 17280	[    2.065725] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported
 17281	[    2.065727] meson8b-dwmac ff3f0000.ethernet: COE Type 2
 17282	[    2.065729] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported
 17283	[    2.065732] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported
 17284	[    2.065774] meson8b-dwmac ff3f0000.ethernet: Normal descriptors
 17285	[    2.065777] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled
 17286	[    2.065780] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
 17287	[    2.065990] libphy: stmmac: probed
 17288	[    2.067276] libphy: mdio_mux: probed
 17289	[    2.072856] meson-vrtc ff8000a8.rtc: registered as rtc1
 17290	[    2.094196] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
 17291	[    2.094395] rtc-pcf8563 1-0051: registered as rtc0
 17292	[    2.095564] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
 17293	[    2.095573] rtc-pcf8563 1-0051: hctosys: unable to read the hardware clock
 17294	[    2.099172] random: fast init done
 17295	[    2.183821] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
 17296	[    2.208455] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.04
 17297	[    2.208461] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
 17298	[    2.208464] usb 2-1: Product: USB3.1 Hub
 17299	[    2.208466] usb 2-1: Manufacturer: GenesysLogic
 17300	[    2.225502] hub 2-1:1.0: USB hub found
 17301	[    2.225786] hub 2-1:1.0: 4 ports detected
 17302	[    2.272124] libphy: mdio_mux: probed
 17303	[    2.331722] usb 1-1: new high-speed USB device number 2 using xhci-hcd
 17304	[    2.481992] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.04
 17305	[    2.481999] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
 17306	[    2.482002] usb 1-1: Product: USB2.1 Hub
 17307	[    2.482006] usb 1-1: Manufacturer: GenesysLogic
 17308	[    2.545579] hub 1-1:1.0: USB hub found
 17309	[    2.545845] hub 1-1:1.0: 4 ports detected
 17310	[    2.735706] usb 1-2: new high-speed USB device number 3 using xhci-hcd
 17311	[    3.475713] usb 1-2: device descriptor read/64, error -71
 17312	[   14.687711] usb 1-2: device descriptor read/64, error -110
 17313	[   14.923698] usb 1-2: new high-speed USB device number 4 using xhci-hcd
 17314	[   20.063712] usb 1-2: device descriptor read/64, error -110
 17315	[   26.931708] usb 1-2: device descriptor read/64, error -71
 17316	[   27.039788] usb usb1-port2: attempt power cycle
 17317	[   27.691695] usb 1-2: new high-speed USB device number 5 using xhci-hcd
 17318	[   27.691813] usb 1-2: Device not responding to setup address.
 17319	[   27.900536] usb 1-2: Device not responding to setup address.
 17320	[   28.107694] usb 1-2: device not accepting address 5, error -71
 17321	[   28.235694] usb 1-2: new high-speed USB device number 6 using xhci-hcd
 17322	[   28.236145] usb 1-2: Device not responding to setup address.
 17323	[   28.444222] usb 1-2: Device not responding to setup address.
 17324	[   28.651692] usb 1-2: device not accepting address 6, error -71
 17325	[   28.651764] usb usb1-port2: unable to enumerate USB device
 17326	[   28.970397] EXT4-fs (mmcblk1p1): mounted filesystem with writeback data mode. Opts: (null)
 17327	[   29.773035] systemd[1]: System time before build time, advancing clock.
 17328	[   29.787881] systemd[1]: Inserted module 'autofs4'
 17329	[   29.834346] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
 17330	[   29.834562] systemd[1]: Detected architecture arm64.
 17331	[   29.869289] systemd[1]: Set hostname to <odroidn2>.
 17332	[   30.197441] random: systemd: uninitialized urandom read (16 bytes read)
 17333	[   30.200788] random: systemd: uninitialized urandom read (16 bytes read)
 17334	[   30.201067] systemd[1]: Listening on udev Control Socket.
 17335	[   30.201265] random: systemd: uninitialized urandom read (16 bytes read)
 17336	[   30.202498] systemd[1]: Created slice system-getty.slice.
 17337	[   30.202714] systemd[1]: Listening on initctl Compatibility Named Pipe.
 17338	[   30.202868] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
 17339	[   30.202970] systemd[1]: Reached target Swap.
 17340	[   30.203339] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
 17341	[   30.203615] systemd[1]: Listening on Journal Socket (/dev/log).
 17342	[   30.277300] EXT4-fs (mmcblk1p1): re-mounted. Opts: commit=600,errors=remount-ro
 17343	[   30.749324] zram: Added device: zram0
 17344	[   30.749817] zram: Added device: zram1
 17345	[   30.750217] zram: Added device: zram2
 17346	[   30.857440] pwm-gpio pwmgpio: 1 gpio pwms loaded
 17347	[   31.012409] panfrost ffe40000.gpu: clock rate = 24000000
 17348	[   31.012463] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19
 17349	[   31.013050] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0
 17350	[   31.013056] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400
 17351	[   31.013061] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
 17352	[   31.013064] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1
 17353	[   31.031671] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 0
 17354	[   31.033255] meson-saradc ff809000.adc: supply vref not found, using dummy regulator
 17355	[   31.037498] mc: Linux media interface: v0.10
 17356	[   31.039988] zram0: detected capacity change from 0 to 1904500736
 17357	[   31.105298] videodev: Linux video capture interface: v2.00
 17358	[   31.120344] meson-drm ff900000.vpu: Queued 2 outputs on vpu
 17359	[   31.167719] Registered IR keymap rc-odroid
 17360	[   31.180880] meson-drm ff900000.vpu: CVBS Output connector not available
 17361	[   31.188871] IR NEC protocol handler initialized
 17362	[   31.207879] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
 17363	[   31.209867] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
 17364	[   31.210197] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
 17365	[   31.210786] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 1
 17366	[   31.223122] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0
 17367	[   31.223262] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
 17368	[   31.223328] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input0
 17369	[   31.223576] meson-ir ff808000.ir: receiver initialized
 17370	[   31.250270] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
 17371	[   31.495850] Console: switching to colour frame buffer device 240x67
 17372	[   31.522379] meson-drm ff900000.vpu: [drm] fb0: mesondrmfb frame buffer device
 17373	[   31.563138] axg-sound-card sound: ASoC: no DMI vendor name!
 17374	[   32.139707] Adding 1859860k swap on /dev/zram0.  Priority:5 extents:1 across:1859860k SSFS
 17375	[   32.202958] zram1: detected capacity change from 0 to 52428800
 17376	[   34.289902] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
 17377	[   34.289923] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
 17378	[   35.488954] systemd[1]: Started Armbian memory supported logging.
 17379	[   35.493072] systemd[1]: Starting Journal Service...
 17380	[   35.549201] systemd[1]: Started Journal Service.
 17381	[   35.578504] systemd-journald[1839]: Received request to flush runtime journal from PID 1
 17382
 17383	### armbian-release:
 17384
 17385	# PLEASE DO NOT EDIT THIS FILE
 17386	BOARD=odroidn2
 17387	BOARD_NAME="Odroid N2"
 17388	BOARDFAMILY=meson-g12b
 17389	BUILD_REPOSITORY_URL=https://github.com/armbian/build
 17390	BUILD_REPOSITORY_COMMIT=5f03d652
 17391	DISTRIBUTION_CODENAME=buster
 17392	DISTRIBUTION_STATUS=supported
 17393	VERSION=21.02.1
 17394	LINUXFAMILY=meson64
 17395	BRANCH=current
 17396	ARCH=arm64
 17397	IMAGE_TYPE=stable
 17398	BOARD_TYPE=conf
 17399	INITRD_ARCH=arm64
 17400	KERNEL_IMAGE_TYPE=Image
 17401
 17402	### boot environment:
 17403
 17404	verbosity=1
 17405	console=both
 17406	overlay_prefix=meson
 17407	rootdev=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c
 17408	rootfstype=ext4
 17409	usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
 17410
 17411	### lsusb:
 17412
 17413	Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc.
 17414	Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
 17415	Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
 17416	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
 17417
 17418	### lscpu:
 17419
 17420	Architecture:        aarch64
 17421	Byte Order:          Little Endian
 17422	CPU(s):              6
 17423	On-line CPU(s) list: 0-5
 17424	Thread(s) per core:  1
 17425	Core(s) per socket:  3
 17426	Socket(s):           2
 17427	NUMA node(s):        1
 17428	Vendor ID:           ARM
 17429	Model:               4
 17430	Model name:          Cortex-A53
 17431	Stepping:            r0p4
 17432	CPU max MHz:         1992.0000
 17433	CPU min MHz:         100.0000
 17434	BogoMIPS:            48.00
 17435	L1d cache:           unknown size
 17436	L1i cache:           unknown size
 17437	L2 cache:            unknown size
 17438	NUMA node0 CPU(s):   0-5
 17439	Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 17440
 17441	### cpuinfo:
 17442
 17443	processor	: 0
 17444	BogoMIPS	: 48.00
 17445	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 17446	CPU implementer	: 0x41
 17447	CPU architecture: 8
 17448	CPU variant	: 0x0
 17449	CPU part	: 0xd03
 17450	CPU revision	: 4
 17451
 17452	processor	: 1
 17453	BogoMIPS	: 48.00
 17454	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 17455	CPU implementer	: 0x41
 17456	CPU architecture: 8
 17457	CPU variant	: 0x0
 17458	CPU part	: 0xd03
 17459	CPU revision	: 4
 17460
 17461	processor	: 2
 17462	BogoMIPS	: 48.00
 17463	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 17464	CPU implementer	: 0x41
 17465	CPU architecture: 8
 17466	CPU variant	: 0x0
 17467	CPU part	: 0xd09
 17468	CPU revision	: 2
 17469
 17470	processor	: 3
 17471	BogoMIPS	: 48.00
 17472	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 17473	CPU implementer	: 0x41
 17474	CPU architecture: 8
 17475	CPU variant	: 0x0
 17476	CPU part	: 0xd09
 17477	CPU revision	: 2
 17478
 17479	processor	: 4
 17480	BogoMIPS	: 48.00
 17481	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 17482	CPU implementer	: 0x41
 17483	CPU architecture: 8
 17484	CPU variant	: 0x0
 17485	CPU part	: 0xd09
 17486	CPU revision	: 2
 17487
 17488	processor	: 5
 17489	BogoMIPS	: 48.00
 17490	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 17491	CPU implementer	: 0x41
 17492	CPU architecture: 8
 17493	CPU variant	: 0x0
 17494	CPU part	: 0xd09
 17495	CPU revision	: 2
 17496
 17497
 17498	### meminfo:
 17499
 17500	MemTotal:        3719728 kB
 17501	MemFree:         3388276 kB
 17502	MemAvailable:    3342788 kB
 17503	Buffers:           11548 kB
 17504	Cached:            46240 kB
 17505	SwapCached:            0 kB
 17506	Active:            30256 kB
 17507	Inactive:         192588 kB
 17508	Active(anon):        100 kB
 17509	Inactive(anon):   170264 kB
 17510	Active(file):      30156 kB
 17511	Inactive(file):    22324 kB
 17512	Unevictable:           0 kB
 17513	Mlocked:               0 kB
 17514	SwapTotal:       1859860 kB
 17515	SwapFree:        1859860 kB
 17516	Dirty:              7152 kB
 17517	Writeback:             0 kB
 17518	AnonPages:        165380 kB
 17519	Mapped:            10952 kB
 17520	Shmem:              4868 kB
 17521	KReclaimable:      13264 kB
 17522	Slab:              39112 kB
 17523	SReclaimable:      13264 kB
 17524	SUnreclaim:        25848 kB
 17525	KernelStack:        2064 kB
 17526	PageTables:         4740 kB
 17527	NFS_Unstable:          0 kB
 17528	Bounce:                0 kB
 17529	WritebackTmp:          0 kB
 17530	CommitLimit:     3719724 kB
 17531	Committed_AS:    4210508 kB
 17532	VmallocTotal:   135290159040 kB
 17533	VmallocUsed:       30896 kB
 17534	VmallocChunk:          0 kB
 17535	Percpu:             1368 kB
 17536	HardwareCorrupted:     0 kB
 17537	AnonHugePages:         0 kB
 17538	ShmemHugePages:        0 kB
 17539	ShmemPmdMapped:        0 kB
 17540	FileHugePages:         0 kB
 17541	FilePmdMapped:         0 kB
 17542	CmaTotal:         917504 kB
 17543	CmaFree:          901724 kB
 17544	HugePages_Total:       0
 17545	HugePages_Free:        0
 17546	HugePages_Rsvd:        0
 17547	HugePages_Surp:        0
 17548	Hugepagesize:       2048 kB
 17549	Hugetlb:               0 kB
 17550
 17551	### virtual memory:
 17552
 17553	vm.admin_reserve_kbytes = 8192
 17554	vm.block_dump = 0
 17555	vm.compaction_proactiveness = 20
 17556	vm.compact_unevictable_allowed = 1
 17557	vm.dirty_background_bytes = 0
 17558	vm.dirty_background_ratio = 10
 17559	vm.dirty_bytes = 0
 17560	vm.dirty_expire_centisecs = 3000
 17561	vm.dirty_ratio = 20
 17562	vm.dirtytime_expire_seconds = 43200
 17563	vm.dirty_writeback_centisecs = 500
 17564	vm.extfrag_threshold = 500
 17565	vm.hugetlb_shm_group = 0
 17566	vm.laptop_mode = 0
 17567	vm.legacy_va_layout = 0
 17568	vm.lowmem_reserve_ratio = 256	256	32	0
 17569	vm.max_map_count = 65530
 17570	vm.memory_failure_early_kill = 0
 17571	vm.memory_failure_recovery = 1
 17572	vm.min_free_kbytes = 45056
 17573	vm.min_slab_ratio = 5
 17574	vm.min_unmapped_ratio = 1
 17575	vm.mmap_min_addr = 4096
 17576	vm.mmap_rnd_bits = 18
 17577	vm.mmap_rnd_compat_bits = 11
 17578	vm.nr_hugepages = 0
 17579	vm.nr_hugepages_mempolicy = 0
 17580	vm.nr_overcommit_hugepages = 0
 17581	vm.numa_stat = 1
 17582	vm.numa_zonelist_order = Node
 17583	vm.oom_dump_tasks = 1
 17584	vm.oom_kill_allocating_task = 0
 17585	vm.overcommit_kbytes = 0
 17586	vm.overcommit_memory = 0
 17587	vm.overcommit_ratio = 50
 17588	vm.page-cluster = 0
 17589	vm.page_lock_unfairness = 5
 17590	vm.panic_on_oom = 0
 17591	vm.percpu_pagelist_fraction = 0
 17592	vm.stat_interval = 1
 17593	vm.swappiness = 100
 17594	vm.user_reserve_kbytes = 115003
 17595	vm.vfs_cache_pressure = 100
 17596	vm.watermark_boost_factor = 15000
 17597	vm.watermark_scale_factor = 10
 17598	vm.zone_reclaim_mode = 0
 17599
 17600	### ip addr:
 17601
 17602	1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
 17603	    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
 17604	    inet XXX.XXX.0.1/8 scope host lo
 17605	       valid_lft forever preferred_lft forever
 17606	    inet6 ::1/128 scope host
 17607	       valid_lft forever preferred_lft forever
 17608	2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
 17609	    link/ether 00:1e:06:42:03:f8 brd ff:ff:ff:ff:ff:ff
 17610
 17611	### partitions:
 17612
 17613	major minor  #blocks  name
 17614
 17615	 179        0   31464960 mmcblk1
 17616	 179        1   31146208 mmcblk1p1
 17617	 252        0    1859864 zram0
 17618	 252        1      51200 zram1
 17619
 17620	### df:
 17621
 17622	udev            1.4G     0  1.4G   0% /dev
 17623	tmpfs           364M  4.9M  359M   2% /run
 17624	/dev/mmcblk1p1   30G  1.8G   28G   6% /
 17625	tmpfs           1.8G     0  1.8G   0% /dev/shm
 17626	tmpfs           5.0M  4.0K  5.0M   1% /run/lock
 17627	tmpfs           1.8G     0  1.8G   0% /sys/fs/cgroup
 17628	tmpfs           1.8G     0  1.8G   0% /tmp
 17629	/dev/zram1       49M  7.0M   38M  16% /var/log
 17630
 17631	### lsblk:
 17632
 17633	NAME        FSTYPE  SIZE MOUNTPOINT UUID
 17634	mmcblk1              30G
 17635	└─mmcblk1p1 ext4   29.7G /          bd34953d-41be-49d6-b1c0-c0c28a5e239c
 17636	zram1                50M /var/log
 17637
 17638	### zramctl:
 17639
 17640	NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
 17641	/dev/zram1 zstd           50M  132K  698B   36K       6 /var/log
 17642	/dev/zram0 lzo-rle       1.8G    4K   74B   12K       6 [SWAP]
 17643
 17644	### mtab:
 17645
 17646	/dev/mmcblk1p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
 17647	/dev/mmcblk1p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
 17648	/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
 17649
 17650	### mmc1:b368 info:
 17651
 17652	               fwrev: 0x0
 17653	              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=CBADS MODALIAS=mmc:block
 17654	                 cid: 6f0303434241445310aa002b4d013b00
 17655	                 rca: 0xb368
 17656	                 csd: 400e005a5b590000f00e7f800a404000
 17657	              manfid: 0x00006f
 17658	                 ocr: 0x00200000
 17659	preferred_erase_size: 2097152
 17660	                type: SD
 17661	               hwrev: 0x1
 17662	                date: 11/2019
 17663	                 dsr: 0x404
 17664	          erase_size: 512
 17665	               oemid: 0x0303
 17666	              serial: 0xaa002b4d
 17667	                 ssr: 00000000000000280402800100fd180a001e00000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
 17668	                 scr: 02b5800300000000
 17669	                name: CBADS
 17670
 17671	### Boot system health:
 17672
 17673	Time       big.LITTLE   load %cpu %sys %usr %nice %io %irq   CPU  C.St.
 17674	14:45:42: 1908/1992MHz  0.59   7%   3%   1%   0%   1%   0% 32.5°C  0/11
 17675	14:45:42: 1908/1992MHz  0.59  87%  33%   3%   0%  49%   0% 31.6°C  0/11
 17676	14:45:43: 1908/1992MHz  0.59  55%   5%   3%   0%  44%   1% 29.3°C  0/11
 17677	14:45:43: 1908/1992MHz  0.59  56%   6%   5%   0%  43%   0% 28.8°C  0/11
 17678	14:45:43: 1908/1000MHz  0.59  41%   3%   5%   0%  32%   0% 28.7°C  0/11
 17679
 17680	### Activated 1 lzo-rle zram swap devices with 1816 MB each
 17681
 17682	### Activated Armbian ramlog partition with zstd compression
 17683
 17684	Sun 21 Feb 2021 02:49:11 PM GMT | Odroid N2 | 21.02.1 | arm64 | aarch64 | 5.10.12-meson64
 17685
 17686	### dmesg:
 17687
 17688	[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
 17689	[    0.000000] Linux version 5.10.12-meson64 (root@beast) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #21.02.1 SMP PREEMPT Wed Feb 3 21:06:36 CET 2021
 17690	[    0.000000] Machine model: Hardkernel ODROID-N2
 17691	[    0.000000] efi: UEFI not found.
 17692	[    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
 17693	[    0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB
 17694	[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
 17695	[    0.000000] NUMA: No NUMA configuration found
 17696	[    0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ed7fffff]
 17697	[    0.000000] NUMA: NODE_DATA [mem 0xb502f100-0xb5030fff]
 17698	[    0.000000] Zone ranges:
 17699	[    0.000000]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
 17700	[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000ed7fffff]
 17701	[    0.000000]   Normal   empty
 17702	[    0.000000] Movable zone start for each node
 17703	[    0.000000] Early memory node ranges
 17704	[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000004ffffff]
 17705	[    0.000000]   node   0: [mem 0x0000000005300000-0x00000000ed7fffff]
 17706	[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ed7fffff]
 17707	[    0.000000] On node 0 totalpages: 972032
 17708	[    0.000000]   DMA zone: 4096 pages used for memmap
 17709	[    0.000000]   DMA zone: 0 pages reserved
 17710	[    0.000000]   DMA zone: 261376 pages, LIFO batch:63
 17711	[    0.000000]   DMA32 zone: 11104 pages used for memmap
 17712	[    0.000000]   DMA32 zone: 710656 pages, LIFO batch:63
 17713	[    0.000000] psci: probing for conduit method from DT.
 17714	[    0.000000] psci: PSCIv1.0 detected in firmware.
 17715	[    0.000000] psci: Using standard PSCI v0.2 function IDs
 17716	[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
 17717	[    0.000000] psci: SMC Calling Convention v1.1
 17718	[    0.000000] percpu: Embedded 23 pages/cpu s56728 r8192 d29288 u94208
 17719	[    0.000000] pcpu-alloc: s56728 r8192 d29288 u94208 alloc=23*4096
 17720	[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
 17721	[    0.000000] Detected VIPT I-cache on CPU0
 17722	[    0.000000] CPU features: detected: ARM erratum 845719
 17723	[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 956832
 17724	[    0.000000] Policy zone: DMA32
 17725	[    0.000000] Kernel command line: root=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c rootwait rootfstype=ext4 console=ttyAML0,115200n8 console=tty1 loglevel=1  no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=custombuilt cvbsmode=576cvbs max_freq_a53=1896 max_freq_a73=1800 maxcpus=6 voutmode=hdmi modeline=1920,1080,148500,56250,50,1920,2448,2492,2640,1080,1084,1089,1125,1,1,1 disablehpd=false  cvbscable= overscan=100 consoleblank=0
 17726	[    0.000000] Kernel parameter elevator= does not have any effect anymore.
 17727	               Please use sysfs to set IO scheduler for individual devices.
 17728	[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
 17729	[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
 17730	[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
 17731	[    0.000000] software IO TLB: mapped [mem 0x0000000038ac5000-0x000000003cac5000] (64MB)
 17732	[    0.000000] Memory: 2785352K/3888128K available (14144K kernel code, 1760K rwdata, 5508K rodata, 3328K init, 592K bss, 185272K reserved, 917504K cma-reserved)
 17733	[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
 17734	[    0.000000] rcu: Preemptible hierarchical RCU implementation.
 17735	[    0.000000] rcu: 	RCU event tracing is enabled.
 17736	[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
 17737	[    0.000000] 	Trampoline variant of Tasks RCU enabled.
 17738	[    0.000000] 	Rude variant of Tasks RCU enabled.
 17739	[    0.000000] 	Tracing variant of Tasks RCU enabled.
 17740	[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
 17741	[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
 17742	[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
 17743	[    0.000000] GIC: Using split EOI/Deactivate mode
 17744	[    0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized
 17745	[    0.000000] random: get_random_bytes called from start_kernel+0x378/0x538 with crng_init=0
 17746	[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
 17747	[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
 17748	[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
 17749	[    0.000243] Console: colour dummy device 80x25
 17750	[    0.000278] printk: console [tty1] enabled
 17751	[    0.000365] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
 17752	[    0.000377] pid_max: default: 32768 minimum: 301
 17753	[    0.000462] LSM: Security Framework initializing
 17754	[    0.000488] Yama: becoming mindful.
 17755	[    0.000579] AppArmor: AppArmor initialized
 17756	[    0.000630] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
 17757	[    0.000649] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
 17758	[    0.002642] rcu: Hierarchical SRCU implementation.
 17759	[    0.004997] EFI services will not be available.
 17760	[    0.005421] smp: Bringing up secondary CPUs ...
 17761	[    0.006092] Detected VIPT I-cache on CPU1
 17762	[    0.006153] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
 17763	[    0.007344] CPU features: detected: ARM erratum 858921
 17764	[    0.007352] CPU features: detected: Spectre-v2
 17765	[    0.007355] CPU features: detected: Spectre-v4
 17766	[    0.007362] Detected VIPT I-cache on CPU2
 17767	[    0.007388] arch_timer: Enabling local workaround for ARM erratum 858921
 17768	[    0.007402] arch_timer: CPU2: Trapping CNTVCT access
 17769	[    0.007415] CPU2: Booted secondary processor 0x0000000100 [0x410fd092]
 17770	[    0.008123] Detected VIPT I-cache on CPU3
 17771	[    0.008139] arch_timer: Enabling local workaround for ARM erratum 858921
 17772	[    0.008146] arch_timer: CPU3: Trapping CNTVCT access
 17773	[    0.008154] CPU3: Booted secondary processor 0x0000000101 [0x410fd092]
 17774	[    0.008780] Detected VIPT I-cache on CPU4
 17775	[    0.008797] arch_timer: Enabling local workaround for ARM erratum 858921
 17776	[    0.008804] arch_timer: CPU4: Trapping CNTVCT access
 17777	[    0.008812] CPU4: Booted secondary processor 0x0000000102 [0x410fd092]
 17778	[    0.009428] Detected VIPT I-cache on CPU5
 17779	[    0.009444] arch_timer: Enabling local workaround for ARM erratum 858921
 17780	[    0.009451] arch_timer: CPU5: Trapping CNTVCT access
 17781	[    0.009458] CPU5: Booted secondary processor 0x0000000103 [0x410fd092]
 17782	[    0.009537] smp: Brought up 1 node, 6 CPUs
 17783	[    0.009555] SMP: Total of 6 processors activated.
 17784	[    0.009563] CPU features: detected: 32-bit EL0 Support
 17785	[    0.009569] CPU features: detected: CRC32 instructions
 17786	[    0.009575] CPU features: detected: 32-bit EL1 Support
 17787	[    0.020867] CPU: All CPU(s) started at EL2
 17788	[    0.020916] alternatives: patching kernel code
 17789	[    0.022868] devtmpfs: initialized
 17790	[    0.030538] Registered cp15_barrier emulation handler
 17791	[    0.030552] Registered setend emulation handler
 17792	[    0.030688] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
 17793	[    0.030728] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
 17794	[    0.044671] pinctrl core: initialized pinctrl subsystem
 17795	[    0.045218] DMI not present or invalid.
 17796	[    0.045620] NET: Registered protocol family 16
 17797	[    0.047147] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
 17798	[    0.047420] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
 17799	[    0.047645] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
 17800	[    0.047690] audit: initializing netlink subsys (disabled)
 17801	[    0.047799] audit: type=2000 audit(0.044:1): state=initialized audit_enabled=0 res=1
 17802	[    0.049031] thermal_sys: Registered thermal governor 'fair_share'
 17803	[    0.049039] thermal_sys: Registered thermal governor 'bang_bang'
 17804	[    0.049044] thermal_sys: Registered thermal governor 'step_wise'
 17805	[    0.049047] thermal_sys: Registered thermal governor 'user_space'
 17806	[    0.049476] cpuidle: using governor menu
 17807	[    0.049845] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
 17808	[    0.049968] ASID allocator initialised with 65536 entries
 17809	[    0.050925] Serial: AMBA PL011 UART driver
 17810	[    0.084631] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
 17811	[    0.084640] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
 17812	[    0.084645] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
 17813	[    0.084649] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
 17814	[    0.087404] cryptd: max_cpu_qlen set to 1000
 17815	[    0.156149] raid6: neonx8   gen()  2786 MB/s
 17816	[    0.224208] raid6: neonx8   xor()  2042 MB/s
 17817	[    0.292310] raid6: neonx4   gen()  2999 MB/s
 17818	[    0.360361] raid6: neonx4   xor()  2395 MB/s
 17819	[    0.428409] raid6: neonx2   gen()  2529 MB/s
 17820	[    0.496476] raid6: neonx2   xor()  2208 MB/s
 17821	[    0.564541] raid6: neonx1   gen()  2080 MB/s
 17822	[    0.632613] raid6: neonx1   xor()  1727 MB/s
 17823	[    0.700691] raid6: int64x8  gen()  1373 MB/s
 17824	[    0.768742] raid6: int64x8  xor()   735 MB/s
 17825	[    0.836827] raid6: int64x4  gen()  1463 MB/s
 17826	[    0.904878] raid6: int64x4  xor()   733 MB/s
 17827	[    0.972940] raid6: int64x2  gen()  1362 MB/s
 17828	[    1.041019] raid6: int64x2  xor()   619 MB/s
 17829	[    1.109077] raid6: int64x1  gen()  1120 MB/s
 17830	[    1.177140] raid6: int64x1  xor()   462 MB/s
 17831	[    1.177144] raid6: using algorithm neonx4 gen() 2999 MB/s
 17832	[    1.177147] raid6: .... xor() 2395 MB/s, rmw enabled
 17833	[    1.177151] raid6: using neon recovery algorithm
 17834	[    1.177582] ACPI: Interpreter disabled.
 17835	[    1.178355] 5V: supplied by 12V
 17836	[    1.179240] VDDAO_3V3: supplied by 12V
 17837	[    1.179744] iommu: Default domain type: Translated
 17838	[    1.179857] vgaarb: loaded
 17839	[    1.180498] SCSI subsystem initialized
 17840	[    1.180699] usbcore: registered new interface driver usbfs
 17841	[    1.180737] usbcore: registered new interface driver hub
 17842	[    1.180772] usbcore: registered new device driver usb
 17843	[    1.181043] pps_core: LinuxPPS API ver. 1 registered
 17844	[    1.181048] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
 17845	[    1.181059] PTP clock support registered
 17846	[    1.181213] EDAC MC: Ver: 3.0.0
 17847	[    1.182550] NetLabel: Initializing
 17848	[    1.182558] NetLabel:  domain hash size = 128
 17849	[    1.182561] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
 17850	[    1.182606] NetLabel:  unlabeled traffic allowed by default
 17851	[    1.183164] clocksource: Switched to clocksource arch_sys_counter
 17852	[    1.183379] VFS: Disk quotas dquot_6.6.0
 17853	[    1.183426] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
 17854	[    1.183791] AppArmor: AppArmor Filesystem Enabled
 17855	[    1.183837] pnp: PnP ACPI: disabled
 17856	[    1.189604] NET: Registered protocol family 2
 17857	[    1.190057] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
 17858	[    1.190163] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
 17859	[    1.190420] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
 17860	[    1.190606] TCP: Hash tables configured (established 32768 bind 32768)
 17861	[    1.190758] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
 17862	[    1.190824] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
 17863	[    1.190871] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
 17864	[    1.191009] NET: Registered protocol family 1
 17865	[    1.191030] PCI: CLS 0 bytes, default 64
 17866	[    1.191248] Trying to unpack rootfs image as initramfs...
 17867	[    1.727520] Freeing initrd memory: 13544K
 17868	[    1.728419] kvm [1]: IPA Size Limit: 40 bits
 17869	[    1.729127] kvm [1]: vgic interrupt IRQ9
 17870	[    1.729260] kvm [1]: Hyp mode initialized successfully
 17871	[    1.734257] Initialise system trusted keyrings
 17872	[    1.734290] Key type blacklist registered
 17873	[    1.734395] workingset: timestamp_bits=44 max_order=20 bucket_order=0
 17874	[    1.737585] zbud: loaded
 17875	[    1.738564] squashfs: version 4.0 (2009/01/31) Phillip Lougher
 17876	[    1.739020] fuse: init (API version 7.32)
 17877	[    1.739802] integrity: Platform Keyring initialized
 17878	[    1.767588] xor: measuring software checksum speed
 17879	[    1.770426]    8regs           :  3473 MB/sec
 17880	[    1.772884]    32regs          :  4025 MB/sec
 17881	[    1.775537]    arm64_neon      :  3719 MB/sec
 17882	[    1.775540] xor: using function: 32regs (4025 MB/sec)
 17883	[    1.775547] Key type asymmetric registered
 17884	[    1.775551] Asymmetric key parser 'x509' registered
 17885	[    1.775582] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
 17886	[    1.775711] io scheduler mq-deadline registered
 17887	[    1.775716] io scheduler kyber registered
 17888	[    1.775796] io scheduler bfq registered
 17889	[    1.778267] gpio-447 (usb-hub-reset): hogged as output/high
 17890	[    1.781153] EINJ: ACPI disabled.
 17891	[    1.787328] soc soc0: Amlogic Meson G12B (S922X) Revision 29:a (40:2) Detected
 17892	[    1.788679] VCC_3V3: supplied by VDDAO_3V3
 17893	[    1.788712] FLASH_1V8: supplied by VCC_3V3
 17894	[    1.788744] VCC_1V8: supplied by VCC_3V3
 17895	[    1.788784] VDDAO_1V8: supplied by VDDAO_3V3
 17896	[    1.788814] VDDCPU_A: supplied by regulator-dummy
 17897	[    1.789159] VDDCPU_B: supplied by regulator-dummy
 17898	[    1.789802] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
 17899	[    1.792176] Serial: AMBA driver
 17900	[    1.792437] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart
 17901	[    1.792528] printk: console [ttyAML0] enabled
 17902	[    1.793001] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 33, base_baud = 1500000) is a meson_uart
 17903	[    1.798206] loop: module loaded
 17904	[    1.800029] libphy: Fixed MDIO Bus: probed
 17905	[    1.801139] tun: Universal TUN/TAP device driver, 1.6
 17906	[    1.801749] thunder_xcv, ver 1.0
 17907	[    1.801777] thunder_bgx, ver 1.0
 17908	[    1.801810] nicpf, ver 1.0
 17909	[    1.802253] e1000e: Intel(R) PRO/1000 Network Driver
 17910	[    1.802256] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
 17911	[    1.802297] igb: Intel(R) Gigabit Ethernet Network Driver
 17912	[    1.802300] igb: Copyright (c) 2007-2014 Intel Corporation.
 17913	[    1.802332] igbvf: Intel(R) Gigabit Virtual Function Network Driver
 17914	[    1.802335] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
 17915	[    1.802456] sky2: driver version 1.30
 17916	[    1.802821] VFIO - User Level meta-driver version: 0.3
 17917	[    1.804253] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
 17918	[    1.804274] ehci-pci: EHCI PCI platform driver
 17919	[    1.804303] ehci-platform: EHCI generic platform driver
 17920	[    1.804422] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
 17921	[    1.804432] ohci-pci: OHCI PCI platform driver
 17922	[    1.804461] ohci-platform: OHCI generic platform driver
 17923	[    1.804834] usbcore: registered new interface driver usb-storage
 17924	[    1.806026] mousedev: PS/2 mouse device common for all mice
 17925	[    1.806357] i2c /dev entries driver
 17926	[    1.811578] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17
 17927	[    1.812241] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz
 17928	[    1.812925] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-1 failed:-17
 17929	[    1.813538] sdhci: Secure Digital Host Controller Interface driver
 17930	[    1.813545] sdhci: Copyright(c) Pierre Ossman
 17931	[    1.813664] Synopsys Designware Multimedia Card Interface Driver
 17932	[    1.814080] sdhci-pltfm: SDHCI platform and OF driver helper
 17933	[    1.814495] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq
 17934	[    1.814922] ledtrig-cpu: registered to indicate activity on CPUs
 17935	[    1.815345] meson-sm: secure-monitor enabled
 17936	[    1.815575] hid: raw HID events driver (C) Jiri Kosina
 17937	[    1.815655] usbcore: registered new interface driver usbhid
 17938	[    1.815657] usbhid: USB HID core driver
 17939	[    1.816739] NET: Registered protocol family 10
 17940	[    1.817167] Segment Routing with IPv6
 17941	[    1.817198] NET: Registered protocol family 17
 17942	[    1.817251] 8021q: 802.1Q VLAN Support v1.8
 17943	[    1.817283] Key type dns_resolver registered
 17944	[    1.817574] registered taskstats version 1
 17945	[    1.817579] Loading compiled-in X.509 certificates
 17946	[    1.819337] Loaded X.509 cert 'Build time autogenerated kernel key: f47c178852ca39740c3546b008122b65f5ed9bce'
 17947	[    1.821084] zswap: loaded using pool zstd/z3fold
 17948	[    1.821259] Key type ._fscrypt registered
 17949	[    1.821262] Key type .fscrypt registered
 17950	[    1.821263] Key type fscrypt-provisioning registered
 17951	[    1.822345] Btrfs loaded, crc32c=crc32c-generic
 17952	[    1.828438] Key type encrypted registered
 17953	[    1.828450] AppArmor: AppArmor sha1 policy hashing enabled
 17954	[    1.834702] HUB_5V: supplied by 5V
 17955	[    1.834897] USB_PWR_EN: supplied by 5V
 17956	[    1.836651] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2
 17957	[    1.836658] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1
 17958	[    1.839566] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator
 17959	[    1.839631] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator
 17960	[    1.839766] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM
 17961	[    1.840358] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
 17962	[    1.840370] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
 17963	[    1.840527] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010
 17964	[    1.840557] xhci-hcd xhci-hcd.0.auto: irq 41, io mem 0xff500000
 17965	[    1.840690] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
 17966	[    1.840693] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 17967	[    1.840696] usb usb1: Product: xHCI Host Controller
 17968	[    1.840699] usb usb1: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
 17969	[    1.840701] usb usb1: SerialNumber: xhci-hcd.0.auto
 17970	[    1.840916] hub 1-0:1.0: USB hub found
 17971	[    1.840929] hub 1-0:1.0: 2 ports detected
 17972	[    1.841054] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
 17973	[    1.841061] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
 17974	[    1.841066] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
 17975	[    1.841089] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
 17976	[    1.841119] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
 17977	[    1.841122] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 17978	[    1.841125] usb usb2: Product: xHCI Host Controller
 17979	[    1.841128] usb usb2: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
 17980	[    1.841130] usb usb2: SerialNumber: xhci-hcd.0.auto
 17981	[    1.841306] hub 2-0:1.0: USB hub found
 17982	[    1.841316] hub 2-0:1.0: 1 port detected
 17983	[    1.842390] meson-gx-mmc ffe05000.sd: Got CD GPIO
 17984	[    1.868154] Freeing unused kernel memory: 3328K
 17985	[    1.903186] Run /init as init process
 17986	[    1.903190]   with arguments:
 17987	[    1.903193]     /init
 17988	[    1.903195]   with environment:
 17989	[    1.903197]     HOME=/
 17990	[    1.903198]     TERM=linux
 17991	[    1.903200]     hdmimode=custombuilt
 17992	[    1.903201]     cvbsmode=576cvbs
 17993	[    1.903203]     max_freq_a53=1896
 17994	[    1.903204]     max_freq_a73=1800
 17995	[    1.903205]     voutmode=hdmi
 17996	[    1.903208]     modeline=1920,1080,148500,56250,50,1920,2448,2492,2640,1080,1084,1089,1125,1,1,1
 17997	[    1.903209]     disablehpd=false
 17998	[    1.903210]     cvbscable=
 17999	[    1.903212]     overscan=100
 18000	[    1.933316] mmc0: new ultra high speed SDR25 SDHC card at address b368
 18001	[    1.933892] mmcblk0: mmc0:b368 CBADS 30.0 GiB
 18002	[    1.936394]  mmcblk0: p1
 18003	[    2.065641] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found
 18004	[    2.065651] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found
 18005	[    2.065823] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock
 18006	[    2.067576] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37
 18007	[    2.067591] meson8b-dwmac ff3f0000.ethernet: 	DWMAC1000
 18008	[    2.067595] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported
 18009	[    2.067598] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported
 18010	[    2.067600] meson8b-dwmac ff3f0000.ethernet: COE Type 2
 18011	[    2.067603] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported
 18012	[    2.067605] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported
 18013	[    2.067686] meson8b-dwmac ff3f0000.ethernet: Normal descriptors
 18014	[    2.067690] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled
 18015	[    2.067693] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
 18016	[    2.068068] libphy: stmmac: probed
 18017	[    2.071970] libphy: mdio_mux: probed
 18018	[    2.081972] meson-vrtc ff8000a8.rtc: registered as rtc1
 18019	[    2.096238] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
 18020	[    2.096623] rtc-pcf8563 1-0051: registered as rtc0
 18021	[    2.097810] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
 18022	[    2.097816] rtc-pcf8563 1-0051: hctosys: unable to read the hardware clock
 18023	[    2.099920] random: fast init done
 18024	[    2.183147] usb 1-1: new high-speed USB device number 2 using xhci-hcd
 18025	[    2.275561] libphy: mdio_mux: probed
 18026	[    2.337483] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.04
 18027	[    2.337490] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
 18028	[    2.337493] usb 1-1: Product: USB2.1 Hub
 18029	[    2.337495] usb 1-1: Manufacturer: GenesysLogic
 18030	[    2.385271] hub 1-1:1.0: USB hub found
 18031	[    2.385521] hub 1-1:1.0: 4 ports detected
 18032	[    2.463241] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
 18033	[    2.485718] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.04
 18034	[    2.485721] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
 18035	[    2.485724] usb 2-1: Product: USB3.1 Hub
 18036	[    2.485726] usb 2-1: Manufacturer: GenesysLogic
 18037	[    2.513264] hub 2-1:1.0: USB hub found
 18038	[    2.513546] hub 2-1:1.0: 4 ports detected
 18039	[    2.611136] usb 1-2: new high-speed USB device number 3 using xhci-hcd
 18040	[    2.759576] usb 1-2: New USB device found, idVendor=2013, idProduct=025f, bcdDevice= 1.00
 18041	[    2.759579] usb 1-2: New USB device strings: Mfr=3, Product=1, SerialNumber=2
 18042	[    2.759582] usb 1-2: Product: PCTV 292e
 18043	[    2.759584] usb 1-2: Manufacturer: PCTV
 18044	[    2.759586] usb 1-2: SerialNumber: 0011356964
 18045	[    3.155694] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
 18046	[    3.958874] systemd[1]: System time before build time, advancing clock.
 18047	[    3.973697] systemd[1]: Inserted module 'autofs4'
 18048	[    4.020247] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
 18049	[    4.020461] systemd[1]: Detected architecture arm64.
 18050	[    4.053149] systemd[1]: Set hostname to <odroidn2>.
 18051	[    4.379877] random: systemd: uninitialized urandom read (16 bytes read)
 18052	[    4.383164] random: systemd: uninitialized urandom read (16 bytes read)
 18053	[    4.383333] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
 18054	[    4.383526] random: systemd: uninitialized urandom read (16 bytes read)
 18055	[    4.383795] systemd[1]: Listening on Journal Socket.
 18056	[    4.386190] systemd[1]: Starting Create list of required static device nodes for the current kernel...
 18057	[    4.386391] systemd[1]: Reached target System Time Synchronized.
 18058	[    4.386758] systemd[1]: Listening on Syslog Socket.
 18059	[    4.387164] systemd[1]: Listening on Journal Audit Socket.
 18060	[    4.388890] systemd[1]: Starting Nameserver information manager...
 18061	[    4.438413] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
 18062	[    4.999893] zram: Added device: zram0
 18063	[    5.000133] zram: Added device: zram1
 18064	[    5.000309] zram: Added device: zram2
 18065	[    5.010518] pwm-gpio pwmgpio: 1 gpio pwms loaded
 18066	[    5.195777] mc: Linux media interface: v0.10
 18067	[    5.221997] panfrost ffe40000.gpu: clock rate = 24000000
 18068	[    5.222071] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19
 18069	[    5.222886] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0
 18070	[    5.222899] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400
 18071	[    5.222904] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
 18072	[    5.222908] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1
 18073	[    5.237482] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 0
 18074	[    5.274596] videodev: Linux video capture interface: v2.00
 18075	[    5.280308] meson-saradc ff809000.adc: supply vref not found, using dummy regulator
 18076	[    5.298544] meson-drm ff900000.vpu: Queued 2 outputs on vpu
 18077	[    5.352888] meson-drm ff900000.vpu: CVBS Output connector not available
 18078	[    5.369381] Registered IR keymap rc-odroid
 18079	[    5.383525] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
 18080	[    5.384179] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
 18081	[    5.384736] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
 18082	[    5.385227] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 1
 18083	[    5.392303] IR NEC protocol handler initialized
 18084	[    5.393784] zram0: detected capacity change from 0 to 1904500736
 18085	[    5.419258] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0
 18086	[    5.419414] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
 18087	[    5.419579] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input0
 18088	[    5.419872] meson-ir ff808000.ir: receiver initialized
 18089	[    5.452234] em28xx 1-2:1.0: New device PCTV PCTV 292e @ 480 Mbps (2013:025f, interface 0, class 0)
 18090	[    5.452244] em28xx 1-2:1.0: DVB interface 0 found: isoc
 18091	[    5.466145] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
 18092	[    5.515212] em28xx 1-2:1.0: chip ID is em28178
 18093	[    5.667320] Console: switching to colour frame buffer device 240x67
 18094	[    5.702033] meson-drm ff900000.vpu: [drm] fb0: mesondrmfb frame buffer device
 18095	[    5.738689] axg-sound-card sound: ASoC: no DMI vendor name!
 18096	[    6.463143] Adding 1859860k swap on /dev/zram0.  Priority:5 extents:1 across:1859860k SSFS
 18097	[    6.529008] zram1: detected capacity change from 0 to 52428800
 18098	[    7.557497] em28xx 1-2:1.0: EEPROM ID = 26 00 01 00, EEPROM hash = 0x8d0cfd04
 18099	[    7.557503] em28xx 1-2:1.0: EEPROM info:
 18100	[    7.557507] em28xx 1-2:1.0: 	microcode start address = 0x0004, boot configuration = 0x01
 18101	[    7.563611] em28xx 1-2:1.0: 	AC97 audio (5 sample rates)
 18102	[    7.563615] em28xx 1-2:1.0: 	500mA max power
 18103	[    7.563620] em28xx 1-2:1.0: 	Table at offset 0x27, strings=0x146a, 0x1888, 0x0a7e
 18104	[    7.623146] em28xx 1-2:1.0: Identified as PCTV tripleStick (292e) (card=94)
 18105	[    7.623153] em28xx 1-2:1.0: dvb set to isoc mode.
