[SOLVED ... I think ...] How do I 100% uninstall lightdm and xfce4 so I can reinstall as new? . . . . before I go unnaturally bald!
EDIT:  SOLVED, I think. I installed gdm3 then performed a full firmware upgrade from armbian-config.  Performed a reboot and now I have an X desktop over RDP.  It's working.  I wonder if I cheated and lightdm is still broken and using gdm3 is simply a cheats way out.  Why would lightdm not work would still be interesting investigating.
I do not know if this is a bug or something I've done, but I can not get the xfce4 desktop environment running over the RDP and was wondering . . .
1) Does someone know how to diagnose this problem and fix it?   ... OR ...
2) How do I rip out the problem software and all other files so I can try and install from like-new?
Installing xfce4 and xrdp on a now (rest in peace) original version 1 Rasberry Pi B want without a hitch.  Installed xrdp, then installed xfce4, made it the default desktop environment and it worked.  This was to replace the Raspian desktop which was choking the original Pi. Well...  It did just have 256Mb RAM in absolute total.   This BananaPi Pro has 1Gb.  More wiggle room.
If anyone wishes to help me figure this one out then this thread may end up being a useful resource for anyone else in this or similar situation.
xrdp seems to be working.  It will time out, give me the connection log, goes back to the login box within the RDP session and when I click on cancel, the Remote Desktop client quits.  I genuinely do not know where the problem lies and how to effectively diagnose this.
armbianmonitor -u: http://ix.io/3yYw
myron@loki:/var/log$ tail -n 100 Xorg.0.log
[  1633.369] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[  1633.373] (II) xfree86: Adding drm device (/dev/dri/card0)
[  1633.374] (II) no primary bus or device found
[  1633.374]    falling back to /sys/devices/platform/soc/1c40000.gpu/drm/card0
[  1633.374] (II) LoadModule: "glx"
[  1633.376] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[  1633.383] (II) Module glx: vendor="X.Org Foundation"
[  1633.383]    compiled for 1.20.11, module version = 1.0.0
[  1633.383]    ABI class: X.Org Server Extension, version 10.0
[  1633.383] (==) Matched modesetting as autoconfigured driver 0
[  1633.383] (==) Matched fbdev as autoconfigured driver 1
[  1633.383] (==) Assigned the driver to the xf86ConfigLayout
[  1633.383] (II) LoadModule: "modesetting"
[  1633.384] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[  1633.385] (II) Module modesetting: vendor="X.Org Foundation"
[  1633.385]    compiled for 1.20.11, module version = 1.20.11
[  1633.386]    Module class: X.Org Video Driver
[  1633.386]    ABI class: X.Org Video Driver, version 24.1
[  1633.386] (II) LoadModule: "fbdev"
[  1633.386] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[  1633.387] (II) Module fbdev: vendor="X.Org Foundation"
[  1633.387]    compiled for 1.20.1, module version = 0.5.0
[  1633.387]    Module class: X.Org Video Driver
[  1633.387]    ABI class: X.Org Video Driver, version 24.0
[  1633.388] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[  1633.388] (II) FBDEV: driver for framebuffer: fbdev
[  1633.389] (WW) Falling back to old probe method for modesetting
[  1633.390] (WW) Falling back to old probe method for fbdev
[  1633.390] (II) Loading sub module "fbdevhw"
[  1633.390] (II) LoadModule: "fbdevhw"
[  1633.391] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[  1633.392] (II) Module fbdevhw: vendor="X.Org Foundation"
[  1633.392]    compiled for 1.20.11, module version = 0.0.2
[  1633.392]    ABI class: X.Org Video Driver, version 24.1
[  1633.392] (EE) open /dev/fb0: No such file or directory
[  1633.393] (WW) Falling back to old probe method for modesetting
[  1633.394] (WW) Falling back to old probe method for fbdev
[  1633.394] (II) Loading sub module "fbdevhw"
[  1633.394] (II) LoadModule: "fbdevhw"
[  1633.395] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[  1633.395] (II) Module fbdevhw: vendor="X.Org Foundation"
[  1633.395]    compiled for 1.20.11, module version = 0.0.2
[  1633.395]    ABI class: X.Org Video Driver, version 24.1
[  1633.396] (EE) open /dev/fb0: No such file or directory
[  1633.396] (EE) No devices detected.
