Lelo Posted May 31, 2021 Posted May 31, 2021 Hello. After my provider (Unitymedia/Vodafone NRW/Germany) asked to run a complete new station search my installation stopped working for me:Stations were missing, EPG-infos not displayed anymore. So I decided to make a hole new installation. The DVB-USB stick was detected fine again (see picture), the configuration wizard is executed step by step, the scan process starts - but stays at 89%, even after 3 hours (see picture). If I stop ithe process, several stations are missing, the EPG-info is missing in wide parts of the stations and the EPG-search is not working at all.. Hardware: - BananapiPro (1GB, LAN 1GBit, SATA with 128GB SDD) - ASTROMETA DVB-T2 (RTL2832) Software: Armbian_20.02.1_Bananapipro_bionic_current_5.4.20 (oldest listed in Archive) ---> sudo apt-add-repository ppa:mamarley/tvheadend-git ---> sudo apt update && sudo apt install tvheadend ---> Successfully installed "HTS Tvheadend 4.3.0~pre+202105051438-0~built202105060457~git637844055~ubuntu18.04.1" A hardware defect seems to me excluded, since the stick works fine under Windows 10 (with AltDVB v2.4_B5488 and DVBViewer Pro 7.1.0.0 each 472 channels, station search took ~15 Minutes). I look forward to the decisive hint from you to solve my problem. Cheers, Lelo. PS:Unfortunately, I can not successfully register in the forum of TvHeadend: - I got an Activation-mail, clicked on it, entered User & PW ---> Allegedly wrong. - Request PW reset, followed the link, entered a new PQ twice successfully ---> User or PW allegedly wrong. ---> Does anyone know who and how to contact for such problems?
thc013 Posted June 5, 2021 Posted June 5, 2021 yeah the admin of that forum and you got 423 channels and tvheadend is fun there is a wiki a manual and a lot of info how it works the wizard is just to get it working , and then you have to tune it to your desires map the services to channels has the option check mux changes to be enabled or not etc,etc and epg is not that fast and works when you have it setup . just check what the mux is to start to scan to get a mux list , is the provider id right ,is there a encryption involved , etc etc