 18106	[    7.623374] usbcore: registered new interface driver em28xx
 18107	[    7.649510] em28xx 1-2:1.0: Binding DVB extension
 18108	[    7.662797] i2c i2c-4: Added multiplexed i2c bus 5
 18109	[    7.662806] si2168 4-0064: Silicon Labs Si2168-B40 successfully identified
 18110	[    7.662808] si2168 4-0064: firmware version: B 4.0.2
 18111	[    7.673803] si2157 5-0060: Silicon Labs Si2147/2148/2157/2158 successfully attached
 18112	[    7.673842] dvbdev: DVB: registering new adapter (1-2:1.0)
 18113	[    7.673848] em28xx 1-2:1.0: DVB: registering adapter 0 frontend 0 (Silicon Labs Si2168)...
 18114	[    7.673854] dvbdev: dvb_create_media_entity: media entity 'Silicon Labs Si2168' registered.
 18115	[    7.674508] dvbdev: dvb_create_media_entity: media entity 'dvb-demux' registered.
 18116	[    7.675900] em28xx 1-2:1.0: DVB extension successfully initialized
 18117	[    7.675909] em28xx: Registered (Em28xx dvb Extension) extension
 18118	[    7.683843] em28xx 1-2:1.0: Registering input extension
 18119	[    7.719130] Registered IR keymap rc-pinnacle-pctv-hd
 18120	[    7.719386] rc rc1: PCTV tripleStick (292e) as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-2/1-2:1.0/rc/rc1
 18121	[    7.719492] rc rc1: lirc_dev: driver em28xx registered at minor = 1, scancode receiver, no transmitter
 18122	[    7.719552] input: PCTV tripleStick (292e) as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-2/1-2:1.0/rc/rc1/input1
 18123	[    7.719632] em28xx 1-2:1.0: Input extension successfully initialized
 18124	[    7.719636] em28xx: Registered (Em28xx Input Extension) extension
 18125	[    8.613898] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
 18126	[    8.613917] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
 18127	[    9.805086] systemd[1]: Started Armbian memory supported logging.
 18128	[    9.807474] systemd[1]: Starting Journal Service...
 18129	[    9.870548] systemd[1]: Started Journal Service.
 18130	[    9.895588] systemd-journald[1846]: Received request to flush runtime journal from PID 1
 18131
 18132	### armbian-release:
 18133
 18134	# PLEASE DO NOT EDIT THIS FILE
 18135	BOARD=odroidn2
 18136	BOARD_NAME="Odroid N2"
 18137	BOARDFAMILY=meson-g12b
 18138	BUILD_REPOSITORY_URL=https://github.com/armbian/build
 18139	BUILD_REPOSITORY_COMMIT=5f03d652
 18140	DISTRIBUTION_CODENAME=buster
 18141	DISTRIBUTION_STATUS=supported
 18142	VERSION=21.02.1
 18143	LINUXFAMILY=meson64
 18144	BRANCH=current
 18145	ARCH=arm64
 18146	IMAGE_TYPE=stable
 18147	BOARD_TYPE=conf
 18148	INITRD_ARCH=arm64
 18149	KERNEL_IMAGE_TYPE=Image
 18150
 18151	### boot environment:
 18152
 18153	verbosity=1
 18154	console=both
 18155	overlay_prefix=meson
 18156	rootdev=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c
 18157	rootfstype=ext4
 18158	usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
 18159
 18160	### lsusb:
 18161
 18162	Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc.
 18163	Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
 18164	Bus 001 Device 003: ID 2013:025f PCTV Systems
 18165	Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
 18166	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
 18167
 18168	### lscpu:
 18169
 18170	Architecture:        aarch64
 18171	Byte Order:          Little Endian
 18172	CPU(s):              6
 18173	On-line CPU(s) list: 0-5
 18174	Thread(s) per core:  1
 18175	Core(s) per socket:  3
 18176	Socket(s):           2
 18177	NUMA node(s):        1
 18178	Vendor ID:           ARM
 18179	Model:               4
 18180	Model name:          Cortex-A53
 18181	Stepping:            r0p4
 18182	CPU max MHz:         1992.0000
 18183	CPU min MHz:         100.0000
 18184	BogoMIPS:            48.00
 18185	L1d cache:           unknown size
 18186	L1i cache:           unknown size
 18187	L2 cache:            unknown size
 18188	NUMA node0 CPU(s):   0-5
 18189	Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 18190
 18191	### cpuinfo:
 18192
 18193	processor	: 0
 18194	BogoMIPS	: 48.00
 18195	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 18196	CPU implementer	: 0x41
 18197	CPU architecture: 8
 18198	CPU variant	: 0x0
 18199	CPU part	: 0xd03
 18200	CPU revision	: 4
 18201
 18202	processor	: 1
 18203	BogoMIPS	: 48.00
 18204	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 18205	CPU implementer	: 0x41
 18206	CPU architecture: 8
 18207	CPU variant	: 0x0
 18208	CPU part	: 0xd03
 18209	CPU revision	: 4
 18210
 18211	processor	: 2
 18212	BogoMIPS	: 48.00
 18213	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 18214	CPU implementer	: 0x41
 18215	CPU architecture: 8
 18216	CPU variant	: 0x0
 18217	CPU part	: 0xd09
 18218	CPU revision	: 2
 18219
 18220	processor	: 3
 18221	BogoMIPS	: 48.00
 18222	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 18223	CPU implementer	: 0x41
 18224	CPU architecture: 8
 18225	CPU variant	: 0x0
 18226	CPU part	: 0xd09
 18227	CPU revision	: 2
 18228
 18229	processor	: 4
 18230	BogoMIPS	: 48.00
 18231	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 18232	CPU implementer	: 0x41
 18233	CPU architecture: 8
 18234	CPU variant	: 0x0
 18235	CPU part	: 0xd09
 18236	CPU revision	: 2
 18237
 18238	processor	: 5
 18239	BogoMIPS	: 48.00
 18240	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 18241	CPU implementer	: 0x41
 18242	CPU architecture: 8
 18243	CPU variant	: 0x0
 18244	CPU part	: 0xd09
 18245	CPU revision	: 2
 18246
 18247
 18248	### meminfo:
 18249
 18250	MemTotal:        3719728 kB
 18251	MemFree:         3397544 kB
 18252	MemAvailable:    3352492 kB
 18253	Buffers:           11700 kB
 18254	Cached:            47116 kB
 18255	SwapCached:            0 kB
 18256	Active:            29092 kB
 18257	Inactive:         180244 kB
 18258	Active(anon):        128 kB
 18259	Inactive(anon):   155668 kB
 18260	Active(file):      28964 kB
 18261	Inactive(file):    24576 kB
 18262	Unevictable:           0 kB
 18263	Mlocked:               0 kB
 18264	SwapTotal:       1859860 kB
 18265	SwapFree:        1859860 kB
 18266	Dirty:              7404 kB
 18267	Writeback:             0 kB
 18268	AnonPages:        150772 kB
 18269	Mapped:            12940 kB
 18270	Shmem:              4984 kB
 18271	KReclaimable:      13072 kB
 18272	Slab:              40464 kB
 18273	SReclaimable:      13072 kB
 18274	SUnreclaim:        27392 kB
 18275	KernelStack:        2592 kB
 18276	PageTables:         6048 kB
 18277	NFS_Unstable:          0 kB
 18278	Bounce:                0 kB
 18279	WritebackTmp:          0 kB
 18280	CommitLimit:     3719724 kB
 18281	Committed_AS:    4240264 kB
 18282	VmallocTotal:   135290159040 kB
 18283	VmallocUsed:       33248 kB
 18284	VmallocChunk:          0 kB
 18285	Percpu:             1368 kB
 18286	HardwareCorrupted:     0 kB
 18287	AnonHugePages:         0 kB
 18288	ShmemHugePages:        0 kB
 18289	ShmemPmdMapped:        0 kB
 18290	FileHugePages:         0 kB
 18291	FilePmdMapped:         0 kB
 18292	CmaTotal:         917504 kB
 18293	CmaFree:          901724 kB
 18294	HugePages_Total:       0
 18295	HugePages_Free:        0
 18296	HugePages_Rsvd:        0
 18297	HugePages_Surp:        0
 18298	Hugepagesize:       2048 kB
 18299	Hugetlb:               0 kB
 18300
 18301	### virtual memory:
 18302
 18303	vm.admin_reserve_kbytes = 8192
 18304	vm.block_dump = 0
 18305	vm.compaction_proactiveness = 20
 18306	vm.compact_unevictable_allowed = 1
 18307	vm.dirty_background_bytes = 0
 18308	vm.dirty_background_ratio = 10
 18309	vm.dirty_bytes = 0
 18310	vm.dirty_expire_centisecs = 3000
 18311	vm.dirty_ratio = 20
 18312	vm.dirtytime_expire_seconds = 43200
 18313	vm.dirty_writeback_centisecs = 500
 18314	vm.extfrag_threshold = 500
 18315	vm.hugetlb_shm_group = 0
 18316	vm.laptop_mode = 0
 18317	vm.legacy_va_layout = 0
 18318	vm.lowmem_reserve_ratio = 256	256	32	0
 18319	vm.max_map_count = 65530
 18320	vm.memory_failure_early_kill = 0
 18321	vm.memory_failure_recovery = 1
 18322	vm.min_free_kbytes = 45056
 18323	vm.min_slab_ratio = 5
 18324	vm.min_unmapped_ratio = 1
 18325	vm.mmap_min_addr = 4096
 18326	vm.mmap_rnd_bits = 18
 18327	vm.mmap_rnd_compat_bits = 11
 18328	vm.nr_hugepages = 0
 18329	vm.nr_hugepages_mempolicy = 0
 18330	vm.nr_overcommit_hugepages = 0
 18331	vm.numa_stat = 1
 18332	vm.numa_zonelist_order = Node
 18333	vm.oom_dump_tasks = 1
 18334	vm.oom_kill_allocating_task = 0
 18335	vm.overcommit_kbytes = 0
 18336	vm.overcommit_memory = 0
 18337	vm.overcommit_ratio = 50
 18338	vm.page-cluster = 0
 18339	vm.page_lock_unfairness = 5
 18340	vm.panic_on_oom = 0
 18341	vm.percpu_pagelist_fraction = 0
 18342	vm.stat_interval = 1
 18343	vm.swappiness = 100
 18344	vm.user_reserve_kbytes = 115026
 18345	vm.vfs_cache_pressure = 100
 18346	vm.watermark_boost_factor = 15000
 18347	vm.watermark_scale_factor = 10
 18348	vm.zone_reclaim_mode = 0
 18349
 18350	### ip addr:
 18351
 18352	1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
 18353	    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
 18354	    inet XXX.XXX.0.1/8 scope host lo
 18355	       valid_lft forever preferred_lft forever
 18356	    inet6 ::1/128 scope host
 18357	       valid_lft forever preferred_lft forever
 18358	2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
 18359	    link/ether 00:1e:06:42:03:f8 brd ff:ff:ff:ff:ff:ff
 18360
 18361	### partitions:
 18362
 18363	major minor  #blocks  name
 18364
 18365	 179        0   31464960 mmcblk0
 18366	 179        1   31146208 mmcblk0p1
 18367	 252        0    1859864 zram0
 18368	 252        1      51200 zram1
 18369
 18370	### df:
 18371
 18372	udev            1.4G     0  1.4G   0% /dev
 18373	tmpfs           364M  4.9M  359M   2% /run
 18374	/dev/mmcblk0p1   30G  1.8G   28G   6% /
 18375	tmpfs           1.8G     0  1.8G   0% /dev/shm
 18376	tmpfs           5.0M  4.0K  5.0M   1% /run/lock
 18377	tmpfs           1.8G     0  1.8G   0% /sys/fs/cgroup
 18378	tmpfs           1.8G     0  1.8G   0% /tmp
 18379	/dev/zram1       49M  7.3M   38M  17% /var/log
 18380
 18381	### lsblk:
 18382
 18383	NAME        FSTYPE  SIZE MOUNTPOINT UUID
 18384	mmcblk0              30G
 18385	└─mmcblk0p1 ext4   29.7G /          bd34953d-41be-49d6-b1c0-c0c28a5e239c
 18386	zram1                50M /var/log
 18387
 18388	### zramctl:
 18389
 18390	NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
 18391	/dev/zram1 zstd           50M  132K  698B   36K       6 /var/log
 18392	/dev/zram0 lzo-rle       1.8G    4K   74B   12K       6 [SWAP]
 18393
 18394	### mtab:
 18395
 18396	/dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
 18397	/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
 18398	/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
 18399
 18400	### mmc0:b368 info:
 18401
 18402	               fwrev: 0x0
 18403	              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=CBADS MODALIAS=mmc:block
 18404	                 cid: 6f0303434241445310aa002b4d013b00
 18405	                 rca: 0xb368
 18406	                 csd: 400e005a5b590000f00e7f800a404000
 18407	              manfid: 0x00006f
 18408	                 ocr: 0x00200000
 18409	preferred_erase_size: 2097152
 18410	                type: SD
 18411	               hwrev: 0x1
 18412	                date: 11/2019
 18413	                 dsr: 0x404
 18414	          erase_size: 512
 18415	               oemid: 0x0303
 18416	              serial: 0xaa002b4d
 18417	                 ssr: 00000000000000280402800100fd180a001e00000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
 18418	                 scr: 02b5800300000000
 18419	                name: CBADS
 18420
 18421	### Boot system health:
 18422
 18423	Time       big.LITTLE   load %cpu %sys %usr %nice %io %irq   CPU  C.St.
 18424	14:49:12: 1908/1992MHz  2.90  25%  11%   5%   0%   8%   0% 26.3°C  0/11
 18425	14:49:13: 1908/1992MHz  2.90  75%  21%   1%   0%  51%   0% 22.3°C  0/11
 18426	14:49:13: 1908/1992MHz  2.90  64%  10%   8%   1%  43%   1% 22.6°C  0/11
 18427	14:49:13: 1908/1992MHz  2.90  50%   5%   3%   0%  41%   0% 21.8°C  0/11
 18428	14:49:14: 1908/1992MHz  2.90  53%   2%   4%   0%  46%   0% 21.6°C  0/11
 18429
 18430	### Activated 1 lzo-rle zram swap devices with 1816 MB each
 18431
 18432	### Activated Armbian ramlog partition with zstd compression
 18433
 18434	Wed 24 Feb 2021 04:03:32 PM GMT | Odroid N2 | 21.02.1 | arm64 | aarch64 | 5.10.12-meson64
 18435
 18436	### dmesg:
 18437
 18438	[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
 18439	[    0.000000] Linux version 5.10.12-meson64 (root@beast) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #21.02.1 SMP PREEMPT Wed Feb 3 21:06:36 CET 2021
 18440	[    0.000000] Machine model: Hardkernel ODROID-N2
 18441	[    0.000000] efi: UEFI not found.
 18442	[    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
 18443	[    0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB
 18444	[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
 18445	[    0.000000] NUMA: No NUMA configuration found
 18446	[    0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ed7fffff]
 18447	[    0.000000] NUMA: NODE_DATA [mem 0xb502f100-0xb5030fff]
 18448	[    0.000000] Zone ranges:
 18449	[    0.000000]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
 18450	[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000ed7fffff]
 18451	[    0.000000]   Normal   empty
 18452	[    0.000000] Movable zone start for each node
 18453	[    0.000000] Early memory node ranges
 18454	[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000004ffffff]
 18455	[    0.000000]   node   0: [mem 0x0000000005300000-0x00000000ed7fffff]
 18456	[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ed7fffff]
 18457	[    0.000000] On node 0 totalpages: 972032
 18458	[    0.000000]   DMA zone: 4096 pages used for memmap
 18459	[    0.000000]   DMA zone: 0 pages reserved
 18460	[    0.000000]   DMA zone: 261376 pages, LIFO batch:63
 18461	[    0.000000]   DMA32 zone: 11104 pages used for memmap
 18462	[    0.000000]   DMA32 zone: 710656 pages, LIFO batch:63
 18463	[    0.000000] psci: probing for conduit method from DT.
 18464	[    0.000000] psci: PSCIv1.0 detected in firmware.
 18465	[    0.000000] psci: Using standard PSCI v0.2 function IDs
 18466	[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
 18467	[    0.000000] psci: SMC Calling Convention v1.1
 18468	[    0.000000] percpu: Embedded 23 pages/cpu s56728 r8192 d29288 u94208
 18469	[    0.000000] pcpu-alloc: s56728 r8192 d29288 u94208 alloc=23*4096
 18470	[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
 18471	[    0.000000] Detected VIPT I-cache on CPU0
 18472	[    0.000000] CPU features: detected: ARM erratum 845719
 18473	[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 956832
 18474	[    0.000000] Policy zone: DMA32
 18475	[    0.000000] Kernel command line: root=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c rootwait rootfstype=ext4 console=ttyAML0,115200n8 console=tty1 loglevel=1  no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=custombuilt cvbsmode=576cvbs max_freq_a53=1896 max_freq_a73=1800 maxcpus=6 voutmode=hdmi modeline=1920,1080,148500,56250,50,1920,2448,2492,2640,1080,1084,1089,1125,1,1,1 disablehpd=false  cvbscable= overscan=100 consoleblank=0
 18476	[    0.000000] Kernel parameter elevator= does not have any effect anymore.
 18477	               Please use sysfs to set IO scheduler for individual devices.
 18478	[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
 18479	[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
 18480	[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
 18481	[    0.000000] software IO TLB: mapped [mem 0x0000000038ac5000-0x000000003cac5000] (64MB)
 18482	[    0.000000] Memory: 2785352K/3888128K available (14144K kernel code, 1760K rwdata, 5508K rodata, 3328K init, 592K bss, 185272K reserved, 917504K cma-reserved)
 18483	[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
 18484	[    0.000000] rcu: Preemptible hierarchical RCU implementation.
 18485	[    0.000000] rcu: 	RCU event tracing is enabled.
 18486	[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
 18487	[    0.000000] 	Trampoline variant of Tasks RCU enabled.
 18488	[    0.000000] 	Rude variant of Tasks RCU enabled.
 18489	[    0.000000] 	Tracing variant of Tasks RCU enabled.
 18490	[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
 18491	[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
 18492	[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
 18493	[    0.000000] GIC: Using split EOI/Deactivate mode
 18494	[    0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized
 18495	[    0.000000] random: get_random_bytes called from start_kernel+0x378/0x538 with crng_init=0
 18496	[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
 18497	[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
 18498	[    0.000003] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
 18499	[    0.000241] Console: colour dummy device 80x25
 18500	[    0.000275] printk: console [tty1] enabled
 18501	[    0.000362] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
 18502	[    0.000374] pid_max: default: 32768 minimum: 301
 18503	[    0.000459] LSM: Security Framework initializing
 18504	[    0.000485] Yama: becoming mindful.
 18505	[    0.000576] AppArmor: AppArmor initialized
 18506	[    0.000626] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
 18507	[    0.000645] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
 18508	[    0.002639] rcu: Hierarchical SRCU implementation.
 18509	[    0.004987] EFI services will not be available.
 18510	[    0.005410] smp: Bringing up secondary CPUs ...
 18511	[    0.006077] Detected VIPT I-cache on CPU1
 18512	[    0.006139] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
 18513	[    0.007330] CPU features: detected: ARM erratum 858921
 18514	[    0.007338] CPU features: detected: Spectre-v2
 18515	[    0.007341] CPU features: detected: Spectre-v4
 18516	[    0.007347] Detected VIPT I-cache on CPU2
 18517	[    0.007375] arch_timer: Enabling local workaround for ARM erratum 858921
 18518	[    0.007388] arch_timer: CPU2: Trapping CNTVCT access
 18519	[    0.007401] CPU2: Booted secondary processor 0x0000000100 [0x410fd092]
 18520	[    0.008107] Detected VIPT I-cache on CPU3
 18521	[    0.008123] arch_timer: Enabling local workaround for ARM erratum 858921
 18522	[    0.008130] arch_timer: CPU3: Trapping CNTVCT access
 18523	[    0.008138] CPU3: Booted secondary processor 0x0000000101 [0x410fd092]
 18524	[    0.008767] Detected VIPT I-cache on CPU4
 18525	[    0.008783] arch_timer: Enabling local workaround for ARM erratum 858921
 18526	[    0.008790] arch_timer: CPU4: Trapping CNTVCT access
 18527	[    0.008798] CPU4: Booted secondary processor 0x0000000102 [0x410fd092]
 18528	[    0.009413] Detected VIPT I-cache on CPU5
 18529	[    0.009429] arch_timer: Enabling local workaround for ARM erratum 858921
 18530	[    0.009436] arch_timer: CPU5: Trapping CNTVCT access
 18531	[    0.009444] CPU5: Booted secondary processor 0x0000000103 [0x410fd092]
 18532	[    0.009523] smp: Brought up 1 node, 6 CPUs
 18533	[    0.009541] SMP: Total of 6 processors activated.
 18534	[    0.009548] CPU features: detected: 32-bit EL0 Support
 18535	[    0.009555] CPU features: detected: CRC32 instructions
 18536	[    0.009560] CPU features: detected: 32-bit EL1 Support
 18537	[    0.020808] CPU: All CPU(s) started at EL2
 18538	[    0.020857] alternatives: patching kernel code
 18539	[    0.022803] devtmpfs: initialized
 18540	[    0.030468] Registered cp15_barrier emulation handler
 18541	[    0.030482] Registered setend emulation handler
 18542	[    0.030619] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
 18543	[    0.030657] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
 18544	[    0.044531] pinctrl core: initialized pinctrl subsystem
 18545	[    0.045110] DMI not present or invalid.
 18546	[    0.045484] NET: Registered protocol family 16
 18547	[    0.047013] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
 18548	[    0.047285] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
 18549	[    0.047522] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
 18550	[    0.047564] audit: initializing netlink subsys (disabled)
 18551	[    0.047663] audit: type=2000 audit(0.044:1): state=initialized audit_enabled=0 res=1
 18552	[    0.048976] thermal_sys: Registered thermal governor 'fair_share'
 18553	[    0.048983] thermal_sys: Registered thermal governor 'bang_bang'
 18554	[    0.048987] thermal_sys: Registered thermal governor 'step_wise'
 18555	[    0.048990] thermal_sys: Registered thermal governor 'user_space'
 18556	[    0.049409] cpuidle: using governor menu
 18557	[    0.049757] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
 18558	[    0.049876] ASID allocator initialised with 65536 entries
 18559	[    0.050789] Serial: AMBA PL011 UART driver
 18560	[    0.084583] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
 18561	[    0.084594] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
 18562	[    0.084598] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
 18563	[    0.084603] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
 18564	[    0.086860] cryptd: max_cpu_qlen set to 1000
 18565	[    0.156169] raid6: neonx8   gen()  2786 MB/s
 18566	[    0.224228] raid6: neonx8   xor()  2042 MB/s
 18567	[    0.292336] raid6: neonx4   gen()  3001 MB/s
 18568	[    0.360440] raid6: neonx4   xor()  1589 MB/s
 18569	[    0.428486] raid6: neonx2   gen()  2080 MB/s
 18570	[    0.496538] raid6: neonx2   xor()  2211 MB/s
 18571	[    0.564613] raid6: neonx1   gen()  2014 MB/s
 18572	[    0.632677] raid6: neonx1   xor()  1718 MB/s
 18573	[    0.700749] raid6: int64x8  gen()  1374 MB/s
 18574	[    0.768805] raid6: int64x8  xor()   735 MB/s
 18575	[    0.836888] raid6: int64x4  gen()  1463 MB/s
 18576	[    0.904948] raid6: int64x4  xor()   733 MB/s
 18577	[    0.973000] raid6: int64x2  gen()  1362 MB/s
 18578	[    1.041075] raid6: int64x2  xor()   619 MB/s
 18579	[    1.109144] raid6: int64x1  gen()  1120 MB/s
 18580	[    1.177198] raid6: int64x1  xor()   462 MB/s
 18581	[    1.177202] raid6: using algorithm neonx4 gen() 3001 MB/s
 18582	[    1.177205] raid6: .... xor() 1589 MB/s, rmw enabled
 18583	[    1.177209] raid6: using neon recovery algorithm
 18584	[    1.177647] ACPI: Interpreter disabled.
 18585	[    1.178470] 5V: supplied by 12V
 18586	[    1.179377] VDDAO_3V3: supplied by 12V
 18587	[    1.179842] iommu: Default domain type: Translated
 18588	[    1.179972] vgaarb: loaded
 18589	[    1.180982] SCSI subsystem initialized
 18590	[    1.181280] usbcore: registered new interface driver usbfs
 18591	[    1.181317] usbcore: registered new interface driver hub
 18592	[    1.181355] usbcore: registered new device driver usb
 18593	[    1.181598] pps_core: LinuxPPS API ver. 1 registered
 18594	[    1.181602] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
 18595	[    1.181622] PTP clock support registered
 18596	[    1.181811] EDAC MC: Ver: 3.0.0
 18597	[    1.183176] NetLabel: Initializing
 18598	[    1.183183] NetLabel:  domain hash size = 128
 18599	[    1.183186] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
 18600	[    1.183229] NetLabel:  unlabeled traffic allowed by default
 18601	[    1.183660] clocksource: Switched to clocksource arch_sys_counter
 18602	[    1.183874] VFS: Disk quotas dquot_6.6.0
 18603	[    1.183920] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
 18604	[    1.184280] AppArmor: AppArmor Filesystem Enabled
 18605	[    1.184387] pnp: PnP ACPI: disabled
 18606	[    1.189958] NET: Registered protocol family 2
 18607	[    1.190460] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
 18608	[    1.190535] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
 18609	[    1.190792] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
 18610	[    1.190980] TCP: Hash tables configured (established 32768 bind 32768)
 18611	[    1.191128] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
 18612	[    1.191193] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
 18613	[    1.191239] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
 18614	[    1.191382] NET: Registered protocol family 1
 18615	[    1.191405] PCI: CLS 0 bytes, default 64
 18616	[    1.191537] Trying to unpack rootfs image as initramfs...
 18617	[    1.727339] Freeing initrd memory: 13544K
 18618	[    1.728257] kvm [1]: IPA Size Limit: 40 bits
 18619	[    1.728968] kvm [1]: vgic interrupt IRQ9
 18620	[    1.729100] kvm [1]: Hyp mode initialized successfully
 18621	[    1.732918] Initialise system trusted keyrings
 18622	[    1.732950] Key type blacklist registered
 18623	[    1.733046] workingset: timestamp_bits=44 max_order=20 bucket_order=0
 18624	[    1.736271] zbud: loaded
 18625	[    1.737229] squashfs: version 4.0 (2009/01/31) Phillip Lougher
 18626	[    1.737680] fuse: init (API version 7.32)
 18627	[    1.738453] integrity: Platform Keyring initialized
 18628	[    1.765902] xor: measuring software checksum speed
 18629	[    1.768752]    8regs           :  3473 MB/sec
 18630	[    1.771201]    32regs          :  4022 MB/sec
 18631	[    1.773849]    arm64_neon      :  3727 MB/sec
 18632	[    1.773852] xor: using function: 32regs (4022 MB/sec)
 18633	[    1.773858] Key type asymmetric registered
 18634	[    1.773862] Asymmetric key parser 'x509' registered
 18635	[    1.773895] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
 18636	[    1.773981] io scheduler mq-deadline registered
 18637	[    1.773985] io scheduler kyber registered
 18638	[    1.774067] io scheduler bfq registered
 18639	[    1.776571] gpio-447 (usb-hub-reset): hogged as output/high
 18640	[    1.779397] EINJ: ACPI disabled.
 18641	[    1.785456] soc soc0: Amlogic Meson G12B (S922X) Revision 29:a (40:2) Detected
 18642	[    1.786810] VCC_3V3: supplied by VDDAO_3V3
 18643	[    1.786858] FLASH_1V8: supplied by VCC_3V3
 18644	[    1.786889] VCC_1V8: supplied by VCC_3V3
 18645	[    1.786915] VDDAO_1V8: supplied by VDDAO_3V3
 18646	[    1.786944] VDDCPU_A: supplied by regulator-dummy
 18647	[    1.787297] VDDCPU_B: supplied by regulator-dummy
 18648	[    1.788007] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
 18649	[    1.790143] Serial: AMBA driver
 18650	[    1.790419] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart
 18651	[    1.790514] printk: console [ttyAML0] enabled
 18652	[    1.791036] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 33, base_baud = 1500000) is a meson_uart
 18653	[    1.796341] loop: module loaded
 18654	[    1.798280] libphy: Fixed MDIO Bus: probed
 18655	[    1.799399] tun: Universal TUN/TAP device driver, 1.6
 18656	[    1.800074] thunder_xcv, ver 1.0
 18657	[    1.800106] thunder_bgx, ver 1.0
 18658	[    1.800132] nicpf, ver 1.0
 18659	[    1.800573] e1000e: Intel(R) PRO/1000 Network Driver
 18660	[    1.800577] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
 18661	[    1.800616] igb: Intel(R) Gigabit Ethernet Network Driver
 18662	[    1.800620] igb: Copyright (c) 2007-2014 Intel Corporation.
 18663	[    1.800650] igbvf: Intel(R) Gigabit Virtual Function Network Driver
 18664	[    1.800654] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
 18665	[    1.800778] sky2: driver version 1.30
 18666	[    1.801134] VFIO - User Level meta-driver version: 0.3
 18667	[    1.802447] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
 18668	[    1.802468] ehci-pci: EHCI PCI platform driver
 18669	[    1.802502] ehci-platform: EHCI generic platform driver
 18670	[    1.802630] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
 18671	[    1.802640] ohci-pci: OHCI PCI platform driver
 18672	[    1.802671] ohci-platform: OHCI generic platform driver
 18673	[    1.803045] usbcore: registered new interface driver usb-storage
 18674	[    1.804352] mousedev: PS/2 mouse device common for all mice
 18675	[    1.804719] i2c /dev entries driver
 18676	[    1.809752] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17
 18677	[    1.810407] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz
 18678	[    1.811091] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-1 failed:-17
 18679	[    1.811713] sdhci: Secure Digital Host Controller Interface driver
 18680	[    1.811723] sdhci: Copyright(c) Pierre Ossman
 18681	[    1.811855] Synopsys Designware Multimedia Card Interface Driver
 18682	[    1.812358] sdhci-pltfm: SDHCI platform and OF driver helper
 18683	[    1.813200] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq
 18684	[    1.813608] ledtrig-cpu: registered to indicate activity on CPUs
 18685	[    1.813871] meson-sm: secure-monitor enabled
 18686	[    1.814027] hid: raw HID events driver (C) Jiri Kosina
 18687	[    1.814109] usbcore: registered new interface driver usbhid
 18688	[    1.814112] usbhid: USB HID core driver
 18689	[    1.815045] NET: Registered protocol family 10
 18690	[    1.815562] Segment Routing with IPv6
 18691	[    1.815590] NET: Registered protocol family 17
 18692	[    1.815676] 8021q: 802.1Q VLAN Support v1.8
 18693	[    1.815703] Key type dns_resolver registered
 18694	[    1.816051] registered taskstats version 1
 18695	[    1.816057] Loading compiled-in X.509 certificates
 18696	[    1.817786] Loaded X.509 cert 'Build time autogenerated kernel key: f47c178852ca39740c3546b008122b65f5ed9bce'
 18697	[    1.819392] zswap: loaded using pool zstd/z3fold
 18698	[    1.819576] Key type ._fscrypt registered
 18699	[    1.819578] Key type .fscrypt registered
 18700	[    1.819580] Key type fscrypt-provisioning registered
 18701	[    1.820871] Btrfs loaded, crc32c=crc32c-generic
 18702	[    1.826839] Key type encrypted registered
 18703	[    1.826850] AppArmor: AppArmor sha1 policy hashing enabled
 18704	[    1.833147] HUB_5V: supplied by 5V
 18705	[    1.833351] USB_PWR_EN: supplied by 5V
 18706	[    1.834967] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2
 18707	[    1.834973] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1
 18708	[    1.837685] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator
 18709	[    1.837741] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator
 18710	[    1.837848] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM
 18711	[    1.838405] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
 18712	[    1.838417] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
 18713	[    1.838504] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010
 18714	[    1.838520] xhci-hcd xhci-hcd.0.auto: irq 41, io mem 0xff500000
 18715	[    1.838640] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
 18716	[    1.838643] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 18717	[    1.838646] usb usb1: Product: xHCI Host Controller
 18718	[    1.838648] usb usb1: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
 18719	[    1.838651] usb usb1: SerialNumber: xhci-hcd.0.auto
 18720	[    1.838838] hub 1-0:1.0: USB hub found
 18721	[    1.838853] hub 1-0:1.0: 2 ports detected
 18722	[    1.838984] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
 18723	[    1.838989] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
 18724	[    1.838995] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
 18725	[    1.839016] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
 18726	[    1.839051] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
 18727	[    1.839054] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 18728	[    1.839057] usb usb2: Product: xHCI Host Controller
 18729	[    1.839059] usb usb2: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
 18730	[    1.839061] usb usb2: SerialNumber: xhci-hcd.0.auto
 18731	[    1.839207] hub 2-0:1.0: USB hub found
 18732	[    1.839218] hub 2-0:1.0: 1 port detected
 18733	[    1.840821] meson-gx-mmc ffe05000.sd: Got CD GPIO
 18734	[    1.868762] Freeing unused kernel memory: 3328K
 18735	[    1.891747] Run /init as init process
 18736	[    1.891751]   with arguments:
 18737	[    1.891753]     /init
 18738	[    1.891755]   with environment:
 18739	[    1.891757]     HOME=/
 18740	[    1.891758]     TERM=linux
 18741	[    1.891760]     hdmimode=custombuilt
 18742	[    1.891761]     cvbsmode=576cvbs
 18743	[    1.891763]     max_freq_a53=1896
 18744	[    1.891764]     max_freq_a73=1800
 18745	[    1.891766]     voutmode=hdmi
 18746	[    1.891767]     modeline=1920,1080,148500,56250,50,1920,2448,2492,2640,1080,1084,1089,1125,1,1,1
 18747	[    1.891769]     disablehpd=false
 18748	[    1.891770]     cvbscable=
 18749	[    1.891772]     overscan=100
 18750	[    1.934719] mmc0: new ultra high speed SDR25 SDHC card at address b368
 18751	[    1.935311] mmcblk0: mmc0:b368 CBADS 30.0 GiB
 18752	[    1.937050]  mmcblk0: p1
 18753	[    2.064803] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found
 18754	[    2.064810] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found
 18755	[    2.064893] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock
 18756	[    2.065363] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37
 18757	[    2.065375] meson8b-dwmac ff3f0000.ethernet: 	DWMAC1000
 18758	[    2.065379] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported
 18759	[    2.065383] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported
 18760	[    2.065386] meson8b-dwmac ff3f0000.ethernet: COE Type 2
 18761	[    2.065389] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported
 18762	[    2.065392] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported
 18763	[    2.065478] meson8b-dwmac ff3f0000.ethernet: Normal descriptors
 18764	[    2.065483] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled
 18765	[    2.065486] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
 18766	[    2.065829] libphy: stmmac: probed
 18767	[    2.069971] libphy: mdio_mux: probed
 18768	[    2.074523] meson-vrtc ff8000a8.rtc: registered as rtc1
 18769	[    2.095413] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
 18770	[    2.095591] rtc-pcf8563 1-0051: registered as rtc0
 18771	[    2.096779] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
 18772	[    2.096790] rtc-pcf8563 1-0051: hctosys: unable to read the hardware clock
 18773	[    2.103208] random: fast init done
 18774	[    2.171781] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
 18775	[    2.196412] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.04
 18776	[    2.196419] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
 18777	[    2.196422] usb 2-1: Product: USB3.1 Hub
 18778	[    2.196424] usb 2-1: Manufacturer: GenesysLogic
 18779	[    2.223254] hub 2-1:1.0: USB hub found
 18780	[    2.223544] hub 2-1:1.0: 4 ports detected
 18781	[    2.276268] libphy: mdio_mux: probed
 18782	[    2.319685] usb 1-1: new high-speed USB device number 2 using xhci-hcd
 18783	[    2.469962] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.04
 18784	[    2.469969] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
 18785	[    2.469973] usb 1-1: Product: USB2.1 Hub
 18786	[    2.469976] usb 1-1: Manufacturer: GenesysLogic
 18787	[    2.511291] hub 1-1:1.0: USB hub found
 18788	[    2.511554] hub 1-1:1.0: 4 ports detected
 18789	[    2.703673] usb 1-2: new high-speed USB device number 3 using xhci-hcd
 18790	[    2.852120] usb 1-2: New USB device found, idVendor=2013, idProduct=025f, bcdDevice= 1.00
 18791	[    2.852126] usb 1-2: New USB device strings: Mfr=3, Product=1, SerialNumber=2
 18792	[    2.852130] usb 1-2: Product: PCTV 292e
 18793	[    2.852133] usb 1-2: Manufacturer: PCTV
 18794	[    2.852136] usb 1-2: SerialNumber: 0011356964
 18795	[    3.160638] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
 18796	[    3.959680] systemd[1]: System time before build time, advancing clock.
 18797	[    3.974510] systemd[1]: Inserted module 'autofs4'
 18798	[    4.021103] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
 18799	[    4.021336] systemd[1]: Detected architecture arm64.
 18800	[    4.053428] systemd[1]: Set hostname to <odroidn2>.
 18801	[    4.381161] random: systemd: uninitialized urandom read (16 bytes read)
 18802	[    4.384670] random: systemd: uninitialized urandom read (16 bytes read)
 18803	[    4.384885] systemd[1]: Listening on Journal Audit Socket.
 18804	[    4.385097] random: systemd: uninitialized urandom read (16 bytes read)
 18805	[    4.385263] systemd[1]: Listening on Journal Socket (/dev/log).
 18806	[    4.385452] systemd[1]: Listening on udev Kernel Socket.
 18807	[    4.385529] systemd[1]: Reached target Swap.
 18808	[    4.385668] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
 18809	[    4.385899] systemd[1]: Listening on Journal Socket.
 18810	[    4.388075] systemd[1]: Starting Nameserver information manager...
 18811	[    4.438579] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
 18812	[    5.005406] pwm-gpio pwmgpio: 1 gpio pwms loaded
 18813	[    5.012697] zram: Added device: zram0
 18814	[    5.013094] zram: Added device: zram1
 18815	[    5.013431] zram: Added device: zram2
 18816	[    5.158381] meson-saradc ff809000.adc: supply vref not found, using dummy regulator
 18817	[    5.178336] mc: Linux media interface: v0.10
 18818	[    5.228065] panfrost ffe40000.gpu: clock rate = 24000000
 18819	[    5.228138] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19
 18820	[    5.228938] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0
 18821	[    5.228947] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400
 18822	[    5.228952] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
 18823	[    5.228956] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1
 18824	[    5.243429] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 0
 18825	[    5.254526] videodev: Linux video capture interface: v2.00
 18826	[    5.263703] Registered IR keymap rc-odroid
 18827	[    5.279348] meson-drm ff900000.vpu: Queued 2 outputs on vpu
 18828	[    5.280487] IR NEC protocol handler initialized
 18829	[    5.311759] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0
 18830	[    5.311867] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
 18831	[    5.311923] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input0
 18832	[    5.312096] meson-ir ff808000.ir: receiver initialized
 18833	[    5.361024] meson-drm ff900000.vpu: CVBS Output connector not available
 18834	[    5.387722] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
 18835	[    5.389716] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
 18836	[    5.389963] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
 18837	[    5.390171] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 1
 18838	[    5.422839] zram0: detected capacity change from 0 to 1904500736
 18839	[    5.431025] em28xx 1-2:1.0: New device PCTV PCTV 292e @ 480 Mbps (2013:025f, interface 0, class 0)
 18840	[    5.431032] em28xx 1-2:1.0: DVB interface 0 found: isoc
 18841	[    5.456934] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
 18842	[    5.675844] Console: switching to colour frame buffer device 240x67
 18843	[    5.710619] meson-drm ff900000.vpu: [drm] fb0: mesondrmfb frame buffer device
 18844	[    5.753124] axg-sound-card sound: ASoC: no DMI vendor name!
 18845	[    6.267700] em28xx 1-2:1.0: unknown em28xx chip ID (0)
 18846	[    6.463708] Adding 1859860k swap on /dev/zram0.  Priority:5 extents:1 across:1859860k SSFS
 18847	[    6.530360] zram1: detected capacity change from 0 to 52428800
 18848	[    7.355711] em28xx 1-2:1.0: reading from i2c device at 0xa0 failed (error=-5)
 18849	[    7.355717] em28xx 1-2:1.0: board has no eeprom
 18850	[    7.927657] em28xx 1-2:1.0: Identified as PCTV tripleStick (292e) (card=94)
 18851	[    7.927661] em28xx 1-2:1.0: dvb set to isoc mode.
 18852	[    7.927785] usbcore: registered new interface driver em28xx
 18853	[    7.954136] em28xx 1-2:1.0: Binding DVB extension
 18854	[    8.614445] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
 18855	[    8.614465] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
 18856	[    8.767747] em28xx 1-2:1.0: writing to i2c device at 0xc8 failed (error=-5)
 18857	[    8.767759] si2168 4-0064: probe failed = -5
 18858	[    8.767775] si2168: probe of 4-0064 failed with error -5
 18859	[    8.767790] em28xx: Registered (Em28xx dvb Extension) extension
 18860	[    8.779819] em28xx 1-2:1.0: Registering input extension
 18861	[    8.779837] em28xx: Registered (Em28xx Input Extension) extension
 18862	[    9.824728] systemd[1]: Started Armbian memory supported logging.
 18863	[    9.827039] systemd[1]: Starting Journal Service...
 18864	[    9.887227] systemd[1]: Started Journal Service.
 18865	[    9.912422] systemd-journald[1843]: Received request to flush runtime journal from PID 1
 18866
 18867	### armbian-release:
 18868
 18869	# PLEASE DO NOT EDIT THIS FILE
 18870	BOARD=odroidn2
 18871	BOARD_NAME="Odroid N2"
 18872	BOARDFAMILY=meson-g12b
 18873	BUILD_REPOSITORY_URL=https://github.com/armbian/build
 18874	BUILD_REPOSITORY_COMMIT=5f03d652
 18875	DISTRIBUTION_CODENAME=buster
 18876	DISTRIBUTION_STATUS=supported
 18877	VERSION=21.02.1
 18878	LINUXFAMILY=meson64
 18879	BRANCH=current
 18880	ARCH=arm64
 18881	IMAGE_TYPE=stable
 18882	BOARD_TYPE=conf
 18883	INITRD_ARCH=arm64
 18884	KERNEL_IMAGE_TYPE=Image
 18885
 18886	### boot environment:
 18887
 18888	verbosity=1
 18889	console=both
 18890	overlay_prefix=meson
 18891	rootdev=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c
 18892	rootfstype=ext4
 18893	usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
 18894
 18895	### lsusb:
 18896
 18897	Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc.
