October 11Oct 11 @Opcode_0xFF What is your box model and chipset? Since these boxes have similar outlook with different components, we need the details that I have asked in the first sentence will be useful to help you.
October 11Oct 11 @sr4armbian i use x88 pro 20 rk3566. board X88PRO-RK3566-4D32-V1.0 I have run upgrade_tool, but it still cant load armbian inside my Sdcard..
October 12Oct 12 @Opcode_0xFF You can restore your box compatible firmware from here. You have to download the file X88_PRO_20_RK3566_11.0_20211122_img.zip and flash your box directly USB to USB cable. Once you have recovered the box which you may continue with the steps given by @Ovaday to make it work with Armbian. Note: The firmware image you are downloading will have have malwares in them. so if possible block the outside access to the box untill you are flashing with your own image.