[  1633.396] (==) Matched modesetting as autoconfigured driver 0
[  1633.396] (==) Matched fbdev as autoconfigured driver 1
[  1633.397] (==) Assigned the driver to the xf86ConfigLayout
[  1633.397] (II) LoadModule: "modesetting"
[  1633.397] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[  1633.398] (II) Module modesetting: vendor="X.Org Foundation"
[  1633.398]    compiled for 1.20.11, module version = 1.20.11
[  1633.398]    Module class: X.Org Video Driver
[  1633.398]    ABI class: X.Org Video Driver, version 24.1
[  1633.398] (II) UnloadModule: "modesetting"
[  1633.398] (II) Unloading modesetting
[  1633.398] (II) Failed to load module "modesetting" (already loaded, 0)
[  1633.398] (II) LoadModule: "fbdev"
[  1633.399] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[  1633.399] (II) Module fbdev: vendor="X.Org Foundation"
[  1633.399]    compiled for 1.20.1, module version = 0.5.0
[  1633.399]    Module class: X.Org Video Driver
[  1633.399]    ABI class: X.Org Video Driver, version 24.0
[  1633.399] (II) UnloadModule: "fbdev"
[  1633.399] (II) Unloading fbdev
[  1633.399] (II) Failed to load module "fbdev" (already loaded, 0)
[  1633.399] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[  1633.399] (II) FBDEV: driver for framebuffer: fbdev
[  1633.399] (WW) xf86OpenConsole: setpgid failed: Operation not permitted
[  1633.400] (WW) xf86OpenConsole: setsid failed: Operation not permitted
[  1633.401] (WW) Falling back to old probe method for modesetting
[  1633.402] (WW) Falling back to old probe method for fbdev
[  1633.402] (II) Loading sub module "fbdevhw"
[  1633.402] (II) LoadModule: "fbdevhw"
[  1633.403] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[  1633.403] (II) Module fbdevhw: vendor="X.Org Foundation"
[  1633.403]    compiled for 1.20.11, module version = 0.0.2
[  1633.403]    ABI class: X.Org Video Driver, version 24.1
[  1633.403] (EE) open /dev/fb0: No such file or directory
[  1633.404] (WW) Falling back to old probe method for modesetting
[  1633.404] (WW) Falling back to old probe method for fbdev
[  1633.405] (II) Loading sub module "fbdevhw"
[  1633.405] (II) LoadModule: "fbdevhw"
[  1633.405] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[  1633.406] (II) Module fbdevhw: vendor="X.Org Foundation"
[  1633.406]    compiled for 1.20.11, module version = 0.0.2
[  1633.406]    ABI class: X.Org Video Driver, version 24.1
[  1633.406] (EE) open /dev/fb0: No such file or directory
[  1633.407] (EE) No devices detected.
[  1633.407] (EE)
Fatal server error:
[  1633.407] (EE) no screens found(EE)
[  1633.407] (EE)
Please consult the The X.Org Foundation support
         at http://wiki.x.org
 for help.
[  1633.407] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[  1633.407] (EE)
[  1633.408] (EE) Server terminated with error (1). Closing log file.
myron@loki:/var/log$ tail -n 100 xrdp.log
[20210915-15:03:28] [INFO ] Socket 12: AF_INET6 connection received from ::ffff:192.168.0.4 port 51809
[20210915-15:03:28] [DEBUG] Closed socket 12 (AF_INET6 ::ffff:192.168.0.81 port 3389)
[20210915-15:03:28] [DEBUG] Closed socket 11 (AF_INET6 :: port 3389)
[20210915-15:03:28] [INFO ] Using default X.509 certificate: /etc/xrdp/cert.pem
[20210915-15:03:28] [INFO ] Using default X.509 key file: /etc/xrdp/key.pem
[20210915-15:03:28] [ERROR] Cannot read private key file /etc/xrdp/key.pem: Permission denied
[20210915-15:03:28] [DEBUG] TLSv1.3 enabled
[20210915-15:03:28] [DEBUG] TLSv1.2 enabled
[20210915-15:03:28] [DEBUG] Security layer: requested 11, selected 0
[20210915-15:03:28] [INFO ] Socket 12: AF_INET6 connection received from ::ffff:192.168.0.4 port 51810
[20210915-15:03:28] [DEBUG] Security layer: requested 0, selected 0
[20210915-15:03:28] [INFO ] connected client computer name: VELOCIRAPTOR
[20210915-15:03:28] [INFO ] adding channel item name rdpdr chan_id 1004 flags 0x80800000
[20210915-15:03:28] [INFO ] adding channel item name rdpsnd chan_id 1005 flags 0xc0000000
[20210915-15:03:28] [INFO ] adding channel item name cliprdr chan_id 1006 flags 0xc0a00000
[20210915-15:03:28] [INFO ] adding channel item name drdynvc chan_id 1007 flags 0xc0800000
[20210915-15:03:28] [INFO ] Non-TLS connection established from ::ffff:192.168.0.4 port 51810: encrypted with standard RDP security
[20210915-15:03:29] [DEBUG] xrdp_00001a12_wm_login_mode_event_00000001
[20210915-15:03:29] [INFO ] Loading keymap file /etc/xrdp/km-00000809.ini
[20210915-15:03:29] [WARN ] local keymap file for 0x00000809 found and doesn't match built in keymap, using local keymap file
[20210915-15:03:29] [DEBUG] xrdp_wm_log_msg: connecting to sesman ip 127.0.0.1 port 3350
[20210915-15:03:29] [INFO ] xrdp_wm_log_msg: sesman connect ok
[20210915-15:03:29] [DEBUG] xrdp_wm_log_msg: sending login info to session manager, please wait...