 18898	Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
 18899	Bus 001 Device 003: ID 2013:025f PCTV Systems
 18900	Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
 18901	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
 18902
 18903	### lscpu:
 18904
 18905	Architecture:        aarch64
 18906	Byte Order:          Little Endian
 18907	CPU(s):              6
 18908	On-line CPU(s) list: 0-5
 18909	Thread(s) per core:  1
 18910	Core(s) per socket:  3
 18911	Socket(s):           2
 18912	NUMA node(s):        1
 18913	Vendor ID:           ARM
 18914	Model:               4
 18915	Model name:          Cortex-A53
 18916	Stepping:            r0p4
 18917	CPU max MHz:         1992.0000
 18918	CPU min MHz:         100.0000
 18919	BogoMIPS:            48.00
 18920	L1d cache:           unknown size
 18921	L1i cache:           unknown size
 18922	L2 cache:            unknown size
 18923	NUMA node0 CPU(s):   0-5
 18924	Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 18925
 18926	### cpuinfo:
 18927
 18928	processor	: 0
 18929	BogoMIPS	: 48.00
 18930	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 18931	CPU implementer	: 0x41
 18932	CPU architecture: 8
 18933	CPU variant	: 0x0
 18934	CPU part	: 0xd03
 18935	CPU revision	: 4
 18936
 18937	processor	: 1
 18938	BogoMIPS	: 48.00
 18939	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 18940	CPU implementer	: 0x41
 18941	CPU architecture: 8
 18942	CPU variant	: 0x0
 18943	CPU part	: 0xd03
 18944	CPU revision	: 4
 18945
 18946	processor	: 2
 18947	BogoMIPS	: 48.00
 18948	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 18949	CPU implementer	: 0x41
 18950	CPU architecture: 8
 18951	CPU variant	: 0x0
 18952	CPU part	: 0xd09
 18953	CPU revision	: 2
 18954
 18955	processor	: 3
 18956	BogoMIPS	: 48.00
 18957	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 18958	CPU implementer	: 0x41
 18959	CPU architecture: 8
 18960	CPU variant	: 0x0
 18961	CPU part	: 0xd09
 18962	CPU revision	: 2
 18963
 18964	processor	: 4
 18965	BogoMIPS	: 48.00
 18966	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 18967	CPU implementer	: 0x41
 18968	CPU architecture: 8
 18969	CPU variant	: 0x0
 18970	CPU part	: 0xd09
 18971	CPU revision	: 2
 18972
 18973	processor	: 5
 18974	BogoMIPS	: 48.00
 18975	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 18976	CPU implementer	: 0x41
 18977	CPU architecture: 8
 18978	CPU variant	: 0x0
 18979	CPU part	: 0xd09
 18980	CPU revision	: 2
 18981
 18982
 18983	### meminfo:
 18984
 18985	MemTotal:        3719728 kB
 18986	MemFree:         3380644 kB
 18987	MemAvailable:    3336096 kB
 18988	Buffers:           11700 kB
 18989	Cached:            47552 kB
 18990	SwapCached:            0 kB
 18991	Active:            29376 kB
 18992	Inactive:         198616 kB
 18993	Active(anon):        104 kB
 18994	Inactive(anon):   173516 kB
 18995	Active(file):      29272 kB
 18996	Inactive(file):    25100 kB
 18997	Unevictable:           0 kB
 18998	Mlocked:               0 kB
 18999	SwapTotal:       1859860 kB
 19000	SwapFree:        1859860 kB
 19001	Dirty:              7760 kB
 19002	Writeback:             0 kB
 19003	AnonPages:        168920 kB
 19004	Mapped:            12916 kB
 19005	Shmem:              4876 kB
 19006	KReclaimable:      13248 kB
 19007	Slab:              40696 kB
 19008	SReclaimable:      13248 kB
 19009	SUnreclaim:        27448 kB
 19010	KernelStack:        2544 kB
 19011	PageTables:         5660 kB
 19012	NFS_Unstable:          0 kB
 19013	Bounce:                0 kB
 19014	WritebackTmp:          0 kB
 19015	CommitLimit:     3719724 kB
 19016	Committed_AS:    4240176 kB
 19017	VmallocTotal:   135290159040 kB
 19018	VmallocUsed:       31752 kB
 19019	VmallocChunk:          0 kB
 19020	Percpu:             1368 kB
 19021	HardwareCorrupted:     0 kB
 19022	AnonHugePages:         0 kB
 19023	ShmemHugePages:        0 kB
 19024	ShmemPmdMapped:        0 kB
 19025	FileHugePages:         0 kB
 19026	FilePmdMapped:         0 kB
 19027	CmaTotal:         917504 kB
 19028	CmaFree:          901724 kB
 19029	HugePages_Total:       0
 19030	HugePages_Free:        0
 19031	HugePages_Rsvd:        0
 19032	HugePages_Surp:        0
 19033	Hugepagesize:       2048 kB
 19034	Hugetlb:               0 kB
 19035
 19036	### virtual memory:
 19037
 19038	vm.admin_reserve_kbytes = 8192
 19039	vm.block_dump = 0
 19040	vm.compaction_proactiveness = 20
 19041	vm.compact_unevictable_allowed = 1
 19042	vm.dirty_background_bytes = 0
 19043	vm.dirty_background_ratio = 10
 19044	vm.dirty_bytes = 0
 19045	vm.dirty_expire_centisecs = 3000
 19046	vm.dirty_ratio = 20
 19047	vm.dirtytime_expire_seconds = 43200
 19048	vm.dirty_writeback_centisecs = 500
 19049	vm.extfrag_threshold = 500
 19050	vm.hugetlb_shm_group = 0
 19051	vm.laptop_mode = 0
 19052	vm.legacy_va_layout = 0
 19053	vm.lowmem_reserve_ratio = 256	256	32	0
 19054	vm.max_map_count = 65530
 19055	vm.memory_failure_early_kill = 0
 19056	vm.memory_failure_recovery = 1
 19057	vm.min_free_kbytes = 45056
 19058	vm.min_slab_ratio = 5
 19059	vm.min_unmapped_ratio = 1
 19060	vm.mmap_min_addr = 4096
 19061	vm.mmap_rnd_bits = 18
 19062	vm.mmap_rnd_compat_bits = 11
 19063	vm.nr_hugepages = 0
 19064	vm.nr_hugepages_mempolicy = 0
 19065	vm.nr_overcommit_hugepages = 0
 19066	vm.numa_stat = 1
 19067	vm.numa_zonelist_order = Node
 19068	vm.oom_dump_tasks = 1
 19069	vm.oom_kill_allocating_task = 0
 19070	vm.overcommit_kbytes = 0
 19071	vm.overcommit_memory = 0
 19072	vm.overcommit_ratio = 50
 19073	vm.page-cluster = 0
 19074	vm.page_lock_unfairness = 5
 19075	vm.panic_on_oom = 0
 19076	vm.percpu_pagelist_fraction = 0
 19077	vm.stat_interval = 1
 19078	vm.swappiness = 100
 19079	vm.user_reserve_kbytes = 115028
 19080	vm.vfs_cache_pressure = 100
 19081	vm.watermark_boost_factor = 15000
 19082	vm.watermark_scale_factor = 10
 19083	vm.zone_reclaim_mode = 0
 19084
 19085	### ip addr:
 19086
 19087	1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
 19088	    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
 19089	    inet XXX.XXX.0.1/8 scope host lo
 19090	       valid_lft forever preferred_lft forever
 19091	    inet6 ::1/128 scope host
 19092	       valid_lft forever preferred_lft forever
 19093	2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
 19094	    link/ether 00:1e:06:42:03:f8 brd ff:ff:ff:ff:ff:ff
 19095
 19096	### partitions:
 19097
 19098	major minor  #blocks  name
 19099
 19100	 179        0   31464960 mmcblk0
 19101	 179        1   31146208 mmcblk0p1
 19102	 252        0    1859864 zram0
 19103	 252        1      51200 zram1
 19104
 19105	### df:
 19106
 19107	udev            1.4G     0  1.4G   0% /dev
 19108	tmpfs           364M  4.9M  359M   2% /run
 19109	/dev/mmcblk0p1   30G  1.8G   28G   6% /
 19110	tmpfs           1.8G     0  1.8G   0% /dev/shm
 19111	tmpfs           5.0M  4.0K  5.0M   1% /run/lock
 19112	tmpfs           1.8G     0  1.8G   0% /sys/fs/cgroup
 19113	tmpfs           1.8G     0  1.8G   0% /tmp
 19114	/dev/zram1       49M  7.6M   38M  17% /var/log
 19115
 19116	### lsblk:
 19117
 19118	NAME        FSTYPE  SIZE MOUNTPOINT UUID
 19119	mmcblk0              30G
 19120	└─mmcblk0p1 ext4   29.7G /          bd34953d-41be-49d6-b1c0-c0c28a5e239c
 19121	zram1                50M /var/log
 19122
 19123	### zramctl:
 19124
 19125	NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
 19126	/dev/zram1 zstd           50M  132K  698B   36K       6 /var/log
 19127	/dev/zram0 lzo-rle       1.8G    4K   74B   12K       6 [SWAP]
 19128
 19129	### mtab:
 19130
 19131	/dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
 19132	/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
 19133	/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
 19134
 19135	### mmc0:b368 info:
 19136
 19137	               fwrev: 0x0
 19138	              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=CBADS MODALIAS=mmc:block
 19139	                 cid: 6f0303434241445310aa002b4d013b00
 19140	                 rca: 0xb368
 19141	                 csd: 400e005a5b590000f00e7f800a404000
 19142	              manfid: 0x00006f
 19143	                 ocr: 0x00200000
 19144	preferred_erase_size: 2097152
 19145	                type: SD
 19146	               hwrev: 0x1
 19147	                date: 11/2019
 19148	                 dsr: 0x404
 19149	          erase_size: 512
 19150	               oemid: 0x0303
 19151	              serial: 0xaa002b4d
 19152	                 ssr: 00000000000000280402800100fd180a001e00000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
 19153	                 scr: 02b5800300000000
 19154	                name: CBADS
 19155
 19156	### Boot system health:
 19157
 19158	Time       big.LITTLE   load %cpu %sys %usr %nice %io %irq   CPU  C.St.
 19159	16:03:33: 1908/1992MHz  2.90  22%  10%   5%   0%   6%   0% 31.4°C  0/11
 19160	16:03:33: 1908/1992MHz  2.90  69%  30%   8%   0%  29%   1% 31.7°C  0/11
 19161	16:03:34: 1908/1992MHz  2.90  84%  24%   2%   0%  56%   0% 29.8°C  0/11
 19162	16:03:34: 1908/1992MHz  2.90  62%   3%   1%   0%  56%   0% 29.1°C  0/11
 19163	16:03:34: 1908/1992MHz  2.90  48%  10%   6%   0%  28%   1% 28.7°C  0/11
 19164
 19165	### Activated 1 lzo-rle zram swap devices with 1816 MB each
 19166
 19167	### Activated Armbian ramlog partition with zstd compression
 19168
 19169	Wed 24 Feb 2021 04:23:02 PM GMT | Odroid N2 | 21.02.1 | arm64 | aarch64 | 5.10.12-meson64
 19170
 19171	### dmesg:
 19172
 19173	[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
 19174	[    0.000000] Linux version 5.10.12-meson64 (root@beast) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #21.02.1 SMP PREEMPT Wed Feb 3 21:06:36 CET 2021
 19175	[    0.000000] Machine model: Hardkernel ODROID-N2
 19176	[    0.000000] efi: UEFI not found.
 19177	[    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
 19178	[    0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB
 19179	[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
 19180	[    0.000000] NUMA: No NUMA configuration found
 19181	[    0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ed7fffff]
 19182	[    0.000000] NUMA: NODE_DATA [mem 0xb502f100-0xb5030fff]
 19183	[    0.000000] Zone ranges:
 19184	[    0.000000]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
 19185	[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000ed7fffff]
 19186	[    0.000000]   Normal   empty
 19187	[    0.000000] Movable zone start for each node
 19188	[    0.000000] Early memory node ranges
 19189	[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000004ffffff]
 19190	[    0.000000]   node   0: [mem 0x0000000005300000-0x00000000ed7fffff]
 19191	[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ed7fffff]
 19192	[    0.000000] On node 0 totalpages: 972032
 19193	[    0.000000]   DMA zone: 4096 pages used for memmap
 19194	[    0.000000]   DMA zone: 0 pages reserved
 19195	[    0.000000]   DMA zone: 261376 pages, LIFO batch:63
 19196	[    0.000000]   DMA32 zone: 11104 pages used for memmap
 19197	[    0.000000]   DMA32 zone: 710656 pages, LIFO batch:63
 19198	[    0.000000] psci: probing for conduit method from DT.
 19199	[    0.000000] psci: PSCIv1.0 detected in firmware.
 19200	[    0.000000] psci: Using standard PSCI v0.2 function IDs
 19201	[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
 19202	[    0.000000] psci: SMC Calling Convention v1.1
 19203	[    0.000000] percpu: Embedded 23 pages/cpu s56728 r8192 d29288 u94208
 19204	[    0.000000] pcpu-alloc: s56728 r8192 d29288 u94208 alloc=23*4096
 19205	[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
 19206	[    0.000000] Detected VIPT I-cache on CPU0
 19207	[    0.000000] CPU features: detected: ARM erratum 845719
 19208	[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 956832
 19209	[    0.000000] Policy zone: DMA32
 19210	[    0.000000] Kernel command line: root=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c rootwait rootfstype=ext4 console=ttyAML0,115200n8 console=tty1 loglevel=1  no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=1080p60hz cvbsmode=576cvbs max_freq_a53=1896 max_freq_a73=1800 maxcpus=6 voutmode=hdmi  disablehpd=false  cvbscable=0 overscan=100 consoleblank=0
 19211	[    0.000000] Kernel parameter elevator= does not have any effect anymore.
 19212	               Please use sysfs to set IO scheduler for individual devices.
 19213	[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
 19214	[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
 19215	[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
 19216	[    0.000000] software IO TLB: mapped [mem 0x0000000038ac5000-0x000000003cac5000] (64MB)
 19217	[    0.000000] Memory: 2785352K/3888128K available (14144K kernel code, 1760K rwdata, 5508K rodata, 3328K init, 592K bss, 185272K reserved, 917504K cma-reserved)
 19218	[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
 19219	[    0.000000] rcu: Preemptible hierarchical RCU implementation.
 19220	[    0.000000] rcu: 	RCU event tracing is enabled.
 19221	[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
 19222	[    0.000000] 	Trampoline variant of Tasks RCU enabled.
 19223	[    0.000000] 	Rude variant of Tasks RCU enabled.
 19224	[    0.000000] 	Tracing variant of Tasks RCU enabled.
 19225	[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
 19226	[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
 19227	[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
 19228	[    0.000000] GIC: Using split EOI/Deactivate mode
 19229	[    0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized
 19230	[    0.000000] random: get_random_bytes called from start_kernel+0x378/0x538 with crng_init=0
 19231	[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
 19232	[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
 19233	[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
 19234	[    0.000250] Console: colour dummy device 80x25
 19235	[    0.000284] printk: console [tty1] enabled
 19236	[    0.000370] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
 19237	[    0.000382] pid_max: default: 32768 minimum: 301
 19238	[    0.000465] LSM: Security Framework initializing
 19239	[    0.000491] Yama: becoming mindful.
 19240	[    0.000583] AppArmor: AppArmor initialized
 19241	[    0.000633] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
 19242	[    0.000652] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
 19243	[    0.002645] rcu: Hierarchical SRCU implementation.
 19244	[    0.005082] EFI services will not be available.
 19245	[    0.005505] smp: Bringing up secondary CPUs ...
 19246	[    0.006177] Detected VIPT I-cache on CPU1
 19247	[    0.006238] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
 19248	[    0.007430] CPU features: detected: ARM erratum 858921
 19249	[    0.007438] CPU features: detected: Spectre-v2
 19250	[    0.007442] CPU features: detected: Spectre-v4
 19251	[    0.007448] Detected VIPT I-cache on CPU2
 19252	[    0.007476] arch_timer: Enabling local workaround for ARM erratum 858921
 19253	[    0.007489] arch_timer: CPU2: Trapping CNTVCT access
 19254	[    0.007502] CPU2: Booted secondary processor 0x0000000100 [0x410fd092]
 19255	[    0.008211] Detected VIPT I-cache on CPU3
 19256	[    0.008227] arch_timer: Enabling local workaround for ARM erratum 858921
 19257	[    0.008234] arch_timer: CPU3: Trapping CNTVCT access
 19258	[    0.008242] CPU3: Booted secondary processor 0x0000000101 [0x410fd092]
 19259	[    0.008864] Detected VIPT I-cache on CPU4
 19260	[    0.008881] arch_timer: Enabling local workaround for ARM erratum 858921
 19261	[    0.008888] arch_timer: CPU4: Trapping CNTVCT access
 19262	[    0.008896] CPU4: Booted secondary processor 0x0000000102 [0x410fd092]
 19263	[    0.009512] Detected VIPT I-cache on CPU5
 19264	[    0.009528] arch_timer: Enabling local workaround for ARM erratum 858921
 19265	[    0.009535] arch_timer: CPU5: Trapping CNTVCT access
 19266	[    0.009543] CPU5: Booted secondary processor 0x0000000103 [0x410fd092]
 19267	[    0.009624] smp: Brought up 1 node, 6 CPUs
 19268	[    0.009641] SMP: Total of 6 processors activated.
 19269	[    0.009649] CPU features: detected: 32-bit EL0 Support
 19270	[    0.009654] CPU features: detected: CRC32 instructions
 19271	[    0.009660] CPU features: detected: 32-bit EL1 Support
 19272	[    0.020903] CPU: All CPU(s) started at EL2
 19273	[    0.020952] alternatives: patching kernel code
 19274	[    0.022892] devtmpfs: initialized
 19275	[    0.030550] Registered cp15_barrier emulation handler
 19276	[    0.030563] Registered setend emulation handler
 19277	[    0.030698] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
 19278	[    0.030736] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
 19279	[    0.044634] pinctrl core: initialized pinctrl subsystem
 19280	[    0.045194] DMI not present or invalid.
 19281	[    0.045603] NET: Registered protocol family 16
 19282	[    0.047177] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
 19283	[    0.047449] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
 19284	[    0.047675] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
 19285	[    0.047719] audit: initializing netlink subsys (disabled)
 19286	[    0.047849] audit: type=2000 audit(0.044:1): state=initialized audit_enabled=0 res=1
 19287	[    0.049234] thermal_sys: Registered thermal governor 'fair_share'
 19288	[    0.049241] thermal_sys: Registered thermal governor 'bang_bang'
 19289	[    0.049245] thermal_sys: Registered thermal governor 'step_wise'
 19290	[    0.049249] thermal_sys: Registered thermal governor 'user_space'
 19291	[    0.049663] cpuidle: using governor menu
 19292	[    0.049997] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
 19293	[    0.050117] ASID allocator initialised with 65536 entries
 19294	[    0.051074] Serial: AMBA PL011 UART driver
 19295	[    0.085075] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
 19296	[    0.085087] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
 19297	[    0.085093] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
 19298	[    0.085098] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
 19299	[    0.087855] cryptd: max_cpu_qlen set to 1000
 19300	[    0.156194] raid6: neonx8   gen()  2785 MB/s
 19301	[    0.224246] raid6: neonx8   xor()  2042 MB/s
 19302	[    0.292309] raid6: neonx4   gen()  3000 MB/s
 19303	[    0.360396] raid6: neonx4   xor()  2346 MB/s
 19304	[    0.428443] raid6: neonx2   gen()  2530 MB/s
 19305	[    0.496506] raid6: neonx2   xor()  2208 MB/s
 19306	[    0.564577] raid6: neonx1   gen()  2072 MB/s
 19307	[    0.632641] raid6: neonx1   xor()  1727 MB/s
 19308	[    0.700718] raid6: int64x8  gen()  1377 MB/s
 19309	[    0.768776] raid6: int64x8  xor()   735 MB/s
 19310	[    0.836868] raid6: int64x4  gen()  1463 MB/s
 19311	[    0.904943] raid6: int64x4  xor()   842 MB/s
 19312	[    0.973000] raid6: int64x2  gen()  1362 MB/s
 19313	[    1.041055] raid6: int64x2  xor()   619 MB/s
 19314	[    1.109122] raid6: int64x1  gen()  1120 MB/s
 19315	[    1.177205] raid6: int64x1  xor()   462 MB/s
 19316	[    1.177208] raid6: using algorithm neonx4 gen() 3000 MB/s
 19317	[    1.177211] raid6: .... xor() 2346 MB/s, rmw enabled
 19318	[    1.177215] raid6: using neon recovery algorithm
 19319	[    1.177669] ACPI: Interpreter disabled.
 19320	[    1.178453] 5V: supplied by 12V
 19321	[    1.179368] VDDAO_3V3: supplied by 12V
 19322	[    1.179842] iommu: Default domain type: Translated
 19323	[    1.180019] vgaarb: loaded
 19324	[    1.180903] SCSI subsystem initialized
 19325	[    1.181244] usbcore: registered new interface driver usbfs
 19326	[    1.181289] usbcore: registered new interface driver hub
 19327	[    1.181326] usbcore: registered new device driver usb
 19328	[    1.181576] pps_core: LinuxPPS API ver. 1 registered
 19329	[    1.181581] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
 19330	[    1.181597] PTP clock support registered
 19331	[    1.181783] EDAC MC: Ver: 3.0.0
 19332	[    1.183072] NetLabel: Initializing
 19333	[    1.183079] NetLabel:  domain hash size = 128
 19334	[    1.183082] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
 19335	[    1.183123] NetLabel:  unlabeled traffic allowed by default
 19336	[    1.183551] clocksource: Switched to clocksource arch_sys_counter
 19337	[    1.183763] VFS: Disk quotas dquot_6.6.0
 19338	[    1.183807] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
 19339	[    1.184167] AppArmor: AppArmor Filesystem Enabled
 19340	[    1.184270] pnp: PnP ACPI: disabled
 19341	[    1.189969] NET: Registered protocol family 2
 19342	[    1.190426] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
 19343	[    1.190531] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
 19344	[    1.190787] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
 19345	[    1.190975] TCP: Hash tables configured (established 32768 bind 32768)
 19346	[    1.191126] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
 19347	[    1.191192] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
 19348	[    1.191238] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
 19349	[    1.191380] NET: Registered protocol family 1
 19350	[    1.191402] PCI: CLS 0 bytes, default 64
 19351	[    1.191534] Trying to unpack rootfs image as initramfs...
 19352	[    1.727512] Freeing initrd memory: 13544K
 19353	[    1.728472] kvm [1]: IPA Size Limit: 40 bits
 19354	[    1.729176] kvm [1]: vgic interrupt IRQ9
 19355	[    1.729306] kvm [1]: Hyp mode initialized successfully
 19356	[    1.734363] Initialise system trusted keyrings
 19357	[    1.734395] Key type blacklist registered
 19358	[    1.734487] workingset: timestamp_bits=44 max_order=20 bucket_order=0
 19359	[    1.737729] zbud: loaded
 19360	[    1.738701] squashfs: version 4.0 (2009/01/31) Phillip Lougher
 19361	[    1.739163] fuse: init (API version 7.32)
 19362	[    1.739945] integrity: Platform Keyring initialized
 19363	[    1.768096] xor: measuring software checksum speed
 19364	[    1.770934]    8regs           :  3473 MB/sec
 19365	[    1.773394]    32regs          :  4021 MB/sec
 19366	[    1.776047]    arm64_neon      :  3718 MB/sec
 19367	[    1.776050] xor: using function: 32regs (4021 MB/sec)
 19368	[    1.776056] Key type asymmetric registered
 19369	[    1.776060] Asymmetric key parser 'x509' registered
 19370	[    1.776093] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
 19371	[    1.776176] io scheduler mq-deadline registered
 19372	[    1.776181] io scheduler kyber registered
 19373	[    1.776259] io scheduler bfq registered
 19374	[    1.778801] gpio-447 (usb-hub-reset): hogged as output/high
 19375	[    1.781791] EINJ: ACPI disabled.
 19376	[    1.787877] soc soc0: Amlogic Meson G12B (S922X) Revision 29:a (40:2) Detected
 19377	[    1.789315] VCC_3V3: supplied by VDDAO_3V3
 19378	[    1.789349] FLASH_1V8: supplied by VCC_3V3
 19379	[    1.789394] VCC_1V8: supplied by VCC_3V3
 19380	[    1.789421] VDDAO_1V8: supplied by VDDAO_3V3
 19381	[    1.789451] VDDCPU_A: supplied by regulator-dummy
 19382	[    1.789801] VDDCPU_B: supplied by regulator-dummy
 19383	[    1.790486] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
 19384	[    1.792862] Serial: AMBA driver
 19385	[    1.793152] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart
 19386	[    1.793245] printk: console [ttyAML0] enabled
 19387	[    1.793778] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 33, base_baud = 1500000) is a meson_uart
 19388	[    1.799144] loop: module loaded
 19389	[    1.801238] libphy: Fixed MDIO Bus: probed
 19390	[    1.802408] tun: Universal TUN/TAP device driver, 1.6
 19391	[    1.803071] thunder_xcv, ver 1.0
 19392	[    1.803099] thunder_bgx, ver 1.0
 19393	[    1.803128] nicpf, ver 1.0
 19394	[    1.803651] e1000e: Intel(R) PRO/1000 Network Driver
 19395	[    1.803655] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
 19396	[    1.803700] igb: Intel(R) Gigabit Ethernet Network Driver
 19397	[    1.803703] igb: Copyright (c) 2007-2014 Intel Corporation.
 19398	[    1.803739] igbvf: Intel(R) Gigabit Virtual Function Network Driver
 19399	[    1.803742] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
 19400	[    1.803874] sky2: driver version 1.30
 19401	[    1.804236] VFIO - User Level meta-driver version: 0.3
 19402	[    1.805640] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
 19403	[    1.805656] ehci-pci: EHCI PCI platform driver
 19404	[    1.805688] ehci-platform: EHCI generic platform driver
 19405	[    1.805818] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
 19406	[    1.805827] ohci-pci: OHCI PCI platform driver
 19407	[    1.805856] ohci-platform: OHCI generic platform driver
 19408	[    1.806267] usbcore: registered new interface driver usb-storage
 19409	[    1.807523] mousedev: PS/2 mouse device common for all mice
 19410	[    1.807924] i2c /dev entries driver
 19411	[    1.813265] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17
 19412	[    1.813934] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz
 19413	[    1.814615] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-1 failed:-17
 19414	[    1.815228] sdhci: Secure Digital Host Controller Interface driver
 19415	[    1.815235] sdhci: Copyright(c) Pierre Ossman
 19416	[    1.815357] Synopsys Designware Multimedia Card Interface Driver
 19417	[    1.815898] sdhci-pltfm: SDHCI platform and OF driver helper
 19418	[    1.816831] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq
 19419	[    1.817242] ledtrig-cpu: registered to indicate activity on CPUs
 19420	[    1.817613] meson-sm: secure-monitor enabled
 19421	[    1.817815] hid: raw HID events driver (C) Jiri Kosina
 19422	[    1.817922] usbcore: registered new interface driver usbhid
 19423	[    1.817925] usbhid: USB HID core driver
 19424	[    1.818934] NET: Registered protocol family 10
 19425	[    1.819388] Segment Routing with IPv6
 19426	[    1.819416] NET: Registered protocol family 17
 19427	[    1.819482] 8021q: 802.1Q VLAN Support v1.8
 19428	[    1.819504] Key type dns_resolver registered
 19429	[    1.819800] registered taskstats version 1
 19430	[    1.819806] Loading compiled-in X.509 certificates
 19431	[    1.821616] Loaded X.509 cert 'Build time autogenerated kernel key: f47c178852ca39740c3546b008122b65f5ed9bce'
 19432	[    1.823220] zswap: loaded using pool zstd/z3fold
 19433	[    1.823405] Key type ._fscrypt registered
 19434	[    1.823408] Key type .fscrypt registered
 19435	[    1.823409] Key type fscrypt-provisioning registered
 19436	[    1.824609] Btrfs loaded, crc32c=crc32c-generic
 19437	[    1.832716] Key type encrypted registered
 19438	[    1.832729] AppArmor: AppArmor sha1 policy hashing enabled
 19439	[    1.838969] HUB_5V: supplied by 5V
 19440	[    1.839210] USB_PWR_EN: supplied by 5V
 19441	[    1.840885] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2
 19442	[    1.840892] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1
 19443	[    1.843643] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator
 19444	[    1.843701] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator
 19445	[    1.843818] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM
 19446	[    1.844507] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
 19447	[    1.844520] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
 19448	[    1.844604] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010
 19449	[    1.844627] xhci-hcd xhci-hcd.0.auto: irq 41, io mem 0xff500000
 19450	[    1.844749] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
 19451	[    1.844752] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 19452	[    1.844756] usb usb1: Product: xHCI Host Controller
 19453	[    1.844758] usb usb1: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
 19454	[    1.844760] usb usb1: SerialNumber: xhci-hcd.0.auto
 19455	[    1.844949] hub 1-0:1.0: USB hub found
 19456	[    1.844962] hub 1-0:1.0: 2 ports detected
 19457	[    1.845090] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
 19458	[    1.845096] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
 19459	[    1.845101] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
 19460	[    1.845123] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
 19461	[    1.845156] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
 19462	[    1.845159] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 19463	[    1.845161] usb usb2: Product: xHCI Host Controller
 19464	[    1.845163] usb usb2: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
 19465	[    1.845166] usb usb2: SerialNumber: xhci-hcd.0.auto
 19466	[    1.845306] hub 2-0:1.0: USB hub found
 19467	[    1.845316] hub 2-0:1.0: 1 port detected
 19468	[    1.846396] meson-gx-mmc ffe05000.sd: Got CD GPIO
 19469	[    1.872671] Freeing unused kernel memory: 3328K
 19470	[    1.911682] Run /init as init process
 19471	[    1.911686]   with arguments:
 19472	[    1.911688]     /init
 19473	[    1.911689]   with environment:
 19474	[    1.911692]     HOME=/
 19475	[    1.911693]     TERM=linux
 19476	[    1.911695]     hdmimode=1080p60hz
 19477	[    1.911696]     cvbsmode=576cvbs
 19478	[    1.911697]     max_freq_a53=1896
 19479	[    1.911699]     max_freq_a73=1800
 19480	[    1.911700]     voutmode=hdmi
 19481	[    1.911702]     disablehpd=false
 19482	[    1.911703]     cvbscable=0
 19483	[    1.911705]     overscan=100
 19484	[    1.937739] mmc1: new ultra high speed SDR25 SDHC card at address b368
 19485	[    1.938331] mmcblk1: mmc1:b368 CBADS 30.0 GiB
 19486	[    1.940150]  mmcblk1: p1
 19487	[    2.062327] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found
 19488	[    2.062333] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found
 19489	[    2.062418] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock
 19490	[    2.062853] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37
 19491	[    2.062862] meson8b-dwmac ff3f0000.ethernet: 	DWMAC1000
 19492	[    2.062866] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported
 19493	[    2.062870] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported
 19494	[    2.062873] meson8b-dwmac ff3f0000.ethernet: COE Type 2
 19495	[    2.062876] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported
 19496	[    2.062879] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported
 19497	[    2.062951] meson8b-dwmac ff3f0000.ethernet: Normal descriptors
 19498	[    2.062955] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled
 19499	[    2.062958] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
 19500	[    2.063364] libphy: stmmac: probed
 19501	[    2.065582] libphy: mdio_mux: probed
 19502	[    2.091123] meson-vrtc ff8000a8.rtc: registered as rtc1
 19503	[    2.101509] random: fast init done
 19504	[    2.102994] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
 19505	[    2.103104] rtc-pcf8563 1-0051: registered as rtc0
 19506	[    2.104259] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
 19507	[    2.104264] rtc-pcf8563 1-0051: hctosys: unable to read the hardware clock
 19508	[    2.187570] usb 1-1: new high-speed USB device number 2 using xhci-hcd
 19509	[    2.272157] libphy: mdio_mux: probed
 19510	[    2.337889] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.04
 19511	[    2.337896] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
 19512	[    2.337898] usb 1-1: Product: USB2.1 Hub
 19513	[    2.337900] usb 1-1: Manufacturer: GenesysLogic
 19514	[    2.389308] hub 1-1:1.0: USB hub found
 19515	[    2.389528] hub 1-1:1.0: 4 ports detected
 19516	[    2.463702] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
 19517	[    2.486175] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.04
 19518	[    2.486180] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
 19519	[    2.486184] usb 2-1: Product: USB3.1 Hub
 19520	[    2.486187] usb 2-1: Manufacturer: GenesysLogic
 19521	[    2.517381] hub 2-1:1.0: USB hub found
 19522	[    2.517675] hub 2-1:1.0: 4 ports detected
 19523	[    2.932646] EXT4-fs (mmcblk1p1): mounted filesystem with writeback data mode. Opts: (null)
 19524	[    3.736668] systemd[1]: System time before build time, advancing clock.
 19525	[    3.751505] systemd[1]: Inserted module 'autofs4'
 19526	[    3.797968] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
 19527	[    3.798182] systemd[1]: Detected architecture arm64.
 19528	[    3.826133] systemd[1]: Set hostname to <odroidn2>.
 19529	[    4.153613] random: systemd: uninitialized urandom read (16 bytes read)
 19530	[    4.156946] random: systemd: uninitialized urandom read (16 bytes read)
 19531	[    4.157226] systemd[1]: Listening on udev Control Socket.
 19532	[    4.157428] random: systemd: uninitialized urandom read (16 bytes read)
 19533	[    4.157580] systemd[1]: Listening on Syslog Socket.
 19534	[    4.157660] systemd[1]: Reached target System Time Synchronized.
 19535	[    4.157858] systemd[1]: Listening on Journal Socket (/dev/log).
 19536	[    4.158117] systemd[1]: Listening on Journal Audit Socket.
 19537	[    4.158196] systemd[1]: Reached target Swap.
 19538	[    4.158270] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
 19539	[    4.217738] EXT4-fs (mmcblk1p1): re-mounted. Opts: commit=600,errors=remount-ro
 19540	[    4.749681] zram: Added device: zram0
 19541	[    4.749927] zram: Added device: zram1
 19542	[    4.751792] zram: Added device: zram2
 19543	[    4.787419] pwm-gpio pwmgpio: 1 gpio pwms loaded
 19544	[    4.974340] mc: Linux media interface: v0.10
 19545	[    4.984389] meson-saradc ff809000.adc: supply vref not found, using dummy regulator
 19546	[    4.996470] panfrost ffe40000.gpu: clock rate = 24000000
 19547	[    4.996555] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19
 19548	[    4.997411] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0
 19549	[    4.997421] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400
 19550	[    4.997426] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
 19551	[    4.997429] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1
 19552	[    5.016736] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 0
 19553	[    5.035988] videodev: Linux video capture interface: v2.00
 19554	[    5.087586] Registered IR keymap rc-odroid
 19555	[    5.098914] meson-drm ff900000.vpu: Queued 2 outputs on vpu
 19556	[    5.107969] IR NEC protocol handler initialized
 19557	[    5.135623] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0
 19558	[    5.135722] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
 19559	[    5.135779] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input0
 19560	[    5.135994] meson-ir ff808000.ir: receiver initialized
 19561	[    5.167424] meson-drm ff900000.vpu: CVBS Output connector not available
 19562	[    5.169317] zram0: detected capacity change from 0 to 1904500736
 19563	[    5.195806] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
 19564	[    5.196171] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
 19565	[    5.196496] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
 19566	[    5.196779] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 1
 19567	[    5.196848] meson-drm ff900000.vpu: [drm] Cannot find any crtc or sizes
 19568	[    5.210132] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
 19569	[    5.233182] axg-sound-card sound: ASoC: no DMI vendor name!
 19570	[    5.563732] Console: switching to colour frame buffer device 240x67
 19571	[    5.598458] meson-drm ff900000.vpu: [drm] fb0: mesondrmfb frame buffer device
 19572	[    6.215568] Adding 1859860k swap on /dev/zram0.  Priority:5 extents:1 across:1859860k SSFS
 19573	[    6.281536] zram1: detected capacity change from 0 to 52428800
 19574	[    8.367588] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
 19575	[    8.367607] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
 19576	[    9.594661] systemd[1]: Started Armbian memory supported logging.
 19577	[    9.597056] systemd[1]: Starting Journal Service...
 19578	[    9.658544] systemd[1]: Started Journal Service.
 19579	[    9.684525] systemd-journald[1847]: Received request to flush runtime journal from PID 1
 19580
 19581	### armbian-release:
 19582
 19583	# PLEASE DO NOT EDIT THIS FILE
 19584	BOARD=odroidn2
 19585	BOARD_NAME="Odroid N2"
 19586	BOARDFAMILY=meson-g12b
 19587	BUILD_REPOSITORY_URL=https://github.com/armbian/build
 19588	BUILD_REPOSITORY_COMMIT=5f03d652
 19589	DISTRIBUTION_CODENAME=buster
 19590	DISTRIBUTION_STATUS=supported
 19591	VERSION=21.02.1
 19592	LINUXFAMILY=meson64
 19593	BRANCH=current
 19594	ARCH=arm64
 19595	IMAGE_TYPE=stable
 19596	BOARD_TYPE=conf
 19597	INITRD_ARCH=arm64
 19598	KERNEL_IMAGE_TYPE=Image
 19599
 19600	### boot environment:
 19601
 19602	verbosity=1
 19603	console=both
 19604	overlay_prefix=meson
 19605	rootdev=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c
 19606	rootfstype=ext4
 19607	usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
 19608
 19609	### lsusb:
 19610
 19611	Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc.
 19612	Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
 19613	Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
 19614	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
 19615
 19616	### lscpu:
 19617
 19618	Architecture:        aarch64
 19619	Byte Order:          Little Endian
 19620	CPU(s):              6
 19621	On-line CPU(s) list: 0-5
 19622	Thread(s) per core:  1
 19623	Core(s) per socket:  3
 19624	Socket(s):           2
 19625	NUMA node(s):        1
 19626	Vendor ID:           ARM
 19627	Model:               4
 19628	Model name:          Cortex-A53
 19629	Stepping:            r0p4
 19630	CPU max MHz:         1992.0000
 19631	CPU min MHz:         100.0000
 19632	BogoMIPS:            48.00
 19633	L1d cache:           unknown size
 19634	L1i cache:           unknown size
 19635	L2 cache:            unknown size
 19636	NUMA node0 CPU(s):   0-5
 19637	Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 19638
 19639	### cpuinfo:
 19640
 19641	processor	: 0
 19642	BogoMIPS	: 48.00
 19643	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 19644	CPU implementer	: 0x41
 19645	CPU architecture: 8
 19646	CPU variant	: 0x0
 19647	CPU part	: 0xd03
 19648	CPU revision	: 4
 19649
 19650	processor	: 1
 19651	BogoMIPS	: 48.00
 19652	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 19653	CPU implementer	: 0x41
 19654	CPU architecture: 8
 19655	CPU variant	: 0x0
 19656	CPU part	: 0xd03
 19657	CPU revision	: 4
 19658
 19659	processor	: 2
 19660	BogoMIPS	: 48.00
 19661	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 19662	CPU implementer	: 0x41
 19663	CPU architecture: 8
 19664	CPU variant	: 0x0
 19665	CPU part	: 0xd09
 19666	CPU revision	: 2
 19667
 19668	processor	: 3
 19669	BogoMIPS	: 48.00
 19670	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 19671	CPU implementer	: 0x41
 19672	CPU architecture: 8
 19673	CPU variant	: 0x0
 19674	CPU part	: 0xd09
 19675	CPU revision	: 2
 19676
 19677	processor	: 4
 19678	BogoMIPS	: 48.00
 19679	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 19680	CPU implementer	: 0x41
 19681	CPU architecture: 8
 19682	CPU variant	: 0x0
 19683	CPU part	: 0xd09
 19684	CPU revision	: 2
 19685
 19686	processor	: 5
 19687	BogoMIPS	: 48.00
 19688	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 19689	CPU implementer	: 0x41
 19690	CPU architecture: 8
 19691	CPU variant	: 0x0
 19692	CPU part	: 0xd09
 19693	CPU revision	: 2
 19694
 19695
 19696	### meminfo:
 19697
 19698	MemTotal:        3719728 kB
 19699	MemFree:         3370988 kB
 19700	MemAvailable:    3326420 kB
 19701	Buffers:           11816 kB
 19702	Cached:            47176 kB
 19703	SwapCached:            0 kB
 19704	Active:            30888 kB
 19705	Inactive:         209212 kB
 19706	Active(anon):        112 kB
 19707	Inactive(anon):   185600 kB
 19708	Active(file):      30776 kB
 19709	Inactive(file):    23612 kB
 19710	Unevictable:           0 kB
 19711	Mlocked:               0 kB
 19712	SwapTotal:       1859860 kB
 19713	SwapFree:        1859860 kB
 19714	Dirty:              8076 kB
 19715	Writeback:             0 kB
 19716	AnonPages:        180612 kB
 19717	Mapped:            10456 kB
 19718	Shmem:              4880 kB
 19719	KReclaimable:      13188 kB
 19720	Slab:              39136 kB
 19721	SReclaimable:      13188 kB
 19722	SUnreclaim:        25948 kB
 19723	KernelStack:        2080 kB
 19724	PageTables:         5336 kB
 19725	NFS_Unstable:          0 kB
 19726	Bounce:                0 kB
 19727	WritebackTmp:          0 kB
 19728	CommitLimit:     3719724 kB
 19729	Committed_AS:    4210660 kB
 19730	VmallocTotal:   135290159040 kB
 19731	VmallocUsed:       30928 kB
 19732	VmallocChunk:          0 kB
 19733	Percpu:             1368 kB
 19734	HardwareCorrupted:     0 kB
 19735	AnonHugePages:         0 kB
 19736	ShmemHugePages:        0 kB
 19737	ShmemPmdMapped:        0 kB
 19738	FileHugePages:         0 kB
 19739	FilePmdMapped:         0 kB
 19740	CmaTotal:         917504 kB
 19741	CmaFree:          901724 kB
 19742	HugePages_Total:       0
 19743	HugePages_Free:        0
 19744	HugePages_Rsvd:        0
 19745	HugePages_Surp:        0
 19746	Hugepagesize:       2048 kB
 19747	Hugetlb:               0 kB
 19748
 19749	### virtual memory:
 19750
 19751	vm.admin_reserve_kbytes = 8192
 19752	vm.block_dump = 0
 19753	vm.compaction_proactiveness = 20
 19754	vm.compact_unevictable_allowed = 1
 19755	vm.dirty_background_bytes = 0
 19756	vm.dirty_background_ratio = 10
 19757	vm.dirty_bytes = 0
 19758	vm.dirty_expire_centisecs = 3000
 19759	vm.dirty_ratio = 20
 19760	vm.dirtytime_expire_seconds = 43200
 19761	vm.dirty_writeback_centisecs = 500
 19762	vm.extfrag_threshold = 500
 19763	vm.hugetlb_shm_group = 0
 19764	vm.laptop_mode = 0
 19765	vm.legacy_va_layout = 0
 19766	vm.lowmem_reserve_ratio = 256	256	32	0
 19767	vm.max_map_count = 65530
 19768	vm.memory_failure_early_kill = 0
 19769	vm.memory_failure_recovery = 1
 19770	vm.min_free_kbytes = 45056
 19771	vm.min_slab_ratio = 5
 19772	vm.min_unmapped_ratio = 1
 19773	vm.mmap_min_addr = 4096
 19774	vm.mmap_rnd_bits = 18
 19775	vm.mmap_rnd_compat_bits = 11
 19776	vm.nr_hugepages = 0
 19777	vm.nr_hugepages_mempolicy = 0
 19778	vm.nr_overcommit_hugepages = 0
 19779	vm.numa_stat = 1
 19780	vm.numa_zonelist_order = Node
 19781	vm.oom_dump_tasks = 1
 19782	vm.oom_kill_allocating_task = 0
 19783	vm.overcommit_kbytes = 0
 19784	vm.overcommit_memory = 0
 19785	vm.overcommit_ratio = 50
 19786	vm.page-cluster = 0
 19787	vm.page_lock_unfairness = 5
 19788	vm.panic_on_oom = 0
 19789	vm.percpu_pagelist_fraction = 0
 19790	vm.stat_interval = 1
 19791	vm.swappiness = 100
 19792	vm.user_reserve_kbytes = 115049
 19793	vm.vfs_cache_pressure = 100
 19794	vm.watermark_boost_factor = 15000
 19795	vm.watermark_scale_factor = 10
 19796	vm.zone_reclaim_mode = 0
 19797
 19798	### ip addr:
 19799
 19800	1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
 19801	    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
 19802	    inet XXX.XXX.0.1/8 scope host lo
 19803	       valid_lft forever preferred_lft forever
 19804	    inet6 ::1/128 scope host
 19805	       valid_lft forever preferred_lft forever
 19806	2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
 19807	    link/ether 00:1e:06:42:03:f8 brd ff:ff:ff:ff:ff:ff
 19808
 19809	### partitions:
 19810
 19811	major minor  #blocks  name
 19812
 19813	 179        0   31464960 mmcblk1
 19814	 179        1   31146208 mmcblk1p1
 19815	 252        0    1859864 zram0
 19816	 252        1      51200 zram1
 19817
 19818	### df:
 19819
 19820	udev            1.4G     0  1.4G   0% /dev
 19821	tmpfs           364M  4.9M  359M   2% /run
 19822	/dev/mmcblk1p1   30G  1.8G   28G   6% /
 19823	tmpfs           1.8G     0  1.8G   0% /dev/shm
 19824	tmpfs           5.0M  4.0K  5.0M   1% /run/lock
 19825	tmpfs           1.8G     0  1.8G   0% /sys/fs/cgroup
 19826	tmpfs           1.8G     0  1.8G   0% /tmp
 19827	/dev/zram1       49M  7.9M   38M  18% /var/log
 19828
 19829	### lsblk:
 19830
 19831	NAME        FSTYPE  SIZE MOUNTPOINT UUID
 19832	mmcblk1              30G
 19833	└─mmcblk1p1 ext4   29.7G /          bd34953d-41be-49d6-b1c0-c0c28a5e239c
 19834	zram1                50M /var/log
 19835
 19836	### zramctl:
 19837
 19838	NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
 19839	/dev/zram1 zstd           50M  132K  697B   36K       6 /var/log
 19840	/dev/zram0 lzo-rle       1.8G    4K   74B   12K       6 [SWAP]
 19841
 19842	### mtab:
 19843
 19844	/dev/mmcblk1p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
 19845	/dev/mmcblk1p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
 19846	/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
 19847
 19848	### mmc1:b368 info:
 19849
 19850	               fwrev: 0x0
 19851	              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=CBADS MODALIAS=mmc:block
 19852	                 cid: 6f0303434241445310aa002b4d013b00
 19853	                 rca: 0xb368
 19854	                 csd: 400e005a5b590000f00e7f800a404000
 19855	              manfid: 0x00006f
 19856	                 ocr: 0x00200000
 19857	preferred_erase_size: 2097152
 19858	                type: SD
 19859	               hwrev: 0x1
 19860	                date: 11/2019
 19861	                 dsr: 0x404
 19862	          erase_size: 512
 19863	               oemid: 0x0303
 19864	              serial: 0xaa002b4d
 19865	                 ssr: 00000000000000280402800100fd180a001e00000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
 19866	                 scr: 02b5800300000000
 19867	                name: CBADS
 19868
 19869	### Boot system health:
 19870
 19871	Time       big.LITTLE   load %cpu %sys %usr %nice %io %irq   CPU  C.St.
 19872	16:23:03: 1908/1992MHz  2.68  23%  10%   5%   0%   7%   0% 27.4°C  0/11
 19873	16:23:03: 1908/1992MHz  2.68  76%  39%   9%   0%  26%   0% 27.0°C  0/11
 19874	16:23:04: 1908/1992MHz  2.68  81%  25%   1%   0%  53%   0% 24.4°C  0/11
 19875	16:23:04: 1908/ 500MHz  2.68  62%   7%   5%   0%  48%   1% 24.2°C  0/11
 19876	16:23:04: 1908/1992MHz  2.68  57%   9%   6%   0%  39%   0% 24.0°C  0/11
 19877
 19878	### Activated 1 lzo-rle zram swap devices with 1816 MB each
 19879
 19880	### Activated Armbian ramlog partition with zstd compression
 19881
 19882	Wed 24 Feb 2021 04:23:02 PM GMT | Odroid N2 | 21.02.1 | arm64 | aarch64 | 5.10.12-meson64
 19883
 19884	### dmesg:
 19885
 19886	[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
 19887	[    0.000000] Linux version 5.10.12-meson64 (root@beast) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #21.02.1 SMP PREEMPT Wed Feb 3 21:06:36 CET 2021
 19888	[    0.000000] Machine model: Hardkernel ODROID-N2
 19889	[    0.000000] efi: UEFI not found.
