w985 Posted August 7, 2021 Posted August 7, 2021 Hi everyone. tell me: I'm making a print server for the hp designjet t520 printer based on armbian and orange pi pc2. data transmission over a wi-fi network (railink 7600u). there are some problems: no ppd driver for this printer, usb-ip, ipp-everywhere, hp pcl6 do not work. the printer, even after upgrade firmware, does not understand data transfer via usb, only rj45. cups, hp lip does not understand the printer. in the windows settings of the printer for the print server set-generic network card, hp jet direct-data transfer is in progress, only when microsoft color publisher printer is selected, the printer transfers a file with normal weight, but there is a limitation of the sheet size to A3. I try used rpt port forwarding idea, but it didn’t work. Have any universal methods / protocols for communicating printers on linux and windows computers? how to set up a computer trick on a print server with linux in windows? Does someone have the same, but successful examples with other mini-PCs on linux (orange pi, raspberry, odroid) or similar?
xwiggen Posted September 27, 2021 Posted September 27, 2021 Try the T120 driver, there's no Linux support for the T520.