[20210915-15:03:29] [DEBUG] return value from xrdp_mm_connect 0
[20210915-15:03:29] [INFO ] xrdp_wm_log_msg: login successful for display 10
[20210915-15:03:29] [DEBUG] xrdp_wm_log_msg: started connecting
[20210915-15:03:33] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:03:36] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:03:40] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:03:43] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:03:47] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:03:50] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:03:54] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:03:57] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:04:01] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:04:04] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:04:08] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:04:11] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:04:15] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:04:18] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:04:22] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:04:25] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:04:29] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:04:32] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:04:36] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:04:39] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:04:43] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:04:46] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:04:50] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:04:53] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:04:57] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:05:00] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:05:04] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:05:07] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:05:11] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:05:14] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:05:18] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:05:22] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:05:25] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:05:29] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:05:32] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:05:36] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:05:39] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:05:43] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:05:46] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:05:50] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:05:53] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:05:57] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:06:00] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:06:04] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:06:07] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:06:11] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:06:14] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:06:18] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:06:21] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:06:25] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:06:28] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:06:32] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:06:35] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:06:39] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:06:42] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:06:46] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:06:49] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:06:53] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:06:56] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:06:59] [DEBUG] xrdp_wm_log_msg: connection problem, giving up
[20210915-15:06:59] [DEBUG] Closed socket 17 (AF_UNIX)
[20210915-15:06:59] [DEBUG] xrdp_wm_log_msg: some problem
[20210915-15:06:59] [DEBUG] xrdp_mm_module_cleanup
[20210915-15:06:59] [DEBUG] Closed socket 16 (AF_INET6 ::1 port 45584)
[20210915-15:12:28] [DEBUG] Closed socket 12 (AF_INET6 ::ffff:192.168.0.81 port 3389)
[20210915-15:12:28] [DEBUG] xrdp_mm_module_cleanup
myron@loki:/var/log$ tail -n 100 xrdp-sesman.log
[20210915-14:05:47] [DEBUG] Closed socket 8 (AF_INET6 ::1 port 3350)
[20210915-14:05:47] [INFO ] /usr/lib/xorg/Xorg :10 -auth .Xauthority -config xrdp/xorg.conf -noreset -nolisten tcp -logfile .xorgxrdp.%s.log
[20210915-14:05:48] [CORE ] waiting for window manager (pid 3027) to exit
[20210915-14:05:48] [CORE ] window manager (pid 3027) did exit, cleaning up session
[20210915-14:05:48] [INFO ] calling auth_stop_session and auth_end from pid 3026
[20210915-14:05:48] [DEBUG] cleanup_sockets:
[20210915-14:05:48] [DEBUG] cleanup_sockets: deleting /run/xrdp/sockdir/xrdp_chansrv_socket_10
[20210915-14:05:48] [DEBUG] cleanup_sockets: deleting /run/xrdp/sockdir/xrdpapi_10
[20210915-14:05:48] [INFO ] ++ terminated session:  username myron, display :10.0, session_pid 3026, ip ::ffff:192.168.0.4:59377 - socket: 12
[20210915-14:08:55] [INFO ] A connection received from ::1 port 55490
[20210915-14:08:55] [INFO ] ++ created session (access granted): username myron, ip ::ffff:192.168.0.4:61540 - socket: 12
[20210915-14:08:55] [INFO ] starting Xorg session...