 19890	[    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
 19891	[    0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB
 19892	[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
 19893	[    0.000000] NUMA: No NUMA configuration found
 19894	[    0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ed7fffff]
 19895	[    0.000000] NUMA: NODE_DATA [mem 0xb502f100-0xb5030fff]
 19896	[    0.000000] Zone ranges:
 19897	[    0.000000]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
 19898	[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000ed7fffff]
 19899	[    0.000000]   Normal   empty
 19900	[    0.000000] Movable zone start for each node
 19901	[    0.000000] Early memory node ranges
 19902	[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000004ffffff]
 19903	[    0.000000]   node   0: [mem 0x0000000005300000-0x00000000ed7fffff]
 19904	[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ed7fffff]
 19905	[    0.000000] On node 0 totalpages: 972032
 19906	[    0.000000]   DMA zone: 4096 pages used for memmap
 19907	[    0.000000]   DMA zone: 0 pages reserved
 19908	[    0.000000]   DMA zone: 261376 pages, LIFO batch:63
 19909	[    0.000000]   DMA32 zone: 11104 pages used for memmap
 19910	[    0.000000]   DMA32 zone: 710656 pages, LIFO batch:63
 19911	[    0.000000] psci: probing for conduit method from DT.
 19912	[    0.000000] psci: PSCIv1.0 detected in firmware.
 19913	[    0.000000] psci: Using standard PSCI v0.2 function IDs
 19914	[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
 19915	[    0.000000] psci: SMC Calling Convention v1.1
 19916	[    0.000000] percpu: Embedded 23 pages/cpu s56728 r8192 d29288 u94208
 19917	[    0.000000] pcpu-alloc: s56728 r8192 d29288 u94208 alloc=23*4096
 19918	[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
 19919	[    0.000000] Detected VIPT I-cache on CPU0
 19920	[    0.000000] CPU features: detected: ARM erratum 845719
 19921	[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 956832
 19922	[    0.000000] Policy zone: DMA32
 19923	[    0.000000] Kernel command line: root=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c rootwait rootfstype=ext4 console=ttyAML0,115200n8 console=tty1 loglevel=1  no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=1080p60hz cvbsmode=576cvbs max_freq_a53=1896 max_freq_a73=1800 maxcpus=6 voutmode=hdmi  disablehpd=false  cvbscable=0 overscan=100 consoleblank=0
 19924	[    0.000000] Kernel parameter elevator= does not have any effect anymore.
 19925	               Please use sysfs to set IO scheduler for individual devices.
 19926	[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
 19927	[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
 19928	[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
 19929	[    0.000000] software IO TLB: mapped [mem 0x0000000038ac5000-0x000000003cac5000] (64MB)
 19930	[    0.000000] Memory: 2785352K/3888128K available (14144K kernel code, 1760K rwdata, 5508K rodata, 3328K init, 592K bss, 185272K reserved, 917504K cma-reserved)
 19931	[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
 19932	[    0.000000] rcu: Preemptible hierarchical RCU implementation.
 19933	[    0.000000] rcu: 	RCU event tracing is enabled.
 19934	[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
 19935	[    0.000000] 	Trampoline variant of Tasks RCU enabled.
 19936	[    0.000000] 	Rude variant of Tasks RCU enabled.
 19937	[    0.000000] 	Tracing variant of Tasks RCU enabled.
 19938	[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
 19939	[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
 19940	[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
 19941	[    0.000000] GIC: Using split EOI/Deactivate mode
 19942	[    0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized
 19943	[    0.000000] random: get_random_bytes called from start_kernel+0x378/0x538 with crng_init=0
 19944	[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
 19945	[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
 19946	[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
 19947	[    0.000248] Console: colour dummy device 80x25
 19948	[    0.000284] printk: console [tty1] enabled
 19949	[    0.000373] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
 19950	[    0.000384] pid_max: default: 32768 minimum: 301
 19951	[    0.000467] LSM: Security Framework initializing
 19952	[    0.000493] Yama: becoming mindful.
 19953	[    0.000586] AppArmor: AppArmor initialized
 19954	[    0.000638] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
 19955	[    0.000657] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
 19956	[    0.002654] rcu: Hierarchical SRCU implementation.
 19957	[    0.005080] EFI services will not be available.
 19958	[    0.005499] smp: Bringing up secondary CPUs ...
 19959	[    0.006172] Detected VIPT I-cache on CPU1
 19960	[    0.006233] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
 19961	[    0.007424] CPU features: detected: ARM erratum 858921
 19962	[    0.007432] CPU features: detected: Spectre-v2
 19963	[    0.007436] CPU features: detected: Spectre-v4
 19964	[    0.007443] Detected VIPT I-cache on CPU2
 19965	[    0.007468] arch_timer: Enabling local workaround for ARM erratum 858921
 19966	[    0.007482] arch_timer: CPU2: Trapping CNTVCT access
 19967	[    0.007495] CPU2: Booted secondary processor 0x0000000100 [0x410fd092]
 19968	[    0.008203] Detected VIPT I-cache on CPU3
 19969	[    0.008219] arch_timer: Enabling local workaround for ARM erratum 858921
 19970	[    0.008226] arch_timer: CPU3: Trapping CNTVCT access
 19971	[    0.008234] CPU3: Booted secondary processor 0x0000000101 [0x410fd092]
 19972	[    0.008857] Detected VIPT I-cache on CPU4
 19973	[    0.008873] arch_timer: Enabling local workaround for ARM erratum 858921
 19974	[    0.008880] arch_timer: CPU4: Trapping CNTVCT access
 19975	[    0.008888] CPU4: Booted secondary processor 0x0000000102 [0x410fd092]
 19976	[    0.009503] Detected VIPT I-cache on CPU5
 19977	[    0.009520] arch_timer: Enabling local workaround for ARM erratum 858921
 19978	[    0.009527] arch_timer: CPU5: Trapping CNTVCT access
 19979	[    0.009535] CPU5: Booted secondary processor 0x0000000103 [0x410fd092]
 19980	[    0.009617] smp: Brought up 1 node, 6 CPUs
 19981	[    0.009634] SMP: Total of 6 processors activated.
 19982	[    0.009641] CPU features: detected: 32-bit EL0 Support
 19983	[    0.009647] CPU features: detected: CRC32 instructions
 19984	[    0.009653] CPU features: detected: 32-bit EL1 Support
 19985	[    0.020903] CPU: All CPU(s) started at EL2
 19986	[    0.020952] alternatives: patching kernel code
 19987	[    0.022895] devtmpfs: initialized
 19988	[    0.030532] Registered cp15_barrier emulation handler
 19989	[    0.030546] Registered setend emulation handler
 19990	[    0.030681] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
 19991	[    0.030718] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
 19992	[    0.044642] pinctrl core: initialized pinctrl subsystem
 19993	[    0.045414] DMI not present or invalid.
 19994	[    0.045777] NET: Registered protocol family 16
 19995	[    0.047360] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
 19996	[    0.047633] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
 19997	[    0.047857] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
 19998	[    0.047901] audit: initializing netlink subsys (disabled)
 19999	[    0.048064] audit: type=2000 audit(0.048:1): state=initialized audit_enabled=0 res=1
 20000	[    0.049338] thermal_sys: Registered thermal governor 'fair_share'
 20001	[    0.049347] thermal_sys: Registered thermal governor 'bang_bang'
 20002	[    0.049351] thermal_sys: Registered thermal governor 'step_wise'
 20003	[    0.049353] thermal_sys: Registered thermal governor 'user_space'
 20004	[    0.049797] cpuidle: using governor menu
 20005	[    0.050136] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
 20006	[    0.050261] ASID allocator initialised with 65536 entries
 20007	[    0.051227] Serial: AMBA PL011 UART driver
 20008	[    0.084683] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
 20009	[    0.084694] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
 20010	[    0.084700] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
 20011	[    0.084704] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
 20012	[    0.087143] cryptd: max_cpu_qlen set to 1000
 20013	[    0.156173] raid6: neonx8   gen()  2781 MB/s
 20014	[    0.224237] raid6: neonx8   xor()  2044 MB/s
 20015	[    0.292309] raid6: neonx4   gen()  3005 MB/s
 20016	[    0.360370] raid6: neonx4   xor()  2248 MB/s
 20017	[    0.428435] raid6: neonx2   gen()  2581 MB/s
 20018	[    0.496501] raid6: neonx2   xor()  2211 MB/s
 20019	[    0.564576] raid6: neonx1   gen()  2012 MB/s
 20020	[    0.632637] raid6: neonx1   xor()  1720 MB/s
 20021	[    0.700711] raid6: int64x8  gen()  1374 MB/s
 20022	[    0.768770] raid6: int64x8  xor()   735 MB/s
 20023	[    0.836864] raid6: int64x4  gen()  1463 MB/s
 20024	[    0.904912] raid6: int64x4  xor()   733 MB/s
 20025	[    0.972969] raid6: int64x2  gen()  1362 MB/s
 20026	[    1.041052] raid6: int64x2  xor()   619 MB/s
 20027	[    1.109113] raid6: int64x1  gen()  1120 MB/s
 20028	[    1.177177] raid6: int64x1  xor()   462 MB/s
 20029	[    1.177181] raid6: using algorithm neonx4 gen() 3005 MB/s
 20030	[    1.177185] raid6: .... xor() 2248 MB/s, rmw enabled
 20031	[    1.177189] raid6: using neon recovery algorithm
 20032	[    1.177631] ACPI: Interpreter disabled.
 20033	[    1.178399] 5V: supplied by 12V
 20034	[    1.179311] VDDAO_3V3: supplied by 12V
 20035	[    1.179768] iommu: Default domain type: Translated
 20036	[    1.179893] vgaarb: loaded
 20037	[    1.180631] SCSI subsystem initialized
 20038	[    1.180880] usbcore: registered new interface driver usbfs
 20039	[    1.180926] usbcore: registered new interface driver hub
 20040	[    1.180962] usbcore: registered new device driver usb
 20041	[    1.181236] pps_core: LinuxPPS API ver. 1 registered
 20042	[    1.181241] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
 20043	[    1.181262] PTP clock support registered
 20044	[    1.181464] EDAC MC: Ver: 3.0.0
 20045	[    1.182822] NetLabel: Initializing
 20046	[    1.182829] NetLabel:  domain hash size = 128
 20047	[    1.182832] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
 20048	[    1.182874] NetLabel:  unlabeled traffic allowed by default
 20049	[    1.183325] clocksource: Switched to clocksource arch_sys_counter
 20050	[    1.183537] VFS: Disk quotas dquot_6.6.0
 20051	[    1.183581] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
 20052	[    1.183946] AppArmor: AppArmor Filesystem Enabled
 20053	[    1.183993] pnp: PnP ACPI: disabled
 20054	[    1.189672] NET: Registered protocol family 2
 20055	[    1.190141] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
 20056	[    1.190246] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
 20057	[    1.190507] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
 20058	[    1.190694] TCP: Hash tables configured (established 32768 bind 32768)
 20059	[    1.190859] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
 20060	[    1.190925] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
 20061	[    1.190972] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
 20062	[    1.191121] NET: Registered protocol family 1
 20063	[    1.191141] PCI: CLS 0 bytes, default 64
 20064	[    1.191267] Trying to unpack rootfs image as initramfs...
 20065	[    1.727347] Freeing initrd memory: 13544K
 20066	[    1.728273] kvm [1]: IPA Size Limit: 40 bits
 20067	[    1.728970] kvm [1]: vgic interrupt IRQ9
 20068	[    1.729114] kvm [1]: Hyp mode initialized successfully
 20069	[    1.734181] Initialise system trusted keyrings
 20070	[    1.734214] Key type blacklist registered
 20071	[    1.734317] workingset: timestamp_bits=44 max_order=20 bucket_order=0
 20072	[    1.737522] zbud: loaded
 20073	[    1.738511] squashfs: version 4.0 (2009/01/31) Phillip Lougher
 20074	[    1.738946] fuse: init (API version 7.32)
 20075	[    1.739743] integrity: Platform Keyring initialized
 20076	[    1.768334] xor: measuring software checksum speed
 20077	[    1.771172]    8regs           :  3473 MB/sec
 20078	[    1.773632]    32regs          :  4020 MB/sec
 20079	[    1.776290]    arm64_neon      :  3719 MB/sec
 20080	[    1.776294] xor: using function: 32regs (4020 MB/sec)
 20081	[    1.776300] Key type asymmetric registered
 20082	[    1.776304] Asymmetric key parser 'x509' registered
 20083	[    1.776336] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
 20084	[    1.776415] io scheduler mq-deadline registered
 20085	[    1.776420] io scheduler kyber registered
 20086	[    1.776496] io scheduler bfq registered
 20087	[    1.779029] gpio-447 (usb-hub-reset): hogged as output/high
 20088	[    1.782004] EINJ: ACPI disabled.
 20089	[    1.788228] soc soc0: Amlogic Meson G12B (S922X) Revision 29:a (40:2) Detected
 20090	[    1.789638] VCC_3V3: supplied by VDDAO_3V3
 20091	[    1.789673] FLASH_1V8: supplied by VCC_3V3
 20092	[    1.789705] VCC_1V8: supplied by VCC_3V3
 20093	[    1.789746] VDDAO_1V8: supplied by VDDAO_3V3
 20094	[    1.789774] VDDCPU_A: supplied by regulator-dummy
 20095	[    1.790135] VDDCPU_B: supplied by regulator-dummy
 20096	[    1.790823] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
 20097	[    1.793217] Serial: AMBA driver
 20098	[    1.793499] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart
 20099	[    1.793593] printk: console [ttyAML0] enabled
 20100	[    1.794120] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 33, base_baud = 1500000) is a meson_uart
 20101	[    1.799602] loop: module loaded
 20102	[    1.801440] libphy: Fixed MDIO Bus: probed
 20103	[    1.802551] tun: Universal TUN/TAP device driver, 1.6
 20104	[    1.803202] thunder_xcv, ver 1.0
 20105	[    1.803234] thunder_bgx, ver 1.0
 20106	[    1.803264] nicpf, ver 1.0
 20107	[    1.803777] e1000e: Intel(R) PRO/1000 Network Driver
 20108	[    1.803781] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
 20109	[    1.803824] igb: Intel(R) Gigabit Ethernet Network Driver
 20110	[    1.803828] igb: Copyright (c) 2007-2014 Intel Corporation.
 20111	[    1.803860] igbvf: Intel(R) Gigabit Virtual Function Network Driver
 20112	[    1.803863] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
 20113	[    1.803996] sky2: driver version 1.30
 20114	[    1.804358] VFIO - User Level meta-driver version: 0.3
 20115	[    1.805752] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
 20116	[    1.805773] ehci-pci: EHCI PCI platform driver
 20117	[    1.805810] ehci-platform: EHCI generic platform driver
 20118	[    1.805949] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
 20119	[    1.805959] ohci-pci: OHCI PCI platform driver
 20120	[    1.805990] ohci-platform: OHCI generic platform driver
 20121	[    1.806410] usbcore: registered new interface driver usb-storage
 20122	[    1.807836] mousedev: PS/2 mouse device common for all mice
 20123	[    1.808242] i2c /dev entries driver
 20124	[    1.813340] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17
 20125	[    1.813998] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz
 20126	[    1.814692] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-1 failed:-17
 20127	[    1.815349] sdhci: Secure Digital Host Controller Interface driver
 20128	[    1.815355] sdhci: Copyright(c) Pierre Ossman
 20129	[    1.815892] Synopsys Designware Multimedia Card Interface Driver
 20130	[    1.816391] sdhci-pltfm: SDHCI platform and OF driver helper
 20131	[    1.816813] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq
 20132	[    1.817306] ledtrig-cpu: registered to indicate activity on CPUs
 20133	[    1.817584] meson-sm: secure-monitor enabled
 20134	[    1.817772] hid: raw HID events driver (C) Jiri Kosina
 20135	[    1.817857] usbcore: registered new interface driver usbhid
 20136	[    1.817860] usbhid: USB HID core driver
 20137	[    1.818851] NET: Registered protocol family 10
 20138	[    1.819240] Segment Routing with IPv6
 20139	[    1.819273] NET: Registered protocol family 17
 20140	[    1.819338] 8021q: 802.1Q VLAN Support v1.8
 20141	[    1.819362] Key type dns_resolver registered
 20142	[    1.819663] registered taskstats version 1
 20143	[    1.819669] Loading compiled-in X.509 certificates
 20144	[    1.821350] Loaded X.509 cert 'Build time autogenerated kernel key: f47c178852ca39740c3546b008122b65f5ed9bce'
 20145	[    1.822908] zswap: loaded using pool zstd/z3fold
 20146	[    1.823070] Key type ._fscrypt registered
 20147	[    1.823072] Key type .fscrypt registered
 20148	[    1.823074] Key type fscrypt-provisioning registered
 20149	[    1.824695] Btrfs loaded, crc32c=crc32c-generic
 20150	[    1.831022] Key type encrypted registered
 20151	[    1.831039] AppArmor: AppArmor sha1 policy hashing enabled
 20152	[    1.837255] HUB_5V: supplied by 5V
 20153	[    1.837480] USB_PWR_EN: supplied by 5V
 20154	[    1.839128] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2
 20155	[    1.839136] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1
 20156	[    1.841826] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator
 20157	[    1.841879] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator
 20158	[    1.841983] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM
 20159	[    1.842552] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
 20160	[    1.842568] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
 20161	[    1.842654] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010
 20162	[    1.842677] xhci-hcd xhci-hcd.0.auto: irq 41, io mem 0xff500000
 20163	[    1.842800] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
 20164	[    1.842803] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 20165	[    1.842807] usb usb1: Product: xHCI Host Controller
 20166	[    1.842809] usb usb1: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
 20167	[    1.842811] usb usb1: SerialNumber: xhci-hcd.0.auto
 20168	[    1.843162] hub 1-0:1.0: USB hub found
 20169	[    1.843181] hub 1-0:1.0: 2 ports detected
 20170	[    1.843389] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
 20171	[    1.843397] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
 20172	[    1.843404] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
 20173	[    1.843435] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
 20174	[    1.843469] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
 20175	[    1.843472] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 20176	[    1.843475] usb usb2: Product: xHCI Host Controller
 20177	[    1.843477] usb usb2: Manufacturer: Linux 5.10.12-meson64 xhci-hcd
 20178	[    1.843479] usb usb2: SerialNumber: xhci-hcd.0.auto
 20179	[    1.843725] hub 2-0:1.0: USB hub found
 20180	[    1.843736] hub 2-0:1.0: 1 port detected
 20181	[    1.845041] meson-gx-mmc ffe05000.sd: Got CD GPIO
 20182	[    1.872387] Freeing unused kernel memory: 3328K
 20183	[    1.903446] Run /init as init process
 20184	[    1.903449]   with arguments:
 20185	[    1.903452]     /init
 20186	[    1.903454]   with environment:
 20187	[    1.903456]     HOME=/
 20188	[    1.903457]     TERM=linux
 20189	[    1.903460]     hdmimode=1080p60hz
 20190	[    1.903461]     cvbsmode=576cvbs
 20191	[    1.903463]     max_freq_a53=1896
 20192	[    1.903465]     max_freq_a73=1800
 20193	[    1.903466]     voutmode=hdmi
 20194	[    1.903467]     disablehpd=false
 20195	[    1.903469]     cvbscable=0
 20196	[    1.903470]     overscan=100
 20197	[    1.938419] mmc0: new ultra high speed SDR25 SDHC card at address b368
 20198	[    1.939306] mmcblk0: mmc0:b368 CBADS 30.0 GiB
 20199	[    1.941271]  mmcblk0: p1
 20200	[    2.067579] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found
 20201	[    2.067589] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found
 20202	[    2.067722] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock
 20203	[    2.068262] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37
 20204	[    2.068275] meson8b-dwmac ff3f0000.ethernet: 	DWMAC1000
 20205	[    2.068280] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported
 20206	[    2.068283] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported
 20207	[    2.068286] meson8b-dwmac ff3f0000.ethernet: COE Type 2
 20208	[    2.068288] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported
 20209	[    2.068290] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported
 20210	[    2.068368] meson8b-dwmac ff3f0000.ethernet: Normal descriptors
 20211	[    2.068373] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled
 20212	[    2.068375] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
 20213	[    2.068586] libphy: stmmac: probed
 20214	[    2.072157] libphy: mdio_mux: probed
 20215	[    2.079500] meson-vrtc ff8000a8.rtc: registered as rtc1
 20216	[    2.096332] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
 20217	[    2.096474] rtc-pcf8563 1-0051: registered as rtc0
 20218	[    2.097644] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
 20219	[    2.097649] rtc-pcf8563 1-0051: hctosys: unable to read the hardware clock
 20220	[    2.102426] random: fast init done
 20221	[    2.175358] usb 1-1: new high-speed USB device number 2 using xhci-hcd
 20222	[    2.279747] libphy: mdio_mux: probed
 20223	[    2.325703] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.04
 20224	[    2.325713] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
 20225	[    2.325716] usb 1-1: Product: USB2.1 Hub
 20226	[    2.325720] usb 1-1: Manufacturer: GenesysLogic
 20227	[    2.387715] hub 1-1:1.0: USB hub found
 20228	[    2.387976] hub 1-1:1.0: 4 ports detected
 20229	[    2.451525] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
 20230	[    2.473940] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.04
 20231	[    2.473946] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
 20232	[    2.473949] usb 2-1: Product: USB3.1 Hub
 20233	[    2.473951] usb 2-1: Manufacturer: GenesysLogic
 20234	[    2.499625] hub 2-1:1.0: USB hub found
 20235	[    2.499907] hub 2-1:1.0: 4 ports detected
 20236	[    3.449925] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
 20237	[    4.217892] systemd[1]: System time before build time, advancing clock.
 20238	[    4.232803] systemd[1]: Inserted module 'autofs4'
 20239	[    4.279405] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
 20240	[    4.279618] systemd[1]: Detected architecture arm64.
 20241	[    4.313034] systemd[1]: Set hostname to <odroidn2>.
 20242	[    4.714730] random: systemd: uninitialized urandom read (16 bytes read)
 20243	[    4.720709] random: systemd: uninitialized urandom read (16 bytes read)
 20244	[    4.721194] systemd[1]: Listening on Journal Audit Socket.
 20245	[    4.721618] random: systemd: uninitialized urandom read (16 bytes read)
 20246	[    4.722037] systemd[1]: Listening on udev Control Socket.
 20247	[    4.723925] systemd[1]: Created slice User and Session Slice.
 20248	[    4.724218] systemd[1]: Reached target Slices.
 20249	[    4.724683] systemd[1]: Listening on udev Kernel Socket.
 20250	[    4.725120] systemd[1]: Listening on initctl Compatibility Named Pipe.
 20251	[    4.725416] systemd[1]: Reached target System Time Synchronized.
 20252	[    4.849576] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
 20253	[    5.360181] zram: Added device: zram0
 20254	[    5.360631] zram: Added device: zram1
 20255	[    5.360975] zram: Added device: zram2
 20256	[    5.370318] pwm-gpio pwmgpio: 1 gpio pwms loaded
 20257	[    5.529791] meson-saradc ff809000.adc: supply vref not found, using dummy regulator
 20258	[    5.537291] mc: Linux media interface: v0.10
 20259	[    5.599233] panfrost ffe40000.gpu: clock rate = 24000000
 20260	[    5.599302] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19
 20261	[    5.600196] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0
 20262	[    5.600206] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400
 20263	[    5.600211] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
 20264	[    5.600215] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1
 20265	[    5.614650] videodev: Linux video capture interface: v2.00
 20266	[    5.614851] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 0
 20267	[    5.651368] Registered IR keymap rc-odroid
 20268	[    5.655777] meson-drm ff900000.vpu: Queued 2 outputs on vpu
 20269	[    5.680606] IR NEC protocol handler initialized
 20270	[    5.701947] meson-drm ff900000.vpu: CVBS Output connector not available
 20271	[    5.707455] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0
 20272	[    5.707599] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
 20273	[    5.707697] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input0
 20274	[    5.707932] meson-ir ff808000.ir: receiver initialized
 20275	[    5.728172] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
 20276	[    5.730173] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
 20277	[    5.730444] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
 20278	[    5.730668] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 1
 20279	[    5.730720] meson-drm ff900000.vpu: [drm] Cannot find any crtc or sizes
 20280	[    5.751145] zram0: detected capacity change from 0 to 1904500736
 20281	[    5.832434] axg-sound-card sound: ASoC: no DMI vendor name!
 20282	[    5.833095] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
 20283	[    6.843330] Adding 1859860k swap on /dev/zram0.  Priority:5 extents:1 across:1859860k SSFS
 20284	[    6.909771] zram1: detected capacity change from 0 to 52428800
 20285	[    9.010090] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
 20286	[    9.010108] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
 20287	[   10.237614] systemd[1]: Started Armbian memory supported logging.
 20288	[   10.239936] systemd[1]: Starting Journal Service...
 20289	[   10.299138] systemd[1]: Started Journal Service.
 20290	[   10.323982] systemd-journald[1815]: Received request to flush runtime journal from PID 1
 20291
 20292	### armbian-release:
 20293
 20294	# PLEASE DO NOT EDIT THIS FILE
 20295	BOARD=odroidn2
 20296	BOARD_NAME="Odroid N2"
 20297	BOARDFAMILY=meson-g12b
 20298	BUILD_REPOSITORY_URL=https://github.com/armbian/build
 20299	BUILD_REPOSITORY_COMMIT=5f03d652
 20300	DISTRIBUTION_CODENAME=buster
 20301	DISTRIBUTION_STATUS=supported
 20302	VERSION=21.02.1
 20303	LINUXFAMILY=meson64
 20304	BRANCH=current
 20305	ARCH=arm64
 20306	IMAGE_TYPE=stable
 20307	BOARD_TYPE=conf
 20308	INITRD_ARCH=arm64
 20309	KERNEL_IMAGE_TYPE=Image
 20310
 20311	### boot environment:
 20312
 20313	verbosity=1
 20314	console=both
 20315	overlay_prefix=meson
 20316	rootdev=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c
 20317	rootfstype=ext4
 20318	usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
 20319
 20320	### lsusb:
 20321
 20322	Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc.
 20323	Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
 20324	Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
 20325	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
 20326
 20327	### lscpu:
 20328
 20329	Architecture:        aarch64
 20330	Byte Order:          Little Endian
 20331	CPU(s):              6
 20332	On-line CPU(s) list: 0-5
 20333	Thread(s) per core:  1
 20334	Core(s) per socket:  3
 20335	Socket(s):           2
 20336	NUMA node(s):        1
 20337	Vendor ID:           ARM
 20338	Model:               4
 20339	Model name:          Cortex-A53
 20340	Stepping:            r0p4
 20341	CPU max MHz:         1992.0000
 20342	CPU min MHz:         100.0000
 20343	BogoMIPS:            48.00
 20344	L1d cache:           unknown size
 20345	L1i cache:           unknown size
 20346	L2 cache:            unknown size
 20347	NUMA node0 CPU(s):   0-5
 20348	Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 20349
 20350	### cpuinfo:
 20351
 20352	processor	: 0
 20353	BogoMIPS	: 48.00
 20354	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 20355	CPU implementer	: 0x41
 20356	CPU architecture: 8
 20357	CPU variant	: 0x0
 20358	CPU part	: 0xd03
 20359	CPU revision	: 4
 20360
 20361	processor	: 1
 20362	BogoMIPS	: 48.00
 20363	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 20364	CPU implementer	: 0x41
 20365	CPU architecture: 8
 20366	CPU variant	: 0x0
 20367	CPU part	: 0xd03
 20368	CPU revision	: 4
 20369
 20370	processor	: 2
 20371	BogoMIPS	: 48.00
 20372	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 20373	CPU implementer	: 0x41
 20374	CPU architecture: 8
 20375	CPU variant	: 0x0
 20376	CPU part	: 0xd09
 20377	CPU revision	: 2
 20378
 20379	processor	: 3
 20380	BogoMIPS	: 48.00
 20381	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 20382	CPU implementer	: 0x41
 20383	CPU architecture: 8
 20384	CPU variant	: 0x0
 20385	CPU part	: 0xd09
 20386	CPU revision	: 2
 20387
 20388	processor	: 4
 20389	BogoMIPS	: 48.00
 20390	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 20391	CPU implementer	: 0x41
 20392	CPU architecture: 8
 20393	CPU variant	: 0x0
 20394	CPU part	: 0xd09
 20395	CPU revision	: 2
 20396
 20397	processor	: 5
 20398	BogoMIPS	: 48.00
 20399	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 20400	CPU implementer	: 0x41
 20401	CPU architecture: 8
 20402	CPU variant	: 0x0
 20403	CPU part	: 0xd09
 20404	CPU revision	: 2
 20405
 20406
 20407	### meminfo:
 20408
 20409	MemTotal:        3719728 kB
 20410	MemFree:         3388812 kB
 20411	MemAvailable:    3344000 kB
 20412	Buffers:           11840 kB
 20413	Cached:            47440 kB
 20414	SwapCached:            0 kB
 20415	Active:            29736 kB
 20416	Inactive:         201112 kB
 20417	Active(anon):        112 kB
 20418	Inactive(anon):   176540 kB
 20419	Active(file):      29624 kB
 20420	Inactive(file):    24572 kB
 20421	Unevictable:           0 kB
 20422	Mlocked:               0 kB
 20423	SwapTotal:       1859860 kB
 20424	SwapFree:        1859860 kB
 20425	Dirty:              8272 kB
 20426	Writeback:             0 kB
 20427	AnonPages:        171804 kB
 20428	Mapped:            11072 kB
 20429	Shmem:              4940 kB
 20430	KReclaimable:      12892 kB
 20431	Slab:              38800 kB
 20432	SReclaimable:      12892 kB
 20433	SUnreclaim:        25908 kB
 20434	KernelStack:        2048 kB
 20435	PageTables:         5080 kB
 20436	NFS_Unstable:          0 kB
 20437	Bounce:                0 kB
 20438	WritebackTmp:          0 kB
 20439	CommitLimit:     3719724 kB
 20440	Committed_AS:    4210504 kB
 20441	VmallocTotal:   135290159040 kB
 20442	VmallocUsed:       30880 kB
 20443	VmallocChunk:          0 kB
 20444	Percpu:             1368 kB
 20445	HardwareCorrupted:     0 kB
 20446	AnonHugePages:         0 kB
 20447	ShmemHugePages:        0 kB
 20448	ShmemPmdMapped:        0 kB
 20449	FileHugePages:         0 kB
 20450	FilePmdMapped:         0 kB
 20451	CmaTotal:         917504 kB
 20452	CmaFree:          909824 kB
 20453	HugePages_Total:       0
 20454	HugePages_Free:        0
 20455	HugePages_Rsvd:        0
 20456	HugePages_Surp:        0
 20457	Hugepagesize:       2048 kB
 20458	Hugetlb:               0 kB
 20459
 20460	### virtual memory:
 20461
 20462	vm.admin_reserve_kbytes = 8192
 20463	vm.block_dump = 0
 20464	vm.compaction_proactiveness = 20
 20465	vm.compact_unevictable_allowed = 1
 20466	vm.dirty_background_bytes = 0
 20467	vm.dirty_background_ratio = 10
 20468	vm.dirty_bytes = 0
 20469	vm.dirty_expire_centisecs = 3000
 20470	vm.dirty_ratio = 20
 20471	vm.dirtytime_expire_seconds = 43200
 20472	vm.dirty_writeback_centisecs = 500
 20473	vm.extfrag_threshold = 500
 20474	vm.hugetlb_shm_group = 0
 20475	vm.laptop_mode = 0
 20476	vm.legacy_va_layout = 0
 20477	vm.lowmem_reserve_ratio = 256	256	32	0
 20478	vm.max_map_count = 65530
 20479	vm.memory_failure_early_kill = 0
 20480	vm.memory_failure_recovery = 1
 20481	vm.min_free_kbytes = 45056
 20482	vm.min_slab_ratio = 5
 20483	vm.min_unmapped_ratio = 1
 20484	vm.mmap_min_addr = 4096
 20485	vm.mmap_rnd_bits = 18
 20486	vm.mmap_rnd_compat_bits = 11
 20487	vm.nr_hugepages = 0
 20488	vm.nr_hugepages_mempolicy = 0
 20489	vm.nr_overcommit_hugepages = 0
 20490	vm.numa_stat = 1
 20491	vm.numa_zonelist_order = Node
 20492	vm.oom_dump_tasks = 1
 20493	vm.oom_kill_allocating_task = 0
 20494	vm.overcommit_kbytes = 0
 20495	vm.overcommit_memory = 0
 20496	vm.overcommit_ratio = 50
 20497	vm.page-cluster = 0
 20498	vm.page_lock_unfairness = 5
 20499	vm.panic_on_oom = 0
 20500	vm.percpu_pagelist_fraction = 0
 20501	vm.stat_interval = 1
 20502	vm.swappiness = 100
 20503	vm.user_reserve_kbytes = 114956
 20504	vm.vfs_cache_pressure = 100
 20505	vm.watermark_boost_factor = 15000
 20506	vm.watermark_scale_factor = 10
 20507	vm.zone_reclaim_mode = 0
 20508
 20509	### ip addr:
 20510
 20511	1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
 20512	    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
 20513	    inet XXX.XXX.0.1/8 scope host lo
 20514	       valid_lft forever preferred_lft forever
 20515	    inet6 ::1/128 scope host
 20516	       valid_lft forever preferred_lft forever
 20517	2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
 20518	    link/ether 00:1e:06:42:03:f8 brd ff:ff:ff:ff:ff:ff
 20519
 20520	### partitions:
 20521
 20522	major minor  #blocks  name
 20523
 20524	 179        0   31464960 mmcblk0
 20525	 179        1   31146208 mmcblk0p1
 20526	 252        0    1859864 zram0
 20527	 252        1      51200 zram1
 20528
 20529	### df:
 20530
 20531	udev            1.4G     0  1.4G   0% /dev
 20532	tmpfs           364M  4.9M  359M   2% /run
 20533	/dev/mmcblk0p1   30G  1.8G   28G   6% /
 20534	tmpfs           1.8G     0  1.8G   0% /dev/shm
 20535	tmpfs           5.0M  4.0K  5.0M   1% /run/lock
 20536	tmpfs           1.8G     0  1.8G   0% /sys/fs/cgroup
 20537	tmpfs           1.8G     0  1.8G   0% /tmp
 20538	/dev/zram1       49M  8.1M   37M  18% /var/log
 20539
 20540	### lsblk:
 20541
 20542	NAME        FSTYPE  SIZE MOUNTPOINT UUID
 20543	mmcblk0              30G
 20544	└─mmcblk0p1 ext4   29.7G /          bd34953d-41be-49d6-b1c0-c0c28a5e239c
 20545	zram1                50M /var/log
 20546
 20547	### zramctl:
 20548
 20549	NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
 20550	/dev/zram1 zstd           50M  132K  698B   36K       6 /var/log
 20551	/dev/zram0 lzo-rle       1.8G    4K   74B   12K       6 [SWAP]
 20552
 20553	### mtab:
 20554
 20555	/dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
 20556	/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
 20557	/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
 20558
 20559	### mmc0:b368 info:
 20560
 20561	               fwrev: 0x0
 20562	              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=CBADS MODALIAS=mmc:block
 20563	                 cid: 6f0303434241445310aa002b4d013b00
 20564	                 rca: 0xb368
 20565	                 csd: 400e005a5b590000f00e7f800a404000
 20566	              manfid: 0x00006f
 20567	                 ocr: 0x00200000
 20568	preferred_erase_size: 2097152
 20569	                type: SD
 20570	               hwrev: 0x1
 20571	                date: 11/2019
 20572	                 dsr: 0x404
 20573	          erase_size: 512
 20574	               oemid: 0x0303
 20575	              serial: 0xaa002b4d
 20576	                 ssr: 00000000000000280402800100fd180a001e00000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
 20577	                 scr: 02b5800300000000
 20578	                name: CBADS
 20579
 20580	### Boot system health:
 20581
 20582	Time       big.LITTLE   load %cpu %sys %usr %nice %io %irq   CPU  C.St.
 20583	16:23:03: 1908/1992MHz  0.37  23%  10%   5%   0%   7%   0% 25.9°C  0/11
 20584	16:23:03: 1908/1992MHz  0.37  79%  38%   8%   0%  32%   0% 25.2°C  0/11
 20585	16:23:04: 1908/1992MHz  0.37  53%  10%   2%   0%  39%   0% 23.4°C  0/11
 20586	16:23:04: 1908/1000MHz  0.37  60%   8%   6%   0%  44%   1% 23.2°C  0/11
 20587	16:23:04: 1908/1992MHz  0.37  42%   1%   2%   1%  37%   0% 22.2°C  0/11
 20588
 20589	### Activated 1 lzo-rle zram swap devices with 1848 MB each
 20590
 20591	### Activated Armbian ramlog partition with zstd compression
 20592
 20593	Mon 03 May 2021 12:20:25 PM BST | Odroid N2 | 21.02.4 | arm64 | aarch64 | 5.10.27-meson64
 20594
 20595	### dmesg:
 20596
 20597	[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
 20598	[    0.000000] Linux version 5.10.27-meson64 (root@hirsute) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #21.02.4 SMP PREEMPT Sun Apr 4 09:23:42 UTC 2021
 20599	[    0.000000] Machine model: Hardkernel ODROID-N2
 20600	[    0.000000] efi: UEFI not found.
 20601	[    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
 20602	[    0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB
 20603	[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
 20604	[    0.000000] NUMA: No NUMA configuration found
 20605	[    0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ed7fffff]
 20606	[    0.000000] NUMA: NODE_DATA [mem 0xb502f100-0xb5030fff]
 20607	[    0.000000] Zone ranges:
 20608	[    0.000000]   DMA      [mem 0x0000000000000000-0x00000000ed7fffff]
 20609	[    0.000000]   DMA32    empty
 20610	[    0.000000]   Normal   empty
 20611	[    0.000000] Movable zone start for each node
 20612	[    0.000000] Early memory node ranges
 20613	[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000004ffffff]
 20614	[    0.000000]   node   0: [mem 0x0000000005000000-0x00000000052fffff]
 20615	[    0.000000]   node   0: [mem 0x0000000005300000-0x00000000ed7fffff]
 20616	[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ed7fffff]
 20617	[    0.000000] On node 0 totalpages: 972800
 20618	[    0.000000]   DMA zone: 15200 pages used for memmap
 20619	[    0.000000]   DMA zone: 0 pages reserved
 20620	[    0.000000]   DMA zone: 972800 pages, LIFO batch:63
 20621	[    0.000000] psci: probing for conduit method from DT.
 20622	[    0.000000] psci: PSCIv1.0 detected in firmware.
 20623	[    0.000000] psci: Using standard PSCI v0.2 function IDs
 20624	[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
 20625	[    0.000000] psci: SMC Calling Convention v1.1
 20626	[    0.000000] percpu: Embedded 23 pages/cpu s56728 r8192 d29288 u94208
 20627	[    0.000000] pcpu-alloc: s56728 r8192 d29288 u94208 alloc=23*4096
 20628	[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
 20629	[    0.000000] Detected VIPT I-cache on CPU0
 20630	[    0.000000] CPU features: detected: ARM erratum 845719
 20631	[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 957600
 20632	[    0.000000] Policy zone: DMA
 20633	[    0.000000] Kernel command line: root=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c rootwait rootfstype=ext4 console=ttyAML0,115200n8 console=tty1 loglevel=1  no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=1080p60hz cvbsmode=576cvbs max_freq_a53=1896 max_freq_a73=1800 maxcpus=6 voutmode=hdmi  disablehpd=false  cvbscable=0 overscan=100 consoleblank=0
 20634	[    0.000000] Kernel parameter elevator= does not have any effect anymore.
 20635	               Please use sysfs to set IO scheduler for individual devices.
 20636	[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
 20637	[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
 20638	[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
 20639	[    0.000000] Memory: 2851276K/3891200K available (14144K kernel code, 1760K rwdata, 5512K rodata, 3328K init, 592K bss, 122420K reserved, 917504K cma-reserved)
 20640	[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
 20641	[    0.000000] rcu: Preemptible hierarchical RCU implementation.
 20642	[    0.000000] rcu: 	RCU event tracing is enabled.
 20643	[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
 20644	[    0.000000] 	Trampoline variant of Tasks RCU enabled.
 20645	[    0.000000] 	Rude variant of Tasks RCU enabled.
 20646	[    0.000000] 	Tracing variant of Tasks RCU enabled.
 20647	[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
 20648	[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
 20649	[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
 20650	[    0.000000] GIC: Using split EOI/Deactivate mode
 20651	[    0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized
 20652	[    0.000000] random: get_random_bytes called from start_kernel+0x378/0x538 with crng_init=0
 20653	[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
 20654	[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
 20655	[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
 20656	[    0.000241] Console: colour dummy device 80x25
 20657	[    0.000273] printk: console [tty1] enabled
 20658	[    0.000356] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
 20659	[    0.000367] pid_max: default: 32768 minimum: 301
 20660	[    0.000451] LSM: Security Framework initializing
 20661	[    0.000475] Yama: becoming mindful.
 20662	[    0.000563] AppArmor: AppArmor initialized
 20663	[    0.000615] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
 20664	[    0.000634] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
 20665	[    0.002626] rcu: Hierarchical SRCU implementation.
 20666	[    0.005021] EFI services will not be available.
 20667	[    0.005441] smp: Bringing up secondary CPUs ...
 20668	[    0.006112] Detected VIPT I-cache on CPU1
 20669	[    0.006172] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
 20670	[    0.007369] CPU features: detected: ARM erratum 858921
 20671	[    0.007377] CPU features: detected: Spectre-v2
 20672	[    0.007381] CPU features: detected: Spectre-v4
 20673	[    0.007387] Detected VIPT I-cache on CPU2
 20674	[    0.007412] arch_timer: Enabling local workaround for ARM erratum 858921
 20675	[    0.007428] arch_timer: CPU2: Trapping CNTVCT access
 20676	[    0.007442] CPU2: Booted secondary processor 0x0000000100 [0x410fd092]
 20677	[    0.008150] Detected VIPT I-cache on CPU3
 20678	[    0.008166] arch_timer: Enabling local workaround for ARM erratum 858921
 20679	[    0.008173] arch_timer: CPU3: Trapping CNTVCT access
 20680	[    0.008181] CPU3: Booted secondary processor 0x0000000101 [0x410fd092]
 20681	[    0.008810] Detected VIPT I-cache on CPU4
 20682	[    0.008827] arch_timer: Enabling local workaround for ARM erratum 858921
 20683	[    0.008834] arch_timer: CPU4: Trapping CNTVCT access
 20684	[    0.008842] CPU4: Booted secondary processor 0x0000000102 [0x410fd092]
 20685	[    0.009463] Detected VIPT I-cache on CPU5
 20686	[    0.009479] arch_timer: Enabling local workaround for ARM erratum 858921
 20687	[    0.009486] arch_timer: CPU5: Trapping CNTVCT access
 20688	[    0.009494] CPU5: Booted secondary processor 0x0000000103 [0x410fd092]
 20689	[    0.009575] smp: Brought up 1 node, 6 CPUs
 20690	[    0.009592] SMP: Total of 6 processors activated.
 20691	[    0.009600] CPU features: detected: 32-bit EL0 Support
 20692	[    0.009606] CPU features: detected: CRC32 instructions
 20693	[    0.009612] CPU features: detected: 32-bit EL1 Support
 20694	[    0.020917] CPU: All CPU(s) started at EL2
 20695	[    0.020966] alternatives: patching kernel code
 20696	[    0.022248] devtmpfs: initialized
 20697	[    0.029840] Registered cp15_barrier emulation handler
 20698	[    0.029854] Registered setend emulation handler
 20699	[    0.030022] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
 20700	[    0.030065] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
 20701	[    0.046136] pinctrl core: initialized pinctrl subsystem
 20702	[    0.046708] DMI not present or invalid.
 20703	[    0.047086] NET: Registered protocol family 16
 20704	[    0.048780] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
 20705	[    0.049012] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
 20706	[    0.049308] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
 20707	[    0.049349] audit: initializing netlink subsys (disabled)
 20708	[    0.049449] audit: type=2000 audit(0.048:1): state=initialized audit_enabled=0 res=1
 20709	[    0.050849] thermal_sys: Registered thermal governor 'fair_share'
 20710	[    0.050856] thermal_sys: Registered thermal governor 'bang_bang'
 20711	[    0.050860] thermal_sys: Registered thermal governor 'step_wise'
 20712	[    0.050864] thermal_sys: Registered thermal governor 'user_space'
 20713	[    0.051265] cpuidle: using governor menu
 20714	[    0.051625] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
 20715	[    0.051744] ASID allocator initialised with 65536 entries
 20716	[    0.052689] Serial: AMBA PL011 UART driver
 20717	[    0.086722] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
 20718	[    0.086734] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
 20719	[    0.086740] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
 20720	[    0.086745] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
 20721	[    0.088443] cryptd: max_cpu_qlen set to 1000
 20722	[    0.156243] raid6: neonx8   gen()  2785 MB/s
 20723	[    0.224319] raid6: neonx8   xor()  1599 MB/s
 20724	[    0.292358] raid6: neonx4   gen()  3152 MB/s
 20725	[    0.360433] raid6: neonx4   xor()  2328 MB/s
 20726	[    0.428502] raid6: neonx2   gen()  2559 MB/s
 20727	[    0.496578] raid6: neonx2   xor()  2173 MB/s
 20728	[    0.564653] raid6: neonx1   gen()  1998 MB/s
 20729	[    0.632714] raid6: neonx1   xor()  1728 MB/s
 20730	[    0.700785] raid6: int64x8  gen()  1380 MB/s
 20731	[    0.768850] raid6: int64x8  xor()   736 MB/s
 20732	[    0.836936] raid6: int64x4  gen()  1463 MB/s
 20733	[    0.904975] raid6: int64x4  xor()   733 MB/s
 20734	[    0.973039] raid6: int64x2  gen()  1362 MB/s
 20735	[    1.041112] raid6: int64x2  xor()   619 MB/s
 20736	[    1.109177] raid6: int64x1  gen()  1127 MB/s
 20737	[    1.177248] raid6: int64x1  xor()   462 MB/s
 20738	[    1.177251] raid6: using algorithm neonx4 gen() 3152 MB/s
 20739	[    1.177254] raid6: .... xor() 2328 MB/s, rmw enabled
 20740	[    1.177258] raid6: using neon recovery algorithm
 20741	[    1.177732] ACPI: Interpreter disabled.
