here I want to report Armbian_20.10_Arm-64_focal_current_5.9.0_desktop boots and run on a Beelink Mini MX S905,1gb, 8gb rom, using meson-gxbb-p200.dtb
The wlan, an external usb hub, a usb Keyboard and a mouse work as expected, but the lan appears disabled and a recursing error message is reported. Also the bluetooth is not working.
Despite that and of the low amount of ram, the system runs surprisingly smoothly if you avoid opening heavy applications ( even firefox can run, but opening a second windowd can freeze the box).
I've also been able to install Arduino-IDE and it works, the driver for CH340 nano compatible board are already installed, and I've been able to load a few test sketches.
I hope that can help other owner of this old little jewel.
BTW if any of the many user of this forum, much more expert than a naive newbie than myself, has some suggestion about how to face and solve the lan adthe bluetooth problems, it will be absolutely appreciated
