H1dden Posted May 18, 2021 Posted May 18, 2021 This is the uart output of the latest image Armbian_21.05.1_Nanopct4_focal_current_5.10.35.img.xz DDR Version 1.24 20191016 In Channel 0: LPDDR3, 800MHz CS = 0 MR0=0x58 MR1=0x58 MR2=0x58 MR3=0x58 MR4=0x2 MR5=0x1 MR6=0x5 MR7=0x0 MR8=0x1F MR9=0x1F MR10=0x1F MR11=0x1F MR12=0x1F MR13=0x1F MR14=0x1F MR15=0x1F MR16=0x1F CS = 1 MR0=0x58 MR1=0x58 MR2=0x58 MR3=0x58 MR4=0x3 MR5=0x1 MR6=0x5 MR7=0x0 MR8=0x1F MR9=0x1F MR10=0x1F MR11=0x1F MR12=0x1F MR13=0x1F MR14=0x1F MR15=0x1F MR16=0x1F Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=32 Size=2048MB Channel 1: LPDDR3, 800MHz CS = 0 MR0=0x58 MR1=0x58 MR2=0x58 MR3=0x58 MR4=0x2 MR5=0x1 MR6=0x5 MR7=0x0 MR8=0x1F MR9=0x1F MR10=0x1F MR11=0x1F MR12=0x1F MR13=0x1F MR14=0x1F MR15=0x1F MR16=0x1F CS = 1 MR0=0x58 MR1=0x58 MR2=0x58 MR3=0x58 MR4=0x3 MR5=0x1 MR6=0x5 MR7=0x0 MR8=0x1F MR9=0x1F MR10=0x1F MR11=0x1F MR12=0x1F MR13=0x1F MR14=0x1F MR15=0x1F MR16=0x1F Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=32 Size=2048MB 256B stride ch 0 ddrconfig = 0x101, ddrsize = 0x2020 ch 1 ddrconfig = 0x101, ddrsize = 0x2020 pmugrf_os_reg[2] = 0x3AA0DAA0, stride = 0xD OUT Boot1: 2019-03-14, version: 1.19 CPUId = 0x0 ChipType = 0x10, 245 SdmmcInit=2 0 BootCapSize=100000 UserCapSize=14910MB FwPartOffset=2000 , 100000 mmc0:cmd5,20 SdmmcInit=0 0 BootCapSize=0 UserCapSize=59238MB FwPartOffset=2000 , 0 StorageInit ok = 153908 SecureMode = 0 SecureInit read PBA: 0x4 SecureInit read PBA: 0x404 SecureInit read PBA: 0x804 SecureInit read PBA: 0xc04 SecureInit read PBA: 0x1004 SecureInit read PBA: 0x1404 SecureInit read PBA: 0x1804 SecureInit read PBA: 0x1c04 SecureInit ret = 0, SecureMode = 0 atags_set_bootdev: ret:(0) GPT 0x3380ec0 signature is wrong recovery gpt... GPT 0x3380ec0 signature is wrong recovery gpt fail! LoadTrust Addr:0x4000 No find bl30.bin No find bl32.bin Load uboot, ReadLba = 2000 Load OK, addr=0x200000, size=0xcc678 RunBL31 0x40000 NOTICE: BL31: v1.3(debug):42583b6 NOTICE: BL31: Built : 07:55:13, Oct 15 2019 NOTICE: BL31: Rockchip release version: v1.1 INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3 INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 0 INFO: plat_rockchip_pmu_init(1190): pd status 3e INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2020.10-armbian (May 06 2021 - 17:32:09 +0000) SoC: Rockchip rk3399 Reset cause: POR Model: FriendlyElec NanoPC-T4 DRAM: 3.9 GiB PMIC: RK808 MMC: mmc@fe310000: 2, mmc@fe320000: 1, sdhci@fe330000: 0 Loading Environment from MMC... *** Warning - bad CRC, using default environment In: serial Out: vidconsole Err: vidconsole Model: FriendlyElec NanoPC-T4 Net: eth0: ethernet@fe300000 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found U-Boot script /boot/boot.scr 3185 bytes read in 6 ms (517.6 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 1 117 bytes read in 6 ms (18.6 KiB/s) 15343864 bytes read in 704 ms (20.8 MiB/s) 28582400 bytes read in 1304 ms (20.9 MiB/s) 77436 bytes read in 16 ms (4.6 MiB/s) 2698 bytes read in 12 ms (218.8 KiB/s) Applying kernel provided DT fixup script (rockchip-fixup.scr) ## Executing script at 09000000 Moving Image from 0x2080000 to 0x2200000, end=3de0000 ## Loading init Ramdisk from Legacy Image at 06000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 15343800 Bytes = 14.6 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 01f00000 Booting using the fdt blob at 0x1f00000 Loading Ramdisk to f107a000, end f1f1c0b8 ... OK Loading Device Tree to 00000000f0ffe000, end 00000000f1079fff ... OK Starting kernel ... And it just stucks here... No response to any input (except reset botton) Then I tried the image Armbian_20.05.7_Nanopct4_focal_current_5.4.49.img.xz and it boots. DDR Version 1.24 20191016 In Channel 0: LPDDR3, 800MHz CS = 0 MR0=0x58 MR1=0x58 MR2=0x58 MR3=0x58 MR4=0x2 MR5=0x1 MR6=0x5 MR7=0x0 MR8=0x1F MR9=0x1F MR10=0x1F MR11=0x1F MR12=0x1F MR13=0x1F MR14=0x1F MR15=0x1F MR16=0x1F CS = 1 MR0=0x58 MR1=0x58 MR2=0x58 MR3=0x58 MR4=0x3 MR5=0x1 