 20742	[    1.178569] 5V: supplied by 12V
 20743	[    1.179464] VDDAO_3V3: supplied by 12V
 20744	[    1.179955] iommu: Default domain type: Translated
 20745	[    1.180134] vgaarb: loaded
 20746	[    1.181073] SCSI subsystem initialized
 20747	[    1.181304] usbcore: registered new interface driver usbfs
 20748	[    1.181342] usbcore: registered new interface driver hub
 20749	[    1.181387] usbcore: registered new device driver usb
 20750	[    1.181696] pps_core: LinuxPPS API ver. 1 registered
 20751	[    1.181702] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
 20752	[    1.181722] PTP clock support registered
 20753	[    1.181905] EDAC MC: Ver: 3.0.0
 20754	[    1.183239] NetLabel: Initializing
 20755	[    1.183246] NetLabel:  domain hash size = 128
 20756	[    1.183249] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
 20757	[    1.183290] NetLabel:  unlabeled traffic allowed by default
 20758	[    1.183710] clocksource: Switched to clocksource arch_sys_counter
 20759	[    1.183913] VFS: Disk quotas dquot_6.6.0
 20760	[    1.183960] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
 20761	[    1.184309] AppArmor: AppArmor Filesystem Enabled
 20762	[    1.184354] pnp: PnP ACPI: disabled
 20763	[    1.189439] NET: Registered protocol family 2
 20764	[    1.189896] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
 20765	[    1.190003] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
 20766	[    1.190259] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
 20767	[    1.190446] TCP: Hash tables configured (established 32768 bind 32768)
 20768	[    1.190595] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
 20769	[    1.190660] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
 20770	[    1.190710] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
 20771	[    1.190855] NET: Registered protocol family 1
 20772	[    1.190874] PCI: CLS 0 bytes, default 64
 20773	[    1.190998] Trying to unpack rootfs image as initramfs...
 20774	[    1.720689] Freeing initrd memory: 13540K
 20775	[    1.721615] kvm [1]: IPA Size Limit: 40 bits
 20776	[    1.722334] kvm [1]: vgic interrupt IRQ9
 20777	[    1.722465] kvm [1]: Hyp mode initialized successfully
 20778	[    1.727650] Initialise system trusted keyrings
 20779	[    1.727683] Key type blacklist registered
 20780	[    1.727828] workingset: timestamp_bits=44 max_order=20 bucket_order=0
 20781	[    1.730995] zbud: loaded
 20782	[    1.731923] squashfs: version 4.0 (2009/01/31) Phillip Lougher
 20783	[    1.732460] fuse: init (API version 7.32)
 20784	[    1.733240] integrity: Platform Keyring initialized
 20785	[    1.761070] xor: measuring software checksum speed
 20786	[    1.763936]    8regs           :  3476 MB/sec
 20787	[    1.766385]    32regs          :  4022 MB/sec
 20788	[    1.769045]    arm64_neon      :  3712 MB/sec
 20789	[    1.769048] xor: using function: 32regs (4022 MB/sec)
 20790	[    1.769057] Key type asymmetric registered
 20791	[    1.769061] Asymmetric key parser 'x509' registered
 20792	[    1.769098] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
 20793	[    1.769204] io scheduler mq-deadline registered
 20794	[    1.769208] io scheduler kyber registered
 20795	[    1.769285] io scheduler bfq registered
 20796	[    1.771838] gpio-447 (usb-hub-reset): hogged as output/high
 20797	[    1.774876] EINJ: ACPI disabled.
 20798	[    1.781171] soc soc0: Amlogic Meson G12B (S922X) Revision 29:a (40:2) Detected
 20799	[    1.782543] VCC_3V3: supplied by VDDAO_3V3
 20800	[    1.782575] FLASH_1V8: supplied by VCC_3V3
 20801	[    1.782622] VCC_1V8: supplied by VCC_3V3
 20802	[    1.782649] VDDAO_1V8: supplied by VDDAO_3V3
 20803	[    1.782676] VDDCPU_A: supplied by regulator-dummy
 20804	[    1.783023] VDDCPU_B: supplied by regulator-dummy
 20805	[    1.783734] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
 20806	[    1.786059] Serial: AMBA driver
 20807	[    1.786353] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart
 20808	[    1.786447] printk: console [ttyAML0] enabled
 20809	[    1.786973] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 33, base_baud = 1500000) is a meson_uart
 20810	[    1.792382] loop: module loaded
 20811	[    1.794203] libphy: Fixed MDIO Bus: probed
 20812	[    1.795179] tun: Universal TUN/TAP device driver, 1.6
 20813	[    1.795915] thunder_xcv, ver 1.0
 20814	[    1.795947] thunder_bgx, ver 1.0
 20815	[    1.795972] nicpf, ver 1.0
 20816	[    1.796455] e1000e: Intel(R) PRO/1000 Network Driver
 20817	[    1.796458] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
 20818	[    1.796499] igb: Intel(R) Gigabit Ethernet Network Driver
 20819	[    1.796502] igb: Copyright (c) 2007-2014 Intel Corporation.
 20820	[    1.796538] igbvf: Intel(R) Gigabit Virtual Function Network Driver
 20821	[    1.796541] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
 20822	[    1.796664] sky2: driver version 1.30
 20823	[    1.797025] VFIO - User Level meta-driver version: 0.3
 20824	[    1.798408] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
 20825	[    1.798424] ehci-pci: EHCI PCI platform driver
 20826	[    1.798456] ehci-platform: EHCI generic platform driver
 20827	[    1.798585] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
 20828	[    1.798594] ohci-pci: OHCI PCI platform driver
 20829	[    1.798623] ohci-platform: OHCI generic platform driver
 20830	[    1.799027] usbcore: registered new interface driver usb-storage
 20831	[    1.800346] mousedev: PS/2 mouse device common for all mice
 20832	[    1.800743] i2c /dev entries driver
 20833	[    1.805963] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17
 20834	[    1.806615] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz
 20835	[    1.807294] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-1 failed:-17
 20836	[    1.807933] sdhci: Secure Digital Host Controller Interface driver
 20837	[    1.807937] sdhci: Copyright(c) Pierre Ossman
 20838	[    1.808055] Synopsys Designware Multimedia Card Interface Driver
 20839	[    1.808497] sdhci-pltfm: SDHCI platform and OF driver helper
 20840	[    1.808931] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq
 20841	[    1.809391] ledtrig-cpu: registered to indicate activity on CPUs
 20842	[    1.809821] meson-sm: secure-monitor enabled
 20843	[    1.810030] hid: raw HID events driver (C) Jiri Kosina
 20844	[    1.810122] usbcore: registered new interface driver usbhid
 20845	[    1.810123] usbhid: USB HID core driver
 20846	[    1.811135] NET: Registered protocol family 10
 20847	[    1.811568] Segment Routing with IPv6
 20848	[    1.811595] NET: Registered protocol family 17
 20849	[    1.811657] 8021q: 802.1Q VLAN Support v1.8
 20850	[    1.811684] Key type dns_resolver registered
 20851	[    1.812253] registered taskstats version 1
 20852	[    1.812259] Loading compiled-in X.509 certificates
 20853	[    1.813965] Loaded X.509 cert 'Build time autogenerated kernel key: 98b5fbd0004968eadd44123544af94c22f57c8e4'
 20854	[    1.815573] zswap: loaded using pool zstd/z3fold
 20855	[    1.815932] Key type ._fscrypt registered
 20856	[    1.815934] Key type .fscrypt registered
 20857	[    1.815936] Key type fscrypt-provisioning registered
 20858	[    1.817008] Btrfs loaded, crc32c=crc32c-generic
 20859	[    1.822961] Key type encrypted registered
 20860	[    1.822973] AppArmor: AppArmor sha1 policy hashing enabled
 20861	[    1.829569] HUB_5V: supplied by 5V
 20862	[    1.829802] USB_PWR_EN: supplied by 5V
 20863	[    1.831413] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2
 20864	[    1.831420] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1
 20865	[    1.834122] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator
 20866	[    1.834173] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator
 20867	[    1.834278] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM
 20868	[    1.834863] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
 20869	[    1.834874] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
 20870	[    1.834957] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010
 20871	[    1.834977] xhci-hcd xhci-hcd.0.auto: irq 41, io mem 0xff500000
 20872	[    1.835098] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
 20873	[    1.835101] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 20874	[    1.835104] usb usb1: Product: xHCI Host Controller
 20875	[    1.835106] usb usb1: Manufacturer: Linux 5.10.27-meson64 xhci-hcd
 20876	[    1.835108] usb usb1: SerialNumber: xhci-hcd.0.auto
 20877	[    1.835321] hub 1-0:1.0: USB hub found
 20878	[    1.835337] hub 1-0:1.0: 2 ports detected
 20879	[    1.835464] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
 20880	[    1.835470] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
 20881	[    1.835475] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
 20882	[    1.835495] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
 20883	[    1.835530] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
 20884	[    1.835533] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 20885	[    1.835536] usb usb2: Product: xHCI Host Controller
 20886	[    1.835538] usb usb2: Manufacturer: Linux 5.10.27-meson64 xhci-hcd
 20887	[    1.835540] usb usb2: SerialNumber: xhci-hcd.0.auto
 20888	[    1.835810] hub 2-0:1.0: USB hub found
 20889	[    1.835829] hub 2-0:1.0: 1 port detected
 20890	[    1.837459] meson-gx-mmc ffe05000.sd: Got CD GPIO
 20891	[    1.864781] Freeing unused kernel memory: 3328K
 20892	[    1.895770] Run /init as init process
 20893	[    1.895774]   with arguments:
 20894	[    1.895776]     /init
 20895	[    1.895778]   with environment:
 20896	[    1.895779]     HOME=/
 20897	[    1.895781]     TERM=linux
 20898	[    1.895782]     hdmimode=1080p60hz
 20899	[    1.895784]     cvbsmode=576cvbs
 20900	[    1.895785]     max_freq_a53=1896
 20901	[    1.895787]     max_freq_a73=1800
 20902	[    1.895788]     voutmode=hdmi
 20903	[    1.895790]     disablehpd=false
 20904	[    1.895791]     cvbscable=0
 20905	[    1.895792]     overscan=100
 20906	[    1.915753] mmc0: new high speed SDHC card at address b368
 20907	[    1.916628] mmcblk0: mmc0:b368 CBADS 30.0 GiB
 20908	[    1.918475]  mmcblk0: p1
 20909	[    2.060183] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found
 20910	[    2.060190] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found
 20911	[    2.060300] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock
 20912	[    2.060304] meson8b-dwmac ff3f0000.ethernet: no reset control found
 20913	[    2.060788] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37
 20914	[    2.060796] meson8b-dwmac ff3f0000.ethernet: 	DWMAC1000
 20915	[    2.060799] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported
 20916	[    2.060801] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported
 20917	[    2.060804] meson8b-dwmac ff3f0000.ethernet: COE Type 2
 20918	[    2.060806] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported
 20919	[    2.060808] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported
 20920	[    2.060869] meson8b-dwmac ff3f0000.ethernet: Normal descriptors
 20921	[    2.060872] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled
 20922	[    2.060874] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
 20923	[    2.061071] libphy: stmmac: probed
 20924	[    2.063129] meson-vrtc ff8000a8.rtc: registered as rtc1
 20925	[    2.064359] libphy: mdio_mux: probed
 20926	[    2.070559] rtc-pcf8563 1-0051: registered as rtc0
 20927	[    2.071768] rtc-pcf8563 1-0051: setting system clock to 2021-05-03T11:20:17 UTC (1620040817)
 20928	[    2.074054] random: fast init done
 20929	[    2.176049] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
 20930	[    2.200460] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.04
 20931	[    2.200467] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
 20932	[    2.200471] usb 2-1: Product: USB3.1 Hub
 20933	[    2.200473] usb 2-1: Manufacturer: GenesysLogic
 20934	[    2.219689] hub 2-1:1.0: USB hub found
 20935	[    2.220001] hub 2-1:1.0: 4 ports detected
 20936	[    2.264175] libphy: mdio_mux: probed
 20937	[    2.323723] usb 1-1: new high-speed USB device number 2 using xhci-hcd
 20938	[    2.473987] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.04
 20939	[    2.473990] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
 20940	[    2.473993] usb 1-1: Product: USB2.1 Hub
 20941	[    2.473995] usb 1-1: Manufacturer: GenesysLogic
 20942	[    2.507705] hub 1-1:1.0: USB hub found
 20943	[    2.507935] hub 1-1:1.0: 4 ports detected
 20944	[    2.813648] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
 20945	[    3.644617] systemd[1]: Inserted module 'autofs4'
 20946	[    3.691677] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
 20947	[    3.691931] systemd[1]: Detected architecture arm64.
 20948	[    3.713685] systemd[1]: Set hostname to <odroidn2>.
 20949	[    4.040317] random: systemd: uninitialized urandom read (16 bytes read)
 20950	[    4.043599] random: systemd: uninitialized urandom read (16 bytes read)
 20951	[    4.044903] systemd[1]: Created slice system-getty.slice.
 20952	[    4.045111] random: systemd: uninitialized urandom read (16 bytes read)
 20953	[    4.045196] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
 20954	[    4.045309] systemd[1]: Reached target System Time Synchronized.
 20955	[    4.045681] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
 20956	[    4.045855] systemd[1]: Listening on initctl Compatibility Named Pipe.
 20957	[    4.046108] systemd[1]: Listening on fsck to fsckd communication Socket.
 20958	[    4.046189] systemd[1]: Reached target Remote File Systems.
 20959	[    4.146695] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
 20960	[    4.678624] zram: Added device: zram0
 20961	[    4.678825] zram: Added device: zram1
 20962	[    4.679183] zram: Added device: zram2
 20963	[    4.682278] pwm-gpio pwmgpio: 1 gpio pwms loaded
 20964	[    4.803075] mc: Linux media interface: v0.10
 20965	[    4.877187] videodev: Linux video capture interface: v2.00
 20966	[    4.913093] panfrost ffe40000.gpu: clock rate = 24000000
 20967	[    4.913145] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19
 20968	[    4.913728] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0
 20969	[    4.913732] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400
 20970	[    4.913736] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
 20971	[    4.913739] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1
 20972	[    4.928105] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 0
 20973	[    4.931232] meson-saradc ff809000.adc: supply vref not found, using dummy regulator
 20974	[    4.970488] meson-drm ff900000.vpu: Queued 2 outputs on vpu
 20975	[    5.013373] meson-drm ff900000.vpu: CVBS Output connector not available
 20976	[    5.015785] Registered IR keymap rc-odroid
 20977	[    5.025047] IR NEC protocol handler initialized
 20978	[    5.043069] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
 20979	[    5.043772] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
 20980	[    5.044098] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
 20981	[    5.044341] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 1
 20982	[    5.044400] meson-drm ff900000.vpu: [drm] Cannot find any crtc or sizes
 20983	[    5.048640] zram0: detected capacity change from 0 to 1938251776
 20984	[    5.051953] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0
 20985	[    5.052105] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
 20986	[    5.052205] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input0
 20987	[    5.052488] meson-ir ff808000.ir: receiver initialized
 20988	[    5.085316] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
 20989	[    5.096777] axg-sound-card sound: ASoC: no DMI vendor name!
 20990	[    6.095729] Adding 1892820k swap on /dev/zram0.  Priority:5 extents:1 across:1892820k SSFS
 20991	[    6.158493] zram1: detected capacity change from 0 to 52428800
 20992	[    8.244508] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
 20993	[    8.244526] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
 20994	[    9.496760] systemd[1]: Started Armbian memory supported logging.
 20995	[    9.500846] systemd[1]: Starting Journal Service...
 20996	[    9.555144] systemd[1]: Started Journal Service.
 20997	[    9.575414] systemd-journald[1816]: Received request to flush runtime journal from PID 1
 20998
 20999	### armbian-release:
 21000
 21001	# PLEASE DO NOT EDIT THIS FILE
 21002	BOARD=odroidn2
 21003	BOARD_NAME="Odroid N2"
 21004	BOARDFAMILY=meson-g12b
 21005	BUILD_REPOSITORY_URL=git@github.com:armbian/build.git
 21006	BUILD_REPOSITORY_COMMIT=23e571cb4-dirty
 21007	DISTRIBUTION_CODENAME=buster
 21008	DISTRIBUTION_STATUS=supported
 21009	VERSION=21.02.4
 21010	LINUXFAMILY=meson64
 21011	BRANCH=current
 21012	ARCH=arm64
 21013	IMAGE_TYPE=stable
 21014	BOARD_TYPE=conf
 21015	INITRD_ARCH=arm64
 21016	KERNEL_IMAGE_TYPE=Image
 21017
 21018	### boot environment:
 21019
 21020	verbosity=1
 21021	console=both
 21022	overlay_prefix=meson
 21023	rootdev=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c
 21024	rootfstype=ext4
 21025	usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
 21026
 21027	### lsusb:
 21028
 21029	Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc.
 21030	Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
 21031	Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
 21032	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
 21033
 21034	### lscpu:
 21035
 21036	Architecture:        aarch64
 21037	Byte Order:          Little Endian
 21038	CPU(s):              6
 21039	On-line CPU(s) list: 0-5
 21040	Thread(s) per core:  1
 21041	Core(s) per socket:  3
 21042	Socket(s):           2
 21043	NUMA node(s):        1
 21044	Vendor ID:           ARM
 21045	Model:               4
 21046	Model name:          Cortex-A53
 21047	Stepping:            r0p4
 21048	CPU max MHz:         1992.0000
 21049	CPU min MHz:         100.0000
 21050	BogoMIPS:            48.00
 21051	L1d cache:           unknown size
 21052	L1i cache:           unknown size
 21053	L2 cache:            unknown size
 21054	NUMA node0 CPU(s):   0-5
 21055	Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 21056
 21057	### cpuinfo:
 21058
 21059	processor	: 0
 21060	BogoMIPS	: 48.00
 21061	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 21062	CPU implementer	: 0x41
 21063	CPU architecture: 8
 21064	CPU variant	: 0x0
 21065	CPU part	: 0xd03
 21066	CPU revision	: 4
 21067
 21068	processor	: 1
 21069	BogoMIPS	: 48.00
 21070	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 21071	CPU implementer	: 0x41
 21072	CPU architecture: 8
 21073	CPU variant	: 0x0
 21074	CPU part	: 0xd03
 21075	CPU revision	: 4
 21076
 21077	processor	: 2
 21078	BogoMIPS	: 48.00
 21079	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 21080	CPU implementer	: 0x41
 21081	CPU architecture: 8
 21082	CPU variant	: 0x0
 21083	CPU part	: 0xd09
 21084	CPU revision	: 2
 21085
 21086	processor	: 3
 21087	BogoMIPS	: 48.00
 21088	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 21089	CPU implementer	: 0x41
 21090	CPU architecture: 8
 21091	CPU variant	: 0x0
 21092	CPU part	: 0xd09
 21093	CPU revision	: 2
 21094
 21095	processor	: 4
 21096	BogoMIPS	: 48.00
 21097	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 21098	CPU implementer	: 0x41
 21099	CPU architecture: 8
 21100	CPU variant	: 0x0
 21101	CPU part	: 0xd09
 21102	CPU revision	: 2
 21103
 21104	processor	: 5
 21105	BogoMIPS	: 48.00
 21106	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 21107	CPU implementer	: 0x41
 21108	CPU architecture: 8
 21109	CPU variant	: 0x0
 21110	CPU part	: 0xd09
 21111	CPU revision	: 2
 21112
 21113
 21114	### meminfo:
 21115
 21116	MemTotal:        3785648 kB
 21117	MemFree:         3541240 kB
 21118	MemAvailable:    3541164 kB
 21119	Buffers:           11800 kB
 21120	Cached:            47908 kB
 21121	SwapCached:            0 kB
 21122	Active:            30476 kB
 21123	Inactive:         119724 kB
 21124	Active(anon):        128 kB
 21125	Inactive(anon):    95696 kB
 21126	Active(file):      30348 kB
 21127	Inactive(file):    24028 kB
 21128	Unevictable:           0 kB
 21129	Mlocked:               0 kB
 21130	SwapTotal:       1892820 kB
 21131	SwapFree:        1892820 kB
 21132	Dirty:              8576 kB
 21133	Writeback:             0 kB
 21134	AnonPages:         90960 kB
 21135	Mapped:            11092 kB
 21136	Shmem:              5024 kB
 21137	KReclaimable:      13056 kB
 21138	Slab:              38932 kB
 21139	SReclaimable:      13056 kB
 21140	SUnreclaim:        25876 kB
 21141	KernelStack:        2112 kB
 21142	PageTables:         3016 kB
 21143	NFS_Unstable:          0 kB
 21144	Bounce:                0 kB
 21145	WritebackTmp:          0 kB
 21146	CommitLimit:     3785644 kB
 21147	Committed_AS:    4210588 kB
 21148	VmallocTotal:   135290159040 kB
 21149	VmallocUsed:       31052 kB
 21150	VmallocChunk:          0 kB
 21151	Percpu:             1368 kB
 21152	HardwareCorrupted:     0 kB
 21153	AnonHugePages:         0 kB
 21154	ShmemHugePages:        0 kB
 21155	ShmemPmdMapped:        0 kB
 21156	FileHugePages:         0 kB
 21157	FilePmdMapped:         0 kB
 21158	CmaTotal:         917504 kB
 21159	CmaFree:          909312 kB
 21160	HugePages_Total:       0
 21161	HugePages_Free:        0
 21162	HugePages_Rsvd:        0
 21163	HugePages_Surp:        0
 21164	Hugepagesize:       2048 kB
 21165	Hugetlb:               0 kB
 21166
 21167	### virtual memory:
 21168
 21169	vm.admin_reserve_kbytes = 8192
 21170	vm.block_dump = 0
 21171	vm.compaction_proactiveness = 20
 21172	vm.compact_unevictable_allowed = 1
 21173	vm.dirty_background_bytes = 0
 21174	vm.dirty_background_ratio = 10
 21175	vm.dirty_bytes = 0
 21176	vm.dirty_expire_centisecs = 3000
 21177	vm.dirty_ratio = 20
 21178	vm.dirtytime_expire_seconds = 43200
 21179	vm.dirty_writeback_centisecs = 500
 21180	vm.extfrag_threshold = 500
 21181	vm.hugetlb_shm_group = 0
 21182	vm.laptop_mode = 0
 21183	vm.legacy_va_layout = 0
 21184	vm.lowmem_reserve_ratio = 256	256	32	0
 21185	vm.max_map_count = 65530
 21186	vm.memory_failure_early_kill = 0
 21187	vm.memory_failure_recovery = 1
 21188	vm.min_free_kbytes = 22528
 21189	vm.min_slab_ratio = 5
 21190	vm.min_unmapped_ratio = 1
 21191	vm.mmap_min_addr = 4096
 21192	vm.mmap_rnd_bits = 18
 21193	vm.mmap_rnd_compat_bits = 11
 21194	vm.nr_hugepages = 0
 21195	vm.nr_hugepages_mempolicy = 0
 21196	vm.nr_overcommit_hugepages = 0
 21197	vm.numa_stat = 1
 21198	vm.numa_zonelist_order = Node
 21199	vm.oom_dump_tasks = 1
 21200	vm.oom_kill_allocating_task = 0
 21201	vm.overcommit_kbytes = 0
 21202	vm.overcommit_memory = 0
 21203	vm.overcommit_ratio = 50
 21204	vm.page-cluster = 0
 21205	vm.page_lock_unfairness = 5
 21206	vm.panic_on_oom = 0
 21207	vm.percpu_pagelist_fraction = 0
 21208	vm.stat_interval = 1
 21209	vm.swappiness = 100
 21210	vm.user_reserve_kbytes = 117084
 21211	vm.vfs_cache_pressure = 100
 21212	vm.watermark_boost_factor = 15000
 21213	vm.watermark_scale_factor = 10
 21214	vm.zone_reclaim_mode = 0
 21215
 21216	### ip addr:
 21217
 21218	1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
 21219	    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
 21220	    inet XXX.XXX.0.1/8 scope host lo
 21221	       valid_lft forever preferred_lft forever
 21222	    inet6 ::1/128 scope host
 21223	       valid_lft forever preferred_lft forever
 21224	2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
 21225	    link/ether 00:1e:06:42:03:f8 brd ff:ff:ff:ff:ff:ff
 21226
 21227	### partitions:
 21228
 21229	major minor  #blocks  name
 21230
 21231	 179        0   31464960 mmcblk0
 21232	 179        1   31146208 mmcblk0p1
 21233	 252        0    1892824 zram0
 21234	 252        1      51200 zram1
 21235
 21236	### df:
 21237
 21238	udev            1.4G     0  1.4G   0% /dev
 21239	tmpfs           370M  5.0M  365M   2% /run
 21240	/dev/mmcblk0p1   30G  1.8G   28G   7% /
 21241	tmpfs           1.9G     0  1.9G   0% /dev/shm
 21242	tmpfs           5.0M  4.0K  5.0M   1% /run/lock
 21243	tmpfs           1.9G     0  1.9G   0% /sys/fs/cgroup
 21244	tmpfs           1.9G     0  1.9G   0% /tmp
 21245	/dev/zram1       49M  8.4M   37M  19% /var/log
 21246
 21247	### lsblk:
 21248
 21249	NAME        FSTYPE  SIZE MOUNTPOINT UUID
 21250	mmcblk0              30G
 21251	└─mmcblk0p1 ext4   29.7G /          bd34953d-41be-49d6-b1c0-c0c28a5e239c
 21252	zram1                50M /var/log
 21253
 21254	### zramctl:
 21255
 21256	NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
 21257	/dev/zram1 zstd           50M  132K  698B   36K       6 /var/log
 21258	/dev/zram0 lzo-rle       1.8G    4K   74B   12K       6 [SWAP]
 21259
 21260	### mtab:
 21261
 21262	/dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
 21263	/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
 21264	/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
 21265
 21266	### mmc0:b368 info:
 21267
 21268	               fwrev: 0x0
 21269	              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=CBADS MODALIAS=mmc:block
 21270	                 cid: 6f0303434241445310aa002b4d013b00
 21271	                 rca: 0xb368
 21272	                 csd: 400e005a5b590000f00e7f800a404000
 21273	              manfid: 0x00006f
 21274	                 ocr: 0x00200000
 21275	preferred_erase_size: 2097152
 21276	                type: SD
 21277	               hwrev: 0x1
 21278	                date: 11/2019
 21279	                 dsr: 0x404
 21280	          erase_size: 512
 21281	               oemid: 0x0303
 21282	              serial: 0xaa002b4d
 21283	                 ssr: 00000000000000280402800100fd180a001e00000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
 21284	                 scr: 02b5800300000000
 21285	                name: CBADS
 21286
 21287	### Boot system health:
 21288
 21289	Time       big.LITTLE   load %cpu %sys %usr %nice %io %irq   CPU  C.St.
 21290	12:20:26: 1908/1992MHz  2.23  25%  11%   5%   0%   7%   0% 32.9°C  0/11
 21291	12:20:26: 1908/1992MHz  2.23  83%  25%   4%   0%  52%   0% 31.8°C  0/11
 21292	12:20:27: 1908/1000MHz  2.23  42%   6%   4%   0%  30%   0% 29.9°C  0/11
 21293	12:20:27: 1908/1000MHz  2.23  51%   4%   5%   0%  40%   0% 29.9°C  0/11
 21294	12:20:27: 1908/1992MHz  2.23  55%   3%   8%   0%  41%   0% 29.9°C  0/11
 21295
 21296	### Activated 1 lzo-rle zram swap devices with 1848 MB each
 21297
 21298	### Activated Armbian ramlog partition with zstd compression
 21299
 21300	Mon 03 May 2021 02:24:27 PM BST | Odroid N2 | 21.02.4 | arm64 | aarch64 | 5.10.27-meson64
 21301
 21302	### dmesg:
 21303
 21304	[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
 21305	[    0.000000] Linux version 5.10.27-meson64 (root@hirsute) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #21.02.4 SMP PREEMPT Sun Apr 4 09:23:42 UTC 2021
 21306	[    0.000000] Machine model: Hardkernel ODROID-N2
 21307	[    0.000000] efi: UEFI not found.
 21308	[    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
 21309	[    0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB
 21310	[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
 21311	[    0.000000] NUMA: No NUMA configuration found
 21312	[    0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ed7fffff]
 21313	[    0.000000] NUMA: NODE_DATA [mem 0xb502f100-0xb5030fff]
 21314	[    0.000000] Zone ranges:
 21315	[    0.000000]   DMA      [mem 0x0000000000000000-0x00000000ed7fffff]
 21316	[    0.000000]   DMA32    empty
 21317	[    0.000000]   Normal   empty
 21318	[    0.000000] Movable zone start for each node
 21319	[    0.000000] Early memory node ranges
 21320	[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000004ffffff]
 21321	[    0.000000]   node   0: [mem 0x0000000005000000-0x00000000052fffff]
 21322	[    0.000000]   node   0: [mem 0x0000000005300000-0x00000000ed7fffff]
 21323	[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ed7fffff]
 21324	[    0.000000] On node 0 totalpages: 972800
 21325	[    0.000000]   DMA zone: 15200 pages used for memmap
 21326	[    0.000000]   DMA zone: 0 pages reserved
 21327	[    0.000000]   DMA zone: 972800 pages, LIFO batch:63
 21328	[    0.000000] psci: probing for conduit method from DT.
 21329	[    0.000000] psci: PSCIv1.0 detected in firmware.
 21330	[    0.000000] psci: Using standard PSCI v0.2 function IDs
 21331	[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
 21332	[    0.000000] psci: SMC Calling Convention v1.1
 21333	[    0.000000] percpu: Embedded 23 pages/cpu s56728 r8192 d29288 u94208
 21334	[    0.000000] pcpu-alloc: s56728 r8192 d29288 u94208 alloc=23*4096
 21335	[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
 21336	[    0.000000] Detected VIPT I-cache on CPU0
 21337	[    0.000000] CPU features: detected: ARM erratum 845719
 21338	[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 957600
 21339	[    0.000000] Policy zone: DMA
 21340	[    0.000000] Kernel command line: root=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c rootwait rootfstype=ext4 console=ttyAML0,115200n8 console=tty1 loglevel=1  no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=custombuilt cvbsmode=576cvbs max_freq_a53=1896 max_freq_a73=1800 maxcpus=6 voutmode=hdmi modeline=1920,1080,148500,56250,50,1920,2448,2492,2640,1080,1084,1089,1125,1,1,1 disablehpd=false  cvbscable= overscan=100 consoleblank=0
 21341	[    0.000000] Kernel parameter elevator= does not have any effect anymore.
 21342	               Please use sysfs to set IO scheduler for individual devices.
 21343	[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
 21344	[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
 21345	[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
 21346	[    0.000000] Memory: 2851276K/3891200K available (14144K kernel code, 1760K rwdata, 5512K rodata, 3328K init, 592K bss, 122420K reserved, 917504K cma-reserved)
 21347	[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
 21348	[    0.000000] rcu: Preemptible hierarchical RCU implementation.
 21349	[    0.000000] rcu: 	RCU event tracing is enabled.
 21350	[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
 21351	[    0.000000] 	Trampoline variant of Tasks RCU enabled.
 21352	[    0.000000] 	Rude variant of Tasks RCU enabled.
 21353	[    0.000000] 	Tracing variant of Tasks RCU enabled.
 21354	[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
 21355	[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
 21356	[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
 21357	[    0.000000] GIC: Using split EOI/Deactivate mode
 21358	[    0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized
 21359	[    0.000000] random: get_random_bytes called from start_kernel+0x378/0x538 with crng_init=0
 21360	[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
 21361	[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
 21362	[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
 21363	[    0.000245] Console: colour dummy device 80x25
 21364	[    0.000278] printk: console [tty1] enabled
 21365	[    0.000360] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
 21366	[    0.000371] pid_max: default: 32768 minimum: 301
 21367	[    0.000455] LSM: Security Framework initializing
 21368	[    0.000480] Yama: becoming mindful.
 21369	[    0.000569] AppArmor: AppArmor initialized
 21370	[    0.000622] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
 21371	[    0.000641] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
 21372	[    0.002636] rcu: Hierarchical SRCU implementation.
 21373	[    0.005137] EFI services will not be available.
 21374	[    0.005558] smp: Bringing up secondary CPUs ...
 21375	[    0.006231] Detected VIPT I-cache on CPU1
 21376	[    0.006291] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
 21377	[    0.007486] CPU features: detected: ARM erratum 858921
 21378	[    0.007494] CPU features: detected: Spectre-v2
 21379	[    0.007498] CPU features: detected: Spectre-v4
 21380	[    0.007504] Detected VIPT I-cache on CPU2
 21381	[    0.007529] arch_timer: Enabling local workaround for ARM erratum 858921
 21382	[    0.007544] arch_timer: CPU2: Trapping CNTVCT access
 21383	[    0.007557] CPU2: Booted secondary processor 0x0000000100 [0x410fd092]
 21384	[    0.008268] Detected VIPT I-cache on CPU3
 21385	[    0.008284] arch_timer: Enabling local workaround for ARM erratum 858921
 21386	[    0.008291] arch_timer: CPU3: Trapping CNTVCT access
 21387	[    0.008299] CPU3: Booted secondary processor 0x0000000101 [0x410fd092]
 21388	[    0.008927] Detected VIPT I-cache on CPU4
 21389	[    0.008944] arch_timer: Enabling local workaround for ARM erratum 858921
 21390	[    0.008951] arch_timer: CPU4: Trapping CNTVCT access
 21391	[    0.008959] CPU4: Booted secondary processor 0x0000000102 [0x410fd092]
 21392	[    0.009581] Detected VIPT I-cache on CPU5
 21393	[    0.009598] arch_timer: Enabling local workaround for ARM erratum 858921
 21394	[    0.009605] arch_timer: CPU5: Trapping CNTVCT access
 21395	[    0.009612] CPU5: Booted secondary processor 0x0000000103 [0x410fd092]
 21396	[    0.009692] smp: Brought up 1 node, 6 CPUs
 21397	[    0.009709] SMP: Total of 6 processors activated.
 21398	[    0.009717] CPU features: detected: 32-bit EL0 Support
 21399	[    0.009722] CPU features: detected: CRC32 instructions
 21400	[    0.009728] CPU features: detected: 32-bit EL1 Support
 21401	[    0.020942] CPU: All CPU(s) started at EL2
 21402	[    0.020991] alternatives: patching kernel code
 21403	[    0.022262] devtmpfs: initialized
 21404	[    0.029901] Registered cp15_barrier emulation handler
 21405	[    0.029916] Registered setend emulation handler
 21406	[    0.030052] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
 21407	[    0.030090] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
 21408	[    0.046212] pinctrl core: initialized pinctrl subsystem
 21409	[    0.046929] DMI not present or invalid.
 21410	[    0.047296] NET: Registered protocol family 16
 21411	[    0.048795] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
 21412	[    0.049030] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
 21413	[    0.049322] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
 21414	[    0.049365] audit: initializing netlink subsys (disabled)
 21415	[    0.049474] audit: type=2000 audit(0.048:1): state=initialized audit_enabled=0 res=1
 21416	[    0.050808] thermal_sys: Registered thermal governor 'fair_share'
 21417	[    0.050816] thermal_sys: Registered thermal governor 'bang_bang'
 21418	[    0.050820] thermal_sys: Registered thermal governor 'step_wise'
 21419	[    0.050823] thermal_sys: Registered thermal governor 'user_space'
 21420	[    0.051227] cpuidle: using governor menu
 21421	[    0.051571] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
 21422	[    0.051696] ASID allocator initialised with 65536 entries
 21423	[    0.052658] Serial: AMBA PL011 UART driver
 21424	[    0.087945] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
 21425	[    0.087955] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
 21426	[    0.087960] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
 21427	[    0.087964] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
 21428	[    0.089494] cryptd: max_cpu_qlen set to 1000
 21429	[    0.160241] raid6: neonx8   gen()  2787 MB/s
 21430	[    0.228300] raid6: neonx8   xor()  2041 MB/s
 21431	[    0.296389] raid6: neonx4   gen()  2998 MB/s
 21432	[    0.364440] raid6: neonx4   xor()  2328 MB/s
 21433	[    0.432503] raid6: neonx2   gen()  2563 MB/s
 21434	[    0.500565] raid6: neonx2   xor()  2197 MB/s
 21435	[    0.568636] raid6: neonx1   gen()  1999 MB/s
 21436	[    0.636697] raid6: neonx1   xor()  1727 MB/s
 21437	[    0.704765] raid6: int64x8  gen()  1379 MB/s
 21438	[    0.772837] raid6: int64x8  xor()   736 MB/s
 21439	[    0.840921] raid6: int64x4  gen()  1463 MB/s
 21440	[    0.908973] raid6: int64x4  xor()   733 MB/s
 21441	[    0.977029] raid6: int64x2  gen()  1362 MB/s
 21442	[    1.045093] raid6: int64x2  xor()   619 MB/s
 21443	[    1.113172] raid6: int64x1  gen()  1127 MB/s
 21444	[    1.181224] raid6: int64x1  xor()   462 MB/s
 21445	[    1.181228] raid6: using algorithm neonx4 gen() 2998 MB/s
 21446	[    1.181231] raid6: .... xor() 2328 MB/s, rmw enabled
 21447	[    1.181235] raid6: using neon recovery algorithm
 21448	[    1.181675] ACPI: Interpreter disabled.
 21449	[    1.182460] 5V: supplied by 12V
 21450	[    1.183344] VDDAO_3V3: supplied by 12V
 21451	[    1.183826] iommu: Default domain type: Translated
 21452	[    1.183939] vgaarb: loaded
 21453	[    1.184725] SCSI subsystem initialized
 21454	[    1.185080] usbcore: registered new interface driver usbfs
 21455	[    1.185120] usbcore: registered new interface driver hub
 21456	[    1.185161] usbcore: registered new device driver usb
 21457	[    1.185394] pps_core: LinuxPPS API ver. 1 registered
 21458	[    1.185398] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
 21459	[    1.185423] PTP clock support registered
 21460	[    1.185610] EDAC MC: Ver: 3.0.0
 21461	[    1.187014] NetLabel: Initializing
 21462	[    1.187021] NetLabel:  domain hash size = 128
 21463	[    1.187024] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
 21464	[    1.187066] NetLabel:  unlabeled traffic allowed by default
 21465	[    1.187509] clocksource: Switched to clocksource arch_sys_counter
 21466	[    1.187709] VFS: Disk quotas dquot_6.6.0
 21467	[    1.187751] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
 21468	[    1.188108] AppArmor: AppArmor Filesystem Enabled
 21469	[    1.188156] pnp: PnP ACPI: disabled
 21470	[    1.193697] NET: Registered protocol family 2
 21471	[    1.194175] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
 21472	[    1.194250] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
 21473	[    1.194506] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
 21474	[    1.194694] TCP: Hash tables configured (established 32768 bind 32768)
 21475	[    1.194845] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
 21476	[    1.194911] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
 21477	[    1.194957] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
 21478	[    1.195101] NET: Registered protocol family 1
 21479	[    1.195123] PCI: CLS 0 bytes, default 64
 21480	[    1.195243] Trying to unpack rootfs image as initramfs...
 21481	[    1.723871] Freeing initrd memory: 13540K
 21482	[    1.724835] kvm [1]: IPA Size Limit: 40 bits
 21483	[    1.725545] kvm [1]: vgic interrupt IRQ9
 21484	[    1.725674] kvm [1]: Hyp mode initialized successfully
 21485	[    1.730741] Initialise system trusted keyrings
 21486	[    1.730778] Key type blacklist registered
 21487	[    1.730872] workingset: timestamp_bits=44 max_order=20 bucket_order=0
 21488	[    1.734049] zbud: loaded
 21489	[    1.734951] squashfs: version 4.0 (2009/01/31) Phillip Lougher
 21490	[    1.735515] fuse: init (API version 7.32)
 21491	[    1.736330] integrity: Platform Keyring initialized
 21492	[    1.764086] xor: measuring software checksum speed
 21493	[    1.766921]    8regs           :  3476 MB/sec
 21494	[    1.769379]    32regs          :  4025 MB/sec
 21495	[    1.772038]    arm64_neon      :  3712 MB/sec
 21496	[    1.772041] xor: using function: 32regs (4025 MB/sec)
 21497	[    1.772048] Key type asymmetric registered
 21498	[    1.772051] Asymmetric key parser 'x509' registered
 21499	[    1.772083] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
 21500	[    1.772171] io scheduler mq-deadline registered
 21501	[    1.772175] io scheduler kyber registered
 21502	[    1.772255] io scheduler bfq registered
 21503	[    1.774812] gpio-447 (usb-hub-reset): hogged as output/high
 21504	[    1.777851] EINJ: ACPI disabled.
 21505	[    1.784193] soc soc0: Amlogic Meson G12B (S922X) Revision 29:a (40:2) Detected
 21506	[    1.785618] VCC_3V3: supplied by VDDAO_3V3
 21507	[    1.785666] FLASH_1V8: supplied by VCC_3V3
 21508	[    1.785696] VCC_1V8: supplied by VCC_3V3
 21509	[    1.785721] VDDAO_1V8: supplied by VDDAO_3V3
 21510	[    1.785749] VDDCPU_A: supplied by regulator-dummy
 21511	[    1.786115] VDDCPU_B: supplied by regulator-dummy
 21512	[    1.786800] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
 21513	[    1.789262] Serial: AMBA driver
 21514	[    1.789553] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart
 21515	[    1.789647] printk: console [ttyAML0] enabled
 21516	[    1.790161] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 33, base_baud = 1500000) is a meson_uart
 21517	[    1.795411] loop: module loaded
 21518	[    1.797453] libphy: Fixed MDIO Bus: probed
 21519	[    1.798518] tun: Universal TUN/TAP device driver, 1.6
 21520	[    1.799179] thunder_xcv, ver 1.0
 21521	[    1.799209] thunder_bgx, ver 1.0
 21522	[    1.799237] nicpf, ver 1.0
 21523	[    1.799778] e1000e: Intel(R) PRO/1000 Network Driver
 21524	[    1.799783] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
 21525	[    1.799828] igb: Intel(R) Gigabit Ethernet Network Driver
 21526	[    1.799831] igb: Copyright (c) 2007-2014 Intel Corporation.
