Groove On Posted May 13, 2021 Posted May 13, 2021 (edited) If anyone needs to get the 3.5mm audio jack working on the N2+, here's one method. 1. Edit or create /etc/asound.conf with these lines. Copied directly from the Hard Kernel Ubuntu setup. pcm.!default{ type hw card 0 device 1 } ctl.!default{ type hw card 0 } 2. Run this script to turn on the 3.5mm audio in alsamixer. The settings are listed in the same order as in alsamixer. #!/bin/bash # 3.5MM JACK, set to max gain amixer sset 'ACODEC' '255' # 3.5MM JACK - set in/out channels (src/sink) amixer sset 'FRDDR_B SINK 1 SEL' 'OUT 2' || true amixer sset 'FRDDR_B SRC 1 EN' 'on' || true # 3.5MM JACK amixer sset 'TOACODEC SRC' 'I2S C' || true amixer sset 'TOACODEC OUT EN' 'on' || true amixer sset 'TOACODEC Lane Select' '0' || true # SAVE NEW SETTINGS alsactl store Edited May 13, 2021 by Groove On 1