MR6=0x5 MR7=0x0 MR8=0x1F MR9=0x1F MR10=0x1F MR11=0x1F MR12=0x1F MR13=0x1F MR14=0x1F MR15=0x1F MR16=0x1F Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=32 Size=2048MB Channel 1: LPDDR3, 800MHz CS = 0 MR0=0x58 MR1=0x58 MR2=0x58 MR3=0x58 MR4=0x2 MR5=0x1 MR6=0x5 MR7=0x0 MR8=0x1F MR9=0x1F MR10=0x1F MR11=0x1F MR12=0x1F MR13=0x1F MR14=0x1F MR15=0x1F MR16=0x1F CS = 1 MR0=0x58 MR1=0x58 MR2=0x58 MR3=0x58 MR4=0x3 MR5=0x1 MR6=0x5 MR7=0x0 MR8=0x1F MR9=0x1F MR10=0x1F MR11=0x1F MR12=0x1F MR13=0x1F MR14=0x1F MR15=0x1F MR16=0x1F Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=32 Size=2048MB 256B stride ch 0 ddrconfig = 0x101, ddrsize = 0x2020 ch 1 ddrconfig = 0x101, ddrsize = 0x2020 pmugrf_os_reg[2] = 0x3AA0DAA0, stride = 0xD OUT Boot1: 2019-03-14, version: 1.19 CPUId = 0x0 ChipType = 0x10, 245 SdmmcInit=2 0 BootCapSize=100000 UserCapSize=14910MB FwPartOffset=2000 , 100000 mmc0:cmd8,20 mmc0:cmd5,20 mmc0:cmd55,20 mmc0:cmd1,20 mmc0:cmd8,20 mmc0:cmd5,20 mmc0:cmd55,20 mmc0:cmd1,20 mmc0:cmd8,20 mmc0:cmd5,20 mmc0:cmd55,20 mmc0:cmd1,20 SdmmcInit=0 1 StorageInit ok = 66981 SecureMode = 0 SecureInit read PBA: 0x4 SecureInit read PBA: 0x404 SecureInit read PBA: 0x804 SecureInit read PBA: 0xc04 SecureInit read PBA: 0x1004 SecureInit read PBA: 0x1404 SecureInit read PBA: 0x1804 SecureInit read PBA: 0x1c04 SecureInit ret = 0, SecureMode = 0 atags_set_bootdev: ret:(0) GPT 0x3380ec0 signature is wrong recovery gpt... GPT 0x3380ec0 signature is wrong recovery gpt fail! LoadTrust Addr:0x4000 No find bl30.bin No find bl32.bin Load uboot, ReadLba = 2000 Load OK, addr=0x200000, size=0xa66c0 RunBL31 0x40000 NOTICE: BL31: v1.3(debug):42583b6 NOTICE: BL31: Built : 07:55:13, Oct 15 2019 NOTICE: BL31: Rockchip release version: v1.1 INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3 INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 0 INFO: plat_rockchip_pmu_init(1190): pd status 3e INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2020.04-armbian (Jun 28 2020 - 18:10:11 +0000) SoC: Rockchip rk3399 Reset cause: POR Model: FriendlyElec NanoPC-T4 DRAM: 3.9 GiB PMIC: RK808 MMC: dwmmc@fe310000: 2, dwmmc@fe320000: 1, sdhci@fe330000: 0 Loading Environment from MMC... *** Warning - bad CRC, using default environment In: serial@ff1a0000 Out: serial@ff1a0000 Err: serial@ff1a0000 Model: FriendlyElec NanoPC-T4 Net: eth0: ethernet@fe300000 Hit any key to stop autoboot: 0 Card did not respond to voltage select! switch to partitions #0, OK mmc0(part 0) is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3185 bytes read in 18 ms (171.9 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 0 166 bytes read in 15 ms (10.7 KiB/s) 14741002 bytes read in 1421 ms (9.9 MiB/s) 21914112 bytes read in 2097 ms (10 MiB/s) 74693 bytes read in 40 ms (1.8 MiB/s) 2698 bytes read in 40 ms (65.4 KiB/s) Applying kernel provided DT fixup script (rockchip-fixup.scr) ## Executing script at 09000000 ## Loading init Ramdisk from Legacy Image at 06000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 14740938 Bytes = 14.1 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 01f00000 Booting using the fdt blob at 0x1f00000 Loading Ramdisk to f5113000, end f5f21dca ... OK Loading Device Tree to 00000000f5098000, end 00000000f5112fff ... OK Starting kernel ... [ 7.289300] OF: graph: no port node found in /i2c@ff3d0000/typec-portc@22 [ 7.324967] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4356-sdio for chip BCM4356/2 [ 10.373166] brcmfmac: brcmf_sdio_readshared: invalid sdpcm_shared address 0xFE8B0174 [ 10.374996] brcmfmac: brcmf_sdio_readshared: unable to obtain sdpcm_shared info: rv=-22 (addr=0xfe8b0174) Armbian 20.05.7 Focal ttyS2 nanopct4 login:
jock Posted May 19, 2021 Posted May 19, 2021 I don't have a NanoPI T4, but surely adding verbosity=7 to /boot/armbianEnv.txt file will provide the full kernel log that may provide some hints. Use a spoiler section (the eye in the toolbar) to post the dmesg log to avoid lengthy posts that are difficult to read on phones.