 21527	[    1.799863] igbvf: Intel(R) Gigabit Virtual Function Network Driver
 21528	[    1.799866] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
 21529	[    1.799996] sky2: driver version 1.30
 21530	[    1.800371] VFIO - User Level meta-driver version: 0.3
 21531	[    1.801769] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
 21532	[    1.801786] ehci-pci: EHCI PCI platform driver
 21533	[    1.801814] ehci-platform: EHCI generic platform driver
 21534	[    1.801948] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
 21535	[    1.801958] ohci-pci: OHCI PCI platform driver
 21536	[    1.801991] ohci-platform: OHCI generic platform driver
 21537	[    1.802405] usbcore: registered new interface driver usb-storage
 21538	[    1.803744] mousedev: PS/2 mouse device common for all mice
 21539	[    1.804131] i2c /dev entries driver
 21540	[    1.809341] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17
 21541	[    1.810000] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz
 21542	[    1.810677] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-1 failed:-17
 21543	[    1.811282] sdhci: Secure Digital Host Controller Interface driver
 21544	[    1.811290] sdhci: Copyright(c) Pierre Ossman
 21545	[    1.811426] Synopsys Designware Multimedia Card Interface Driver
 21546	[    1.811915] sdhci-pltfm: SDHCI platform and OF driver helper
 21547	[    1.812331] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq
 21548	[    1.812775] ledtrig-cpu: registered to indicate activity on CPUs
 21549	[    1.813228] meson-sm: secure-monitor enabled
 21550	[    1.813456] hid: raw HID events driver (C) Jiri Kosina
 21551	[    1.813560] usbcore: registered new interface driver usbhid
 21552	[    1.813562] usbhid: USB HID core driver
 21553	[    1.814614] NET: Registered protocol family 10
 21554	[    1.815058] Segment Routing with IPv6
 21555	[    1.815086] NET: Registered protocol family 17
 21556	[    1.815150] 8021q: 802.1Q VLAN Support v1.8
 21557	[    1.815175] Key type dns_resolver registered
 21558	[    1.815455] registered taskstats version 1
 21559	[    1.815461] Loading compiled-in X.509 certificates
 21560	[    1.817214] Loaded X.509 cert 'Build time autogenerated kernel key: 98b5fbd0004968eadd44123544af94c22f57c8e4'
 21561	[    1.818816] zswap: loaded using pool zstd/z3fold
 21562	[    1.818989] Key type ._fscrypt registered
 21563	[    1.818991] Key type .fscrypt registered
 21564	[    1.818993] Key type fscrypt-provisioning registered
 21565	[    1.820088] Btrfs loaded, crc32c=crc32c-generic
 21566	[    1.826012] Key type encrypted registered
 21567	[    1.826025] AppArmor: AppArmor sha1 policy hashing enabled
 21568	[    1.832642] HUB_5V: supplied by 5V
 21569	[    1.832859] USB_PWR_EN: supplied by 5V
 21570	[    1.834479] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2
 21571	[    1.834487] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1
 21572	[    1.837158] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator
 21573	[    1.837204] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator
 21574	[    1.837309] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM
 21575	[    1.837893] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
 21576	[    1.837904] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
 21577	[    1.837994] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010
 21578	[    1.838015] xhci-hcd xhci-hcd.0.auto: irq 41, io mem 0xff500000
 21579	[    1.838138] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
 21580	[    1.838141] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 21581	[    1.838144] usb usb1: Product: xHCI Host Controller
 21582	[    1.838146] usb usb1: Manufacturer: Linux 5.10.27-meson64 xhci-hcd
 21583	[    1.838148] usb usb1: SerialNumber: xhci-hcd.0.auto
 21584	[    1.838338] hub 1-0:1.0: USB hub found
 21585	[    1.838351] hub 1-0:1.0: 2 ports detected
 21586	[    1.838479] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
 21587	[    1.838485] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
 21588	[    1.838491] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
 21589	[    1.838515] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
 21590	[    1.838546] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
 21591	[    1.838549] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 21592	[    1.838551] usb usb2: Product: xHCI Host Controller
 21593	[    1.838553] usb usb2: Manufacturer: Linux 5.10.27-meson64 xhci-hcd
 21594	[    1.838555] usb usb2: SerialNumber: xhci-hcd.0.auto
 21595	[    1.838695] hub 2-0:1.0: USB hub found
 21596	[    1.838705] hub 2-0:1.0: 1 port detected
 21597	[    1.840015] meson-gx-mmc ffe05000.sd: Got CD GPIO
 21598	[    1.864625] Freeing unused kernel memory: 3328K
 21599	[    1.907583] Run /init as init process
 21600	[    1.907587]   with arguments:
 21601	[    1.907589]     /init
 21602	[    1.907590]   with environment:
 21603	[    1.907592]     HOME=/
 21604	[    1.907593]     TERM=linux
 21605	[    1.907595]     hdmimode=custombuilt
 21606	[    1.907596]     cvbsmode=576cvbs
 21607	[    1.907598]     max_freq_a53=1896
 21608	[    1.907599]     max_freq_a73=1800
 21609	[    1.907601]     voutmode=hdmi
 21610	[    1.907602]     modeline=1920,1080,148500,56250,50,1920,2448,2492,2640,1080,1084,1089,1125,1,1,1
 21611	[    1.907604]     disablehpd=false
 21612	[    1.907605]     cvbscable=
 21613	[    1.907607]     overscan=100
 21614	[    1.929818] mmc0: new ultra high speed SDR25 SDHC card at address b368
 21615	[    1.930359] mmcblk0: mmc0:b368 CBADS 30.0 GiB
 21616	[    1.932163]  mmcblk0: p1
 21617	[    2.060157] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found
 21618	[    2.060166] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found
 21619	[    2.060298] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock
 21620	[    2.060303] meson8b-dwmac ff3f0000.ethernet: no reset control found
 21621	[    2.060887] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37
 21622	[    2.060899] meson8b-dwmac ff3f0000.ethernet: 	DWMAC1000
 21623	[    2.060902] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported
 21624	[    2.060905] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported
 21625	[    2.060907] meson8b-dwmac ff3f0000.ethernet: COE Type 2
 21626	[    2.060909] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported
 21627	[    2.060911] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported
 21628	[    2.060971] meson8b-dwmac ff3f0000.ethernet: Normal descriptors
 21629	[    2.060975] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled
 21630	[    2.060977] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
 21631	[    2.061206] libphy: stmmac: probed
 21632	[    2.064108] libphy: mdio_mux: probed
 21633	[    2.066445] meson-vrtc ff8000a8.rtc: registered as rtc1
 21634	[    2.084722] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
 21635	[    2.084910] rtc-pcf8563 1-0051: registered as rtc0
 21636	[    2.086343] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
 21637	[    2.086352] rtc-pcf8563 1-0051: hctosys: unable to read the hardware clock
 21638	[    2.087179] random: fast init done
 21639	[    2.171641] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
 21640	[    2.200251] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.04
 21641	[    2.200257] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
 21642	[    2.200260] usb 2-1: Product: USB3.1 Hub
 21643	[    2.200262] usb 2-1: Manufacturer: GenesysLogic
 21644	[    2.222701] hub 2-1:1.0: USB hub found
 21645	[    2.222983] hub 2-1:1.0: 4 ports detected
 21646	[    2.267985] libphy: mdio_mux: probed
 21647	[    2.323536] usb 1-1: new high-speed USB device number 2 using xhci-hcd
 21648	[    2.473788] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.04
 21649	[    2.473794] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
 21650	[    2.473798] usb 1-1: Product: USB2.1 Hub
 21651	[    2.473801] usb 1-1: Manufacturer: GenesysLogic
 21652	[    2.510778] hub 1-1:1.0: USB hub found
 21653	[    2.511018] hub 1-1:1.0: 4 ports detected
 21654	[    2.703520] usb 1-2: new high-speed USB device number 3 using xhci-hcd
 21655	[    2.851951] usb 1-2: New USB device found, idVendor=2013, idProduct=025f, bcdDevice= 1.00
 21656	[    2.851955] usb 1-2: New USB device strings: Mfr=3, Product=1, SerialNumber=2
 21657	[    2.851959] usb 1-2: Product: PCTV 292e
 21658	[    2.851962] usb 1-2: Manufacturer: PCTV
 21659	[    2.851965] usb 1-2: SerialNumber: 0011356964
 21660	[    3.267540] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
 21661	[    4.081422] systemd[1]: System time before build time, advancing clock.
 21662	[    4.096328] systemd[1]: Inserted module 'autofs4'
 21663	[    4.143328] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
 21664	[    4.143561] systemd[1]: Detected architecture arm64.
 21665	[    4.169344] systemd[1]: Set hostname to <odroidn2>.
 21666	[    4.495594] random: systemd: uninitialized urandom read (16 bytes read)
 21667	[    4.498883] random: systemd: uninitialized urandom read (16 bytes read)
 21668	[    4.499105] systemd[1]: Listening on udev Kernel Socket.
 21669	[    4.499321] random: systemd: uninitialized urandom read (16 bytes read)
 21670	[    4.499548] systemd[1]: Listening on Journal Socket.
 21671	[    4.500416] systemd[1]: Created slice User and Session Slice.
 21672	[    4.500515] systemd[1]: Reached target Slices.
 21673	[    4.502369] systemd[1]: Mounting POSIX Message Queue File System...
 21674	[    4.502841] systemd[1]: Listening on Journal Socket (/dev/log).
 21675	[    4.503175] systemd[1]: Listening on udev Control Socket.
 21676	[    4.568484] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
 21677	[    5.094247] zram: Added device: zram0
 21678	[    5.094407] zram: Added device: zram1
 21679	[    5.094553] zram: Added device: zram2
 21680	[    5.131994] pwm-gpio pwmgpio: 1 gpio pwms loaded
 21681	[    5.305135] mc: Linux media interface: v0.10
 21682	[    5.326439] panfrost ffe40000.gpu: clock rate = 24000000
 21683	[    5.326493] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19
 21684	[    5.327098] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0
 21685	[    5.327102] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400
 21686	[    5.327105] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
 21687	[    5.327108] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1
 21688	[    5.341466] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 0
 21689	[    5.384168] meson-saradc ff809000.adc: supply vref not found, using dummy regulator
 21690	[    5.405887] videodev: Linux video capture interface: v2.00
 21691	[    5.423291] meson-drm ff900000.vpu: Queued 2 outputs on vpu
 21692	[    5.451538] Registered IR keymap rc-odroid
 21693	[    5.463050] meson-drm ff900000.vpu: CVBS Output connector not available
 21694	[    5.491414] IR NEC protocol handler initialized
 21695	[    5.491572] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
 21696	[    5.505132] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
 21697	[    5.505423] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
 21698	[    5.505695] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 1
 21699	[    5.511476] zram0: detected capacity change from 0 to 1938251776
 21700	[    5.519646] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0
 21701	[    5.519782] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
 21702	[    5.519869] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input0
 21703	[    5.521358] meson-ir ff808000.ir: receiver initialized
 21704	[    5.559594] em28xx 1-2:1.0: New device PCTV PCTV 292e @ 480 Mbps (2013:025f, interface 0, class 0)
 21705	[    5.559606] em28xx 1-2:1.0: DVB interface 0 found: isoc
 21706	[    5.567190] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
 21707	[    5.619641] em28xx 1-2:1.0: chip ID is em28178
 21708	[    5.787666] Console: switching to colour frame buffer device 240x67
 21709	[    5.814188] meson-drm ff900000.vpu: [drm] fb0: mesondrmfb frame buffer device
 21710	[    5.862474] axg-sound-card sound: ASoC: no DMI vendor name!
 21711	[    6.555534] Adding 1892820k swap on /dev/zram0.  Priority:5 extents:1 across:1892820k SSFS
 21712	[    6.618388] zram1: detected capacity change from 0 to 52428800
 21713	[    7.653845] em28xx 1-2:1.0: EEPROM ID = 26 00 01 00, EEPROM hash = 0x8d0cfd04
 21714	[    7.653851] em28xx 1-2:1.0: EEPROM info:
 21715	[    7.653856] em28xx 1-2:1.0: 	microcode start address = 0x0004, boot configuration = 0x01
 21716	[    7.659957] em28xx 1-2:1.0: 	AC97 audio (5 sample rates)
 21717	[    7.659960] em28xx 1-2:1.0: 	500mA max power
 21718	[    7.659964] em28xx 1-2:1.0: 	Table at offset 0x27, strings=0x146a, 0x1888, 0x0a7e
 21719	[    7.719530] em28xx 1-2:1.0: Identified as PCTV tripleStick (292e) (card=94)
 21720	[    7.719539] em28xx 1-2:1.0: dvb set to isoc mode.
 21721	[    7.719773] usbcore: registered new interface driver em28xx
 21722	[    7.746664] em28xx 1-2:1.0: Binding DVB extension
 21723	[    7.760345] i2c i2c-4: Added multiplexed i2c bus 5
 21724	[    7.760353] si2168 4-0064: Silicon Labs Si2168-B40 successfully identified
 21725	[    7.760356] si2168 4-0064: firmware version: B 4.0.2
 21726	[    7.768709] si2157 5-0060: Silicon Labs Si2147/2148/2157/2158 successfully attached
 21727	[    7.768740] dvbdev: DVB: registering new adapter (1-2:1.0)
 21728	[    7.768745] em28xx 1-2:1.0: DVB: registering adapter 0 frontend 0 (Silicon Labs Si2168)...
 21729	[    7.768752] dvbdev: dvb_create_media_entity: media entity 'Silicon Labs Si2168' registered.
 21730	[    7.769398] dvbdev: dvb_create_media_entity: media entity 'dvb-demux' registered.
 21731	[    7.770719] em28xx 1-2:1.0: DVB extension successfully initialized
 21732	[    7.770729] em28xx: Registered (Em28xx dvb Extension) extension
 21733	[    7.777964] em28xx 1-2:1.0: Registering input extension
 21734	[    7.815531] Registered IR keymap rc-pinnacle-pctv-hd
 21735	[    7.815738] rc rc1: PCTV tripleStick (292e) as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-2/1-2:1.0/rc/rc1
 21736	[    7.815834] rc rc1: lirc_dev: driver em28xx registered at minor = 1, scancode receiver, no transmitter
 21737	[    7.815894] input: PCTV tripleStick (292e) as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-2/1-2:1.0/rc/rc1/input1
 21738	[    7.815962] em28xx 1-2:1.0: Input extension successfully initialized
 21739	[    7.815967] em28xx: Registered (Em28xx Input Extension) extension
 21740	[    8.703751] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
 21741	[    8.703771] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
 21742	[    9.964579] systemd[1]: Started Armbian memory supported logging.
 21743	[    9.968799] systemd[1]: Starting Journal Service...
 21744	[   10.031810] systemd[1]: Started Journal Service.
 21745	[   10.061701] systemd-journald[1846]: Received request to flush runtime journal from PID 1
 21746
 21747	### armbian-release:
 21748
 21749	# PLEASE DO NOT EDIT THIS FILE
 21750	BOARD=odroidn2
 21751	BOARD_NAME="Odroid N2"
 21752	BOARDFAMILY=meson-g12b
 21753	BUILD_REPOSITORY_URL=git@github.com:armbian/build.git
 21754	BUILD_REPOSITORY_COMMIT=23e571cb4-dirty
 21755	DISTRIBUTION_CODENAME=buster
 21756	DISTRIBUTION_STATUS=supported
 21757	VERSION=21.02.4
 21758	LINUXFAMILY=meson64
 21759	BRANCH=current
 21760	ARCH=arm64
 21761	IMAGE_TYPE=stable
 21762	BOARD_TYPE=conf
 21763	INITRD_ARCH=arm64
 21764	KERNEL_IMAGE_TYPE=Image
 21765
 21766	### boot environment:
 21767
 21768	verbosity=1
 21769	console=both
 21770	overlay_prefix=meson
 21771	rootdev=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c
 21772	rootfstype=ext4
 21773	usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
 21774
 21775	### lsusb:
 21776
 21777	Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc.
 21778	Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
 21779	Bus 001 Device 003: ID 2013:025f PCTV Systems
 21780	Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
 21781	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
 21782
 21783	### lscpu:
 21784
 21785	Architecture:        aarch64
 21786	Byte Order:          Little Endian
 21787	CPU(s):              6
 21788	On-line CPU(s) list: 0-5
 21789	Thread(s) per core:  1
 21790	Core(s) per socket:  3
 21791	Socket(s):           2
 21792	NUMA node(s):        1
 21793	Vendor ID:           ARM
 21794	Model:               4
 21795	Model name:          Cortex-A53
 21796	Stepping:            r0p4
 21797	CPU max MHz:         1992.0000
 21798	CPU min MHz:         100.0000
 21799	BogoMIPS:            48.00
 21800	L1d cache:           unknown size
 21801	L1i cache:           unknown size
 21802	L2 cache:            unknown size
 21803	NUMA node0 CPU(s):   0-5
 21804	Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 21805
 21806	### cpuinfo:
 21807
 21808	processor	: 0
 21809	BogoMIPS	: 48.00
 21810	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 21811	CPU implementer	: 0x41
 21812	CPU architecture: 8
 21813	CPU variant	: 0x0
 21814	CPU part	: 0xd03
 21815	CPU revision	: 4
 21816
 21817	processor	: 1
 21818	BogoMIPS	: 48.00
 21819	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 21820	CPU implementer	: 0x41
 21821	CPU architecture: 8
 21822	CPU variant	: 0x0
 21823	CPU part	: 0xd03
 21824	CPU revision	: 4
 21825
 21826	processor	: 2
 21827	BogoMIPS	: 48.00
 21828	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 21829	CPU implementer	: 0x41
 21830	CPU architecture: 8
 21831	CPU variant	: 0x0
 21832	CPU part	: 0xd09
 21833	CPU revision	: 2
 21834
 21835	processor	: 3
 21836	BogoMIPS	: 48.00
 21837	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 21838	CPU implementer	: 0x41
 21839	CPU architecture: 8
 21840	CPU variant	: 0x0
 21841	CPU part	: 0xd09
 21842	CPU revision	: 2
 21843
 21844	processor	: 4
 21845	BogoMIPS	: 48.00
 21846	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 21847	CPU implementer	: 0x41
 21848	CPU architecture: 8
 21849	CPU variant	: 0x0
 21850	CPU part	: 0xd09
 21851	CPU revision	: 2
 21852
 21853	processor	: 5
 21854	BogoMIPS	: 48.00
 21855	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 21856	CPU implementer	: 0x41
 21857	CPU architecture: 8
 21858	CPU variant	: 0x0
 21859	CPU part	: 0xd09
 21860	CPU revision	: 2
 21861
 21862
 21863	### meminfo:
 21864
 21865	MemTotal:        3785648 kB
 21866	MemFree:         3468676 kB
 21867	MemAvailable:    3469232 kB
 21868	Buffers:           11688 kB
 21869	Cached:            48896 kB
 21870	SwapCached:            0 kB
 21871	Active:            29088 kB
 21872	Inactive:         176696 kB
 21873	Active(anon):        108 kB
 21874	Inactive(anon):   150284 kB
 21875	Active(file):      28980 kB
 21876	Inactive(file):    26412 kB
 21877	Unevictable:           0 kB
 21878	Mlocked:               0 kB
 21879	SwapTotal:       1892820 kB
 21880	SwapFree:        1892820 kB
 21881	Dirty:              8840 kB
 21882	Writeback:             0 kB
 21883	AnonPages:        145284 kB
 21884	Mapped:            13568 kB
 21885	Shmem:              5048 kB
 21886	KReclaimable:      13304 kB
 21887	Slab:              40784 kB
 21888	SReclaimable:      13304 kB
 21889	SUnreclaim:        27480 kB
 21890	KernelStack:        2544 kB
 21891	PageTables:         6064 kB
 21892	NFS_Unstable:          0 kB
 21893	Bounce:                0 kB
 21894	WritebackTmp:          0 kB
 21895	CommitLimit:     3785644 kB
 21896	Committed_AS:    4241352 kB
 21897	VmallocTotal:   135290159040 kB
 21898	VmallocUsed:       33324 kB
 21899	VmallocChunk:          0 kB
 21900	Percpu:             1368 kB
 21901	HardwareCorrupted:     0 kB
 21902	AnonHugePages:     40960 kB
 21903	ShmemHugePages:        0 kB
 21904	ShmemPmdMapped:        0 kB
 21905	FileHugePages:         0 kB
 21906	FilePmdMapped:         0 kB
 21907	CmaTotal:         917504 kB
 21908	CmaFree:          901212 kB
 21909	HugePages_Total:       0
 21910	HugePages_Free:        0
 21911	HugePages_Rsvd:        0
 21912	HugePages_Surp:        0
 21913	Hugepagesize:       2048 kB
 21914	Hugetlb:               0 kB
 21915
 21916	### virtual memory:
 21917
 21918	vm.admin_reserve_kbytes = 8192
 21919	vm.block_dump = 0
 21920	vm.compaction_proactiveness = 20
 21921	vm.compact_unevictable_allowed = 1
 21922	vm.dirty_background_bytes = 0
 21923	vm.dirty_background_ratio = 10
 21924	vm.dirty_bytes = 0
 21925	vm.dirty_expire_centisecs = 3000
 21926	vm.dirty_ratio = 20
 21927	vm.dirtytime_expire_seconds = 43200
 21928	vm.dirty_writeback_centisecs = 500
 21929	vm.extfrag_threshold = 500
 21930	vm.hugetlb_shm_group = 0
 21931	vm.laptop_mode = 0
 21932	vm.legacy_va_layout = 0
 21933	vm.lowmem_reserve_ratio = 256	256	32	0
 21934	vm.max_map_count = 65530
 21935	vm.memory_failure_early_kill = 0
 21936	vm.memory_failure_recovery = 1
 21937	vm.min_free_kbytes = 22528
 21938	vm.min_slab_ratio = 5
 21939	vm.min_unmapped_ratio = 1
 21940	vm.mmap_min_addr = 4096
 21941	vm.mmap_rnd_bits = 18
 21942	vm.mmap_rnd_compat_bits = 11
 21943	vm.nr_hugepages = 0
 21944	vm.nr_hugepages_mempolicy = 0
 21945	vm.nr_overcommit_hugepages = 0
 21946	vm.numa_stat = 1
 21947	vm.numa_zonelist_order = Node
 21948	vm.oom_dump_tasks = 1
 21949	vm.oom_kill_allocating_task = 0
 21950	vm.overcommit_kbytes = 0
 21951	vm.overcommit_memory = 0
 21952	vm.overcommit_ratio = 50
 21953	vm.page-cluster = 0
 21954	vm.page_lock_unfairness = 5
 21955	vm.panic_on_oom = 0
 21956	vm.percpu_pagelist_fraction = 0
 21957	vm.stat_interval = 1
 21958	vm.swappiness = 100
 21959	vm.user_reserve_kbytes = 117113
 21960	vm.vfs_cache_pressure = 100
 21961	vm.watermark_boost_factor = 15000
 21962	vm.watermark_scale_factor = 10
 21963	vm.zone_reclaim_mode = 0
 21964
 21965	### ip addr:
 21966
 21967	1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
 21968	    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
 21969	    inet XXX.XXX.0.1/8 scope host lo
 21970	       valid_lft forever preferred_lft forever
 21971	    inet6 ::1/128 scope host
 21972	       valid_lft forever preferred_lft forever
 21973	2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
 21974	    link/ether 00:1e:06:42:03:f8 brd ff:ff:ff:ff:ff:ff
 21975
 21976	### partitions:
 21977
 21978	major minor  #blocks  name
 21979
 21980	 179        0   31464960 mmcblk0
 21981	 179        1   31146208 mmcblk0p1
 21982	 252        0    1892824 zram0
 21983	 252        1      51200 zram1
 21984
 21985	### df:
 21986
 21987	udev            1.4G     0  1.4G   0% /dev
 21988	tmpfs           370M  5.0M  365M   2% /run
 21989	/dev/mmcblk0p1   30G  1.8G   28G   7% /
 21990	tmpfs           1.9G     0  1.9G   0% /dev/shm
 21991	tmpfs           5.0M  4.0K  5.0M   1% /run/lock
 21992	tmpfs           1.9G     0  1.9G   0% /sys/fs/cgroup
 21993	tmpfs           1.9G     0  1.9G   0% /tmp
 21994	/dev/zram1       49M  8.7M   37M  20% /var/log
 21995
 21996	### lsblk:
 21997
 21998	NAME        FSTYPE  SIZE MOUNTPOINT UUID
 21999	mmcblk0              30G
 22000	└─mmcblk0p1 ext4   29.7G /          bd34953d-41be-49d6-b1c0-c0c28a5e239c
 22001	zram1                50M /var/log
 22002
 22003	### zramctl:
 22004
 22005	NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
 22006	/dev/zram1 zstd           50M  132K  698B   36K       6 /var/log
 22007	/dev/zram0 lzo-rle       1.8G    4K   74B   12K       6 [SWAP]
 22008
 22009	### mtab:
 22010
 22011	/dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
 22012	/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
 22013	/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
 22014
 22015	### mmc0:b368 info:
 22016
 22017	               fwrev: 0x0
 22018	              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=CBADS MODALIAS=mmc:block
 22019	                 cid: 6f0303434241445310aa002b4d013b00
 22020	                 rca: 0xb368
 22021	                 csd: 400e005a5b590000f00e7f800a404000
 22022	              manfid: 0x00006f
 22023	                 ocr: 0x00200000
 22024	preferred_erase_size: 2097152
 22025	                type: SD
 22026	               hwrev: 0x1
 22027	                date: 11/2019
 22028	                 dsr: 0x404
 22029	          erase_size: 512
 22030	               oemid: 0x0303
 22031	              serial: 0xaa002b4d
 22032	                 ssr: 00000000000000280402800100fd180a001e00000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
 22033	                 scr: 02b5800300000000
 22034	                name: CBADS
 22035
 22036	### Boot system health:
 22037
 22038	Time       big.LITTLE   load %cpu %sys %usr %nice %io %irq   CPU  C.St.
 22039	14:24:28: 1908/1992MHz  0.60  22%  10%   4%   0%   7%   0% 34.1°C  0/11
 22040	14:24:28: 1908/1992MHz  0.60  66%  35%  11%   0%  18%   1% 33.7°C  0/11
 22041	14:24:29: 1908/1992MHz  0.60  83%  27%   1%   0%  53%   0% 31.7°C  0/11
 22042	14:24:29: 1908/1992MHz  0.60  48%   5%   5%   0%  34%   0% 30.4°C  0/11
 22043	14:24:29: 1908/1992MHz  0.60  62%  10%   4%   0%  46%   0% 30.5°C  0/11
 22044
 22045	### Activated 1 lzo-rle zram swap devices with 1848 MB each
 22046
 22047	### Activated Armbian ramlog partition with zstd compression
 22048
 22049	Mon 03 May 2021 02:53:28 PM BST | Odroid N2 | 21.02.4 | arm64 | aarch64 | 5.10.27-meson64
 22050
 22051	### dmesg:
 22052
 22053	[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
 22054	[    0.000000] Linux version 5.10.27-meson64 (root@hirsute) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #21.02.4 SMP PREEMPT Sun Apr 4 09:23:42 UTC 2021
 22055	[    0.000000] Machine model: Hardkernel ODROID-N2
 22056	[    0.000000] efi: UEFI not found.
 22057	[    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
 22058	[    0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB
 22059	[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
 22060	[    0.000000] NUMA: No NUMA configuration found
 22061	[    0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ed7fffff]
 22062	[    0.000000] NUMA: NODE_DATA [mem 0xb502f100-0xb5030fff]
 22063	[    0.000000] Zone ranges:
 22064	[    0.000000]   DMA      [mem 0x0000000000000000-0x00000000ed7fffff]
 22065	[    0.000000]   DMA32    empty
 22066	[    0.000000]   Normal   empty
 22067	[    0.000000] Movable zone start for each node
 22068	[    0.000000] Early memory node ranges
 22069	[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000004ffffff]
 22070	[    0.000000]   node   0: [mem 0x0000000005000000-0x00000000052fffff]
 22071	[    0.000000]   node   0: [mem 0x0000000005300000-0x00000000ed7fffff]
 22072	[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ed7fffff]
 22073	[    0.000000] On node 0 totalpages: 972800
 22074	[    0.000000]   DMA zone: 15200 pages used for memmap
 22075	[    0.000000]   DMA zone: 0 pages reserved
 22076	[    0.000000]   DMA zone: 972800 pages, LIFO batch:63
 22077	[    0.000000] psci: probing for conduit method from DT.
 22078	[    0.000000] psci: PSCIv1.0 detected in firmware.
 22079	[    0.000000] psci: Using standard PSCI v0.2 function IDs
 22080	[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
 22081	[    0.000000] psci: SMC Calling Convention v1.1
 22082	[    0.000000] percpu: Embedded 23 pages/cpu s56728 r8192 d29288 u94208
 22083	[    0.000000] pcpu-alloc: s56728 r8192 d29288 u94208 alloc=23*4096
 22084	[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
 22085	[    0.000000] Detected VIPT I-cache on CPU0
 22086	[    0.000000] CPU features: detected: ARM erratum 845719
 22087	[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 957600
 22088	[    0.000000] Policy zone: DMA
 22089	[    0.000000] Kernel command line: root=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c rootwait rootfstype=ext4 console=ttyAML0,115200n8 console=tty1 loglevel=1  no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=custombuilt cvbsmode=576cvbs max_freq_a53=1896 max_freq_a73=1800 maxcpus=6 voutmode=hdmi modeline=1920,1080,148500,56250,50,1920,2448,2492,2640,1080,1084,1089,1125,1,1,1 disablehpd=false  cvbscable= overscan=100 consoleblank=0
 22090	[    0.000000] Kernel parameter elevator= does not have any effect anymore.
 22091	               Please use sysfs to set IO scheduler for individual devices.
 22092	[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
 22093	[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
 22094	[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
 22095	[    0.000000] Memory: 2851276K/3891200K available (14144K kernel code, 1760K rwdata, 5512K rodata, 3328K init, 592K bss, 122420K reserved, 917504K cma-reserved)
 22096	[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
 22097	[    0.000000] rcu: Preemptible hierarchical RCU implementation.
 22098	[    0.000000] rcu: 	RCU event tracing is enabled.
 22099	[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
 22100	[    0.000000] 	Trampoline variant of Tasks RCU enabled.
 22101	[    0.000000] 	Rude variant of Tasks RCU enabled.
 22102	[    0.000000] 	Tracing variant of Tasks RCU enabled.
 22103	[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
 22104	[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
 22105	[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
 22106	[    0.000000] GIC: Using split EOI/Deactivate mode
 22107	[    0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized
 22108	[    0.000000] random: get_random_bytes called from start_kernel+0x378/0x538 with crng_init=0
 22109	[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
 22110	[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
 22111	[    0.000003] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
 22112	[    0.000249] Console: colour dummy device 80x25
 22113	[    0.000281] printk: console [tty1] enabled
 22114	[    0.000366] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
 22115	[    0.000378] pid_max: default: 32768 minimum: 301
 22116	[    0.000463] LSM: Security Framework initializing
 22117	[    0.000488] Yama: becoming mindful.
 22118	[    0.000577] AppArmor: AppArmor initialized
 22119	[    0.000629] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
 22120	[    0.000647] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
 22121	[    0.002642] rcu: Hierarchical SRCU implementation.
 22122	[    0.005119] EFI services will not be available.
 22123	[    0.005544] smp: Bringing up secondary CPUs ...
 22124	[    0.006217] Detected VIPT I-cache on CPU1
 22125	[    0.006276] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
 22126	[    0.007476] CPU features: detected: ARM erratum 858921
 22127	[    0.007485] CPU features: detected: Spectre-v2
 22128	[    0.007489] CPU features: detected: Spectre-v4
 22129	[    0.007495] Detected VIPT I-cache on CPU2
 22130	[    0.007519] arch_timer: Enabling local workaround for ARM erratum 858921
 22131	[    0.007535] arch_timer: CPU2: Trapping CNTVCT access
 22132	[    0.007549] CPU2: Booted secondary processor 0x0000000100 [0x410fd092]
 22133	[    0.008257] Detected VIPT I-cache on CPU3
 22134	[    0.008273] arch_timer: Enabling local workaround for ARM erratum 858921
 22135	[    0.008281] arch_timer: CPU3: Trapping CNTVCT access
 22136	[    0.008289] CPU3: Booted secondary processor 0x0000000101 [0x410fd092]
 22137	[    0.008917] Detected VIPT I-cache on CPU4
 22138	[    0.008934] arch_timer: Enabling local workaround for ARM erratum 858921
 22139	[    0.008940] arch_timer: CPU4: Trapping CNTVCT access
 22140	[    0.008948] CPU4: Booted secondary processor 0x0000000102 [0x410fd092]
 22141	[    0.009572] Detected VIPT I-cache on CPU5
 22142	[    0.009588] arch_timer: Enabling local workaround for ARM erratum 858921
 22143	[    0.009596] arch_timer: CPU5: Trapping CNTVCT access
 22144	[    0.009604] CPU5: Booted secondary processor 0x0000000103 [0x410fd092]
 22145	[    0.009684] smp: Brought up 1 node, 6 CPUs
 22146	[    0.009701] SMP: Total of 6 processors activated.
 22147	[    0.009709] CPU features: detected: 32-bit EL0 Support
 22148	[    0.009715] CPU features: detected: CRC32 instructions
 22149	[    0.009720] CPU features: detected: 32-bit EL1 Support
 22150	[    0.020988] CPU: All CPU(s) started at EL2
 22151	[    0.021038] alternatives: patching kernel code
 22152	[    0.022308] devtmpfs: initialized
 22153	[    0.029954] Registered cp15_barrier emulation handler
 22154	[    0.029967] Registered setend emulation handler
 22155	[    0.030103] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
 22156	[    0.030143] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
 22157	[    0.046227] pinctrl core: initialized pinctrl subsystem
 22158	[    0.046945] DMI not present or invalid.
 22159	[    0.047322] NET: Registered protocol family 16
 22160	[    0.048937] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
 22161	[    0.049181] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
 22162	[    0.049474] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
 22163	[    0.049516] audit: initializing netlink subsys (disabled)
 22164	[    0.049630] audit: type=2000 audit(0.048:1): state=initialized audit_enabled=0 res=1
 22165	[    0.050924] thermal_sys: Registered thermal governor 'fair_share'
 22166	[    0.050932] thermal_sys: Registered thermal governor 'bang_bang'
 22167	[    0.050936] thermal_sys: Registered thermal governor 'step_wise'
 22168	[    0.050939] thermal_sys: Registered thermal governor 'user_space'
 22169	[    0.051366] cpuidle: using governor menu
 22170	[    0.051713] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
 22171	[    0.051834] ASID allocator initialised with 65536 entries
 22172	[    0.052790] Serial: AMBA PL011 UART driver
 22173	[    0.087316] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
 22174	[    0.087326] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
 22175	[    0.087330] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
 22176	[    0.087335] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
 22177	[    0.088782] cryptd: max_cpu_qlen set to 1000
 22178	[    0.156225] raid6: neonx8   gen()  2785 MB/s
 22179	[    0.224285] raid6: neonx8   xor()  2042 MB/s
 22180	[    0.292372] raid6: neonx4   gen()  2996 MB/s
 22181	[    0.360455] raid6: neonx4   xor()  2328 MB/s
 22182	[    0.428510] raid6: neonx2   gen()  2523 MB/s
 22183	[    0.496597] raid6: neonx2   xor()  1460 MB/s
 22184	[    0.564648] raid6: neonx1   gen()  2009 MB/s
 22185	[    0.632710] raid6: neonx1   xor()  1728 MB/s
 22186	[    0.700775] raid6: int64x8  gen()  1378 MB/s
 22187	[    0.768844] raid6: int64x8  xor()   736 MB/s
 22188	[    0.836921] raid6: int64x4  gen()  1462 MB/s
 22189	[    0.904980] raid6: int64x4  xor()   733 MB/s
 22190	[    0.973037] raid6: int64x2  gen()  1362 MB/s
 22191	[    1.041108] raid6: int64x2  xor()   619 MB/s
 22192	[    1.109172] raid6: int64x1  gen()  1127 MB/s
 22193	[    1.177235] raid6: int64x1  xor()   462 MB/s
 22194	[    1.177238] raid6: using algorithm neonx4 gen() 2996 MB/s
 22195	[    1.177241] raid6: .... xor() 2328 MB/s, rmw enabled
 22196	[    1.177245] raid6: using neon recovery algorithm
 22197	[    1.177699] ACPI: Interpreter disabled.
 22198	[    1.178476] 5V: supplied by 12V
 22199	[    1.179360] VDDAO_3V3: supplied by 12V
 22200	[    1.179852] iommu: Default domain type: Translated
 22201	[    1.179991] vgaarb: loaded
 22202	[    1.180665] SCSI subsystem initialized
 22203	[    1.180912] usbcore: registered new interface driver usbfs
 22204	[    1.180949] usbcore: registered new interface driver hub
 22205	[    1.180996] usbcore: registered new device driver usb
 22206	[    1.181297] pps_core: LinuxPPS API ver. 1 registered
 22207	[    1.181302] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
 22208	[    1.181316] PTP clock support registered
 22209	[    1.181527] EDAC MC: Ver: 3.0.0
 22210	[    1.182891] NetLabel: Initializing
 22211	[    1.182899] NetLabel:  domain hash size = 128
 22212	[    1.182902] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
 22213	[    1.182944] NetLabel:  unlabeled traffic allowed by default
 22214	[    1.183436] clocksource: Switched to clocksource arch_sys_counter
 22215	[    1.183653] VFS: Disk quotas dquot_6.6.0
 22216	[    1.183695] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
 22217	[    1.184039] AppArmor: AppArmor Filesystem Enabled
 22218	[    1.184086] pnp: PnP ACPI: disabled
 22219	[    1.189703] NET: Registered protocol family 2
 22220	[    1.190156] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
 22221	[    1.190261] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
 22222	[    1.190518] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
 22223	[    1.190706] TCP: Hash tables configured (established 32768 bind 32768)
 22224	[    1.190858] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
 22225	[    1.190926] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
 22226	[    1.190973] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
 22227	[    1.191108] NET: Registered protocol family 1
 22228	[    1.191127] PCI: CLS 0 bytes, default 64
 22229	[    1.191253] Trying to unpack rootfs image as initramfs...
 22230	[    1.720670] Freeing initrd memory: 13540K
 22231	[    1.721604] kvm [1]: IPA Size Limit: 40 bits
 22232	[    1.722324] kvm [1]: vgic interrupt IRQ9
 22233	[    1.722456] kvm [1]: Hyp mode initialized successfully
 22234	[    1.727603] Initialise system trusted keyrings
 22235	[    1.727634] Key type blacklist registered
 22236	[    1.727757] workingset: timestamp_bits=44 max_order=20 bucket_order=0
 22237	[    1.730912] zbud: loaded
 22238	[    1.731844] squashfs: version 4.0 (2009/01/31) Phillip Lougher
 22239	[    1.732379] fuse: init (API version 7.32)
 22240	[    1.733154] integrity: Platform Keyring initialized
 22241	[    1.760727] xor: measuring software checksum speed
 22242	[    1.763594]    8regs           :  3476 MB/sec
 22243	[    1.766045]    32regs          :  4020 MB/sec
 22244	[    1.768710]    arm64_neon      :  3712 MB/sec
 22245	[    1.768713] xor: using function: 32regs (4020 MB/sec)
 22246	[    1.768719] Key type asymmetric registered
 22247	[    1.768723] Asymmetric key parser 'x509' registered
 22248	[    1.768756] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
 22249	[    1.768875] io scheduler mq-deadline registered
 22250	[    1.768880] io scheduler kyber registered
 22251	[    1.768958] io scheduler bfq registered
 22252	[    1.771484] gpio-447 (usb-hub-reset): hogged as output/high
 22253	[    1.774532] EINJ: ACPI disabled.
 22254	[    1.780848] soc soc0: Amlogic Meson G12B (S922X) Revision 29:a (40:2) Detected
 22255	[    1.782247] VCC_3V3: supplied by VDDAO_3V3
 22256	[    1.782282] FLASH_1V8: supplied by VCC_3V3
 22257	[    1.782317] VCC_1V8: supplied by VCC_3V3
 22258	[    1.782344] VDDAO_1V8: supplied by VDDAO_3V3
 22259	[    1.782385] VDDCPU_A: supplied by regulator-dummy
 22260	[    1.782733] VDDCPU_B: supplied by regulator-dummy
 22261	[    1.783450] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
 22262	[    1.786157] Serial: AMBA driver
 22263	[    1.786551] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart
 22264	[    1.786689] printk: console [ttyAML0] enabled
 22265	[    1.787336] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 33, base_baud = 1500000) is a meson_uart
 22266	[    1.792655] loop: module loaded
 22267	[    1.794532] libphy: Fixed MDIO Bus: probed
 22268	[    1.795701] tun: Universal TUN/TAP device driver, 1.6
 22269	[    1.796416] thunder_xcv, ver 1.0
 22270	[    1.796448] thunder_bgx, ver 1.0
 22271	[    1.796473] nicpf, ver 1.0
 22272	[    1.796949] e1000e: Intel(R) PRO/1000 Network Driver
 22273	[    1.796952] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
 22274	[    1.796989] igb: Intel(R) Gigabit Ethernet Network Driver
 22275	[    1.796992] igb: Copyright (c) 2007-2014 Intel Corporation.
 22276	[    1.797023] igbvf: Intel(R) Gigabit Virtual Function Network Driver
 22277	[    1.797026] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
 22278	[    1.797163] sky2: driver version 1.30
 22279	[    1.797555] VFIO - User Level meta-driver version: 0.3
 22280	[    1.799046] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
 22281	[    1.799068] ehci-pci: EHCI PCI platform driver
 22282	[    1.799102] ehci-platform: EHCI generic platform driver
 22283	[    1.799237] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
 22284	[    1.799248] ohci-pci: OHCI PCI platform driver
 22285	[    1.799280] ohci-platform: OHCI generic platform driver
 22286	[    1.799736] usbcore: registered new interface driver usb-storage
 22287	[    1.801066] mousedev: PS/2 mouse device common for all mice
 22288	[    1.801414] i2c /dev entries driver
 22289	[    1.806342] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17
 22290	[    1.807025] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz
 22291	[    1.808178] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-1 failed:-17
 22292	[    1.808809] sdhci: Secure Digital Host Controller Interface driver
 22293	[    1.808816] sdhci: Copyright(c) Pierre Ossman
 22294	[    1.808940] Synopsys Designware Multimedia Card Interface Driver
 22295	[    1.809399] sdhci-pltfm: SDHCI platform and OF driver helper
 22296	[    1.809819] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq
 22297	[    1.810871] ledtrig-cpu: registered to indicate activity on CPUs
 22298	[    1.811122] meson-sm: secure-monitor enabled
 22299	[    1.811286] hid: raw HID events driver (C) Jiri Kosina
 22300	[    1.811365] usbcore: registered new interface driver usbhid
 22301	[    1.811368] usbhid: USB HID core driver
 22302	[    1.812415] NET: Registered protocol family 10
 22303	[    1.812879] Segment Routing with IPv6
 22304	[    1.812906] NET: Registered protocol family 17
 22305	[    1.812965] 8021q: 802.1Q VLAN Support v1.8
 22306	[    1.812988] Key type dns_resolver registered
 22307	[    1.813298] registered taskstats version 1
 22308	[    1.813304] Loading compiled-in X.509 certificates
 22309	[    1.814999] Loaded X.509 cert 'Build time autogenerated kernel key: 98b5fbd0004968eadd44123544af94c22f57c8e4'
 22310	[    1.816896] zswap: loaded using pool zstd/z3fold
 22311	[    1.817118] Key type ._fscrypt registered
 22312	[    1.817120] Key type .fscrypt registered
 22313	[    1.817122] Key type fscrypt-provisioning registered
 22314	[    1.818200] Btrfs loaded, crc32c=crc32c-generic
 22315	[    1.824236] Key type encrypted registered
 22316	[    1.824248] AppArmor: AppArmor sha1 policy hashing enabled
 22317	[    1.830505] HUB_5V: supplied by 5V
 22318	[    1.830740] USB_PWR_EN: supplied by 5V
 22319	[    1.832418] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2
 22320	[    1.832425] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1
 22321	[    1.835099] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator
 22322	[    1.835147] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator
 22323	[    1.835254] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM
 22324	[    1.835947] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
 22325	[    1.835960] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
 22326	[    1.836055] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010
 22327	[    1.836080] xhci-hcd xhci-hcd.0.auto: irq 41, io mem 0xff500000
 22328	[    1.836208] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
 22329	[    1.836211] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 22330	[    1.836214] usb usb1: Product: xHCI Host Controller
 22331	[    1.836217] usb usb1: Manufacturer: Linux 5.10.27-meson64 xhci-hcd
 22332	[    1.836219] usb usb1: SerialNumber: xhci-hcd.0.auto
 22333	[    1.836435] hub 1-0:1.0: USB hub found
 22334	[    1.836448] hub 1-0:1.0: 2 ports detected
 22335	[    1.836583] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
 22336	[    1.836589] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
 22337	[    1.836602] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
 22338	[    1.836628] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
 22339	[    1.836663] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
 22340	[    1.836666] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 22341	[    1.836668] usb usb2: Product: xHCI Host Controller
 22342	[    1.836670] usb usb2: Manufacturer: Linux 5.10.27-meson64 xhci-hcd
 22343	[    1.836672] usb usb2: SerialNumber: xhci-hcd.0.auto
 22344	[    1.836852] hub 2-0:1.0: USB hub found
 22345	[    1.836863] hub 2-0:1.0: 1 port detected
 22346	[    1.838377] meson-gx-mmc ffe05000.sd: Got CD GPIO
 22347	[    1.864487] Freeing unused kernel memory: 3328K
 22348	[    1.895507] Run /init as init process
 22349	[    1.895511]   with arguments:
 22350	[    1.895513]     /init
 22351	[    1.895515]   with environment:
 22352	[    1.895516]     HOME=/
 22353	[    1.895518]     TERM=linux
 22354	[    1.895520]     hdmimode=custombuilt
 22355	[    1.895521]     cvbsmode=576cvbs
 22356	[    1.895523]     max_freq_a53=1896
 22357	[    1.895524]     max_freq_a73=1800
 22358	[    1.895526]     voutmode=hdmi
 22359	[    1.895528]     modeline=1920,1080,148500,56250,50,1920,2448,2492,2640,1080,1084,1089,1125,1,1,1
 22360	[    1.895529]     disablehpd=false
 22361	[    1.895531]     cvbscable=
 22362	[    1.895532]     overscan=100
 22363	[    1.914169] mmc0: new high speed SDHC card at address b368
 22364	[    1.914751] mmcblk0: mmc0:b368 CBADS 30.0 GiB
 22365	[    1.916727]  mmcblk0: p1
 22366	[    2.043757] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found
 22367	[    2.043765] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found
 22368	[    2.043857] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock
 22369	[    2.043862] meson8b-dwmac ff3f0000.ethernet: no reset control found
 22370	[    2.044281] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37
 22371	[    2.044289] meson8b-dwmac ff3f0000.ethernet: 	DWMAC1000
 22372	[    2.044293] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported
 22373	[    2.044295] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported
 22374	[    2.044298] meson8b-dwmac ff3f0000.ethernet: COE Type 2
 22375	[    2.044300] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported
 22376	[    2.044302] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported
 22377	[    2.044359] meson8b-dwmac ff3f0000.ethernet: Normal descriptors
 22378	[    2.044362] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled
 22379	[    2.044364] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
 22380	[    2.044573] libphy: stmmac: probed
 22381	[    2.048272] libphy: mdio_mux: probed
 22382	[    2.060356] meson-vrtc ff8000a8.rtc: registered as rtc1
 22383	[    2.077399] rtc-pcf8563 1-0051: registered as rtc0
 22384	[    2.078748] rtc-pcf8563 1-0051: setting system clock to 2021-05-03T13:53:18 UTC (1620049998)
 22385	[    2.085393] random: fast init done
 22386	[    2.171449] usb 1-1: new high-speed USB device number 2 using xhci-hcd
 22387	[    2.255842] libphy: mdio_mux: probed
 22388	[    2.321802] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.04
 22389	[    2.321809] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
 22390	[    2.321811] usb 1-1: Product: USB2.1 Hub
 22391	[    2.321814] usb 1-1: Manufacturer: GenesysLogic
 22392	[    2.380822] hub 1-1:1.0: USB hub found
 22393	[    2.381042] hub 1-1:1.0: 4 ports detected
 22394	[    2.447557] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
 22395	[    2.470033] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.04
 22396	[    2.470038] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
 22397	[    2.470041] usb 2-1: Product: USB3.1 Hub
 22398	[    2.470045] usb 2-1: Manufacturer: GenesysLogic
 22399	[    2.492852] hub 2-1:1.0: USB hub found
 22400	[    2.493139] hub 2-1:1.0: 4 ports detected
 22401	[    2.595437] usb 1-2: new high-speed USB device number 3 using xhci-hcd
 22402	[    2.723443] usb 1-2: device descriptor read/64, error -71
 22403	[    2.959441] usb 1-2: device descriptor read/64, error -71
 22404	[    3.195431] usb 1-2: new high-speed USB device number 4 using xhci-hcd
 22405	[    3.323441] usb 1-2: device descriptor read/64, error -71
 22406	[    3.559440] usb 1-2: device descriptor read/64, error -71
 22407	[    3.667459] usb usb1-port2: attempt power cycle
 22408	[    4.319429] usb 1-2: new high-speed USB device number 5 using xhci-hcd
 22409	[    4.319457] usb 1-2: Device not responding to setup address.
