MichaGue Posted August 14, 2015 Posted August 14, 2015 Hi Igor, hi all, I use a BPi M1 and today I tested Igor's debian wheezy 4.1.2 image. It works really great. Thanks a lot. As mentioned in the FAQ I had a look at /etc/init.d/cpufrequtils. As written there it is possible to change the frequencies. The possible values are stored in "scaling_available_frequencies". The default value for "max_speed" in Igor's image is "max_speed=1010000". But this value ist not available inside "scaling_available_frequencies". "cpufreq-info -m" tells the current policy: frequency shoukd be within 480-960 MHz. 960 MHz is the maximum value in "scaling_available_frequencies". Normally BPi is able to run at 1008 MHz. How can I change the values inside "scaling_available_frequencies"? Is there a reason why the govenor "interactive" ist choosen? Thanks a lot. Best regards, Michael
MichaGue Posted August 14, 2015 Author Posted August 14, 2015 I found the answer for my question: http://www.lemaker.org/thread-15543-1-1.html Thanks a lot. 1