[20210915-14:08:55] [DEBUG] Closed socket 9 (AF_INET6 :: port 5910)
[20210915-14:08:55] [DEBUG] Closed socket 9 (AF_INET6 :: port 6010)
[20210915-14:08:55] [DEBUG] Closed socket 9 (AF_INET6 :: port 6210)
[20210915-14:08:55] [INFO ] calling auth_start_session from pid 3184
[20210915-14:08:55] [DEBUG] Closed socket 8 (AF_INET6 ::1 port 3350)
[20210915-14:08:56] [DEBUG] Closed socket 7 (AF_INET6 ::1 port 3350)
[20210915-14:08:56] [DEBUG] Closed socket 8 (AF_INET6 ::1 port 3350)
[20210915-14:08:56] [INFO ] /usr/lib/xorg/Xorg :10 -auth .Xauthority -config xrdp/xorg.conf -noreset -nolisten tcp -logfile .xorgxrdp.%s.log
[20210915-14:09:05] [ERROR] X server for display 10 startup timeout
[20210915-14:09:05] [CORE ] waiting for window manager (pid 3185) to exit
[20210915-14:09:06] [ERROR] X server for display 10 startup timeout
[20210915-14:09:06] [ERROR] another Xserver might already be active on display 10 - see log
[20210915-14:09:06] [DEBUG] aborting connection...
[20210915-14:09:06] [CORE ] window manager (pid 3185) did exit, cleaning up session
[20210915-14:09:06] [INFO ] calling auth_stop_session and auth_end from pid 3184
[20210915-14:09:06] [DEBUG] cleanup_sockets:
[20210915-14:09:06] [DEBUG] cleanup_sockets: deleting /run/xrdp/sockdir/xrdp_chansrv_socket_10
[20210915-14:09:06] [DEBUG] cleanup_sockets: deleting /run/xrdp/sockdir/xrdpapi_10
[20210915-14:09:06] [INFO ] ++ terminated session:  username myron, display :10.0, session_pid 3184, ip ::ffff:192.168.0.4:61540 - socket: 12
[20210915-14:11:50] [INFO ] A connection received from ::1 port 55512
[20210915-14:11:51] [INFO ] ++ created session (access granted): username myron, ip ::ffff:192.168.0.4:61820 - socket: 12
[20210915-14:11:51] [INFO ] starting Xorg session...
[20210915-14:11:51] [DEBUG] Closed socket 9 (AF_INET6 :: port 5910)
[20210915-14:11:51] [DEBUG] Closed socket 9 (AF_INET6 :: port 6010)
[20210915-14:11:51] [DEBUG] Closed socket 9 (AF_INET6 :: port 6210)
[20210915-14:11:51] [DEBUG] Closed socket 8 (AF_INET6 ::1 port 3350)
[20210915-14:11:51] [INFO ] calling auth_start_session from pid 3462
[20210915-14:11:51] [DEBUG] Closed socket 7 (AF_INET6 ::1 port 3350)
[20210915-14:11:51] [INFO ] /usr/lib/xorg/Xorg :10 -auth .Xauthority -config xrdp/xorg.conf -noreset -nolisten tcp -logfile .xorgxrdp.%s.log
[20210915-14:12:01] [ERROR] X server for display 10 startup timeout
[20210915-14:12:01] [CORE ] waiting for window manager (pid 3463) to exit
[20210915-14:12:01] [ERROR] another Xserver might already be active on display 10 - see log
[20210915-14:12:01] [DEBUG] aborting connection...
[20210915-14:12:01] [CORE ] window manager (pid 3463) did exit, cleaning up session
[20210915-14:12:01] [INFO ] calling auth_stop_session and auth_end from pid 3462
[20210915-14:12:01] [DEBUG] cleanup_sockets:
[20210915-14:12:01] [DEBUG] cleanup_sockets: deleting /run/xrdp/sockdir/xrdp_chansrv_socket_10
[20210915-14:12:01] [DEBUG] cleanup_sockets: deleting /run/xrdp/sockdir/xrdpapi_10
[20210915-14:12:01] [INFO ] ++ terminated session:  username myron, display :10.0, session_pid 3462, ip ::ffff:192.168.0.4:61820 - socket: 12
[20210915-14:13:32] [INFO ] A connection received from ::1 port 55526
[20210915-14:13:33] [INFO ] ++ created session (access granted): username myron, ip ::ffff:192.168.0.4:61962 - socket: 12
[20210915-14:13:33] [INFO ] starting Xorg session...