 22410	[    4.527452] usb 1-2: Device not responding to setup address.
 22411	[    4.735428] usb 1-2: device not accepting address 5, error -71
 22412	[    4.863429] usb 1-2: new high-speed USB device number 6 using xhci-hcd
 22413	[    4.863457] usb 1-2: Device not responding to setup address.
 22414	[    5.071452] usb 1-2: Device not responding to setup address.
 22415	[    5.279429] usb 1-2: device not accepting address 6, error -71
 22416	[    5.279461] usb usb1-port2: unable to enumerate USB device
 22417	[    5.521831] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
 22418	[    6.358497] systemd[1]: Inserted module 'autofs4'
 22419	[    6.405594] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
 22420	[    6.405809] systemd[1]: Detected architecture arm64.
 22421	[    6.433313] systemd[1]: Set hostname to <odroidn2>.
 22422	[    6.761970] random: systemd: uninitialized urandom read (16 bytes read)
 22423	[    6.765241] random: systemd: uninitialized urandom read (16 bytes read)
 22424	[    6.766504] systemd[1]: Created slice system-serial\x2dgetty.slice.
 22425	[    6.766728] random: systemd: uninitialized urandom read (16 bytes read)
 22426	[    6.766811] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
 22427	[    6.766992] systemd[1]: Listening on initctl Compatibility Named Pipe.
 22428	[    6.767250] systemd[1]: Listening on Syslog Socket.
 22429	[    6.767750] systemd[1]: Created slice system-getty.slice.
 22430	[    6.768033] systemd[1]: Listening on udev Control Socket.
 22431	[    6.768116] systemd[1]: Reached target System Time Synchronized.
 22432	[    6.865788] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
 22433	[    7.417623] pwm-gpio pwmgpio: 1 gpio pwms loaded
 22434	[    7.428902] zram: Added device: zram0
 22435	[    7.429059] zram: Added device: zram1
 22436	[    7.429209] zram: Added device: zram2
 22437	[    7.545923] mc: Linux media interface: v0.10
 22438	[    7.602113] videodev: Linux video capture interface: v2.00
 22439	[    7.620445] panfrost ffe40000.gpu: clock rate = 24000000
 22440	[    7.620519] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19
 22441	[    7.621480] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0
 22442	[    7.621492] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400
 22443	[    7.621497] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
 22444	[    7.621501] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1
 22445	[    7.631717] meson-saradc ff809000.adc: supply vref not found, using dummy regulator
 22446	[    7.636711] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 0
 22447	[    7.657458] meson-drm ff900000.vpu: Queued 2 outputs on vpu
 22448	[    7.660029] Registered IR keymap rc-odroid
 22449	[    7.704852] IR NEC protocol handler initialized
 22450	[    7.719386] meson-drm ff900000.vpu: CVBS Output connector not available
 22451	[    7.731510] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0
 22452	[    7.731616] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
 22453	[    7.731674] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input0
 22454	[    7.731907] meson-ir ff808000.ir: receiver initialized
 22455	[    7.747529] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
 22456	[    7.751237] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
 22457	[    7.751811] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
 22458	[    7.752210] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 1
 22459	[    7.781673] zram0: detected capacity change from 0 to 1938251776
 22460	[    7.810089] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
 22461	[    8.039625] Console: switching to colour frame buffer device 240x67
 22462	[    8.074355] meson-drm ff900000.vpu: [drm] fb0: mesondrmfb frame buffer device
 22463	[    8.115794] axg-sound-card sound: ASoC: no DMI vendor name!
 22464	[    8.839445] Adding 1892820k swap on /dev/zram0.  Priority:5 extents:1 across:1892820k SSFS
 22465	[    8.905376] zram1: detected capacity change from 0 to 52428800
 22466	[   10.990864] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
 22467	[   10.990883] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
 22468	[   12.268772] systemd[1]: Started Armbian memory supported logging.
 22469	[   12.271064] systemd[1]: Starting Journal Service...
 22470	[   12.326848] systemd[1]: Started Journal Service.
 22471	[   12.345629] systemd-journald[1838]: Received request to flush runtime journal from PID 1
 22472
 22473	### armbian-release:
 22474
 22475	# PLEASE DO NOT EDIT THIS FILE
 22476	BOARD=odroidn2
 22477	BOARD_NAME="Odroid N2"
 22478	BOARDFAMILY=meson-g12b
 22479	BUILD_REPOSITORY_URL=git@github.com:armbian/build.git
 22480	BUILD_REPOSITORY_COMMIT=23e571cb4-dirty
 22481	DISTRIBUTION_CODENAME=buster
 22482	DISTRIBUTION_STATUS=supported
 22483	VERSION=21.02.4
 22484	LINUXFAMILY=meson64
 22485	BRANCH=current
 22486	ARCH=arm64
 22487	IMAGE_TYPE=stable
 22488	BOARD_TYPE=conf
 22489	INITRD_ARCH=arm64
 22490	KERNEL_IMAGE_TYPE=Image
 22491
 22492	### boot environment:
 22493
 22494	verbosity=1
 22495	console=both
 22496	overlay_prefix=meson
 22497	rootdev=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c
 22498	rootfstype=ext4
 22499	usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
 22500
 22501	### lsusb:
 22502
 22503	Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc.
 22504	Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
 22505	Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
 22506	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
 22507
 22508	### lscpu:
 22509
 22510	Architecture:        aarch64
 22511	Byte Order:          Little Endian
 22512	CPU(s):              6
 22513	On-line CPU(s) list: 0-5
 22514	Thread(s) per core:  1
 22515	Core(s) per socket:  3
 22516	Socket(s):           2
 22517	NUMA node(s):        1
 22518	Vendor ID:           ARM
 22519	Model:               4
 22520	Model name:          Cortex-A53
 22521	Stepping:            r0p4
 22522	CPU max MHz:         1992.0000
 22523	CPU min MHz:         100.0000
 22524	BogoMIPS:            48.00
 22525	L1d cache:           unknown size
 22526	L1i cache:           unknown size
 22527	L2 cache:            unknown size
 22528	NUMA node0 CPU(s):   0-5
 22529	Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 22530
 22531	### cpuinfo:
 22532
 22533	processor	: 0
 22534	BogoMIPS	: 48.00
 22535	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 22536	CPU implementer	: 0x41
 22537	CPU architecture: 8
 22538	CPU variant	: 0x0
 22539	CPU part	: 0xd03
 22540	CPU revision	: 4
 22541
 22542	processor	: 1
 22543	BogoMIPS	: 48.00
 22544	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 22545	CPU implementer	: 0x41
 22546	CPU architecture: 8
 22547	CPU variant	: 0x0
 22548	CPU part	: 0xd03
 22549	CPU revision	: 4
 22550
 22551	processor	: 2
 22552	BogoMIPS	: 48.00
 22553	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 22554	CPU implementer	: 0x41
 22555	CPU architecture: 8
 22556	CPU variant	: 0x0
 22557	CPU part	: 0xd09
 22558	CPU revision	: 2
 22559
 22560	processor	: 3
 22561	BogoMIPS	: 48.00
 22562	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 22563	CPU implementer	: 0x41
 22564	CPU architecture: 8
 22565	CPU variant	: 0x0
 22566	CPU part	: 0xd09
 22567	CPU revision	: 2
 22568
 22569	processor	: 4
 22570	BogoMIPS	: 48.00
 22571	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 22572	CPU implementer	: 0x41
 22573	CPU architecture: 8
 22574	CPU variant	: 0x0
 22575	CPU part	: 0xd09
 22576	CPU revision	: 2
 22577
 22578	processor	: 5
 22579	BogoMIPS	: 48.00
 22580	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 22581	CPU implementer	: 0x41
 22582	CPU architecture: 8
 22583	CPU variant	: 0x0
 22584	CPU part	: 0xd09
 22585	CPU revision	: 2
 22586
 22587
 22588	### meminfo:
 22589
 22590	MemTotal:        3785648 kB
 22591	MemFree:         3533624 kB
 22592	MemAvailable:    3533676 kB
 22593	Buffers:           11664 kB
 22594	Cached:            48452 kB
 22595	SwapCached:            0 kB
 22596	Active:            30408 kB
 22597	Inactive:         118544 kB
 22598	Active(anon):         96 kB
 22599	Inactive(anon):    94048 kB
 22600	Active(file):      30312 kB
 22601	Inactive(file):    24496 kB
 22602	Unevictable:           0 kB
 22603	Mlocked:               0 kB
 22604	SwapTotal:       1892820 kB
 22605	SwapFree:        1892820 kB
 22606	Dirty:              9132 kB
 22607	Writeback:             0 kB
 22608	AnonPages:         89248 kB
 22609	Mapped:            10964 kB
 22610	Shmem:              5016 kB
 22611	KReclaimable:      12880 kB
 22612	Slab:              38132 kB
 22613	SReclaimable:      12880 kB
 22614	SUnreclaim:        25252 kB
 22615	KernelStack:        2064 kB
 22616	PageTables:         2960 kB
 22617	NFS_Unstable:          0 kB
 22618	Bounce:                0 kB
 22619	WritebackTmp:          0 kB
 22620	CommitLimit:     3785644 kB
 22621	Committed_AS:    4210624 kB
 22622	VmallocTotal:   135290159040 kB
 22623	VmallocUsed:       31004 kB
 22624	VmallocChunk:          0 kB
 22625	Percpu:             1368 kB
 22626	HardwareCorrupted:     0 kB
 22627	AnonHugePages:         0 kB
 22628	ShmemHugePages:        0 kB
 22629	ShmemPmdMapped:        0 kB
 22630	FileHugePages:         0 kB
 22631	FilePmdMapped:         0 kB
 22632	CmaTotal:         917504 kB
 22633	CmaFree:          901212 kB
 22634	HugePages_Total:       0
 22635	HugePages_Free:        0
 22636	HugePages_Rsvd:        0
 22637	HugePages_Surp:        0
 22638	Hugepagesize:       2048 kB
 22639	Hugetlb:               0 kB
 22640
 22641	### virtual memory:
 22642
 22643	vm.admin_reserve_kbytes = 8192
 22644	vm.block_dump = 0
 22645	vm.compaction_proactiveness = 20
 22646	vm.compact_unevictable_allowed = 1
 22647	vm.dirty_background_bytes = 0
 22648	vm.dirty_background_ratio = 10
 22649	vm.dirty_bytes = 0
 22650	vm.dirty_expire_centisecs = 3000
 22651	vm.dirty_ratio = 20
 22652	vm.dirtytime_expire_seconds = 43200
 22653	vm.dirty_writeback_centisecs = 500
 22654	vm.extfrag_threshold = 500
 22655	vm.hugetlb_shm_group = 0
 22656	vm.laptop_mode = 0
 22657	vm.legacy_va_layout = 0
 22658	vm.lowmem_reserve_ratio = 256	256	32	0
 22659	vm.max_map_count = 65530
 22660	vm.memory_failure_early_kill = 0
 22661	vm.memory_failure_recovery = 1
 22662	vm.min_free_kbytes = 22528
 22663	vm.min_slab_ratio = 5
 22664	vm.min_unmapped_ratio = 1
 22665	vm.mmap_min_addr = 4096
 22666	vm.mmap_rnd_bits = 18
 22667	vm.mmap_rnd_compat_bits = 11
 22668	vm.nr_hugepages = 0
 22669	vm.nr_hugepages_mempolicy = 0
 22670	vm.nr_overcommit_hugepages = 0
 22671	vm.numa_stat = 1
 22672	vm.numa_zonelist_order = Node
 22673	vm.oom_dump_tasks = 1
 22674	vm.oom_kill_allocating_task = 0
 22675	vm.overcommit_kbytes = 0
 22676	vm.overcommit_memory = 0
 22677	vm.overcommit_ratio = 50
 22678	vm.page-cluster = 0
 22679	vm.page_lock_unfairness = 5
 22680	vm.panic_on_oom = 0
 22681	vm.percpu_pagelist_fraction = 0
 22682	vm.stat_interval = 1
 22683	vm.swappiness = 100
 22684	vm.user_reserve_kbytes = 117115
 22685	vm.vfs_cache_pressure = 100
 22686	vm.watermark_boost_factor = 15000
 22687	vm.watermark_scale_factor = 10
 22688	vm.zone_reclaim_mode = 0
 22689
 22690	### ip addr:
 22691
 22692	1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
 22693	    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
 22694	    inet XXX.XXX.0.1/8 scope host lo
 22695	       valid_lft forever preferred_lft forever
 22696	    inet6 ::1/128 scope host
 22697	       valid_lft forever preferred_lft forever
 22698	2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
 22699	    link/ether 00:1e:06:42:03:f8 brd ff:ff:ff:ff:ff:ff
 22700
 22701	### partitions:
 22702
 22703	major minor  #blocks  name
 22704
 22705	 179        0   31464960 mmcblk0
 22706	 179        1   31146208 mmcblk0p1
 22707	 252        0    1892824 zram0
 22708	 252        1      51200 zram1
 22709
 22710	### df:
 22711
 22712	udev            1.4G     0  1.4G   0% /dev
 22713	tmpfs           370M  5.0M  365M   2% /run
 22714	/dev/mmcblk0p1   30G  1.8G   28G   7% /
 22715	tmpfs           1.9G     0  1.9G   0% /dev/shm
 22716	tmpfs           5.0M  4.0K  5.0M   1% /run/lock
 22717	tmpfs           1.9G     0  1.9G   0% /sys/fs/cgroup
 22718	tmpfs           1.9G     0  1.9G   0% /tmp
 22719	/dev/zram1       49M  9.0M   37M  20% /var/log
 22720
 22721	### lsblk:
 22722
 22723	NAME        FSTYPE  SIZE MOUNTPOINT UUID
 22724	mmcblk0              30G
 22725	└─mmcblk0p1 ext4   29.7G /          bd34953d-41be-49d6-b1c0-c0c28a5e239c
 22726	zram1                50M /var/log
 22727
 22728	### zramctl:
 22729
 22730	NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
 22731	/dev/zram1 zstd           50M  132K  695B   36K       6 /var/log
 22732	/dev/zram0 lzo-rle       1.8G    4K   74B   12K       6 [SWAP]
 22733
 22734	### mtab:
 22735
 22736	/dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
 22737	/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
 22738	/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
 22739
 22740	### mmc0:b368 info:
 22741
 22742	               fwrev: 0x0
 22743	              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=CBADS MODALIAS=mmc:block
 22744	                 cid: 6f0303434241445310aa002b4d013b00
 22745	                 rca: 0xb368
 22746	                 csd: 400e005a5b590000f00e7f800a404000
 22747	              manfid: 0x00006f
 22748	                 ocr: 0x00200000
 22749	preferred_erase_size: 2097152
 22750	                type: SD
 22751	               hwrev: 0x1
 22752	                date: 11/2019
 22753	                 dsr: 0x404
 22754	          erase_size: 512
 22755	               oemid: 0x0303
 22756	              serial: 0xaa002b4d
 22757	                 ssr: 00000000000000280402800100fd180a001e00000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
 22758	                 scr: 02b5800300000000
 22759	                name: CBADS
 22760
 22761	### Boot system health:
 22762
 22763	Time       big.LITTLE   load %cpu %sys %usr %nice %io %irq   CPU  C.St.
 22764	14:53:29: 1908/1992MHz  0.07  18%   8%   4%   0%   5%   0% 34.0°C  0/11
 22765	14:53:30: 1908/1992MHz  0.07  93%  37%   6%   0%  48%   1% 33.6°C  0/11
 22766	14:53:30: 1908/1992MHz  0.07  78%  22%   6%   0%  47%   1% 31.7°C  0/11
 22767	14:53:30: 1908/1992MHz  0.07  46%   4%   2%   0%  39%   0% 30.2°C  0/11
 22768	14:53:31: 1908/1992MHz  0.07  57%   2%   4%   0%  48%   0% 29.9°C  0/11
 22769
 22770	### Activated 1 lzo-rle zram swap devices with 1848 MB each
 22771
 22772	### Activated Armbian ramlog partition with zstd compression
 22773
 22774	Mon 03 May 2021 02:58:15 PM BST | Odroid N2 | 21.02.4 | arm64 | aarch64 | 5.10.27-meson64
 22775
 22776	### dmesg:
 22777
 22778	[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
 22779	[    0.000000] Linux version 5.10.27-meson64 (root@hirsute) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #21.02.4 SMP PREEMPT Sun Apr 4 09:23:42 UTC 2021
 22780	[    0.000000] Machine model: Hardkernel ODROID-N2
 22781	[    0.000000] efi: UEFI not found.
 22782	[    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
 22783	[    0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB
 22784	[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
 22785	[    0.000000] NUMA: No NUMA configuration found
 22786	[    0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ed7fffff]
 22787	[    0.000000] NUMA: NODE_DATA [mem 0xb502f100-0xb5030fff]
 22788	[    0.000000] Zone ranges:
 22789	[    0.000000]   DMA      [mem 0x0000000000000000-0x00000000ed7fffff]
 22790	[    0.000000]   DMA32    empty
 22791	[    0.000000]   Normal   empty
 22792	[    0.000000] Movable zone start for each node
 22793	[    0.000000] Early memory node ranges
 22794	[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000004ffffff]
 22795	[    0.000000]   node   0: [mem 0x0000000005000000-0x00000000052fffff]
 22796	[    0.000000]   node   0: [mem 0x0000000005300000-0x00000000ed7fffff]
 22797	[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ed7fffff]
 22798	[    0.000000] On node 0 totalpages: 972800
 22799	[    0.000000]   DMA zone: 15200 pages used for memmap
 22800	[    0.000000]   DMA zone: 0 pages reserved
 22801	[    0.000000]   DMA zone: 972800 pages, LIFO batch:63
 22802	[    0.000000] psci: probing for conduit method from DT.
 22803	[    0.000000] psci: PSCIv1.0 detected in firmware.
 22804	[    0.000000] psci: Using standard PSCI v0.2 function IDs
 22805	[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
 22806	[    0.000000] psci: SMC Calling Convention v1.1
 22807	[    0.000000] percpu: Embedded 23 pages/cpu s56728 r8192 d29288 u94208
 22808	[    0.000000] pcpu-alloc: s56728 r8192 d29288 u94208 alloc=23*4096
 22809	[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
 22810	[    0.000000] Detected VIPT I-cache on CPU0
 22811	[    0.000000] CPU features: detected: ARM erratum 845719
 22812	[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 957600
 22813	[    0.000000] Policy zone: DMA
 22814	[    0.000000] Kernel command line: root=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c rootwait rootfstype=ext4 console=ttyAML0,115200n8 console=tty1 loglevel=1  no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=custombuilt cvbsmode=576cvbs max_freq_a53=1896 max_freq_a73=1800 maxcpus=6 voutmode=hdmi modeline=1920,1080,148500,56250,50,1920,2448,2492,2640,1080,1084,1089,1125,1,1,1 disablehpd=false  cvbscable= overscan=100 consoleblank=0
 22815	[    0.000000] Kernel parameter elevator= does not have any effect anymore.
 22816	               Please use sysfs to set IO scheduler for individual devices.
 22817	[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
 22818	[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
 22819	[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
 22820	[    0.000000] Memory: 2851276K/3891200K available (14144K kernel code, 1760K rwdata, 5512K rodata, 3328K init, 592K bss, 122420K reserved, 917504K cma-reserved)
 22821	[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
 22822	[    0.000000] rcu: Preemptible hierarchical RCU implementation.
 22823	[    0.000000] rcu: 	RCU event tracing is enabled.
 22824	[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
 22825	[    0.000000] 	Trampoline variant of Tasks RCU enabled.
 22826	[    0.000000] 	Rude variant of Tasks RCU enabled.
 22827	[    0.000000] 	Tracing variant of Tasks RCU enabled.
 22828	[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
 22829	[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
 22830	[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
 22831	[    0.000000] GIC: Using split EOI/Deactivate mode
 22832	[    0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized
 22833	[    0.000000] random: get_random_bytes called from start_kernel+0x378/0x538 with crng_init=0
 22834	[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
 22835	[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
 22836	[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
 22837	[    0.000250] Console: colour dummy device 80x25
 22838	[    0.000284] printk: console [tty1] enabled
 22839	[    0.000370] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
 22840	[    0.000382] pid_max: default: 32768 minimum: 301
 22841	[    0.000465] LSM: Security Framework initializing
 22842	[    0.000490] Yama: becoming mindful.
 22843	[    0.000580] AppArmor: AppArmor initialized
 22844	[    0.000632] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
 22845	[    0.000650] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
 22846	[    0.002644] rcu: Hierarchical SRCU implementation.
 22847	[    0.005143] EFI services will not be available.
 22848	[    0.005564] smp: Bringing up secondary CPUs ...
 22849	[    0.006239] Detected VIPT I-cache on CPU1
 22850	[    0.006298] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
 22851	[    0.007495] CPU features: detected: ARM erratum 858921
 22852	[    0.007504] CPU features: detected: Spectre-v2
 22853	[    0.007508] CPU features: detected: Spectre-v4
 22854	[    0.007514] Detected VIPT I-cache on CPU2
 22855	[    0.007539] arch_timer: Enabling local workaround for ARM erratum 858921
 22856	[    0.007554] arch_timer: CPU2: Trapping CNTVCT access
 22857	[    0.007568] CPU2: Booted secondary processor 0x0000000100 [0x410fd092]
 22858	[    0.008277] Detected VIPT I-cache on CPU3
 22859	[    0.008294] arch_timer: Enabling local workaround for ARM erratum 858921
 22860	[    0.008301] arch_timer: CPU3: Trapping CNTVCT access
 22861	[    0.008308] CPU3: Booted secondary processor 0x0000000101 [0x410fd092]
 22862	[    0.008937] Detected VIPT I-cache on CPU4
 22863	[    0.008954] arch_timer: Enabling local workaround for ARM erratum 858921
 22864	[    0.008961] arch_timer: CPU4: Trapping CNTVCT access
 22865	[    0.008969] CPU4: Booted secondary processor 0x0000000102 [0x410fd092]
 22866	[    0.009593] Detected VIPT I-cache on CPU5
 22867	[    0.009610] arch_timer: Enabling local workaround for ARM erratum 858921
 22868	[    0.009616] arch_timer: CPU5: Trapping CNTVCT access
 22869	[    0.009624] CPU5: Booted secondary processor 0x0000000103 [0x410fd092]
 22870	[    0.009705] smp: Brought up 1 node, 6 CPUs
 22871	[    0.009722] SMP: Total of 6 processors activated.
 22872	[    0.009730] CPU features: detected: 32-bit EL0 Support
 22873	[    0.009736] CPU features: detected: CRC32 instructions
 22874	[    0.009741] CPU features: detected: 32-bit EL1 Support
 22875	[    0.020994] CPU: All CPU(s) started at EL2
 22876	[    0.021043] alternatives: patching kernel code
 22877	[    0.022318] devtmpfs: initialized
 22878	[    0.029964] Registered cp15_barrier emulation handler
 22879	[    0.029978] Registered setend emulation handler
 22880	[    0.030115] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
 22881	[    0.030155] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
 22882	[    0.046225] pinctrl core: initialized pinctrl subsystem
 22883	[    0.046937] DMI not present or invalid.
 22884	[    0.047301] NET: Registered protocol family 16
 22885	[    0.048907] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
 22886	[    0.049139] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
 22887	[    0.049432] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
 22888	[    0.049472] audit: initializing netlink subsys (disabled)
 22889	[    0.049585] audit: type=2000 audit(0.048:1): state=initialized audit_enabled=0 res=1
 22890	[    0.050922] thermal_sys: Registered thermal governor 'fair_share'
 22891	[    0.050931] thermal_sys: Registered thermal governor 'bang_bang'
 22892	[    0.050935] thermal_sys: Registered thermal governor 'step_wise'
 22893	[    0.050938] thermal_sys: Registered thermal governor 'user_space'
 22894	[    0.051347] cpuidle: using governor menu
 22895	[    0.051691] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
 22896	[    0.051810] ASID allocator initialised with 65536 entries
 22897	[    0.052775] Serial: AMBA PL011 UART driver
 22898	[    0.088886] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
 22899	[    0.088896] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
 22900	[    0.088901] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
 22901	[    0.088905] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
 22902	[    0.090400] cryptd: max_cpu_qlen set to 1000
 22903	[    0.160259] raid6: neonx8   gen()  2779 MB/s
 22904	[    0.228300] raid6: neonx8   xor()  2041 MB/s
 22905	[    0.296368] raid6: neonx4   gen()  2999 MB/s
 22906	[    0.364437] raid6: neonx4   xor()  2246 MB/s
 22907	[    0.432512] raid6: neonx2   gen()  2580 MB/s
 22908	[    0.500581] raid6: neonx2   xor()  2136 MB/s
 22909	[    0.568646] raid6: neonx1   gen()  1989 MB/s
 22910	[    0.636708] raid6: neonx1   xor()  1718 MB/s
 22911	[    0.704770] raid6: int64x8  gen()  1377 MB/s
 22912	[    0.772845] raid6: int64x8  xor()   736 MB/s
 22913	[    0.840920] raid6: int64x4  gen()  1463 MB/s
 22914	[    0.908974] raid6: int64x4  xor()   733 MB/s
 22915	[    0.977036] raid6: int64x2  gen()  1362 MB/s
 22916	[    1.045109] raid6: int64x2  xor()   619 MB/s
 22917	[    1.113166] raid6: int64x1  gen()  1127 MB/s
 22918	[    1.181247] raid6: int64x1  xor()   462 MB/s
 22919	[    1.181251] raid6: using algorithm neonx4 gen() 2999 MB/s
 22920	[    1.181254] raid6: .... xor() 2246 MB/s, rmw enabled
 22921	[    1.181258] raid6: using neon recovery algorithm
 22922	[    1.181708] ACPI: Interpreter disabled.
 22923	[    1.182486] 5V: supplied by 12V
 22924	[    1.183378] VDDAO_3V3: supplied by 12V
 22925	[    1.183845] iommu: Default domain type: Translated
 22926	[    1.183971] vgaarb: loaded
 22927	[    1.184922] SCSI subsystem initialized
 22928	[    1.185122] usbcore: registered new interface driver usbfs
 22929	[    1.185153] usbcore: registered new interface driver hub
 22930	[    1.185248] usbcore: registered new device driver usb
 22931	[    1.185550] pps_core: LinuxPPS API ver. 1 registered
 22932	[    1.185555] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
 22933	[    1.185625] PTP clock support registered
 22934	[    1.185828] EDAC MC: Ver: 3.0.0
 22935	[    1.187190] NetLabel: Initializing
 22936	[    1.187197] NetLabel:  domain hash size = 128
 22937	[    1.187200] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
 22938	[    1.187243] NetLabel:  unlabeled traffic allowed by default
 22939	[    1.187709] clocksource: Switched to clocksource arch_sys_counter
 22940	[    1.187909] VFS: Disk quotas dquot_6.6.0
 22941	[    1.187952] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
 22942	[    1.188311] AppArmor: AppArmor Filesystem Enabled
 22943	[    1.188359] pnp: PnP ACPI: disabled
 22944	[    1.193525] NET: Registered protocol family 2
 22945	[    1.194000] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
 22946	[    1.194110] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
 22947	[    1.194366] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
 22948	[    1.194554] TCP: Hash tables configured (established 32768 bind 32768)
 22949	[    1.194709] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
 22950	[    1.194775] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
 22951	[    1.194822] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
 22952	[    1.194964] NET: Registered protocol family 1
 22953	[    1.194988] PCI: CLS 0 bytes, default 64
 22954	[    1.195117] Trying to unpack rootfs image as initramfs...
 22955	[    1.724688] Freeing initrd memory: 13540K
 22956	[    1.725641] kvm [1]: IPA Size Limit: 40 bits
 22957	[    1.726366] kvm [1]: vgic interrupt IRQ9
 22958	[    1.726498] kvm [1]: Hyp mode initialized successfully
 22959	[    1.731599] Initialise system trusted keyrings
 22960	[    1.731631] Key type blacklist registered
 22961	[    1.731751] workingset: timestamp_bits=44 max_order=20 bucket_order=0
 22962	[    1.734903] zbud: loaded
 22963	[    1.735828] squashfs: version 4.0 (2009/01/31) Phillip Lougher
 22964	[    1.736331] fuse: init (API version 7.32)
 22965	[    1.737082] integrity: Platform Keyring initialized
 22966	[    1.764845] xor: measuring software checksum speed
 22967	[    1.767681]    8regs           :  3476 MB/sec
 22968	[    1.770138]    32regs          :  4023 MB/sec
 22969	[    1.772797]    arm64_neon      :  3712 MB/sec
 22970	[    1.772801] xor: using function: 32regs (4023 MB/sec)
 22971	[    1.772807] Key type asymmetric registered
 22972	[    1.772811] Asymmetric key parser 'x509' registered
 22973	[    1.772844] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
 22974	[    1.772980] io scheduler mq-deadline registered
 22975	[    1.772983] io scheduler kyber registered
 22976	[    1.773061] io scheduler bfq registered
 22977	[    1.775577] gpio-447 (usb-hub-reset): hogged as output/high
 22978	[    1.778596] EINJ: ACPI disabled.
 22979	[    1.784799] soc soc0: Amlogic Meson G12B (S922X) Revision 29:a (40:2) Detected
 22980	[    1.786208] VCC_3V3: supplied by VDDAO_3V3
 22981	[    1.786244] FLASH_1V8: supplied by VCC_3V3
 22982	[    1.786292] VCC_1V8: supplied by VCC_3V3
 22983	[    1.786319] VDDAO_1V8: supplied by VDDAO_3V3
 22984	[    1.786349] VDDCPU_A: supplied by regulator-dummy
 22985	[    1.786703] VDDCPU_B: supplied by regulator-dummy
 22986	[    1.787393] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
 22987	[    1.789639] Serial: AMBA driver
 22988	[    1.789930] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 25, base_baud = 1500000) is a meson_uart
 22989	[    1.790021] printk: console [ttyAML0] enabled
 22990	[    1.790502] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 33, base_baud = 1500000) is a meson_uart
 22991	[    1.795630] loop: module loaded
 22992	[    1.797624] libphy: Fixed MDIO Bus: probed
 22993	[    1.798736] tun: Universal TUN/TAP device driver, 1.6
 22994	[    1.799389] thunder_xcv, ver 1.0
 22995	[    1.799417] thunder_bgx, ver 1.0
 22996	[    1.799447] nicpf, ver 1.0
 22997	[    1.799976] e1000e: Intel(R) PRO/1000 Network Driver
 22998	[    1.799981] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
 22999	[    1.800025] igb: Intel(R) Gigabit Ethernet Network Driver
 23000	[    1.800028] igb: Copyright (c) 2007-2014 Intel Corporation.
 23001	[    1.800065] igbvf: Intel(R) Gigabit Virtual Function Network Driver
 23002	[    1.800068] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
 23003	[    1.800196] sky2: driver version 1.30
 23004	[    1.800556] VFIO - User Level meta-driver version: 0.3
 23005	[    1.801941] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
 23006	[    1.801958] ehci-pci: EHCI PCI platform driver
 23007	[    1.801987] ehci-platform: EHCI generic platform driver
 23008	[    1.802120] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
 23009	[    1.802130] ohci-pci: OHCI PCI platform driver
 23010	[    1.802158] ohci-platform: OHCI generic platform driver
 23011	[    1.802571] usbcore: registered new interface driver usb-storage
 23012	[    1.803864] mousedev: PS/2 mouse device common for all mice
 23013	[    1.804239] i2c /dev entries driver
 23014	[    1.809488] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17
 23015	[    1.810146] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz
 23016	[    1.810830] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-1 failed:-17
 23017	[    1.811427] sdhci: Secure Digital Host Controller Interface driver
 23018	[    1.811432] sdhci: Copyright(c) Pierre Ossman
 23019	[    1.811553] Synopsys Designware Multimedia Card Interface Driver
 23020	[    1.812067] sdhci-pltfm: SDHCI platform and OF driver helper
 23021	[    1.813011] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq
 23022	[    1.813436] ledtrig-cpu: registered to indicate activity on CPUs
 23023	[    1.813700] meson-sm: secure-monitor enabled
 23024	[    1.813831] hid: raw HID events driver (C) Jiri Kosina
 23025	[    1.813891] usbcore: registered new interface driver usbhid
 23026	[    1.813892] usbhid: USB HID core driver
 23027	[    1.814694] NET: Registered protocol family 10
 23028	[    1.815227] Segment Routing with IPv6
 23029	[    1.815286] NET: Registered protocol family 17
 23030	[    1.815779] 8021q: 802.1Q VLAN Support v1.8
 23031	[    1.815812] Key type dns_resolver registered
 23032	[    1.816126] registered taskstats version 1
 23033	[    1.816133] Loading compiled-in X.509 certificates
 23034	[    1.817866] Loaded X.509 cert 'Build time autogenerated kernel key: 98b5fbd0004968eadd44123544af94c22f57c8e4'
 23035	[    1.819491] zswap: loaded using pool zstd/z3fold
 23036	[    1.819678] Key type ._fscrypt registered
 23037	[    1.819681] Key type .fscrypt registered
 23038	[    1.819682] Key type fscrypt-provisioning registered
 23039	[    1.821245] Btrfs loaded, crc32c=crc32c-generic
 23040	[    1.827296] Key type encrypted registered
 23041	[    1.827309] AppArmor: AppArmor sha1 policy hashing enabled
 23042	[    1.833612] HUB_5V: supplied by 5V
 23043	[    1.833814] USB_PWR_EN: supplied by 5V
 23044	[    1.835442] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2
 23045	[    1.835450] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1
 23046	[    1.838127] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator
 23047	[    1.838174] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator
 23048	[    1.838285] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM
 23049	[    1.838878] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
 23050	[    1.838888] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
 23051	[    1.838972] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010
 23052	[    1.838994] xhci-hcd xhci-hcd.0.auto: irq 41, io mem 0xff500000
 23053	[    1.839121] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
 23054	[    1.839124] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 23055	[    1.839126] usb usb1: Product: xHCI Host Controller
 23056	[    1.839129] usb usb1: Manufacturer: Linux 5.10.27-meson64 xhci-hcd
 23057	[    1.839131] usb usb1: SerialNumber: xhci-hcd.0.auto
 23058	[    1.839317] hub 1-0:1.0: USB hub found
 23059	[    1.839331] hub 1-0:1.0: 2 ports detected
 23060	[    1.839462] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
 23061	[    1.839467] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
 23062	[    1.839473] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
 23063	[    1.839500] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
 23064	[    1.839532] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
 23065	[    1.839535] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 23066	[    1.839537] usb usb2: Product: xHCI Host Controller
 23067	[    1.839539] usb usb2: Manufacturer: Linux 5.10.27-meson64 xhci-hcd
 23068	[    1.839541] usb usb2: SerialNumber: xhci-hcd.0.auto
 23069	[    1.839689] hub 2-0:1.0: USB hub found
 23070	[    1.839719] hub 2-0:1.0: 1 port detected
 23071	[    1.841580] meson-gx-mmc ffe05000.sd: Got CD GPIO
 23072	[    1.868799] Freeing unused kernel memory: 3328K
 23073	[    1.907765] Run /init as init process
 23074	[    1.907770]   with arguments:
 23075	[    1.907772]     /init
 23076	[    1.907774]   with environment:
 23077	[    1.907775]     HOME=/
 23078	[    1.907777]     TERM=linux
 23079	[    1.907778]     hdmimode=custombuilt
 23080	[    1.907780]     cvbsmode=576cvbs
 23081	[    1.907781]     max_freq_a53=1896
 23082	[    1.907783]     max_freq_a73=1800
 23083	[    1.907784]     voutmode=hdmi
 23084	[    1.907786]     modeline=1920,1080,148500,56250,50,1920,2448,2492,2640,1080,1084,1089,1125,1,1,1
 23085	[    1.907787]     disablehpd=false
 23086	[    1.907789]     cvbscable=
 23087	[    1.907790]     overscan=100
 23088	[    1.935152] mmc1: new ultra high speed SDR25 SDHC card at address b368
 23089	[    1.936111] mmcblk1: mmc1:b368 CBADS 30.0 GiB
 23090	[    1.938002]  mmcblk1: p1
 23091	[    2.063464] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found
 23092	[    2.063476] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found
 23093	[    2.063606] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock
 23094	[    2.063612] meson8b-dwmac ff3f0000.ethernet: no reset control found
 23095	[    2.066420] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37
 23096	[    2.066434] meson8b-dwmac ff3f0000.ethernet: 	DWMAC1000
 23097	[    2.066438] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported
 23098	[    2.066442] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported
 23099	[    2.066444] meson8b-dwmac ff3f0000.ethernet: COE Type 2
 23100	[    2.066446] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported
 23101	[    2.066448] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported
 23102	[    2.066515] meson8b-dwmac ff3f0000.ethernet: Normal descriptors
 23103	[    2.066518] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled
 23104	[    2.066521] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
 23105	[    2.066742] libphy: stmmac: probed
 23106	[    2.067851] libphy: mdio_mux: probed
 23107	[    2.080393] meson-vrtc ff8000a8.rtc: registered as rtc1
 23108	[    2.088563] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
 23109	[    2.089148] rtc-pcf8563 1-0051: registered as rtc0
 23110	[    2.091055] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
 23111	[    2.091066] rtc-pcf8563 1-0051: hctosys: unable to read the hardware clock
 23112	[    2.097752] random: fast init done
 23113	[    2.175743] usb 1-1: new high-speed USB device number 2 using xhci-hcd
 23114	[    2.276124] libphy: mdio_mux: probed
 23115	[    2.326074] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.04
 23116	[    2.326082] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
 23117	[    2.326086] usb 1-1: Product: USB2.1 Hub
 23118	[    2.326089] usb 1-1: Manufacturer: GenesysLogic
 23119	[    2.383790] hub 1-1:1.0: USB hub found
 23120	[    2.384027] hub 1-1:1.0: 4 ports detected
 23121	[    2.451822] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
 23122	[    2.474313] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.04
 23123	[    2.474317] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
 23124	[    2.474319] usb 2-1: Product: USB3.1 Hub
 23125	[    2.474322] usb 2-1: Manufacturer: GenesysLogic
 23126	[    2.495679] hub 2-1:1.0: USB hub found
 23127	[    2.495961] hub 2-1:1.0: 4 ports detected
 23128	[    2.599716] usb 1-2: new high-speed USB device number 3 using xhci-hcd
 23129	[    2.748150] usb 1-2: New USB device found, idVendor=2013, idProduct=025f, bcdDevice= 1.00
 23130	[    2.748155] usb 1-2: New USB device strings: Mfr=3, Product=1, SerialNumber=2
 23131	[    2.748158] usb 1-2: Product: PCTV 292e
 23132	[    2.748161] usb 1-2: Manufacturer: PCTV
 23133	[    2.748164] usb 1-2: SerialNumber: 0011356964
 23134	[    3.049189] EXT4-fs (mmcblk1p1): mounted filesystem with writeback data mode. Opts: (null)
 23135	[    3.865542] systemd[1]: System time before build time, advancing clock.
 23136	[    3.880447] systemd[1]: Inserted module 'autofs4'
 23137	[    3.927490] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
 23138	[    3.927720] systemd[1]: Detected architecture arm64.
 23139	[    3.961598] systemd[1]: Set hostname to <odroidn2>.
 23140	[    4.288457] random: systemd: uninitialized urandom read (16 bytes read)
 23141	[    4.291730] random: systemd: uninitialized urandom read (16 bytes read)
 23142	[    4.293000] systemd[1]: Created slice system-serial\x2dgetty.slice.
 23143	[    4.293219] random: systemd: uninitialized urandom read (16 bytes read)
 23144	[    4.293237] systemd[1]: Reached target Swap.
 23145	[    4.293544] systemd[1]: Listening on Journal Socket (/dev/log).
 23146	[    4.293691] systemd[1]: Listening on initctl Compatibility Named Pipe.
 23147	[    4.293878] systemd[1]: Listening on fsck to fsckd communication Socket.
 23148	[    4.294166] systemd[1]: Listening on Journal Audit Socket.
 23149	[    4.294377] systemd[1]: Listening on udev Control Socket.
 23150	[    4.382516] EXT4-fs (mmcblk1p1): re-mounted. Opts: commit=600,errors=remount-ro
 23151	[    4.933380] pwm-gpio pwmgpio: 1 gpio pwms loaded
 23152	[    4.936566] zram: Added device: zram0
 23153	[    4.937926] zram: Added device: zram1
 23154	[    4.938375] zram: Added device: zram2
 23155	[    5.074726] mc: Linux media interface: v0.10
 23156	[    5.095734] Registered IR keymap rc-odroid
 23157	[    5.125865] meson-saradc ff809000.adc: supply vref not found, using dummy regulator
 23158	[    5.136200] IR NEC protocol handler initialized
 23159	[    5.136462] videodev: Linux video capture interface: v2.00
 23160	[    5.164244] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0
 23161	[    5.165000] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
 23162	[    5.165122] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input0
 23163	[    5.165408] meson-ir ff808000.ir: receiver initialized
 23164	[    5.222651] meson-drm ff900000.vpu: Queued 2 outputs on vpu
 23165	[    5.277310] meson-drm ff900000.vpu: CVBS Output connector not available
 23166	[    5.297513] panfrost ffe40000.gpu: clock rate = 24000000
 23167	[    5.297574] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19
 23168	[    5.303779] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
 23169	[    5.304786] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0
 23170	[    5.304795] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400
 23171	[    5.304799] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
 23172	[    5.304802] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1
 23173	[    5.305097] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
 23174	[    5.305393] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
 23175	[    5.305662] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 0
 23176	[    5.319530] zram0: detected capacity change from 0 to 1938251776
 23177	[    5.321834] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 1
 23178	[    5.347986] em28xx 1-2:1.0: New device PCTV PCTV 292e @ 480 Mbps (2013:025f, interface 0, class 0)
 23179	[    5.347993] em28xx 1-2:1.0: DVB interface 0 found: isoc
 23180	[    5.358231] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
 23181	[    5.407785] em28xx 1-2:1.0: chip ID is em28178
 23182	[    5.587869] Console: switching to colour frame buffer device 240x67
 23183	[    5.614383] meson-drm ff900000.vpu: [drm] fb0: mesondrmfb frame buffer device
 23184	[    5.651965] axg-sound-card sound: ASoC: no DMI vendor name!
 23185	[    6.379732] Adding 1892820k swap on /dev/zram0.  Priority:5 extents:1 across:1892820k SSFS
 23186	[    6.442841] zram1: detected capacity change from 0 to 52428800
 23187	[    7.430031] em28xx 1-2:1.0: EEPROM ID = 26 00 01 00, EEPROM hash = 0x8d0cfd04
 23188	[    7.430037] em28xx 1-2:1.0: EEPROM info:
 23189	[    7.430041] em28xx 1-2:1.0: 	microcode start address = 0x0004, boot configuration = 0x01
 23190	[    7.436143] em28xx 1-2:1.0: 	AC97 audio (5 sample rates)
 23191	[    7.436147] em28xx 1-2:1.0: 	500mA max power
 23192	[    7.436151] em28xx 1-2:1.0: 	Table at offset 0x27, strings=0x146a, 0x1888, 0x0a7e
 23193	[    7.495717] em28xx 1-2:1.0: Identified as PCTV tripleStick (292e) (card=94)
 23194	[    7.495723] em28xx 1-2:1.0: dvb set to isoc mode.
 23195	[    7.495951] usbcore: registered new interface driver em28xx
 23196	[    7.522719] em28xx 1-2:1.0: Binding DVB extension
 23197	[    7.536446] i2c i2c-4: Added multiplexed i2c bus 5
 23198	[    7.536454] si2168 4-0064: Silicon Labs Si2168-B40 successfully identified
 23199	[    7.536457] si2168 4-0064: firmware version: B 4.0.2
 23200	[    7.544900] si2157 5-0060: Silicon Labs Si2147/2148/2157/2158 successfully attached
 23201	[    7.544930] dvbdev: DVB: registering new adapter (1-2:1.0)
 23202	[    7.544936] em28xx 1-2:1.0: DVB: registering adapter 0 frontend 0 (Silicon Labs Si2168)...
 23203	[    7.544941] dvbdev: dvb_create_media_entity: media entity 'Silicon Labs Si2168' registered.
 23204	[    7.545612] dvbdev: dvb_create_media_entity: media entity 'dvb-demux' registered.
 23205	[    7.546973] em28xx 1-2:1.0: DVB extension successfully initialized
 23206	[    7.546982] em28xx: Registered (Em28xx dvb Extension) extension
 23207	[    7.554221] em28xx 1-2:1.0: Registering input extension
 23208	[    7.587736] Registered IR keymap rc-pinnacle-pctv-hd
 23209	[    7.587928] rc rc1: PCTV tripleStick (292e) as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-2/1-2:1.0/rc/rc1
 23210	[    7.587997] rc rc1: lirc_dev: driver em28xx registered at minor = 1, scancode receiver, no transmitter
 23211	[    7.588058] input: PCTV tripleStick (292e) as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-2/1-2:1.0/rc/rc1/input1
 23212	[    7.588175] em28xx 1-2:1.0: Input extension successfully initialized
 23213	[    7.588183] em28xx: Registered (Em28xx Input Extension) extension
 23214	[    8.528069] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
 23215	[    8.528096] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
 23216	[    9.820462] systemd[1]: Started Armbian memory supported logging.
 23217	[    9.824606] systemd[1]: Starting Journal Service...
 23218	[    9.887423] systemd[1]: Started Journal Service.
