Canon provides source code for cups driver, but with some proprietary binary libs.
This libs available only for x86. No way for direct compiling cnijfilter for ARM (and other architectures). :(
But we have qemu! We can transparently run x86 executables on any other host architectures.
Easy steps to run cnijfilter on ARM (or any other arch):
- Build https://github.com/endlessm/cnijfilter-common for x86
- Copy all needed x86 libs using recursive ldd. And copy it to /usr/lib/bjlib/
- Patch all executables: set interpreter to /usr/lib/bjlib/x86/ld-linux.so.2 and rpath to /usr/lib/bjlib/
- Install these patched packages to ARM system
- Install qemu-user and qemu-user-binfmt (or qemu-arm-static)
You do not need to do this manually. I have implemented an automated build system: https://github.com/Azq2/cnijfilter-arm-build
All you need is any x86 machine to do the build.
How to use
1. On any x86 machine:
# Install dependencies
sudo apt install debootstrap git util-linux
# Get build system
git clone https://github.com/Azq2/cnijfilter-arm-build
# Start building
cd cnijfilter-arm-build
sudo ./build.sh build
# Get .deb packages
ls -lah ./result/full
ls -lah ./result/light
After build we have two variants of packages: full and light
Item Full Light
PPD files
CUPS filters
CUPS backends
lgmon + -
canon-maintenance
cngpij + -
cngpijmnt + -
cnijlgmon2 + -
cnijnetprn + -
cnijnpr + -
docs + -
In most cases, a light package is completely sufficient:
- We don't need canon usb backend, because cups have builtin USB support
- We don't need canon network backend, because cups have builtin BJNP support (package cups-backend-bjnp)
- Other canon maintenance utils are useless (in my opinion)
2. Copy .deb from result/light or result/full to your ARM machine.
3. On your ARM machine:
sudo apt install qemu-user qemu-user-binfmt # or sudo apt install qemu-user-static
# Install common for all printers package
sudo dpkg -i cnijfilter-common.deb
# Install printer-specific package
# Choose right package for your printer! e400series only for reference!
sudo dpkg -i cnijfilter-e400series.deb
4. Done. You can now configure CUPS.
Security with apparmor (optional)
CUPS filters don't need any specific permissions.
Create file /etc/apparmor.d/cnijfilter-filters with contents:
#include <tunables/global>
/usr/bin/bjfilter* {
	#include <abstractions/base>
	@{PROC}/sys/vm/mmap_min_addr r,
/usr/bin/cif[a-z]*[0-9d]* {
/usr/lib/cups/filter/{cmdtocanonij,pstocanonbj,pstocanonij} {
Then restart apparmor:
sudo systemctl reload apparmor
sudo aa-enforce cnijfilter-filters
Note: this minimal file full coverage all executables in light package. For full package you need write additional rules by yourself.
Great work.
Currently still running building, so i dont know if it will work.
building for a while now & ill leave it for the night 😴.
Just a suggestion, I see that my terminal is showing its building for all canon printer models. (see screenshot)
In the future it would be nice if a specific model can be chosen instead of all model, to save time.
Goodnight.
Nice, I see that your strating from the build of https://github.com/endlessm/cnijfilter-common that has not been maintained since 3 years now.
Unfortunately for me it doesn't support yet my pixma G5550.  However Canon distribute new sources for the cnijfilter (https://www.canon-europe.com/support/consumer/products/printers/pixma/g-series/pixma-g550.html?type=drivers&detailId=tcm:13-2160851&os=all&language=en&productTcmUri=tcm:13-2080172).
Any suggestion how I can adapt your build to use directly Canon sources ? (or directly 64bits binaries)