[20210915-14:13:33] [DEBUG] Closed socket 9 (AF_INET6 :: port 5910)
[20210915-14:13:33] [DEBUG] Closed socket 9 (AF_INET6 :: port 6010)
[20210915-14:13:33] [DEBUG] Closed socket 9 (AF_INET6 :: port 6210)
[20210915-14:13:33] [DEBUG] Closed socket 8 (AF_INET6 ::1 port 3350)
[20210915-14:13:33] [INFO ] calling auth_start_session from pid 3535
[20210915-14:13:33] [DEBUG] Closed socket 7 (AF_INET6 ::1 port 3350)
[20210915-14:13:33] [INFO ] /usr/lib/xorg/Xorg :10 -auth .Xauthority -config xrdp/xorg.conf -noreset -nolisten tcp -logfile .xorgxrdp.%s.log
[20210915-14:13:43] [ERROR] X server for display 10 startup timeout
[20210915-14:13:43] [CORE ] waiting for window manager (pid 3536) to exit
[20210915-14:13:43] [ERROR] another Xserver might already be active on display 10 - see log
[20210915-14:13:43] [DEBUG] aborting connection...
[20210915-14:13:43] [CORE ] window manager (pid 3536) did exit, cleaning up session
[20210915-14:13:43] [INFO ] calling auth_stop_session and auth_end from pid 3535
[20210915-14:13:43] [DEBUG] cleanup_sockets:
[20210915-14:13:43] [DEBUG] cleanup_sockets: deleting /run/xrdp/sockdir/xrdp_chansrv_socket_10
[20210915-14:13:43] [DEBUG] cleanup_sockets: deleting /run/xrdp/sockdir/xrdpapi_10
[20210915-14:13:43] [INFO ] ++ terminated session:  username myron, display :10.0, session_pid 3535, ip ::ffff:192.168.0.4:61962 - socket: 12
[20210915-14:14:04] [INFO ] shutting down sesman 1
[20210915-14:14:04] [DEBUG] Closed socket 7 (AF_INET6 ::1 port 3350)
[20210915-14:14:51] [DEBUG] libscp initialized
[20210915-14:14:51] [DEBUG] Testing if xrdp-sesman can listen on 127.0.0.1 port 3350.
[20210915-14:14:51] [DEBUG] Closed socket 5 (AF_INET6 ::1 port 3350)
[20210915-14:14:51] [INFO ] starting xrdp-sesman with pid 1382
[20210915-14:14:51] [INFO ] listening to port 3350 on 127.0.0.1
[20210915-15:03:29] [INFO ] A connection received from ::1 port 45584
[20210915-15:03:29] [INFO ] ++ created session (access granted): username myron, ip ::ffff:192.168.0.4:51810 - socket: 12
[20210915-15:03:29] [INFO ] starting Xorg session...
[20210915-15:03:29] [DEBUG] Closed socket 9 (AF_INET6 :: port 5910)
[20210915-15:03:29] [DEBUG] Closed socket 9 (AF_INET6 :: port 6010)
[20210915-15:03:29] [DEBUG] Closed socket 9 (AF_INET6 :: port 6210)
[20210915-15:03:29] [DEBUG] Closed socket 8 (AF_INET6 ::1 port 3350)
[20210915-15:03:29] [INFO ] calling auth_start_session from pid 6676
[20210915-15:03:29] [DEBUG] Closed socket 7 (AF_INET6 ::1 port 3350)
[20210915-15:03:29] [INFO ] /usr/lib/xorg/Xorg :10 -auth .Xauthority -config xrdp/xorg.conf -noreset -nolisten tcp -logfile .xorgxrdp.%s.log
[20210915-15:03:29] [CORE ] waiting for window manager (pid 6677) to exit
[20210915-15:03:31] [CORE ] window manager (pid 6677) did exit, cleaning up session
[20210915-15:03:31] [INFO ] calling auth_stop_session and auth_end from pid 6676
[20210915-15:03:31] [DEBUG] cleanup_sockets:
[20210915-15:03:31] [DEBUG] cleanup_sockets: deleting /run/xrdp/sockdir/xrdp_chansrv_socket_10
[20210915-15:03:31] [DEBUG] cleanup_sockets: deleting /run/xrdp/sockdir/xrdpapi_10
[20210915-15:03:31] [INFO ] ++ terminated session:  username myron, display :10.0, session_pid 6676, ip ::ffff:192.168.0.4:51810 - socket: 12
lightdm is also failing to start.
Is there any other additional information needed from me?
  • Myron changed the title to [SOLVED ... I think ...] How do I 100% uninstall lightdm and xfce4 so I can reinstall as new? . . . . before I go unnaturally bald!