 23219	[    9.908864] systemd-journald[1849]: Received request to flush runtime journal from PID 1
 23220
 23221	### armbian-release:
 23222
 23223	# PLEASE DO NOT EDIT THIS FILE
 23224	BOARD=odroidn2
 23225	BOARD_NAME="Odroid N2"
 23226	BOARDFAMILY=meson-g12b
 23227	BUILD_REPOSITORY_URL=git@github.com:armbian/build.git
 23228	BUILD_REPOSITORY_COMMIT=23e571cb4-dirty
 23229	DISTRIBUTION_CODENAME=buster
 23230	DISTRIBUTION_STATUS=supported
 23231	VERSION=21.02.4
 23232	LINUXFAMILY=meson64
 23233	BRANCH=current
 23234	ARCH=arm64
 23235	IMAGE_TYPE=stable
 23236	BOARD_TYPE=conf
 23237	INITRD_ARCH=arm64
 23238	KERNEL_IMAGE_TYPE=Image
 23239
 23240	### boot environment:
 23241
 23242	verbosity=1
 23243	console=both
 23244	overlay_prefix=meson
 23245	rootdev=UUID=bd34953d-41be-49d6-b1c0-c0c28a5e239c
 23246	rootfstype=ext4
 23247	usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
 23248
 23249	### lsusb:
 23250
 23251	Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc.
 23252	Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
 23253	Bus 001 Device 003: ID 2013:025f PCTV Systems
 23254	Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
 23255	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
 23256
 23257	### lscpu:
 23258
 23259	Architecture:        aarch64
 23260	Byte Order:          Little Endian
 23261	CPU(s):              6
 23262	On-line CPU(s) list: 0-5
 23263	Thread(s) per core:  1
 23264	Core(s) per socket:  3
 23265	Socket(s):           2
 23266	NUMA node(s):        1
 23267	Vendor ID:           ARM
 23268	Model:               4
 23269	Model name:          Cortex-A53
 23270	Stepping:            r0p4
 23271	CPU max MHz:         1992.0000
 23272	CPU min MHz:         100.0000
 23273	BogoMIPS:            48.00
 23274	L1d cache:           unknown size
 23275	L1i cache:           unknown size
 23276	L2 cache:            unknown size
 23277	NUMA node0 CPU(s):   0-5
 23278	Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 23279
 23280	### cpuinfo:
 23281
 23282	processor	: 0
 23283	BogoMIPS	: 48.00
 23284	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 23285	CPU implementer	: 0x41
 23286	CPU architecture: 8
 23287	CPU variant	: 0x0
 23288	CPU part	: 0xd03
 23289	CPU revision	: 4
 23290
 23291	processor	: 1
 23292	BogoMIPS	: 48.00
 23293	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 23294	CPU implementer	: 0x41
 23295	CPU architecture: 8
 23296	CPU variant	: 0x0
 23297	CPU part	: 0xd03
 23298	CPU revision	: 4
 23299
 23300	processor	: 2
 23301	BogoMIPS	: 48.00
 23302	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 23303	CPU implementer	: 0x41
 23304	CPU architecture: 8
 23305	CPU variant	: 0x0
 23306	CPU part	: 0xd09
 23307	CPU revision	: 2
 23308
 23309	processor	: 3
 23310	BogoMIPS	: 48.00
 23311	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 23312	CPU implementer	: 0x41
 23313	CPU architecture: 8
 23314	CPU variant	: 0x0
 23315	CPU part	: 0xd09
 23316	CPU revision	: 2
 23317
 23318	processor	: 4
 23319	BogoMIPS	: 48.00
 23320	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 23321	CPU implementer	: 0x41
 23322	CPU architecture: 8
 23323	CPU variant	: 0x0
 23324	CPU part	: 0xd09
 23325	CPU revision	: 2
 23326
 23327	processor	: 5
 23328	BogoMIPS	: 48.00
 23329	Features	: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
 23330	CPU implementer	: 0x41
 23331	CPU architecture: 8
 23332	CPU variant	: 0x0
 23333	CPU part	: 0xd09
 23334	CPU revision	: 2
 23335
 23336
 23337	### meminfo:
 23338
 23339	MemTotal:        3785648 kB
 23340	MemFree:         3449092 kB
 23341	MemAvailable:    3449892 kB
 23342	Buffers:           11688 kB
 23343	Cached:            49440 kB
 23344	SwapCached:            0 kB
 23345	Active:            29116 kB
 23346	Inactive:         196176 kB
 23347	Active(anon):        140 kB
 23348	Inactive(anon):   169376 kB
 23349	Active(file):      28976 kB
 23350	Inactive(file):    26800 kB
 23351	Unevictable:           0 kB
 23352	Mlocked:               0 kB
 23353	SwapTotal:       1892820 kB
 23354	SwapFree:        1892820 kB
 23355	Dirty:              9364 kB
 23356	Writeback:             0 kB
 23357	AnonPages:        164640 kB
 23358	Mapped:            13260 kB
 23359	Shmem:              5060 kB
 23360	KReclaimable:      13404 kB
 23361	Slab:              40884 kB
 23362	SReclaimable:      13404 kB
 23363	SUnreclaim:        27480 kB
 23364	KernelStack:        2592 kB
 23365	PageTables:         5964 kB
 23366	NFS_Unstable:          0 kB
 23367	Bounce:                0 kB
 23368	WritebackTmp:          0 kB
 23369	CommitLimit:     3785644 kB
 23370	Committed_AS:    4239916 kB
 23371	VmallocTotal:   135290159040 kB
 23372	VmallocUsed:       33372 kB
 23373	VmallocChunk:          0 kB
 23374	Percpu:             1368 kB
 23375	HardwareCorrupted:     0 kB
 23376	AnonHugePages:         0 kB
 23377	ShmemHugePages:        0 kB
 23378	ShmemPmdMapped:        0 kB
 23379	FileHugePages:         0 kB
 23380	FilePmdMapped:         0 kB
 23381	CmaTotal:         917504 kB
 23382	CmaFree:          901212 kB
 23383	HugePages_Total:       0
 23384	HugePages_Free:        0
 23385	HugePages_Rsvd:        0
 23386	HugePages_Surp:        0
 23387	Hugepagesize:       2048 kB
 23388	Hugetlb:               0 kB
 23389
 23390	### virtual memory:
 23391
 23392	vm.admin_reserve_kbytes = 8192
 23393	vm.block_dump = 0
 23394	vm.compaction_proactiveness = 20
 23395	vm.compact_unevictable_allowed = 1
 23396	vm.dirty_background_bytes = 0
 23397	vm.dirty_background_ratio = 10
 23398	vm.dirty_bytes = 0
 23399	vm.dirty_expire_centisecs = 3000
 23400	vm.dirty_ratio = 20
 23401	vm.dirtytime_expire_seconds = 43200
 23402	vm.dirty_writeback_centisecs = 500
 23403	vm.extfrag_threshold = 500
 23404	vm.hugetlb_shm_group = 0
 23405	vm.laptop_mode = 0
 23406	vm.legacy_va_layout = 0
 23407	vm.lowmem_reserve_ratio = 256	256	32	0
 23408	vm.max_map_count = 65530
 23409	vm.memory_failure_early_kill = 0
 23410	vm.memory_failure_recovery = 1
 23411	vm.min_free_kbytes = 22528
 23412	vm.min_slab_ratio = 5
 23413	vm.min_unmapped_ratio = 1
 23414	vm.mmap_min_addr = 4096
 23415	vm.mmap_rnd_bits = 18
 23416	vm.mmap_rnd_compat_bits = 11
 23417	vm.nr_hugepages = 0
 23418	vm.nr_hugepages_mempolicy = 0
 23419	vm.nr_overcommit_hugepages = 0
 23420	vm.numa_stat = 1
 23421	vm.numa_zonelist_order = Node
 23422	vm.oom_dump_tasks = 1
 23423	vm.oom_kill_allocating_task = 0
 23424	vm.overcommit_kbytes = 0
 23425	vm.overcommit_memory = 0
 23426	vm.overcommit_ratio = 50
 23427	vm.page-cluster = 0
 23428	vm.page_lock_unfairness = 5
 23429	vm.panic_on_oom = 0
 23430	vm.percpu_pagelist_fraction = 0
 23431	vm.stat_interval = 1
 23432	vm.swappiness = 100
 23433	vm.user_reserve_kbytes = 117055
 23434	vm.vfs_cache_pressure = 100
 23435	vm.watermark_boost_factor = 15000
 23436	vm.watermark_scale_factor = 10
 23437	vm.zone_reclaim_mode = 0
 23438
 23439	### ip addr:
 23440
 23441	1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
 23442	    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
 23443	    inet XXX.XXX.0.1/8 scope host lo
 23444	       valid_lft forever preferred_lft forever
 23445	    inet6 ::1/128 scope host
 23446	       valid_lft forever preferred_lft forever
 23447	2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
 23448	    link/ether 00:1e:06:42:03:f8 brd ff:ff:ff:ff:ff:ff
 23449
 23450	### partitions:
 23451
 23452	major minor  #blocks  name
 23453
 23454	 179        0   31464960 mmcblk1
 23455	 179        1   31146208 mmcblk1p1
 23456	 252        0    1892824 zram0
 23457	 252        1      51200 zram1
 23458
 23459	### df:
 23460
 23461	udev            1.4G     0  1.4G   0% /dev
 23462	tmpfs           370M  5.0M  365M   2% /run
 23463	/dev/mmcblk1p1   30G  1.8G   28G   7% /
 23464	tmpfs           1.9G     0  1.9G   0% /dev/shm
 23465	tmpfs           5.0M  4.0K  5.0M   1% /run/lock
 23466	tmpfs           1.9G     0  1.9G   0% /sys/fs/cgroup
 23467	tmpfs           1.9G     0  1.9G   0% /tmp
 23468	/dev/zram1       49M  9.2M   36M  21% /var/log
 23469
 23470	### lsblk:
 23471
 23472	NAME        FSTYPE  SIZE MOUNTPOINT UUID
 23473	mmcblk1              30G
 23474	└─mmcblk1p1 ext4   29.7G /          bd34953d-41be-49d6-b1c0-c0c28a5e239c
 23475	zram1                50M /var/log
 23476
 23477	### zramctl:
 23478
 23479	NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
 23480	/dev/zram1 zstd           50M  132K  695B   36K       6 /var/log
 23481	/dev/zram0 lzo-rle       1.8G    4K   74B   12K       6 [SWAP]
 23482
 23483	### mtab:
 23484
 23485	/dev/mmcblk1p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
 23486	/dev/mmcblk1p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
 23487	/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
 23488
 23489	### mmc1:b368 info:
 23490
 23491	               fwrev: 0x0
 23492	              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=CBADS MODALIAS=mmc:block
 23493	                 cid: 6f0303434241445310aa002b4d013b00
 23494	                 rca: 0xb368
 23495	                 csd: 400e005a5b590000f00e7f800a404000
 23496	              manfid: 0x00006f
 23497	                 ocr: 0x00200000
 23498	preferred_erase_size: 2097152
 23499	                type: SD
 23500	               hwrev: 0x1
 23501	                date: 11/2019
 23502	                 dsr: 0x404
 23503	          erase_size: 512
 23504	               oemid: 0x0303
 23505	              serial: 0xaa002b4d
 23506	                 ssr: 00000000000000280402800100fd180a001e00000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
 23507	                 scr: 02b5800300000000
 23508	                name: CBADS
 23509
 23510	### Boot system health:
 23511
 23512	Time       big.LITTLE   load %cpu %sys %usr %nice %io %irq   CPU  C.St.
 23513	14:58:16: 1908/1992MHz  3.30  23%  10%   5%   0%   6%   0% 33.6°C  0/11
 23514	14:58:16: 1908/1992MHz  3.30  74%  41%   8%   0%  22%   1% 33.3°C  0/11
 23515	14:58:17: 1908/1992MHz  3.30  78%  31%   3%   0%  39%   2% 30.9°C  0/11
 23516	14:58:17: 1908/1000MHz  3.30  64%  12%   6%   0%  42%   1% 30.9°C  0/11
 23517	14:58:17: 1908/1992MHz  3.30  45%   4%   0%   0%  37%   1% 30.1°C  0/11
 23518
 23519	### lsusb:
 23520
 23521	Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc.
 23522	Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
 23523	Bus 001 Device 003: ID 2013:025f PCTV Systems
 23524	Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
 23525	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
 23526
 23527	/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
 23528	    |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 5000M
 23529	/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/2p, 480M
 23530	    |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
 23531	    |__ Port 2: Dev 3, If 0, Class=Vendor Specific Class, Driver=em28xx, 480M
 23532
 23533	### lspci:
 23534
 23535
 23536	### Installed packages:
 23537
 23538	iU  armbian-config                     21.02.4                              all          Armbian configuration utility
 23539	ii  armbian-firmware                   21.02.4                              all          Linux firmware
 23540	ii  armbian-zsh                        21.02.4                              all          Armbian improved ZShell
 23541	ii  hostapd                            3:2.9-102~armbian20.05.2+1           arm64        IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator
 23542	ii  htop                               3.1.0-0~armbian20.08.2+1             arm64        interactive processes viewer
 23543	ii  linux-base                         4.6                                  all          Linux image base package
 23544	ii  linux-buster-root-current-odroidn2 21.02.4                              arm64        Armbian tweaks for buster on odroidn2 (current branch)
 23545	ii  linux-dtb-current-meson64          21.02.4                              arm64        Linux DTB, version 5.10.27-meson64
 23546	ii  linux-image-current-meson64        21.02.4                              arm64        Linux kernel, version 5.10.27-meson64
 23547	ii  linux-libc-dev:arm64               4.19.181-1                           arm64        Linux support headers for userspace development
 23548	ii  linux-u-boot-odroidn2-current      21.02.4                              arm64        Uboot loader 2015.01
 23549
 23550	### Loaded modules:
 23551
 23552	Module                  Size  Used by
 23553	rfkill                 36864  1
 23554	cpufreq_powersave      20480  0
 23555	cpufreq_conservative    16384  0
 23556	rc_pinnacle_pctv_hd    16384  0
 23557	em28xx_rc              24576  0
 23558	si2157                 24576  1
 23559	si2168                 24576  1
 23560	i2c_mux                16384  1 si2168
 23561	em28xx_dvb             40960  1
 23562	dvb_core              147456  1 em28xx_dvb
 23563	videobuf2_vmalloc      20480  1 dvb_core
 23564	snd_soc_hdmi_codec     20480  1
 23565	dw_hdmi_i2s_audio      16384  0
 23566	meson_vdec             73728  0
 23567	em28xx                 98304  2 em28xx_rc,em28xx_dvb
 23568	v4l2_mem2mem           40960  1 meson_vdec
 23569	tveeprom               28672  1 em28xx
 23570	videobuf2_dma_contig    24576  1 meson_vdec
 23571	panfrost               65536  0
 23572	snd_soc_meson_axg_sound_card    16384  0
 23573	meson_dw_hdmi          24576  0
 23574	videobuf2_memops       20480  2 videobuf2_vmalloc,videobuf2_dma_contig
 23575	snd_soc_meson_axg_toddr    28672  3
 23576	snd_soc_meson_g12a_tohdmitx    20480  1
 23577	snd_soc_meson_axg_tdm_interface    16384  3 snd_soc_meson_axg_sound_card
 23578	snd_soc_meson_axg_frddr    36864  3
 23579	snd_soc_meson_axg_tdmin    24576  4
 23580	snd_soc_meson_axg_tdmout    24576  2
 23581	snd_soc_simple_amplifier    16384  1
 23582	videobuf2_v4l2         32768  2 meson_vdec,v4l2_mem2mem
 23583	snd_soc_meson_t9015    24576  1
 23584	snd_soc_meson_g12a_toacodec    16384  1
 23585	snd_soc_meson_card_utils    16384  2 snd_soc_meson_axg_sound_card
 23586	gpu_sched              32768  1 panfrost
 23587	dw_hdmi                53248  2 meson_dw_hdmi,dw_hdmi_i2s_audio
 23588	meson_drm              61440  1 meson_dw_hdmi
 23589	snd_soc_meson_axg_fifo    20480  2 snd_soc_meson_axg_toddr,snd_soc_meson_axg_frddr
 23590	snd_soc_meson_codec_glue    16384  2 snd_soc_meson_g12a_toacodec,snd_soc_meson_g12a_tohdmitx
 23591	snd_soc_meson_axg_tdm_formatter    16384  3 snd_soc_meson_axg_tdmin,snd_soc_meson_axg_tdm_interface,snd_soc_meson_axg_tdmout
 23592	videobuf2_common       57344  4 meson_vdec,videobuf2_v4l2,dvb_core,v4l2_mem2mem
 23593	snd_soc_core          221184  15 snd_soc_meson_axg_tdm_formatter,snd_soc_meson_t9015,snd_soc_meson_g12a_toacodec,snd_soc_meson_axg_sound_card,snd_soc_hdmi_codec,snd_soc_meson_g12a_tohdmitx,snd_soc_meson_axg_tdmin,snd_soc_simple_amplifier,snd_soc_meson_axg_tdm_interface,snd_soc_meson_axg_fifo,snd_soc_meson_axg_tdmout,snd_soc_meson_axg_toddr,snd_soc_meson_axg_frddr,snd_soc_meson_card_utils,snd_soc_meson_codec_glue
 23594	drm_kms_helper        245760  5 meson_dw_hdmi,meson_drm,dw_hdmi
 23595	ir_nec_decoder         20480  0
 23596	videodev              278528  5 meson_vdec,videobuf2_v4l2,videobuf2_common,em28xx,v4l2_mem2mem
 23597	ac97_bus               16384  1 snd_soc_core
 23598	meson_saradc           24576  0
 23599	snd_pcm_dmaengine      20480  1 snd_soc_core
 23600	cec                    73728  2 drm_kms_helper,dw_hdmi
 23601	snd_pcm               122880  7 snd_soc_hdmi_codec,snd_soc_meson_axg_tdm_interface,snd_soc_core,snd_soc_meson_axg_fifo,snd_soc_meson_axg_toddr,snd_soc_meson_codec_glue,snd_pcm_dmaengine
 23602	display_connector      20480  0
 23603	mc                     61440  7 videodev,si2157,videobuf2_v4l2,dvb_core,videobuf2_common,em28xx,v4l2_mem2mem
 23604	meson_gxbb_wdt         20480  0
 23605	rc_odroid              16384  0
 23606	snd_timer              40960  1 snd_pcm
 23607	drm                   561152  8 gpu_sched,meson_dw_hdmi,meson_drm,drm_kms_helper,display_connector,dw_hdmi,panfrost
 23608	meson_ir               16384  0
 23609	snd                    90112  6 snd_soc_hdmi_codec,snd_timer,snd_soc_core,snd_pcm
 23610	rc_core                57344  7 em28xx_rc,rc_pinnacle_pctv_hd,ir_nec_decoder,meson_ir,rc_odroid
 23611	reset_meson_audio_arb    16384  6
 23612	meson_canvas           16384  2 meson_drm,meson_vdec
 23613	pwm_fan                20480  0
 23614	meson_rng              16384  0
 23615	soundcore              16384  1 snd
 23616	drm_panel_orientation_quirks    20480  1 drm
 23617	zram                   36864  2
 23618	pwm_gpio               16384  1
 23619	ip_tables              32768  0
 23620	x_tables               45056  1 ip_tables
 23621	autofs4                45056  2
 23622	meson_gxl              20480  0
 23623	rtc_pcf8563            24576  0
 23624	axg_audio              77824  49
 23625	rtc_meson_vrtc         20480  1
 23626	realtek                24576  1
 23627	sclk_div               16384  1 axg_audio
 23628	clk_phase              16384  1 axg_audio
 23629	dwmac_generic          16384  0
 23630	dwmac_meson8b          16384  0
 23631
 23632	### nand-sata-install.log:
 23633
 23634	Mon  3 May 12:10:32 BST 2021: Start nand-sata-install.
 23635
 23636
 23637
 23638
 23639
 23640	Mon  3 May 12:10:46 BST 2021: Start nand-sata-install.
 23641
 23642	### Current system health:
 23643
 23644	Time       big.LITTLE   load %cpu %sys %usr %nice %io %irq   CPU  C.St.
 23645	15:12:37:   ---      0.71   1%   0%   0%   0%   0%   0% 30.3°C  0/11
 23646	15:12:37:   ---      0.71   1%   1%   0%   0%   0%   0% 28.7°C  0/11
 23647	15:12:37:   ---      0.71   1%   1%   0%   0%   0%   0% 28.4°C  0/11
 23648	15:12:38:   ---      0.73   1%   1%   0%   0%   0%   0% 28.2°C  0/11
 23649	15:12:38:   ---      0.73   1%   1%   0%   0%   0%   0% 28.2°C  0/11
 23650	15:12:40:   ---      0.73   1%   0%   1%   0%   0%   0% 42.0°C  0/11
 23651	15:12:41:   ---      0.73 100%   0%  99%   0%   0%   0% 42.9°C  0/11
 23652	15:12:42:   ---      0.73  59%   0%  58%   0%   0%   0% 32.1°C  0/11
 23653	15:12:42:   ---      0.73   1%   1%   0%   0%   0%   0% 30.7°C  0/11
 23654	15:12:42:   ---      0.73   1%   0%   0%   0%   0%   0% 30.1°C  0/11
 23655
 23656	### resolv.conf
 23657
 23658	-rw-r--r-- 1 root root 53 May  3 14:58 /etc/resolv.conf
 23659	# Generated by NetworkManager
 23660	nameserver XXX.XXX.0.1
 23661
 23662	### Current sysinfo:
 23663
 23664	Linux 5.10.27-meson64 (odroidn2) 	03/05/21 	_aarch64_	(6 CPU)
 23665
 23666	avg-cpu:  %user   %nice %system %iowait  %steal   %idle
 23667	           1.32    0.02    0.31    0.36    0.00   97.99
 23668
 23669	Device             tps    kB_read/s    kB_wrtn/s    kB_read    kB_wrtn
 23670	mmcblk1           9.67       262.99         1.24     222465       1052
 23671	mmcblk1p1         9.43       258.05         1.24     218285       1052
 23672	zram0             0.67         2.69         0.00       2272          4
 23673	zram1             0.33         0.52        11.91        440      10076
 23674	zram2             0.00         0.00         0.00          0          0
 23675
 23676	procs -----------------------memory---------------------- ---swap-- -----io---- -system-- --------cpu--------
 23677	 r  b         swpd         free         buff        cache   si   so    bi    bo   in   cs  us  sy  id  wa  st
 23678	 0  0            0      3379448        19076       228732    0    0    44     2   64   52   1   0  98   0   0
 23679
 23680	              total        used        free      shared  buff/cache   available
 23681	Mem:          3.6Gi       154Mi       3.2Gi       5.0Mi       242Mi       3.4Gi
 23682	Swap:         1.8Gi          0B       1.8Gi
 23683
 23684	NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
 23685	/dev/zram1 zstd           50M  9.5M  2.6M    3M       6 /var/log
 23686	/dev/zram0 lzo-rle       1.8G    4K   74B   12K       6 [SWAP]
 23687
 23688	 15:12:43 up 14 min,  1 user,  load average: 0.75, 0.70, 0.53
 23689
 23690	[    1.799389] thunder_xcv, ver 1.0
 23691	[    1.799417] thunder_bgx, ver 1.0
 23692	[    1.799447] nicpf, ver 1.0
 23693	[    1.799976] e1000e: Intel(R) PRO/1000 Network Driver
 23694	[    1.799981] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
 23695	[    1.800025] igb: Intel(R) Gigabit Ethernet Network Driver
 23696	[    1.800028] igb: Copyright (c) 2007-2014 Intel Corporation.
 23697	[    1.800065] igbvf: Intel(R) Gigabit Virtual Function Network Driver
 23698	[    1.800068] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
 23699	[    1.800196] sky2: driver version 1.30
 23700	[    1.800556] VFIO - User Level meta-driver version: 0.3
 23701	[    1.801941] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
 23702	[    1.801958] ehci-pci: EHCI PCI platform driver
 23703	[    1.801987] ehci-platform: EHCI generic platform driver
 23704	[    1.802120] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
 23705	[    1.802130] ohci-pci: OHCI PCI platform driver
 23706	[    1.802158] ohci-platform: OHCI generic platform driver
 23707	[    1.802571] usbcore: registered new interface driver usb-storage
 23708	[    1.803864] mousedev: PS/2 mouse device common for all mice
 23709	[    1.804239] i2c /dev entries driver
 23710	[    1.809488] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17
 23711	[    1.810146] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz
 23712	[    1.810830] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-1 failed:-17
 23713	[    1.811427] sdhci: Secure Digital Host Controller Interface driver
 23714	[    1.811432] sdhci: Copyright(c) Pierre Ossman
 23715	[    1.811553] Synopsys Designware Multimedia Card Interface Driver
 23716	[    1.812067] sdhci-pltfm: SDHCI platform and OF driver helper
 23717	[    1.813011] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq
 23718	[    1.813436] ledtrig-cpu: registered to indicate activity on CPUs
 23719	[    1.813700] meson-sm: secure-monitor enabled
 23720	[    1.813831] hid: raw HID events driver (C) Jiri Kosina
 23721	[    1.813891] usbcore: registered new interface driver usbhid
 23722	[    1.813892] usbhid: USB HID core driver
 23723	[    1.814694] NET: Registered protocol family 10
 23724	[    1.815227] Segment Routing with IPv6
 23725	[    1.815286] NET: Registered protocol family 17
 23726	[    1.815779] 8021q: 802.1Q VLAN Support v1.8
 23727	[    1.815812] Key type dns_resolver registered
 23728	[    1.816126] registered taskstats version 1
 23729	[    1.816133] Loading compiled-in X.509 certificates
 23730	[    1.817866] Loaded X.509 cert 'Build time autogenerated kernel key: 98b5fbd0004968eadd44123544af94c22f57c8e4'
 23731	[    1.819491] zswap: loaded using pool zstd/z3fold
 23732	[    1.819678] Key type ._fscrypt registered
 23733	[    1.819681] Key type .fscrypt registered
 23734	[    1.819682] Key type fscrypt-provisioning registered
 23735	[    1.821245] Btrfs loaded, crc32c=crc32c-generic
 23736	[    1.827296] Key type encrypted registered
 23737	[    1.827309] AppArmor: AppArmor sha1 policy hashing enabled
 23738	[    1.833612] HUB_5V: supplied by 5V
 23739	[    1.833814] USB_PWR_EN: supplied by 5V
 23740	[    1.835442] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2
 23741	[    1.835450] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1
 23742	[    1.838127] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator
 23743	[    1.838174] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator
 23744	[    1.838285] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM
 23745	[    1.838878] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
 23746	[    1.838888] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
 23747	[    1.838972] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010
 23748	[    1.838994] xhci-hcd xhci-hcd.0.auto: irq 41, io mem 0xff500000
 23749	[    1.839121] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
 23750	[    1.839124] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 23751	[    1.839126] usb usb1: Product: xHCI Host Controller
 23752	[    1.839129] usb usb1: Manufacturer: Linux 5.10.27-meson64 xhci-hcd
 23753	[    1.839131] usb usb1: SerialNumber: xhci-hcd.0.auto
 23754	[    1.839317] hub 1-0:1.0: USB hub found
 23755	[    1.839331] hub 1-0:1.0: 2 ports detected
 23756	[    1.839462] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
 23757	[    1.839467] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
 23758	[    1.839473] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
 23759	[    1.839500] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
 23760	[    1.839532] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
 23761	[    1.839535] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 23762	[    1.839537] usb usb2: Product: xHCI Host Controller
 23763	[    1.839539] usb usb2: Manufacturer: Linux 5.10.27-meson64 xhci-hcd
 23764	[    1.839541] usb usb2: SerialNumber: xhci-hcd.0.auto
 23765	[    1.839689] hub 2-0:1.0: USB hub found
 23766	[    1.839719] hub 2-0:1.0: 1 port detected
 23767	[    1.841580] meson-gx-mmc ffe05000.sd: Got CD GPIO
 23768	[    1.868799] Freeing unused kernel memory: 3328K
 23769	[    1.907765] Run /init as init process
 23770	[    1.907770]   with arguments:
 23771	[    1.907772]     /init
 23772	[    1.907774]   with environment:
 23773	[    1.907775]     HOME=/
 23774	[    1.907777]     TERM=linux
 23775	[    1.907778]     hdmimode=custombuilt
 23776	[    1.907780]     cvbsmode=576cvbs
 23777	[    1.907781]     max_freq_a53=1896
 23778	[    1.907783]     max_freq_a73=1800
 23779	[    1.907784]     voutmode=hdmi
 23780	[    1.907786]     modeline=1920,1080,148500,56250,50,1920,2448,2492,2640,1080,1084,1089,1125,1,1,1
 23781	[    1.907787]     disablehpd=false
 23782	[    1.907789]     cvbscable=
 23783	[    1.907790]     overscan=100
 23784	[    1.935152] mmc1: new ultra high speed SDR25 SDHC card at address b368
 23785	[    1.936111] mmcblk1: mmc1:b368 CBADS 30.0 GiB
 23786	[    1.938002]  mmcblk1: p1
 23787	[    2.063464] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found
 23788	[    2.063476] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found
 23789	[    2.063606] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock
 23790	[    2.063612] meson8b-dwmac ff3f0000.ethernet: no reset control found
 23791	[    2.066420] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37
 23792	[    2.066434] meson8b-dwmac ff3f0000.ethernet: 	DWMAC1000
 23793	[    2.066438] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported
 23794	[    2.066442] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported
 23795	[    2.066444] meson8b-dwmac ff3f0000.ethernet: COE Type 2
 23796	[    2.066446] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported
 23797	[    2.066448] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported
 23798	[    2.066515] meson8b-dwmac ff3f0000.ethernet: Normal descriptors
 23799	[    2.066518] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled
 23800	[    2.066521] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
 23801	[    2.066742] libphy: stmmac: probed
 23802	[    2.067851] libphy: mdio_mux: probed
 23803	[    2.080393] meson-vrtc ff8000a8.rtc: registered as rtc1
 23804	[    2.088563] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
 23805	[    2.089148] rtc-pcf8563 1-0051: registered as rtc0
 23806	[    2.091055] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
 23807	[    2.091066] rtc-pcf8563 1-0051: hctosys: unable to read the hardware clock
 23808	[    2.097752] random: fast init done
 23809	[    2.175743] usb 1-1: new high-speed USB device number 2 using xhci-hcd
 23810	[    2.276124] libphy: mdio_mux: probed
 23811	[    2.326074] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.04
 23812	[    2.326082] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
 23813	[    2.326086] usb 1-1: Product: USB2.1 Hub
 23814	[    2.326089] usb 1-1: Manufacturer: GenesysLogic
 23815	[    2.383790] hub 1-1:1.0: USB hub found
 23816	[    2.384027] hub 1-1:1.0: 4 ports detected
 23817	[    2.451822] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
 23818	[    2.474313] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.04
 23819	[    2.474317] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
 23820	[    2.474319] usb 2-1: Product: USB3.1 Hub
 23821	[    2.474322] usb 2-1: Manufacturer: GenesysLogic
 23822	[    2.495679] hub 2-1:1.0: USB hub found
 23823	[    2.495961] hub 2-1:1.0: 4 ports detected
 23824	[    2.599716] usb 1-2: new high-speed USB device number 3 using xhci-hcd
 23825	[    2.748150] usb 1-2: New USB device found, idVendor=2013, idProduct=025f, bcdDevice= 1.00
 23826	[    2.748155] usb 1-2: New USB device strings: Mfr=3, Product=1, SerialNumber=2
 23827	[    2.748158] usb 1-2: Product: PCTV 292e
 23828	[    2.748161] usb 1-2: Manufacturer: PCTV
 23829	[    2.748164] usb 1-2: SerialNumber: 0011356964
 23830	[    3.049189] EXT4-fs (mmcblk1p1): mounted filesystem with writeback data mode. Opts: (null)
 23831	[    3.865542] systemd[1]: System time before build time, advancing clock.
 23832	[    3.880447] systemd[1]: Inserted module 'autofs4'
 23833	[    3.927490] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
 23834	[    3.927720] systemd[1]: Detected architecture arm64.
 23835	[    3.961598] systemd[1]: Set hostname to <odroidn2>.
 23836	[    4.288457] random: systemd: uninitialized urandom read (16 bytes read)
 23837	[    4.291730] random: systemd: uninitialized urandom read (16 bytes read)
 23838	[    4.293000] systemd[1]: Created slice system-serial-getty.slice.
 23839	[    4.293219] random: systemd: uninitialized urandom read (16 bytes read)
 23840	[    4.293237] systemd[1]: Reached target Swap.
 23841	[    4.293544] systemd[1]: Listening on Journal Socket (/dev/log).
 23842	[    4.293691] systemd[1]: Listening on initctl Compatibility Named Pipe.
 23843	[    4.293878] systemd[1]: Listening on fsck to fsckd communication Socket.
 23844	[    4.294166] systemd[1]: Listening on Journal Audit Socket.
 23845	[    4.294377] systemd[1]: Listening on udev Control Socket.
 23846	[    4.382516] EXT4-fs (mmcblk1p1): re-mounted. Opts: commit=600,errors=remount-ro
 23847	[    4.933380] pwm-gpio pwmgpio: 1 gpio pwms loaded
 23848	[    4.936566] zram: Added device: zram0
 23849	[    4.937926] zram: Added device: zram1
 23850	[    4.938375] zram: Added device: zram2
 23851	[    5.074726] mc: Linux media interface: v0.10
 23852	[    5.095734] Registered IR keymap rc-odroid
 23853	[    5.125865] meson-saradc ff809000.adc: supply vref not found, using dummy regulator
 23854	[    5.136200] IR NEC protocol handler initialized
 23855	[    5.136462] videodev: Linux video capture interface: v2.00
 23856	[    5.164244] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0
 23857	[    5.165000] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
 23858	[    5.165122] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input0
 23859	[    5.165408] meson-ir ff808000.ir: receiver initialized
 23860	[    5.222651] meson-drm ff900000.vpu: Queued 2 outputs on vpu
 23861	[    5.277310] meson-drm ff900000.vpu: CVBS Output connector not available
 23862	[    5.297513] panfrost ffe40000.gpu: clock rate = 24000000
 23863	[    5.297574] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19
 23864	[    5.303779] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
sysctl: permission denied on key 'vm.mmap_rnd_bits'
sysctl: permission denied on key 'vm.mmap_rnd_compat_bits'
sysctl: permission denied on key 'vm.stat_refresh'
 23865	[    5.304786] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0
 23866	[    5.304795] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400
 23867	[    5.304799] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
 23868	[    5.304802] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1
 23869	[    5.305097] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
 23870	[    5.305393] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
 23871	[    5.305662] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 0
 23872	[    5.319530] zram0: detected capacity change from 0 to 1938251776
 23873	[    5.321834] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 1
 23874	[    5.347986] em28xx 1-2:1.0: New device PCTV PCTV 292e @ 480 Mbps (2013:025f, interface 0, class 0)
 23875	[    5.347993] em28xx 1-2:1.0: DVB interface 0 found: isoc
 23876	[    5.358231] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
 23877	[    5.407785] em28xx 1-2:1.0: chip ID is em28178
 23878	[    5.587869] Console: switching to colour frame buffer device 240x67
 23879	[    5.614383] meson-drm ff900000.vpu: [drm] fb0: mesondrmfb frame buffer device
 23880	[    5.651965] axg-sound-card sound: ASoC: no DMI vendor name!
 23881	[    6.379732] Adding 1892820k swap on /dev/zram0.  Priority:5 extents:1 across:1892820k SSFS
 23882	[    6.442841] zram1: detected capacity change from 0 to 52428800
 23883	[    7.430031] em28xx 1-2:1.0: EEPROM ID = 26 00 01 00, EEPROM hash = 0x8d0cfd04
 23884	[    7.430037] em28xx 1-2:1.0: EEPROM info:
 23885	[    7.430041] em28xx 1-2:1.0: 	microcode start address = 0x0004, boot configuration = 0x01
 23886	[    7.436143] em28xx 1-2:1.0: 	AC97 audio (5 sample rates)
 23887	[    7.436147] em28xx 1-2:1.0: 	500mA max power
 23888	[    7.436151] em28xx 1-2:1.0: 	Table at offset 0x27, strings=0x146a, 0x1888, 0x0a7e
 23889	[    7.495717] em28xx 1-2:1.0: Identified as PCTV tripleStick (292e) (card=94)
 23890	[    7.495723] em28xx 1-2:1.0: dvb set to isoc mode.
 23891	[    7.495951] usbcore: registered new interface driver em28xx
 23892	[    7.522719] em28xx 1-2:1.0: Binding DVB extension
 23893	[    7.536446] i2c i2c-4: Added multiplexed i2c bus 5
 23894	[    7.536454] si2168 4-0064: Silicon Labs Si2168-B40 successfully identified
 23895	[    7.536457] si2168 4-0064: firmware version: B 4.0.2
 23896	[    7.544900] si2157 5-0060: Silicon Labs Si2147/2148/2157/2158 successfully attached
 23897	[    7.544930] dvbdev: DVB: registering new adapter (1-2:1.0)
 23898	[    7.544936] em28xx 1-2:1.0: DVB: registering adapter 0 frontend 0 (Silicon Labs Si2168)...
 23899	[    7.544941] dvbdev: dvb_create_media_entity: media entity 'Silicon Labs Si2168' registered.
 23900	[    7.545612] dvbdev: dvb_create_media_entity: media entity 'dvb-demux' registered.
 23901	[    7.546973] em28xx 1-2:1.0: DVB extension successfully initialized
 23902	[    7.546982] em28xx: Registered (Em28xx dvb Extension) extension
 23903	[    7.554221] em28xx 1-2:1.0: Registering input extension
 23904	[    7.587736] Registered IR keymap rc-pinnacle-pctv-hd
 23905	[    7.587928] rc rc1: PCTV tripleStick (292e) as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-2/1-2:1.0/rc/rc1
 23906	[    7.587997] rc rc1: lirc_dev: driver em28xx registered at minor = 1, scancode receiver, no transmitter
 23907	[    7.588058] input: PCTV tripleStick (292e) as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-2/1-2:1.0/rc/rc1/input1
 23908	[    7.588175] em28xx 1-2:1.0: Input extension successfully initialized
 23909	[    7.588183] em28xx: Registered (Em28xx Input Extension) extension
 23910	[    8.528069] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
 23911	[    8.528096] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
 23912	[    9.820462] systemd[1]: Started Armbian memory supported logging.
 23913	[    9.824606] systemd[1]: Starting Journal Service...
 23914	[    9.887423] systemd[1]: Started Journal Service.
 23915	[    9.908864] systemd-journald[1849]: Received request to flush runtime journal from PID 1
 23916	[   11.126642] random: crng init done
 23917	[   11.126656] random: 7 urandom warning(s) missed due to ratelimiting
 23918	[   14.442205] meson8b-dwmac ff3f0000.ethernet eth0: PHY [0.0:00] driver [RTL8211F Gigabit Ethernet] (irq=42)
 23919	[   14.455686] meson8b-dwmac ff3f0000.ethernet eth0: No Safety Features support found
 23920	[   14.455702] meson8b-dwmac ff3f0000.ethernet eth0: PTP not supported by HW
 23921	[   14.456098] meson8b-dwmac ff3f0000.ethernet eth0: configuring for phy/rgmii link mode
 23922	[   16.880151] si2168 4-0064: downloading firmware from file 'dvb-demod-si2168-b40-01.fw'
 23923	[   17.247621] em28xx 1-2:1.0: writing to i2c device at 0xc8 failed (error=-5)
 23924	[   17.247634] si2168 4-0064: firmware download failed -5
 23925	[   17.759589] em28xx 1-2:1.0: writing to i2c device at 0xc8 failed (error=-5)
 23926	[   18.214391] meson8b-dwmac ff3f0000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
 23927	[   18.214420] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
 23928	[   18.271564] em28xx 1-2:1.0: writing to i2c device at 0xc8 failed (error=-5)
 23929	[   18.783581] em28xx 1-2:1.0: writing to i2c device at 0xc8 failed (error=-5)
 23930	[   19.039539] em28xx 1-2:1.0: writing to i2c device at 0xc8 failed (error=-5)
 23931	[   19.039617] em28xx 1-2:1.0: DVB: adapter 0 frontend 0 frequency 0 out of range (48000000..870000000)
 23932	[   19.551496] em28xx 1-2:1.0: writing to i2c device at 0xc8 failed (error=-5)
 23933	[   20.063477] em28xx 1-2:1.0: writing to i2c device at 0xc8 failed (error=-5)
 23934	[   20.575435] em28xx 1-2:1.0: writing to i2c device at 0xc8 failed (error=-5)
 23935	[   21.087424] em28xx 1-2:1.0: writing to i2c device at 0xc8 failed (error=-5)
 23936	[   21.603412] em28xx 1-2:1.0: writing to i2c device at 0xc8 failed (error=-5)
 23937	[   22.143359] em28xx 1-2:1.0: writing to i2c device at 0xc8 failed (error=-5)
 23938	[   22.659370] em28xx 1-2:1.0: writing to i2c device at 0xc8 failed (error=-5)
 23939	[   23.199327] em28xx 1-2:1.0: writing to i2c device at 0xc8 failed (error=-5)
 23940
 23941
 23942	vm.admin_reserve_kbytes = 8192
 23943	vm.block_dump = 0
 23944	vm.compaction_proactiveness = 20
 23945	vm.compact_unevictable_allowed = 1
 23946	vm.dirty_background_bytes = 0
 23947	vm.dirty_background_ratio = 10
 23948	vm.dirty_bytes = 0
 23949	vm.dirty_expire_centisecs = 3000
 23950	vm.dirty_ratio = 20
 23951	vm.dirtytime_expire_seconds = 43200
 23952	vm.dirty_writeback_centisecs = 500
 23953	vm.extfrag_threshold = 500
 23954	vm.hugetlb_shm_group = 0
 23955	vm.laptop_mode = 0
 23956	vm.legacy_va_layout = 0
 23957	vm.lowmem_reserve_ratio = 256	256	32	0
 23958	vm.max_map_count = 65530
 23959	vm.memory_failure_early_kill = 0
 23960	vm.memory_failure_recovery = 1
 23961	vm.min_free_kbytes = 22528
 23962	vm.min_slab_ratio = 5
 23963	vm.min_unmapped_ratio = 1
 23964	vm.mmap_min_addr = 4096
 23965	vm.nr_hugepages = 0
 23966	vm.nr_hugepages_mempolicy = 0
 23967	vm.nr_overcommit_hugepages = 0
 23968	vm.numa_stat = 1
 23969	vm.numa_zonelist_order = Node
 23970	vm.oom_dump_tasks = 1
 23971	vm.oom_kill_allocating_task = 0
 23972	vm.overcommit_kbytes = 0
 23973	vm.overcommit_memory = 0
 23974	vm.overcommit_ratio = 50
 23975	vm.page-cluster = 0
 23976	vm.page_lock_unfairness = 5
 23977	vm.panic_on_oom = 0
 23978	vm.percpu_pagelist_fraction = 0
 23979	vm.stat_interval = 1
 23980	vm.swappiness = 100
 23981	vm.user_reserve_kbytes = 117055
 23982	vm.vfs_cache_pressure = 100
 23983	vm.watermark_boost_factor = 15000
 23984	vm.watermark_scale_factor = 10
 23985	vm.zone_reclaim_mode = 0
 23986
 23987	### interrupts:
 23988	           CPU0       CPU1       CPU2       CPU3       CPU4       CPU5
 23989	  9:          0          0          0          0          0          0     GICv2  25 Level     vgic
 23990	 11:     162364       7248      19171      12183      14242       7186     GICv2  30 Level     arch_timer
 23991	 12:          0          0          0          0          0          0     GICv2  27 Level     kvm guest vtimer
 23992	 14:        891          0          0          0          0          0     GICv2  40 Level     eth0
 23993	 15:        257          0          0          0          0          0     GICv2  89 Edge      dw_hdmi_top_irq, ff600000.hdmi-tx
 23994	 25:          1          0          0          0          0          0     GICv2 225 Edge      ttyAML0
 23995	 26:          2          0          0          0          0          0     GICv2 228 Edge      ff808000.ir
 23996	 27:          7          0          0          0          0          0     GICv2 232 Edge      ff809000.adc
 23997	 28:          0          0          0          0          0          0     GICv2  76 Edge      vdec
 23998	 29:          0          0          0          0          0          0     GICv2  64 Edge      esparserirq
 23999	 30:        518          0          0          0          0          0     GICv2  35 Edge      meson
 24000	 31:         37          0          0          0          0          0     GICv2  71 Edge      ffd1c000.i2c
 24001	 32:          0          0          0          0          0          0     GICv2 247 Edge      ffd1d000.i2c
 24002	 34:      17352          0          0          0          0          0     GICv2 222 Edge      ffe05000.sd
 24003	 35:         13          0          0          0          0          0     GICv2 223 Edge      ffe07000.mmc
 24004	 36:          0          0          0          0          0          0     GICv2  48 Level     ffe09000.usb
 24005	 37:          0          0          0          0          0          0     GICv2 194 Level     panfrost-job
 24006	 38:          0          0          0          0          0          0     GICv2 193 Level     panfrost-mmu
 24007	 39:          3          0          0          0          0          0     GICv2 192 Level     panfrost-gpu
 24008	 40:          0          0          0          0          0          0     GICv2  63 Level     ff400000.usb, ff400000.usb
 24009	 41:        224          0       4015          0          0          0     GICv2  62 Level     xhci-hcd:usb1
 24010	 42:          2          0          0          0          0          0  meson-gpio-irqchip  26 Level     0.0:00
 24011	IPI0:       785       2451       6771      15045       6499       9678       Rescheduling interrupts
 24012	IPI1:      6340      10486       4791       4706       3807       4229       Function call interrupts
 24013	IPI2:         0          0          0          0          0          0       CPU stop interrupts
 24014	IPI3:         0          0          0          0          0          0       CPU stop (for crash dump) interrupts
 24015	IPI4:         0          0          0          0          0          0       Timer broadcast interrupts
 24016	IPI5:      1932        250       1275       2424        696         44       IRQ work interrupts
 24017	IPI6:         0          0          0          0          0          0       CPU wake-up interrupts
 24018	Err:          0
Please upload the [1mwhole output[0m above to an online pasteboard service
and provide the URL in the forum where you have been asked for this.
